22. Annexure C - IC Rule Set-up
This Annexure lists the Interest and Charge (IC) rules that need to be maintained for the CASA module of Oracle FLEXCUBE. It also gives the UDEs and rates for which values need to be maintained.
22.1 IC Rule Maintenance
22.1.1 Maintaining IC Rule
The components required to calculate interest (the principal, period, and rate) are broadly referred to as ‘Data Elements’. Data elements are of two types:
In addition to specifying how the SDEs and UDEs are connected through the formulae, you also define certain other attributes for a rule using the ‘Interest & Charges Rule Maintenance’ screen. You can invoke this screen by typing ‘‘ICDURUMNT’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
For details about the screen, refer the chapter ‘Maintaining Interest Rules’ in the Interest and Charges User Manual.
You can maintain rules for the following:
22.1.2 Interest on Saving and Current Bank Accounts for Retail Customer
Specify the following details:
On Account Opening Month
Check this box.
On Account Closure Month
Check this box.
SDE
Maintain the following SDEs:
UDE
Maintain the following UDEs:
User Defined Elements
Type
NORMAL_RATE1
Rate
NORMAL_RATE2
Rate
NORMAL_RATE3
Rate
NORMAL_RATE4
Rate
AMOUNT1
Amount
AMOUNT2
Amount
AMOUNT3
Amount
TAX1
Rate
Get Latest
For each of the UDEs, select the option ‘Use Effective’ from the adjoining drop-down list.
Click ‘Formulas’ button and invoke the ‘Formulas’ screen.
You need to maintain two booked formulae and one tax formula.
Formula 1
Periodicity
Select ‘Daily’ from the adjoining drop-down list.
Book Flag
Select ‘Booked’ from the adjoining drop-down list.
Debit/Credit
Select ‘Credit’ from the adjoining drop-down list.
Days in a Month
Select ‘Actuals’ from the adjoining drop-down list.
Days in a Year
Select ‘365’ from the adjoining drop-down list.
Accrual Required
Check this box.
Rounding Required
Check this box.
Click ‘Formula Wizard’ button and invoke the ‘Formula Wizard’ screen.
In this screen, specify the following expressions:
Case
Result
(VD_DLY_CR_BAL_M >=0 AND VD_DLY_CR_BAL_M <= AMOUNT2)
(VD_DLY_CR_BAL_M*NORMAL_RATE1*DAYS)/(YEAR*100)
(VD_DLY_CR_BAL_M > AMOUNT2
(VD_DLY_CR_BAL_M*NORMAL_RATE3*DAYS)/(YEAR*100)
Formula 2
Book Flag
Periodicity
Debit/Credit
Select ‘Debit’ from the adjoining drop-down list.
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Click ‘Formula Wizard’ button and invoke the ‘Formula Wizard’ screen. In this screen, you need to maintain the following expressions:
Case
Result
VD_DLY_DR_BAL_M >=AMOUNT3
(VD_DLY_DR_BAL_M <AMOUNT3
(VD_DLY_DR_BAL_M*NORMAL_RATE4*DAYS)/(YEAR*100)
Formula 3
Book Flag
Select ‘Tax’ from the adjoining drop-down list.
Periodicity
Select ‘Periodic’ from the adjoining drop-down list.
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Leave this box unchecked.
Rounding Required
Check this box.
Case
Result
FORMULA1 > AMOUNT1
(TRUNC((FORMULA1*TAX1)/100)
(FORMULA1 < AMOUNT1
0
22.1.3 Debit Interest on Current Accounts
Check this box.
Check this box.
SDE
UDE
Type
For each of the UDEs, select the option ‘Rate’ from the adjoining drop-down list.
Get Latest
Click ‘Formulas’ button and invoke the ‘Formulas’ screen. You need to maintain two booked formulae and one non-booked formula.
Formula 1
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Click ‘Formula Wizard’ button and invoke the ‘Formula Wizard’ screen. In this screen, you need to maintain the following expression:
Case
Result
DLY_NET_BAL_M > 0
ABS((DLY_NET_BAL_M*NORMAL_RATE1*DAYS)/(YEAR*100))
Formula 2
Book Flag
Select ‘Non-Booked’ from the adjoining drop-down list.
