Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2319 Cmd Rej: New class name cannot be the same as an existing class name
The value specified for the nclass parameter cannot be the same as an existing class name.
Recovery
  1. Display a list of valid command class names. Enter the rtrv-cmdclass command.
  2. Re-enter the chg-cmdclass command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - System Management User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
