8. Management Fee
Management fee is the periodic load charged by the AMC from the customer.
This fee that the policyholder is charged will be used to pay the brokers
their commissions. Management fee is calculated for the total holding
in the policy, across all the funds and the amount is deducted from the
customer’s holdings through a redemption policy transaction. An
AMC, however, might not want to apply a fee on some funds. The Management
Fee Applicability screen allows you to apply a management fee to the
funds you wish.
While generating a redemption transaction for the management fee;
the system first checks if you have selected a fund against the field
‘Preferred Fund For Redemption’ in the Unit Holder Maintenance
screen (for further information on the Unit Holder Maintenance screen,
refer to the chapter Managing Investor Accounts in Volume 1 of the Agency
Branch User Manual)
- If you have, a redemption transaction will be generated for the fund
you have selected.
- If you have not, a redemption transaction will be generated for funds
you have marked as being applicable for Management Fee.
Note
You can apply a Management Fee to funds through the
Fund Manager component only.
The next section gives you step-by-step instructions to do the same.
8.1 Management Fee
8.1.1 Applying Management Fee
The following are the steps you need to follow to apply a Management
Fee to funds in a product. Each of these steps is explained in detail
in subsequent sections.
- Enter information in the ‘Management Fee Applicability Detail’
screen.
- Save the information entered.
8.1.2 Invoking Screen
You can invoke the ‘Management Fee Applicability Detail’
screen by typing ‘LEDMGMAP’ in the field at the top right corner
of the Application tool bar and clicking on the adjoining arrow button.
You can enter following details in the Management Fee Applicability
Screen
Product Details
In the Product Details section, you will have to enter information
in the following fields:
Product ID
Alphanumeric; 10 Characters; Mandatory
Select the ID of the product, the funds for which you are applying
a management fee. The option list includes all authorized products that
you have maintained.
Product Name
Display
The system displays the name of the selected fund ID.
When you select the Product ID and click ‘Get Funds’ button,
the funds mapped to it will be displayed in the Fund ID section.
Details
Fund ID
Alphanumeric; 6 Characters; Mandatory
Specify the fund ID.
Management Fee Applicable
Mandatory
Select if management fee is applicable or not from the drop-down list.
The list displays the following values:
For each fund that you want to apply the management fee to, select
the corresponding box.
8.1.3 Saving Information Entered
When you have entered all the mandatory information, click ‘Ok’
button.
The system displays the confirmation message as “Record Successfully
Saved”.
This indicates the record has been saved. Click ‘Ok’ button.
8.2 Management Fee Applicability Summary Screen
8.2.1 Invoking the Management Fee Applicability Summary
Screen
You can invoke the ‘Management Fee Applicability Summary’
screen by typing ‘LESMGMAP’ in the field at the top right corner
8.2.2 Retrieving Management Fee Applicability
You can retrieve a previously entered record in the Summary screen,
as follows:
Specify any or all of the following details in the Management Fee
Applicability Summary screen:
- Select the status of the record in the Authorization Status
field. If you choose the “Blank Space” option, then all the
records are retrieved.
- Select the status of the record in the Record Status field.
If you choose the “Blank Space” option, then all the records
are retrieved.
- Product ID
After you have specified the required details, click ‘Search’
button. All records with the specified details are retrieved and displayed
in the lower portion of the screen.
Note
You can also retrieve the individual record detail
from the detail screen by doing query in the following manner:
- Press F7
- Input the Product ID
- Press F8
You can perform Edit, Delete, Amend, Authorize, Reverse, Confirm operation
by selecting from the Action list.
You can also search the record by using combination of % and alphanumeric
value.
Example:
You can search the record for Product Type by using the combination
of % and alphanumeric value as follows:
- Search by A%: System will fetch all the records whose Product Type
starts from Alphabet ‘A’. For example, AGC17, AGVO6, AGC74
etc.
