Welcome to Oracle FLEXCUBE Investor Services ™, a comprehensive mutual funds automation software from Oracle Financial Services Software Ltd. ©.
This Oracle FLEXCUBE Investor Services User Manual helps you use the system to achieve optimum automation of all your mutual fund investor services processes. It contains guidelines for specific tasks, descriptions of various features and processes in the system and general information.
The User Manual is organized in to various parts, each discussing a component of the Oracle FLEXCUBE Investor Services system.
This Fund Manager User Manual is intended for the Fund Administrator users and system operators in the AMC.
This volume of the Fund Manager User manual is organized under the following chapter sequence:
Chapter |
Description |
Chapter 1 |
About This Manual explains the structure, audience, organization, and related documents of this manual. |
Chapter 2 |
LEP Product Setup – An Overview enables you learn about the LEP Product Setup. |
Chapter 3 |
LEP Product Setup – Product Class deals with the first step in the workflow. A reference has been made to a chapter in the Fund Manager User Manual, where the process has been explained. |
Chapter 4 |
LEP Product Setup – Product Type explains the second step in the workflow. Once you have maintained Product Classes, the next step is to define various Products Types. |
Chapter 5 |
LEP Product Setup – Product explains how to maintain Products under which a customer would buy a Policy. |
Chapter 6 |
LEP Product Setup – Other Product Activities explains the process of setting up applicable fee or incentives for a product which in turn impacts the processing of transactions in the product. It also deals with mapping entities to a product. |
Chapter 7 |
LEP Product Setup – Product With-Holding Tax You may refer to this chapter if, for a Product, you want to capture the details of tax applicability on annuity payments. |
Chapter 8 |
LEP Product Setup – Periodic Load A reference has been made to a chapter in the Fund Manager User Manual, where Periodic Load has been explained. There is a difference in the way periodic load is maintained for UT transactions and Policies. This chapter highlights the same. |
Chapter 9 |
LEP Product Setup – Management Fee Applicability may be referred to only if a Management Fee is to be applied to a Product. |
Chapter 10 |
LEP Product Setup – GL Set Up A reference has been made to a chapter in the Fund Manager User Manual where the General Ledger Set Up has been explained. |
Chapter 11 |
LEP Product Setup – CMA explains more about CMA. |
Chapter 12 |
LEP Product Setup – PIGS explains in detail Prudential Investment Guidelines and Forex Compliance. |
Before you begin using this User Manual, it is important to understand the typographical conventions used in it.
Convention |
Type of Information |
Italic type |
Functional /foreign terms |
Numbered Bullet |
Step by step procedures |
Convention |
Keys |
All keys of the keyboard are represented in capital letters. For example, <CTRL>. |
Shortcut keys |
All short cut keys are contained in brackets. For example, <ALT+SHIFT>. |
This User Manual may refer to all or some of the following icons.
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
The following acronyms and abbreviations are adhered to in this User Manual:
Abbreviation/ Acronym |
Meaning |
ADMIN |
User Administrator |
AGY |
The Agency Branch component of the system |
AMC |
Asset Management Company |
BOD |
Beginning of Day |
CDSC |
Contingent Deferred Sales Charge |
CGT |
Capital Gains Tax |
CIF |
Customer Information File |
EOD |
End of Day |
EPU |
Earnings per unit |
FC-IS |
Oracle FLEXCUBE Investor Services |
FMG |
The Fund Manager component of the system |
FPADMIN |
Oracle FLEXCUBE Administrator |
ID |
Identification |
IHPP |
Inflation Hedged Pension Plan |
IPO |
Initial Public Offering |
LEP |
Life and Endowment Products |
LOI |
Letter of Intent |
NAV |
Net Asset Value |
REG |
The Registrar component of the system |
ROA |
Rights of Accumulation |
ROI |
Return on Investment |
SI |
Standing Instructions |
SMS |
Security Management System |
URL |
Uniform Resource Locator |
VAT |
Value Added Tax |
WAUC |
Weighted Average Unit Cost |
Online help is available for all tasks. You can get help for any function by clicking the help icon provided or by pressing F1.
