Multi Bank Cash Concentration (MBCC) are automated cash management systems for corporations with at-least one third party bank account.
It is an automated means of centralizing balances held at third-party banks of the corporate (In this process liquidity is either transferred to the various TPB accounts or Liquidity is pulled out of various TPB accounts)
It caters to the corporate need to maintain important third-party local bank relationships for rendering truly localized services while optimizing the potential yield from liquidity consolidated with a global concentration bank
The benefit of MBCC can be listed as below:
The following features are provided for MBCC in LM:
This following steps lists out the sweep mechanism through MT920 requests:
The steps followed for sweep in are as below:
While generating MT101 request for funds, system will take in to consideration the sweep parameters set at the other bank (can be own bank or third party bank) to arrive at the amount. In some cases there can be combination of these parameters at work.
MT |
MT Message |
Purpose |
920 |
Request Message |
Requests the account servicing institution to send an MT 940, 941, 942 or 950 |
940 |
Customer Statement Message |
Provides balance and transaction details of an account to a FI on behalf of the account owner |
941 |
Balance Report |
Provides balance information of an account to a financial institution on behalf of the account owner |
942 |
Interim Transaction Report |
Provides balance and transaction details of an account, for a specified period of time, to a financial institution on behalf of an account owner It is used to transmit detailed and/or summary information about entries debited or credited to the account since: • The last statement or balance report, or • The last interim transaction report (sent in the period since the last statement or balance report). |
950 |
Statement Message |
Provides balance and transaction details of an account to the account owner |
The following maintenance screens has to be configured to set up multi bank cash concentration structure:
Allow multiple bank, Allow cross-border transaction and Allow cross-currency transaction options must be enabled at system level maintenance screen to allow bank to provide this feature.
System ID
Specify the unique system ID. This is usually a back-end upload.
Release Number
Specify the LM release number. This is usually a back-end upload.
Instance Name
Specify the name of the LM instance. This is usually a back-end upload
Instance Description
Specify a description if any for the instance. This is usually a back-end upload
Instance Host Country
Select the ISO code of the country in which the instance has been installed from the drop down list.
Region
Select the region in which the instance is installed from the drop down list.
Multiple Bank Cash Concentration .
Check this box to allow set up of Multi Bank Cash Concentration Liquidity Structures.
Allow Account In Multiple Structure
Check this box to allow account in Multiple Structure
Products
Select the type of products allowed in the structure. The options are: Physical Sweeping - Check this box to allow only sweep structures in the system Notional Pooling - Check this box to allow only pooling structures in the system
Sweep
Check this box to select domestic/cross border/cross currency in liquidity structures.
Domestic Sweep
Check this box to allow Domestic pairs in sweep liquidity structures.
Cross Border Sweep
Check this box to allow cross border pairs in sweep liquidity structures.
Cross Currency Sweep
Check this box to allow cross currency structures in sweep Liquidity Structures.
Pool
Cross Border Pool
Check this box to allow cross border pairs in pool liquidity structures.
Domestic Pool
Check this box to allow Domestic pairs in pool liquidity structures.
Cross Currency Pool
Check this box to allow cross currency structures in pool Liquidity Structures.
Hybrid
Cross Border Pool Hybrid
Check this box to allow cross border hybrid pairs in pool liquidity structures.
Domestic Pool Hybrid
Check this box to allow Domestic hybrid pairs in pool liquidity structures.
Cross Border Sweep Hybrid
Check this box to allow cross border hybrid pairs in sweep liquidity structures.
Domestic Sweep Hybrid
Check this box to allow Domestic hybrid pairs in sweep liquidity structures.
Cross Currency Pool Hybrid
Check this box to allow cross currency hybrid structures in pool Liquidity Structures.
Cross Currency Sweep Hybrid
Check this box to allow cross currency hybrid structures in sweep Liquidity Structures.
Action When Account Is Blocked / Insufficient Funds
Indicate the action to be taken by the system when an account in the structure is blocked. You can select one the following options:
Skip Account Pair - Skip the account pair and continue with the rest of the structure
Skip Whole Structure - Skip the whole structure
Parameter
Specify any custom parameters specific to the instance. Click '+' to add a row and specify the Parameter, Value and Description of the same.Click '-' to remove a row.
The regulatory system must allow corporate to set-up MBCC in the country where liquidity management instance is running.
While defining a MBCC group the system will validate whether multiple bank facility is allowed in particular country
Country Code
Specify the country code of the country for which the compliance is to be set. You can select the relevant country code from the option list. The list displays all the country codes maintained in the system
Country Name
Specify the name of the country.
Currency Code
Input the base currency
Resident Type
Select the account type allowed in the country from the drop down list. The options are:
Resident
Non Resident
Both
Not Applicable.
IE Participation
Check this box to allow the accounts in Interest Enhancement Structure.
IE Benefit
Sweep
Check this box to select domestic/cross border/cross currency sweep account pairs in the country.
Domestic Sweep
Check this box to allow domestic sweep for the accounts in the country.
Cross Border Sweep
Check this box to allow cross border sweep for the accounts in the country.
Check this box to allow cross currency account pairs in the country.
Pool
Check this box to select domestic/cross border/cross currency pool account pairs in the country.
Cross Border Pool
Check this box to allow cross border pool for the accounts in the country.
Cross Currency Pool
Check this box to allow cross currency pool for the accounts in the country.
Domestic Pool
Check this box to allow domestic pool for the accounts in the country.
Hybrid
Check this box to select domestic/cross border/cross currency hybrid account pairs in the country.
Domestic Hybrid Sweep
Check this box to allow domestic hybrid sweep for the accounts in the country.
