7. Error Messages for Derivative
This chapter contains the following section:
7.1 Error Codes and Messages
Function ID
Error Code
Message
DV-RVN-001
DVRE­SET0
Unhandled Exception while processing rate revision.
DV-ADV-001
DVAD­VSRV
Unhandled exception while processing messages to be gen­erated.
DV-AML-001
DVAMLSRV
Unhandled exception during message generation for FRA confirmation.
DV-AML-002
DVAMLSRV
This message cannot be sent for this contract.
DV-AML-003
DVAMLSRV
DV-AML-004
DVAMLSRV
Unhandled exception while generating message for Rate Swap confirmation.
DV-AML-005
DVAMLSRV
Unhandled exception while generating message for contract assignment.
DV-AML-006
DVAMLSRV
Unhandled exception while getting in leg details.
DV-AML-007
DVAMLSRV
Unhandled exception while getting out leg details.
DV-AML-008
DVAMLSRV
DV-AML-009
DVAMLSRV
DV-AML-010
DVAMLSRV
Unhandled exception while getting the general terms of the contract.
DV-AML-011
DVAMLSRV
Unhandled exception while getting sender and receiver addresses.
DV-AML-012
DVAMLSRV
Unhandled exception while getting broker details.
DV-AML-013
DVAMLSRV
Unhandled exception while getting agreement details.
DV-AML-014
DVAMLSRV
Unhandled exception while getting payment dates.
DV-AML-015
DVAMLSRV
DV-AML-016
DVAMLSRV
Unhandled exception while getting reset dates.
DV-AML-017
DVAMLSRV
Unhandled exception while getting compounding dates.
DV-AML-018
DVAMLSRV
Unhandled exception while getting settlement details.
DV-AML-019
DVAMLSRV
Unhandled exception while getting account details.
DV-AML-020
DVAMLSRV
Unhandled exception while processing a tag.
DV-AMR-002
DVA­MORT0
Product is not Open.
DV-AMR-003
DVA­MORT0
Product is not Authorized.
DV-AMR-004
DVA­MORT0
DV-AMR-005
DVA­MORT0
DV-AMR-011
DVA­MORT0
Unhandled exception while obtaining the periodic amort date.
DV-AMR-021
DVA­MORT0
Unhandled exception while processing periodic inception amort.
DV-AMR-031
DVA­MORT0
Unhandled exception while processing periodic termination amort.
DV-AMR-101
DVA­MORT1
Unhandled exception while processing for a contract.
DV-AMR-102
DVA­MORT1
Failed to round the amount.
DV-AMR-103
DVA­MORT1
DV-AMR-121
DVA­MORT1
Unhandled exception while populating product amort.
DV-AMR-131
DVA­MORT1
Unhandled exception while populating period amort.
DV-AMR-132
DVA­MORT1
No data found for periodic amortization details.
DV-AMR-141
DVA­MORT1
Unhandled exception while populating amort master.
DV-AMR-151
DVA­MORT1
Unhandled exception while populating product entry.
DV-AMR-161
DVA­MORT1
Unhandled exception while building accounting entry.
DV-AMR-171
DVA­MORT1
Unhandled exception while processing for amount tag.
DV-AUT-001
DVC­COATH
Unhandled exception while authorizing the Contract.
DV-AUT-002
DVC­COATH
Maker Cannot Authorize the Contract.
DV-AUT-003
DVC­COATH
Rekey Field In Leg Currency is incorrect.
DV-AUT-004
DVC­COATH
Rekey Field Out Leg Currency is incorrect.
DV-AUT-005
DVC­COATH
Rekey Field In Leg Principal Amount is incorrect.
DV-AUT-006
DVC­COATH
Rekey Field Out Leg Principal Amount is incorrect.
DV-AUT-007
DVC­COATH
Rekey Field Value Date is Incorrect.
DV-AUT-008
DVC­COATH
Rekey Field Maturity Date is Incorrect.
DV-AUT-009
DVC­COATH
Override(s) are not confirmed.
DV-AUT-010
DVC­COATH
Do You Want to Continue Authorization.
DV-AUT-012
DVC­COATH
Failed to authorize the contract.
DV-BCH-001
DVBCHSRV
Unhandled exception while preparing for batch.
DV-BCH-002
DVBCHSRV
Batch is configured as Mandatory Function in invalid End of Cycle Group.
DV-BCH-005
DVBCHSRV
Unhandled exception while obtaining the process till date.
DV-BCH-011
DVBCHSRV
Unhandled exception while checking program status.
DV-BCH-012
DVBCHSRV
Batch already processed.
DV-BCH-013
DVBCHSRV
Predecessor Functions to Batch are pending.
DV-BCH-021
DVBATCH
Unhandled Exception while calculating the process till date.
DV-BCH-022
DVBCHSRV
Branch Parameters not maintained for Derivatives.
DV-BCH-031
DVBCHSRV
Unhandled exception while obtaining the Period End Date.
DV-BCH-032
DVBCHSRV
Failed to obtain the Period End date for the Branch.
DV-BCH-041
DVBCHSRV
DV-BCH-051
DVBCHSRV
DV-BCH-061
DVBCHSRV
DV-BCH-071
DVBCHSRV
Unhandled exception while processing batch.
DV-BCH-081
DVBCHSRV
DV-BCH-091
DVBCHSRV
DV-BCH-101
DVBCHSRV
Unhandled exception while unmarking End of Transaction Input.
DV-BCH-111
DVBATCH
Unhandled Exception while processing Batch.
DV-CEV-001
DVCNTEV0
Unhandled Exception While Processing The Booking Event.
DV-CEV-011
DVCNTEV0
Unhandled Exception While Processing the revision Event.
DV-CEV-021
DVCNTEV0
Unhandled Exception While Processing the Initiation Event.
DV-CEV-031
DVCNTEV0
Unhandled Exception While Amortizing Inception Value.
DV-CEV-041
DVCNTEV0
Unhandled Exception While Processing the Liquidation Event.
DV-CEV-051
DVCNTEV0
Unhandled Exception While Accruing Interest.
DV-CEV-061
DVCNTEV0
Unhandled Exception While Processing Termination Event.
