1. Preface
1.1 Introduction
This manual is designed to help acquaint you with the integration of Oracle FLEXCUBE and Oracle FLEXCUBE Document Management System Interface.
1.2 Audience
This manual is intended for the following User/User Roles:
Role
Function
Back office data entry Clerks
Input functions for maintenances
Back office Managers/Officers
Authorization functions
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Organization
This manual is organized as follows:
Chapter
Description
Chapter 1
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual.
Chapter 2
Oracle FLEXCUBE - DMS Integration explains about Oracle IPM which is an external Document Management System with which Oracle FLEXCUBE integrates for document processes.
1.5 Acronyms and Abbreviations
Abbreviation
Description
DMS
IPM
Imaging and Process Management
1.6 Organization
This document talks about the required maintenance and further processing of data transfer between Oracle FLEXCUBE and DMS.
1.7 Glossary of Icons
This User Manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
1.8 Related Documents
You can refer to the following documents:
