Siebel CRM is an application to capture customer information. Information could vary from creating a customer profile to creating and operating various financial products available at the bank. The corresponding information is captured in Siebel Customer Relationship Management (CRM) and sent to Oracle FLEXCUBE, which is the backend processor, for further processing.
Bank in a Box (BIB) refers to a program as a part of which different Oracle applications in the financial services industry are integrated. In BIB, Oracle FLEXCUBE and Siebel CRM are integrated based on the standards of Oracle Application Integration Architecture (AIA). The messages exchanged between them are in Enterprise Business Messaging (EBM) format.
The functionalities available in Oracle FLEXCUBE and Siebel CRM are also available in BIB Solution by default.
There are two types of patterns available for exchanging message between Oracle FLEXCUBE and Siebel CRM. They are:
As mentioned earlier, message exchange between Oracle FLEXCUBE and Siebel CRM can be done in SYNC or FAF patterns. In SYNC pattern, the service requestor requests for the service and expects/waits for a response. In FAF, the service requestor requests for the service and does not expect/wait for a response.
In this exchange, CRM requests for service and expects/waits for a response from Oracle FLEXCUBE. The information exchange between Oracle FLEXCUBE and CRM is depicted below:
The system handles the errors during the process based on the following error types:
Error Type |
Error Handling |
Technical |
SOAP Fault message will be sent as response. |
Functional |
FaultNotification Element in EBM Header of response will contain the Oracle FLEXCUBE error code and message. |
While processing the message, Oracle FLEXCUBE will log the following information:
In this exchange, CRM requests for service and does not expect/wait for a response from Oracle FLEXCUBE.
The system handles the error during the process based on the following error types:
Error Type |
Error Handling |
Technical |
MDB will retry listening to the EBM request, and if it finds the message to be repeated, it will send the repeated message directly to the Dead Letter Queue. |
Functional |
MDB will send the repeated message directly to the Dead Letter Queue. |
In this exchange, Oracle FLEXCUBE requests for service and expects/waits for a response from CRM. The information exchange between Oracle FLEXCUBE and CRM is depicted below:
If there is any error during the process, the system will handle it based on the following error types:
Error Type |
Error Handling |
Technical |
SOAP Fault message will be received as a response. |
Functional |
Fault Notification Element in EBM Header of the response will contain the SIEBEL error code and message. |
In this exchange, Oracle FLEXCUBE requests for service and does not expect/wait for a response from CRM. The information exchange between Oracle FLEXCUBE and CRM is depicted below:
Error Type |
Error Handling |
Technical |
MDB will queue up the messages to Dead Letter Queue. |
Siebel CRM requests for and receives XML messages from Oracle FLEXCUBE in EBM format. The functional approach of single customer view is as follows:
Siebel CRM inquires from Oracle FLEXCUBE using SYNC message pattern in AIA standards. The WSDL for the service provided by Oracle FLEXCUBE is in line with the AIA’s Enterprise Business Service provided in the Enterprise Object Library (EOL). The service details are as follows.
Service Details |
WSDL |
BankingAndWealthManagementCustomerPartyEBSV2.wsdl |
Service Name |
CustomerPartyService |
Operation |
QueryCustomerParty |
Description |
CustomerParty Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\CustomerParty\V2\CustomerPartyEBM.xsd |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Oracle FLEXCUBE receives Customer ID along with the request for XML message from Siebel CRM and provides customer details to Siebel CRM. The information received and provided by Oracle FLEXCUBE is as follows:
Input |
Output |
Customer ID |
Customer Details |
The message details are as follows:
EBM Root Element |
Message Name |
Direction Of Flow |
QueryCustomerPartyEBM |
QueryCustomerPartyReqMsg |
REQUEST |
QueryCustomerPartyResponseEBM |
QueryCustomerPartyRespMsg |
RESPONSE |
To build reply messages for a summary view of all the accounts and limit the facilities of an existing customer in the bank, current Single Customer View service, ‘FCUBSSCVService’ is used as a part of the Oracle FLEXCUBE gateway service for query operation, ‘QuerySCVCustSumm’. The service details are as follows:
Service Name |
Operation Code |
Description |
FCUBSSCVService |
QuerySCVCustSumm
Querying for a summary view of all the accounts and limit facility that the customer owns in the bank |
The inquiry and handoff messages initiated from Oracle FLEXCUBE to CRM and vice versa are in EBM format. The Web Service Definition Language (WSDL) for the service provided by Siebel should be in line with the AIA’s Enterprise Business Service (EBS) provided in the Enterprise Object Library (EOL).
