| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
If a value from 1 - 16 is specified for the trm parmaeter, then the type=telnet parameter cannot be specified.
Recovery
Re-enter the chg-trm command that generated this error message specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - System Management User's Guide for assistance.