DV-CEV-071
DVCNTEV0
Unhandled Exception While building tags for Booking Event.
DV-CEV-081
DVCNTEV0
Unhandled Exception While building tags for Initiation Event.
DV-CEV-091
DVCNTEV0
Unhandled Exception While building tags for Termination Event.
DV-CSR-001
DVCNS­RV0
Unhandled Exception While registering a event.
DV-CSR-002
DVCNS­RV0
Inconsistent Database. No record found for the contract in contract table.
DV-CSR-011
DVCNS­RV0
Unhandled Exception While Locking the Record.
DV-CSR-021
DVCNS­RV0
Unhandled Exception While authorizing the Contract.
DV-CSR-022
DVCNS­RV0
Unable to obtain Contract Lock.
DV-CSR-101
DVCNS­RV1
Unhandled Exception While Saving the contract.
DV-CSR-102
DVCNS­RV1
The Value Date $1 should be within the Product Start Date $2 and the Product End Date $3.
DV-CSR-103
DVCNS­RV1
The Maturity Date $1 should be within the Product Start Date $2 and the Product End Date $3.
DV-CSR-104
DVCNS­RV1
The Exchange Rate exceeds the allowed Maximum Variance $1 %.
DV-CSR-105
DVCNS­RV1
The Exchange Rate exceeds the allowed Normal Variance $1 %.
DV-CSR-106
DVCNS­RV1
In Leg Principal Details are Defaulted.
DV-CSR-107
DVCNS­RV1
Out Leg Principal Details are Defaulted.
DV-CSR-108
DVCNS­RV1
In Leg Interest Details are Defaulted.
DV-CSR-109
DVCNS­RV1
Out Leg Interest Details are Defaulted.
DV-CSR-110
DVCNS­RV1
Brokerage Details Defaulted.
DV-CSR-112
DVCNS­RV1
Advice Details Defaulted.
DV-CSR-113
DVCNS­RV1
User Defined Fields Defaulted.
DV-CSR-114
DVCNS­RV1
Charges Defaulted.
DV-CSR-115
DVCNS­RV1
MIS Details Defaulted.
DV-CSR-116
DVCNS­RV1
Settlement Details Defaulted.
DV-CSR-117
DVCNS­RV1
Tax Details Defaulted.
DV-CSR-118
DVDMG­MNT
For event $1 no receiver id given for message type $2.
DV-CSR-121
DVCNS­RV1
Unhandled Exception while defaulting interest details.
DV-CSR-122
DVCNS­RV1
For the component $1 the spread $2 is less than the allowed minimum spread $3.
DV-CSR-123
DVCNS­RV1
For the Component $1 the spread $2 is more than the allowed spread $3.
DV-CSR-124
DVCNS­RV1
For the component $1 the Interest rate Cannot be NULL.
DV-CSR-125
DVCNS­RV1
For the component $1 the Interest rate $2 is less than the allowed minimum rate $3.
DV-CSR-126
DVCNS­RV1
For the component $1 the Interest Rate $2 is more than the allowed maximum rate $3.
DV-CSR-127
DVCNS­RV1
For this Counterparty $1 the Line Code $2 is not allowed.
DV-CSR-128
DVCNS­RV1
For this Product $1 the Line Code $2 is not allowed.
DV-CSR-129
DVCNS­RV1
For this Branch $1 the Line Code $2 is not allowed.
DV-CSR-130
DVCNS­RV1
For this Base Currency $1 the Line Code $2 is not allowed.
DV-CSR-201
DVCNS­RV2
Unhandled Exception while deleting the contract.
DV-CSR-202
DVCNS­RV2
Error While Deleting the MIS details.
DV-CSR-211
DVCNS­RV2
Unhandled Exception while amending the contract.
DV-CSR-221
DVCNS­RV2
Unhandled Exception while copying the Contract.
DV-CSR-222
DVCNS­RV2
Product is not Valid.
DV-CSR-223
DVCNS­RV2
No Primary Interest component defined for the In Leg.
DV-CSR-224
DVCNS­RV2
No Primary Interest component defined for the Out leg.
DV-CSR-225
DVCNS­RV2
Error While copying the MIS details.
DV-CSR-231
DVCNS­RV2
Unhandled Exception while reversing the contract.
DV-CSR-232
DVCNS­RV2
DV-CSR-241
DVCNS­RV2
Unhandled Exception while reversing the Accounting Entries.
DV-CSR-251
DVCNS­RV2
Unhandled Exception while populating the handoff table.
DV-CSR-261
DVCNS­RV2
Unhandled Exception on handoff of accounting Entries.
DV-IAC-001
DVACCR
Unhandled Exception while building the queue array.
DV-IAC-011
DVACCR
Unhandled Exception while calculating the periodic accrual date.
DV-IAC-021
DVACCR
Unhandled Exception while processing periodic interest accrual.
DV-IAC-101
DVACCR
Unhandled Exception while accruing for a contract.
DV-IAC-121
DVACCR
Unhandled Exception while calculating the accrual amount.
DV-IAC-122
DVACCR
Reset not done for interest rates.
DV-IAC-123
DVACCR
No discount rate obtained for the interest component.
DV-IAC-124
DVACCR
For Component $1 liquidation for the past period is pending.
DV-IAC-131
DVACCR
Unhandled exception while processing product level accrual.
DV-IAC-141
DVACCR
Unhandled Exception when processing interest accrual.
DV-IAC-142
DVACCR
No data found for the current product code.
DV-IAC-151
DVACCR
Unhandled exception while processing interest accrual.
DV-IAC-161
DVACCR
DV-IAC-171
DVACCR
DV-IAC-172
DVACCR
No data found for the current contract ref no.
DV-IAC-191
DVACCR
Unhandled exception while processing the amount tags.
DV-ICA-001
DVINTCAL
Unhandled exception while computing Interest Amount.
DV-ICA-002
DVINTCAL
Failed to round the Interest Amount.
DV-ICA-011
DVINTCAL
Unhandled exception while computing Discount Amount.
DV-ICA-012
DVINTCAL
Failed to round the Discount Amount.
