The external files containing the information that is to be imported from the bulk client are required to be in the following format:
File Type |
ASCII EXCEL |
ASCII file format |
Delimited Fixed width |
Field delimiter |
Comma Tab Colon Semi colon Space |
String delimiter |
Single quotes Double quotes NULL |
Date Format (all dates will have 4 digit years) |
DMY MDY DMonY YMD |
Date delimiter |
/ (Slash) Hyphen (Space) From registry |
Decimal symbol |
Point Comma |
Digit grouping symbol |
Point Comma |
Negative Sign symbol |
Hyphen Parenthesis |
Time delimiter |
Null Colon Semi colon Space |
Column Header on first line |
True / False |
Note
You can maintain only one sheet in the template.
Segment Identification Number |
Description |
Segment Mandatory / Optional? |
00UH |
This segment is used for providing UnitHolder related Information |
Mandatory |
01KYC |
This segment is used for providing KYC related Information |
Mandatory |
02BEN |
This segment is used for providing Beneficiary related Information |
Mandatory |
03BNK |
This segment is used for providing UnitHolder Bank related Information |
Mandatory |
04INM |
This segment is used for providing UnitHolder Intermediary related Information |
Mandatory |
05DEL |
This segment is used for providing UnitHolder Delivery related Information |
Optional |
06REL |
This segment is used for providing UnitHolder Related Parties related Information |
Optional |
07JNT |
This segment is used for providing UnitHolder JointHolder related Information |
Optional |
08NME |
This segment is used for providing Nominee related Information |
Optional |
09DIR |
This segment is used for providing Director related Information |
Optional |
10ADD |
This segment is used for providing Additional Information related Information |
Optional |
11KAP |
This segment is used for providing KYC Application form related Information |
Optional |
12STP |
This segment is used for providing Stop Code Restrictions related Information |
Optional |
13COM |
This segment is used for providing Communication Mode Restrictions related Information |
Optional |
14KII |
This segment is used for providing Unit Holder KIID Details |
Optional |
15CON |
This segment is used for providing Unit Holder Contact information |
Optional |
Note
For all imports of unit holder new account and information change data, the external hand-off file containing the information must:
Serial Number: 1
Segment Identification Number: 00UH
Description: This segment is used for providing UnitHolder related Information.
Segment Mandatory / Optional: Mandatory
Field Name (as expected in the file) |
Data type |
Length |
Mandatory |
Characteristics/rules |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id. Value of Segment Id is 00UH |
SEQUENCENUMBER |
Number |
10 |
Mandatory |
System generated sequence number of records in the file |
PROCESSID |
String |
50 |
Mandatory |
The Process ID, along with the system generated sequence number, identifies the uploaded record uniquely. Each file must have a unique Process ID. This should be same for all records within a file. |
BULKCLIENTCODE |
String |
12 |
Mandatory |
The Code of the Bulk client. |
IMPORTFILENAME |
String |
255 |
Mandatory |
Name of the file being uploaded should be specified. Each file must have a unique name. |
AMCID |
String |
12 |
Mandatory |
The ID of the AMC/Distributor for which the bulk client has maintained the defaults details. |
UPLOADMODE |
String |
1 |
Mandatory |
“N” for New unit holder uploads and ‘I’ for Incremental change. |
CIFNUMBER |
String |
12 |
Optional |
CIF Number |
UNITHOLDERID |
String |
12 |
Mandatory |
Is blank for new record |
REFERENCENUMBER |
String |
12 |
Mandatory |
Accepted from hand off file contents; or system generated reference number, according to the option selected in the Bulk Account Client Defaults for “unit holder import” or “both” |
ACCOUNTOPENINGDATE |
DATE |
Optional |
If this is not found in the hand off file, the application date is deemed as the account opening date by default. |
TITLE |
String |
15 |
Optional |
Value defaulted as maintained in Bulk client defaults in the absence of information in the file |
This should be one of the valid Title codes as maintained in system parameters. |
FIRSTNAME |
String |
100 |
Mandatory |
Accepted from the user’s specification for the same in the hand off file contents |
MIDDLENAME |
String |
40 |
Optional |
LASTNAME |
String |
40 |
Optional |
ACCOUNTOPERATIONTYPE |
String |
1 |
Optional |
Could be any of the values in the following list: S- Single, E- Either Or Survivor, J-Joint |
FIRSTNOMINEE |
String |
60 |
Accepted from the user’s specification for the same in the hand off file contents – This information is mandatory for Account Operation type as “J” – Joint |
SECONDNOMINEE |
String |
60 |
THIRDNOMINEE |
String |
60 |
Optional |
FATHER_SPOUSENAME |
String |
20 |
Optional |
INVESTORTYPE |
String |
1 |
Optional |
Could be any of the values from the following list: I – Individual Or C – Corporate – Mandatory |
CONTACTADDRESSLINE1 |
String |
105 |
Optional |
CONTACTADDRESSLINE2 |
String |
105 |
Optional |
PRIMARYCITY |
String |
105 |
Optional |
PRIMARYSTATE |
String |
80 |
Optional |
PRIMARYUSSTATE |
Number |
1 |
Optional |
Should be left blank |
ZIPCODE |
String |
10 |
Optional |
Hand off file contents |
SECONDARYADDRESSLINE1 |
String |
105 |
Optional |
Address Line 1 |
SECONDARYADDRESSLINE2 |
String |
105 |
Optional |
Address Line 2 |
SECONDARYCITY |
String |
105 |
Optional |
SECONDARYSTATE |
String |
80 |
Optional |
SECONDARYUSSTATE |
Number |
1 |
Optional |
SECONDARYZIPCODE |
String |
10 |
Optional |
SWIFTADDRESSLINE1 |
String |
105 |
Optional |
SWIFTADDRESSLINE2 |
String |
105 |
Optional |
SWIFTADDRESSLINE3 |
String |
105 |
Optional |
SWIFTADDRESSLINE4 |
String |
80 |
Optional |
Address Line 4 |
SWIFTCOUNTRYCODE |
String |
3 |
Optional |
Country Code |
BICCODE |
String |
16 |
Optional |
BIC Code |
HOMETELEPHONENUMBER |
String |
60 |
Optional |
OFFICETELEPHONENUMBER |
String |
60 |
Optional |
FAXNUMBER |
String |
120 |
Optional |
TAXDEDUCTEDATSOURCE |
Number |
1 |
Optional |
Could be either true (1) or false (0) |
TAXID |
String |
50 |
Optional |
TAXCIRCLE |
String |
15 |
Optional |
IDENTIFICATIONTYPE |
String |
3 |
Optional |
Could be any of the values maintained in Params maintenance for Identification Type |
IDENTIFICATIONNUMBER |
String |
50 |
Mandatory |
IDENTIFICATIONISSUEDATE |
DATE |
Optional |
IDENTIFICATIONEXPIRYDATE |
DATE |
Optional |
RESIDENTSTATUS |
String |
1 |
Optional |
Could be any of the values from the following list: "R";"Resident";;"F";"Foreign" |
UHCATEGORY |
String |
2 |
Mandatory |
Could be any of the valid values from the Category list maintained |
ACCOUNTSTMTFREQ |
String |
1 |
Optional |
Could be any of the values in the following list from Frequency Table : D – Daily, W - Weekly, F - Fortnightly, M – Monthly, Q - Quarterly, H - Half Yearly, Y - Yearly |
YTDSTMTREQD |
Number |
1 |
Optional |
Accepted from the user’s specification for the same in the hand off file contents. By default, it is deemed to be 'No' |
DATEOFBIRTH |
DATE |
Optional |
GUARDIANNAME |
String |
70 |
Optional |
RELATIONSHIP |
String |
70 |
Optional |
BENEFICIARY |
String |
70 |
Optional |
SEX |
String |
1 |
Optional |
Could be either of the following values - “M”(Male) or ”F” (Female) |
MARITALSTATUS |
String |
1 |
Optional |
Could be either of the following values - “S” (Single) ,”M” (Married). The default status is taken to be Single. |
OCCUPATION |
String |
3 |
Mandatory |
Could be any of the values maintained in Occupation Maintenance |
NATIONALITY |
String |
3 |
Optional |
COUNTRYOFDOMICILE |
String |
3 |
Optional |
Could be any of the values maintained in Country Maintenance |
CORPORATIONTYPE |
String |
3 |
Optional |
Could be any of the valid values maintained in Corporation Maintenance. This information can be specified only for corporate investors (Investor Type – C) |
FIRSTAUTHORIZEDSIGNATORY |
String |
70 |
Optional |
SECONDAUTHORIZEDSIGNATORY |
String |
70 |
Optional |
THIRDAUTHORIZEDSIGNATORY |
String |
70 |
Optional |
CONTACTNAME |
String |
70 |
Optional |
MINNOOFCORPORATESIGNATORY |
Number |
Optional |
SCHEMECROSSREFNO |
60 |
Optional |
Scheme/Cross Reference Number |
UHBASECURRENCY |
String |
3 |
Optional |
Could be any of the valid currencies maintained in Currency Maintenance. If this information is not given in the import file, then the default unit holder base currency specified in the Bulk Client Defaults Maintenance for the bulk client will be used. |
LANGUAGE |
String |
12 |
Optional |
Could be any of the languages defined in the system. If this information is not given in the import file, then the Default Language Value mentioned in the Bulk Client Defaults Maintenance for the bulk client will be used. |
REDEMPTIONMOP |
String |
1 |
Optional |
Could be either of the following Values: “Q” - Cheque, “T” – Transfer. If this information is not given in the import file, then the Default Redemption Mode of Payment specified in the Bulk Client Defaults Maintenance for the bulk client will be used. |
ACCOUNTSTMTCURRENCY |
String |
3 |
Optional |
Could be any of the valid currencies maintained in Currency Maintenance. If this information is not given in the import file, then the Default Account Statement Currency mentioned in the Bulk Client Defaults Maintenance for the bulk client will be used. |
EMAILID |
String |
255 |
Optional |
FIRSTJOINTUHNAME |
String |
60 |
Optional |
The primary unit holder name in case of joint accounts. |
SECONDJOINTUHNAME |
String |
60 |
Optional |
The secondary unit holder name in case of joint accounts. |
THIRDJOINTUHNAME |
String |
60 |
Optional |
The third unit holder name in case of joint accounts. |
ALTADDRESSFROMDATE |
DATE |
Optional |
Alternate Address From date |
ALTADDRESSTODATE |
DATE |
Optional |
Alternate Address To date |
TELEPHONERED |
Number |
1 |
Optional |
Could be either 0 (false) or 1 (true) to indicate whether redemption transactions can be accepted through telephone for the unit holder or not. If null, it will be picked up from the bulk client defaults table. |
TELEPHONESWI |
Number |
1 |
Optional |
WRITECHECKFORMMF |
Number |
1 |
Optional |
Could be either 0 (False) or 1 (True). If not supplied, will be taken from the bulk client defaults table. |
FEDWIREACHPAYMENT |
Number |
1 |
Optional |
IRSNOTIFICATION |
String |
10 |
Optional |
ROAINVESTOR |
Number |
1 |
Optional |
Could be either 0 (False) or 1 (True). This should be read only when 'ROA Option at Investor’ in AMC policies table is true. |
ALLOWROAATCIFLEVEL |
Number |
1 |
Optional |
Could be either 0 (False) or 1 (True). If an investor is an ROA investor, then this option will be set based on the value of the 'Allow ROA LOI at CIF level' in the AMC policies table |
UHACCOUNTTYPE |
String |
2 |
Optional |
Should be a valid unit holder account type as available in the Params maintenance |
RPOCODE |
String |
10 |
Optional |
Should be a valid code as maintained in the Params table for the Param code RPOESCHCODE. If not supplied, will be picked up from the bulk client defaults table. |
REGISTRATIONTYPE |
String |
2 |
Optional |
Should be a valid code as maintained in the Params table for the Param code UHREGISTRATIONTYPE. If not supplied, will be taken from the bulk client defaults table. |
REGISTRATIONNAME |
String |
50 |
Optional |
If registration type = 'SN' (Street name), only then this value is to be read. |
ACCOUNTOPENINGPURPOSE |
String |
30 |
Optional |
Account Opening Purpose |
REMARKS |
String |
255 |
Optional |
Remarks |
PREFERREDMAILMODE |
String |
2 |
Optional |
Should be a valid code as read from the Params table for the Param code PREFERREDMAILMODE. If not supplied, will be taken from the bulk client defaults table. |
NOTEPADAVAILABLE |
Number |
1 |
Optional |
Could be either 0 (False) or 1 (True). If not supplied, default will be 1 (True) |
FEECATEGORY |
String |
3 |
Optional |
Should be a valid category for the type of investor (individual or corporate). If not supplied, will be taken from the bulk client defaults table based on the investor category |
FEESUBCATEGORY |
String |
6 |
Optional |
Should be a valid sub category for the category. If not supplied will be taken from the bulk client defaults table based on the investor category |
AGENTCODE |
Number |
12 |
Mandatory |
Agent Code |
BRANCHCODE |
Number |
12 |
Mandatory |
Branch |
MAKERID |
String |
15 |
Optional |
There should not be any validation on Maker ID field with regards to the user profile maintenance in FCIS if it is supplied with the import file. If it is not supplied, default it to the logged in user id |
MAKER_DT_STAMP
DATE |
If the date is not specified in the import file, the application date is considered to be the Maker Date by default. |
CHECKERID |
String |
15 |
Optional |
this information is specified in the import file, no validation is made with regards to the user profile maintenance in the FCIS system. If it is not specified, it is defaulted to ‘SYSTEM’. This information is applicable for authorized unit holder generation. |
CHECKER_DT_STAMP |
DATE |
Optional |
If the date is not specified in the import file, the application date is considered to be the Checker Date by default. This information is applicable for authorized unit holder generation. |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
Auth Status |
AUTHTYPE |
String |
1 |
Mandatory |
Could be either of the following values: "U" - Unauthorized, "A" - Authorized |
STOPACCOUNTREASON |
String |
255 |
Optional |
Must be left blank |
RELEASEDATE |
DATE |
Optional |
ALLSIGNATORIESREQDTOSIGN |
Number |
1 |
Optional |
TAXEXEMPTED |
Number |
1 |
Optional |
Either 0 or 1 to indicate if tax is exempted for this Unit holder |
INDEXATIONONCGT |
String |
1 |
Optional |
CERTDELIVERYPREF |
String |
1 |
Optional |
Could be any of the values from the following list to indicate the preferred certificate delivery option: 'A','C','F','P','R' |
TEMPLATEID |
String |
6 |
Template ID |
EFFECTIVEDATE |
DATE |
Optional |
Effective Date |
CELLPHONENUMBER |
String |
16 |
Optional |
Cell Phone Number |
PRIMARYCOUNTRYCODE |
String |
3 |
Optional |
Primary Country Code |
ALTCELLPHONENUMBER |
String |
16 |
Optional |
Alternate Cell phone Number |
ALTHOMEPHONENUMBER |
String |
15 |
Optional |
Alternate Home phone Number |
ALTOFFICEPHONENUMBER |
String |
15 |
Optional |
Alternate Office phone Number |
ALTEMAILID |
String |
60 |
Optional |
Alternate Email ID |
SECONDARYCOUNTRYCODE |
String |
3 |
Optional |
Secondary Country Code |
PLACEOFISSUE |
String |
3 |
Optional |
Place of Issue |
ALTCONTACTNAME |
String |
70 |
Optional |
Alternate Contact Name |
ALTFAXNUMBER |
String |
15 |
Optional |
Alternate Fax Number |
PREFERREDFUNDFORREDEMPTION |
String |
6 |
Optional |
Should be a valid fund Id which would be used for redeeming the trailer commission to pay the intermediary |
GUARDIANPANGIRNO |
String |
15 |
Optional |
If the unit holder is a minor then the PAN (tax id) details of the Guardian |
GUARDIANFORM6061 |
Number |
1 |
Optional |
PRIMARYUHFORM6061 |
Number |
1 |
Optional |
UNITHOLDERNRI |
Number |
1 |
Optional |
Indicate if the Unit holder is a Non resident |
EUSDOPTION |
String |
1 |
Optional |
Applicable only for EUSD Countries Value defaulted from defaults maintenance in the absence of information in the file |
W – Withholding Tax |
TAXCERTIFICATEEXPDATE |
Date |
Optional |
If the EUSD Option is ‘T’ then tax certificate expiry date is mandatory |
Tax certificate expiry date |
PLACEOFBIRTH |
String |
80 |
Optional |
Unit Holder’s Place of birth |
COUNTRYOFBIRTH |
String |
3 |
Optional |
Unit Holder’s Country of birth. It should be the country code of the country |
FATFORNONFATF |
String |
1 |
Optional |
F – FATF Country |
CHASINGDATE |
Date |
Optional |
In case the KYC list is incomplete for a unit holder and the document has been requested, the date on which the document chasing action must be initiated. |
ADDNCOMMENTS |
String |
255 |
Optional |
Any additional narrative, or descriptive text, if any, concerning the document and the chasing date |
ALLKYCRECIEVED |
Number |
1 |
Optional |
Can have a value of 0 or
1. |
RETAINTRADEACK |
Number |
1 |
Optional |
0 or 1 (1 to indicate that trade acknowledgements for the unitholder has to be retained. |
RETAINCONTRACTNOTES |
Number |
1 |
Optional |
0 or 1 |
NOTREPORTKYCREQ |
Number |
1 |
Optional |
0 or 1 (Value 1 to indicate that any KYC documents yet to be submitted must not be reported in trade acknowledgements |
UHBICCODE |
String |
6 |
Optional |
Unit holder’s swift BIC Code |
ALTLANGFIRSTNAME |
String |
100 |
Optional |
Should not exist in the absence of First Name |
First Name specified in alternate language. |
ALTLANGMIDDLENAME |
String |
40 |
Optional |
Should not exist in the absence of Middle Name |
Middle Name specified in alternate language |
ALTLANGLASTNAME |
VARCHAR2 |
40 |
Optional |
Alternate Language LastName |
ALTLANGFIRSTAUTHSIGN |
String |
70 |
Optional |
Should not exist in the absence of First authorized signatory |
First authorized signatory specified in alternate language |
ALTLANGSECONDAUTHSIGN |
String |
70 |
Optional |
Should not exist in the absence of Second authorized signatory |
Second authorized signatory specified in alternate language |
ALTLANGTHIRDAUTHSIGN |
String |
70 |
Optional |
Should not exist in the absence of Third authorized signatory |
Third authorized signatory specified in alternate language |
ALTLANGCONTACTPERSON |
String |
70 |
Optional |
Should not exist in the absence of Contact person |
Contact person specified in alternate language |
ALTLANGCORADDRESSLINE1 |
String |
80 |
Optional |
Should not exist in the absence of Correspondence address line 1 |
Correspondence address line 1 specified in alternate language |
ALTLANGCORADDRESSLINE2 |
String |
80 |
Optional |
Should not exist in the absence of Correspondence address line 2 |
Correspondence address line 2 specified in alternate language |
ALTLANGCORADDRESSLINE3 |
String |
80 |
Optional |
Should not exist in the absence of Correspondence address line 3 |
Correspondence address line 3 specified in alternate language |
ALTLANGCORADDRESSLINE4 |
String |
80 |
Optional |
Should not exist in the absence of Correspondence address line 4 |
Correspondence address line 4 specified in alternate language |
ALTLANGALTADDRESSLINE1 |
String |
80 |
Optional |
Should not exist in the absence of address line1 |
ALTLANGALTADDRESSLINE2 |
String |
80 |
Optional |
Should not exist in the absence of address line2 |
ALTLANGALTADDRESSLINE3 |
String |
80 |
Optional |
Should not exist in the absence of address line 3 |
ALTLANGALTADDRESSLINE4 |
String |
80 |
Optional |
Should not exist in the absence of address line 4 |
DATEOFCONTRIBUTION |
Date |
Optional |
Date Member became Contributory |
TRANSFERDATE |
Date |
Optional |
Date Member details were transferred |
RETIREMENTAGE |
Number |
5,2 |
Optional |
Employee Retirement Age |
RETIREMENTDATE |
Date |
Optional |
Employee Retirement Date |
DATEOFDEATH |
Date |
Optional |
Date of Death |
DEATHCAUSE |
String |
Optional |
Cause of Death |
DISPATCHDATE |
Date |
Optional |
Dispatch Date |
RETURNEDDATE |
Date |
Optional |
Returned Date |
PRIMARYUHMFIN |
VARCHAR2 |
15 |
Optional |
Applicable only if unitholder is major |
Primary MFIN of the Primary Unitholder |
GUARDIANMFIN |
VARCHAR2 |
15 |
Optional |
Applicable only if unitholder is minor |
Mutual fund identification number of the Guardian |
RECOVERCGT |
NUMBER |
1 |
Optional |
For Calculating Capital Gain Tax |
CAMPAIGNCODE |
String |
6 |
Optional |
Used to capture the CAMPAIGNCODE |
PROCESSID1 |
VARCHAR2 |
60 |
Optional |
Process ID |
INITIALS |
VARCHAR2 |
30 |
Optional |
Initials |
KYCPURCHASELIMIT |
NUMBER |
30 |
Optional |
KYC Purchase Limit |
KYCANNUALDEBITORDERLIMIT |
NUMBER |
30 |
Optional |
KYC Annual Debit Order Limit |
CAMPAIGNCODE |
VARCHAR2 |
6 |
Optional |
Campaign Code |
REDEMPTIONPAYOUT |
VARCHAR2 |
1 |
Optional |
Redemption Payout |
DIVIDENDPAYOUT |
VARCHAR2 |
1 |
Optional |
Dividend Payout |
PRIMARYINDITELCODE1 |
VARCHAR2 |
10 |
Optional |
Int. Dialing Code 1 |
PRIMARYINDITELCODE2 |
VARCHAR2 |
10 |
Optional |
Int. Dialing Code 2 |
PRIMARYINDIPHONECODE |
VARCHAR2 |
10 |
Optional |
Primary Phone Code |
PRIMARYINDIFAXCODE |
VARCHAR2 |
10 |
Optional |
Primary Fax code |
SECONDARYINDITELCODE1 |
VARCHAR2 |
10 |
Optional |
SECONDARYINDITELCODE2 |
VARCHAR2 |
10 |
Optional |
SECONDARYINDIFAXCODE |
VARCHAR2 |
10 |
Optional |
Secondary Phone Code |
DUALNATIONALITY |
VARCHAR2 |
3 |
Optional |
Dual Nationality |
SUBSTANTIALSTAYINUS |
NUMBER |
1 |
Optional |
Substantial Stay in US |
TAXCERTIFICATEEFFEDATE |
DATE |
10 |
Optional |
Tax Effective Certificate Date |
COUNTRYOFINCORPORATION |
VARCHAR2 |
3 |
Optional |
Country Of Incorporation |
SECONDIDENTITYTYPE |
VARCHAR2 |
12 |
Optional |
SECONDIDENTITYNUMBER |
VARCHAR2 |
50 |
Optional |
SECONDISSUEDATE |
DATE |
10 |
Optional |
Second Issue Date |
SECONDEXPIRYDATE |
DATE |
10 |
Optional |
Second Expiry Date |
SECONDPLACEOFISSUE |
DATE |
10 |
Optional |
Second Place Issue |
DUEDILIGENCELEVEL |
VARCHAR2 |
2 |
Optional |
Due Diligence Level |
REVIEWEDBY |
VARCHAR2 |
255 |
Optional |
Reviewed By |
LASTREVIEWEDDATE |
DATE |
10 |
Optional |
Last Reviewed date |
CHASERID |
VARCHAR2 |
255 |
Optional |
Chaser ID |
CHASINGMODE |
VARCHAR2 |
2 |
Optional |
Chasing Mode |
NAMESCHECKOPTION |
VARCHAR2 |
2 |
Optional |
Names Check Option |
NAMESCHECKREMARKS |
VARCHAR2 |
255 |
Optional |
Names Check Remarks |
ACCOUNTSTATEMENT |
VARCHAR2 |
1 |
Optional |
Account Statement |
CONTRACTNOTES |
VARCHAR2 |
1 |
Optional |
Contract notes |
INVESTORRISKLEVEL |
VARCHAR2 |
1 |
Optional |
Investor risk level |
HEALTHSTATUS |
VARCHAR2 |
1 |
Optional |
Health status |
Serial Number: 2
Segment Identification Number: 01KYC
Description: This segment is used for providing KYC related Information
Data type |
Length |
Mandatory/Optional |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id. Value of Segment Id is 01KYC |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Upload Mode |
UHKYCSLNO |
NUMBER |
10 |
Mandatory |
Represents a serial number. |
UNITHOLDERID |
VARCHAR2 |
12 |
Mandatory |
Unitholder ID |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
Authorization Status |
REQUESTED |
VARCHAR2 |
1 |
Optional |
For Standard Doc’s this flag should be ‘1’ |
Flag which specifies whether the document is requested or not. |
DOCUMENTDESCRIPTION |
VARCHAR2 |
255 |
Optional |
Represents the description of document produced for the KYC form. |
FAXRECEIVED |
VARCHAR2 |
1 |
Optional |
Represents the Fax received is a check box field Y - Yes ,N-No |
ORIGINALRECEIVED |
VARCHAR2 |
1 |
Optional |
Represents the Original received is a check box field Y - Yes ,Nno |
RECEIVEDDATE |
DATE |
7 |
Optional |
Represents the Received date |
USERCOMMENT |
VARCHAR2 |
255 |
Optional |
Represents the User comment |
WORKFLOWREFNO |
VARCHAR2 |
20 |
Optional |
Represents the Work flow reference no |
DOCUMENTTYPE |
VARCHAR2 |
1 |
Optional |
Represents the Document type |
Serial Number: 3
Segment Identification Number: 02BEN
Description: This segment is used for providing Beneficiary related Information.
