Oracle FLEXCUBE Investor Servicing is accessibility compliant. This chapter deals with the following activities on the screens available in the browser:
You can minimize main screens by clicking minimize button. The minimized screens reside in the provided task bar. These minimized screens can be maximized either from the task bar or from the windows menu option.
Oracle FLEXCUBE Investor Servicing is compatible with keyboard. You can comfortably navigate using arrow keys and tab keys. You can use the appropriate keyboard shortcuts to navigate through the following sections:
Oracle FLEXCUBE Investor Servicing provides keyboard compatibility in navigating through Side Bar and Toolbar of the Application Browser.
Side bar menu refers to the menus available in the Application Browser. You can navigate through the side bar menus using Tab Key, Shift and Tab Key, and Arrow Keys. The side bar menus include Menu, Workflow, Customer, My Dashboard, etc.
Tab Key
Note
If the action keys are hidden, then it moves to the first drop-down menu.
Shift + Tab Key
Note
If the element of the side bar menu container further opens its details in the dashboard then the focus will shift to the first element of the detail.
Arrow Keys
You can even navigate through the toolbar options using keyboard.
You can navigate through Action Keys using keyboard.
Tab Key
Shift + Tab Key
Arrow Keys
You can navigate through drop-down menus using keyboard.
Tab Key
Shift + Tab Key
Note
If the action keys are hidden, then it moves the focus to the last side bar menu.
Arrow Keys
Esc
Oracle FLEXCUBE provides keyboard compatibility to navigate through Detailed and Summary screens. Detail screens contain Tabs and Buttons. Clicking them opens a sub-screen. Hence, navigation in these screens is handled in different stages.
Generic navigation involves navigating through the general fields available.
Tab Key
Shift +Tab Key
Shortcut keys
Tabs Navigation
Tabs navigation involves navigating through the tabs available.
Tab Key
Shift +Tab Key
Arrow Keys
Data Table navigation involves navigating through the rows and cells of the rows in the table.
Tab Key
Shift +Tab Key
Up and Down Arrow Keys
Shortcut Keys
To avoid focusing on pagination, adding row, deleting row, and single view buttons of data table; the following shortcut keys are available:
You can open single view screen by using ‘Ctrl + I’ shortcut key.
Tab Key
Esc
Shortcut Keys
To avoid focusing on navigation buttons, the following shortcut keys are available:
You can open LOV window by pressing ‘F4’ key. LOV navigation involves navigating through the list of values available.
Tab Key
Shift +Tab Key
Esc
Arrow Keys
Shortcut Keys
You can open Calendar window by pressing ‘F4’ key. Calendar navigation involves navigating through the years, months, and days.
Tab Key
Shift +Tab Key
Esc
Arrow Keys
Shortcut Keys
You can open Editor window by pressing ‘F4’ key.
Tab Key
Esc
Note
Press ‘Enter’ if the editor window is only a display field.
Summary screens display details related to a specific query based on the selected criteria available in the screen. Navigation through these criteria can be handled through keyboard keys.
Tab Key
Shift +Tab Key
Arrow Keys
Shortcut Keys
Advance search navigation involves navigating through Query criteria and Other Fields listed in the window.
Tab Key
Arrow Keys