DV-ICA-021
DVINTCAL
DV-ICA-022
DVINTCAL
DV-ICA-031
DVINTCAL
Unhandled Exception while calculating the interest amount.
DV-ICA-041
DVINTCAL
DV-ICA-051
DVINTCAL
DV-ICA-061
DVINTCAL
DV-INT-001
DVDINDET
Unhandled exception while validating the Start Date.
DV-INT-002
DVDINDET
Start Date Cannot be before the application Date.
DV-INT-003
DVDINDET
Start Date Cannot be before the Value Date.
DV-INT-004
DVDINDET
Start Date Cannot be after the Maturity Date.
DV-INT-005
DVDINDET
Schedule Date is not Unique.
DV-INT-011
DVDINDET
Unhandled exception while validating the Schedule.
DV-INT-012
DVDINDET
Mandatory field Start Date is NULL.
DV-INT-013
DVDINDET
Mandatory field Frequency is NULL.
DV-INT-014
DVDINDET
Mandatory field Frequency Unit is NULL.
DV-INT-015
DVDINDET
Mandatory field No of Schedules is NULL.
DV-INT-016
DVDINDET
Mandatory field Amount is NULL.
DV-INT-021
DVDINDET
Unhandled exception while amending the Schedules.
DV-INT-031
DVDINDET
Unhandled exception while defaulting the Schedules.
DV-INT-041
DVDINDET
Unhandled exception while Canceling the changes.
DV-INT-051
DVDINDET
Unhandled exception while exploding the Schedules.
DV-INT-061
DVDINDET
DV-INT-071
DVDINDET
Unhandled exception while validating the Schedules.
DV-INT-072
DVDINDET
Mandatory field Discount Rate is NULL.
DV-INT-073
DVDINDET
Mandatory field Discount Floating Component is NULL.
DV-INT-074
DVDINDET
Mandatory field Discount Rate Code is NULL.
DV-INT-075
DVDINDET
Mandatory field Discount Rate Source is NULL.
DV-INT-076
DVDINDET
Mandatory field Discount Tenor Code is NULL.
DV-INT-077
DVDINDET
Mandatory field Discount Rate Spread is NULL.
DV-INT-078
DVDINDET
Mandatory field Interest Rate is NULL.
DV-INT-079
DVDINDET
Mandatory field Interest Rate Code is NULL.
DV-INT-080
DVDINDET
Mandatory field Interest Rate Source is NULL.
DV-INT-082
DVDINDET
Mandatory field Interest Tenor Code is NULL.
DV-INT-083
DVDINDET
Mandatory field Interest Rate Spread is NULL.
DV-INT-084
DVDINDET
Mandatory field Flat Amount is NULL.
DV-INT-091
DVDINDET
DV-INT-092
DVDINDET
Mandatory field Schedule Holiday Currency is NULL.
DV-INT-093
DVDINDET
Mandatory field Schedule Financial Center is NULL.
DV-INT-101
DVDINDET
Unhandled exception while validating revision schedules
DV-INT-102
DVDINDET
Mandatory field Revision Holiday Currency is NULL.
DV-INT-103
DVDINDET
Mandatory field Revision Financial Center is NULL.
DV-INT-104
DVDINDET
Mandatory field Reset Date movement Days is NULL.
DV-INT-105
DVDINDET
Mandatory field Reset Date Holiday Currency is NULL.
DV-INT-106
DVDINDET
Mandatory field Reset Date Financial Center is NULL.
DV-INT-111
DVDINDET
Unhandled exception while defaulting the schedules.
DV-INT-121
DVDINDET
DV-ISR-001
DVINTSRV
Unhandled Exception while defaulting for a event.
DV-ISR-011
DVINTSRV
Unhandled Exception While picking up currency rates.
DV-ISR-021
DVINTSRV
Unhandled Exception While referring Contract Associations.
DV-ISR-031
DVINTSRV
Unhandled Exception While fetching floating Rates.
DV-ISR-032
DVINTSRV
Rate Code Selection is not Valid.
DV-ISR-033
DVINTSRV
Rate Code maintenance is Unauthorized.
DV-ISR-034
DVINTSRV
The Selected Rate Code is Closed.
DV-ISR-035
DVINTSRV
No Rate Details are found. Inconsistent Database.
DV-LM-00001
DVLIMITS
The Issuer Limits details are incomplete. Complete/Delete the Issuer Limits details.
DV-LM-00002
DVLIMITS
The Line Code is not a Limits Template.
DV-LM-00003
DVLIMITS
The Line Code is not entered.
DV-LM-00004
DVLIMITS
The Liability is not entered.
DV-LM-00005
DVLIMITS
The Line Start Date cannot be later than the Line Expiry Date.
DV-LM-00006
DVLIMITS
The Last Available Date cannot be later than the Line Expiry Date.
DV-LM-00007
DVLIMITS
The Line Currency is not entered.
DV-LM-00008
DVLIMITS
This Tenor has been maintained for the Limit.
DV-LM-00009
DVLIMITS
The Tenor details are incomplete. Complete/Delete the Tenor details.
DV-LM-00010
DVLIMITS
The Products Allowed details are incomplete. Complete/Delete the Products Allowed details.
DV-LM-00011
DVLIMITS
The Branches Allowed details are incomplete. Complete/Delete the Branches Allowed details.
DV-LM-00012
DVLIMITS
The Last Available Date cannot be less than the Line Start Date.
DV-LM-00013
DVLIMITS
The Customers Allowed details are incomplete. Complete/Delete the Customers Allowed details.
DV-LM-00014
DVLIMITS
The Tenor Limit Amount exceeds the Line Limit Amount.
DV-LM-00015
DVLIMITS
The Sub Line Tenor Limit Amount cannot be greater than the next higher Main Line Tenor Limit Amount. $1 - $2.
DV-LM-00016
DVLIMITS
The Sub Line Tenor cannot be greater than Maximum Main Line Tenor. $1 Days.
DV-LM-00017
DVLIMITS
There are no Tenors specified for the Main Line.
DV-LM-00018
DVLIMITS
The Line Code is Limits Template. Details will be copied from template. Continue?
