The system provides the facility of capturing the details of tax applicability on annuity payments.
Note
With-Holding Tax Products can be defined through the Fund Manager component only.
The With-Holding Tax Product – Load Mapping screen allows you to capture the characteristics of the With-Holding Tax Product you wish to maintain. The next section gives you step-by-step instructions to do the same.
The following are the steps you need to follow to define a With-Holding Tax Product. Each of these steps is explained in detail in subsequent sections.
You can invoke the ‘Product With-holding Tax Detail’ screen by typing ‘LEDPWHTD’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Select ‘New’ from the Actions menu in the Application tool bar or click new icon to enter the details of the Product WHT Setup.
You can enter the following details in this screen:
In the WHT Product – Load Mapping section, you will have to enter information in the following fields:
Product ID
Alphanumeric; 10 Characters; Mandatory
Select the Product for which the tax on annuity details needs to be captured from the option.
Product Name
Display
The system displays the product name.
Load ID
Alphanumeric; 5 Characters; Mandatory
Select the load corresponding to with-holding tax from option list.
Load Description
Display
The system displays the description for the selected load ID.
Effective Date
Date Format; Mandatory
Select the date from which the tax details captured from the adjoining calendar.
Age Limit Applicable for Rebates
Optional
Select ‘Yes’ to indicate an age limit constraint is applicable for eligibility for rebates on the tax.
Note
If you select ‘Yes’, the Rebate Details section is displayed as shown below.
Applicable for CGT
Optional
Select ‘Yes’ if applicable for CGT from drop-down list. Else ‘No’.
Note
This section will be displayed only if have checked the box ‘Age Limit Applicable for Rebates’.
You will have to enter information in the following fields in this section.
Age From
Numeric; 3 Characters; Mandatory
Specify the age from which the rebates are applicable.
Age To
Specify the age up to which the rebates are applicable.
Rebate Amount
Numeric; 30 Characters; Mandatory
Specify the amount of rebate that is applicable.
You can click add icon to add the tax details.
Note
Click on ‘Tax Class Details’ tab to enter tax class details.
You can specify the following details:
Policy Tax Class
Alphanumeric; 3 Characters; Mandatory
Specify the policy tax class details. Alternatively, you can select policy tax class from the option list. The list displays all the valid policy tax class details maintained in the system.
Load ID for Tax Class
Numeric; 5 Characters; Mandatory
Specify the load ID for tax class details. Alternatively, you can select load ID for tax class from the option list. The list displays all the valid load ID for tax class details maintained in the system.
Tax class load mapping will be allowed only if ‘Applicable for CGT’ field is selected as ‘Yes’.
When you have entered all the mandatory information; click ‘Ok’ button.
The system displays the confirmation message as “Record Successfully Saved ”.
This indicates the record has been saved. Click ‘Ok’ button.
You can invoke the ‘Product With-holding Tax Summary’ screen by typing ‘LESPWHTD’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.:
You can retrieve a previously entered record in the Summary screen, as follows:
Specify any or all of the following details in the Product With-Holding Tax Summary screen:
After you have specified the required details, click ‘Search’ button. All records with the specified details are retrieved and displayed in the lower portion of the screen.
Note
You can also retrieve the individual record detail from the detail screen by doing query in the following manner:
You can perform Edit, Delete, Amend, Authorize, Reverse, Confirm operation by selecting from the Action list.
You can also search the record by using combination of % and alphanumeric value.
For example
You can search the record for Product ID by using the combination of % and alphanumeric value as follows:
You can modify the details of a record that you have already entered into the system, provided it has not been subsequently authorized. You can perform this operation as follows:
To view a Product With-Holding Tax you have previously entered, you must retrieve the same in the Product With-Holding Tax Summary screen, as follows:
You can delete only unauthorized records in the system.
To delete a record that you have previously entered, you must retrieve the same in the Product With-Holding Tax Summary screen, as follows:
An unauthorized record must be authorized in the system for it to be processed.
To authorize a record, you must first retrieve the same in the Product With-Holding Tax Summary screen.
When the checker authorizes a record, details of validations, if any, that were overridden by the maker of the record during the Save operation, are displayed. If any of these overrides results in an error, the checker must reject the transaction.
After a record is authorized, it can be modified using the Unlock operation from Action list. To make changes to a record after authorization, you must invoke the Unlock operation which is termed as Amend Operation.
An amended Product With-Holding Tax must be authorized for the amendment to be made effective in the system.
