1. Preface
1.1 Introduction
This manual is designed to help acquaint you with the interface between Oracle FLEXCUBE and the other systems within your bank.
This manual provides you extensive explanations about the various maintenances required for the smooth exchange of data between Oracle FLEXCUBE and the applicable systems through the interface. It also gives you an insight into the processes involved in the actual exchange of data.
1.2 Audience
This manual is intended for the following User/User Roles:
Role
Function
Back office data entry Clerks
Input functions for maintenance related to the interface
End of day operators
Processing during end of day
Implementation Teams
For setting up integration
Product Managers
Product definition and authorization
Financial Controller / Product Managers
Generation of reports
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Organization
This chapter is organized into following chapters:
Chapter
Description
Chapter 1
Preface gives information on the intended audience. It also lists the various chapters covered in this User Man­ual.
Chapter 2
Oracle FCUBS - DAP Integration explains the integration between Oracle FLEXCUBE Universal Banking and Direct Accounting Process.
1.5 Acronyms and Abbreviations
Abbreviation
Description
System
Unless and otherwise specified, it always refers to Oracle FLEXCUBE Universal Banking system
FCUBS
Oracle FLEXCUBE Universal Banking Sys­tem
DAP
GL
General Ledger
ISB GL
Inter System Bridge General Ledger
1.6 Glossary of Icons
This user manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
1.7 Related Information Sources
Along with this user manual you may also refer the following related resources:
