Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2658 Cmd Rej: LHOST and LPORT combination already has connection
For the ent-ip-conn command, duplicate LHOST, RHOST, LPORT and RPORT entry combination is not allowed with PROT=TCP or PROT=UDP with RHOST, RPORT specified.
Recovery
  1. For the rtrv-ip-conn command to display the outputs of LHOST and LPORT parameters specified in the system.
  2. Refer to the command description in Commands User's Guide and Database Administration - Features User's Guide for assistance. Re-enter the command that generated this error message, specifying a valid combination.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