DV-LM-00019
DVLIMITS
The Sub Line Limit cannot exceed the Main Line Limit. $1-$2.
DV-LM-00020
DVLIMITS
The Main Line Limit cannot be less than any of its Sub Line Limit. $1 -$2.
DV-LM-00021
DVLIMITS
The Main Line Tenor cannot be Less than the Minimum Tenor of any Sub Lines reporting to it. - $1 Days.
DV-LM-00022
DVLIMITS
The Main Line Tenor Limit Amount cannot be less than the next lower Sub Line Tenor Limit Amount. $1 - $2.
DV-LM-00023
DVLIMITS
The Limits Copy could not be completed.
DV-LM-00024
DVLIMITS
Blank spaces cannot be a part of this field.
DV-LM-00025
DVLIMITS
The Line Code should have nine characters.
DV-LM-00026
DVLIMITS
The Tenor Mnemonic is not entered.
DV-LM-00027
DVLIMITS
The Limit is not entered
DV-LM-00028
DVLIMITS
The Collateral Start Date cannot be later than the Collateral Expiry Date.
DV-LM-00029
DVLIMITS
The Margin computed is not between 0 and 100.
DV-LM-00030
DVLIMITS
The Collateral Currency is not entered.
DV-LM-00031
DVLIMITS
The Collateral Type is not entered.
DV-LM-00032
DVLIMITS
The Collateral Review Date cannot be later than the Collat­eral Expiry Date.
DV-LM-00033
DVLIMITS
The Collateral Review Date cannot be earlier than Collateral Start Date.
DV-LM-00034
DVLIMITS
The Expiry Date cannot be earlier than Start Date.
DV-LM-00035
DVLIMITS
The Security Code is not entered.
DV-LM-00036
DVLIMITS
The Security Type is not entered.
DV-LM-00037
DVLIMITS
The Currency is not entered.
DV-LM-00038
DVLIMITS
The Market Price Details are incomplete. Complete / Delete the Market Price Details.
DV-LM-00039
DVLIMITS
DV-LM-00040
DVLIMITS
The computed exposure is not between 1 and 100.
DV-LM-00041
DVLIMITS
There are Active Sub Lines reporting to this Main Line. Main Line cannot be closed.
DV-LM-00042
DVLIMITS
The Last Price Change Date cannot be greater than Branch Date.
DV-LM-00043
DVLIMITS
The Security Code is not entered for the MVBC.
DV-LM-00044
DVLIMITS
The Price Code is not entered for the MVBC.
DV-LM-00045
DVLIMITS
The Number Of Units is not entered for the MVBC.
DV-LM-00046
DVLIMITS
The Collateral Ccy is not entered for the Collateral.
DV-LM-00047
DVLIMITS
Security Code has not been entered.
DV-LM-00048
DVLIMITS
The Issuer Exposure Details are incomplete. Complete/ Delete the Issuer Exposure Details.
DV-LM-00049
DVLIMITS
The Start Date cannot be greater than the Branch Date.
DV-LM-00050
DVLIMITS
The Last Price Change Date cannot be earlier than Start Date.
DV-LM-00051
DVLIMITS
The Expiry Date cannot be earlier than Branch Date.
DV-LM-00052
DVLIMITS
The Last Price Change Date cannot later than Expiry Date.
DV-LM-00053
DVLIMITS
The Description is not entered.
DV-LM-00054
DVLIMITS
The Face Value is not entered.
DV-LM-00055
DVLIMITS
The Limit Contribution cannot be greater than the Cap Amount.
DV-LM-00056
DVLIMITS
Report date should be greater than the date today.
DV-LM-00057
DVLIMITS
The Total Issuer Exposure should be greater than 100 %.
DV-LM-00058
DVLIMITS
Collaterals exist with the Issuer Code. Record cannot be closed.
DV-LM-00059
DVLIMITS
Securities exist with the Issuer Code. Record cannot be closed.
DV-LM-00060
DVLIMITS
There are Collaterals linked to this Limit. Record cannot be closed.
DV-LM-00061
DVLIMITS
There are Collaterals linked to this Security. Record cannot be closed.
DV-LM-00062
DVLIMITS
There are Collaterals linked to this Price Code. Record can­not be closed.
DV-LM-00063
DVLIMITS
There are Collaterals linked to this Collateral Type. Record cannot be deleted.
DV-LM-00064
DVLIMITS
This Facility is not available at this Branch.
DV-LM-00065
DVLIMITS
No Details exist for the Reference Number.
DV-LM-00066
DVLIMITS
Customer Clean Risk Limit cannot be greater than Liability Clean Risk Limit.
DV-LM-00067
DVLIMITS
Customer Clean Risk Limit cannot be greater than Overall Limit.
DV-LM-00068
DVLIMITS
Liability Clean Risk Limit cannot be greater than Overall Limit.
DV-LM-00069
DVLIMITS
Limit Currency is not Entered.
DV-LM-00070
DVLIMITS
Overall Limit is not Entered.
DV-LM-00071
DVLIMITS
Liability Clean Risk Limit is not Entered.
DV-LM-00100
DVLIMITS
Line Not Authorized.
DV-LM-00101
DVLIMITS
Line Closed.
DV-LM-00102
DVLIMITS
Line Not Found.
DV-LM-00103
DVLIMITS
Invalid Customer ID.
DV-LM-00104
DVLIMITS
Liability ID. Not Specified.
DV-LM-00105
DVLIMITS
Account ID. Not specified.
DV-LM-00106
DVLIMITS
Reference Id not specified.
DV-LM-00107
DVLIMITS
Amount tag not specified.
DV-LM-00108
DVLIMITS
Amount not specified.
DV-LM-00109
DVLIMITS
Currency not specified.
DV-LM-00110
DVLIMITS
Branch not specified.
DV-LM-00111
DVLIMITS
Line $1 - Amount exceeds Limit for specified tenor by $2.
DV-LM-00112
DVLIMITS
Line $1 - Amount exceeds all available tenor limits by $2 $3 $3.
DV-LM-00113
DVLIMITS
Line $1 - Amount exceeds line limit. Limit = $3 $2. Utilization = $4 $2. Overdraft = $5 $2 %Overdraft = $6.
