9. Maintaining Time Zones
9.1 Time Zone
9.1.1 Maintaining Time Zones
Oracle FLEXCUBE Investor Servicing (FCIS) enables you to capture time
zones for a particular module. This feature is particularly applicable
if you are using Oracle FLEXCUBE Investor Servicing for your Financial
Services across the globe.
The ‘Time Zone Maintenance Detail’ screen allows you to
capture time zones for various modules. You can invoke this screen by
typing ‘UTDTIMEZ’ in the field at the top right corner
of the Application tool bar and clicking on the adjoining arrow button.
Select ‘New’ from the Actions menu in the Application tool
bar or click new icon to enter the time zone details.
You can specify the following fields in this screen:
Time Zone
Alphanumeric; 12 Characters; Mandatory
Enter the Time Zone. This can be captured for a particular entity.
Description
Alphanumeric; 255 Characters; Mandatory
Enter a brief description of the Time Zone specified.
Rule Effective Date
Date Format; Mandatory
Enter the date from when the Time Zone has to be considered for any
particular entity.
Daylight Start Date
Date Format; Optional
Specify the date from when the Daylight Saving Time or Summer Time
starts.
Daylight End Date
ends.
Offset From GMT (HH24:MI:SS)
Numeric; 24 Characters; Mandatory
Enter the time difference between the Time Zone and Greenwich Meridian
Time.
Server Time Zone
Optional
Select ‘Yes’ from drop-down list to specify if the time
zone code is where the server would be located.
Behind GMT
Optional
Select ‘Yes’ from drop-down list to denote that the Time
Zone being maintained is behind GMT.
Click ‘Ok’ button to save the Time Zone captured in the
system.
Note
- If there are multiple time zones within a country, one Front office
module (agency branch) has to be created and associated to each time
zone.
- The latest rule of the time zone incase it has been amended is updated
during BOD processing.
9.2 Time Zone Maintenance Summary Screen
- Section 9.2.1, "Invoking the Time Zone Maintenance Summary
Screen"
- Section 9.2.2, "Retrieving Record in Time Zone
Summary Screen"
- Section 9.2.3, "Editing Time Zone Maintenance"
- Section 9.2.4, "Viewing Time Zone Maintenance"
- Section 9.2.5, "Deleting Time Zone Maintenance"
- Section 9.2.6, "Authorizing Time Zone Maintenance"
- Section 9.2.7, "Amending Time Zone Maintenance"
- Section 9.2.8, "Authorizing Amended Time Zone
Maintenance"
- Section 9.2.9, "Copying Attributes"
- Section 9.2.10, "Database and Web Server Time"
9.2.1 Invoking the Time Zone Maintenance Summary Screen
To perform any operation on Fund-ISIN association, you must first
retrieve the record from the database in the Summary screen. You can
invoke the ‘Time Zone Maintenance Summary’ screen by typing
‘UTSTIMEZ’ in the field at the top right corner
- You can perform the following operations on a Time Zone:
- View
- Edit
- Delete
- Authorize
- Amend
- Authorize an amended record
- Copy the Attributes
9.2.2 Retrieving Record in Time Zone Summary Screen
You can retrieve a previously entered record in the Summary Screen,
as follows:
Invoke the summary screen and specify any or all of the following
details in the corresponding fields:
- The status of the record in the Authorized field. If you choose the
‘Blank Space’ option, then all the records are retrieved.
- The status of the record in the Open field. If you choose the ‘Blank
Space’ option, then all records are retrieved
- Time Zone
- Click ‘Search’ button to view the records. All the records
with the specified details are retrieved and displayed in the lower portion
of the screen.
Note
You can also retrieve the individual record detail
from the detail screen by querying in the following manner:
- Press F7
- Input the Time Zone
- Press F8
You can perform Edit, Delete, Amend, Authorize, Reverse, Confirm operations
by selecting the operation from the Action list. You can also search
a record by using a combination of % and alphanumeric value.
Example
You can search the record for Time Zone by using the combination of
% and alphanumeric value as follows:-
- Search by I%: The system will fetch all the records
whose Time Zone starts from Alphabet ‘I’. For example, IST
and so forth.
- Search by %7 : The system will fetch all the records
whose Time Zone ends by numeric value’ 7’ .For example, AGC17,GSD267,AGC77
and so forth.
- Search by %17%: The system will fetch all the records
whose Time Zone contains the numeric value 17. For example, GSD217, GSD172,
AGC17 and so forth.
9.2.3 Editing Time Zone Maintenance
You can modify the details of a Time Zone Maintenance that you have
already entered into the system, provided it has not been subsequently
authorized. You can perform this operation as follows:
- Invoke the Time Zone Summary screen from the Browser.
