Welcome to Oracle FLEXCUBE Investor Servicing™, a comprehensive mutual funds automation software from Oracle Financial Servicing Software Ltd. ©.
This Oracle FLEXCUBE Investor Servicing User Manual helps you use the system to achieve optimum automation of all your mutual fund investor servicing processes. It contains privacy by design guidelines for specific tasks, descriptions of various features and processes in the system and general information.
The User Manual is organized in to various parts, each discussing a component of the Oracle FLEXCUBE Investor Servicing system.
This Fund Manager User Manual is intended for the Fund Administrator users and system operators in the AMC.
This volume of the Fund Manager User manual is organized under the following chapter sequence:
Chapter |
Description |
Chapter 1 |
About This Manual explains the structure, audience, organization, and related documents of this manual. |
Chapter 2 |
Privacy By Design – explains the details about personal identifiable information, consent maintenance, transparent data encryption. |
Before you begin using this User Manual, it is important to understand the typographical conventions used in it.
Convention |
Type of Information |
Italics type |
Functional /foreign terms |
Numbered Bullet |
Step by step procedures |
Convention |
Keys |
All keys of the keyboard are represented in capital letters. For example, <CTRL>. |
Shortcut keys |
All short cut keys are contained in brackets. For example, <ALT+SHIFT>. |
This User Manual may refer to all or some of the following icons.
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
The following acronyms and abbreviations are adhered to in this User Manual:
Abbreviation/ Acronym |
Meaning |
MFA |
Multi Factor Authentication |
TDE |
Transparent Data Encryption |
PII |
Personal Identifier Information |
Online help is available for all tasks. You can get help for any function by clicking the help icon provided or by pressing F1.
