This document helps you get acquainted with the information on inter-connecting Oracle FLEXCUBE Universal Banking System (FCUBS) with Oracle FLEXCUBE Payments (PM).
Besides this user manual, while maintaining the interface related details, you can invoke the context sensitive help available for each field in FCUBS. This help describes the purpose of each field within a screen. You can obtain this information by placing the cursor on the relevant field and striking the <F1> key on the keyboard.
This manual is intended for the following User/User Roles:
Role |
Function |
Back office data entry Clerks |
Input functions for maintenance related to the interface |
End of day operators |
Processing during end of day |
Implementation Teams |
For setting up integration |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This chapter is organized into following chapters:
Chapter |
Description |
Chapter 1 |
Preface gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
Chapter 2 |
Oracle FCUBS - Payments Integration explains the integration between Oracle FLEXCUBE Universal Banking and Oracle FLEXCUBE Payments. |
Abbreviation |
Description |
System |
Unless and otherwise specified, it always refers to Oracle FLEXCUBE Universal Banking system |
FCUBS |
Oracle FLEXCUBE Universal Banking System |
PM |
Oracle FLEXCUBE Payments |
Source System |
Oracle FLEXCUBE Universal Banking System (FCUBS) |
FX |
Foreign Exchange |
This user manual may refer to all or some of the following icons.
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
Along with this user manual you may also refer the following related resources:
