Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2837 Cmd Rej: NCR must be enabled to enter NCAI param
The Nested Cluster Routing (NCR) feature must be turned on before the ncai parameter can be specified.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.
Recovery
  1. Display the status of the NCR feature. Enter the rtrv-feat command.
  2. Turn on the NCR feature as necessary. Refer to the Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
