Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2993 Cmd Rej: True Point Code must remain primary entity
The true point code in the MAPGROUP must be and remain the primary PC/SSN for that MAPGROUP. The RC value of the pc parameter cannot be changed nor can a new point code be added to the MAPGROUP, which would result in the true point code no longer being the primary PC/SSN of the MAPGROUP.
Recovery
  1. Display the entities in the load sharing group.
    Enter the rtrv-map command.
  2. Re-enter the chg-map command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to Database Administration - GTT User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
