Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3427 Cmd Rej: ITU PC parameters are invalid for ANSI cards
A valid parameter combination must be entered for the card type and GPL. Refer to the command description for the ent-trace command in the Commands User's Guide for a discussion of the valid parameters.
Recovery
  1. Display the card types. Enter the rtrv-card command.
  2. Display the GPLs running on the card. Enter the rtrv-gpl command.
  3. Re-enter the ent-trace command that generated this error message, specifying a valid combination of parameters.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
