10. Cash Management Account
Cash Management Account is a money-market fund (in a portfolio of funds) that is used for recovering ongoing fees and annuity payments related to the funds in the portfolio. When the CMA is used for ongoing fee payments, it is called as an Expense Management Account (EPA) and for Annuity as an Income Management Account (IMA). The system calculates the ongoing fees as well as the annuity payments for a period of one year.
10.1 Cash Management Account
10.1.1 Cash Management Account Description
The following constitute the balance in a CMA:
The projected ongoing fees are calculated on the basis of the loads and load levels specified in the Product Load Maintenance and invested in the CMA.The investment into the CMA becomes available for recovery of fees only during top-up investments and not at the time of initial investment (since the CMA fund becomes operational only after the initial investment).
You need to keep in mind the following for loads for CMA:
10.1.2 CMA Operations
The various operations in a CMA are as follows:
Let us consider the following examples:
The fee set-up in an AMC is defined below:
Rate L4 – Ongoing Admin Fee per annum
Slab (in ZAR)
Rate (in %)
0 -100,000
0.5
100,000 – 500,000
0.25
L5 – Ongoing Broker Fee per annum
Slab (in ZAR)
Rate (in %)
0 -100,000
0.5
100,000 – 500,000
0.25
L1 – Initial Admin Fee
Slab (in ZAR)
Rate (in %)
0 -100,000
2.5
100,000 – 500,000
1.5
500,000 – 1,000,000
1
L2 – Initial Broker Fee
Slab (in ZAR)
Rate (in %)
0 -999,999,999
2.0
10.1.3 Operating CMA Generate Switch Transaction Batch
You can run this batch either on a periodic basis or manually. You can invoke ‘CMA Generate Switch Transaction’ screen by typing ‘UTDCMABP’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
If you wish to run this batch on a periodic basis during EOD, you can do so by defining the following System Parameters.
CMA Switch Date
You can specify the date on which you would want the batch run for the first time. For example, you may choose to run it on 2nd January.
CMA Switch Freq
You need to specify the frequency at which you would like the batch to be run. The system uses this information to run the batch from the second time on. For example, if you have specified a monthly frequency, the system checks every day to see if the current date matches the date defined by the CMA Switch Date and Freq. It then runs the batch when the date is 2nd February.
You can execute the CMA Generate Switch transaction Batch manually when ever you choose. The manual execution is independent of the parameters you may have specified above.
Note
During a top-up or switch transaction for a policy having funds in different currencies, the load amounts for the individual funds are converted to policy base currency before the CMA transaction.