In Oracle FLEXCUBE, you can create leads for both prospective customer and existing customers.
The Create Lead process comprises of the following processes:
Customer details - existing customer or a prospect is fetched from CRM using SYNC message pattern in AIA standards. The request for the details is sent from Oracle FLEXCUBE to CRM as a query.
You can search for individual and corporate CRM customer/prospect details in the ‘Customer Search’ screen. To invoke this screen, type ‘STSCUSSH’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
Note
It is mandatory to specify the customer type as a search criteria.
For more information on ‘Customer Search’ screen, refer the section ‘Searching for Customers’ in the chapter ‘Maintaining Customer Information Files’ in the Core Entities User manual.
The results of the query are displayed as multiple entry blocks in the ‘Customer Search’ screen. You can select any one of the customer that are displayed in Oracle FLEXCUBE.
Service Details |
WSDL |
Service Name |
Operation |
QueryCustomerPartyList |
Description |
Customer Party Enterprise Business Service |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
SYNC |
EBM Root Element |
Message Name |
Direction Of Flow |
QueryCustomerPartyListEBM |
QueryCustomerPartyListReqMsg |
Request |
QueryCustomerPartyListResponseEBM |
QueryCustomerPartyListRespMsg |
Response |
For more information on message exchange pattern between Oracle FLEXCUBE and CRM, refer ‘SYNC - CRM Provider’ section of this User Manual.
The Offer details for the customer can be fetched from Siebel CRM using SYNC message pattern in AIA standards. Oracle FLEXCUBE provides the customer reference number and branch code to Siebel CRM; and requests for offer details as a query.
You can query the CRM offers using the ‘Offer Query’ screen. To invoke this screen, type ‘STSOFRQY’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
You can search for the offers based on one or more of the following parameters:
Once you have set the search criteria, click ‘Execute Query’ button. The system displays all valid offers that match the search criteria.
You can select any one of the offers that are displayed on this screen.
Service Details |
WSDL |
BankingAndWealthManagementMarketingOfferEBSV1.wsdl |
Service Name |
MarketingOfferService |
Operation |
QueryMarketingOfferList |
Description |
Marketing Offer Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\MarketingOffer\V1\MarketingOfferEBM.xsd |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
SYNC |
EBM Root Element |
Message Name |
Direction Of Flow |
QueryMarketingOfferListEBM |
QueryMarketingOfferListReqMsg |
Request |
QueryMarketingOfferListResponseEBM |
QueryMarketingOfferListRespMsg |
Response |
For more information, refer the section ‘Querying Offers’ in the chapter ‘Maintaining Mandatory Information’ in the Core Entities User manual.
The products and offers that are rendered to a customer and the response of the customer to the same can be created in Oracle FLEXCUBE using FAF message pattern in AIA terminology.
You can create leads in Oracle FLEXCUBE using ‘Lead Maintenance’ screen. To invoke this screen, type ‘STDLEDMT’ in the field at the top right corner of the application toolbar and click the adjoining arrow button.
Note
You can maintain a lead either for products or for offers. The system will not allow you to maintain one lead for both products and offers.
For more information, refer the section ‘Maintaining Lead Details’ in the chapter ‘Maintaining Mandatory Information’ in the Core Entities User manual.
Service Details |
WSDL |
BankingAndWealthManagementSalesOpportunityEBSV1.wsdl |
Service Name |
SalesOpportunityService |
Operation |
CreateSalesOpportunity |
Description |
Sales Opportunity Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\SalesOpportunity\V1\SalesOpportunityEBM.xsd |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
EBM Root Element |
Message Name |
Direction Of Flow |
CreateSalesOpportunityEBM |
CreateSalesOpportunityReqMsg |
REQUEST |
For more information on message exchange pattern between Oracle FLEXCUBE and CRM, refer ‘FAF - CRM Provider’ section of this User Manual.
If the customer is new to Oracle FLEXCUBE & Siebel CRM, a customer party is created in Siebel CRM. The WSDL for the service provided by Siebel CRM should be in line with the AIA’s EBS provided in the EOL. Oracle FLEXCUBE will request for and receive the information in EBM format.
