Oracle FLEXCUBE Investor Servicing provides a facility to effect data exchanges and transfers with external systems. You can import exchange rates or NAV from an external system, or export transaction and dividend information to any external accounting system. The external system may be a file system or an application.
The data exchange can be affected through an interface with the external system. This interface consists of the following components:
You can process an interface in one of the following ways:
You can access the interface processing screens from the following menu categories in the Fund Manager component:
For each of the below function ID, Modify, Delete or Authorize Action is supported from the module in which the record is created.
ACCOUNTOFFICERIFATBL |
UTDAOIFA |
AMCAGENTSLATBL |
UTDAMCSL |
AMCBANKBRANCHMAPPINGTBL |
UTDAGYBN |
B_AMINTERFACESETUPTBL |
UTDACSYC |
B_COUNTRYCURRENCYTBL |
UTDCONCU |
B_CURRENCYTBL |
UTDCURMA |
B_EXCHANGERATETBL |
UTDEXCRM |
B_LOADTBL |
UTDLOADM |
B_MODEOFPAYMENTTBL |
UTDMPAYS |
B_SOURCETBL |
UTDSORCE |
DEFAULTSTBL |
UTDDEFMT |
DISTRIBUTORAOTBL |
UTDAGTAO |
DIVIDENDCOMPONENTTBL |
UTDDVCOM |
ELEMENTTBL |
UTDENMNT |
ENTITYBASETBL |
UTDENTMN |
ENTITYNOTEPADTBL |
UTDNTPDE |
ENTITYPAYMENTDETAILSTBL |
UTDENTPY |
FEECATEGORYHDRTBL |
UTDFEECA |
FUNDTYPETBL |
UTDFNTYP |
INDEXATIONTBL |
UTDINDEX |
INTERFACEDEFINITIONTBL |
UTDIFAC |
LANGUAGETBL |
UTDLNGSU |
PARAMSHDRTBL |
UTDPARAM |
PRODUCTTYPETBL |
UTDPRTYP |
RATETBL |
UTDRATES |
RULETBL |
UTDHDRUL |
STTM_CUSTOMER |
UTDCUST |
TIMEZONETBL |
UTDTIMEZ |
Refer to the chapter ‘Interfaces with External Systems’ in Volume Four for further details on setting up and maintaining interfaces.
At the end of a day’s batch processing, Oracle FLEXCUBE Investor Servicing will produce a file which contains all the transactions that have failed validation criteria. The FCIS – AWD Interface will assign a unique error code for each of the failed transactions and pass the file to another external system. This external system will translate the error codes into AWD Worktype and produces an AWD/RIP control file for AWD/RIP.
You need to maintain the external system AWD in the FCIS Data Mapping Maintenance screen with the code description as ERROR CODE. Consequently, the file that will be sent to AWD by FLEXCUBE Investor Services will have the header ‘AWD’.
Refer to the section ‘Maintaining Data Mapping’ in the chapter ‘Maintaining System Parameters’ for further details.
The FCIS – AWD Interface has the following attributes:
Trigger |
EOD Activity |
Transport Type |
File System |
File Type |
Delimited |
Header Row |
No |
Record Separator |
New Line Character |
Field Separator |
Comma |
The FCIS - AWD interface will fetch all the allocation errors that have occurred on transactions after all the validations. The interface will then transfer a file with the details in the required format. The interface will also provide the subscriptions, redemptions and income distributions for which the bank details are unverified.
The file which contains the errors that have occurred on transactions will be in the following format:
Field Name |
Data Type |
Details |
Error Code |
Number |
The FCIS error code will be translated as per the data mapping maintenance. |
Account Number |
Character |
The unit holder ID of the transaction. |
Fund id |
Character |
The fund ID of the transaction. |
Account Group No |
Character |
Product ID of the transaction. The value will be ‘UT’ if it is a unit trust transaction. |
Account Group Type |
Character |
The product type of the product maintained in FCIS. |
Surname |
Character |
The Last Name of the unit holder involved in the transaction |
Date of birth |
Number(8) |
Unit holder’s Date of birth in YYYYMMDD format |
Account Reference Number |
Character |
The transaction number. |
Date |
Number(8) |
Transaction date in YYYYMMDD format |
