| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The value specified for the spc parameter must already be defined in the SPC table.
If the point code specified by the spc parameter is valid and the linkset type specified by the lst parameter is not prx, then the SPC point code must exist in the SPC table.
Recovery
