2. Oracle FCUBS - ILM Integration
The integration between the Oracle FLEXCUBE Universal Banking System (FCUBS) and Integrated Liquidity Management (ILM) enables the financial institutions to get value dated balance or credit-debit turnover for given set of accounts that participate in Liquidity Management.
2.1 Scope
This section describes the scope of the integration with respect to FCUBS and ILM.
2.1.1 Fetching Value Dated Balance through Webservice
You can fetch the value dated balance or credit-debit turnover through a webservice by providing the account details, balance type and value date.
2.1.2 Generating Balance Report at EOD through GI Batch
You can generate a balance file at EOD for all the accounts that participate in the Liquidity Management. This file will be uploaded into the ILM system for reconciliation.
2.2 Prerequisites
Set up Oracle FLEXCUBE Universal Banking Application and Oracle Global Liquidity Management Application.
Refer the ‘Oracle FLEXCUBE Universal Banking Installation’ manual.
2.3 Integration Process
This section contains the following topic:
2.3.1 Fetching Value Dated Balance
You have to specify the account number, transaction date and balance type to query the value dated balance for a particular account.
You can specify the balance type as ‘VDBALANCE’ or ‘DRCRTURNOVER’. If the balance type is VDBALANCE then value dated balance will be returned. If the balance type is DRCRTURNOVER, then the sum total of debit/credit will be returned.
If the given value date has any back value dated entries then the response will return multiple values.
2.3.2 Generating EOD Batch at EOD
You can create a GI Batch to be run at EOD which will generate a balance file at branch EOD for all the accounts that participate in Liquidity Management.
You can create a UDF check box in User Defined Fields Maintenance (UDDUDFMT) screen and link it to Customer Accounts Maintenance (STDCUSAC) using UDDFNMNT. This check box should be enabled for all the accounts that participate in liquidity management.
2.4 Assumptions
Liquidity management should be enabled for the Customer Accounts, then GI will pick them up during EOD batch.
