2. Creating Electronic Fund Transfer Interfaces
Oracle FLEXCUBE Investor Servicing (FC-IS) provides the AMC with the
facility of interfacing with external clearing bureaus and clearing banks.
The interface is facilitated through electronic funds transfer (EFT),
and specific transfer instruction data can be generated as EFT files
that are sent to these clearing bureaus.
In the FC-IS system, you can create transfer instructions to be sent
to the clearing bank of the AMC from where transfers can be effected
to the unit holder bank accounts, for the following business events:
- Redemption Payments: For all the payments that need to be effected
through transfer to unit holder bank account due to redemption transactions
on any given date, you can generate an EFT file in the system with all
the relevant transfer instruction data and the amounts. This file can
then be exported to the clearing bank of the AMC.
- Dividend Payments: For all dividend payments that must be effected
through transfer to unit holder bank accounts, on a given date, an EFT
file can be generated that contains all the relevant transfer instruction
data and the amounts. This file can then be manually transmitted to the
clearing bank of the AMC that will actually effect the transfers.
- Broker Commission Payments: For all payments through transfer to
an agent or broker bank accounts due to commission accrual on any given
date, an EFT file can be generated that contains the transfer details
and the amounts. This file can be exported to the clearing bank of the
AMC.
You can also create transfer instructions to an external clearing
bureau for the purpose of debiting the relevant unit holder accounts
in the case of debit orders. A hand-off file can be generated with the
transfer instruction information that can be sent to an external clearing
bureau that will debit the relevant unit holder bank accounts and credit
the AMC account as applicable.
In case of NPI payments to a trust, you can generate a single EFT
file that contains all the transfer details and the total NPI amount
that must be paid to charitable trusts.
This chapter describes the functions in the FC-IS system that you
can use to create these transfer instructions EFT files.
2.1 Create Transfer Instruction Files
The following screens in the system facilitate the creation and generation
of these transfer instructions interface files:
- The EFT Setup (Detail and Summary) Screen that you can access from
the EFT Setup menu in the Browser.
- The Payment Clearing Screen that you can access from the Payment
Clearing menu in the Browser.
2.2 Few Basic Terms
You must have a clear understanding of a few basic terms before you
use these screens to generate the EFT files:
Batch
A batch is a logical group of records that forms a single transfer
instruction EFT file. Accordingly, one single batch can include transfer
instructions records that could apply to any one of the four business
events mentioned above – redemption payments, dividend payments,
broker commission payments or debit orders, as of the date on which (the
effective date) the hand-off files are to be generated.
Instruction Type
Each of the four business events that will result in transfer instructions
being sent to the clearing bureau (for debit orders) or clearing bank
(for redemption payments, dividend payments or broker commission payments),
is designated within the system as an instruction type. Therefore, a
single batch can contain records that pertain to a single instruction
type, for a given date.
Instruction Medium
The instruction medium is the method using which the interfacing with
the external entity is achieved. Therefore, the medium could be an automated
clearing bureau, an electronic funds transfer, a SWIFT interface, and
so on.
Taking a typical example, if the generated transfer instruction files
are exported to an external clearing bank, they may need to be exported
through an electronic funds transfer. In this case, the instruction medium
would be EFT or electronic funds transfer.
Settlements and Link Settlement Numbers
Settlement of the records in a batch involves the debiting or crediting
of the applicable bank accounts. For each account that is impacted by
the debit or credit entries due to the settlement, the system generates
a number known as the link settlement number. This number is typically
used for tracking the record in the different stages of the settlement.
If more than one of the records retrieved for a batch are to be settled
by crediting or debiting the same unit holder account, then the system
internally deems the settlement to be a single one. It also assesses
the number of such settlements, and displays the same.
For example, in the case of redemption payments, let us suppose that
a certain unit holder A has performed redemption transactions T1 and
T2, and that these transactions have been allocated on the date 3rd –
April - 2000. Let us suppose that the only bank account to be credited
as a result of these transactions is AC1. When you extract redemption
payment records for the date 3rd - April - 2000 in this screen, the system
retrieves T1 and T2. When it finds, during the process of extraction,
that both the proceeds of both transactions are to be credited to a single
account AC1, it deems both the transactions as a single settlement, and
assigns a single link settlement number, for both these transactions.