Oracle FLEXCUBE creates customer party message and uses SYNC message pattern in AIA standards. The service details are as follows:
Service Details |
WSDL |
Service Name |
Operation |
CreateCustomerParty |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
SYNC |
EBM Root Element |
Message Name |
Direction Of Flow |
CreateCustomerPartyEBM |
CreateCustomerPartyReqMsg |
Request |
CreateCustomerPartyResponseEBM |
CreateCustomerPartyRespMsg |
Response |
If Know Your Customer (KYC) validation fails for a customer during any of the customer and account origination process, the information is propagated to the Siebel CRM system. Oracle FLEXCUBE updates about the KYC failure to Siebel CRM using FAF message pattern in AIA standards. The service details are as follows:
Service Details |
WSDL |
Service Name |
Operation |
UpdateCustomerParty |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
EBM Root Element |
Message Name |
Direction Of Flow |
UpdateCustomerPartyEBM |
UpdateCustomerPartyReqMsg |
REQUEST |
UpdateCustomerPartyResponseEBM |
UpdateCustomerPartyRespMsg |
RESPONSE |
Origination process comprises customer and account origination. The origination process in Oracle FLEXCUBE is facilitated through the Business Process Execution Language (BPEL) processes. Oracle FLEXCUBE and Siebel CRM exchange messages in EBM format and the service interfaces in EBS that conforms to AIA standards. Hence, the following BPEL processes are changed to conform to AIA standards.
To open a savings account in Oracle FLEXCUBE, details of the customer - prospect or an existing customer - need to be fetched from CRM.
In case of a prospect customer, create prospect request is sent from Oracle FLEXCUBE to Siebel CRM after entering the customer information in the opening form. The function id STDSA050 is changed to exchange EBM messages with the CRM.
For further details on this screen, refer to Origination - Savings Account Creation user manual.
In case of an existing customer, the request for customer details is sent from Oracle FLEXCUBE to CRM as a query. The results of the query are displayed in the ‘Customer Search’ screen. You can select any one of the customers to create the savings account in Oracle FLEXCUBE. While receiving and verifying savings account opening form and other documents, the ‘Customer Search’ screen (STSCUSSH) is changed to exchange EBM messages with the CRM.
For more information, refer the chapter ‘Savings Account Creation’ in the ‘Savings Account Creation’ BPEL Process Flow Manual.
To open a current account in Oracle FLEXCUBE, details of the customer - prospect or an existing customer - need to be fetched from CRM.
In case of a prospect customer, create prospect request will be sent from Oracle FLEXCUBE to CRM after entering the customer information in the opening form. The function id (STDCA050) is changed to exchange EBM messages with the Siebel CRM.
For further details on this screen, refer to Origination - Current Account Creation user manual.
In case of an existing customer, the request for the customer details is sent from Oracle FLEXCUBE to Siebel CRM as a query. The results of the query are displayed in the ‘Customer Search’ screen. You can select any one of the customer to create the account in Oracle FLEXCUBE. While receiving and verifying current account opening form and other documents, the ‘Customer Search’ screen (STSCUSSH) changed during savings account opening process is used.
For more information, refer the chapter ‘Current Account Creation’ in the ‘Current Account Creation’ BPEL Process Flow Manual.
To create a corporate customer in Oracle FLEXCUBE, details of the customer - prospect or an existing customer - need to be fetched from CRM.
In case of a prospect customer, create prospect request will be sent from Oracle FLEXCUBE to Siebel CRM after entering the customer information in the account opening form. The function id (STDCC050) changed during savings account opening process is used.
For further details, refer to Origination - Corporate Customer Creation user manual.
In case of an existing customer, the request for the customer details is sent from Oracle FLEXCUBE to CRM as a query. The results of the query are displayed in the ‘Customer Search’ screen. You can select any one of the customer to create the customer details in Oracle FLEXCUBE. While entering the details of the prospective customers, the ‘Customer Search’ screen (STSCUSSH) changed during savings account opening process is used.
For more information, refer the chapter ‘Corporate Customer Creation’ in the ‘Corporate Customer’ BPEL Process Flow Manual.
To open a retail term deposit in Oracle FLEXCUBE, details of the customer - prospect or an existing customer - need to be fetched from CRM.
In case of a prospect customer, create prospect request will be sent from Oracle FLEXCUBE to Siebel CRM after entering the customer information in the account opening form. The function id (ORDTDRVY) changed during savings account opening process is used.
For further details, refer to Origination - Retail Term Deposit Account Creation user manual.