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id. Value of Segment Id is 02BEN |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BENEFICIARYID |
VARCHAR2 |
12 |
Mandatory |
Represents the unique identification code for the beneficary of unitholder. |
BENEFICIARYTYPE |
VARCHAR2 |
2 |
Mandatory |
Indicates the type of beneficary. |
BENEFICIARYNAME |
VARCHAR2 |
105 |
Mandatory |
Indicates the descriptive name for the beneficiary. |
BENEFICIARYDOB |
DATE |
7 |
Optional |
Represents the Date of Birth for the beneficiary. |
BENEFICIARYRELATION |
VARCHAR2 |
70 |
Optional |
Represents the relation of beneficary to the mentioned unitholder. |
BENEFICIARYUIN |
VARCHAR2 |
15 |
Optional |
US Indicia Available |
BENEFICIARYGROUP |
VARCHAR2 |
1 |
Optional |
Represents the group for the beneficiary. |
BENEFICIARYGENDER |
VARCHAR2 |
1 |
Optional |
Indicates the gender of beneficiary. |
BENEFICIARYIDTYPE |
VARCHAR2 |
3 |
Optional |
Indicates the identification type of beneficiary. |
BENEFICIARYIDNUMBER |
VARCHAR2 |
50 |
Optional |
Indicates the unique identification number for the beneficiary |
BENEFICIARYAWARD |
NUMBER |
5 |
Optional |
Indicates the award percentage applicable for the beneficiary |
BENEFICIARYBANKCODE |
VARCHAR2 |
12 |
Mandatory |
Represents the bank identification code for the beneficiary. |
BENEFICIARYBRANCHCODE |
VARCHAR2 |
12 |
Mandatory |
Represents the branch identificaiton code for the beneficiary. |
BENEFICIARYACCTYPE |
VARCHAR2 |
1 |
Optional |
Represents the beneficiary's account type. |
BENEFICIARYACCNAME |
VARCHAR2 |
105 |
Optional |
Represents the beneficiary's account name. |
BENEFICIARYACCCCY |
VARCHAR2 |
3 |
Optional |
Represents the account currency of the beneficiary's bank account. |
ACCOUNTNUMBER |
VARCHAR2 |
20 |
Mandatory |
Indicates the account number of the beneficary |
COUNTRYOFDOMICILE |
VARCHAR2 |
3 |
Optional |
Country Of Domicile |
IBAN |
VARCHAR2 |
40 |
Optional |
Indicates the International Bank Account Number. |
FATCASTATUS |
VARCHAR2 |
25 |
Optional |
FATCA Status |
ADDRESSLINE1 |
VARCHAR2 |
105 |
Mandatory |
Represents the first line of beneficary's address. |
ADDRESSLINE2 |
VARCHAR2 |
105 |
Mandatory |
Represents the second line of beneficary's address. |
ADDRESSLINE3 |
VARCHAR2 |
105 |
Optional |
Represents the third line of beneficary's address. |
ADDRESSLINE4 |
VARCHAR2 |
80 |
Optional |
Represents the fourth line of beneficary's address. |
ZIPCODE |
VARCHAR2 |
10 |
Mandatory |
Indicates the locational ZIP code for the beneficary's address |
COUNTRY |
VARCHAR2 |
3 |
Mandatory |
Indicates the country of beneficiary |
TELEPHONE1 |
VARCHAR2 |
60 |
Optional |
Telephone Number 1 |
VARCHAR2 |
255 |
Optional |
Email ID |
CONTACTPERSON |
VARCHAR2 |
160 |
Optional |
Indicates the name of beneficiary's contact person. |
EXISTINGUHORCIF |
VARCHAR2 |
1 |
Mandatory |
Indicates whether its existing UH or CIF |
Serial Number: 4
Segment Identification Number: 03BNK
Description: This segment is used for providing UnitHolder Bank related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment Id. Value of Segment Id is 03BNK |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Process ID |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Sequence Number |
BANKCODE |
VARCHAR2 |
12 |
Mandatory |
Represents the Entity bank code. |
BRANCHCODE |
VARCHAR2 |
12 |
Mandatory |
Represents the Entity branch code. |
ACCOUNTTYPE |
VARCHAR2 |
1 |
Mandatory |
Represents Type of the Account. |
ACCOUNTNUMBER |
VARCHAR2 |
20 |
Mandatory |
Represents Entity account number. |
ACCOUNTNAME |
VARCHAR2 |
100 |
Mandatory |
Represents Entity account name. |
ACCOUNTCURRENCY |
VARCHAR2 |
3 |
Mandatory |
Represents Entity account currency. |
DEFAULTDETAILS |
NUMBER |
1 |
Mandatory |
Indicatest the default details |
DIRECTDEBITAPPLICABLE |
NUMBER |
1 |
Optional |
Indicates whether direct debit is applicable for the entity. If Yes (1) else (0). |
ACCOUNTCATEGORY |
VARCHAR2 |
1 |
Optional |
Indicates the account category for the unitholder. |
INITIALS |
VARCHAR2 |
10 |
Optional |
Indicates the initials for the unitholder entity. |
LASTNAME |
VARCHAR2 |
40 |
Optional |
Indicates the last name for the unitholder entity. |
VARCHAR2 |
3 |
Optional |
Indicates the type of identification used for the unitholder. |
VARCHAR2 |
50 |
Mandatory |
Indicates the identification number used for the unitholder. |
STATUS |
VARCHAR2 |
1 |
Optional |
Indicates the Transaction status |
IBAN |
VARCHAR2 |
40 |
Optional |
UNITHOLDERID |
VARCHAR2 |
12 |
Mandatory |
Unitholder ID |
REFERENCENUMBER |
VARCHAR2 |
12 |
Optional |
Indicates a unique reference Number for a Transaction. It can be entered by the user, otherwise it is system generated. |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Represents a unique Identification for each Fund in the system. It consist of maximum of 6 alphanumeric character.Its Foreign key is FUNDID column Of FUNDDEMOGRAPHICSTBL Table. |
TRANSACTIONTYPE |
VARCHAR2 |
3 |
Mandatory |
Indicates the Transaction Type for which Transaction Rules will be specified. |
UHBICCODE |
VARCHAR2 |
24 |
Optional |
UnitHolder BIC Code |
SWIFTFORMAT |
VARCHAR2 |
6 |
Optional |
Specifies Swift Format used for the entity |
BANKCHARGED |
VARCHAR2 |
12 |
Optional |
Indicates bank charged |
BENEFICIARY |
VARCHAR2 |
35 |
Optional |
Specifies Beneficiary name of the entity. |
BENEFICIARYADD1 |
VARCHAR2 |
105 |
Optional |
Specifies Entity's Beneficiary address line1. |
BENEFICIARYADD2 |
VARCHAR2 |
105 |
Optional |
Specifies Entity's Beneficiary address line2. |
BENEFICIARYADD3 |
VARCHAR2 |
105 |
Optional |
Specifies Entity's Beneficiary address line3. |
BENEFICIARYBICCODE |
VARCHAR2 |
24 |
Optional |
Specifies BIC Code of the Beneficiary. |
BENEFICIARYACCTNO |
VARCHAR2 |
34 |
Optional |
Specifies Beneficiary's Account Number. |
BENEFICIARYCODE |
VARCHAR2 |
24 |
Optional |
Specifies Unique code of the beneficiary. |
BENEFICIARYINFO |
VARCHAR2 |
100 |
Optional |
Specifies Additional information about the beneficiary. |
INTERMEDIARY |
VARCHAR2 |
35 |
Optional |
Specifies Intermediary name of the entity. |
INTERMEDIARYADD1 |
VARCHAR2 |
105 |
Optional |
Specifies Entity's Intermediary address line1. |
INTERMEDIARYADD2 |
VARCHAR2 |
105 |
Optional |
Specifies Entity's Intermediary address line2. |
INTERMEDIARYADD3 |
VARCHAR2 |
105 |
Optional |
Specifies Entity's Intermediary address line3. |
INTERMEDIARYBICCODE |
VARCHAR2 |
24 |
Optional |
Specifies BIC Code of the Intermediary. |
INTERMEDIARYACCTNO |
VARCHAR2 |
34 |
Optional |
Specifies Intermediary's Account number |
INTERMEDIARYCODE |
VARCHAR2 |
24 |
Optional |
Specifies Unique code of the intermediary. |
INTERMEDIARYINFO |
VARCHAR2 |
100 |
Optional |
Specifies Additional information about the intermediary. |
FURTHERCREDITNAME |
VARCHAR2 |
35 |
Optional |
Specifies further credit name |
FURTHERCREDITACCTNO |
VARCHAR2 |
35 |
Optional |
Specifies Account number to which further credits must be carried out. |
REFERENCE1 |
VARCHAR2 |
35 |
Optional |
Specifies Reference 1 for the Entity. |
REFERENCE2 |
VARCHAR2 |
35 |
Optional |
Specifies Reference 2 for the Entity. |
RELATIONSHIP |
VARCHAR2 |
40 |
Optional |
Indicates the relationship between the beneficiary and the customer. |
BENEFICIARYIBAN |
VARCHAR2 |
40 |
Optional |
Specifies Beneficiary's International Bank Account Number. |
INTERMEDIARYIBAN |
VARCHAR2 |
40 |
Optional |
Specifies Intermediary's International Bank Account Number. |
Serial Number: 5
Segment Identification Number: 04INM
Description: This segment is used for providing UnitHolder Intermediary related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment Id. Value of Segment Id is 04INM |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Process ID |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Sequence Number |
ENTITYTYPE |
VARCHAR2 |
1 |
Mandatory |
Indicates the type of entity who acts as an intermediary for the unitholder. Along with UNITHOLDERID, forms the primary key of the table. |
ENTITYID |
VARCHAR2 |
12 |
Mandatory |
Represents the unique identification code for the entity who acts as the intermediary for the unitholder. Along with UNITHOLDERID, forms the primary key of the table. |
SPLITPERCENT |
NUMBER |
5 |
Mandatory |
Indicates the commission percentage entitled for the respective unitholder's intermediary. |
DEFAULTINTERMEDIARY |
NUMBER |
1 |
Mandatory |
Default intermediary |
Serial Number: 6
Segment Identification Number: 05DEL
Description: This segment is used for providing UnitHolder Delivery related Information
Segment Mandatory / Optional: Optional
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment Id. Value of Segment Id is 05DEL |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Sequence Number |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Process ID |
ENTITYID |
VARCHAR2 |
12 |
Mandatory |
Represents the Entityid |
ACCOUNTTYPE |
VARCHAR2 |
1 |
Mandatory |
Represents the Accounttype |
ACCOUNTNUMBER |
VARCHAR2 |
20 |
Mandatory |
Represents the Accountnumber |
ACCOUNTNAME |
VARCHAR2 |
105 |
Mandatory |
Represents the Accountname |
DEFAULTDETAILS |
NUMBER |
1 |
Mandatory |
Represents the Defaultdetails |
Serial Number: 7
Segment Identification Number: 06REL
Description: This segment is used for providing UnitHolder Related Parties related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment Id. Value of Segment Id is 06REL |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Sequence Number |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Process ID |
ENTITYID |
VARCHAR2 |
12 |
Mandatory |
Indicates the unique identification code for the related party entity associated with the unitholder. |
ENTITYTYPE |
VARCHAR2 |
2 |
Mandatory |
Indicates the entity type of the unitholder's related party. |
RELATIONSHIP |
VARCHAR2 |
10 |
Optional |
Indicates the relationship between the related party entity and the unitholder. |
REPORTINGLEVEL |
VARCHAR2 |
1 |
Optional |
Indicates the reporting level of the related party entity to the unitholder. |
PREFMAILMODE |
VARCHAR2 |
1 |
Optional |
Indicates the preferred mail mode for the related party entity. |
REMARKS |
VARCHAR2 |
255 |
Optional |
Indicates the descriptive remarks column for the record. |
Serial Number: 8
Segment Identification Number: 07JNT
Description: This segment is used for providing UnitHolder JointHolder related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment Id. Value of Segment Id is 07JNT |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Process ID |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Sequence Number |
BENEFICIARYID |
VARCHAR2 |
12 |
Optional |
Indicates the joint holder Id. |
BENEFICIARYNAME |
VARCHAR2 |
100 |
Optional |
Indicates the descriptive name for the joint holder. |
BENEFICIARYTYPE |
VARCHAR2 |
2 |
Mandatory |
Indicates the type of joint holder. |
BENEFICIARYDOB |
DATE |
10 |
Mandatory |
Represents the Date of Birth for the joint holder. |
BENEFICIARYGENDER |
VARCHAR2 |
1 |
Mandatory |
Indicates the gender of joint holder |
BENEFICIARYPANNO |
VARCHAR2 |
15 |
Optional |
Indicates the Permanent Account Number of the joint holder. |
BENEFICIARYFORM60 |
NUMBER |
1 |
Optional |
Indicates whether the Form 60 is needed in case the joint holder doesn't have a valid PAN number. |
BENEFICIARYMFIN |
VARCHAR2 |
15 |
Optional |
Indicates the MFIN information for the joint holder. |
COUNTRYOFDOMICILE |
VARCHAR2 |
3 |
Optional |
Indicates the country of domicile of joint holder. |
RECOVERCGT |
NUMBER |
1 |
Optional |
Indicates whether the capital gain tax is to be deducted from the transaction or not. |
ADDRESSLINE1 |
VARCHAR2 |
105 |
Mandatory |
Represents the first line of joint holder's address. |
ADDRESSLINE2 |
VARCHAR2 |
105
Mandatory |
Represents the second line of joint holder's address. |
ADDRESSLINE3 |
VARCHAR2 |
105 |
Optional |
Represents the third line of joint holder's address. |
ADDRESSLINE4 |
VARCHAR2 |
80 |
Optional |
Represents the fourth line of joint holder's address. |
ZIPCODE |
VARCHAR2 |
10 |
Mandatory |
Indicates the locational ZIP code for the joint holder's address |
COUNTRY |
VARCHAR2 |
3 |
Mandatory |
Indicates the country of joint holder |
VARCHAR2 |
255 |
Optional |
Indicates the email address of joint holder. |
CONTACTPERSON |
VARCHAR2 |
160 |
Optional |
Indicates the name of joint holder's contact person. |
EXISTINGUHORCIF |
VARCHAR2 |
1 |
Mandatory |
Serial Number: 9
Segment Identification Number: 08NME
Description: This segment is used for providing Nominee related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment Id. Value of Segment Id is 08NME |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BENEFICIARYID |
VARCHAR2 |
12 |
Mandatory |
Represents the unique identification code for the nominee of unitholder. |
BENEFICIARYNAME |
VARCHAR2 |
100 |
Mandatory |
Indicates the type of nominee. |
BENEFICIARYTYPE |
VARCHAR2 |
2 |
Mandatory |
Indicates the descriptive name for the nominee. |
BENEFICIARYDOB |
DATE |
10 |
Mandatory |
Represents the Date of Birth for the nominee. |
BENEFICIARYGENDER |
VARCHAR2 |
1 |
Optional |
Indicates the gender of nominee. |
BENEFICIARYIDTYPE |
VARCHAR2 |
3 |
Optional |
Indicates the identification type of nominee. |
VARCHAR2 |
50 |
Optional |
Indicates the unique identification number for the nominee |
BENEFICIARYPANNO |
VARCHAR2 |
15 |
Optional |
Indicates the Permanent Account Number of the nominee. |
BENEFICIARYFORM60 |
NUMBER |
1 |
Optional |
Indicates whether the Form 60 is needed in case the nominee doesn't have a valid PAN number. |
VARCHAR2 |
70 |
Optional |
Represents the relation of nominee to the mentioned unitholder. |
BENEFICIARYAWARD |
NUMBER |
5 |
Optional |
Indicates the award percentage applicable for the nominee |
ADDRESSLINE1 |
VARCHAR2 |
105
Mandatory |
Represents the first line of nominee's address. |
ADDRESSLINE2 |
VARCHAR2 |
105
Mandatory |
Represents the second line of nominee's address. |
ADDRESSLINE3 |
VARCHAR2 |
105
Optional |
Represents the third line of nominee's address. |
ADDRESSLINE4 |
VARCHAR2 |
80 |
Optional |
Represents the fourth line of nominee's address. |
ZIPCODE |
VARCHAR2 |
10 |
Mandatory |
Indicates the locational ZIP code for the nominee's address |
COUNTRY |
VARCHAR2 |
3 |
Mandatory |
Indicates the country of nominee |
VARCHAR2 |
255 |
Optional |
Indicates the email address of nominee. |
CONTACTPERSON |
VARCHAR2 |
160 |
Optional |
Indicates the name of nominee's contact person. |
VARCHAR2 |
12 |
Mandatory |
Represents the bank identification code for the nominee. |
VARCHAR2 |
12 |
Mandatory |
Represents the branch identificaiton code for the nominee. |
VARCHAR2 |
1 |
Optional |
Represents the nominee's account type. |
BENEFICIARYACCCCY |
VARCHAR2 |
3 |
Optional |
Represents the nominee's account name. |
ACCOUNTNUMBER |
VARCHAR2 |
20 |
Mandatory |
Represents the account currency of the nominee's bank account. |
VARCHAR2 |
100 |
Optional |
Indicates the account number of the nominee |
IBAN |
VARCHAR2 |
40 |
Optional |
COUNTRYOFDOMICILE |
VARCHAR2 |
25 |
Optional |
Indicates the country of domicile of nominee. |
EXISTINGUHORCIF |
VARCHAR2 |
1 |
Mandatory |
Serial Number: 10
Segment Identification Number: 09DIR
Description: This segment is used for providing Director related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment Id. Value of Segment Id is 09DIR |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
EXISTINGUHORCIF |
VARCHAR2 |
1 |
Optional |
BENEFICIARYNAME |
VARCHAR2 |
100 |
Optional |
Indicates the descriptive name for the Director. |
BENEFICIARYID |
VARCHAR2 |
12 |
Mandatory |
Represents the unique identification code for the Director of unitholder. |
BENEFICIARYDOB |
DATE |
10 |
Mandatory |
Represents the Date of Birth for the Director. |
BENEFICIARYGENDER |
VARCHAR2 |
1 |
Mandatory |
Indicates the gender of Director. |
BENEFICIARYIDTYPE |
VARCHAR2 |
3 |
Optional |
Indicates the identification type of Director. |
VARCHAR2 |
50 |
Mandatory |
Indicates the unique identification number for the Director |
COUNTRYOFDOMICILE |
VARCHAR2 |
3 |
Optional |
Indicates the country of domicile of Director. |
ADDRESSLINE1 |
VARCHAR2 |
105
Mandatory |
Represents the first line of Director's address. |
ADDRESSLINE2 |
VARCHAR2 |
105
Mandatory |
Represents the second line of Director's address. |
ADDRESSLINE3 |
VARCHAR2 |
105
Optional |
Represents the third line of Director's address. |
ADDRESSLINE4 |
VARCHAR2 |
80 |
Optional |
Represents the fourth line of Director's address. |
COUNTRY |
VARCHAR2 |
3 |
Optional |
Indicates the country of Director |
ZIPCODE |
VARCHAR2 |
10 |
Mandatory |
Indicates the locational ZIP code for the Director's address |
VARCHAR2 |
255 |
Optional |
Indicates the email address of Director. |
CONTACTPERSON |
VARCHAR2 |
160 |
Optional |
Indicates the name of Director's contact person. |
VARCHAR2 |
12 |
Optional |
Represents the bank identification code for the Director. |
VARCHAR2 |
12 |
Optional |
Represents the branch identificaiton code for the Director. |
VARCHAR2 |
1 |
Optional |
Represents the Director's account type. |
BENEFICIARYACCCCY |
VARCHAR2 |
3 |
Optional |
Represents the account currency of the Director's bank account. |
ACCOUNTNUMBER |
VARCHAR2 |
20 |
Optional |
VARCHAR2 |
100 |
Optional |
Represents the Director's account name. |
IBAN |
VARCHAR2 |
40 |
Optional |
PERCENTHOLDINGS |
NUMBER |
5 |
Optional |
Indicate Percentage Holding |
DESIGNATION |
VARCHAR2 |
100 |
Optional |
Designation |
Serial Number: 11
Segment Identification Number: 10ADD
Description: This segment is used for providing Additional Information related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment Id. Value of Segment Id is 10ADD |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
200 |
Mandatory |
Process ID |
ADDINFOLABEL |
VARCHAR2 |
120 |
Mandatory |
Addinfo Label |
FIELDVALUE |
CHAR |
92 |
Mandatory |
Field Value |
Serial Number: 12
Segment Identification Number: 11KAP
Description: This segment is used for providing KYC Application form related Information.