For a single link settlement number, all the underlying transactions
must be cleared or rejected together.
2.3 EFT Files Generation
Typically, it is recommended that you perform the generation of an
EFT batch file after the End of Day process at the Fund Manager has been
preformed by the Operator users.
You can create and generate the transfer instruction files in the
system by using the following procedures, in sequence:
- For the date on which the hand-off instruction files are to be generated,
for sending to the clearing bureau, you must extract the records that
must appear in these files. You can use the EFT Batch Maintenance (Detail)
screen to do this.
- After you have extracted and saved the batch in the EFT Batch Generation
screen, authorize it using the EFT Batch Maintenance (Summary) screen.
- The user that has generated the batch record in the EFT Batch Maintenance
(Detail) screen cannot authorize the batch. Typically, a user belonging
to the Supervisor user group can authorize the batch in the EFT Batch
- After authorization, you can generate and export the actual transfer
instruction interface file that contains the batch records using the
interface processing functions in the system.
Refer to the Interfaces chapter of this User Manual
for a detailed discussion of the interface processing functions.
Re-exporting Batch EFT File
Once a batch has been authorized, it cannot be generated again for
the same instruction type, for the same date.
If the transmitted EFT batch file is misplaced due to any reason,
then you can re-export the same batch again. The saved batch data is
exported. You can use the Mark Batch for Re-Export screen to do this.
The Interface processing function may be used again to re-transmit the
EFT batch file.
2.4 EFT Batch Generation Screen
2.4.1 Invoking the EFT Setup Detail Screen
You can use the ‘EFT Setup Detail’ screen to generate
a batch for an EFT file. You can invoke this screen by typing ‘UTDEFTSD’ in the field at the top right corner
of the Application tool bar and clicking on the adjoining arrow button.
2.4.2 Generating EFT Batch in this Screen
To create a batch that can be used for generating and exporting an
EFT file, you must
- Specify the following mandatory information in the applicable fields
in the header or main portion of this screen:
- The Instruction Type that will determine the records that must be
extracted for this batch.
- The Effective Date for which the records must be extracted for this
batch
- The Batch Description
- Click the Extract button. The job is submitted and the corresponding
procedure is run. The Asynchronous Process screen is opened, where the
current status of the job is indicated.
- All the relevant transaction records pertaining to the specified
Instruction Type and Effective Date are extracted, and the amounts involved
are summed across all the transaction and displayed in the Instruction
Information section in the lower portion of the screen. This displayed
row will also contain the number of records that are tagged with a link
settlement number
- To view the records in detail, with the actual transaction numbers,
and the bank account details, click the View Details button. The records
that make up the batch are displayed transaction-wise in the Instruction
Details section in the lower portion of the form.
- Choose the Save option from the File menu or click on the Save button
to save the batch.
Select ‘New’ from the Actions menu in the Application
tool bar or click new icon to enter the details of the EFT Setup Screen.
The EFT Setup Screen depicts the following EFT information:
Batch Number
Display
The Batch Number is a unique identifier that is assigned to each batch
that is generated in this screen. When you have extracted all the records
in this screen, the Batch Number is generated when you choose the Save
option and the system successfully saves the batch.
The Batch Number consists of a 20-character number, and is generated
by the system according to the following logic:
Character
Description
Characters 1-2
‘BN’
Characters 3-4
The instruction type, ‘DO’
for debit orders, ‘RE’ for redemption payments, ‘BC’
for broker commission payments and ‘DI’ for dividend payments.
Characters 5-12
The date stamp (as ‘yyyymmdd’
format)
Characters 13-20
A running serial number
prefixed with zeros
Batch Description
Alphanumeric; 30 Characters; Mandatory
Specify the batch description.
Instruction Type
Alphanumeric, 2 Characters; Mandatory
Select the type of business event that results in the EFT file transfer
to the external bureau in the form of this batch. The records that will
be extracted by the system in this screen will be filtered according
to the instruction type that you specify here.
Instruction Type Description
Display
When you select the instruction type, the description for the respective
instruction type is displayed.
The following types are available:
- Debit Orders
- Redemption Payouts
- Dividend Payouts
- Broker Commission Payouts
- NPI Payments to Trust
For instance, if you specify the instruction type as Redemption Payouts,
the system will retrieve only records of redemption transactions that
have been allocated on the specified date.
The drop-down list in this field contains all the instruction types
that have been identified for the AMC and the interface. The instruction
types are set up in the system by the implementers at installation time.
Instruction Medium
Alphanumeric; 6 Characters; Mandatory
so on.
At the time of installation of the system, the implementers set up
the different instruction mediums as applicable to the AMC. Each instruction
type is mapped to an instruction medium. Therefore, when you specify
the instruction type, the instruction medium that is mapped to the selected
instruction type is displayed here, and it cannot be altered.
Instruction Medium Description
Display
When you select the Instruction medium, the description for the respective
instruction medium is displayed for the EFT Setup.
Entity ID
Alphanumeric; 12 Characters; Optional
The ID of the entity involved in the transaction is displayed here.
Description
Display
The system displays the description for the selected entity ID.
Bank
Alphanumeric; 12 Characters; Mandatory
Specify the code of the bank, in which the transfer account is located,
from which the settlement will be done for the transaction.
Sub Payment Mode
Alphanumeric; 2 Characters; Mandatory
Select the sub payment mode from the option list.
Description
Display
The system displays the description for the selected sub payment mode.
Effective Date
Date Format; Mandatory
Specify the date for which the records must be extracted for this
batch.
- For redemption payments, the redemption transactions that have occurred
on the date you specify here must have been allocated.
- For dividend payments, the following events must have already occurred
for the date you specify here:
- The fund dividend should have been declared and authorized for all
funds earlier than the date you specify here.
- The dividend that has been declared must already have been processed
for the date you specify here.
- For broker commissions, the commissions that are accruing to the
broker on the date you specify here must already have been processed
in the system.
- For debit orders, the date you specify here must be the date of generation
of the standing instructions transaction. Therefore, it must always
be a future date.
Therefore, for redemption payments, broker commission payments and
dividend payments, the date you specify here can be a past date, subject
to the conditions mentioned above.
Agent Code
Select the agent code from the option list.
Unit Holder ID
Select the ID of the respective unit holder from the option list.
You can also select unit holder ID by clicking ‘Find UH’
button.
Process Date
Select the process date from the adjoining calendar.
This is the date on which the batch record is saved in this screen.
Net Amount
Display
The net amount involved in the transaction is displayed here.
Held Back Payment?
Optional
Select ‘Yes’ or ‘No’ from drop-down list to
specify whether any payments are held back or not.
Broker Code
Enter the broker code.
Held From
Date Format; Optional
Enter from when the payment is held back.
Count of Records
Display
The number of the allotted transaction in the system that has been
extracted for this batch is displayed here.
For dividend payments and commission payments, it is the corresponding
payment number. For redemption transactions, it is the actual redemption
transaction number in the system. For debit orders, it is the actual
system-generated Standing Instructions transaction number that is assigned
when the transaction is actually generated in the system.
Mark for Re-Export
Click ‘Mark For Re-Export’ button to mark the records
for re-export.
2.4.3 Reports Printed on Saving EFT Batch
When you save an EFT batch in this screen, the following reports are
printed:
- The Instruction Batch Report, containing the following details:
- Batch Number and Description
- Instruction Description
- Instruction Medium
- Net Amount
- Process Date and Effective Date
- Authorization Status and Batch Status
- Rejection Reason, if any.
- The EFT Batch Details Report, containing the following details:
- The Link Settlement Numbers, if any
- The transaction amounts, at the settlement number level, and a sum
for the entire batch
- The transfer bank account details at the link settlement number level
2.5 EFT Batch Maintenance Summary Screen
2.5.1 Invoking the EFT Batch Maintenance Summary Screen
After you have extracted an EFT batch, you must have another user
authorize it to be effective in the system.
Before the EFT batch is authorized, you can edit it as many times
as necessary. You can also delete it before it is authorized.
