1. Preface
1.1 Introduction
This document helps you acquaint with the information on inter-connecting Oracle FLEXCUBE Universal Banking System (FCUBS) with Enterprise Limits and Collateral Management (ELCM).
Besides this user manual, while maintaining the interface related details, you can invoke the context sensitive help available for each field in FCUBS. This help describes the purpose of each field within a screen. You can obtain this information by placing the cursor on the relevant field and striking the <F1> key on the keyboard.
1.2 Audience
This manual is intended for the following User/User Roles:
Role
Function
Back office data entry Clerks
Input functions for maintenance related to the interface
End of day operators
Processing during end of day
Implementation Teams
For setting up integration
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Organization
This chapter is organized into following chapters:
Chapter
Description
Chapter 1
Preface gives information on the intended audience. It also lists the various chapters covered in this User Man­ual.
Chapter 2
Oracle FCUBS - ELCM Integration explains the integra­tion between Oracle FLEXCUBE Universal Banking and Enterprise Limits and Collateral Management.
Chapter 3
Annexure provides the details of supported and unsup­ported functionalities of ELCM.
1.5 Acronyms and Abbreviations
Abbreviation
Description
System
Unless and otherwise specified, it always refers to Oracle FLEXCUBE Universal Banking system
FCUBS
Oracle FLEXCUBE Universal Banking Sys­tem
ELCM
Enterprise Limits and Collateral Manage­ment
SYNC
Synchronous
ASYNC
Asynchronous
XML
Extensible Markup Language
1.6 Glossary of Icons
This user manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
1.7 Related Information Sources
Along with this user manual you may also refer the following related resource:
