The following are the steps you need to follow to enter and save Allocation Details. Each of these steps is explained in detail in subsequent sections.
You can invoke the ‘Allocation Details’ screen by typing ‘LEDPLALC’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Select ‘New’ from the Actions menu in the Application tool bar or click new icon to enter the details of the Allocation Details.
You can specify the following fields in this screen:
Product ID
Alphanumeric; 10 Characters; Mandatory
Select the product ID from the option list.
Policy Number
Alphanumeric; 16 Characters; Mandatory
Select the Policy Number from the option list.
Transaction Type
Alphanumeric; 2 Characters; Mandatory
Select the transaction type from the option list.
Policy Txn Number
Select the policy transaction number from the option list.
Allotted?
Mandatory
If you want to allot allocation, select ‘Yes’. Else ‘No’.
Transaction Amount
Display
The system displays the amount applied for the transaction.
Date of Allocation
Display
The system displays the date of allocation.
Gross Amount
Display
The system displays the Gross Amount.
Switch In Gross Amount
Display
The system displays the Switch in Gross Amount for Switch in Fund.
Net Investible Amount
Display
The system displays the Net Investible amount.
Click ‘Fetch Allocation Details’ button to specify the Fund Transactions, Allocation Details and Fee Details.
The system displays the following values:
The system displays the following details:
Note
If load is applied at product level, the policy transaction amount gets converted in terms of product base currency, while computing the amount slabs. The transaction amount in product base currency is calculated using the latest available exchange rate for the default source.
If exchange rate is not available for the currency pair, the allocation fails.