Invoke the ‘EFT Setup Summary’ screen by typing ‘UTSEFTSD’ in the field at the top right corner
The ‘EFT Setup Summary’ screen can be used for the following
operations on EFT batches:
- Retrieval for viewing
- Authorizing batches
- Marking a batch for re-export
2.5.2 Retrieving Batch in EFT Setup Summary Screen
You can retrieve a previously entered record in the EFT Setup Summary
screen, as follows:
In the browser select Transaction screen and click on Summary, specify
any or all of the following details in the corresponding fields:
- The status of the transaction in the Authorized field. If you choose
the “Blank Space” option, then all the records are retrieved.
- The status of the Transaction in the Open field. If you choose the
- The medium of instruction, in the Instruction Medium field.
- The type of instruction, in the Instruction Type field.
- The date of process, in the Process Date field.
- The effective date, in the Effective Date field.
- The code of bank, in the Bank field.
- The mode of sub payment for the transaction, in the Sub Payment Mode
field.
- Batch Number
After you have specified the required details, click the Query button.
All transactions with the specified details are retrieved and displayed
Note
You can also retrieve the individual record detail
from the detail screen by doing query in the following manner:-
- Press F7
- Input the Instruction Type
- Press F8
You can perform Edit, Delete, Amend, Authorize, Reverse, Confirm operations
by selecting from the Action list.
You can also search the record by using combination of % and alphanumeric
value.
For example
You can search the record for Batch Number by using the combination
of % and alphanumeric value as follows:-
- Search by A%: System will fetch all the records whose Instruction
Type starts from Alphabet ‘A’. Ex: AGC17, AGVO6, AGC74 and
so forth.
- Search by %7: System will fetch all the records whose Instruction
Type ends by numeric value’ 7’. Ex: AGC17, GSD267, AGC77
and so forth.
- Search by %17%: System will fetch all the records whose Instruction
Type contains the numeric value 17. Ex: GSD217, GSD172, AGC17 and so
forth.
2.5.3 Editing Record
You can modify the details of a record that you have already entered
into the system, provided it has not been subsequently authorized. You
can perform this operation as follows:
- Invoke the EFT Setup Summary screen from the Browser.
- Select the status of the transaction that you want to retrieve for
modification in the Authorized field. You can only modify records of
transactions that are unauthorized. Accordingly, choose the unauthorized
option from the drop down list.
- Specify any or all of the details of the records in the corresponding
fields on the screen to retrieve the record that is to be modified. All
unauthorized transactions with the specified details are retrieved and
displayed in the lower portion of the screen.
- Double click the record that you want to modify in the list of displayed
records. The EFT Setup Detail screen is displayed.
- Select Unlock Operation from Action list to modify the record. Modify
the necessary information
- Click Save to save your changes. The EFT Setup Detail screen is closed
and the changes made are reflected in the EFT Setup Summary screen.
2.5.4 Viewing Record
To view a transaction that you have previously entered, you must retrieve
the same in the EFT Setup Summary screen, as follows:
- Invoke the EFT Setup Summary Screen from the Browser.
- Select the status of the record that you want to retrieve for viewing
in the Authorization Status field. You can also view all transactions
that are either unauthorized or authorized only, by choosing the Unauthorized
/ Authorized option.
- Specify any or all of the details of the record in the corresponding
fields on the screen, and click ‘Search’ button. All records
with the specified details are retrieved and displayed in the lower portion
of the screen.
- Double click the record that you want to view in the list of displayed
records, in the lower portion of the screen. The EFT Setup Detail screen
is opened in view mode.
- Select Delete operation from the Action list. The system prompts
you to confirm the deletion, and the record is deleted physically from
the system database.
2.5.5 Authorizing Record
An unauthorized record must be authorized in the system for it to
be processed.
To authorize a record you must first retrieve the same in the EFT
- Select the status of the record that you want to retrieve for authorization.
Typically, choose the unauthorized option from the drop down list.
fields on the screen. Click ‘Search’ button. All transactions
with the specified details that are pending authorization are retrieved
and displayed in the lower portion of the screen.
- Double click the record that you wish to authorize. The EFT Setup
screen is opened in view mode.
- Select Authorize operation from Action list.
- To mark all retrieved records for authorization,
- In the retrieved list, specify the value of each transaction in the
Transaction Value field.
- Click the Mark All for Authorize link.