Data type |
Length |
Mandatory |
Characteristics/ rules |
Values |
SEGMENTID |
VARCHAR2 |
20 |
YES |
Segment ID |
SEQUENCENUMBER |
NUMBER |
22 |
YES |
Sequence number |
PROCESSID |
VARCHAR2 |
50 |
YES |
Process ID |
UNITHOLDERID |
VARCHAR2 |
12 |
YES |
Unitholder ID |
APPLICABLELEVEL |
VARCHAR2 |
1 |
NO |
Applicable level |
APPLICABLEENTITYID |
VARCHAR2 |
12 |
NO |
Applicable Entity |
COPYRECEIVED |
VARCHAR2 |
1 |
NO |
Copy received |
ORIGINALRECEIVED |
VARCHAR2 |
1 |
NO |
Original received |
Serial Number: 13
Segment Identification Number: 12STP
Description: This segment is used for providing Stop Code Restrictions related Information.
Data type |
Length |
Mandatory |
Values |
SEGMENTID |
VARCHAR2 |
20 |
YES |
Segment Id. Value of Segment Id is 12STP |
SEQUENCENUMBER |
NUMBER |
10 |
YES |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
YES |
Process ID |
UNITHOLDERID |
VARCHAR2 |
12 |
YES |
Unitholder ID |
STOPCODE |
VARCHAR2 |
25 |
YES |
Stop Code |
STOPACCOUNTCODE |
VARCHAR2 |
20 |
YES |
Stop Account Code |
REASON |
VARCHAR2 |
255 |
NO |
Stop Account Reason |
EFFECTIVEDATE |
DATE |
YES |
Stop Account Effective Date |
RELEASEDATE |
DATE |
NO |
Stop Account Release Date |
Serial Number: 14
Segment Identification Number: 13COM
Description: This segment is used for providing Communication Mode Restrictions related Information.
Data type |
Length |
Mandatory |
Values |
SEGMENTID |
VARCHAR2 |
20 |
YES |
Segment Id. Value of Segment Id is 13COM |
SEQUENCENUMBER |
NUMBER |
10 |
YES |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
YES |
Process ID |
UNITHOLDERID |
VARCHAR2 |
12 |
YES |
Unitholder ID |
COMMUNICATIONMODE |
VARCHAR2 |
2 |
YES |
Communication Mode |
RESTRICTION |
VARCHAR2 |
1 |
YES |
Restriction Value |
Serial Number: 15
Segment Identification Number: 14KII
Description: This segment is used for providing KIID Details.
Data type |
Length |
Mandatory |
Values |
SEGMENTID |
VARCHAR2 |
80 |
YES |
Segment Id. Value of Segment Id is 14KII |
SEQUENCENUMBER |
NUMBER |
22 |
YES |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
YES |
Process ID |
UNITHOLDERID |
VARCHAR2 |
12 |
NO |
Unitholder ID |
FUNDID |
VARCHAR2 |
6 |
NO |
Fund ID |
EFFECTIVEDATE |
DATE |
7 |
NO |
Effective Date |
Serial Number: 16
Segment Identification Number: 15CON
Description: This segment is used for providing Unit Holder Contact information.
Data type |
Length |
Mandatory |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Yes |
Segment Id. Value of Segment Id is 15CON |
PROCESSID |
VARCHAR2 |
50 |
Yes |
Sequence Number |
SEQUENCENUMBER |
NUMBER |
10 |
Yes |
Process ID |
UNITHOLDERID |
VARCHAR2 |
12 |
Yes |
Unitholder ID |
REFERENCENUMBER |
VARCHAR2 |
12 |
Yes |
Reference Number |
ADDRESSTYPE |
VARCHAR2 |
2 |
Yes |
Address Type |
ADDRESSLINE1 |
VARCHAR2 |
105 |
No |
Address Line 1 |
ADDRESSLINE2 |
VARCHAR2 |
105 |
No |
Address Line 2 |
ADDRESSLINE3 |
VARCHAR2 |
105 |
No |
Address Line 3 |
ADDRESSLINE4 |
VARCHAR2 |
80 |
No |
Address Line 4 |
ZIPCODE |
VARCHAR2 |
10 |
No |
Zip Code |
COUNTRY |
VARCHAR2 |
3 |
No |
Country |
USSTATE |
NUMBER |
1 |
No |
Us State |
TELEPHONE1 |
VARCHAR2 |
105 |
No |
Telephone 1 |
TELEPHONE2 |
VARCHAR2 |
60 |
No |
Telephone 2 |
CELLPHONENUMBER |
VARCHAR2 |
60 |
No |
Cell Phone Number |
FAX |
VARCHAR2 |
120 |
No |
Fax Number |
VARCHAR2 |
255 |
No |
CONTACTPERSON |
VARCHAR2 |
160 |
No |
Contact Person |
EFFECTIVEFROMDATE |
DATE |
No |
Effective From Date |
EFFECTIVETODATE |
DATE |
No |
Effective To Date |
BICCODE |
VARCHAR2 |
16 |
No |
Biccode |
INTDIALLINGCODEPH1 |
VARCHAR2 |
10 |
No |
Phone Number 1 |
INTDIALLINGCODEPH2 |
VARCHAR2 |
10 |
No |
Phone Number 2 |
INTDIALLINGCODECELL |
VARCHAR2 |
10 |
No |
Phone Number 3 |
INTDIALLINGCODEFAX |
VARCHAR2 |
10 |
No |
Fax Number |
Note
For all imports of new and amended transactions data, the external hand-off file containing the information must:
Note
If you have disallowed upload of amended transactions for a particular client, by selecting the ‘No’ option in the Allow Amendment field, when you are setting up the default information for the bulk client, amended orders are not imported for the bulk client, but errors are logged in respect of them.
The upload file would contain various segment identification numbers in the first column to indicate the type of data that is present in that entire row. Each segment identified by a unique tag, indicates the type of transaction information such as Transaction, Settlement info and so on. The possible segments that would be used in Transaction upload are given below for reference:
Description |
00CON |
This segment is used for providing Transaction related Information |
Mandatory; and will be the driving header segment for all the other segments. |
01SET |
This segment is used for providing Transaction Settlement related Information |
Mandatory |
02KYC |
This segment is used for providing KYC Transaction related Information |
Optional |
03AIF |
This segment is used for providing Additional Information Details |
Optional |
04INT |
This segment is used for providing Transaction Intermediary related Information |
Optional |
05CER |
This segment is used for providing Certificate related Information |
Optional |
06REC |
This segment is used for providing Transaction Receipt related Information |
Optional |
07DEL |
This segment is used for providing Delivery related Information |
Optional |
08LMO |
This segment is used for providing Limit Order related Information |
Optional |
09LOD |
This segment is used for providing Transaction Load Override related Information |
Optional |
10DLO |
This segment is used for providing Derived Load Override related Information |
Optional |
11PSE |
This segment is used for providing Pseudo Switch related Information |
Optional |
12PSL |
This segment is used for providing Switch In Fund Load Override related Information |
Optional |
13PSD |
This segment is used for providing Switch In Fund Derived Load Override related Information |
Optional |
Serial Number: 1
Segment Identification Number: 00CON
Description: This segment is used for providing Transaction related Information.
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 00CON |
TXNSERIALNUMBER |
NUMBER |
10 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Transaction Serial Number |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Mode of Transaction upload |
TRANSACTIONNUMBER |
VARCHAR2 |
16 |
Mandatory |
Transaction Number |
REFERENCENUMBER |
VARCHAR2 |
16 |
Optional |
Reference Number |
TRANSACTIONDATE |
DATE |
7 |
Optional |
Transaction Date |
UNITHOLDERID |
VARCHAR2 |
60 |
Mandatory |
Unitholder Id |
REFUNITHOLDERID |
VARCHAR2 |
12 |
Optional |
Reference Unit Holder ID |
AGENTCODE |
VARCHAR2 |
12 |
Mandatory |
Agent Code |
BRANCHCODE |
VARCHAR2 |
12 |
Mandatory |
Branch Code |
FUNDID |
VARCHAR2 |
25 |
Mandatory |
Fund ID |
AMOUNT |
NUMBER |
15 |
Optional |
Amount |
PAYMENTMODE |
VARCHAR2 |
1 |
Optional |
Payment Mode.C-Cash, Q-Cheque, T-Transfer, R-Card, M-Multipayment, D-Draft. |
CHEQUENUMBER |
VARCHAR2 |
16 |
Optional |
Cheque Number |
CLEARINGDATE |
DATE |
7 |
Optional |
Clearing Date |
TRANSACTIONCURRENCY |
VARCHAR2 |
3 |
Optional |
Transaction Currency |
TRANSACTIONMODE |
VARCHAR2 |
1 |
Optional |
Transaction Mode.A-Amount, U-Units, P-Percentage |
UNITSAPPLIED |
NUMBER |
15 |
Optional |
Units |
PERCENTAPPLIED |
NUMBER |
5 |
Optional |
Percentage |
TOFUNDID |
VARCHAR2 |
25 |
Optional |
To Fund Id |
TOUNITHOLDERID |
VARCHAR2 |
60 |
Optional |
To Unitholder Id |
REFTOUNITHOLDERID |
VARCHAR2 |
12 |
Optional |
Reference To Unit Holder ID |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type. 01-IPO Subscription,02-Subscription,03-Redemption,04-Switch,05-Transfer |
REFTYPE |
VARCHAR2 |
2 |
Optional |
Ref Type. For example ,reftype - 56, transaction Type - 05 it will consider as "No Change of beneficiary ownership' Transfer transaction |
REMARKS |
VARCHAR2 |
255 |
Optional |
Remarks |
CIFNUMBER |
VARCHAR2 |
12 |
Optional |
CIF Number |
TOCIFNUMBER |
VARCHAR2 |
12 |
Optional |
To CIF Number |
GROSSORNET |
VARCHAR2 |
1 |
Optional |
Gross Or Net.G-Gross,N-Net |
SUBPAYMENTMODE |
VARCHAR2 |
2 |
Optional |
Sub Payment Mode.T-Money Transfer,Q-Cheque,R-Credit Card,D-Demand Draft,F-Against Payment,I-In Kind Payment,AT-Advice,BQ-Broker Cheque,CQ-Cashier cheque,DR-Debit Card,DT-Direct Debit,FQ-Foreign Cheque,GQ-Government Cheque,IQ-Other Institution Cheque,LQ-Local Cheque,OQ-Out Of Town Cheque,PD-Pay Order,PQ-Payroll Deduction,RQ-Reserve Bank Cheque,TT-Telegraphic Transfer,WT-Wire Transfer. |
COMMUNICATIONMODE |
VARCHAR2 |
2 |
Optional |
Communication Mode.CW-Check Writing,DI-Direct (In Person),EM-E-Mail,IN-Internet,RA-Registered Investment Advisor,RD-Registered Dealer,SP-Savings Plan,SW-SWIFT,TL-Telephone |
POLICYNUMBER |
VARCHAR2 |
16 |
Optional |
Policy Number |
PRODUCTID |
VARCHAR2 |
10 |
Optional |
Product Id |
LOIAPPLICABLE |
NUMBER |
1 |
Optional |
LOI Transaction.1-Yes,0-No |
REFFUNDID |
VARCHAR2 |
6 |
Optional |
Reference Fund ID |
REFTOFUNDID |
VARCHAR2 |
6 |
Optional |
Reference To Fund ID |
ENTITYTYPE |
VARCHAR2 |
1 |
Optional |
Entity Type.A-Agent,N-Branch Code,I-IFA,O-Account Officer,B-Broker |
ENTITYID |
VARCHAR2 |
12 |
Optional |
Entity Id |
SETTLEMENTDATE |
DATE |
7 |
Optional |
Settlement Date |
DELIVERYOPTION |
VARCHAR2 |
1 |
Optional |
Delivery Option. Y-On,N-Off |
TRANSACTIONSUBTYPE |
VARCHAR2 |
1 |
Optional |
Transaction Sub Type |
REVERSALCODE |
VARCHAR2 |
2 |
Optional |
Reversal Code |
CANCELINSTRUCTION |
VARCHAR2 |
2 |
Optional |
Cancel Instruction.SI-Standing Instruction |
FROMFUNDPRICEBASIS |
VARCHAR2 |
10 |
Optional |
Fund Price Basis |
TOFUNDPRICEBASIS |
VARCHAR2 |
10 |
Optional |
Switch In Price Basis |
TXN_OR_PRICE_DATE_FLAG |
VARCHAR2 |
1 |
Optional |
Transaction/price date |
FROMPRICEDATE |
DATE |
7 |
Optional |
Price Date |
TOPRICEDATE |
DATE |
7 |
Optional |
Switch In Price Date |
SUBSCRIPTIONFUNDID |
VARCHAR2 |
6 |
Optional |
Subscription Fund ID |
SUBSCRIPTIONPRICEBASIS |
VARCHAR2 |
10 |
Optional |
Subscription Price Basis |
PAYMENTALLOWED |
NUMBER |
1 |
Optional |
Payment Allowed |
PROCESSID1 |
VARCHAR2 |
51 |
Mandatory |
Process ID . Should be same as the Process ID given above. |
SUBSETTLEMENTDATE |
DATE |
10 |
Optional |
Settlement Date |
SUBPRICEDATE |
DATE |
10 |
Optional |
Subscription price Date |
BASECOST |
NUMBER |
15 |
Optional |
Base cost |
EXCHANGERATEDETAILS |
VARCHAR2 |
35 |
Optional |
Exchange Rate Details - Unit Currency,Quoted Currency,Exchange Rate.Seperated by '#' for eg. ZAR#GBP#0.2# |
DEALINGDATE |
DATE |
10 |
Mandatory |
Dealing Date |
COMPLETIONDATE |
DATE |
10 |
Mandatory |
Completion Date |
EUSDOPTION |
VARCHAR2 |
1 |
Mandatory |
EUSD Option.W-With Holiding Tax,E-Exchange of Information,T-Tax Exemption Certificate |
TODEALINGDATE |
DATE |
10 |
Mandatory |
Switch In Dealing Date |
KYCCHASINGDATE |
DATE |
10 |
Mandatory |
Kyc Chasing Date |
KYCRECEIVED |
NUMBER |
1 |
Mandatory |
Kyc Received.1-Yes,0-No |
LOCKINPERIODFORGAIN |
NUMBER |
4 |
Optional |
Lock-In Period for Gain |
SWIINEXCHANGERATEAPPLIED |
NUMBER |
15 |
Mandatory |
Switch-In Exchange Rate Applied |
AUTOCLEARPROVISIONALBALANCE |
NUMBER |
1 |
Optional |
Valid values are 0, 1 and 2 |
Auto Clear Provisional Balance.1-Yes,0-No |
AUTOCLEARREINVESTMENTS |
NUMBER |
1 |
Optional |
Auto Clear Reinvestments.1-Yes,0-No |
FEECURRENCY |
VARCHAR2 |
3 |
Optional |
Valid values are ‘FBC’ and ‘TC’ |
Fee Currency |
MATURITYDATE |
DATE |
10 |
Optional |
Maturity Date |
SUBSOURCEID |
VARCHAR2 |
6 |
Optional |
Subscription Source ID |
CERTSPILLOVER |
NUMBER |
1 |
Optional |
Certificate SpillOver |
ISSUED |
NUMBER |
1 |
Optional |
From Issued Balances.1-Yes,0-No |
BLOCKTXNNUMBER |
VARCHAR2 |
16 |
Optional |
Block Transaction Number |
CPMFBONUSPERCENT |
NUMBER |
30 |
Optional |
CPMF Bonus Percent |
CPMFCREDITLAG |
NUMBER |
3 |
Optional |
CPMF Credit Lag |
RETAINAGEING |
NUMBER |
1 |
Optional |
Retain Ageing |
CAMPAIGNCODE |
VARCHAR2 |
6 |
Optional |
Campaign Code |
FXDEALDATE |
DATE |
10 |
Optional |
Applicable for only IPO Subscription/Subscription/Redemption and Pseudo Switch |
FX Deal Date |
FXVALUEDATE |
DATE |
10 |
Optional |
FX Value Date |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Maker Id |
MAKER_DT_STAMP |
DATE |
10 |
Optional |
Maker Date Stamp |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
Checker Id |
CHECKER_DT_STAMP |
DATE |
10 |
Optional |
Checker Date Stamp |
AUTH_STAT |
VARCHAR2 |
1 |
Mandatory |
Authorisation Status. A-Authorized,U-Unauthorized |
ORDERRECEIVEDDATE |
DATE |
7 |
Optional |
Order Received Date |
ORDERRECEIVEDTIME |
VARCHAR2 |
5 |
Optional |
Order Received Time |
TXNCATEGORY |
VARCHAR2 |
1 |
Optional |
Transaction Category(E-Executiononly L-Legacy A-Advise Mode) |
LOADREFTYPE |
VARCHAR2 |
4 |
Optional |
Load Ref Type |
SOURCEID |
VARCHAR2 |
6 |
Optional |
Source ID |
KIIDRECEIVED |
VARCHAR2 |
1 |
Optional |
KIID Received |
Serial Number: 2
Segment Identification Number: 01SET
Description: This segment is used for providing Transaction Settlement related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 01SET |
TXNSERIALNUMBER |
NUMBER |
10 |
Mandatory |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
UPLOADMODE |
VARCHAR2 |
1 |
Optional |
Upload Mode |
PAYMENTREFERENCENUMBER |
VARCHAR2 |
50 |
Optional |
Payment Reference Number |
PAYMENTMODE |
VARCHAR2 |
2 |
Optional |
Payment Mode.C-Cash,Q-Cheque,T-Transfer,R-Card,M-Multipayment,D-Draft. |
SUBPAYMENTMODE |
VARCHAR2 |
2 |
Optional |
PAYMENTCURRENCY |
VARCHAR2 |
3 |
Optional |
Payment Currency |
PAYMENTDATE |
DATE |
10 |
Optional |
Payment Date |
PAYMENTAMOUNT |
NUMBER |
15 |
Optional |
Payment Amount |
BANKCHARGES |
NUMBER |
15 |
Optional |
Bank Charges |
PAYMENTCHARGES |
NUMBER |
15 |
Optional |
Payment Charges |
EXCHANGERATESOURCE |
VARCHAR2 |
6 |
Optional |
Exchange Rate Source |
EXCHANGERATE |
NUMBER |
15 |
Optional |
F X Rate |
PAYMENTALTERNATEAMOUNT |
NUMBER |
30 |
Optional |
Payment Alternate Amount |
PAIDDATE |
DATE |
10 |
Optional |
Paid Date |
AUTOSETTLEMENT |
NUMBER |
1 |
Optional |
Auto Settle.1-Yes,0-No |
SETTLEMENTMETHOD |
VARCHAR2 |
5 |
Optional |
Settlement Method |
SETTLEMENTSTATUS |
VARCHAR2 |
2 |
Optional |
Settlement Status |
CHEQUEDATE |
DATE |
10 |
Optional |
Cheque Date |
CHEQUENUMBER |
VARCHAR2 |
16 |
Optional |
Cheque Number |
CHEQUECURRENCY |
VARCHAR2 |
3 |
Optional |
Cheque Currency |
CHEQUEAMOUNT |
NUMBER |
15 |
Optional |
Cheque Amount |
DRAWEEBANKCODE |
VARCHAR2 |
12 |
Optional |
Drawee Bank Code |
DRAWEEBRANCHNAME |
VARCHAR2 |
20 |
Optional |
Drawee Branch Name |
PAYMENTREMARKS |
VARCHAR2 |
255 |
Optional |
Payment Remarks |
PAYMENTTYPE |
VARCHAR2 |
1 |
Optional |
Payment Type.S-Self,T-Third Party,B-Broker,R-Retained,AP-Advanced Payment,A-Absorbed/Paid back |
THIRDPARTYADDRESS |
VARCHAR2 |
255 |
Optional |
Third Party Address |
THIRDPARTYADDRESSLINE1 |
VARCHAR2 |
80 |
Optional |
Third Party Address line 1 |
THIRDPARTYADDRESSLINE2 |
VARCHAR2 |
80 |
Optional |
Third Party Address line 2 |
THIRDPARTYADDRESSLINE3 |
VARCHAR2 |
80 |
Optional |
Third Party Address line 3 |
THIRDPARTYADDRESSLINE4 |
VARCHAR2 |
80 |
Optional |
Third Party Address line 4 |
THIRDPARTYBICCODE |
VARCHAR2 |
12 |
Optional |
Third Party BIC Code |
THIRDPARTYCOUNTRYCODE |
VARCHAR2 |
3 |
Optional |
Third Party Country |
THIRDPARTYPAYMENTREFERENCE |
VARCHAR2 |
255 |
Optional |
Third Party Reference |
THIRDPARTYSTATE |
VARCHAR2 |
20 |
Optional |
Third Party State |
THIRDPARTYUSSTATE |
NUMBER |
1 |
Optional |
Third Party US State |
THIRDPARTYZIPCODE |
VARCHAR2 |
10 |
Optional |
Third Party Zip Code |
TRANSFERACCOUNTCURRENCY |
VARCHAR2 |
3 |
Optional |
Transfer Account Currency |
TRANSFERACCOUNTHOLDERNAME |
VARCHAR2 |
100 |
Optional |
Transfer Account Holder Name |