DV-LM-00114
DVLIMITS
Main Line $1 - Amount exceeds Main line limit amount. Limit = $3 $2. Utilization = $4 $2. Overdraft = $5 $2 %Overdraft = $6.
DV-LM-00115
DVLIMITS
Line has matured.
DV-LM-00116
DVLIMITS
Line not available.
DV-LM-00117
DVLIMITS
Amount exceeds limit for liability $1. Limit = $3 $2 Utilization = $4 $2 Overdraft = $5 $2 %Overdraft = $6.
DV-LM-00200
DVLIMITS
Clean risk limit exceeded for Customer $1 On $2. Limit = $4 $3.
DV-LM-00201
DVLIMITS
Clean risk limit exceeded for Liability $1 On $2. Limit = $4 $3.
DV-LM-00202
DVLIMITS
Date input is a holiday. Do you want to continue?
DV-LM-99998
DVLIMITS
Limits: Node $1 Unavailable. Utilization’s will be updated later.
DV-LM-99999
DVLIMITS
Limits Service - Unexpected Error - $1.
DV-MNT-001
DVMNT
Failed to create a new record.
DV-MNT-002
DVMNT
DV-MNT-003
DVMNT
Do you want to delete the record?
DV-MNT-004
DVMNT
Record successfully deleted.
DV-MNT-005
DVMNT
Failed to delete the record.
DV-MNT-006
DVMNT
DV-MNT-007
DVMNT
Do you want to close the record?
DV-MNT-008
DVMNT
Unauthorized records can not be closed.
DV-MNT-009
DVMNT
Record successfully closed.
DV-MNT-010
DVMNT
Failed to close the record.
DV-MNT-011
DVMNT
DV-MNT-012
DVMNT
Failed to unlock the record.
DV-MNT-013
DVMNT
DV-MNT-014
DVMNT
Do you want to reopen the record?
DV-MNT-015
DVMNT
Record successfully reopened.
DV-MNT-016
DVMNT
Failed to reopen the record.
DV-MNT-017
DVMNT
DV-MNT-018
DVMNT
Failed to save the record.
DV-MNT-019
DVMNT
DV-MNT-020
DVMNT
Unhandled exception while saving the record.
DV-MNT-021
DVMNT
Record successfully saved.
DV-MNT-022
DVMNT
Failed to authorize the record.
DV-MNT-023
DVMNT
DV-MNT-024
DVMNT
Failed to copy the record.
DV-MNT-025
DVMNT
DV-MNT-026
DVMNT
Do you want undo changes made to the record?
DV-MNT-101
DVDDT­MNT
Mandatory Field Derivative Type is NULL.
DV-MNT-102
DVDDT­MNT
Mandatory Field Type Description is NULL.
DV-MNT-103
DVDTMNT
Derivative Type is not Unique.
DV-MNT-104
CFDRTSRC
Mandatory Field Rate Source is NULL.
DV-MNT-105
CFDRTSRC
Rate Source is not Unique.
DV-MNT-106
CFDRTSRC
Mandatory field Description is NULL.
DV-MNT-107
STD­CLMNT
Mandatory Field Clearing House is NULL.
DV-MNT-108
STD­CLMNT
Clearing house is not Unique.
DV-MNT-109
STD­CLMNT
Mandatory Field Description is NULL.
DV-MNT-116
DVDLM­VAL
Mandatory fields cannot be null.
DV-MNT-201
DVDCN­VAL
Mandatory field Contract Ref No is NULL.
DV-MNT-202
DVDCN­VAL
Mandatory field Reval Date is NULL.
DV-MNT-203
DVDCN­VAL
Mandatory field In Fair Value is NULL.
DV-MNT-204
DVDCN­VAL
Mandatory field Out Fair Value is NULL.
DV-MNT-205
DVDCN­VAL
Mandatory field Net Fair Value is NULL.
DV-MNT-206
DVDCN­VAL
In and Out fair values are not synchronous with Net Fair Value.
DV-MNT-207
DVDCN­VAL
No Data found for the Contract Ref No.
DV-MNT-208
DVDCN­VAL
Reval Date should be before Next Working Date $1.
DV-MNT-209
DVDCN­VAL
Reval Date should be after the previous reval date $1.
DV-MNT-210
DVDCN­VAL
Reval Date already exists.
DV-MNT-215
DVDCN­RAT
Mandatory field Contract ref no is NULL.
DV-MNT-216
DVDCN­RAT
DV-MNT-217
DVDCN­RAT
Mandatory field Interest rate is NULL.
DV-MNT-218
DVDCN­RAT
Reval Date cannot be greater than the next working day.
DV-MNT-219
DVDCN­RAT
Reval date cannot be less than the previous reval date.
DV-MNT-220
DVDCN­RAT
Reval Date already exists for this contract.
DV-MNT-230
DVD­BRRAT
Mandatory field Rate Code is NULL.
DV-MNT-231
DVD­BRRAT
Mandatory field Rate Source is NULL.
DV-MNT-232
DVD­BRRAT
DV-MNT-233
DVD­BRRAT
DV-MNT-234
DVD­BRRAT
DV-MNT-235
DVD­BRRAT
Mandatory field Currency code is NULL.
DV-MNT-236
DVD­BRRAT
Mandatory field Period start date is NULL.
DV-MNT-237
DVD­BRRAT
Mandatory field Period end date is NULL.
DV-MNT-238
DVD­BRRAT
DV-MNT-239
DVD­BRRAT
Record for this period already exists.
DV-MNT-240
DVD­BRRAT
Period Start Date can not be before Reval Date $1.
DV-MNT-241
DVD­BRRAT
Period End Date should be after Period Start Date.
DV-MNT-252
DVDCP­MNT
Master Agreement Code is not Unique.
DV-MNT-253
DVDCP­MNT
Mandatory Field Master Agreement Code is NULL.
DV-MNT-254
DVDCP­MNT
Mandatory Fields are NULL.
DV-MNT-255
DVDCP­MNT
Active Contracts are existing for current Record.
DV-MNT-256
DVDMG­MNT
Mandatory Field Receiver ID / Medium is NULL.