- Click the Authorize Marked Records button to complete the authorization.
When the checker authorizes a transaction, details of validations,
if any, that were overridden by the maker of the transaction during the
Save operation, are displayed. If any of these overrides results in
an error, the checker must reject the transaction.
2.5.6 Amending Record
After a record is authorized, it can be modified using the Unlock
operation from Action list. To make changes to a record after authorization,
you must invoke the Unlock operation which is termed as Amend Operation.
- Select the status of the record that you wish to retrieve for amendment.
You can only amend records of transactions that are authorized.
fields on the screen. All record with the specified details are retrieved
- Double click the record that you want to amend. The EFT Setup screen
will be displayed in Amendment mode. Click the Unlock operation from
the Action list to amend the record.
- Amend the necessary information. Click the Save button to save your
changes.
2.5.7 Authorizing Amended Record
An amended record must be authorized for the amendment to be made
Authorization of amended records can only be done from Fund Manager
Module and Agency branch Module.
The process of authorization is subsequently the same as that for
normal transactions.
2.5.8 Copying Attributes
If you want to create a new record having the same attributes of an
existing record, you can copy the attributes of the existing record to
the new record.
To copy the attributes of an existing record to a new record:
- Retrieve the record whose attributes the new record should inherit.
You can retrieve the record through the Summary screen or through the
F7 - F8 operation which are explained in the previous section.
- In the EFT Setup Detail screen, click on ‘Copy’ Action.
- Indicate the ID for the new record. You can however change the details
of the new records if required.
2.6 Marking a Batch for Re-Export
If the data is lost due to any reason, or the EFT file is misplaced,
then you can re-export the same batch again. The saved data is exported
again. You can use the Mark EFT Batch for Re-Export option in the Operation
field, in the EFT Batch Maintenance (Summary) to do this.
Only batches that have been authorized and subsequently processed
at least once can be marked for re-export.
To mark a batch for re-export in the EFT Batch Maintenance Summary
screen,
- Select Mark for Re-Export in the Operation field.
- Retrieve the batch that you must re-export. Specify the appropriate
search criteria, and retrieve the batch.
- When you have successfully retrieved the batch, the details of the
batch are displayed in the grid portion of the screen. The following
details are displayed for the batch:
- The Batch ID and description
- The Process Date and the Effective Date for the batch
- The count of the number of link settlements for the batch
- To mark a batch for re-export, check the Re-Export check box in the
row corresponding to the batch in the grid.
- Similarly, mark as many batches as required, for Re-Export
- When you have finished, choose the Save option from the File menu
or click the Save button to save the marked batches.
2.7 Payment Clearing Screen
2.7.1 Invoking the Payment Clearing Detail Screen
In an exported EFT batch file, if the external clearing bureau directs
that some settlements must be reconciled in the system, you can use the
‘Payment Clearing Detail’ screen to do this. You can invoke
this screen by typing ‘UTDPYCLR’ in the field at the top right corner
Select ‘New’ from the Actions menu in the Application tool
bar or click new icon to enter the details of the Payment Clearing screen.
2.7.2 Fields in Payment Clearing Screen
The following are the fields in the Payment Clearing Screen:
AMC ID
Select the AMC ID from the option list, for which clearing to be processed.
Transaction Number
Alphanumeric; 16 Characters; Optional
Specify the transaction number for which payment needs to be processed.
Fund ID
Alphanumeric; 6 Characters; Optional
Specify the fund ID for which payment needs to be processed.
ISIN Code
Display
The system displays the ISIN code for the selected fund ID.
Fund Name
Display
The system displays the fund name for the selected fund ID.
Payment Mode
Optional
Select the mode of payment from the drop-down list. The list displays
the following values:
- ALL
- Cheque
- Demand Draft
- Transfer
- Credit Card
Level
Optional
Select the level of transactions to be selected from the drop-down
list. The list displays the following values:
- Transaction
- Policy
- Settlement
Date Range
Optional
Select the date range to be consider for filtering in from and to
date from the drop-down list. The list displays the following values:
- Transaction Date
- Allocation Date
- Payment Date
From
Specify the from date for which transactions to be filtered based
on Date Range selected.
