Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2588 Cmd Rej: Connection Name already exists
For the ent-dconn command, a unique DCNAME must be specified for a new connection.
For the ent-ip-conn command, the CNAME connection should be unique for every new connection.
Recovery - ent-dconn
  1. Enter the rtrv-dconn command to display the diameter connection name in the database.
  2. Re-enter the ent-dconn command with a new diameter connection name. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this message appears again. See My Oracle Support (MOS).
Recovery - ent-ip-conn
  1. Enter the rtrv-ip-conn command to display the connection name in the database.
  2. Re-enter the ent-ip-conn command to enter a new connection name. Refer to the command description in Commands User's Guide for assistance.