- Search by %7: System will fetch all the records whose Product Type
ends by numeric value’ 7’. For example, AGC17, GSD267, AGC77
etc.
- Search by %17%:- System will fetch all the records whose Product
Type contains the numeric value 17. For example, GSD217, GSD172, AGC17
etc.
8.2.3 Editing Management Fee Applicability
You can modify the details of a record that you have already entered
into the system, provided it has not been subsequently authorized. You
can perform this operation as follows:
- Invoke the Management Fee Applicability Summary screen
from the Browser.
- Select the status of the record that you want to retrieve
for modification in the Authorization Status field. You can only modify
records that are unauthorized. Accordingly, choose the Unauthorized option
from the drop down list.
- Specify any or all of the details of the record in the
corresponding fields on the screen to retrieve the record that is to
be modified. All unauthorized records with the specified details are
retrieved and displayed in the lower portion of the screen.
- Double click the record that you want to modify in the
list of displayed records. The Management Fee Applicability Detail screen
is displayed.
- Select Unlock Operation from Action list to modify the
record. Modify the necessary information.
- Click Save to save your changes. The Management Fee Applicability
Detail screen is closed and the changes made are reflected in the Management
Fee Applicability Summary screen.
8.2.4 Viewing Management Fee Applicability
To view a Management Fee Applicability you have previously entered,
you must retrieve the same in the Management Fee Applicability Summary
screen, as follows:
- Invoke the Management Fee Applicability Summary Screen
from the Browser.
for viewing in the Authorization Status field. You can also view all
records that are either unauthorized or authorized only, by choosing
the Unauthorized/ Authorized option.
- Specify any or all of the details of the records in the
corresponding fields on the screen, and click ‘Search’ button.
All records with the specified details are retrieved and displayed in
- Double click the record that you want to view in the list
of displayed records, in the lower portion of the screen. The Management
Fee Applicability screen is opened in view mode.
8.2.5 Deleting Management Fee Applicability
You can delete only unauthorized records in the system.
To delete a record that you have previously entered, you must retrieve
the same in the Management Fee Applicability Summary screen, as follows:
from the browser.
for deletion.
- Double click the record that you want to delete in the
list of displayed records, in the lower portion of the screen. Management
Fee Applicability Detail screen is opened in View mode.
- Select Delete operation from the Action list. The system
prompts you to confirm the deletion, and the record is deleted physically
from the system database.
8.2.6 Authorizing Management Fee Applicability
An unauthorized record must be authorized in the system for it to
be processed.
To authorize a record, you must first retrieve the same in the Management
from the Browser.
for authorization. Typically, choose the Unauthorized option from the
drop down list.
corresponding fields on the screen. Click ‘Search’ button.All
records with the specified details that are pending authorization are
- Double click the record that you wish to authorize. The
Management Fee Applicability Detail screen is opened in View mode.
- Select Authorize operation from Action list.
When the checker authorizes a record, details of validations, if any,
that were overridden by the maker of the record during the Save operation,
are displayed. If any of these overrides results in an error, the checker
must reject the transaction.
8.2.7 Amending Management Fee Applicability
After a record is authorized, it can be modified using the Unlock
operation from Action list. To make changes to a record after authorization,
you must invoke the Unlock operation which is termed as Amend Operation.
from the Browser.
- Select the status of the record that you wish to retrieve
for amendment. You can only amend records that are authorized.
corresponding fields on the screen. All records with the specified details
are retrieved and displayed in the lower portion of the screen.
- Double click the record that you want to amend. The Management
Fee Applicability screen will be displayed in Amendment mode. Click the
Unlock operation from the Action list to amend the record.
- Amend the necessary information. Click the Save button
8.2.8 Authorizing Amended Management Fee Applicability
An amended Management Fee Applicability must be authorized for the
amendment to be made effective in the system.
Authorization of amended records can only be done from Fund Manager
Module and Agency branch Module. The process of authorization is subsequently
the same as that for normal transactions.