In case of an existing customer, the request for the customer details is sent from Oracle FLEXCUBE to Siebel CRM as a query. The results of the query are displayed in the ‘Customer Search’ screen. You can select any one of the customer to create the deposit in Oracle FLEXCUBE. While receiving and verifying current account opening form and other documents, the ‘Customer Search’ screen (STSCUSSH) changed during savings account opening process is used.
For more information, refer the chapter ‘Retail Term Deposit Account Creation’ in the ‘Term Deposit’ BPEL Process Flow Manual.
When KYC validation fails for a customer while updating customer party, Siebel CRM process is invoked from the above origination processes to send and update the information of the new customer. The process is changed to perform the necessary transformations in order to exchange messages in EBM format with Siebel CRM.
For more information on message exchange pattern between Oracle FLEXCUBE and CRM, refer ‘SYNC - CRM Provider’ and ‘FAF - CRM Provider’ section of this User Manual.
Oracle FLEXCUBE sends and receives inquiry XML messages from Siebel CRM in EBM format using SYNC pattern in AIA standards. The WSDL for the service provided by Oracle FLEXCUBE is in line with the AIA’s EBS provided in the EOL.
Service Details |
WSDL |
BankingAndWealthManagementDepositAccountEBSV1.wsdl |
Service Name |
DepositAccountService |
Operation |
QueryDepositAccount |
Description |
DepositAccount Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\DepositAccount\V1\DepositAccountEBM.xsd |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Account Number |
Current or Savings Account Details |
Branch Code |
The messages details are given below:
EBM Root Element |
Message Name |
Direction Of Flow |
QueryDepositAccountEBM |
QueryDepositAccountReqMsg |
Request |
QueryDepositAccountResponseEBM |
QueryDepositAccountRespMsg |
Response |
To build reply message for CASA account, existing single customer view service ‘FCUBSAccService’ is used as a part of the gateway for query operation ‘QueryCustAcc’.
Service Name |
Operation Code |
Description |
FCUBSAccService |
QueryCustAcc |
For querying CASA account |
Service Details |
WSDL |
BankingAndWealthManagementFinancialTransactionEBSV1.wsdl |
Service Name |
FinancialTransactionService |
Operation |
QueryFinancialTransaction |
Description |
FinancialTransaction Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\FinancialTransaction\V1\FinancialTransactionEBM.xsd |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Account Number |
CASA transaction details |
Branch Code |
From Date |
To Date |
EBM Root Element |
Message Name |
Direction Of Flow |
QueryFinancialTransactionEBM |
QueryFinancialTransactionReqMsg |
Request |
QueryFinancialTransactionResponseEBM |
QueryFinancialTransactionRespMsg |
Response |
To build a reply message for retail term deposit account, existing single customer view service ‘FCUBSSCVService’ is used as part of the gateway for query operation ‘QuerySCVCATxnDetails’.
Service Name |
Operation Code |
Description |
FCUBSSCVService |
QuerySCVCATxnDetails |
For querying the transaction details for the CASA account |
The service details are given below:
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Account Number |
Retail Term transaction details |
Branch Code |
From Date |
To Date |
EBM Root Element |
Message Name |
Direction Of Flow |
Request |
Response |
To build a reply message for retail term deposit account, existing single customer view service ‘FCUBSSCVService’ is used as part of the gateway for query operation ‘QuerySCVTDTxnDetails’.
Service Name |
Operation Code |
Description |
FCUBSSCVService |
QuerySCVTDTxnDetails |
For querying the transaction details for the term deposit account |
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Account Number |
Retail Term Deposit Account Details |
Branch Code |
EBM Root Element |
Message Name |
Direction Of Flow |
Request |
Response |
To build a reply message for retail term deposit account, existing single customer view service “FCUBSAccService” will be used as part of the gateway for query operation “QueryTDCustAcc”.
Service Name |
Operation Code |
Description |
FCUBSAccService |
QueryTDCustAcc |
For querying retail term deposit account |
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Account Number |
Retail Term Deposit Redemption Details |
Branch Code |
EBM Root Element |
Message Name |
Direction Of Flow |
Request |
Response |
To build a reply message for retail term deposit account, existing single customer view service “FCUBSTDService” is used as part of the gateway for query operation “QueryTDRedemption”.
Changes are made in “QueryTDRedemption” to send all the previously redeemed amounts to CRM during the query operation.
