| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
The backup procedures should be performed according to the preventive maintenance procedures in Chapter 2, “Preventive Maintenance,” of Maintenance Guide. The procedures copy the current database to either the inactive (backup) partition on the fixed disk or to the removable media. To backup a database, the chg-db command uses these parameters.
:action=backup – the operation to perform on the database, a backup of the current database
dest – the destination of the backup operation.fixed – the backup partition of the fixed disk.remove – the removable media for E5-based control cards installed in the EAGLE.The database can also be backed up to the FTP server. Perform the procedure Making a Backup of the Database to the FTP Server to backup the database to the FTP server.
