15. Retrieving Information in Oracle FLEXCUBE
During the day, or at the end of the day, you may want to retrieve information on any of the several operations that were performed during the day in your bank. You can generate this information in the form of reports in Oracle FLEXCUBE.
For every module you can generate reports, which give you data about the various events in the life of a specific contract, or across contracts, at a specific point in time. You can have analysis reports, daily reports, exception reports (reports on events that ought to have taken place on the contract but have not, due to various reasons), history reports and so on. A set of report formats is pre-defined for every module.
15.1 Report Options
15.1.1 Specifying the Output of a Report
When a report is generated, you can either Save, or Print the same. The reports are viewed/printed from following screen.
Select the format, output and the name of a printer defined in the Printer Maintenance table. Select the location as ‘Client’ or ‘Server’ to specify where the report needs to be spooled. The destination is determined at the maintenance level.
15.1.2 Contents of the report
The contents of the report are discussed under the following heads:
Header
The Header section of the report carries the title of the Report, information on the User who generated the report, the branch code, the date and time and the page number of the report.
Body of the report
The actual contents of the report are displayed in this section. It is detailed for each report, in the subsequent sections of this document.
15.2 Accrual Control List Report
15.2.1 Generating Accrual Control List Report
The accrual control journal gives the details of accruals done on finance contracts, as of a specific date.
This report shows the Events and Component details for each account and will be generated for a specific combination of the Account Number, Event Date and Branch Name.
The Component and Item details will be displayed based on Events and Account Number.
You can invoke this report screen by typing ‘CIRPACCR’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
15.2.2 Selection Options
If you generate the report manually, the report will list the accounts whose Accrual Processing Date is equal to the date that you specify in the screen CL Accrual Control List.
15.2.3 Contents of the Report
The options that you have specified while generating the report are printed at the beginning of the report. Apart from the header the following information is provided for each contract:
Body of the Report
Field
Description
Account Number
The account number of the contract
Status
The status of the finance contract
Component
This is the component of the finance against which accrual entries are passed
Currency
This is the component currency. If not specified at the Component level, the finance currency is displayed
Current Accrual
This is the amount for which accrual entries are passed for the current month
Value Date
The Value Date of the contract
15.3 Accrual Control List Summary Report
15.3.1 Generating Accrual Control List Summary Report
The Accrual Control List Summary report summarizes the details of accruals product wise.
15.3.2 Contents of the Report
Field
Description
Product
This is the product for which the summary report is being gener­ated
Status
The status of the finance contract under the product
Compo­nent
This is the component of the finance against which accrual entries are passed, for the contract under the product
Ccy
This is the component currency. If not specified at the Compo­nent level, the finance currency is displayed
Current Accrual
Value Date
The Value Date of the contract under this product
15.4 Adverse Status Report
15.4.1 Generating Adverse Status Report
The Adverse status report gives details of finance contracts that have moved into a status other than active and liquidated.
The amounts outstanding for the various components are reported in this report.
You can invoke this report screen by typing ‘CIRPSTAT’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
15.4.2 Selection Options
If you generate the report manually (from the reports Browser) you can specify preferences for the generation of the report. The contents of the report are determined by the preferences that you specify.
You can specify the following preferences for the report:
Product Category
You can generate the Adverse Status report for a specific Product Category or for all categories. Select a Product Category from the option list provided.
Product Code
You can generate a product-wise report. Select the Product Code from the option list which contains all valid products under the category you have selected.
Account Ccy
Under specific Product(s), you can choose to generate reports in a specific currency(s).
Customer
You can generate this report for specific customer(s).
From Date (Value Date)
Enter the Value Date of the contract. The system will generate a report for the contracts that have a Value Date greater than the date you enter here.
To Date (Value Date)
Enter the Value Date of the contract. The system will generate a report for the contracts that have a Value Date lesser than the date you enter here.
15.4.3 Contents of the Report
The report options that you selected while generating this report are printed at the beginning of the report.
