| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to configure the unauthorized use warning message that is displayed after a user successfully logs into the EAGLE.
These parameters are used in this procedure.
:wrnln – the line number of the text of the unauthorized use warning message. The unauthorized use warning message can contain from 1 to 20 lines of text.
:wrntx – the text of the line number of the unauthorized use warning message. The each line of text can contain up to 70 alphanumeric characters and must be enclosed in quotes (“). A blank line is specified with this text string, “ “, the blank space character enclosed in double quotes.
:clrwrntx - This parameter specifies whether or not the text of the warning message is removed and will not be displayed. This parameter has three values.no - the text of a specific line in the warning message is not removed.yes - the text of a specific line in the warning message is removed and will not be displayed.all - the text in all the lines of the warning message are removed and no warning message will be displayed.The clrwrntx=yes parameter can be specified only with the wrnln parameter.
The chg-secu-dflt command contains other parameters that are not used in this procedure. These parameters are used to change the user ID and password security defaults on the EAGLE. To change the user ID and password security defaults, perform the Changing the Security Defaults procedure.
When the EAGLE is delivered to the user, the database will contain this login warning message.NOTICE: This is a private computer system. Unauthorized access or use may lead to prosecution.
The example in this procedure is used to change the unauthorized use warning message from the system default message to this message.
************************************************************ * NOTICE: This is a private computer system. * * UNAUTHORIZED ACCESS OR USE WILL BE PROSECUTED * * * * * * 03/17/08 Notice!!! System will be upgraded between * * the hours of 2am-3am on 04/01/08 * * * * * ************************************************************
The rtrv-secu-dflt command uses the msg parameter to specify whether the unauthorized use warning message text is displayed in the command output. The msg parameter has two values.
yes – the unauthorized use warning message text is displayed.
no – the unauthorized use warning message text is not displayed.
The default value for this parameter is no.
Regardless of the value specified for the msg parameter, the user ID and password security defaults are displayed in the rtrv-secu-dflt command output.
Figure 4-3 Configuring the Unauthorized Use Warning Message