TRANSFERACCOUNTNUMBER |
VARCHAR2 |
20 |
Optional |
Transfer Account Number |
TRANSFERACCOUNTTYPE |
VARCHAR2 |
1 |
Optional |
Transfer Account Type |
TRANSFERBRANCHCODE |
VARCHAR2 |
12 |
Optional |
Transfer Branch Code |
TRANSFERREFERENCENUMBER |
VARCHAR2 |
20 |
Optional |
Transfer Reference Number |
CREDITCARDREFNO |
VARCHAR2 |
16 |
Optional |
Credit Card Reference Number |
INKINDPAYMENTDETAILS |
VARCHAR2 |
255 |
Optional |
In Kind Payment Details |
PAYMENTADDRESSDETAILS |
VARCHAR2 |
255 |
Optional |
Payment Address Details |
OLDPAYMENTREFERENCENO |
VARCHAR2 |
16 |
Optional |
Old Payment Reference Number |
UHBICCODE |
VARCHAR2 |
24 |
Optional |
UH BIC Code |
SWIFTFORMAT |
VARCHAR2 |
6 |
Optional |
Swift Format.MT103-MT103,MT202-MT202 |
BANKCHARGED |
VARCHAR2 |
12 |
Optional |
Bank Charged.Beneficiary-Beneficiary,Remitter-Remitter,Share-Share |
BENEFICIARY |
VARCHAR2 |
35 |
Optional |
Beneficiary |
BENEFICIARYADD1 |
VARCHAR2 |
105 |
Optional |
Beneficiary Address1 |
BENEFICIARYADD2 |
VARCHAR2 |
105 |
Optional |
Beneficiary Address2 |
BENEFICIARYADD3 |
VARCHAR2 |
105 |
Optional |
Beneficiary Address3 |
VARCHAR2 |
24 |
Optional |
Beneficiary BIC Code |
BENEFICIARYACCTNO |
VARCHAR2 |
34 |
Optional |
Beneficiary Account Number |
BENEFICIARYCODE |
VARCHAR2 |
24 |
Optional |
Beneficiary Code |
BENEFICIARYINFO |
VARCHAR2 |
100 |
Optional |
Beneficiary Information |
INTERMEDIARY |
VARCHAR2 |
35 |
Optional |
Intermediary |
INTERMEDIARYADD1 |
VARCHAR2 |
105 |
Optional |
Intermediary Address1 |
INTERMEDIARYADD2 |
VARCHAR2 |
105 |
Optional |
Intermediary Address2 |
INTERMEDIARYADD3 |
VARCHAR2 |
105 |
Optional |
Intermediary Address3 |
VARCHAR2 |
24 |
Optional |
Intermediary BIC Code |
VARCHAR2 |
34 |
Optional |
Intermediary Account No |
INTERMEDIARYCODE |
VARCHAR2 |
24 |
Optional |
Intermediary Code |
INTERMEDIARYINFO |
VARCHAR2 |
100 |
Optional |
Intermediary Info |
FURTHERCREDITNAME |
VARCHAR2 |
35 |
Optional |
Further Credit Name |
VARCHAR2 |
35 |
Optional |
Further Credit Account Number |
REFERENCE1 |
VARCHAR2 |
35 |
Optional |
Reference1 |
REFERENCE2 |
VARCHAR2 |
35 |
Optional |
Reference2 |
ENTITYID |
VARCHAR2 |
12 |
Optional |
Entity ID |
ENTITYTYPE |
VARCHAR2 |
1 |
Optional |
Entity Type |
IBAN |
VARCHAR2 |
40 |
Optional |
IBAN |
BENEFICIARYIBAN |
VARCHAR2 |
40 |
Optional |
Beneficiary IBAN |
INTERMEDIARYIBAN |
VARCHAR2 |
40 |
Optional |
Intermediary IBAN |
BENEFICIARYID |
VARCHAR2 |
12 |
Optional |
Beneficiary ID |
BENEFICIARYPERCENTAGE |
NUMBER |
5 |
Optional |
Beneficiary Percentage |
AMOUNTBLOCKNO |
VARCHAR2 |
16 |
Optional |
Amount Block Number |
SETTLED |
VARCHAR2 |
1 |
Optional |
Settled. Y- Yes , N- No |
REVERSED |
VARCHAR2 |
1 |
Optional |
Reversed. Y- Yes , N- No |
Serial Number: 3
Segment Identification Number: 02KYC
Description: This segment is used for providing KYC Transaction related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 02KYC |
TXNSERIALNUMBER |
NUMBER |
10 |
Mandatory |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
TRANSACTIONNUMBER |
VARCHAR2 |
16 |
Mandatory |
VARCHAR2 |
255 |
Optional |
Document Description |
RECEIVED |
VARCHAR2 |
1 |
Optional |
Received.On-Y,Off-N |
RECEIVEDDATE |
DATE |
10 |
Optional |
Received Date |
REQUESTED |
VARCHAR2 |
1 |
Optional |
Requested.On-Y,Off-N |
TAXDOCUMENT |
NUMBER |
1 |
Optional |
Tax Document.1-Yes,0-No |
Serial Number: 4
Segment Identification Number: 03AIF
Description: This segment is used for providing Additional Information Details
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 03AIF |
TXNSERIALNUMBER |
NUMBER |
10 |
Mandatory |
Transaction serial Number |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
TRANSACTIONNUMBER |
VARCHAR2 |
16 |
Mandatory |
REFERENCENUMBER |
VARCHAR2 |
12 |
Mandatory |
Reference Number |
OTHERINFO1 |
VARCHAR2 |
60 |
Optional |
Other Information 1 |
OTHERINFO2 |
VARCHAR2 |
60 |
Optional |
Other Information 2 |
OTHERINFO3 |
VARCHAR2 |
60 |
Optional |
Other Information 3 |
OTHERINFO4 |
VARCHAR2 |
60 |
Optional |
Other Information 4 |
OTHERINFO5 |
VARCHAR2 |
60 |
Optional |
Other Information 5 |
OTHERINFO6 |
VARCHAR2 |
60 |
Optional |
Other Information 6 |
OTHERINFO7 |
VARCHAR2 |
60 |
Optional |
Other Information 7 |
OTHERINFO8 |
VARCHAR2 |
60 |
Optional |
Other Information 8 |
OTHERINFO9 |
VARCHAR2 |
60 |
Optional |
Other Information 9 |
OTHERINFO10 |
VARCHAR2 |
60 |
Optional |
Other Information 10 |
OTHERINFO11 |
VARCHAR2 |
60 |
Optional |
Other Information 11 |
OTHERINFO12 |
VARCHAR2 |
60 |
Optional |
Other Information 12 |
OTHERINFO13 |
VARCHAR2 |
60 |
Optional |
Other Information 13 |
OTHERINFO14 |
VARCHAR2 |
60 |
Optional |
Other Information 14 |
OTHERINFO15 |
VARCHAR2 |
60 |
Optional |
Other Information 15 |
OTHERINFO16 |
VARCHAR2 |
60 |
Optional |
Other Information 16 |
OTHERINFO17 |
VARCHAR2 |
60 |
Optional |
Other Information 17 |
OTHERINFO18 |
VARCHAR2 |
60 |
Optional |
Other Information 18 |
OTHERINFO19 |
VARCHAR2 |
60 |
Optional |
Other Information 19 |
OTHERINFO20 |
VARCHAR2 |
60 |
Optional |
Other Information 20 |
OTHERINFO21 |
VARCHAR2 |
60 |
Optional |
Other Information 21 |
OTHERINFO22 |
VARCHAR2 |
60 |
Optional |
Other Information 22 |
OTHERINFO23 |
VARCHAR2 |
60 |
Optional |
Other Information 23 |
OTHERINFO24 |
VARCHAR2 |
60 |
Optional |
Other Information 24 |
OTHERINFO25 |
VARCHAR2 |
60 |
Optional |
Other Information 25 |
OTHERINFO26 |
VARCHAR2 |
60 |
Optional |
Other Information 26 |
OTHERINFO27 |
VARCHAR2 |
60 |
Optional |
Other Information 27 |
OTHERINFO28 |
VARCHAR2 |
60 |
Optional |
Other Information 28 |
OTHERINFO29 |
VARCHAR2 |
60 |
Optional |
Other Information 29 |
OTHERINFO30 |
VARCHAR2 |
60 |
Optional |
Other Information 30 |
Serial Number: 5
Segment Identification Number: 04INT
Description: This segment is used for providing Transaction Intermediary related Information
Field Name (as expected in the file) |
Data type |
Length |
Characteristics/rules |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 04INT |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process Id |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
TXNSERIALNUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
ENTITYID |
VARCHAR2 |
12 |
Mandatory |
Entity Id |
ENTITYTYPE |
VARCHAR2 |
1 |
Mandatory |
SPLITPERCENTAGE |
NUMBER |
5 |
Optional |
Split Percentage |
FROMORTOLEG |
VARCHAR2 |
1 |
Mandatory |
From Or To Leg |
Serial Number: 6
Segment Identification Number: 05CER
Description: This segment is used for providing Certificate related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 05CER |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
CERTIFICATENUMBER |
NUMBER |
10 |
Mandatory |
Certificate Number |
NOOFUNITS |
NUMBER |
27 |
Mandatory |
Number of Units |
Serial Number: 7
Segment Identification Number: 06REC
Description: This segment is used for providing Transaction Receipt related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 06REC |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process Id |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
TRANSACTIONNUMBER |
VARCHAR2 |
16 |
Optional |
TRANSACTIONUNITS |
NUMBER |
27 |
Mandatory |
Transaction Units |
Serial Number: 8
Segment Identification Number: 07DEL
Description: This segment is used for providing Delivery related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 07DEL |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
TXNSERIALNUMBER |
NUMBER |
10 |
Optional |
DELIVERYTYPE |
VARCHAR2 |
1 |
Mandatory |
Transaction Units |
ENTITYID |
VARCHAR2 |
12 |
Optional |
Entity ID |
ACCOUNTNUMBER |
VARCHAR2 |
20 |
Optional |
Account Number |
ACCOUNTNAME |
VARCHAR2 |
100 |
Optional |
Account Name |
ADDRESSTYPE |
VARCHAR2 |
2 |
Optional |
Address Type |
ADDRESSLINE1 |
VARCHAR2 |
105
Mandatory |
Address Line1 |
ADDRESSLINE2 |
VARCHAR2 |
105
Mandatory |
Address Line2 |
ADDRESSLINE3 |
VARCHAR2 |
105
Optional |
Address Line3 |
ADDRESSLINE4 |
VARCHAR2 |
80 |
Optional |
Address Line4 |
ZIPCODE |
VARCHAR2 |
10 |
Optional |
Zipcode |
COUNTRY |
VARCHAR2 |
3 |
Optional |
Country |
BICCODE |
VARCHAR2 |
12 |
Optional |
BIC code |
IBAN |
VARCHAR2 |
40 |
Optional |
IBAN |
Serial Number: 9
Segment Identification Number: 08LMO
Description: This segment is used for providing Limit Order related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 08LMO |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process Id |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
TXNSERIALNUMBER |
NUMBER |
10 |
Optional |
LIMITORDERTYPE |
VARCHAR2 |
1 |
Mandatory |
Limit order type |
LIMITORDERSTATUS |
VARCHAR2 |
1 |
Optional |
Limit order status |
LIMITPRICE |
NUMBER |
17 |
Optional |
Limit price |
LIMITDATE |
DATE |
10 |
Optional |
Limit date |
LIMITSTARTDATE |
DATE |
10 |
Optional |
Limit start date |
LIMITENDDATE |
DATE |
10 |
Optional |
Limit end date |
LIMITSTATUS |
VARCHAR2 |
1 |
Optional |
Limit status |
LIMITGENDATE |
DATE |
10 |
Optional |
Limit generation date |
Serial Number: 10
Segment Identification Number: 09LOD
Description: This segment is used for providing Transaction Load Override related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 09LOD |
TXNSERIALNUMBER |
NUMBER |
10 |
Mandatory |
Process Id |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Optional |
LOADID |
NUMBER |
5 |
Mandatory |
Load ID |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
CHANGETYPE |
VARCHAR2 |
1 |
Optional |
Change Type |
CHANGEVALUE |
NUMBER |
30 |
Optional |
Change Value |
GROUPID |
VARCHAR2 |
6 |
Optional |
Group Id |
Serial Number: 11
Segment Identification Number: 10DLO
Description: This segment is used for providing Derived Load Override related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 10DLO |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process Id |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
TXNSERIALNUMBER |
NUMBER |
10 |
Optional |
DERIVEDLOADID |
VARCHAR2 |
6 |
Mandatory |
Load ID |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
PARENTLOADID |
NUMBER |
5 |
Optional |
Parent Load Id |
CHANGETYPE |
VARCHAR2 |
1 |
Optional |
Change Type |
CHANGEVALUE |
NUMBER |
17 |
Optional |
Change Value |
Serial Number: 12
Segment Identification Number: 11PSE
Description: This segment is used for providing Pseudo Switch related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 11PSE |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process Id |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
TXNSERIALNUMBER |
NUMBER |
10 |
Optional |
REFERENCENUMBER |
VARCHAR2 |
16 |
Optional |
Reference Number |
FUNDID |
VARCHAR2 |
12 |
Optional |
Fund Id |
TRANSACTIONDATE |
DATE |
10 |
Optional |
Transaction Date |
LOADID |
NUMBER |
5 |
Optional |
Load Id |
ORIGINALRETURNVALUE |
NUMBER |
30 |
Optional |
Original Return Value |
OVERRIDENRETURNVALUE |
NUMBER |
30 |
Optional |
Overriden Return Value |
CHANGETYPE |
VARCHAR2 |
1 |
Optional |
Change Type |
CHANGEVALUE |
NUMBER |
30 |
Optional |
Change Value |
DERIVEDLOADID |
VARCHAR2 |
6 |
Optional |
Derived Load Id |
DERORIGINALRETURNVALUE |
NUMBER |
30 |
Optional |
Derived Original Return Value |
DEROVERRIDENRETURNVALUE |
NUMBER |
30 |
Optional |
Derived Overriden Return Value |
DERCHANGETYPE |
VARCHAR2 |
1 |
Optional |
Derived Change Type |
DERCHANGEVALUE |
NUMBER |
30 |
Optional |
Derived Change Value |
SUBSCRIPTIONPRICEDATE |
DATE |
10 |
Optional |
Subscription Price Date |
NUMBER |
15 |
Optional |
Exchangerate Applied |
EXCHANGERATEOVERRIDEN |
NUMBER |
15 |
Optional |
Exchangerate Overriden |
OVERRIDEEXCHANGERATE |
VARCHAR2 |
1 |
Optional |
Override Exchangerate |
EXCHANGERATESERIALNO |
VARCHAR2 |
16 |
Optional |
Exchangerate Serial No |
EXCHANGERATEOVERRIDDENSERIALNO |
VARCHAR2 |
16 |
Optional |
Exchangerate Overriddens Erialno |
EXCHANGERATESTATUS |
VARCHAR2 |
1 |
Optional |
Exchangerate Status |
SUBSCRIPTIONSETTLEMENTDATE |
DATE |
10 |
Optional |
Subscription Settlement Date |
SUBSCRIPTIONSOURCEID |
VARCHAR2 |
6 |
Optional |
Subscription Source Id |
SUBTRANSACTIONDATE |
DATE |
10 |
Optional |
Subscription Transaction Date |
FXDEALDATE |
DATE |
10 |
Optional |
Fxdealdate |
FXVALUEDATE |
DATE |
10 |
Optional |
Fxvaluedate |
PROJECTEDRETURNVALUE |
VARCHAR2 |
31 |
Optional |
Projected Return Value |
Serial Number: 13
Segment Identification Number: 12PSL
Description: This segment is used for providing Switch In Fund Load Override related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 12PSL |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process Id |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
TXNSERIALNUMBER |
NUMBER |
10 |
Mandatory |
REFERENCENUMBER |
VARCHAR2 |
16 |
Optional |
Reference Number |
FUNDID |
VARCHAR2 |
12 |
Optional |
Load ID |
LOADID |
NUMBER |
5 |
Mandatory |
Fund ID |
GROUPID |
VARCHAR2 |
6 |
Optional |
Group Id |
CHANGETYPE |
VARCHAR2 |
1 |
Optional |
Change Type |
CHANGEVALUE |
NUMBER |
30 |
Optional |
Change Value |
Serial Number: 14
Segment Identification Number: 13PSD
Description: This segment is used for providing Switch In Fund Derived Load Override related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID - 13PSD |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process Id |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
TXNSERIALNUMBER |
NUMBER |
10 |
Mandatory |
REFERENCENUMBER |
VARCHAR2 |
16 |
Optional |
Reference Number |
FUNDID |
VARCHAR2 |
12 |
Optional |
Fund ID |
DERIVEDLOADID |
VARCHAR2 |
6 |
Mandatory |
Load ID |
PARENTLOADID |
VARCHAR2 |
6 |
Optional |
Group Id |
DERCHANGETYPE |
VARCHAR2 |
1 |
Optional |
Change Type |
DERCHANGEVALUE |
NUMBER |
30 |
Optional |
Change Value |
Segment Identification Number |
Description |
Segment Mandatory / Optional? |
00SIN |
This segment is used for providing Standing Instruction related Information |
Mandatory |
01BRK |
This segment is used for providing SI Intermediary related Information |
Optional |
02CHQ |
This segment is used for providing SI Payment related Information |
Optional |
03DEL |
This segment is used for providing SI Delivery related Information |
Optional |
04FND |
This segment is used for providing SI Fund related Information |
Mandatory |
05CRT |
This segment is used for providing SI Certificate related Information |
Optional |
06ADD |
This segment is used for providing SI Additional Information |
Optional |
Serial Number: 1
Segment Identification Number: 00SIN
Description: This segment is used for providing Standing Instruction related Information
Segment Mandatory / Optional: Mandatory
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Optional |
Segment id. Value of Segment id is 00SIN |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Upload Mode |
SIID |
VARCHAR2 |
16 |
Optional |
Standing Instruction ID |
SIDESCRIPTION |
VARCHAR2 |
255 |
Optional |
SI Description |
FUNDID |
VARCHAR2 |
25 |
Optional |
Fundid |
REFUNITHOLDERID |
VARCHAR2 |
12 |
Optional |
This must be blank |
REFTOUNITHOLDERID |
VARCHAR2 |
12 |
Optional |
UNITHOLDERID |
VARCHAR2 |
12 |
Optional |
Unitholder Id |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Optional |
Transaction Type . 01-IPO Subscription,02-Subscription,03-Redemption,04-Switch,05-Transfer. |
EFFECTIVESTARTDATE |
DATE |
10 |
Optional |
Effective Start Date |
EFFECTIVEENDDATE |
DATE |
10 |
Optional |
Effective End Date |
SIFREQUENCY |
VARCHAR2 |
1 |
Optional |
SI Frequency.M-Monthly,Q-Quartely,H-Half Yearly,Y-Yearly,W-Weekly,F-BiWeekly,D-Daily |
AMOUNT |
NUMBER |
30 |
Optional |
Amount |
UNITS |
NUMBER |
27 |
Optional |
Units |
HOLDINGSPERCENTAGE |
NUMBER |
5 |
Optional |
Percentage |
VARCHAR2 |
3 |
Optional |
Transaction Currency. |
TOUNITHOLDERID |
VARCHAR2 |
12 |
Optional |
To Unitholder Id |
TOFUNDID |
VARCHAR2 |
25 |
Optional |
To FundId |
AGENTCODE |
VARCHAR2 |
12 |
Optional |
Agent Code |