To
Specify the to date for which transactions to be filtered based on
Click ‘Clear All’ button to clear the process for fetched
list of transactions.
Click ‘Reject All’ button to reject the process for fetched
Click ‘Show Details’ button to fetch the data as per the
search criteria given in the header block. The following details are
displayed:
- Transaction Number - Displays transaction numbers of above selected
filter criteria.
- Txn Dtl - On clicking of this button corresponding Transaction screen
will be queried
- Payment Mode - Displays the mode of payment of the corresponding
transaction.
- Payment Details - On clicking of this button corresponding Transaction
Settlement screen will get queried with the settlement details.
- Clearing Date - Captures the clearing date of the transaction, while
fetching this filed will be defaulted with clearing date from transaction
level if captured. However, you can override this defaulted value.
- Clearing Status - Specify if the payment clearing of corresponding
transaction has to be cleared or rejected.
- Drawee Bank Name - Displays the drawee bank name from transaction
level if captured.
- Pledgee Branch - Displays the Pledgee Branch from transaction level
if captured.
- Txn Base Currency - Displays the transaction base currency.
- Instrument Status - Specify the instrument status of payment clearing
of settlement to received or rejected.
- Remarks - Capture the remarks for the payment clearing process.
- Sys Reference Number - Display the system Reference Number of the
- Check Status - Display the Cheque status, if the payment mode is
cheque.
- Clearing Level - Display the Clearing level of the record either
transaction, policy, settlement.
- Auth Status - Display the Authorisation status of the transaction.
- Maker ID - Display the Maker ID of the transaction.
- Maker DT Stamp - Display the Maker date of the transaction.
- Checker Id - Display the Checker ID of the transaction.
- Checker DT Stamp - Display the Checker date of the transaction.
2.8 Payment Clearing Summary Screen
- Section 2.8.1, "Invoking the Payment Clearing Summary
Screen"
- Section 2.8.2, "Retrieving Record in Payment
Clearing Summary Screens"
- Section 2.8.3, "Editing Transaction"
- Section 2.8.4, "Viewing Transaction"
- Section 2.8.5, "Deleting Transaction"
- Section 2.8.6, "Authorizing Transaction"
- Section 2.8.7, "Amending Transaction"
- Section 2.8.8, "Authorizing Amended Transactions"
- Section 2.8.9, "Copying Attributes "
- Section 2.8.10, "To Clear or Reject Settlement"
2.8.1 Invoking the Payment Clearing Summary Screen
You can invoke the ‘Payment Clearing Summary’ screen by
typing ‘UTSPYCLR’ in the field at the top right corner
2.8.2 Retrieving Record in Payment Clearing Summary Screens
You can retrieve a previously entered transaction in the Summary screen,
as follows:
- In the browser, select Payment Clearing screen and click on Summary,
specify any or all of the following details in the corresponding fields:
- The status of the transaction in the Authorization field. If you
choose the “Blank Space” option, then all transactions are
retrieved.
- The status of the Transaction in the Record Status field. If you
retrieved
- The number of the transaction, in the Transaction Number field.
- The dates of the transaction, in the Transaction Date field.
- The date of clearing, in the Clearing Date field.
- The status of clearing, in the Clearing Status field.
- The ID of the clearer, in the Clearer ID field.
After you have specified the required details, click ‘Search’
button. All transactions with the specified details are retrieved and
Note
- Press F7
- Input the Transaction Number
- Press F8
value.
For example
You can search the record for Transaction Number by using the combination
- Search by A%: The system will fetch all the records whose Transaction
Number starts from Alphabet ‘A’. Ex: AGC17, AGVO6, AGC74
and so forth.
- Search by %7: The system will fetch all the records whose Transaction
Number ends by numeric value’ 7’. Ex: AGC17, GSD267, AGC77
and so forth.
- Search by %17%: The system will fetch all the records whose Transaction
Number contains the numeric value 17. Ex: GSD217, GSD172, AGC17 and so
forth.
2.8.3 Editing Transaction
You can modify the details of a transaction that you have already
entered into the system, provided it has not been subsequently authorized.