Service Name |
Operation Code |
Description |
FCUBSTDService |
QueryTDRedemption |
For querying retail term deposit redemption account |
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Account Number |
Corporate Deposit Contract Details |
Branch Code |
EBM Root Element |
Message Name |
Direction Of Flow |
Request |
Response |
Existing Corporate Deposit service “FCUBSLDService” is used as part of the gateway for query operation “QueryLDContract” to build a reply message for Corporate Deposit Contract
Service Name |
Operation Code |
Description |
FCUBSLDService |
QueryLDContract |
For querying corporate deposit contract details |
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Account Number |
Branch Code |
EBM Root Element |
Message Name |
Direction Of Flow |
Request |
Response |
Existing single customer view service “FCUBSSCVService” is used as part of the gateway for query operation “QuerySCVSISum” to build a reply message for Standing Instructions.
Service name |
Operation Code |
Description |
FCUBSSCVService |
QuerySCVSISum |
For querying all the standing instruction contracts maintained for the debit account and account branch |
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Account Number |
Branch Code |
EBM Root Element |
Message Name |
Direction Of Flow |
REQUEST |
RESPONSE |
Existing single customer view service “FCUBSSCVService” is used as part of the gateway for query operation “QuerySCVPCSum” to build a reply message for Standing Instructions.
Service name |
Operation Code |
Description |
FCUBSSCVService |
QuerySCVPCSum |
For querying all the periodic instruction contracts maintained for the customer account and branch |
Service Details |
WSDL |
BankingAndWealthManagementLoanAccountEBSV1.wsdl |
Service Name |
LoanAccountService |
Operation |
QueryLoanAccount |
Description |
LoanAccount Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\LoanAccount\V1\LoanAccountEBM.xsd |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Loan Account Number |
Loan Account Details |
Branch Code |
EBM Root Element |
Message Name |
Direction Of Flow |
QueryLoanAccountEBM |
QueryLoanAccountReqMsg |
REQUEST |
QueryLoanAccountResponseEBM |
QueryLoanAccountRespMsg |
RESPONSE |
Existing Loan account service “FCUBSCLService” is used as part of the gateway for query operation “QueryAccount” to build a reply message for Corporate Deposit Contract.
Service Name |
Operation Code |
Description |
FCUBSCLService |
QueryAccount |
For querying loan account details |
Service Details |
WSDL |
BankingAndWealthManagementDocumentaryCollectionEBSV1.wsdl |
Service Name |
DocumentaryCollectionService |
Operation |
QueryDocumentaryCollection |
Description |
DocumentaryCollection Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\DocumentaryCollection\V1\DocumentaryCollectionEBM.xsd |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Contract Reference Number |
Bills & Collections Contract Details |
Branch |
EBM Root Element |
Message Name |
Direction Of Flow |
QueryDocumentaryCollectionEBM |
QueryDocumentaryCollectionReqMsg |
Request |
QueryDocumentaryCollectionResponseEBM |
QueryDocumentaryCollectionRespMsg |
Response |
Existing Bills & Collections service “FCUBSBCService” is used as part of the gateway for query operation “QueryBCContract” to build a reply message for Bills & Collections contract.
Service Name |
Operation Code |
Description |
FCUBSBCService |
QueryBCContract |
For querying Bills & Collections contract |
Service Details |
WSDL |
BankingAndWealthManagementLineOfCreditEBSV1.wsdl |
Service Name |
LineOfCreditService |
Operation |
QueryLineOfCredit |
Description |
LineOfCredit Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\LineOfCredit\V1\LineOfCreditEBM.xsd |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Liability Code |
Limit Details |
Line Code |
Line Serial Number |
EBM Root Element |
Message Name |
Direction Of Flow |
QueryLineOfCreditEBM |
QueryLineOfCreditReqMsg |
Request |
QueryLineOfCreditResponseEBM |
QueryLineOfCreditRespMsg |
Response |
Existing Enterprise Limit and Collateral Management (ELCM) Service “LSFacilityService” is used as part of the gateway for query operation “FacilityExecuteQuery” to build a reply message for line information.