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Rounding Required
Check this box.
Case
Result
DLY_NET_BAL_M <0
ABS(DLY_NET_BAL_M)
Formula 3
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box if rounding is required.
Case
Result
FORMULA2> ACCOUNT_LIMIT
ABS((DLY_NET_BAL_M*NORMAL_RATE2*DAYS)/(YEAR*100))
FORMULA2< ACCOUNT_LIMIT
ABS((DLY_NET_BAL_M*NORMAL_RATE3*DAYS)/(YEAR*100))
22.1.4 Interest on Current account for Corporate Customer
Check this box.
Check this box.
SDE
UDE
Type
RATE1
Rate
RATE2
Rate
AMOUNT1
Amount
AMOUNT2
Amount
TAX1
Rate
TAX2
Rate
Get Latest
Click ‘Formulas’ button and invoke the ‘Formulas’ screen. You need to maintain two booked formulae and one tax formula.
Formula 1
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Interest Method Default From Currency Definition
Check this box.
Case
Result
( MON_AVG_BAL <0
ABS((MON_AVG_BAL*RATE1*DAYS)/(YEAR*100))
Formula 2
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Case
Result
MON_AVG_BAL >0
ABS((MON_AVG_BAL*RATE2*DAYS)/(YEAR*100))
Formula 3
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Leave the box unchecked.
Rounding Required
Check this box.
Case
Result
FORMULA2 < AMOUNT1
0
FORMULA2>AMOUNT1
TRUNC((FORMULA2*TAX1)/100)
FORMULA2>AMOUNT2
TRUNC((FORMULA2*TAX2)/100)
22.1.4.1 Interest on Saving and Current Bank Accounts for Retail Customer
Check this box.
Check this box.
SDE
UDE
Type
NORMAL_RATE1
Rate
NORMAL_RATE2
Rate
NORMAL_RATE3
Rate
NORMAL_RATE4
Rate
AMOUNT1
Amount
AMOUNT2
Amount
AMOUNT3
Amount
TAX1
Rate
Get Latest
Formula 1
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box..
Click ‘Formula Wizard’ button and invoke the ‘Formula Wizard’ screen. In this screen you need to maintain the following expressions.
Case
Result
Formula 2
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Case
Result
(VD_DLY_DR_BAL_M*NORMAL_RATE2*DAYS)/(YEAR*100)
Formula 3
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Rounding Required
Check this box.
Case
Result
FORMULA1 > AMOUNT1
(FORMULA1 < AMOUNT1
0
22.1.4.2 Interest on Saving and Current Bank Accounts for Retail Customer
Check this box.
SDE
UDE
Type
NORMAL_RATE1
Rate
NORMAL_RATE2
Rate
NORMAL_RATE3
Rate
NORMAL_RATE4
Rate
AMOUNT2
Amount
AMOUNT3
Amount
Get Latest
Click ‘Formulas’ button and invoke the ‘Formulas’ screen. You need to maintain two booked formulae.
Formula 1
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Case
Result
(VD_DLY_CR_BAL_M*NOR­MAL_RATE1*DAYS)/(YEAR*100)
Formula 2
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Check this box.
Rounding Required
Check this box.
Case
Result
22.1.5 Charge as Dr Interest when the Balance is Less than Minimum Average Balance
Check this box.
Check this box.
SDE
UDE
Type
AVSLAMT1
Amount
AVSLAMT2
Amount
AVSLAMT3
Amount
AVSLAMT4
Amount
AVSLAMT5
Amount
CHGAMT1
Amount
CHGAMT2
Amount
CHGAMT3
Amount
CHGAMT4
Amount
CHGAMT5
Amount
TAX3
Rate
Get Latest
Click ‘Formulas’ button and invoke the ‘Formulas’ screen. You need to maintain one booked formula and one tax formula.
Formula 1
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Rounding Required
Check this box.
