| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
To delete all subsystem numbers for a given point code, the all=yes parameter must be specified.
Recovery
Re-enter the dlt-map command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