Service Name |
Operation Code |
Description |
LSFacilityService |
FacilityExecuteQuery |
For querying limit information contract details |
Service Details |
WSDL |
BankingAndWealthManagementDocumentaryCreditEBSV1.wsdl |
Service Name |
DocumentaryCreditService |
Operation |
QueryDocumentaryCredit |
Description |
DocumentaryCredit Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\DocumentaryCredit\V1\DocumentaryCreditEBM.xsd |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Letter Of Credit Contract Details |
Branch |
EBM Root Element |
Message Name |
Direction Of Flow |
QueryDocumentaryCreditEBM |
QueryDocumentaryCreditReqMsg |
Request |
QueryDocumentaryCreditResponseEBM |
QueryDocumentaryCreditRespMsg |
Response |
Existing Letter Of Credit service “FCUBSLCService” is used as part of the gateway for query operation “QueryLCContract” to build a reply message for Letter Of Credit & Guarantees contract.
Service Name |
Operation Code |
Description |
FCUBSLCService |
QueryLCContract |
For querying Letter Of Credit contract |
Service Details |
WSDL |
BankingAndWealthManagementBankGuaranteeEBSV1.wsdl |
Service Name |
BankGuaranteeService |
Operation |
QueryBankGuarantee |
Description |
BankGuarantee Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\BankGuarantee\V1\BankGuaranteeEBM.xsd |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
SYNC |
Input |
Output |
Guarantees Contract Details |
Branch |
EBM Root Element |
Message Name |
Direction Of Flow |
QueryBankGuaranteeEBM |
QueryBankGuaranteeReqMsg |
REQUEST |
QueryBankGuaranteeResponseEBM |
QueryBankGuaranteeRespMsg |
RESPONSE |
Service Name |
Operation Code |
Description |
FCUBSLCService |
QueryLCContract |
For querying Guarantees contract |
Oracle FLEXCUBE handoffs SML messages to Siebel CRM in EBM format using FAF pattern in AIA standards. The WSDL for the service provided by Siebel CRM will be in line with the AIA’s EBS provided in the EOL. Oracle FLEXCUBE handoffs the following details to Siebel CRM:
Whenever a new customer is created in the ‘Customer Maintenance’ screen and authorized for the current application date, Oracle FLEXCUBE will handoff the customer details to Siebel CRM. The service details are given below:
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
The message details are given below:
EBM Root Element |
Message Name |
Direction Of Flow |
Request |
Response |
For more information on the screen, refer the section ‘Invoking Customer Information Screen’ in the chapter ‘Maintaining Customer Information Files’ in the Core Entities User Manual.
Whenever an existing customer details are successfully modified and authorized for the current application date in the ‘Customer Maintenance’ screen, Oracle FLEXCUBE will handoff the modified customer details to CRM using JMS queue approach. The service details are given below:
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
Message Name |
Message Exchange Pattern |
Description |
Request only |
This operation is used to Update a CustomerParty. |
Whenever a new current or savings account is created and authorized for the current application date through the ‘Customer Accounts Maintenance’ screen, Oracle FLEXCUBE will handoff the customer account details to Siebel CRM using JMS queue approach. The service details are given below:
Service Details |
WSDL |
Service Name |
Operation |
CreateDepositAccount |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
Message Name |
Description |
CreateDepositAccountReqMsg |
Request only |
This operation is used to Create a DepositAccount EBO. |
For more information on the screen, refer the section ‘Invoking Customer Accounts Screen’ in the chapter ‘Maintaining Customer Accounts’ in the Core Entities User Manual.
Whenever the joint holder details of CASA account is modified and authorized for the current application date through the ‘Customer Accounts Maintenance’ screen, Oracle FLEXCUBE will handoff the account details to Siebel CRM using JMS queue approach. The service details are given below:
Service Details |
WSDL |
Service Name |
Operation |
UpdateDepositAccount |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
Message Name |
Description |
UpdateDepositAccountReqMsg |
REQUEST_ONLY |
This operation is used to Update CASA Account. |
Whenever a new retail term deposit account is created through the ‘IC Special Conditions Maintenance’ screen, Oracle FLEXCUBE will handoff the new term deposit account details to Siebel CRM using JMS queue approach. The service details are given below:
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
Message Name |
Description |
Request only |
For more information on the screen, refer the section ‘Maintaining Time Deposit Accounts’ in the chapter ‘Maintaining Tax Allowance Limit’ in the Core Entities User Manual.
Whenever the joint holder details of retail deposit account is modified and authorized for the current application date through the ‘IC Special Conditions Maintenance’ screen, Oracle FLEXCUBE will handoff the term deposit account details to CRM using JMS queue approach.