BRANCHCODE |
VARCHAR2 |
12 |
Optional |
Branch Code |
MODULEID |
VARCHAR2 |
30 |
Optional |
Module Id |
MODEOFPAYMENT |
VARCHAR2 |
1 |
Optional |
Mode Of Payment |
PAYMENTBRANCHCODE |
VARCHAR2 |
12 |
Optional |
Payment Branch |
VARCHAR2 |
1 |
Optional |
Account Type |
VARCHAR2 |
20 |
Optional |
Account Number |
REMINDERBEFOREPERIOD |
NUMBER |
3 |
Optional |
Reminder Period |
REMINDERBEFOREACTION |
NUMBER |
1 |
Optional |
Reminder Before Action |
SISTATUS |
VARCHAR2 |
1 |
Optional |
SI Status |
GENERATEAUTHTXN |
NUMBER |
1 |
Optional |
Generate Auth Transactions.1-Yes,0-No |
SITYPE |
VARCHAR2 |
10 |
Optional |
SIESCALATIONFREQUENCY |
VARCHAR2 |
1 |
Optional |
Escalation Frequency.M-Monthly,Q-Quarterly,H-Half-Yearly,Y-Yearly,W-Weekly,F-Bi-Weekly,D-Daily |
NEXTESCALATIONDATE |
DATE |
10 |
Mandatory |
Next Escalation Date |
ESCALATIONTYPE |
VARCHAR2 |
1 |
Optional |
Escalation Type.A-Amount/Units,P-Percentage. |
ESCALATIONVALUE |
NUMBER |
30 |
Optional |
Escalation Value |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Maker Id |
MAKER_DT_STAMP |
DATE |
10 |
Optional |
Maker Date Stamp |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
Checker Id |
CHECKER_DT_STAMP |
DATE |
10 |
Optional |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
Authorisation Status.A-Authorized,U-Unauthorized. |
GROSSORNET |
VARCHAR2 |
1 |
Mandatory |
Mandatory for transaction types (01, 02 & 03) I.e IPO, Subscription and redemption |
Gross or Net.G-Gross,N-Net. |
MEANSOFPURCHASE |
VARCHAR2 |
2 |
Optional |
Value should be a valid means of purchase code maintained in the system |
ISSUED |
VARCHAR2 |
1 |
Optional |
Issued.1-Yes,0-No,2-Both. |
CERTREQD |
VARCHAR2 |
1 |
Optional |
Certificate Required? . 1-Yes,0-No |
SINGLECERT |
VARCHAR2 |
1 |
Optional |
Single Certificate? . 1-Yes , 0-No |
TOSINGLECERT |
VARCHAR2 |
1 |
Optional |
Applicable for script based fund only. |
SUBPAYMENTMODE |
VARCHAR2 |
2 |
Optional |
Mode Of Payment.T-Money Transfer,Q-Cheque,R-Credit Card,D-Demand Draft,F-Against Payment,I-In Kind Payment,AT-Advice,BQ-Broker Cheque,CQ-Cashier cheque,DR-Debit Card,DT-Direct Debit,FQ-Foreign Cheque,GQ-Government Cheque,IQ-Other Institution Cheque,LQ-Local Cheque,OQ-Out Of Town Cheque,PD-Pay Order,PQ-Payroll Deduction,RQ-Reserve Bank Cheque,TT-Telegraphic Transfer,WT-Wire Transfer. |
ESCALATIONSTARTDATE |
DATE |
10 |
Mandatory |
Mandatory if Escalation type is provided |
Escalation Start Date |
ESCALATIONENDDATE |
DATE |
10 |
Mandatory |
Escalation End Date |
PAYMENTBANKCODE |
VARCHAR2 |
12 |
Mandatory |
Required for payment modes check transfer, credit card and demand draft |
Payment Bank Code |
VARCHAR2 |
60 |
Optional |
PAYMENTTYPE |
VARCHAR2 |
1 |
Optional |
Payment Type. S-Self,T-Third Party. |
VARCHAR2 |
255 |
Optional |
THIRDPARTYZIPCODE |
VARCHAR2 |
6 |
Optional |
THIRDPARTYUSSTATE |
NUMBER |
1 |
Optional |
DELIVERYOPTION |
VARCHAR2 |
1 |
Optional |
Delivery Option |
THIRDPARTYBICCODE |
VARCHAR2 |
12 |
Optional |
BIC Code |
VARCHAR2 |
3 |
Optional |
Country |
VARCHAR2 |
80 |
Optional |
Address Line 1 |
VARCHAR2 |
80 |
Optional |
Address Line 2 |
VARCHAR2 |
80 |
Optional |
City |
VARCHAR2 |
80 |
Optional |
Country |
VARCHAR2 |
20 |
Optional |
CIFNUMBER |
VARCHAR2 |
12 |
Optional |
CIF Number |
TOCIFNUMBER |
VARCHAR2 |
12 |
Optional |
To CIF Number |
POLICYNUMBER |
VARCHAR2 |
16 |
Optional |
PRODUCTID |
VARCHAR2 |
10 |
Optional |
ENTITYTYPE |
VARCHAR2 |
1 |
Optional |
Entity Type.B-Broker,A-Agent,I-IFA,O-Account Officer,N-Agency Branch. |
ENTITYID |
VARCHAR2 |
12 |
Optional |
Broker/Intermediary |
REFFUNDID |
VARCHAR2 |
6 |
Optional |
Specify the fund code here |
REFTOFUNDID |
VARCHAR2 |
6 |
Optional |
Specify the fund code if the SI is switch type of instruction |
MINHOLDCHKREQ |
NUMBER |
1 |
Optional |
Minimum Holding Check Required? 1-Yes,0-No |
VARCHAR2 |
10 |
Optional |
Price Basis |
TOFUNDPRICEBASIS |
VARCHAR2 |
10 |
Optional |
PHASEIN |
NUMBER |
1 |
Optional |
Phase In |
PHASEINTYPE |
VARCHAR2 |
1 |
Optional |
If PHASEIN is applicable then this field is mandatory. |
Phase In Type. H-Holdings. |
PHASEINOCCURENCES |
NUMBER |
3 |
Optional |
If Phase In is applicable then this field is mandatory. |
REMAININGOCCURENCES |
NUMBER |
3 |
Optional |
GENERATEON |
VARCHAR2 |
255 |
Optional |
NOOFSI |
NUMBER |
5 |
Optional |
No. of SI Transactions |
SWIFTFORMAT |
VARCHAR2 |
6 |
Optional |
Swift Format. MT103-MT103,MT202-MT202 |
BANKCHARGED |
VARCHAR2 |
12 |
Optional |
Bank Charged.Shared-Shared,Remit-Remit. |
BENEFICIARY |
VARCHAR2 |
35 |
Optional |
Beneficiary |
BENEFICIARYADD1 |
VARCHAR2 |
105 |
Optional |
BENEFICIARYADD2 |
VARCHAR2 |
105 |
Optional |
BENEFICIARYADD3 |
VARCHAR2 |
105 |
Optional |
VARCHAR2 |
24 |
Optional |
BENEFICIARYACCTNO |
VARCHAR2 |
34 |
Optional |
BENEFICIARYCODE |
VARCHAR2 |
24 |
Optional |
Beneficiary Code |
BENEFICIARYINFO |
VARCHAR2 |
100 |
Optional |
Beneficiary Info |
INTERMEDIARY |
VARCHAR2 |
35 |
Optional |
Intermediary |
INTERMEDIARYADD1 |
VARCHAR2 |
105 |
Optional |
INTERMEDIARYADD2 |
VARCHAR2 |
105 |
Optional |
INTERMEDIARYADD3 |
VARCHAR2 |
105 |
Optional |
VARCHAR2 |
24 |
Optional |
VARCHAR2 |
34 |
Optional |
Intermediary Account Number |
INTERMEDIARYCODE |
VARCHAR2 |
24 |
Optional |
Intermediary Code |
INTERMEDIARYINFO |
VARCHAR2 |
100 |
Optional |
Intermediary Info |
FURTHERCREDITNAME |
VARCHAR2 |
35 |
Optional |
VARCHAR2 |
35 |
Optional |
REFERENCE1 |
VARCHAR2 |
35 |
Optional |
Reference1 |
REFERENCE2 |
VARCHAR2 |
35 |
Optional |
Reference2 |
NOOFSITRANSACTIONS |
NUMBER |
4 |
Optional |
SILEVEL |
VARCHAR2 |
1 |
Optional |
Valid values are ‘F’ and ‘P’ |
SI Level. P-Plan,F-Fund |
PLANCODE |
VARCHAR2 |
6 |
Optional |
Plan Code |
FIRSTPAYMENTDATE |
DATE |
10 |
Optional |
First Generation Date |
IBAN |
VARCHAR2 |
40 |
Optional |
IBAN |
CAMPAIGNCODE |
VARCHAR2 |
6 |
Optional |
Campaign Code |
BENEFICIARYIBAN |
VARCHAR2 |
40 |
Optional |
Beneficiary IBAN |
INTERMEDIARYIBAN |
VARCHAR2 |
40 |
Optional |
Intermediary IBAN |
SIPAYMENTREJECTIONCOUNTER |
NUMBER |
3 |
Optional |
No. of Cumulative Payment Rejections |
SIAUTOTERMINATIONCOUNTER |
NUMBER |
3 |
Optional |
SI Auto-Termination Cumulative Counter |
CONSSIPAYMNTREJCNTER |
NUMBER |
3 |
Optional |
No. of Consecutive Payment Rejections |
CONSSIAUTOCOUNTER |
NUMBER |
3 |
Optional |
SI Auto-Termination Consecutive Counter |
MAXSITXNSALLOWED |
NUMBER |
3 |
Optional |
Maximum SI Transactions Allowed |
Serial Number: 2
Segment Identification Number: 01BRK
Description: This segment is used for providing SI Intermediary related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment id. Value of Segment id is 01BRK |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Optional |
Import file Name |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
UPLOADMODE |
VARCHAR2 |
1 |
Optional |
Uplaod Mode |
SIID |
VARCHAR2 |
16 |
Optional |
SI Id |
ENTITYID |
VARCHAR2 |
12 |
Optional |
ENTITYTYPE |
VARCHAR2 |
1 |
Optional |
Entity Type. B-Broker,A-Agent,I-IFA,O-Account Officer,N-Agency Branch. |
SPLITPERCENTAGE |
NUMBER |
5 |
Optional |
Split Percentage |
FROMORTOLEG |
VARCHAR2 |
1 |
Mandatory |
From Or To Leg. F-From,T-To |
Serial Number: 3
Segment Identification Number: 02CHQ
Description: This segment is used for providing SI Payment related Information
Data type |
Length |
Mandatory/Optional |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment id. Value of Segment id is 02CHQ |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Optional |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Optional |
Import file Name |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
UPLOADMODE |
VARCHAR2 |
1 |
Optional |
Uplaod Mode |
SIID |
VARCHAR2 |
16 |
Optional |
SI Id |
PAYMENTMODE |
VARCHAR2 |
1 |
Optional |
Payment Mode |
PAYMENTNUMBER |
VARCHAR2 |
16 |
Optional |
Cheque Number |
PAYMENTDATE |
DATE |
10 |
Optional |
Payment Date |
PROCESSED |
NUMBER |
1 |
Optional |
Processed. 1-Yes , 0-No |
Serial Number: 4
Segment Identification Number: 03DEL
Description: This segment is used for providing SI Delivery related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment id. Value of Segment id is 03DEL
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Optional |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Optional |
Import file Name |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
UPLOADMODE |
VARCHAR2 |
1 |
Optional |
Uplaod Mode |
SIID |
VARCHAR2 |
16 |
Optional |
SI Id |
DELIVERYTYPE |
VARCHAR2 |
1 |
Optional |
Delivery Type. S-Self ,T-Third Party |
ENTITYID |
VARCHAR2 |
12 |
Optional |
Clearing Agent/Custodian Bank |
ACCOUNTNUMBER |
VARCHAR2 |
1620 |
Optional |
Account Number |
ACCOUNTNAME |
VARCHAR2 |
100 |
Optional |
Account Name |
ADDRESSTYPE |
VARCHAR2 |
2 |
Optional |
Address Type |
ADDRESSLINE1 |
VARCHAR2 |
105
Mandatory |
Address Line1 |
ADDRESSLINE2 |
VARCHAR2 |
105
Mandatory |
Address Line2 |
ADDRESSLINE3 |
VARCHAR2 |
105 |
Optional |
Address Line3 |
ADDRESSLINE4 |
VARCHAR2 |
80 |
Optional |
Address Line4 |
ZIPCODE |
VARCHAR2 |
10 |
Optional |
Zip Code |
COUNTRY |
VARCHAR2 |
3 |
Optional |
Country |
BICCODE |
VARCHAR2 |
12 |
Optional |
BIC Code |
IBAN |
VARCHAR2 |
40 |
Optional |
IBAN |
Serial Number: 5
Segment Identification Number: 04FND
Description: This segment is used for providing SI Fund related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment id. Value of Segment id is 04FND
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Optional |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Optional |
Import file Name |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
UPLOADMODE |
VARCHAR2 |
1 |
Optional |
Uplaod Mode |
SIID |
VARCHAR2 |
16 |
Optional |
SI Id |
FUNDID |
VARCHAR2 |
6 |
Optional |
FundId |
ISSUED |
VARCHAR2 |
1 |
Optional |
From Issued Balances. 1-Yes,0-No,2-Both |
CERTREQD |
VARCHAR2 |
1 |
Optional |
Certificate Required? 1-Yes , 0-No |
SINGLECERT |
VARCHAR2 |
1 |
Optional |
Single Certificate? 1-Yes , 0-No |
MINHOLDCHKREQ |
NUMBER |
1 |
Mandatory |
Minimum Holding Check Required? 1-Yes , 0-No |
VARCHAR2 |
10 |
Optional |
Price Basis |
CONTRIBUTIONPERCENTAGE |
NUMBER |
5 |
Optional |
Contribution Percentage |
CONTRIBUTIONAMOUNT |
NUMBER |
30 |
Optional |
Contribution Amount |
Serial Number: 6
Segment Identification Number: 05CRT
Description: This segment is used for providing SI Certificate related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Optional |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Optional |
Import file Name |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
UPLOADMODE |
VARCHAR2 |
1 |
Optional |
Uplaod Mode |
TRANSACTIONNUMBER |
VARCHAR2 |
16 |
Optional |
REFERENCENUMBER |
VARCHAR2 |
16 |
Optional |
Reference Number |
CERTIFICATENUMBER |
NUMBER |
10 |
Mandatory |
NOOFUNITS |
NUMBER |
27 |
Optional |
Number of Units |
Serial Number: 7
Segment Identification Number: 06ADD
Description: This segment is used for providing SI Additional Information
Data type |
Length |
Mandatory |
Values |
SEGMENTID |
NUMBER |
20 |
Yes |
Segment id. Value of Segment id is 06ADD |
SEQUENCENUMBER |
NUMBER |
22 |
Yes |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Yes |
Process id |
OTHERINFOFIELD |
VARCHAR2 |
100 |
No |
Other info |
FIELDVALUE |
VARCHAR2 |
60 |
No |
Field value |
Description |
00IDI |
This segment is used for providing Income Distribution related Information |
Mandatory |
00IDR |
This segment is used for providing Income Distribution Reinvestment related Information |
Mandatory |
Serial Number: 1
Segment Identification Number: 00IDI
Description: This segment is used for providing Income Distribution related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 00IDI |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Mandatory |
Upload Mode |
UPLOADMODE |
VARCHAR2 |
1 |
Optional |
AMC ID |
REFUNITHOLDERID |
VARCHAR2 |
12 |
Optional |
FUNDID |
VARCHAR2 |
25 |
Mandatory |
Fund Id |
DISTRIBUTIONMODE |
VARCHAR2 |
1 |
Mandatory |
Distribution Mode.P-Full Payment,R-Full Reinvestment,B-Both |
PAYMENTSPLITPERCENTAGE |
NUMBER |
5 |
Optional |
Payment Percentage |
CHEQUEPAYMENTSPLIT |
NUMBER |
5 |
Optional |
Cheque Payment Split Percentage |
TRANSFERPAYMENTSPLIT |
NUMBER |
5 |
Optional |
Transfer Payment Split Percentage |
XFERBANKCODE |
VARCHAR2 |
12 |
Optional |
Transfer Bank Code |
XFERBRANCHCODE |
VARCHAR2 |
12 |
Optional |
XFERACCOUNTTYPE |
VARCHAR2 |
1 |
Optional |
XFERACCOUNTNUMBER |
VARCHAR2 |
20 |
Mandatory |
Required if Payment SplitPercentage > 0 and Payment by Transfer |
XFERACCOUNTCURRENCY |
VARCHAR2 |
3 |
Optional |
AGENTCODE |
VARCHAR2 |
12 |
Mandatory |
Agent Code |
BRANCHCODE |
VARCHAR2 |
12 |
Mandatory |
Branch Code |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
Rule Effective Date |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Maker Id |
MAKER_DT_STAMP |
DATE |
7 |
Optional |
Maker Date Stamp |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
Checker Id |
CHECKER_DT_STAMP |
DATE |
7 |
Optional |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
Authorization Status.A-Authorized,U-Unauthorized |
PAYMENTMODE |
VARCHAR2 |
1 |
Optional |
Payment Mode.Q-Cheque-Cheque,T-Transfer-Transfer |
SUBPAYMENTMODE |
VARCHAR2 |
2 |
Optional |
Subpayment Mode.Q-Cheque-Cheque,T-Transfer-Transfer |
PAYMENTTYPE |
VARCHAR2 |
1 |
Optional |
Payment Type.S-Self,T-Third Party,E-Entity |
VARCHAR2 |
255 |
Optional |
THIRDPARTYPAYMENTADDRESS |
VARCHAR2 |
255 |
Optional |
Third Party Payment Address |
THIRDPARTYPAYMENTCITY |
VARCHAR2 |
20 |
Optional |
Third Party Payment City |
THIRDPARTYPAYMENTSTATE |
VARCHAR2 |
20 |
Optional |
US State/ Non-US State |
USSTATE |
NUMBER |
1 |
Optional |
US State.1-Yes,0-No |
THIRDPARTYPAYMENTZIPCODE |
VARCHAR2 |
10 |
Optional |
Third Party Payment Zip Code |
XFERACCOUNTHOLDERNAME |
VARCHAR2 |
100 |
Mandatory |
ENTITYTYPE |
VARCHAR2 |
1 |
Optional |
Entity Type.B-Broker |
ENTITYID |
VARCHAR2 |
12 |
Optional |
Entity ID |
REFFUNDID |
VARCHAR2 |
6 |
Mandatory |
Reference Fund ID |
IDSENTITYTYPE |
VARCHAR2 |
1 |
Mandatory |
Unit Holder Or Broker. U-Unitholder,B-Broker |
IDSENTITYID |
VARCHAR2 |
12 |
Optional |
Unitholder Id Or Broker Code |
SWIFTFORMAT |
VARCHAR2 |
6 |
Optional |
Swift Format |
BANKCHARGED |
VARCHAR2 |
12 |
Optional |
Bank Charged |
BENEFICIARY |
VARCHAR2 |
35 |
Optional |
Beneficiary |
BENEFICIARYADD1 |
VARCHAR2 |
105 |
Optional |
BENEFICIARYADD2 |
VARCHAR2 |
105 |
Optional |
BENEFICIARYADD3 |
VARCHAR2 |
105 |
Optional |
BENEFICIARYBICCODE |
VARCHAR2 |
24 |
Optional |
BENEFICIARYACCTNO |
VARCHAR2 |
34 |
Optional |
Beneficiary Account No |
BENEFICIARYCODE |
VARCHAR2 |
24 |
Optional |
Beneficiary Code |
BENEFICIARYINFO |
VARCHAR2 |
100 |
Optional |
Beneficiary Info |
INTERMEDIARY |
VARCHAR2 |
35 |
Optional |
Intermediary |
INTERMEDIARYADD1 |
VARCHAR2 |
105 |
Optional |
INTERMEDIARYADD2 |
VARCHAR2 |
105 |
Optional |
INTERMEDIARYADD3 |
VARCHAR2 |
105 |
Optional |
INTERMEDIARYBICCODE |
VARCHAR2 |
24 |
Optional |
INTERMEDIARYACCTNO |
VARCHAR2 |
34 |
Optional |
INTERMEDIARYCODE |
VARCHAR2 |
24 |
Optional |
Intermediary Code |
INTERMEDIARYINFO |
VARCHAR2 |
100 |
Optional |
Intermediary Info |
FURTHERCREDITNAME |
VARCHAR2 |
35 |
Optional |
FURTHERCREDITACCTNO |
VARCHAR2 |
35 |
Optional |
REFERENCE1 |
VARCHAR2 |
35 |
Optional |
Reference1 |
REFERENCE2 |
VARCHAR2 |
35 |
Optional |
Reference2 |
POLICYNUMBER |
VARCHAR2 |
16 |
Optional |
Policy Number |
PRODUCTID |
VARCHAR2 |
10 |
Optional |
Product ID |
PAYMENTCURRENCY |
VARCHAR2 |
3 |
Optional |
Payment Currency |
IBAN |
VARCHAR2 |
40 |
Optional |
IBAN |
BENEFICIARYIBAN |
VARCHAR2 |
40 |
Optional |
Beneficiary IBAN |
INTERMEDIARYIBAN |
VARCHAR2 |
40 |
Optional |
Intermediary IBAN |
Serial Number: 2
Segment Identification Number: 00IDR