Case
Result
MON_AVG_BAL >0 AND MON_AVG_BAL > MIN_BAL_REQD
0
MON_AVG_BAL < AVSLAMT1
CHGAMT1
MON_AVG_BAL < AVSLAMT2 AND MON_AVG_BAL > AVSLAMT1
CHGAMT2
MON_AVG_BAL < AVSLAMT3 AND MON_AVG_BAL > AVSLAMT2
CHGAMT3
MON_AVG_BAL < AVSLAMT4 AND MON_AVG_BAL > AVSLAMT3
CHGAMT4
MON_AVG_BAL < AVSLAMT5 AND MON_AVG_BAL > AVSLAMT4
CHGAMT5
Formula 2
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Rounding Required
Check this box.
Case
Result
FORMULA1 >0 AND FORMULA1 < MON_AVG_BAL
TRUNC((FORMULA1*TAX3)/100)
22.1.6 Dormancy Charge
Check this box.
Check this box.
SDE
UDE
Type
For each of the UDEs, select the option ‘Amount’ from the adjoining drop-down list.
Get Latest
Click ‘Formulas’ button and invoke the ‘Formulas’ screen. You need to maintain one booked formula.
Formula 1
Book Flag
Periodicity
Debit/Credit
Days in a Month
Days in a Year
Accrual Required
Rounding Required
Check this box.
Case
Result
AC_DORMANT =1 AND (AC_DOR­MANCY_DAYS >=1 AND AC_DOR­MANCY_DAYS <=30)
AC_DORMANCY_­DAYS*DORM_CH_PER_DAY1
AC_DORMANT =1 AND AC_DOR­MANCY_DAYS >30
AC_DORMANCY_­DAYS*DORM_CH_PER_DAY2
22.2 UDE Value Maintenance
22.2.1 Maintaining UDE Value
You can maintain UDE values for the rules using the ‘Interest and Charges User Data Element Maintenance’ screen. You can invoke the ‘Interest and Charges User Data Element Maintenance’ screen by typing ‘ICDUDVAL’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
For details about the screen, refer the chapter ‘Giving UDE Values for Condition’ in the Interest and Charges User Manual.
In this screen, you need to maintain the following UDEs for the different IC products. Assume that you have maintained the following interest products:
22.2.2 Interest on Saving and current Bank Accounts for Retail Customer
You need to maintain values for the following UDEs under this product:
22.2.3 Debit Interest on Current Accounts
22.2.4 Interest on Current account for Corporate Customer
22.2.5 Interest on Liqd Before Month End on Saving and Current Bank Ac­counts For Retail Customer
22.2.6 Interest on Saving and Current Bank Accounts For Retail Customer
22.2.7 Charge On Less Average Balance
22.2.8 Stamp Duty Taxation
You need to maintain value for the UDE, STAMP_DUTY, under this product.
In addition to specifying how the SDEs and UDEs are connected through the formulae, you also need to define certain other attributes for a rule using the ‘Interest & Charges Rule Maintenance’ screen. You can invoke this screen by typing ‘ICDRUMNT’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
Specify the following parameters in the Formulas section of the Interest & Charges Rule Maintenance screen:
Debit/Credit
Select ‘Debit’ from the Debit/Credit list.
Book Flag
Select ‘Booked’ from the Book Flag list.
Periodicity
Select ‘Quarterly’ from the Periodicity list.
Case
Result
CURRENT_BAL < 0
((CURRENT_BAL*STAMP_DUTY) * -1)
22.3 IC Rates Maintenance
You can maintain rate codes for branches using the ‘Interest & Charges Branch Availability Maintenance’ screen. You can invoke this screen by typing ‘ICDBRSTR’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
You need to maintain the following rate code for all branches of your bank:
For the aforesaid rate code, you need to maintain rates and effective dates in the ‘Interest and Charges Rate Input’ screen. You can invoke the ‘Interest and Charges Rate Input’ screen by typing ‘ICDRATMA’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
These rates are picked up by the CASA module while processing interest applicable on a CASA.
Refer the chapter ‘Floating Rate Codes for IC Module’ for details about rate maintenance.
