| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to turn off the HIPR2 High Rate Mode feature, using the chg-ctrl-feat command.
Caution:
The HIPR2 High Rate Mode feature cannot be turned off if any of these conditions are present.init-flash command.The chg-ctrl-feat command uses the following parameters:
:partnum - The part number of the HIPR2 High Rate Mode feature, 893020101.
:status=off – used to turn off the HIPR2 High Rate Mode feature.
The status of the HIPR2 High Rate Mode feature must be on and is shown with the rtrv-ctrl-feat command.
Caution:
If the HIPR2 High Rate Mode feature is turned off, the throughput rate for the IMT bus is limited to 1 Gbps.Figure A-7 Turning Off the HIPR2 High Rate Mode Feature