Body of the Report
Field
Description
PRODUCT
This is the product for which the report is generated
STATUS
This is the current status of the component that is in a status other than Active or Liquidated. The status codes are defined for a product and applied to contracts involving the product
CUSTOMER
This is the CIF ID of the customer involved in the finance.
CUSTOMER­NAME
The name of the customer
CONTRAC­TREFNO
This is the reference number of the finance being reported
COMPONENT
The component whose status details the report reflects
CCY
MATURITY
This is the Maturity Date of the finance
MAXOVERDUE­DAYS
If more than one account is overdue under the product, this field will reflect the number of overdue days of the account with the highest number of overdue days
OVERDUEAMT
This is the total amount that is overdue for the component as of the date of report generation
15.5 Adverse Status Summary Report
15.5.1 Generating Adverse Status Summary Report
The Adverse Status Summary report summarizes the details of each contract.
15.5.2 Contents of the Report
Body of the Report
Field
Description
PRODUCT
STATUS
This is the current status of the contract for which details are being reported
COMPONENT
This is the component of the finance against which the payment due is being reported. If more than one component falls due on the same day they will be reported one by one
CURRENCY
EARLIEST DUEDATE
For all the finances reported, this is the earliest date on which a repay­ment is due
LATEST DUE­DATE
For all the finances reported, this is the latest date on which a repay­ment is due
CUMULATIVE OVERDUEAMT
This is the total amount that is overdue for the component(s) as of the date of report generation
15.6 Amortization Report
15.6.1 Generating Amortization Report
The Amortization Report gives the amortization details of finance contracts. You can invoke this report screen by typing ‘CIRPAMSC’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
15.6.2 Selection Options
Account Number
Enter the Account Number for which amortization details should be displayed in the report. If you do not enter an account number here, the report will be generated for all accounts.
15.6.3 Contents of the Report
Body of the Report
Field
Description
REFERENCE NO
PRINCIPAL
The principal amount of the finance being reported
PRODUCT
CUSTOMER ID
TENOR
The tenor of the finance being reported
YEAR
This is the year for which the amortization details are being dis­played in the report
DUE DATE
The due date of an installment of the finance
INSTALLMENT
This is the installment amount of the finance
PROFIT DUE
The profit amount due
PRINCIPAL DUE
The principal amount due
TOTAL PRINCI­PAL DUE
The total principal amount due on the finance
15.7 Contract Retrieval Report
15.7.1 Generating Contract Retrieval Report
The Contract Retrieval report gives you comprehensive information about a finance contract. Information about finance contracts that are active, liquidated and reversed can be retrieved through this report. You can generate the report for a variety of reasons.
You can invoke this report screen by typing ‘CIRPRETR’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
15.7.2 Selection Options
Product Category
You can generate the Contract Retrieval Report for a specific Product Category or for all categories. Select a Product Category from the option list provided.
Product Code
Account Ccy
Customer
From (Value Date)
To (Value Date)
Enter the Value Date of the contracts. The system will generate a report for the contracts that have a Value Date lesser than the date you enter here.
Maturity Type
You can generate the report only for a particular Maturity Type. The Maturity type of a finance can be
You can generate the report either for fixed maturity finances or call finances.
From (Maturity Date)
Specify the Maturity Date of the finance. The report will be generated for all contracts whose Maturity Date is equal to, or greater than the date you have specified here.
To (Maturity Date)
Specify the Maturity Date of the finance. The report will be generated for all contracts whose Maturity Date is equal to, or less than the date you have specified here.
Account Status
You can generate the report based on the status of the finance contract. The report can be generated for finances with the following statuses only:
All the finances with the specified status for the specific period will be reported.
Auth Status
You can generate the report for finance contracts either with an authorized or unauthorized status.
15.7.3 Contents of the Report
Body of the Report
Field
Description
Account No.
