This User Guide is intended to familiarize you with the light-weight REST based services of Oracle FLEXCUBE Investor Servicing. The manual gives you an overview of the services developed, input\request parameters and the response of the each REST service.
The manual is intended for integrating external systems to Oracle FLEXCUBE Investor Servicing using RESTFUL framework.
The manual is organized into the following chapters:
Chapter |
Description |
Chapter 1 |
Preface - Gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
Chapter 2 |
Rest API - An Overview provides a snapshot of the features of the entire module. |
Chapter 3 |
Rest API Services –List of APIs. |