The corresponding service details are given below:
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
The message details of are given below:
Message Name |
Description |
UpdatedepositAccountReqMsg |
REQUEST_ONLY |
This operation is used to Update Deposit Account. |
Whenever a new corporate deposit account is created through the ‘Corporate Deposits Contract Input’ screen, Oracle FLEXCUBE will handoff the corporate deposit account details to CRM using JMS queue approach. The service details are given below:
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
Message Name |
Description |
REQUEST_ONLY |
For more information on the screen, refer the section ‘Features of Corporate Deposits Contract Input Screen’ in the chapter ‘Capturing Details of Deposit’ in the Corporate Deposit User Manual.
Whenever a new loan account is created through the ‘Account Details’ screen, Oracle FLEXCUBE will handoff the new loan account details to Siebel CRM using JMS queue approach. The corresponding service details are given below:
Service Details |
WSDL |
Service Name |
Operation |
CreateLoanAccount |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
Message Name |
Description |
CreateLoanAccountReqMsg |
Request only |
For more information on the screen, refer the section ‘Creating a Loan Account’ in the chapter ‘Account Creation’ in the Retail Lending User Manual.
Whenever Value Dates are amended and authorized on a loan account for the execution date same as current application date through the ‘Amendments’ screen, Oracle FLEXCUBE will handoff the loan account details to CRM using the new JMS queue approach.
The corresponding services details are given below:
Service Details |
WSDL |
Service Name |
Operation |
UpdateLoanAccount |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
Message Name |
Description |
UpdateLoanAccountReqMsg |
REQUEST_ONLY |
For more information on the screen, refer the section ‘Loan Amendments’ in the chapter ‘Operations’ in the Retail Lending User Manual.
Whenever the primary customer is changed to a new customer, loan is reassigned and authorized for the current application date through the ‘Account Details’ screen, Oracle FLEXCUBE will handoff the loan re-assignment account details to CRM using JMS queue approach. The corresponding service details are as follows:
Service Details |
WSDL |
Service Name |
Operation |
UpdateLoanAccount |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
Message Name |
Description |
REQUEST_ONLY |
This operation is used to Update Loan Account. |
Stop Payment and Check Book Request screens were converted to extensibility. Whenever a stop payment is authorized, Oracle FLEXCUBE will handoff the stop payment, check book request or standing instruction details to Siebel CRM using JMS queue approach.
Service Details |
WSDL |
BankingAndWealthManagementCustomerInteractionEBSV1.wsdl |
Service Name |
CustomerInteractionService |
Operation |
CreateCustomerInteraction |
Description |
CustomerInteraction Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\CustomerInteraction\V1\CustomerInteractionEBM.xsd |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
Message Name |
Description |
CreateCustomerInteractionReqMsg |
REQUEST_ONLY |
This operation is used to create Customer Interaction. |
Siebel CRM sends handoff XML messages to Oracle FLEXCUBE in EBM format using FAF pattern in AIA standards. The WSDL for the service provided by Oracle FLEXCUBE is in line with the AIA’s EBS provided in the EOL.
Whenever an existing customer attributes, which are common across for contact or account (individual or corporate type of customer) are modified in the ‘Customer Maintenance’ screen, Siebel CRM handoff the customer details (both the modified and unmodified details) to Oracle FLEXCUBE using JMS queue approach.
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
FAF |
Message Name |
Description |
REQUEST_ONLY |
This operation is used to Update a Customer Party EBO |
To modify customer details in ‘Modify Customer’ operation, ‘FCUBS Customer Service’ is used as a part of the gateway service. The corresponding message details are given below:
Service name |
Operation Code |
Description |
FCUBSCustomerService |
ModifyCustomer |
For updating the customer details |
For more information on message exchange pattern between Oracle FLEXCUBE and CRM, refer ‘FAF – Oracle FLEXCUBE Provider’ section of this User Manual.
Whenever an existing customer account address attributes, which are common for CASA and Retail Deposit accounts, are modified in the respective screen, Siebel CRM hands off the customer account address details (both the modified and unmodified details) to Oracle FLEXCUBE using JMS queue approach.
Service Details |
WSDL |
Service Name |
Operation |
Description |
EBM XSD |
Provider |
Oracle FLEXCUBE |
Consumer |
CRM |
Message Pattern |
FAF |
Message Name |
Description |
REQUEST_ONLY |
This operation is used to update a DepositAccount EBO |
To modify customer details in ‘ModifyCustAcc’ operation, ‘FCUBSAccService’ is used as a part of the gateway service. The corresponding message details are given below:
Service name |
Operation Code |
Description |
FCUBSAccService |
ModifyCustAcc |
For updating the CASA account address details |
For more information on the screen, refer the chapter ‘Maintaining Customer Accounts’ in the Current and Savings Account User Manual.