Description: This segment is used for providing Income Distribution Reinvestment related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 00IDR |
SEQUENCENUMBER |
NUMBER |
10 |
Optional |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Optional |
Process ID |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Fund id |
REINVESTMENTUNITHOLDERID |
VARCHAR2 |
12 |
Mandatory |
Unitholder Id |
REINVESTMENTFUNDID |
VARCHAR2 |
6 |
Mandatory |
TO Fund id |
SPLITPERCENTAGE |
NUMBER |
5 |
Mandatory |
Split Percentage |
RULEEFFECTIVEDATE |
DATE |
20 |
Optional |
Rule Effective date |
IDSENTITYTYPE |
VARCHAR2 |
1 |
Mandatory |
IDSENTITYID |
VARCHAR2 |
12 |
Mandatory |
POLICYNUMBER |
VARCHAR2 |
16 |
Optional |
Policy Number |
PRODUCTID |
VARCHAR2 |
10 |
Optional |
Product ID |
Description |
00FPI |
This segment is used for providing Fund Price related Information |
Mandatory |
01FBP |
This segment is used for providing Fund Price Base Price Constant related Information |
Optional |
02FCT |
This segment is used for providing Fund Price Components related Information |
Optional |
03FAI |
This segment is used for providing Fund Price Additional Information related Information |
Optional |
04FPH |
This segment is used for providing NAV related information for the fund price currencies maintained at the fund level |
Optional |
05FPD |
This segment is used for providing Fund Price Base Price Constant related Information for the fund price currencies maintained at fund level |
Optional |
06FPC |
This segment is used for providing Fund Price Component related Information for the fund price currencies maintained at fund level |
Optional |
Serial Number: 1
Segment Identification Number: 00FPI
Description: This segment is used for providing Fund Price related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID.Value should be 00FPI |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
FUNDID |
VARCHAR2 |
25 |
Mandatory |
Fund ID |
EFFECTIVEDATE |
DATE |
10 |
Optional |
SWINGINGPRICE |
NUMBER |
30 |
Mandatory |
Swinging Price |
SWINGPRICEBASIS |
VARCHAR |
50 |
Mandatory |
Swinging Price Basis (Offer, Mid or Bid Price |
REALNAVPERUNIT |
NUMBER |
17 |
Optional |
Real NAV per Unit |
FLOORPRICE |
NUMBER |
17 |
Optional |
Floor Price |
CEILINGPRICE |
NUMBER |
17 |
Optional |
Ceiling Price |
DECLAREDNAV |
NUMBER |
17 |
Optional |
Declared NAV |
LATESTPRICE |
NUMBER |
1 |
Optional |
Latest Price |
EUROEQUIVALENTOFNAV |
NUMBER |
24 |
Optional |
Euro Equivalent of NAV |
AMENDTXNFLAG |
NUMBER |
10 |
Optional |
Amend Transaction Flag |
HURDLERATE |
NUMBER |
10 |
Optional |
Hurdle Rate |
HWMPLUSHURDLE |
NUMBER |
27 |
Optional |
HWM + Hurdle |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
It shows the name of the user who has created or modified the specific record |
MAKER_DT_STAMP |
DATE |
10 |
Optional |
This field specifies the date and time at which this record was created or modified. It is defaulted by system and will be in date format |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
It shows the Name of the user who authorizes that specific record |
CHECKER_DT_STAMP |
DATE |
10 |
Optional |
This field specifies the date and time at which this record was authorized is displayed in this field. It is defaulted by system and will be in date format |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Operation mode which will be performed on the Upload records. It can have N-New,D-Delete,A-Auth & E- Modify |
Serial Number: 2
Segment Identification Number: 01FBP
Description: This segment is used for providing Fund Price Base Price Constant related Information
Segment Mandatory / Optional: Optional
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID.Value should be 01FPB |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
BASEPRICECONSTANT |
NUMBER |
22 |
Optional |
Base Price Constant |
TRANSACTIONBASEPRICE |
NUMBER |
22 |
Optional |
Transaction Base Price |
ALLOCATIONPERVSREGCAPITAL |
NUMBER |
22 |
Optional |
Allocation vs Register Capital |
Segment Identification Number: 03FAI
Description: This segment is used for providing Fund Price Additional Information related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID.Value shoule be 03FAI |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
ADDINFOLABEL |
VARCHAR2 |
30 |
Optional |
Add Information Label |
FIELDVALUE |
CHAR |
23 |
Optional |
Field Value |
Serial Number: 4
Segment Identification Number: 02FCT
Description: This segment is used for providing Fund Price Component related Information
Data Type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
COMPONENT ID |
VARCHAR2 |
10 |
Optional |
Component ID |
COMPONENT VALUE |
NUMBER |
30 |
Optional |
Component Value |
Serial Number: 5
Segment Identification Number: 04FPH
Description: This segment is used for providing NAV related information for the fund price currencies maintained at the fund level
Data Type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID. Value of Segment id is 04FPH |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Fund id |
EFFECTIVEDATE |
DATE |
Mandatory |
Rule effective date |
CURRENCY |
VARCHAR2 |
3 |
Mandatory |
Fund price currency |
REALNAVPERUNIT |
NUMBER |
17 |
Optional |
Real Nav per unit |
DECLAREDNAV |
NUMBER |
17 |
Optional |
Declared nav per unit |
FLOORPRICE |
NUMBER |
17 |
Optional |
Floor price |
CEILINGPRICE |
NUMBER |
17 |
Optional |
Ceiling price |
LATESTPRICE |
NUMBER |
1 |
Optional |
Latest Price |
AMENDTXNFLAG |
NUMBER |
1 |
Optional |
Amend transaction flag-when set all the transactions captured in the particular currency are amended |
Serial Number: 6
Segment Identification Number: 05FPD
Description: This segment is used for providing Fund Price Base Price Constant related Information for the fund price currencies maintained at fund level.
Data Type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID. Value of Segment id is 05FPD |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Fund id |
EFFECTIVEDATE |
DATE |
Mandatory |
CURRENCY |
VARCHAR2 |
3 |
Mandatory |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
BASEPRICECONSTANT |
NUMBER |
17 |
Optional |
NUMBER |
17 |
Optional |
NUMBER |
20 |
Optional |
Allocation Vs Register Capital |
Serial Number: 7
Segment Identification Number: 06FPC
Description: This segment is used for providing Fund Price Component related Information for the fund price currencies maintained at fund level.
Data Type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID. Value of Segment id is 06FPC |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Fund id |
EFFECTIVEDATE |
DATE |
Mandatory |
CURRENCY |
VARCHAR2 |
3 |
Mandatory |
COMPONENTID |
VARCHAR2 |
10 |
Mandatory |
Component ID |
COMPONENTVALUE |
NUMBER |
30 |
Optional |
Component Value |
Description |
00BRO |
This segment is used for providing Broker Upload related Information |
Mandatory |
01CON |
This segment is used for providing Broker Contact Information related Information |
Optional |
02BAN |
This segment is used for providing Brokers Bank Information related details |
Optional |
03LEG |
This segment is used for providing Brokers Legacy related Information |
Optional |
04PRE |
This segment is used for providing Brokers Preference related Information |
Optional |
05ADD |
This segment is used for providing Broker Additional Information related details |
Optional |
06REL |
This segment is used for providing Broker Related Party Details |
Optional |
Serial Number: 1
Segment Identification Number: 00BRO
Description: This segment is used for providing Broker Upload related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id. Value for Segment id is 00BRO |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Value defaulted as maintained in Bulk client defaults in the absence of information in the file |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Mode of operation which has to be performed on the record |
BROKERCODE |
VARCHAR2 |
12 |
Mandatory |
The code to uniquely identify the broker. |
BROKERNAME |
VARCHAR2 |
105 |
Mandatory |
Name of the broker |
PARENTBROKERCODE |
VARCHAR2 |
12 |
Mandatory |
Represents the parent of the broker. The commission received by the broker is shared with this parent |
BROKERBASECCY |
VARCHAR2 |
3 |
Mandatory |
Represents the base currency of the broker. Tax and other calculations are done based on this currency |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
DELETEDSTATUS |
NUMBER |
1 |
Mandatory |
Flag to identify whether the broker record is in any of these states 1-active or 0-closed or 2-pending closure state |
OVERRIDDENTAXPERCENTAGE |
NUMBER |
156 |
Mandatory |
The tax percentage applicable for the broker can be overridden here |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Represents the user id who has entered the latest record. |
MAKER_DT_STAMP |
DATE |
10 |
Mandatory |
Represents the time when the record is created |
LEVELNUMBER |
NUMBER |
3 |
Optional |
Represents at which level the broker is in the parent broker hierarchy. The top parent will have level number 0 |
RULEEFFECTIVEDATE |
DATE |
10 |
Mandatory |
The date from which the changes are applicable. This along with broker code forms the PRIMARY KEY |
CHANGETYPE |
VARCHAR2 |
1 |
Optional |
This column is not used |
VATREGISTERED |
NUMBER |
1 |
Mandatory |
Represents whether the broker is VAT Registered broker or not. If the broker is VAT registered then VAT will be applicable on the commission amount he gets |
VATREGISTRATIONNUMBER |
VARCHAR2 |
15 |
Mandatory |
Represents the VAT Registration number of the broker |
COMMISSIONPERCENTAGE |
NUMBER |
52 |
Mandatory |
Represents how much percentage commission should be shared with his parent broker. If the broker is the top level broker then this value should be 100 |
COMMISSIONPAYMENTFREQ |
VARCHAR2 |
1 |
Mandatory |
Indicates at what frequency the commission should be paid to the broker. |
UNITHOLDERID |
VARCHAR2 |
12 |
Mandatory |
Represents the default unit holder of the broker |
NEXTPAYMENTDATE |
DATE |
10 |
Mandatory |
Indicates the next payment date of the broker. Commission accumulated from last payment date to till this date will be paid on this date |
CHECKER_ID |
VARCHAR2 |
15 |
Mandatory |
Represents the checker id who has authorized the latest record. |
CHECKER_DT_STAMP |
DATE |
10 |
Mandatory |
Represents the time when it was Authorized. |
BROKERTYPE |
VARCHAR2 |
6 |
Mandatory |
Represents the type of the broker; user can define broker type throught broker type maintenance |
USEBROKERTYPEPAYMENTDATES |
NUMBER |
1 |
Mandatory |
Flag to identify whether the payment details based in the broker type maintenance or not |
BROKERCONSULTANT |
VARCHAR2 |
40 |
Mandatory |
Represents broker consultant name |
BROKERCATEGORY |
VARCHAR2 |
1 |
Mandatory |
Represents the category of the broker, whether Individual or Corporate |
HOLDBACKPAYMENT |
NUMBER |
1 |
Mandatory |
Flag to identify whether the payment should be kept hold for the broker |
MOD_NO |
NUMBER |
10 |
Optional |
Represents the number of times the record got modified |
HOLDPYMTFROMDATE |
DATE |
10 |
Mandatory |
Represents the payment hold back from date |
BROKERSTATUS |
VARCHAR2 |
1 |
Mandatory |
Represents whether the broker is in normal or weeded status |
REPLICATEPARENTDET |
CHAR |
1 |
Mandatory |
Flag to identify whether the details of the parent broker should be replicated or not. If this is true then the parent brokers data will be defaulted based on the template maintained |
VATREGISTRATIONDATE |
DATE |
10 |
Mandatory |
Represents from when the broker got VAT registered |
TEMPLATEID |
VARCHAR2 |
6 |
Mandatory |
Represents the template id to replicate the parent details, the fields available in template will be replicated to child broker if REPLICATEPARENTDET flag is set to true |
NATIONALITY |
VARCHAR2 |
3 |
Mandatory |
Nationality of the broker |
COUNTRYOFBIRTH |
VARCHAR2 |
3 |
Mandatory |
Birth country of the broker |
COUNTRYOFDOMICILE |
VARCHAR2 |
3 |
Mandatory |
Country of domicile of the broker |
INCORPORATIONCOUNTRY |
VARCHAR2 |
3 |
Mandatory |
The country of the corporate |
TAXID |
VARCHAR2 |
50 |
Mandatory |
Tax identification |
EIN |
VARCHAR2 |
50 |
Mandatory |
Employer ID number |
TAXCERTIFICATEEFFEDATE |
DATE |
10 |
Mandatory |
Tax certificate effective Date |
TAXCERTIFICATEEXPDATE |
DATE |
10 |
Mandatory |
Tax certificate expiry Date |
TAXCIRCLE |
VARCHAR2 |
3 |
Mandatory |
Name of the Place. |
VATEXPIRYDATE |
DATE |
10 |
Optional |
Represents the expiry date for VAT registered flag |
Serial Number: 2
Segment Identification Number: 01CON
Description: This segment is used for providing Broker Contact Information related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id. Value for Segment id is 01CON |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
ADDRESSTYPE |
VARCHAR2 |
2 |
Mandatory |
Represents the Addresstype |
ADDRESSLINE1 |
VARCHAR2 |
105
Mandatory |
Represents the Addressline1 |
ADDRESSLINE2 |
VARCHAR2 |
105
Optional |
Represents the Addressline2 |
ADDRESSLINE3 |
VARCHAR2 |
105 |
Optional |
Represents the Addressline3 |
ADDRESSLINE4 |
VARCHAR2 |
80 |
Optional |
Represents the Addressline4 |
ZIPCODE |
VARCHAR2 |
10 |
Mandatory |
Represents the Zipcode |
COUNTRY |
VARCHAR2 |
3 |
Mandatory |
Represents the Country |
USSTATE |
NUMBER |
1 |
Mandatory |
Represents the US state |
TELEPHONE1 |
VARCHAR2 |
60 |
Mandatory |
Represents the Telephone1 |
TELEPHONE2 |
VARCHAR2 |
60 |
Mandatory |
Represents the Telephone2 |
CELLPHONENUMBER |
VARCHAR2 |
105 |
Mandatory |
Represents the Cellphone number |
FAX |
VARCHAR2 |
120 |
Mandatory |
Represents the Fax Number |
VARCHAR2 |
255 |
Mandatory |
Represents the Email ID |
CONTACTPERSON |
VARCHAR2 |
160 |
Mandatory |
Represents the Contact person |
EFFECTIVEFROMDATE |
DATE |
10 |
Mandatory |
Represents the Effective from date |
EFFECTIVETODATE |
DATE |
10 |
Mandatory |
Represents the Effective to date |
BICCODE |
VARCHAR2 |
12 |
Mandatory |
Represents the Bic code |
INTDIALLINGCODEFAX |
VARCHAR2 |
10 |
Mandatory |
International dialling code for FAX |
INTDIALLINGCODEPH2 |
VARCHAR2 |
10 |
Mandatory |
International dialling code for telephone number 2 |
INTDIALLINGCODEPH1 |
VARCHAR2 |
10 |
Mandatory |
International dialling code for telephone number 1 |
INTDIALLINGCODECELL |
VARCHAR2 |
10 |
Mandatory |
International dialling code for cellphone number |
Serial Number: 3
Segment Identification Number: 02BAN
Description: This segment is used for providing Brokers Bank Information related details
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id. Value for Segment id is 02BAN |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BANKCODE |
VARCHAR2 |
12 |
Mandatory |
Indicates the Bank code. |
BRANCHCODE |
VARCHAR2 |
12 |
Mandatory |
Indicates the Branch code. |
ACCOUNTTYPE |
VARCHAR2 |
1 |
Mandatory |
Indicates Type of the account. |
ACCOUNTNUMBER |
VARCHAR2 |
20 |
Mandatory |
Indicates the Unique account number. |
ACCOUNTNAME |
VARCHAR2 |
100 |
Mandatory |
Indicates the Account holders name. |
ACCOUNTCURRENCY |
VARCHAR2 |
3 |
Mandatory |
Indicates the currency in which the account is maintained. |
DEFAULTDETAILS |
NUMBER |
1 |
Mandatory |
This Flag decides whether its default account to be used for this currency.Mandatory to give "YES" for anyone record of each currency. |
DIRECTDEBITAPPLICABLE |
NUMBER |
1 |
Mandatory |
This Flag decides whether direct debit is applicable for this account or not. |
IBAN |
VARCHAR2 |
40 |
Mandatory |
Indicates the IBAN number of the bank. |
Serial Number: 4
Segment Identification Number: 03LEG
Description: This segment is used for providing Brokers Legacy related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id. Value for Segment id is 03LEG |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BROKERLEGACYCODE |
