Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3697 Cmd Rej: 15-minute measurement feature must be ON
The 15 Minute Measurements feature must be turned on before the collect15min=on parameter can be specified.
Recovery
  1. Display the status of the 15 Minute Measurements feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Enable and turn on the 15 Minute Measurements feature as necessary. Refer to the Commands User's Guide and the Database Administration - System Management User's Guide for assistance.
  3. Re-enter the chg-measopts command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
