The integration between the Oracle FLEXCUBE Universal Banking System (FCUBS) and Oracle FLEXCUBE Payments (PM) allows you to trigger notification during creation, modification or authorization of Customer, Customer Account, Currency Rate, GL Code and Transaction Code. The integration also allows you to provide response to the external system request on exchange rate lookup and utilization, de-utilization of an FX contract.
The integration allows FCUBS modules to request the External payment System for outgoing payment processing and SWIFT Payment Message (Customer Transfer and Bank Transfer) generation.
This section describes the scope of the integration with respect to FCUBS and PM.This section contains the following topics:
You can generate notification to an external system if the following details are created, modified or authorized in FCUBS:
You can process exchange rate lookup and utilization or de-utilization on an FX contract linked to an external payment system. The system hands over the process response along with the exchange rate details to the external system.
All modules interfacing with PC module, for outgoing payment, interfaces with External Payment System for payment processing. All modules interfacing with FT and IS module, for Payment Message (Customer Transfer and Bank Transfer) generation, interfaces with External Payment System for message generation
Set up Oracle FLEXCUBE Universal Banking Application and Oracle FLEXCUBE Payments Application.
Refer the ‘Oracle FLEXCUBE Universal Banking Installation’ manual.
This section contains the following topic:
Notification framework in FCUBS is used to communicate the business event in FCUBS to external systems. Depending on the event an XML message is send to external system queues.
You can trigger notification message to an external system when the following details are created or modified on authorization:
The system generates a notification when the above created or modified details are authorized.
You can process exchange rate lookup and utilization or de-utilization request if an FX contract is linked to an external payment system.
The integration allows FCUBS modules to request External payment System for outgoing payment processing and SWIFT Payment Message (Customer Transfer and Bank Transfer) generation.
You can capture the details of external payment system in External Payment System Maintenance screen. You can invoke this screen by typing ‘IFDEPSMT’ in the top right corner of the Application toolbar and clicking the adjoining arrow button.
You can maintain the following details in this screen:
External System
Specify the name of the External Payment System.
Description
Give a brief description on External Payment System specified.
Inter System Bridge GL
Specify the Bridge GL account for Inter System Accounting. Alternatively, you can select the Inter System Bridge GL from the option list. The list displays all valid options.
Source System
Specify the name of the source system.
Read Time Out (In Seconds)
Specify the web service read time out in seconds.
Connection Time Out (In Seconds)
Specify the web service connection time out in seconds.
Service Code
Select the service code from the drop-down list. The list displays ‘GenPayMessage’ value which indicates single payment service.
Service Name
Specify the web service name.
Operation Code
Specify the web service operation code.
Web Service User Option
Select the web service user option from the drop-down list. The list displays the following values:
Web Service User
Specify the web service user ID. This field is applicable only if ‘Web Service User Option’ is selected as ‘Predefined User’.
Web Service URL
Specify the web service URL.
You can view the external payment system maintenance details in ‘External Payment System Summary’ screen. You can invoke the summary screen by typing ‘IFSEPSMT’ in the top right corner of the Application toolbar and clicking adjoining arrow button.
You can view the details of payment request sent or to be send to an external payments system through ‘External Payment System Queue’ screen. You can invoke this screen by typing ‘IFDEPSQU’ in the top right corner of the Application toolbar and clicking the adjoining arrow button.
Queue Reference Number
Specify the queue reference number and click ‘Execute Query’ to view the details of payment request sent to external payment system.