The account number for which the report is being generated
Account Status
This is the current status of the account
Outstanding Amount
This is the total outstanding amount that the customer has to repay. This amount also includes amounts belonging to earlier schedules that are yet to be paid. In case the customer has made pre-pay­ments the outstanding amount can be less than the due amount
Product Code
Product Category
This is the product category to which the generated report belongs
User Ref No
Customer
Customer Name
Related Ref No
This is the alternate account number
Account Currency
The currency of the account
Financed Amount
The finance amount financed
Original Start Date
This is the original start date of the finance
Booking Date
The Booking Date of the contract
Value Date
Maturity Type
This is the Maturity Type of the contract
Maturity Date
The Maturity Date of the contract
Tenor
User Defined Sta­tus
Auth Status
The authorization status of the contract
Liquidation Mode
The liquidation mode of the contract
Rollover Mode
The rollover mode
Rollover Count
The rollover count
Component
The components of the finance are listed here
Ccy
This is the currency of the component
Rate Type
This is the rate type
Code Usage
This is the code usage
Effective Rate(%)
This is the effective rate
Special Amount
This is the special amount for the component
15.8 Event Report
15.8.1 Generating Event Report
Contract events are events that have taken place during the tenor of a finance contract.
Contract Events report gives a list of all the events that have taken place during the tenor of a finance contract. The events are listed by their Value Date.
You can invoke this report screen by typing ‘CIRPEVNT’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
15.8.2 Selection Options
From (Account Number)
Select the starting account number. The system will display event details of all accounts from this account number.
To (Account Number)
Select the ending account number. The system will display event details of all accounts upto this account number.
Note
If you do not enter an account number in the above two field, the system will display the event details of all accounts.
From (Event Date)
Enter the date from which event details should be generated in the report for accounts.
To (Event Date)
Enter the date upto which event details should be generated in the report for accounts.
Note
You have the option of not specifying the ‘From’ and ‘To’ dates, but if you specify the ‘From Event Date’, it will be mandatory for you to specify the ‘To Event Date’.
Include Accrual Events also
Check this box to indicate accrual related events should be included.
Single Account No.
Select this option to indicate the report should be generated for a single account number or for a range.
All
Select this option to indicate the report should be generated for all accounts.
15.8.3 Contents of the Report
Body of the Report
Field
Description
ACCOUNT NO
CUSTOMER ID
CUSTOMER NAME
ACCOUNT CCY
EVENT
This is the code of the event for which details are being reported
EVENT DATE
This indicates the date on which the event took place.
SEQ. NO.
The sequence number of the event
COMPONENT NAME
The component for which details are displayed in the report
ITEM NAME
The amount tag
ITEM VALUE
The value of the amount tag
15.9 Forward Contract Report
15.9.1 Generating Forward Contract Report
A forward contract is a finance with a future value date. The value date is the date on which the finance takes effect. The tenor of the finance contract will begin on this date. All accounting entries for the finance contract, all calculations for profit and all the other components based on the tenor will be made from this date onwards.
The forward contract report gives details of all the finance contracts with a future value date. Only contracts that take effect on a date later than or same as the specified date are included in the report.
You can invoke this report screen by typing ‘CIRPFRWD’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
15.9.2 Selection Options
From (Value Date)
To (Value Date)
Note
It is not mandatory for you to enter the ‘From’ and ‘To’ dates.
Product Category
You can generate the Forward Contract Report for a specific Product Category or for all categories. Select a Product Category from the option list provided.
15.9.3 Contents of the Report
Body of the Report
Field
Description
Product Category
Account No
The account number of the contract for which the report is generated
Customer Id
Customer Name
Amount
This is the principal amount involved in the finance
EuroEqv
The Euro equivalent of the finance amount
Value Date
This is the date on which the finance takes effect
Mat.Type
This is the maturity type of the finance. It could be fixed or call.
Mat. Date
This is the date on which the finance matures. The maturity date is gen­erated in the report only in case of fixed maturity finances.
CHARGE DETAILS
Component
The component on which a charge is being applied
Amount
The charge amount
Euro Eqv.
The Euro equivalent of the charge
Waiver
Whether or not the charge has been waived
PROFIT DETAILS
Component
The profit component
Amount
The profit amount
Euro Eqv
The Euro equivalent
Rate
The profit rate being applied
Effective Rate
The effective profit rate
Waiver
Whether the profit has been waived
15.10 Forward Amendments Details Changes Report
15.10.1 Generating Forward Amendments Details Changes Report
The Forward Amendments Details Changes Report gives a list of all the amendments made to contracts with a future value date.
You can invoke this screen by typing ‘CIRPFWCH’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
15.10.2 Selection Options
If you generate the report manually, the report will list the accounts whose Effective Date is between the dates that you specify in the screen Forward Amendments Report screen.
From (Effective Date)
Enter the date from which the report should include amendment details.
To (Effective Date)
Enter the date upto which the report should include amendment details.
15.10.3 Contents of the Report
Body of the Report
Field
Description
ACCOUNT NO
The account number of the contract for which the report is being generated
MATURITY DATE
VALUE DATE
LOAN AMOUNT
The principal finance amount of the contract
CURRENCY
CUSTOMER ID
CUSTOMER NAME
TRANSACTION DATE
The date of the transaction
AMENDMENT DATE
The date of amendment
NEW MATURITY DATE
The Maturity Date after amendment
DIFFERENTIAL AMOUNT
This is the difference between the original financed amount and the new financed amount. If there is no change in the finance value, this field will be zero.
LATEST ESN
The latest Event Sequence Number
COMPONENT NAME
The component that has been amended
NEW RATE
The new rate that has been applied to the component
OLD RATE
The original rate
NEW RATE CODE
The new rate code
OLD RATE CODE
The original rate code
LATEST ESN
This is the latest Event Sequence Number
15.11 Profit Calculation Analysis Report
15.11.1 Generating Profit Calculation Analysis Report
The Profit Calculation Analysis Report is generated for the accounts required between the given Value Date ranges.
The report will be generated for a specific combination of Branch, Account Number and Value Date range.
You can invoke this screen by typing ‘CIRPCALC’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
15.11.2 Selection Options
Single/Range (Account Type)
Select this option to indicate you are either specifying a range of account numbers or a specific one whose report is to be generated.
All (Account Type)
Select the starting account number. The system will display details of all accounts from this account number.
To (Account Number)
Select the ending account number. The system will display details of all accounts upto this account number.
From (Value Date)
To (Value Date)
15.11.3 Contents of the Report
Body of the Report
Field
Description
AccountNo.
The account number of the contract for which the report is being gen­erated
Value Date
Maturity Date
The Maturity Date of the finance contract
Customer Id
Customer Name
Component
The component for which details are being displayed in the report
Int. Method
The method if profit calculation
Currency
The account currency
Start Date and End Date
Reflects the various periods of change of profit rate
Basis Amount
The basis amount on which the profit is calculated
Rate
The profit rate applicable to a certain period
No. of Days
The number of days for which the rate is applicable
Profit Amount
The is the profit amount
15.12 Linked Contracts Utilization Report
15.12.1 Generating Linked Contracts Utilization Report
This report will include the details of the accounts, lines or collaterals that have been linked to an account, based on the selection criteria. Linkage Account details and the Amount Financed will be shown for each Account in this report.
You can invoke this screen by typing ‘CIRPLICU’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
15.12.2 Selection Options
If you generate the report manually, the report will list the accounts that you have specified in the Linked Contract Utilization screen.
Note
If you enter an account number in this field, you will have to enter an account number in the field ‘To’.
To (Account Number)
Note
If you do not enter an account number in the above two fields, the system will display the event details of all accounts.
15.12.3 Contents of the Report
Body of the Report
Field
Description
Account Number
Amount Financed
The finance amount
Currency
Value Date
Maturity Date
Linkage Type
This is the linkage type
Linked Ref. No.
The reference number of the linkage type
Customer ID
Customer Name
Linkage Amount
The amount linked
Secured Portion
This is the secured portion of the finance
15.13 Maturity Report
15.13.1 Generating Maturity Report
The maturity report gives information about a contract that is:
You can invoke this screen by typing ‘CIRPMATR’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
15.13.2 Selection Options
Product Category
Product Code
Contract Ccy
Customer
Maturity Type
You can generate the report either for fixed maturity finance or call finances.
