Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2086 Cmd Rej: GTT must be turned ON for A-Port
The GTT feature must be turned on before the A-Port feature can be enabled.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.
Recovery
  1. Determine the status of the GTT feature. Enter the rtrv-feat command.
  2. If necessary, turn on the GTT feature. Refer to the Database Administration - GTT User's Guide for assistance.
  3. Re-enter the enable-ctrl-feat command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