Cross Border Hybrid Sweep
Check this box to allow cross border hybrid sweep for the accounts in the country.
Cross Currency Hybrid Sweep
Check this box to allow cross currency hybrid sweep account pairs in the country.
Check this box to allow domestic hybrid pool for the accounts in the country.
Check this box to allow cross border hybrid pool for the accounts in the country.
Check this box to allow cross Currency hybrid pools for the accounts in the country.
Click ‘Bank Maintenance’ link in Setup screen to define Bank details
Bank Code
Specify the bank code. You can select the bank code from the option list.
Bank Name
The system displays the bank name based on the selected bank code.
Bank Type
Select the bank type as ‘Internal’ or ‘External’ from the drop down list.
Check this box if the selected banks is to participate in MBCC. If the Bank is internal and this box is selected, it means that the host bank supports MBCC. If the Bank is external and this box is selected, it means that the host bank can create MBCC structures involving these banks
BVT Allowed
Check this box if selected banks allow BVT.
Sweep
Check this box to select domestic/cross border/cross currency sweep account pairs in the Bank.
Domestic Sweep
Check this box to allow domestic sweep for the accounts in the Bank.
Cross Border Sweep
Check this box to allow cross border sweep for the accounts in the Bank.
Check this box to allow cross currency account pairs in the Bank.
Pool
Check this box to select domestic/cross border/cross currency pool account pairs in the Bank.
Cross Border Pool
Check this box to allow cross border pool for the accounts in the Bank.
Cross Currency Pool
Check this box to allow cross currency pool for the accounts in the Bank.
Domestic Pool
Check this box to allow domestic pool for the accounts in the Bank.
Hybrid
Check this box to select domestic/cross border/cross currency hybrid account pairs in the Bank.
Check this box to allow domestic hybrid sweep for the accounts in the Bank.
Check this box to allow cross border hybrid sweep for the accounts in the Bank.
Check this box to allow cross currency hybrid sweep account pairs in the Bank.
Check this box to allow domestic hybrid pool for the accounts in the Bank.
Check this box to allow cross border hybrid pool for the accounts in the Bank.
Check this box to allow cross Currency hybrid pools for the accounts in the Bank.
Address
Specify the address of the bank in below fields.
Line 1
Line 2
Line 3
Line 4
Parameter
Specify additional parameters if any. Click '+' to add a row and specify the Parameter, Value of the same. Click '-' to remove a row.
Click ‘Branch Maintenance’ link in Setup screen to define Branch details for created Bank
Branch Code
Specify the branch code.
Branch Name
Specify the name of the branch.
Bank Code
Specify the bank code. You can select the bank code from the option list.The list displays all the bank codes maintained in the system.
Local Clearing Code
Specify local clearing code for the selected branch.
BIC Code
Specify BIC code relevant for the branch.
Local Currency
Select the local currency used by the branch from the drop down list.
Balance Type
Select the balance build method as online or offline
External Reference
Specify the External Reference for branch.
Sweep
Domestic Sweep
Check this box to allow domestic sweep for the accounts in the Branch.
Cross Border Sweep
Check this box to allow cross border sweep for the accounts in the Branch.
Check this box to allow cross currency account pairs in the Branch.
Pool
Check this box to select domestic/cross border/cross currency pool account pairs in the Branch.
Cross Border Pool
Check this box to allow cross border pool for the accounts in the Branch.
Cross Currency Pool
Check this box to allow cross currency pool for the accounts in the Branch.
Domestic Pool
Check this box to allow domestic pool for the accounts in the Branch.
Hybrid
Check this box to select domestic/cross border/cross currency hybrid account pairs in the Branch.
Check this box to allow domestic hybrid sweep for the accounts in the Branch.
Check this box to allow cross border hybrid sweep for the accounts in the Branch.
Check this box to allow cross currency hybrid sweep account pairs in the Branch.
Check this box to allow domestic hybrid pool for the accounts in the Branch.
Check this box to allow cross border hybrid pool for the accounts in the Branch.
Check this box to allow cross Currency hybrid pools for the accounts in the Branch.
Address
Line 1
Line 2
Line 3
Line 4
Country
Specify the Country
Region
Specify Region
Parameter
Interface Details
Specify the Interface details by selecting the System ID from System ID LOV.
You can maintain payment parameter values at bank level for all the internal and external banks participating in liquidity management structure. The values captured in this screen will be handed off to payment systems to initiate domestic or cross border sweep.
External System ID
Specify the external system ID for which the instruction is to be set. You can select the relevant external system from the option list. The list displays all the external system id maintained in the system.
Service Name
The system displays the service name for selected external system Id.
Network Type
The system displays network type for the selected external system Id.
Message Type
The system displays message type for the selected external system Id.
Service Type
The system displays Service type for the selected external system Id.
Name
Specify the interface parameter name for interface instruction.
Value
Specify the interface parameter value for interface instruction.
Event Code
Specify the event code for interface instruction.
Event Description
Specify the event description for interface instruction.
Parameter Name
Specify the parameter name.
Parameter Value
Specify the parameter value.Dynamic values are entered as #.
Branch level & Currency level cut off are maintained in here. If the message arrives after the cut-off time, balance will not be considered for upcoming sweep schedule.
Exception messages will be logged separately
BIC Code
Select the BIC Code of the branch for which currency cutoffs are to be maintained
Currency
Specify the currency for which the cut off time is to be set. You can select the currency from the option list. The list displays all the currencies maintained in the system
MessageType
Specify the message type to be associated with the currency.You can select the message type from the option list. The list displays all the message type maintained in the system
IncomingCutOfTime
Specify the incoming cut off time for the currency.
OutgoingCutOffTime
Specify the outgoing cut off time for the currency