DV-MNT-257
DVDMG­MNT
Receiver ID and Medium is not Unique.
DV-MNT-258
DVDMG­MNT
Message Type and CIF Id combination is not Unique.
DV-MNT-259
DVDMG­MNT
Message Type-CIF Id Combination is already defaulted.
DV-MNT-260
DVDMG­MNT
ALL-CIF Id Combination is already defaulted.
DV-MNT-301
DVD­PRMNT
Interest Not yet defined for product. Schedules will be incom­plete. Continue?.
DV-MNT-302
DVD­PRMNT
DV-MNT-303
DVD­PRMNT
Mandatory field Weekday is NULL.
DV-MNT-304
DVD­PRMNT
Mandatory field Start day is NULL.
DV-MNT-305
DVD­PRMNT
Mandatory field Start Month is NULL
DV-MNT-306
DVMNT
Revaluation method cannot be NULL.
DV-MNT-307
DVMNT
Mandatory field Denomination basis is NULL.
DV-MNT-308
DVD­PRMNT
Mandatory field Numerator method is NULL.
DV-MNT-309
DVD­PRMNT
Mandatory field Denominator method is NULL.
DV-MNT-310
DVD­PRMNT
For this derivative type only one IN interest component is allowed.
DV-MNT-311
DVD­PRMNT
For this derivative type only one OUT interest component is allowed.
DV-MNT-312
DVD­PRMNT
There should be one primary component for this derivative type
DV-MNT-313
DVD­PRMNT
Stop association not allowed for primary component.
DV-MNT-315
DVD­PRMNT
Not more than one component can be defined as primary component for IN leg.
DV-MNT-316
DVD­PRMNT
Mandatory field Leg type is NULL.
DV-MNT-317
DVD­PRMNT
Not more than one component can be defined as primary component for OUT leg.
DV-MNT-318
DVD­PRMNT
Interest components not defined.
DV-MNT-319
DVD­PRMNT
Schedules for some components not defined.
DV-MNT-320
DVD­PRMNT
No primary In leg interest components defined.
DV-MNT-321
DVD­PRMNT
No primary out leg interest components defined.
DV-MNT-322
DVD­PRMNT
Asynchronous Principal schedules not allowed for this deriv­ative type.
DV-MNT-323
DVD­PRMNT
Asynchronous IN interest schedules not allowed for this derivative type.
DV-MNT-324
DVD­PRMNT
Asynchronous OUT interest schedules not allowed for this derivative type.
DV-MNT-325
DVD­PRMNT
Asynchronous IN revision schedules not allowed for this derivative type.
DV-MNT-326
DVD­PRMNT
Asynchronous OUT revision schedules not allowed for this derivative type.
DV-MNT-328
DVD­PRMNT
DV-MNT-330
DVD­PRMNT
DV-MNT-331
DVD­PRMNT
Mandatory field Start reference is NULL.
DV-MNT-403
DVBAUDLY
Batch Processing completed successfully.
DV-MNT-411
DVBAUDLY
Unhandled exception while processing the batch.
DV-ONL-001
DVDC­NONL
Unhandled exception while creating a new contract.
DV-ONL-011
DVDC­NONL
Unhandled exception while copying the contract.
DV-ONL-012
DVDC­NONL
Failed to the copy the Contract.
DV-ONL-021
DVDC­NONL
Unhandled exception while deleting the contract.
DV-ONL-023
DVDC­NONL
Only the maker of the contract can delete the contract.
DV-ONL-024
DVDC­NONL
Do you want to delete the contract completely?
DV-ONL-025
DVDC­NONL
Do you want to undo all the changes made?
DV-ONL-026
DVDC­NONL
Contract Deleted Successfully.
DV-ONL-027
DVDC­NONL
Failed to delete the contract.
DV-ONL-031
DVDC­NONL
Unhandled exception while unlocking the contract.
DV-ONL-033
DVDC­NONL
The Version of the contract is not the latest version. Cannot be amended.
DV-ONL-034
DVDC­NONL
Contract is pending Authorization. Cannot be amended.
DV-ONL-035
DVDC­NONL
Contract is matured, Cannot be amended.
DV-ONL-036
DVDC­NONL
Only the maker of the contract can amend the contract.
DV-ONL-037
DVDC­NONL
Contract is Reversed or Terminated, Cannot Amend.
DV-ONL-038
DVDC­NONL
Failed to Amend the contract.
DV-ONL-041
DVDC­NONL
Unhandled exception while saving the contract.
DV-ONL-042
DVDC­NONL
Unhandled exception.
DV-ONL-043
DVDC­NONL
DV-ONL-044
DVDC­NONL
Failed to obtain contract amounts.
DV-ONL-045
DVDC­NONL
Contract Saved Successfully.
DV-ONL-046
DVDC­NONL
Failed to save the contract.
DV-ONL-051
DVDC­NONL
Unhandled exception while authorizing the contract.
DV-ONL-052
DVDC­NONL
Cannot Create the Parameter List.
DV-ONL-061
DVDC­NONL
Unhandled exception while keeping the contract on Hold.
DV-ONL-062
DVDC­NONL
Contract Ref No Is Null.
DV-ONL-063
DVDC­NONL
DV-ONL-082
DVDC­NONL
Product Code is NULL.
DV-ONL-092
DVDC­NONL
Maturity Date Cannot be Less than Value Date.
DV-ONL-093
DVDC­NONL
Maturity Date Cannot be less than the application Date.
DV-ONL-094
DVDC­NONL
Maturity Date $1 is a Holiday Will be Changed to $2.
DV-ONL-111
DVDC­NONL
Unhandled exception while defaulting Principal Schedules.
DV-ONL-121
DVDC­NONL
Unhandled exception while retrieving the contract amounts.
DV-ONL-132
DVDC­NONL
Not a valid product.
DV-ONL-141
DVDC­NONL
Unhandled exception while validating the Contract.
DV-ONL-142
DVDC­NONL
Mandatory field Counterparty is NULL.
DV-ONL-143
DVDC­NONL
Mandatory field Valued Date is NULL.
DV-ONL-144
DVDC­NONL
Mandatory field Maturity Date is NULL.