To modify TD account address details ‘ModifyTDCustAcc’ operation, ‘FCUBSAccService’ is used as a part of the gateway service. The corresponding message details are given below:
Service name |
Operation Code |
Description |
FCUBSAccService |
ModifyTDCustAcc |
For updating the TD account address details |
For more information on the screen, refer the chapter ‘TD Account’ in the Term Deposits User Manual.
Oracle FLEXCUBE inquires and handoffs XML messages to Siebel CRM in EBM format. The WSDL for the service provided by Siebel should be in line with the AIA’s EBS provided in the EOL. The function id STDSRQST is modified to invoke web service operations of Siebel CRM and the message is transformed from Oracle FLEXCUBE format to EBM format.
Oracle FLEXCUBE creates, modifies and inquires service requests using SYNC message pattern in AIA standards. Oracle FLEXCUBE receives the response and Service Requests are displayed on the screen. The functional approach of Service Request is as follows:
After creating a Service Request, the service request number is displayed on to the screen. The service details are as follows:
Service Details |
WSDL |
BankingAndWealthManagementServiceRequestEBSV1.wsdl |
Service Name |
ServiceRequestService |
Operation |
CreateServiceRequest |
Description |
Service Request Enterprise Business Service |
EBM XSD |
EnterpriseObjectLibrary\Industry\BankingAndWealthManagement\EBO\ServiceRequest\V1\ServiceRequestEBM.xsd |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
SYNC |
The messages details are as follows:
EBM Root Element |
Message Name |
Direction Of Flow |
CreateServiceRequestEBM |
CreateServiceRequestReqMsg |
REQUEST |
CreateServiceRequestResponseEBM |
CreateServiceRequestRespMsg |
RESPONSE |
After modifying a Service Request, the service request number is displayed on to the screen. The service details are as follows:
Service Details |
WSDL |
Service Name |
Operation |
UpdateServiceRequest |
Description |
Service Request Offer Enterprise Business Service |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
FAF |
EBM Root Element |
Message Name |
Direction Of Flow |
UpdateServiceRequestEBM |
UpdateServiceRequestReqMsg |
REQUEST |
UpdateServiceRequestResponseEBM |
UpdateServiceRequestRespMsg |
RESPONSE |
The service information is given below:
Service Details |
WSDL |
Service Name |
Operation |
QueryServiceRequestList |
Description |
EBM XSD |
Provider |
CRM |
Consumer |
Oracle FLEXCUBE |
Message Pattern |
SYNC |
The message information is given below:
EBM Root Element |
Message Name |
Direction Of Flow |
QueryServiceRequestListEBM |
QueryServiceRequestListReqMsg |
REQUEST |
QueryServiceRequestListResponseEBM |
QueryServiceRequestListRespMsg |
RESPONSE |
When Siebel CRM inquires a Service Request, Contact Date, Target Date of Closure and Actual Date of Closure fields in the Service Request Input screen are populated. To invoke this screen, type ‘STDSRQST’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
For further details on this screen, refer to the section ‘Maintaining Service Request Input Details’ in chapter ‘Maintaining Mandatory Information’ of Core Entities user manual.
In Service Request Input screen, Contact Date, Target Date of Closure and Actual Date of Closure are read-only fields. Service Request Type value synchronizes with the CRM values. The other values which synchronize with the Service Request Type values are as follows:
You can view the summary of service request details in the ‘Service Request Fetch’ screen. To invoke this screen, type ‘STSSRQST’ in the field at the top right corner of the Application tool bar and click on the adjoining arrow button.
Note
It is mandatory to specify the Service Number as a search criteria.
For further details on this screen, refer to the section ‘Viewing Service Request Details’ in chapter ‘Maintaining Mandatory Information’ of Core Entities user manual.
In an integration perspective, the List Of Values (LOV) in Oracle FLEXCUBE can be broadly classified in the following types:
Static values remain constant and are not subjected to changes. For example, Account type.
Dynamic values are subjected to changes. For example, Branch, Product etc,
Day-0-Dynamic values are created during day-zero. For example, Currency, Country etc,