- Select the status of the record that you want to retrieve for modification
in the Authorized field. You can only modify records that are unauthorized.
Accordingly, choose the unauthorized option.
- Specify any or all of the details in the corresponding fields to
retrieve the record that is to be modified.
- Click ‘Search’ button. All unauthorized records with
of the screen.
- Double click the record that you want to modify in the list of displayed
records. The Time Zone Detail screen is displayed.
- Select Unlock Operation from the Action list to modify the record.
Modify the necessary information.
- Click Save to save your changes. The Time Zone Maintenance Detail
screen is closed and the changes made are reflected in the Time Zone
Summary screen.
9.2.4 Viewing Time Zone Maintenance
To view a record that you have previously input, you must retrieve
the same in the Time Zone Summary screen as follows:
- Select the status of the record that you want to retrieve for viewing
in the Authorization Status field. You can also view all records that
are either unauthorized or authorized only, by choosing the Unauthorized/
Authorized option.
- Specify any or all of the details of the record in the corresponding
fields on the screen.
- Click ‘Search’ button. All records with the specified
fields are retrieved and displayed in the lower portion of the screen.
- Double click the record that you want to view in the list of displayed
records. The Time Zone Maintenance Detail screen is displayed in View
mode.
9.2.5 Deleting Time Zone Maintenance
You can delete only unauthorized records in the system. To delete
a record that you have previously entered:
- Select the status of the record that you want to retrieve for deletion.
- Specify any or all of the details in the corresponding fields on
the screen.
- Double click the record that you want to delete in the list of displayed
records. The Time Zone Maintenance Detail screen is displayed.
- Select Delete Operation from the Action list. The system prompts
you to confirm the deletion and the record is physically deleted from
the system database.
9.2.6 Authorizing Time Zone Maintenance
An unauthorized Time Zone Maintenance must be authorized in the system
for it to be processed. To authorize a record:
- Select the status of the record that you want to retrieve for authorization.
Typically, choose the unauthorized option.
the screen.
details that are pending authorization are retrieved and displayed in
- Double click the record that you wish to authorize. The Time Zone
Maintenance Detail screen is displayed. Select Authorize operation from
the Action List.
When a checker authorizes a record, details of validation, if any,
that were overridden by the maker of the record, during the Save operation
are displayed. If any of these overrides results in an error, the checker
must reject the record.
9.2.7 Amending Time Zone Maintenance
After a Time Zone Maintenance is authorized, it can be modified using
the Unlock operation from the Action List. To make changes to a record
after authorization:
You can only amend authorized records.
the screen.
Maintenance Detail screen is displayed in amendment mode. Select Unlock
operation from the Action List to amend the record.
- Amend the necessary information and click on Save to save the changes.
9.2.8 Authorizing Amended Time Zone Maintenance
An amended Time Zone Maintenance must be authorized for the amendment
to be made effective in the system. The authorization of amended records
can be done only from Fund Manager Module and Agency Branch module.
The subsequent process of authorization is the same as that for normal
transactions.
9.2.9 Copying Attributes
If you want to create a new Time Zone Maintenance with the same attributes
of an existing maintenance, you can copy the attributes of an existing
Time Zone Maintenance to a new one.
To copy the attributes:
- Retrieve the record whose attributes the new Time Zone Maintenance
should inherit. You can retrieve the record through the Summary screen
or through the F7-F8 operation explained in the previous sections of
this chapter.
- Click on Copy
- Indicate the ID for the new Time Zone Maintenance. You can, however,
change the details of the new maintenance.
9.2.10 Database and Web Server Time
The Agency Branch is the entity for which a Time Zone is associated.
The Agency Branch module time is used instead of the Database server
time as the transaction save and authorization time. The Agency Branch
time is arrived by the time zone set for it with respect to the module
from which the transaction is being captured.
During handoff of Fund Rule, the cut off time is not changed as per
the local time, but Fund Amendment is allowed from distributor. The fund
cut off time must be amended manually to reflect the local time by the
Distributor. This Fund local time is used to arrive into transaction
cut off time at the time of transaction capturing from distributor and
if the fund local time exceeds the fund cut off time the transaction
date is captured as next working date.
9.3 Default Time Zones and Scheduler Changes Maintenance
Each Agency Branch is associated with a time zone. This time zone
is used in case a country has multiple time zones.
While setting up the job for scheduler, you can schedule a job based
on the client time. This time has to be the web server time for that
module.
The Defaults Maintenance screen allows you to capture the default
time zone.
Refer to the chapter ‘Maintaining System Parameters’ in
this User Manual for further information on the Defaults Maintenance
screen.