You can perform this operation as follows:
- Invoke the Payment Clearing screen from the Browser.
modification in the Authorization Status field. You can only modify records
of transactions that are unauthorized. Accordingly, choose the unauthorized
- Specify any or all of the details of the transaction in the corresponding
fields on the screen to retrieve the transaction that is to be modified.
All unauthorized transactions with the specified details are retrieved
transactions. The Payment Clearing Detail screen is displayed.
- Click Save to save your changes. The Transaction Detail screen is
closed and the changes made are reflected in the Transaction Summary
screen.
2.8.4 Viewing Transaction
the same in the Payment Clearing Summary screen, as follows:
- Invoke the Payment Clearing Summary Screen from the Browser.
viewing in the Authorization Status field. You can also view all transactions
fields on the screen, and click ‘Search’ button. All transactions
of the screen.
- Double click the transaction that you want to view in the list of
displayed transactions, in the lower portion of the screen. The Payment
Clearing Detail screen is opened in view mode.
2.8.5 Deleting Transaction
You can delete only unauthorized transactions in the system.
To delete a transaction that you have previously entered, you must
retrieve the same in the Payment Clearing Summary screen, as follows:
- Invoke the Payment Clearing Summary screen from the browser.
deletion.
of the screen.
- Double click the transaction that you want to delete in the list
of displayed transactions, in the lower portion of the screen. The Payment
2.8.6 Authorizing Transaction
An unauthorized transaction must be authorized in the system for it
to be processed.
To authorize a transaction, you must first retrieve the same in the
Payment Clearing Summary screen.
- Invoke the Payment Clearing Summary screen from the Browser.
authorization. Typically, choose the unauthorized option from the drop
down list.
- Double click the transaction that you wish to authorize. The Payment
Clearing screen is opened in view mode.
Save operation, are displayed. If any of these overrides results in an
2.8.7 Amending Transaction
After a transaction is authorized, it can be modified using the Unlock
operation from Action list. To make changes to a transaction after authorization,
- Select the status of the transaction that you wish to retrieve for
amendment. You can only amend records of transactions that are authorized.
fields on the screen. All transactions with the specified details are
retrieved and displayed in the lower portion of the screen.
- Double click the transaction that you want to amend. The Transaction
screen will be displayed in Amendment mode. Click the Unlock operation
from the Action list to amend the transaction.
changes.
2.8.8 Authorizing Amended Transactions
- An amended transaction must be authorized for the amendment to be
made effective in the system.
- Authorization of amended transactions can only be done from Fund
Manager Module and Agency branch Module.
2.8.9 Copying Attributes
If you want to create a new transaction having the same attributes
of an existing transaction, you can copy the attributes of the existing
transaction to the new transaction.
To copy the attributes of an existing transaction to a new transaction:
- Retrieve the transaction whose attributes the new transaction should
inherit. You can retrieve the transaction through the Payment Clearing
Summary screen or through the F7 F8 operation which are explained in
- In the Payment Clearing Detail screen, click on ‘Copy’
Action.
- Indicate the ID for the new transaction. You can however change the
details of the new transactions if required.
2.8.10 To Clear or Reject Settlement
- In the Payment Clearing screen, select the Transaction option in
the Level field.
- In the Payment Mode field, select the Link Settlement Number option.
You must key in the link settlement number for the settlement that you
want to clear or reject in the Specific Number field.
- Click the Show button to retrieve all the transactions that are to
be settled together for the specified Link Settlement Number. The system
retrieves the details for these transactions and displays the same in
the lower grid portion of the screen. The following details are displayed
for each transaction:
- The Transaction Number
- The Txn Dtl
- The Payment Mode Description
- The Payment Details
- The transfer account details (the Bank Name, Branch Name, Account
Type, Account Number, Account Currency and Account Name)
- The clearing instrument number
- You must specify the clearing date for the settlement in the Clearing
Date field. In the case of link settlement numbers, all the transactions
must be cleared together or rejected together. Individual transactions
cannot be cleared or rejected in isolation. Therefore, you must specify
the clearing dates for all the transactions together
- After you have specified the clearing dates for all the transactions,
select the Clear All option to mark all the transactions for clearing,
or the Reject All option, to mark all the transactions for rejection.
- Click the Save button to actually effect the clearance of the settlement.