DV-ONL-145
DVDC­NONL
Mandatory field In Leg Currency is NULL.
DV-ONL-146
DVDC­NONL
Mandatory field In Leg Principal Amount is NULL.
DV-ONL-147
DVDC­NONL
Mandatory field In Leg interest Rate Type is NULL.
DV-ONL-148
DVDC­NONL
Mandatory field In Leg interest Rate Code is NULL.
DV-ONL-149
DVDC­NONL
Mandatory field In Leg interest Rate Source is NULL.
DV-ONL-150
DVDC­NONL
Mandatory field In Leg interest Tenor Code is NULL.
DV-ONL-152
DVDC­NONL
Mandatory field In Leg interest Rate Spread is NULL.
DV-ONL-153
DVDC­NONL
Mandatory field In Leg interest rate is NULL.
DV-ONL-154
DVDC­NONL
Mandatory field In Leg interest Flat amount is NULL.
DV-ONL-155
DVDC­NONL
Mandatory field Out Leg Currency Cannot is NULL.
DV-ONL-156
DVDC­NONL
Mandatory field Out Leg principal Amount is NULL.
DV-ONL-157
DVDC­NONL
Mandatory field Out Leg interest Rate Type is NULL.
DV-ONL-158
DVDC­NONL
Mandatory field Out Leg interest Rate Code is NULL.
DV-ONL-159
DVDC­NONL
Mandatory field Out Leg interest Rate Source is NULL
DV-ONL-160
DVDC­NONL
Mandatory field Out Leg interest Tenor Code is NULL.
DV-ONL-162
DVDC­NONL
Mandatory field Out Leg interest Rate Spread is NULL.
DV-ONL-163
DVDC­NONL
Mandatory field Out Leg interest rate is NULL.
DV-ONL-164
DVDC­NONL
Mandatory field Out Leg interest Flat amount is NULL.
DV-ONL-165
DVDC­NONL
Mandatory field Settlement Account is NULL.
DV-ONL-171
DVDC­NONL
DV-ONL-172
DVDC­NONL
Mandatory field Base Currency is NULL.
DV-ONL-173
DVDC­NONL
Mandatory field Reval Method is NULL.
DV-ONL-174
DVDC­NONL
Mandatory field Reval Rate Code is NULL.
DV-ONL-175
DVDC­NONL
Mandatory field Reval Rate Source is NULL.
DV-ONL-176
DVDC­NONL
Mandatory field Master Agreement Code is NULL.
DV-ONL-177
DVDC­NONL
Mandatory field Line Code is NULL.
DV-ONL-178
DVDC­NONL
Mandatory field Maturity Holiday Treatment is NULL.
DV-ONL-179
DVDC­NONL
Mandatory field Maturity Holiday Currency is NULL.
DV-ONL-180
DVDC­NONL
Mandatory field Maturity Financial Center is NULL.
DV-ONL-191
DVDC­NONL
Unhandled Exception While Terminating the contract.
DV-ONL-192
DVDC­NONL
The Contract is already terminated cannot terminate again.
DV-ONL-193
DVDC­NONL
Contract is pending Authorization. Cannot be terminated.
DV-ONL-194
DVDC­NONL
Do You want to terminate the contract?
DV-ONL-195
DVDC­NONL
Mandatory Field Termination type is NULL.
DV-ONL-196
DVDC­NONL
Mandatory Field Termination Currency is NULL.
DV-ONL-197
DVDC­NONL
Mandatory Field Termination Value is NULL.
DV-ONL-198
DVDC­NONL
Failed to terminate the contract.
DV-ONL-201
DVDC­NONL
DV-ONL-202
DVDC­NONL
Contract pending Authorization Cannot Reverse.
DV-ONL-203
DVDC­NONL
Do you want to reverse the contract completely?
DV-ONL-204
DVDC­NONL
Contract Reversed Successfully.
DV-ONL-205
DVDC­NONL
Failed to reverse the contract.
DV-ONL-206
DVDC­NONL
User Reference no should be Unique.
DV-PRN-001
DVCPR­DET
Unhandled exception while validating the schedules.
DV-PRN-002
DVCPR­DET
DV-PRN-003
DVCPR­DET
DV-PRN-004
DVCPR­DET
DV-PRN-005
DVCPR­DET
Mandatory field No Of Schedules is NULL.
DV-PRN-006
DVCPR­DET
Mandatory field Adjustment Type is NULL.
DV-PRN-007
DVCPR­DET
DV-PRN-011
DVCPR­DET
DV-PRN-012
DVCPR­DET
DV-PRN-013
DVCPR­DET
DV-PRN-014
DVCPR­DET
DV-PRN-015
DVCPR­DET
DV-PRN-021
DVCPR­DET
Unhandled exception while validating the Holiday Treatment Details.
DV-PRN-022
DVCPR­DET
DV-PRN-023
DVCPR­DET
DV-RET001
LDRPCSSM
To Date Should be greater than From Date.
DV-RVL-001
DVREVAL
Unhandled exception while building the queue array.
DV-RVL-002
DVREVAL
Failed to obtain the next working day.
DV-RVL-003
DVREVAL
Product is closed.
DV-RVL-004
DVREVAL
Product is not authorized.
DV-RVL-005
DVREVAL
DV-RVL-006
DVREVAL
Product is closed.
DV-RVL-007
DVREVAL
DV-RVL-011
DVREVAL
Unhandled exception while calculating the periodic reval date.
DV-RVL-021
DVREVAL
Unhandled exception while processing periodic revaluation.
DV-RVL-031
DVREVAL
Unhandled exception while populating reval records.
DV-RVL-101
DVREVAL
Unhandled exception while revaluing a contract.
DV-RVL-111
DVREVAL
Unhandled exception while processing product level revalua­tion.
DV-RVL-121
DVREVAL
Unhandled exception while processing revaluation.
DV-RVL-122
DVREVAL
DV-RVL-131
DVREVAL
DV-RVL-132
DVREVAL
DV-RVL-141
DVREVAL
DV-RVL-151
DVREVAL
DV-RVL-161
DVREVAL
Unhandled exception while building the accounting entry lists.
DV-RVL-171
DVREVAL
DV-RVL-301
DVREVAL
Unhandled exception while calculating the fair value of con­tract.
DV-RVL-302
DVREVAL
No confirmed records for the fair values of the contract.
DV-RVL-303
DVREVAL
No rates are maintained for the contract for carrying out revaluation.
DV-RVL-311
DVREVAL
Unhandled exception while calculating the leg fair value.
DV-RVL-313
DVREVAL
DV-RVL-314
DVREVAL
No rates are maintained for the branch to carry out revalua­tion.
DV-RVL-315
DVREVAL
Failed to round the fair value amount.
DV-RVL-321
DVREVAL
Unhandled exception while revaluation processing.
DV-RVL-331
DVREVAL
DV-RVL_312
DVREVAL
DV-RVN-001
DVRESET
DV-SCH-001
DVSCHED0
Unhandled Exception while getting next schedule Date.
DV-SCH-011
DVSCHED0
DV-SCH-021
DVSCHED0
Unhandled Exception while getting next periodic Date.
DV-SCH-031
DVSCHED0
Unhandled Exception while getting schedule Date.
DV-SCH-032
DVSCHED0
Error while checking whether the scheduled date is a holi­day.
DV-SCH-033
DVSCHED0
Improper Holiday maintenance.
DV-SCH-041
DVSCHED0
Unhandled Exception while Computing Reset Date.
DV-SCH-042
DVSCHED0
DV-SCH-043
DVSCHED0
DV-SCH-051
DVSCHED0
Unhandled Exception while Adding months.
DV-SCH-101
DVSCHED1
Unhandled Exception while defaulting Principal Schedules.
DV-SCH-102
DVSCHED1
Error While rounding the amount.
DV-SCH-111
DVSCHED1
Unhandled Exception while Exploding Principal Schedules.
DV-SCH-112
DVSCHED1
Principal amount Cannot be Negative.
DV-SCH-113
DVSCHED1
The Frequency and Frequency Units are Invalid.
DV-SCH-121
DVSCHED1
Unhandled Exception while defaulting Interest Schedules.
DV-SCH-131
DVSCHED1
Unhandled Exception while Exploding Interest Schedules.
DV-SCH-132
DVSCHED1
The Frequency and Frequency Units is Invalid.
DV-SCH-133
DVSCHED1
Interest amount is Negative.
DV-SCH-141
DVSCHED1
Unhandled Exception while Defaulting Revision Schedules.
DV-SCH-151
DVSCHED1
Unhandled Exception while Exploding Revision Schedules.
DV-SCH-152
DVSCHED1
DV-SCH-201
DVSCHED2
Unhandled Exception while Replicating Principal Schedules.
DV-SCH-211
DVSCHED2
Unhandled Exception while Replicating Principal Schedule Periods.
DV-SCH-221
DVSCHED2
Unhandled Exception while Replicating Interest Schedules.
DV-SCH-231
DVSCHED2
Unhandled Exception while Replicating Interest Schedule Periods.
DV-SCH-241
DVSCHED2
Unhandled Exception while Replicating Revision schedules.
DV-SCH-251
DVSCHED2
Unhandled Exception while Replicating Revision Schedule.
DV-SCH-301
DVSCHED3
Unhandled Exception while splitting the Contract Schedules.
DV-SCH-311
DVSCHED3
Unhandled Exception while re-defaulting Principal Sched­ules.
DV-SCH-321
DVSCHED3
Unhandled Exception while re-defaulting Non Principal Schedules.
DV-SCH-331
DVSCHED3
Unhandled Exception while re-defaulting Interest Schedules.
DV-SCH-341
DVSCHED3
Unhandled Exception while re-defaulting Revision sched­ules.
DV-SCH-401
DVSCHED4
DV-SCH-411
DVSCHED4
Unhandled Exception while replicating Interest Schedules.
DV-SCH-421
DVSCHED4
Unhandled Exception while replicating Revision Schedules.
DV-SET-001
DVAUSET0
Unhandled exception while processing for branch.
DV-SET-011
DVAUSET0
Unhandled exception while processing for contract.
DV-SET-021
DVAUSET0
Unhandled exception while processing principal compo­nents.
DV-SET-031
DVAUSET0
Unhandled exception while processing interest components.
DV-SET-041
DVAUSET0
Unhandled exception while populating interest liquidation amount.
DV-SET-051
DVAUSET0
Unhandled exception while populating interest accrual amounts.
DV-SET-063
DVAUSET0
Unhandled exception while populating interest accrual.
DV-SET-101
DVAUSET1
DV-SET-102
DVAUSET1
Reset not done for component $1for the period starting $2.
DV-SET-103
DVAUSET1
DV-SET-104
DVAUSET1
No data found for component $1for the period starting $2.
DV-SET-105
DVAUSET1
DV-SET-106
DVAUSET1
DV-SET-107
DVAUSET1
DV-SET-108
DVAUSET1
DV-SUB-001
DVSUB­SYS
Unhandled Exception while Processing Brokerage.
DV-SUB-011
DVSUB­SYS
Unhandled Exception while processing Advices.
DV-SUB-021
DVSUB­SYS
Unhandled Exception while Processing User Defined Fields.
DV-SUB-031
DVSUB­SYS
Unhandled Exception while processing Charge.
DV-SUB-041
DVSUB­SYS
Unhandled Exception while Processing MIS.
DV-SUB-042
DVSUB­SYS
Error While defaulting MIS details from contract.
DV-SUB-051
DVSUB­SYS
Unhandled Exception while picking settlement details.
DV-SUB-061
DVSUB­SYS
Unhandled Exception while processing tax.
DV-SUB-071
DVSUB­SYS
Unhandled Exception while processing module tags.
DV-SUB-081
DVSUB­SYS
Unhandled Exception while processing interest tags.
DV-SUB-082
DVSUB­SYS
No Settlement Details are maintained for the tag $1.
DV-SUB-091
DVSUB­SYS
Unhandled Exception while processing charge tags.
DV-SUB-101
DVSUB­SYS
Unhandled Exception while processing tax tags.
DV_AMR-001
DVA­MORT0
Unhandled exception while building queue array.