VARCHAR2 |
12 |
Mandatory |
Indicates the legacy code mapped to the broker |
Serial Number: 5
Segment Identification Number: 04PRE
Description: This segment is used for providing Broker Preference related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id. Value for Segment id is 04PRE |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
FEEDTYPE |
VARCHAR2 |
20 |
Mandatory |
Represents the FEED type preference for broker |
FEEDSTRUCT |
VARCHAR2 |
4 |
Mandatory |
Represents the FEED sttucture for the feed type |
FEEDSTARTDATE |
DATE |
10 |
Mandatory |
Indicates the start date of FEED maintenance |
FEEDFREQUENCY |
VARCHAR2 |
20 |
Mandatory |
Indicates the frequency of FEED maintenance |
FEEDFORMAT |
VARCHAR2 |
6 |
Mandatory |
Indicates the format of FEED for broker |
Serial Number: 6
Segment Identification Number: 05ADD
Description: This segment is used for providing Broker Additional Information related details
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id.Value for Segment id is 05ADD |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
OTHERINFOFIELD |
VARCHAR2 |
100 |
Mandatory |
Indicates the additional field name. |
FIELDVALUE |
VARCHAR2 |
60 |
Mandatory |
Indicates the additional field informations. |
Serial Number: 7
Segment Identification Number: 06REL
Description: This segment is used for providing Broker Related Party related details
Data Type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Optional |
Segment Id. Value for Segment id is 06REL |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BROKERCODE |
VARCHAR2 |
12 |
Mandatory |
The code to uniquely identify the broker. Broker code and ruleeffectivedate forms a PRIMARY KEY combination. |
RULEEFFECTIVEDATE |
DATE |
Mandatory |
The date from which the changes are applicable. This along with broker code forms the PRIMARY KEY. |
RPENTITYID |
VARCHAR2 |
12 |
Mandatory |
Indicates the unique identification code for the related party entity associated with the unitholder. |
RPENTITYTYPE |
VARCHAR2 |
1 |
Mandatory |
Indicates the entity type of the unitholder's related party. |
PREFMAILMODE |
VARCHAR2 |
1 |
Optional |
Indicates the preferred mail mode for the related party entity. |
REPORTINGLEVEL |
VARCHAR2 |
1 |
Optional |
Indicates which all reports to be sent to the entities mapped |
REMARKS |
VARCHAR2 |
255 |
Optional |
Indicates the descriptive remarks column for the record. |
APPLYTO |
VARCHAR2 |
12 |
Yes |
Based on the level selected in the Related party Level field , the user can either select fund ID (if he has selected Fund in Related Party Level) or AMC Id (if he has selected AMC Related Party Level) etc. If the user selects ALL in the Related Party Level then the system will default ALL in this field also and the user will not be allowed to edit it. |
APPLYLEVEL |
VARCHAR2 |
3 |
Yes |
Related party level would specify at which level does the user wants to associate the Related Party. The possible LOV values are – ALL, AMC, Fund, Fund Family , Legal entity |
Description |
00UHD |
This segment is used for providing UnitHolder Deal related Information |
Mandatory |
01ULD |
This segment is used for providing UnitHolder Deal Load related Information |
Optional |
02UDL |
This segment is used for providing UnitHolder Deal Derived Load related Information |
Optional |
Serial Number: 1
Segment Identification Number: 00UHD
Description: This segment is used for providing UnitHolder Deal related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID. Value for Segment id is 00UHD |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
Optional |
Upload Mode |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
DEALTRANSACTIONNUMBER |
VARCHAR2 |
16 |
Optional |
UH Deal Transaction Number |
UHIDORCIFNUMBER |
VARCHAR2 |
12 |
Mandatory |
Unit Holder ID / CIF Number |
APPLYATCIFLEVEL |
NUMBER |
1 |
Optional |
Apply At CIF Level.1-Yes,0-No |
APPLYDEALAT |
VARCHAR2 |
1 |
Mandatory |
Apply Deal At.L-Load Level,G-Load Group Level,F-Fund Level,P-Product Level |
STATUS |
VARCHAR2 |
1 |
Mandatory |
Status |
DATE |
7 |
Mandatory |
EFFECTIVEENDDATE |
DATE |
7 |
Optional |
AUTH_STAT |
VARCHAR2 |
1 |
Mandatory |
Authorization Status.A-Authorized,U-Unauthorized. |
LOADGROUPID |
VARCHAR2 |
16 |
Optional |
Load Group Id |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
LOADID |
NUMBER |
5 |
Mandatory |
Load Id |
APPLYRETVALUETOALLSLABS |
NUMBER |
1 |
Optional |
Value for the return values are changed as in the excel only if the value for APPLYRETVALUETOALLSLABS is '1'. |
RETURNVALUE |
VARCHAR2 |
30 |
Optional |
Return Value |
PRODUCTID |
VARCHAR2 |
10 |
Optional |
Product Id |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Maker ID |
MAKER_DT_STAMP |
DATE |
7 |
Optional |
Maker Date Stamp |
POLICYNUMBER |
VARCHAR2 |
16 |
Optional |
Policy Number |
DEALBASEDON |
VARCHAR2 |
1 |
Optional |
Deal Based On |
TAXTYPE |
VARCHAR2 |
1 |
Optional |
Tax Type.D-Directive,I-Instruction |
Serial Number: 2
Segment Identification Number: 01ULD
Description: This segment is used for providing UnitHolder Deal Load related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID. Value for Segment id is 01ULD |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SLABSEQNO |
NUMBER |
5 |
Mandatory |
Slab Sequence Number |
OVERRIDEVALUE |
NUMBER |
30 |
Mandatory |
Override Value |
Serial Number: 3
Segment Identification Number: 02UDL
Description: This segment is used for providing UnitHolder Deal Derived Load related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Mandatory |
Segment ID. Value for Segment id is 02UDL |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
LOADID |
VARCHAR2 |
6 |
Mandatory |
Load Id |
OVERRIDEVALUE |
NUMBER |
30 |
Mandatory |
Override Value |
Description |
00PTN |
This segment is used for providing information related to policy transactions that is to be uploaded into the system |
Mandatory |
01BRK |
This segment is used for providing information related to brokers involved in the policy transactions |
Mandatory |
02FDR |
This segment is used for providing information related to transaction fund ratio that is to be uploaded into the system. |
Mandatory |
03SET |
This segment is used for providing Policy Transaction Settlement related Information |
Optional |
04SFR |
This segment is used for providing Policy Switch Asset Allocation related Information |
Mandatory for Switch transactions |
05FOI |
This segment is used for providing Policy Transaction Load Override related Information |
Optional |
06DFO |
This segment is used for providing Policy Transaction Derived Load Override related Information |
Optional |
Serial Number: 1
Segment Identification Number: 00PTN
Description: This segment is used for providing information related to policy transactions that is to be uploaded into the system
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 00PTN |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Upload Mode |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
POLICYTXNNUMBER |
VARCHAR2 |
16 |
Mandatory |
Policy Transaction Number |
POLICYNUMBER |
VARCHAR2 |
16 |
Mandatory |
Policy Reference Number |
TXNREFERENCENUMBER |
VARCHAR2 |
16 |
Optional |
Transaction Reference Number |
TXNTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
TXNDATE |
DATE |
7 |
Mandatory |
Transaction Date |
TXNINPUTDATE |
DATE |
7 |
Optional |
Transaction Input Date |
TXNAMT |
NUMBER |
15 |
Mandatory |
Transaction Amount |
NETAMT |
NUMBER |
15 |
Optional |
Net Amount |
TXNBASECCY |
VARCHAR2 |
3 |
Optional |
Transaction base currency |
TXNGENFLAG |
NUMBER |
1 |
Optional |
Transaction Generated Flag |
TXNREMARKS |
VARCHAR2 |
255 |
Optional |
Transaction Remarks |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Maker Id |
MAKER_DT_STAMP |
DATE |
7 |
Optional |
Maker date stamp |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
Checker Id |
CHECKER_DT_STAMP |
DATE |
7 |
Optional |
Cheker date stamp |
LASTMODIFIEDUSERID |
VARCHAR2 |
15 |
Optional |
Last Modified User ID |
LASTMODIFIEDUSERDATE |
DATE |
7 |
Optional |
Last Modified User Date |
MOD_NO |
NUMBER |
38 |
Optional |
Modification Number |
AUTH_STAT |
VARCHAR2 |
1 |
Mandatory |
Authorisation Status. A-Authorized,U-Unauthorized |
AGENTCODE |
VARCHAR2 |
12 |
Mandatory |
Agent Code |
BRANCHCODE |
VARCHAR2 |
12 |
Mandatory |
Branch Code |
DRAWEEBANKCODE |
VARCHAR2 |
12 |
Optional |
Drawee Bank Code |
VARCHAR2 |
12 |
Optional |
TRANSFERACCOUNTTYPE |
VARCHAR2 |
1 |
Optional |
Transfer Account Type |
TRANSFERACCOUNTNUMBER |
VARCHAR2 |
20 |
Optional |
Transfer Account Number |
TRANSFERACCOUNTCURRENCY |
VARCHAR2 |
3 |
Optional |
Transfer Account Currency |
PAYMENTMODE |
VARCHAR2 |
1 |
Optional |
Payment Mode |
CHEQUENUMBER |
VARCHAR2 |
16 |
Optional |
Cheque Number |
CHEQUEDATE |
DATE |
7 |
Optional |
Cheque Date |
CLEARINGDATE |
DATE |
7 |
Optional |
Clearing Date |
CLEARINGSTATUS |
VARCHAR2 |
3 |
Optional |
Clearing Status |
PRODUCTID |
VARCHAR2 |
10 |
Optional |
Product ID |
POLICYHOLDERID |
VARCHAR2 |
12 |
Optional |
Policy Holder ID |
POLICYTRANSACTIONMODE |
VARCHAR2 |
1 |
Mandatory |
Policy Transaction Mode.A -Amount,U-Units,P-Percent |
ALLOTTEDFLAG |
NUMBER |
1 |
Optional |
Alloted Flag |
TOPUPINCLUSIVE |
NUMBER |
1 |
Optional |
Top up Inclusive Flag.0 -No,1-Yes |
SYNCFLAG |
NUMBER |
1 |
Optional |
Sync Flag |
ACKNOWLEDGEMENTPRINTED |
NUMBER |
1 |
Optional |
Acknowledgement Printed |
TRANSFERORID |
VARCHAR2 |
12 |
Optional |
Transfer Order ID |
PERCENTAGEAPPLIED |
NUMBER |
5 |
Optional |
Percentage Applied |
OLDPOLICYTXNNUMBER |
VARCHAR2 |
16 |
Optional |
Old Policy Txn number |
NETINVESTIBLEAMOUNT |
NUMBER |
15 |
Optional |
Net Investible Amount |
MODULEID |
VARCHAR2 |
30 |
Mandatory |
Module ID |
ADJUSTMENTTXNTYPE |
VARCHAR2 |
3 |
Optional |
Adjustment Transaction Type |
PORTFOLIOSWITCH |
NUMBER |
1 |
Optional |
Port Folio Switch |
SURRENDERMONEYPAYABLE |
VARCHAR2 |
1 |
Mandatory |
Surrender Money Payable |
FUNDINGPERCENTAGE |
NUMBER |
5 |
Optional |
Funding Percentage |
CANCELLED_PHASEINID |
VARCHAR2 |
16 |
Optional |
Cancelled Phase In ID |
UNITSAPPLIED |
NUMBER |
15 |
Optional |
Units Applied |
INTERESTAMOUNT |
NUMBER |
15 |
Mandatory |
Interest Amount |
DATEALLOTED |
DATE |
7 |
Optional |
Date Alloted |
GROSSAMOUNT |
NUMBER |
22 |
Optional |
Gross Amount |
SWITCHINGROSSAMT |
NUMBER |
15 |
Optional |
Switch In Gross Amount |
SWITCHINNETAMT |
NUMBER |
15 |
Optional |
Switch In Net Amount |
ADJUSTMENTTXN |
NUMBER |
1 |
Optional |
Adjustment Transaction |
IBAN |
VARCHAR2 |
40 |
Optional |
Internation Bank Account Number |
SOURCEID |
VARCHAR2 |
6 |
Optional |
Source ID |
EXCHANGERATEAPPLIED |
NUMBER |
24 |
Optional |
Exchange Rate Applied |
AMOUNTAPPLIED |
NUMBER |
30 |
Optional |
Amount Applied |
BALANCETRANSFER |
NUMBER |
1 |
Optional |
Balance transfer |
VARCHAR2 |
1 |
Optional |
Override Exchange Rate |
INTAMTINTXNCCY |
NUMBER |
30 |
Optional |
Initial amount in Transaction currency |
INCLUDE_INTEREST_IN_INVESTMENT |
VARCHAR2 |
1 |
Optional |
Include Interest In Investment |
FXDEALDATE |
DATE |
7 |
Optional |
FX Deal Date |
FXVALUEDATE |
DATE |
7 |
Optional |
FX Value Date |
VARCHAR2 |
1 |
Optional |
Exchange Rate Status |
Serial Number: 2
Description: This segment is used for providing information related to brokers involved in the policy transactions
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 01BRK |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
POLICYTXNNUMBER |
VARCHAR2 |
16 |
Mandatory |
BROKERCODE |
VARCHAR2 |
9 |
Optional |
Broker Code |
SPLITPERCENTAGE |
NUMBER |
5 |
Mandatory |
Split Percentage |
Serial Number: 3
Segment Identification Number: 02FDR
Description: This segment is used for providing information related to transaction fund ratio that is to be uploaded into the system.
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 02FDR |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
POLICYTXNNUMBER |
VARCHAR2 |
16 |
Mandatory |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Fund ID |
RATIO |
NUMBER |
15 |
Optional |
Ratio |
TXNAMOUNT |
NUMBER |
15 |
Mandatory |
UNITSAPPLIED |
NUMBER |
15 |
Optional |
Units Applied |
WAC |
NUMBER |
15 |
Optional |
Weighted Average Cost |
AUTOCLEARPROVISIONALBALANCE |
VARCHAR2 |
1 |
Mandatory |
Auto Clear Provisional balance |
AUTOCLEARREINVESTMENTS |
VARCHAR2 |
1 |
Mandatory |
Auto Clear Reinvestments |
TXNAMOUNT_IN_TXNCCY |
NUMBER |
30 |
Optional |
Transaction Amount in Transaction Currency |
TRANSACTIONCURRENCY |
VARCHAR2 |
3 |
Optional |
NUMBER |
15 |
Optional |
VARCHAR2 |
1 |
Optional |
SOURCEID |
VARCHAR2 |
6 |
Optional |
Source ID |
FXDEALDATE |
DATE |
7 |
Optional |
FX Deal Date |
FXVALUEDATE |
DATE |
7 |
Optional |
FX Value Date |
Serial Number: 4
Segment Identification Number: 03SET
Description: This segment is used for providing Policy Transaction Settlement related Information.
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 03SET |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
POLICYTXNNUMBER |
VARCHAR2 |
16 |
Mandatory |
PAYMENTTYPE |
VARCHAR2 |
1 |
Optional |
Payment Type.Self-S,Product -P,Third Party -T,Beneficiary -B |
PAYMENTMODE |
VARCHAR2 |
1 |
Optional |
Payment Mode ,Cash -C,Cheque -Q,Demand Draft -D,Money Transfer -T |
PAYMENTENTITY |
VARCHAR2 |
12 |
Optional |
Payment Entity |
DRAWEEBANKCODE |
VARCHAR2 |
12 |
Optional |
Drawee Bank code |
TRANSFERBRANCHCODE |
VARCHAR2 |
12 |
Optional |
Transfer Branch Code |
VARCHAR2 |
1 |
Optional |
VARCHAR2 |
20 |
Optional |
VARCHAR2 |
3 |
Optional |
CHEQUENUMBER |
VARCHAR2 |
16 |
Optional |
Cheque Number |
CHEQUEDATE |
VARCHAR2 |
11 |
Optional |
Cheque Date |
CLEARINGDATE |
VARCHAR2 |
11 |
Optional |
Clearing Date |
CLEARINGSTATUS |
VARCHAR2 |
3 |
Optional |
Clearing Status |
RATIO |
NUMBER |
5 |
Optional |
Ratio |
AUTH_STAT |
VARCHAR2 |
1 |
Mandatory |
IDENTIFICATIONNUMBER |
VARCHAR2 |
50 |
Mandatory |
CONTACTNAME |
VARCHAR2 |
100 |
Optional |
Contact Name |
ADDRESSLINE1 |
VARCHAR2 |
105
Mandatory |
Address Line 1 |
ADDRESSLINE2 |
VARCHAR2 |
105 |
Mandatory |
Address Line 2 |
TRANSFERREFNUMBER |
VARCHAR2 |
16 |
Optional |
Transfer Reference Number |
IBAN |
VARCHAR2 |
40 |
Optional |
International Bank Account Number |
FXDEALDATE |
DATE |
7 |
Optional |
FX Deal Date |
FXVALUEDATE |
DATE |
7 |
Optional |
FX Value Date |
NUMBER |
15 |
Optional |
VARCHAR2 |
1 |
Optional |
SOURCEID |
VARCHAR2 |
6 |
Optional |
Source ID |
PAYMENT_CURRENCY |
VARCHAR2 |
3 |
Optional |
Payment Currency |
PAYMENT_DATE |
DATE |
7 |
Optional |
Payment Date |
PAYMENT_AMOUNT |
NUMBER |
30 |
Optional |
Payment amount |
VARCHAR2 |
1 |
Optional |
INTERESTRATE |
NUMBER |
30 |
Optional |
Interest Rate |
INTERESTAMOUNT |
NUMBER |
30 |
Optional |
Interest Amount |
NOOFDAYS |
NUMBER |
30 |
Optional |
No of Days |
BASISDAYS |
NUMBER |
30 |
Optional |
Basis days |
PAYMENT_AMT_IN_TXNCCY |
NUMBER |
30 |
Optional |
Payment amount in Transaction currency |
INTEREST_AMT_IN_TXNCCY |
NUMBER |
30 |
Optional |
Interest Amount in Transaction currency |
SEQ_NO |
NUMBER |
30 |
Optional |
Sequence Number |
TRANSFERACCOUNTHOLDERNAME |
VARCHAR2 |
100 |
Optional |
Transfer Account holder Name |
Serial Number: 5
Segment Identification Number: 04SFR
Segment Mandatory / Optional: Mandatory for Switch Transactions
Field Name (as expected in the file) |
Data type |
Length |
Characteristics/rules |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 04SFR |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
POLICYTXNNUMBER |
VARCHAR2 |
16 |
Mandatory |
TOFUNDID |
VARCHAR2 |
6 |
Mandatory |
To Fund ID |
RATIO |
NUMBER |
9 |
Optional |
Ratio |
Serial Number: 6
Segment Identification Number: 05FOI
Description: This segment is used for providing Policy Transaction Load Override related Information.
