FATCA is the acronym for Foreign Account Tax Compliance Act enacted by the US Government as part of the Hiring Incentives to Restore Employment (HIRE) Act, in 2010.The purpose of FATCA is to help Internal Revenue Service (IRS) to identify and collect tax from US Persons (USP) holding financial assets outside US.
This chapter deals with Foreign Account Tax Compliance regulation. It includes the description about functions that would help FCIS to support FATCA.
The below mentioned table describe the system parameters for the related fields:
Field |
System Parameter |
Maximum Length |
FATCA Classification –Individual |
FATCACATIND |
10 |
FATCA Classification –Corporate |
FATCACATCOR |
10 |
FATCA Classification Reasons |
FATCACATREASON |
10 |
FATCA Effective Date |
FATCAEFFDATE |
10 |
FATCA Individual UH Reporting |
FATCAINDUHLIMIT |
10 |
FATCA Corporate UH Reporting |
FATCACORPUHLIMIT |
10 |
FATCA Verification Time Limit in days |
FATCAVERTMLIMIT |
4 |
FATCA Due Diligence Date |
FATCADUEDELIGENCEDATE |
10 |
FATCA Country Code |
FATCACNTRYCD |
3 |
FATCA Amount Limit |
FATCAAMOUNTLIMIT |
10 |
FATCA WHT Applicable |
FATCAWHTAPPLICABLE |
3 |
FATCA WHT Effective Date |
FATCAWHTEFFDT |
10 |
FATCA WHT Percentage |
FATCAWHTPERCENTAGE |
3 |
Document for individuals |
MASTERDOCIND |
Max |
Document for corporate |
MASTERDOCCORP |
Max |
Category of the documents |
MASTERDOCCAT |
3,2 |
Max % of holding for Corporate UH for the defined directors |
FATCAMINPCNTHLDG |
Max |
The international dialling country code |
INTDIALCODE |
You can maintain FATCA Classification and record document details in the ‘Entity FATCA Classification Maintenance Detail’ screen. To invoke this screen type ‘UTDFATMT’ in the field at the top right corner of the Application tool bar and click on the adjoining arrow button.
You can capture the following details in this screen:
Reference Number
Display
The system displays the reference number.
FATCA Entity Type
Alphanumeric; 2 Characters; Mandatory
Select the FATCA entity type from the adjoining option list. The options available are:
FATCA Entity Type Description
Display
The system displays the description for the selected FATCA entity type.
Entity ID
Alphanumeric; 12 Characters; Mandatory
Select the Entity identification from the adjoining option list.
You can also query for entity ID by clicking ‘Find UH’ button.
Entity Name
Display
The system defaults the entity name from the entity record.
Entity Category Type
Display
The system displays the entity category type.
Alphanumeric; 25 Characters; Mandatory
Select the FATCA Classification from the adjoining option list.
Description
Display
The system displays the description for the selected FATCA classification.
Select the reason for FATCA classification from the adjoining option list.
Description
Display
The system displays the description for the selected FATCA classification reason.
FATCA Reportable
Optional
Select the FATCA Reportable status for the entity selected from the drop-down list. The list displays the following values:
FATCA With holdable
Optional
Select the FATCA with holdable status for the entity selected from the drop-down list. The list displays the following values:
Document Category
Select the document category from the adjoining option list.
Document Category Description
Display
The system displays the description for the selected document category.
Document Type
Select the type of the document from the adjoining option list.
Document Type Description
Display
The system displays the description for the selected document type.
Mandatory
Optional
You need to indicate whether the document is mandatory or optional. The drop-down list displays the following options:
Select the appropriate option.
Document ID
Alphanumeric; 25 Characters; Optional
Specify the document identification.
Issue Date
Date Format; Mandatory
Specify the issue date of the received document.
Expiry Date
Date Format; Optional
Specify the expiry date of the received document.
Copy Received
Mandatory
Check this box to indicate that the copy is received.
Original Received
Mandatory
Check this box to indicate that the original is received.
Received Date
Specify the document received date.
Document Reference Number
Alphanumeric; Optional
Specify the document tracking reference number.
Remarks
Alphanumeric; 255 Characters; Optional
Specify remarks, if any.
Chasing Date
Specify the document chasing date.
Specify the document reference number
Document Serial Number
Display
The system displays the document serial number.
Document Upload
Click this button to upload or view the documents.
FATCA Compliant
Display
The system displays whether you are FATCA compliant.
Description
Display
The system displays the description for the FATACA compliant.
Reason
Click ‘View’ button. The ‘Single Entity Maintenance Detail’ screen is displayed. You can maintain the details of single entity in this screen.
Click on Linked Entity button to view linked entity details.
The system displays the following values:
View
Click on ‘View’ to view the details of FATCA Maintenance of a linked entity.
Note
During UT Transaction capture for US Indicia Available Funds, if the FATCA Status of the unit holder or linked entity of a unit holder is:
During LEP Transaction capture for US Indicia Available Funds, if the FATCA Status of the unit holder or linked entity of a unit holder is:
If the US Indicia is available for one of the customer during the CIF merge, then the customer account to which this account is being merged will also be US Indicia.
You can view, modify, delete and authorize Entity FATCA Classification Maintenance details in the ‘Entity FATCA Classification Maintenance Summary’ screen. You can invoke this screen by typing ‘UTSFATMT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can perform the following actions using this screen
You can view previously entered details of Entity FATCA Classification Maintenance Detail in the ‘Entity FATCA Classification Maintenance Summary’ screen, as follows:
Click ‘Search’ button to view the records. All records with the specified details are retrieved and displayed in the lower portion of the screen.
You can also search the record by using combination of % and alphanumeric value.
You can delete only unauthorized records in the system. To delete a record that you have previously entered:
You can modify only unauthorized records in the system. To modify a record that you have previously entered:
You can authorize records in the system. To authorize a record that you have previously entered:
You can maintain FATCA with holding tax repayment using ‘FATCA WHT Repayment’ screen. You can invoke this screen by typing ‘UTDFATRP’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
You can specify the following details:
Entity Type
Alphanumeric; 1 Character; Optional
Specify the entity type. Alternatively, you can select entity type from the option list. The list displays all valid entity types maintained in the system.
Entity ID
Alphanumeric; 12 Characters; Optional
Specify the entity ID. Alternatively, you can select entity ID from the option list. The list displays all valid entity ID maintained in the system.
Submit For
Optional
Select the submit option from the drop-down list. The list displays the following values:
