1. Preface
1.1 Introduction
This manual talks about the interface between Oracle FLEXCUBE and the Oracle Identity Manager system used in your bank. The maintenances required for the proper functioning of this interface, the interface workflow, validations, and processing for the interface have been documented in this manual.
1.2 Audience
This manual is intended for the following User/User Roles:
Role
Function
Back office data entry Clerks
Input functions for maintenance related to the interface.
Back office Managers/Officers
Authorization functions.
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Organization
This manual is organized as follows:
Chapter
Description
Chapter 1
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual.
Chapter 2
Oracle FLEXCUBE - Oracle Identity Manager Interface explains about the integration and configuration of OIM with Oracle Flexcube.
Chapter 3
Annexure A details about the OIM Components and the various Messages generated within the module.
Chapter 4
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.5 Abbreviations
Abbreviation
Description
System
Unless specified, it shall always refer to Oracle FLECUBE
OIM
SPML
Service Provisioning Mark-up Language
DSML
Directory Service Mark-up Language
GTC
Generic Technology Connector
1.6 Organization
This manual is organized into the following chapters:
Chapter
Description
Chapter 1
Chapter 2
Oracle FLEXCUBE – Oracle Identity Manager Interface: Oracle Identity Manager Interface helps in integrating the two systems for user provi­sioning and de-provisioning services.
Chapter 3
Annexure A - deals with the: OIM Components, SPML Request and Response Message Formats, Message Exchange Sequences.
1.7 Glossary of Icons
This User Manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
Refer the Procedures User Manual for further details about the icons.
1.7.1 Related Documents
You may refer the following manuals for more information
