| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to remove an FTP server from the database using the dlt-ftp-serv command.
The dlt-ftp-serv command uses these parameters.
:app – The application of the FTP server. There are four values for the app parameter:
meas – The FTP servers for the Measurements Platformuser – The FTP servers for the FTP Retrieve and Replace feature.db - The FTP server for the database backup/restore application.dist - the FTP server for the EAGLE software release distribution application.:ipaddr – The IP address of the FTP server.
Caution:
Removing all FTP servers for an application will disable the feature supported by the FTP servers.Figure 4-24 Removing an FTP Server
