1. Preface
1.1 Introduction
This manual is designed to help acquaint you with the interface between Oracle FLEXCUBE and the other systems within your bank.
This manual provides you extensive explanations about the various maintenances required for the smooth exchange of data between Oracle FLEXCUBE and the applicable systems through the interface. It also gives you an insight into the processes involved in the actual exchange of data.
1.2 Audience
This manual is intended for the following User/User Roles:
Role
Function
Back office data entry Clerks
Input functions for maintenance related to the interface.
Back office Managers/Officers
Authorization functions.
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Organization
This manual is organized as follows:
Chapter
Description
Chapter 1
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual.
Chapter 2
The Oracle FLEXCUBE EMS Interface explains about the EMS (Electronic Messaging Service) interface between external systems and Oracle FLEXCUBE.
Chapter 3
Maintaining Interface specific Details deals with the maintenance of various customer account transactions through EMS.
Chapter 4
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.5 Acronyms and Abbreviations
Abbreviation
Description
System
Unless and otherwise specified, it shall always refer to Oracle FLEX­CUBE system
1.6 Related Documents
1.7 Glossary of Icons
This User Manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