From Date (Schedule Date)
Specify the Starting Date of the schedule.
To Date (Schedule Date)
Specify the Ending Date of the schedule.
Liquidation Mode
Components of a finance can be liquidated automatically or manually. In auto liquidation a schedule will be automatically liquidated on the day it falls due. In manual liquidation a schedule amount has to be liquidated manually.
You can generate the report based on the liquidation mode that you have specified. The report can be generated only for finances with auto liquidation or you can generate the report for finances that have to be manually liquidated.
Non Maturity Schedules
Select the option ‘YES’ to indicate you want the report to include finances which have not matured. Select the option ‘NO’ to indicate it should include matured finances.
15.13.3 Contents of the Report
15.13.4 Body of the Report
Field
Description
CALL CONTRACTS
CUSTOMER ID
CUSTOMER NAME
ACCOUNT NUMBER
The account number for which the report is being gener­ated
Ccy
FINANCED AMOUNT
The finance amount
OUTSTANDING AMOUNT
This is the total outstanding amount that the customer has to repay. This amount also includes amounts belonging to earlier schedules that are yet to be paid. In case the cus­tomer has made pre-payments the outstanding amount can be less than the due amount.
FIXED MATURITY CONTRACTS
DUE DATE
This is the due date for the due amount
CUSTOMER ID
CUSTOMER NAME
ACCOUNT NUMBER
MATURITY DATE
COMPONENT
Component which is due
CCY
Currency of the component
DUE AMOUNT
The amount which is due
O/S AMOUNT
This is the due amount minus the amount paid
15.14 Overdue Schedules Details
15.14.1 Generating Overdue Schedules Details Report
Repayment schedules can be defined for various components of a product like principal, profit, commission and fees. These schedules will apply to all the finances involving the product unless you redefine them at the time of processing the finance.
The Overdue Schedules report gives details of all repayment schedules of a finance that are overdue (i.e., are not paid even when they are beyond their scheduled repayment dates.
You can invoke this screen by typing ‘CIRPOSCH’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
15.14.2 Selection Options
Product Category
You can generate the Overdue Schedules Report for a specific Product Category or for all categories. Select a Product Category from the option list provided.
Product Code
Contract Ccy
Customer
15.14.3 Contents of the Report
Body of the Report
Field
Description
DUEDATE
The due date of the component which is overdue
OVERDUEDAYS
The number of days by which the component is overdue
CUSTOMER
CUSTOMER NAME
ACCOUNT NUM­BER
The account number of the customer for whom the report is being generated
STATUS
The status of the component which is overdue
COMPONENT
The component which is overdue
Ccy
This is the component currency. If not specified at the Com­ponent level, the finance currency is displayed
OVERDUE AMT
This is the component amount that is overdue
EURO EQUIVA­LENT
This is the euro equivalent of the overdue amount
15.15 Periodic Rate Revision
15.15.1 Generating Periodic Rate Revision Report
The Periodic Rate Revision Report lists the details of a customer, the rate revision date and the effective rate.
The report will be generated for a specific combination of Revision Date, Customer, Account Number and Rate Code. You can invoke this screen by typing ‘CIRPREVN’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
15.15.2 Selection Options
Product Category
Product Code
Account Ccy
Customer
Maturity Type
You can generate the report only for a particular Maturity Type. The Maturity type of a finance can be:
From Date (Revision Date)
Enter the Revision Date from which the report has to be generated.
To Date (Revision Date)
Enter the Revision Date upto which the report has to be generated.
15.15.3 Contents of the Report
Body of the Report
Field
Description
REVN DATE
The rate revision date
RATE CODE
The rate code
CUSTOMER
CUSTOMER NAME
CONTRACTREFNO
CCY
CONTRACTA­MOUNT
The contract amount
COMPONENT
The component that has undergone a rate revision
COMPONENTCCY
The currency of the component
UDEID
The User Defined Element
EFFECTIVE RATE
The rate applicable
