Multiple structures have to be created within a framework to add accounts to allow sweeps/notional pooling. Structure maintenance allows you to do the following:
System allows you to add as many accounts and as many hierarchies as required.It also enables hybrid structures, where both pool and sweep can be configured.Hybrid structures are basically pool over sweep structures.
You can invoke the ‘Structure Maintenance’ page by clicking on the Structure Maintenance tab in application..
Click New button to add a new structure. Specify the following details:
Structure ID
The system displays the auto generated unique structure ID.
Structure Description
Specify a description for the new structure.
Version Number
Displays the version number
MultiBank Cash Concentration
This field will get automatically selected on save if the underlying structure created has external bank accounts.
Structure Type
Specify the Structure Type from the drop down list. The option are:
Sweep
Pool
Hybrid
Cross Currency
This field will get automatically selected on save if the underlying structure is created with accounts which are in different currencies.
Customer ID
Specify the customer. You can select the customer ID from the option list. The list displays all the customer IDs maintained in the system
Customer Description
The system displays the description of the customer selected.
Cross Border
This field will get automatically selected on save if the underlying structure is created with accounts which are from two or more different countries.
Status
Indicate the status of the Structure to be maintained. The options are:
Resumed
Paused
A user should be able view the flag 'Status' at the structure level and be able to select either Paused or Resumed for a new structure or an existing structure. Default value would be “Resumed”.
Default Frequency
Specify the default frequency at which the structure should be executed. You can select the frequency from the option list. The list displays all the frequencies maintained in the system.
The frequency defined at the structure level will get defaulted to all the account pairs in the structure, but you can over ride and define a specific frequency for a specific pair of account.
This changed preference will override the global preference.
Effective Date
Specify the date from which the structure becomes effective.This date cannot be less than the system date but can be a future date.
Rate Type
Specify the rate type to be used in case the underlying structure has cross currency pairs.
End Date
Specify the date till which the structure is effective.This date should always be greater than the effective date.
EOD
Check this box to execute the structure at end of day.
Allow Sweep on Currency Holidays
Check this field to allow sweep on currency holidays.
Central Account Number
Specify the Central Account to be applied to the structure. You can select the Central account from the option list. The list displays all the accounts maintained in the system.
Central Account Branch
Displays the Central Account Branch
Central Account Currency
Displays the Central Account Currency
Rate PickUp
Specify the rate pick up for the sweeps on currency holidays from the drop down list. The option are:
Note
This field is active only if ‘Allow Sweep on Currency Holidays’ is selected.
Reverse Frequency
Specify the reverse frequency at which the reverse sweep for structure should be executed. You can select the frequency from the option list. The list displays all the frequencies maintained in the system.
Interest Method
Specify the Interest method for the structure from the drop down list. The options are:
This data needs to be captured only for Pooling Structures.
Instruction Type
Specify the instruction type to be applied to the structure. You can select the instruction type from the option list. The list displays all the instruction types maintained in the system.
Reallocation Method
Specify the reallocation method for the structure from the drop down list. This refers to the method in which the interest is shared with the participating account entities.The options are:
Investment Sweep
Investment sweep type should be selected as TD(term deposits) or MM (Money Market) at structure level.
The structure will have header account as Notional account, this account will have only one child account and that child account can have multiple other sub child accounts.
Holiday Treatment
Specify the action to be taken on the structure in case of a holiday from the drop down list.The options are:
Max Backward Days
Specify the maximum number of days the system can go back to execute the structure when the execution day falls on a holiday.
Note
This field will be enabled only if ‘Holiday Treatment’ is selected as ‘Previous Working Date’.
Backward Treatment
When the ‘Holiday Treatment’ is selected as ‘Previous Working Day’ and the ‘Max Backward Days’ set is also falling on a holiday, then the system decides on the day of execution of the action based on the Backward Treatment.
Select the backward treatment to be applied from the drop down list. The options are:
Note
This field is enabled only if ‘Holiday Treatment’ is selected as ‘Previous Working Date’.
Parameters like Frequency, Reverse Frequency and Instruction type which are defined at the structure level will be applicable at each account pair level in the structure however user can change these parameters at the account pair level. If the user changes them at the account pair level the system will ignore the structure level set up and go by the pair level settings
FX Rate Pickup
Specify the FX Rate Pickup for the structure from the drop down list. The options are:
Online
Offline
Default value would be “Offline”
Accounts have to be added to create a structure. Click ‘+’ button under the Accounts section to add accounts.The search box opens.
You can search for an account using the following parameters:
User can search for Account by entering Prefixes in Account Number, Branch Code, External Account, Currency Code and BIC Code text boxes.
After clicking on search user will get a list of accounts to be added to the Structure.
Select the accounts to be added and click ADD button. The accounts get listed under the Accounts section.
You can view the following details of the added accounts:
Click ‘Save’ button to save the details.
After the participating accounts for a structure are selected, you can start creating the structure. Click Next button to start creating a structure.
