Oracle FLEXCUBE facilitates the outgoing and incoming payments with SKN network. SKN networks dispatches and processes Incoming Credit Payment, Return of Incoming Credit Payment, Outgoing Credit Payment and Return of Outgoing Credit Payment messages.
This chapter contains the following section:
You need to maintain the following details for this interface:
You need to specify the external system connected to the interface by using the ‘External System Maintenance’ screen. You can invoke the ‘External System Maintenance’ screen by typing ‘GWDEXSYS’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
In this screen, you can specify the following details:
External System
Specify ‘SKN’ as the external system.
For more details refer Maintaining External System(s) Details section of Generic Interface User Manual
Generic Interface (GI) provides a facility to define format details and properties associated to interface file.You can maintain format details and properties associated with SKN interface file in the ‘Interface Definition’ screen. You can invoke this screen by typing ‘GIDIFTDF’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
The following details are maintained for PCSKNSIN interface here:
External System
Specify ‘BIS’ as external system.
Interface code
Specify interface code as ‘PCSKNSIN’.
Interface Type
Select Incoming as interface type from the adjoining drop-down list.
File Path
Specify the directory path of the incoming files to be processed.
File Name
Specify the file name as per network.
Frequency Type
Select Multiple times in a day as the frequency type from the adjoining drop-down list.
Incoming File Mask
Select ‘Start With File Name’ as the incoming file mask from the adjoining drop-down list.
The interface details and the external system details are maintained using the Interface Definition Details and External System Maintenance screens. For more details refer Specifying Interface Definition Details section of Generic Interface User Manual.
The following table specifies the various message types and the corresponding transaction code of SKN Network:
Serial No |
Network (from Product) |
Message Type (Outgoing/ Incoming) |
Payment /Collection |
Product Type(from Product Category) |
Message Name |
Message Description |
1 |
SKN |
Incoming |
Customer |
Incoming Credit Payment |
S01 |
This is an incoming SKN Payment message for the Customer. The message type received in the message will be “BMSKN01” based on which the product type will be identified. Mapping between the message type and the corresponding Payment product has to be provided based on which the transaction will be created. |
2 |
SKN |
Incoming |
Customer |
Return of Outgoing Credit Payment |
S03 |
The message is the return of “Outgoing credit payment”. The first 16 characters of the “Remarks field” in the message contain the Reference number based on which the transaction will be identified. |
3 |
SKN |
Outgoing |
Payment |
Outgoing Credit |
S05 |
This message will be generated for the “Outgoing Payment” transaction using the SKN product |
4 |
SKN |
Outgoing |
Payment |
Return of Incoming Credit |
S07 |
This message will be generated when the authorizer rejects the Incoming credit Payment |
The interface PCSKNSINC uploads the incoming payment files through SKN networks. The incoming files uploaded in the ASCII format is placed in a specified folder and the path is mapped to GI maintenance.
Steps involved in File processing of Incoming SKN Message:.
The interface PCSKNOUT uploads the outgoing payment files through SKN networks. The outgoing files uploaded in the ASCII format is placed in a specified folder and the path is mapped to GI maintenance.
Steps involved in File processing of Outgoing SKN Message:
