32519 5000000000080000 – NTP Offset Check Failed
Alarm Type: TPD
Description: This minor alarm indicates that time on the server is outside the acceptable range (or offset) from the NTP server. The Alarm message will provide the offset value of the server from the NTP server and the offset limit that the application has set for the system.
Severity: Minor
OID: ntpOffsetCheckFailedNotify 1.3.6.1.4.1.323.5.3.18.3.1.3.20
Alarm ID: TKSPLATMI205000000000080000
Recovery
- Contact My Oracle Support.