You can drag and drop accounts into the drawing plane to make the structure. For any account selected, click on the account to view the account details in the ‘Account Details’ section in left. You have to enter the following details:
Account Type
Select the account type of the account from the drop down list. The options are:
When an account is set as ‘Pool’, this account is highlighted in blue in the system.
To set account as a child account, drag and drop the accounts onto the parent account.
Mouseover the account to view the ‘+’ link. Click on it to view the structure expanded.
You can mouseover the account to view the ‘-’ link. Click on it to compress the structure.
When an account selected is an external account, this account is highlighted in amber colour..
To view the parent account details of an account, select the account and click on the ‘Parent Details’ link in the left side of the application.You can view the following details:
Mouseover an account in a structure to view the isolate link. Click on it to isolate the account and view its details. This will be helpful in case of complex structures.
To restore back and view the entire structure, you can click the restore link.
Click on the account in the structure to view the ‘Delete’ button enabled. Click on this button to delete the account..
A control panel allows you to view the designed structure better. Click the control panel icon to open it. The table below briefs the icon and their functions in the control panel.
Icons |
Function |
Description |
Control Panel |
Click this icon to open and close the control panel |
Structure Panel |
Click this icon to view the designed structure in various inbuilt views. |
Zoom to Fit |
Click this icon to view the map zoomed to fit the screen |
Zoom In |
Click this icon to zoom in and get a closer look |
Zoom Out |
Click this icon to zoom out and get an overall look. |
Once the structure is set, click ‘Validate’ button to validate the structure. The system checks the validations set up at the various setup screens and throws error, if the structure formed is not complying.
If all the validations are met, system displays a message ‘Structure Validated Successfully’.Click ‘OK’.
Click ‘Next’ to set the instruction parameters.
Click on a child account to set the instruction details for that child-parent account pair.
Click ‘Instruction Details’ link in the left of the application.Click ‘+’ button to add instruction ID. An option list is displayed with all the instruction IDs maintained in the system.
You can select the instruction ID from the option list. One or more instruction IDs can be selected for an account. Click ‘ADD’ to add them.
In case of multiple Instruction IDs, you can select the instruction priority from the drop down list.
To set frequencies for the selected Instruction ID, click on ‘+’ button. An option list is displayed with all the frequencies maintained in the system.
You can select the frequencies from the option list. One or more frequencies can be selected for an instruction. Click ‘ADD’ to add them.
You can click on the Instruction set and view the selected frequencies for it under the tab Frequency.
Delete
Select the check box and click ‘-’ button to delete the frequency.
You can view the parameters values set for an instruction. Select the Instruction and Click on Parameter tab to view the parameter values set for it.
You can enter the following details in the Instruction Details section:
Sweep Priority
When a parent has more than one child accounts sweeps are executed based on the Sweep priority. During the sweep execution the least account priority pair will get executed first
Select the sweep priority for the account pair from the drop down list.
Sweep Direction
Select the sweep direction from the drop down list. The options are:
Rev Sweep Frequency
Reverse sweep frequency is the frequency at which the swept funds are remitted back to remitter account.Specify the frequency of reverse sweep. You can select the frequency from the option list. The list displays all the frequencies maintained in the system.
Parent Sweep Priority
The system provides prioritized sweeps to child accounts if a parent has multiple child accounts in debit balances and the Master/parent account does not have sufficient funds to cover all child account overdrafts during the 2 way sweep
The child account having the least priority will get the funds first.
Instruction Priority
Select the instruction priority from the drop down list. When more than one instruction is set up between a pair of accounts the instruction priority comes in to picture, the instruction with the least number will get executed first
Rate Type
Specify the rate type of the account pair. You can select the rate type from the option list. The list displays all the rate types maintained in the system
EOD
Check this box to execute the instructions at EOD.
Hold
Check this box to hold the execution of instruction of the account pair.
Payment details are set for the account pair based on which payment parameters will be sent to DDA to fetch the balances.
If the account pair is set for one way, only one way parameter can be viewed on screen. Else both one way and two way options can be viewed. Select the one way and two way parameters from the drop down list. The list displays all the parameters that are set for the account in payment parameters setup.
Payment Instruction for Beneficiary Account details are displayed on the payment instruction panel.
Click Save to save the structure.
Any structure which is designed can be modified by opening the structure and clicking on the Modify button.The following modifications can be done:
You cannot change the header account of a structure..
The processing of sweeps\pools on a structure can be paused temporarily by selecting the pause button on the structure though the modification operation.
Following are the effects of Pause on structure.
The structure processing can be resumed the by unselecting the Pause option.
On Pausing the Structure, Alert gets generated on the alert widget on banker dashboard about the structure being paused for execution.
On revoking the Pause, an Alert message should be generated on the Alert widget on banker dashboard about the structure pause being revoked.
On selection of Get History option user would be able to view the entire history for that specific Structure starting from the creation, pause, resume and modifications.
This screen is used to find out the structure in which the selected account is a participant . User can search records using Customer ID, Account Number & Structure ID.
Customer ID
Specify the customer ID.
Account Number
Specify the account number of the customer.
Structure ID
Specify the Structure ID associated to the customer
On Click of Get Details button, Structure details will be display in Structure Summary Tab