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 05FOI |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
POLICYNUMBER |
VARCHAR2 |
16 |
Optional |
Policy Number |
TRANSACTIONNUMBER |
VARCHAR2 |
16 |
Optional |
TRANSACTIONDATE |
DATE |
7 |
Mandatory |
Transaction Date |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Fund ID |
POLICYHOLDERID |
VARCHAR2 |
12 |
Optional |
Policy Holder ID |
LOADID |
NUMBER |
5 |
Optional |
Load ID |
CHANGETYPE |
VARCHAR2 |
1 |
Optional |
Change Type |
CHANGEVALUE |
NUMBER |
15 |
Optional |
Change Value |
GROUPID |
VARCHAR2 |
6 |
Optional |
Group ID |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
Auth Stat |
TXNTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
REFTYPE |
VARCHAR2 |
2 |
Optional |
Ref Type |
Serial Number: 7
Segment Identification Number: 06DFO
Description: This segment is used for providing Policy Transaction Derived Load Override related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Optional |
Segment ID - 06DFO |
SEQUENCENUMBER |
NUMBER |
10 |
Optional |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Optional |
Process ID |
TRANSACTIONNUMBER |
VARCHAR2 |
16 |
Optional |
TRANSACTIONDATE |
DATE |
7 |
Optional |
Transaction Date |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
POLICYHOLDERID |
VARCHAR2 |
12 |
Optional |
Policy Holder ID |
DERIVEDLOADID |
VARCHAR2 |
6 |
Optional |
Derived Load ID |
PARENTLOADID |
NUMBER |
5 |
Optional |
Parent Load ID |
CHANGETYPE |
VARCHAR2 |
1 |
Optional |
Change Type |
CHANGEVALUE |
NUMBER |
5 |
Optional |
Change Value |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
Authorisation Status |
TXNTYPE |
VARCHAR2 |
2 |
Optional |
Transaction Type |
REFTYPE |
VARCHAR2 |
2 |
Optional |
Ref Type |
Description |
00CON |
This segment is used for providing Transaction related Information |
Mandatory |
01SET |
This segment is used for providing Transaction Settlement related Information |
Optional |
02KYC |
This segment is used for providing KYC Transaction related Information |
Optional |
Serial Number: 1
Segment Identification Number: 00CON
Description: This segment is used for providing Transaction related Information
Data type |
Length |
Mandatory/ Optional |
Values |
SEGMENTID |
VARCHAR2 |
5 |
Mandatory |
Segment Identifier (00CON) |
TXNSERIALNUMBER |
NUMBER |
10 |
Mandatory |
Transaction Serial Number |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCAHR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
REFERENCENUMBER |
VARCHAR2 |
16 |
Optional |
Reference Number |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Upload Mode |
TRANSACTIONDATE |
DATE |
Optional |
Transaction Date |
UNITHOLDERID |
VARCHAR2 |
60 |
Mandatory |
Unitholderid |
FUNDID |
VARCHAR2 |
25 |
Mandatory |
Fund ID |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
TRANSACTIONSUBTYPE |
VARCHAR2 |
1 |
Mandatory |
Transaction Type |
TOUNITHOLDERID |
VARCHAR2 |
60 |
Optional |
For Transfer, tounitholderid is mandatory |
TOFUNDID |
VARCHAR2 |
25 |
Optional |
For normal switch, tofundid is mandatory |
VARCHAR2 |
3 |
Optional |
TRANSACTIONMODE |
VARCHAR2 |
1 |
Mandatory |
Transaction Mode: A-Amount U-Units P-Percentage |
UNITSAPPLIED |
NUMBER |
27 |
Optional |
When Transaction Mode is chosen as Units then this fields is mandatory |
PERCENTAPPLIED |
NUMBER |
5 |
Optional |
When Transaction Mode is chosen as Percentage then this fields is mandatory |
AMOUNT |
NUMBER |
30 |
Optional |
When Transaction Mode is chosen as Amount then this fields is mandatory |
SUBPAYMENTMODE |
VARCHAR2 |
2 |
Optional |
Valid Sub Payment mode of selected Payment mode |
SUBSCRIPTIONFUNDID |
VARCHAR2 |
6 |
Optional |
For Switch Transaction Subscription Fund ID is Mandatory
KIIDRECEIVED |
VARCHAR2 |
1 |
Optional |
KIID Received-Mandatory Only For UCITS Fund. |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Maker ID |
MAKER_DT_STAMP |
DATE |
Optional |
Maker DT Stamp |
KYCCHASINGDATE |
DATE |
Optional |
KYC Chasing Date |
KYCRECEIVED |
NUMBER |
1 |
Optional |
KYC Received flag |
Serial Number: 2
Segment Identification Number: 01SET
Description: This segment is used for providing Transaction Settlement related Information.
Column Name |
Data Type |
Mandatory |
Description |
SEGMENT ID |
VARCHAR2(5) |
Yes |
Segment Identifier(01SET) |
TXNSERIALNUMBER |
NUMBER(10) |
Yes |
SEQUENCENUMBER |
NUMBER(10) |
Yes |
Sequence Number |
PROCESSID |
VARCHAR2(50) |
Yes |
Process ID |
BULKCLIENTCODE |
VARCHAR2(12) |
Yes |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2(255) |
Yes |
Import File Name |
AMCID |
VARCHAR2(12) |
Yes |
AMC ID |
TRANSACTIONNUMBER |
VARCHAR2(16) |
No |
PRODUCTID |
VARCHAR2(10) |
No |
Product ID |
POLICYNUMBER |
VARCHAR2(16) |
No |
Policy Number |
SYSREFERENCENUMBER |
VARCHAR2(25) |
No |
Sys Reference Number |
UNITHOLDERID |
VARCHAR2(12) |
Yes |
Unitholder Id |
PAYMENTREFERENCENUMBER |
VARCHAR2(50) |
No |
Payment Reference Number |
PAYMENTMODE |
VARCHAR2(2) |
No |
Payment Mode.C-Cash,Q-Cheque,T-Transfer,R-Card,M-Multipayment,D-Draft. |
SUBPAYMENTMODE |
VARCHAR2(2) |
No |
Sub Payment Mode.T-Money Transfer,Q-Cheque,R-Credit Card,D-Demand Draft,F-Against Payment,I-In Kind Payment,AT-Advice,BQ-Broker Cheque,CQ-Cashier cheque,DR-Debit Card,DT-Direct Debit,FQ-Foreign Cheque,GQ-Government Cheque,IQ-Other Institution Cheque,LQ-Local Cheque,OQ-Out Of Town Cheque,PD-Pay Order,PQ-Payroll Deduction,RQ-Reserve Bank Cheque,TT-Telegraphic Transfer,WT-Wire Transfer. |
PAYMENTCURRENCY |
VARCHAR2(3) |
No |
Payment Currency |
PAYMENTDATE |
DATE |
No |
Payment Date |
PAYMENTAMOUNT |
NUMBER(30,12) |
No |
Payment Amount |
BANKCHARGES |
NUMBER(30,12) |
No |
Bank Charges |
PAYMENTCHARGES |
NUMBER(30,12) |
No |
Payment Charges |
EXCHANGERATESOURCE |
VARCHAR2(6) |
No |
Exchange Rate Source |
EXCHANGERATE |
NUMBER(15,9) |
No |
F X Rate |
PAYMENTFBCTXNAMOUNT |
NUMBER(30,12) |
No |
FBC Amount |
PAYMENTALTERNATEAMOUNT |
NUMBER(30,12) |
No |
Payment Alternate Amount |
SETTLEMENTDUEDATE |
DATE |
No |
Settlement Due Date |
PAIDDATE |
DATE |
No |
Paid Date |
AUTOSETTLEMENT |
NUMBER(1) |
No |
Auto Settle.1-Yes,0-No |
PAYMENTSTATUS |
VARCHAR2(1) |
No |
Payment Status |
CLEARINGSTATUS |
VARCHAR2(5) |
No |
Clearing Status |
PAID |
NUMBER(1) |
No |
Paid |
SETTLEMENTMETHOD |
VARCHAR2(5) |
No |
Settlement Method |
SETTLEMENTSTATUS |
VARCHAR2(2) |
No |
Settlement Status |
SETTLEMENTAT |
VARCHAR2(3) |
No |
Settlement At |
CHEQUEDATE |
DATE |
No |
Cheque Date |
CHEQUENUMBER |
VARCHAR2(16) |
No |
Cheque Number |
CHEQUECURRENCY |
VARCHAR2(3) |
No |
Cheque Currency |
CHEQUEAMOUNT |
NUMBER(30,12) |
No |
Cheque Amount |
DRAWEEBANKCODE |
VARCHAR2(12) |
No |
Drawee Bank Code |
DRAWEEBRANCHNAME |
VARCHAR2(20) |
No |
Drawee Branch Name |
PAYMENTREMARKS |
VARCHAR2(255) |
No |
Payment Remarks |
PAYMENTTYPE |
VARCHAR2(2) |
No |
Payment Type.S-Self, T-Third Party, B-Broker, R-Retained, AP-Advanced Payment, A-Absorbed/Paid back |
THIRDPARTYADDRESS |
VARCHAR2(255) |
No |
Third Party Address |
THIRDPARTYADDRESSLINE1 |
VARCHAR2(80) |
Yes |
Third Party Address line 1 |
THIRDPARTYADDRESSLINE2 |
VARCHAR2(80) |
Yes |
Third Party Address line 2 |
THIRDPARTYADDRESSLINE3 |
VARCHAR2(80) |
Yes |
Third Party Address line 3 |
THIRDPARTYADDRESSLINE4 |
VARCHAR2(80) |
Yes |
Third Party Address line 4 |
THIRDPARTYBICCODE |
VARCHAR2(12) |
No |
Third Party BIC Code |
THIRDPARTYCOUNTRYCODE |
VARCHAR2(3) |
No |
Third Party Country |
THIRDPARTYPAYMENTREFERENCE |
VARCHAR2(255) |
No |
Third Party Reference |
THIRDPARTYSTATE |
VARCHAR2(20) |
No |
Third Party State |
THIRDPARTYUSSTATE |
NUMBER(1) |
No |
Third Party US State |
THIRDPARTYZIPCODE |
VARCHAR2(10) |
No |
Third Party Zip Code |
VARCHAR2(3) |
No |
VARCHAR2(100) |
No |
Transfer Account Holder Name |
VARCHAR2(20) |
No |
VARCHAR2(1) |
Yes |
VARCHAR2(12) |
No |
TRANSFERREFERENCENUMBER |
VARCHAR2(20) |
No |
CREDITCARDREFNO |
VARCHAR2(16) |
No |
Credit Card Reference Number |
INKINDPAYMENTDETAILS |
VARCHAR2(255) |
No |
In Kind Payment Details |
PAYMENTADDRESSDETAILS |
VARCHAR2(255) |
No |
Payment Address Details |
OLDPAYMENTREFERENCENO |
VARCHAR2(25) |
No |
Old Payment Reference Number |
UHBICCODE |
VARCHAR2(24) |
No |
UH BIC Code |
SWIFTFORMAT |
VARCHAR2(6) |
No |
Swift Format.MT103-MT103,MT202-MT202 |
BANKCHARGED |
VARCHAR2(12) |
No |
Bank Charged.Beneficiary-Beneficiary,Remitter-Remitter,Share-Share |
BENEFICIARY |
VARCHAR2(35) |
No |
Beneficiary |
BENEFICIARYADD1 |
VARCHAR2(105) |
Yes |
Beneficiary Address1 |
BENEFICIARYADD2 |
VARCHAR2(105) |
Yes |
Beneficiary Address2 |
BENEFICIARYADD3 |
VARCHAR2(105) |
Yes |
Beneficiary Address3 |
VARCHAR2(24) |
No |
Beneficiary BIC Code |
BENEFICIARYACCTNO |
VARCHAR2(34) |
No |
Beneficiary Account Number |
BENEFICIARYCODE |
VARCHAR2(24) |
No |
Beneficiary Code |
BENEFICIARYINFO |
VARCHAR2(100) |
No |
Beneficiary Information |
INTERMEDIARY |
VARCHAR2(35) |
No |
Intermediary |
INTERMEDIARYADD1 |
VARCHAR2(35) |
No |
Intermediary Address1 |
INTERMEDIARYADD2 |
VARCHAR2(35) |
No |
Intermediary Address2 |
INTERMEDIARYADD3 |
VARCHAR2(35) |
No |
Intermediary Address3 |
VARCHAR2(24) |
No |
Intermediary BIC Code |
VARCHAR2(24) |
No |
Intermediary Account No |
INTERMEDIARYCODE |
VARCHAR2(24) |
No |
Intermediary Code |
INTERMEDIARYINFO |
VARCHAR2(100) |
No |
Intermediary Info |
FURTHERCREDITNAME |
VARCHAR2(35) |
No |
Further Credit Name |
VARCHAR2(35) |
No |
Further Credit Account Number |
REFERENCE1 |
VARCHAR2(35) |
No |
Reference1 |
REFERENCE2 |
VARCHAR2(35) |
No |
Reference2 |
ENTITYID |
VARCHAR2(12) |
No |
Entity ID |
ENTITYTYPE |
VARCHAR2(1) |
No |
Entity Type |
IBAN |
VARCHAR2(40) |
No |
IBAN |
BENEFICIARYIBAN |
VARCHAR2(40) |
No |
Beneficiary IBAN |
INTERMEDIARYIBAN |
VARCHAR2(40) |
No |
Intermediary IBAN |
BENEFICIARYID |
VARCHAR2(12) |
No |
Beneficiary ID |
BENEFICIARYPERCENTAGE |
NUMBER(5,2) |
No |
Beneficiary Percentage |
Serial Number: 3
Segment Identification Number: 02KYC
Description: This segment is used for providing KYC Transaction related Information.
Column Name |
Data Type |
Mandatory |
Description |
SEGMENT ID |
VARCHAR2(5) |
Yes |
Segment Identifier(02KYC) |
TXNSERIALNUMBER |
NUMBER(10) |
Yes |
SEQUENCENUMBER |
NUMBER(10) |
Yes |
Sequence Number |
PROCESSID |
VARCHAR2(50) |
Yes |
Process ID |
BULKCLIENTCODE |
VARCHAR2(12) |
Yes |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2(255) |
Yes |
Import File Name |
AMCID |
VARCHAR2(12) |
No |
AMC ID |
TRANSACTIONNUMBER |
VARCHAR2(16) |
Yes |
REQUESTED |
VARCHAR2(1) |
No |
Requested.On-Y,Off-N |
DOCUMENTDESCRIPTION |
VARCHAR2(255) |
No |
Requirement |
RECEIVED |
VARCHAR2(1) |
No |
Received.On-Y,Off-N |
RECEIVEDDATE |
DATE |
No |
Received Date |
TAXDOCUMENT |
NUMBER(1) |
No |
Tax Document.1-Yes,0-No |
Data type |
Length |
Values |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
YEAR |
NUMBER |
4 |
Mandatory |
Year |
JAN |
VARCHAR2 |
100 |
Optional |
Holiday Bits For Jan.eg) 00000000000000000011100000. |
FEB |
VARCHAR2 |
100 |
Optional |
Holiday Bits For Febrauary |
MAR |
VARCHAR2 |
100 |
Optional |
Holiday Bits For March |
APR |
VARCHAR2 |
100 |
Optional |
Holiday Bits For April |
MAY |
VARCHAR2 |
100 |
Optional |
Holiday Bits For May |
JUN |
VARCHAR2 |
100 |
Optional |
Holiday Bits For June |
JUL |
VARCHAR2 |
100 |
Optional |
Holiday Bits For July |
AUG |
VARCHAR2 |
100 |
Optional |
Holiday Bits For August |
SEP |
VARCHAR2 |
100 |
Optional |
Holiday Bits For September |
OCT |
VARCHAR2 |
100 |
Optional |
Holiday Bits For October |
NOV |
VARCHAR2 |
100 |
Optional |
Holiday Bits For November |
DEC |
VARCHAR2 |
100 |
Optional |
Holiday Bits For December |
MAKER_ID |
VARCHAR2 |
15 |
Optional |
MakerId |
MAKER_DT_STAMP |
DATE |
15 |
Optional |
Maker Date Stamp |
AUTH_STAT |
VARCHAR2 |
1 |
Mandatory |
Authorisation Status. A-Authorized,U-UnAuthorized |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
Checker Id |
CHECKER_DT_STAMP |
DATE |
10 |
Optional |
Checker Date Stamp |
ENTITYTYPE |
VARCHAR2 |
1 |
Mandatory |
Calendar Type |
ENTITYID |
VARCHAR2 |
12 |
Mandatory |
Calendar Type |
Field Name |
Data Type |
Field Length |
Mandatory? |
Characteristics/Rules |
Values |
SEQUENCENUMBER |
Number |
10 |
Yes |
System generated sequence number of records in the file |
PROCESSID |
String |
50 |
Yes |
The Process ID, along with the system generated sequence number, identifies the uploaded record uniquely. Each file must have a unique Process ID. This should be same for all records within a file. |
BULKCLIENTCODE |
String |
12 |
Yes |
The Code of the Bulk Client |
IMPORTFILENAME |
String |
255 |
Yes |
Name of the file being uploaded should be specified. Each file must have a unique name. |
UPLOADMODE |
String |
1 |
Yes |
‘N’ for New unit holder uploads and ‘I’ for Incremental change. |
FUNDID |
Alphanumeric |
6 |
Yes |
ID of the fund involved in the transaction. A valid fund id maintained in the system. |
UNITHOLDERID |
String |
12 |
Yes |
The unit holder ID available in FCIS. |
EFFECTIVEDATE |
Date |
10 |
No |
Effective Date |
G2UNITS |
Number |
30,12 |
No |
Adjustable Units |
AUTH_STAT |
Varchar2 |
1 |
Yes |
Must be ‘A’ |
MAKER_ID |
Varchar2 |
15 |
Yes |
Maker ID |
MAKER_DT_STAMP |
Date |
10 |
Yes |
Maker Date |
CHECKER_ID |
Varchar2 |
15 |
Yes |
Checker ID |
CHECKER_DT_STAMP |
Date |
10 |
Yes |
Checker Date |
Field Name |
Data Type |
Field Length |
Mandatory? |
Values |
SOURCEID |
VARCHAR2 |
6 |
YES |
Source maintained in the system |
REFCURRENCY |
VARCHAR2 |
3 |
YES |
Base Currency of the Source |
PAIRCURRENCY |
VARCHAR2 |
3 |
YES |
Pair Currency for the exchange rate would be made available |
FXDEALDATE |
DATE |
10 |
YES |
Should be application date |
Effective date for the Exchange rate |
FXVALUEDATE |
DATE |
10 |
YES |
Should be greater than or equal to FXDEALDATE |
Value date for Forward Rates |
BUYRATE |
NUMBER |
15 |
YES |
Buy Rate for the mentioned currencies |
SELLRATE |
NUMBER |
15 |
YES |
Sell Rate for the mentioned currencies |
EXCHRATEFORREPORT |
NUMBER |
1 |
NO |
Flag to set whether the maintained FX Rate is used for Reporting |
USERID |
VARCHAR2 |
15 |
YES |
Maker Id of the Exchange Rate |
IMPORTSTATUS |
VARCHAR2 |
1 |
NO |
Status of the Import |
ERRORDESC |
VARCHAR2 |
255 |
NO |
Error description |
AUTH_STAT |
VARCHAR2 |
1 |
NO |
Authorization Status. A- Authorised. U -Unauthorised |
PROCESSID |
VARCHAR2 |
50 |
NO |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
NO |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255
NO |
Import File Name |
AMCID |
VARCHAR2 |
12 |
NO |
AMC ID |
SERIALNUMBER |
VARCHAR2 |
16 |
NO |
Serial Number |
MAKER_ID |
VARCHAR2 |
15 |
NO |
MAKER_DT_STAMP |
DATE |
7 |
NO |
CHECKER_ID |
VARCHAR2 |
15 |
NO |
CHECKER_DT_STAMP |
DATE |
7 |
NO |
SEQUENCENUMBER |
VARCHAR2 |
10 |
NO |
Sequence Number |
UPLOADMODE |
VARCHAR2 |
1 |
NO |
Data type |
Length |
Values |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Maker of the record |
MAKER_DT_STAMP |
DATE |
10 |
Optional |
Date Time stamp on which the Maker created the record |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
Authorizer of the record |
CHECKER_DT_STAMP |
DATE |
10 |
Optional |
Date Time stamp on which the record was authorised |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
MODULEID |
VARCHAR2 |
30 |
Mandatory |
Module ID of the Authorized representative |
AUTHREPREFNO |
VARCHAR2 |
12 |
Optional |
Authorized Representative Reference Number |
AUTHREPID |
VARCHAR2 |
12 |
Optional |
Authorized Representative ID |
AUTHREPADDRESS |
VARCHAR2 |
255 |
Optional |
Authorized Representative Address |
AUTHREPZIPCODE |
VARCHAR2 |
10 |
Optional |
Authorized Representative ZIP Code |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
Authorisation Status. A- Authorise, U - unauthorised |
AGENTCODE |
VARCHAR2 |
12 |
Optional |
Agent Code |
BRANCHCODE |
VARCHAR2 |
12 |
Optional |
Branch Code |
AUTHREPSIGNATURE |
VARCHAR2 |
255 |
Optional |
Authorized Representative Signature |
IMAGEAVAILABLE |
NUMBER |
1 |
Optional |
Image available or Not |
AUTHREPTITLE |
VARCHAR2 |
15 |
Optional |
Authorized Representative Title |
AUTHREPSTATE |
VARCHAR2 |
20 |
Optional |
Authorized Representative State |
AUTHREPUSSTATE |
NUMBER |
1 |
Optional |
Authorized Representative US State |
AUTHREPCITY |
VARCHAR2 |
10 |
Optional |
Authorized Representative City |
FIRSTNAME |
VARCHAR2 |
105 |
Optional |
First Name |
MIDDLENAME |
VARCHAR2 |
105 |
Optional |
Middle Name |
LASTNAME |
VARCHAR2 |
105 |
Optional |
Last Name |
AUTHREPCOUNTRY |
VARCHAR2 |
3 |
Mandatory |
Country of the authorized representative |
NATIONALITY |
VARCHAR2 |
3 |
Mandatory |
Nationality of the authorized representative |
COUNTRYOFBIRTH |
VARCHAR2 |
3 |
Mandatory |
Country of birth of the authorized representative |
COUNTRYOFDOMICILE |
VARCHAR2 |
3 |
Mandatory |
Country of domicile of the authorized representative |
TELEPHONE1 |
VARCHAR2 |
60 |
Mandatory |
Telephone 1 of the authorized representative |
TELEPHONE2 |
VARCHAR2 |
60 |
Mandatory |
Telephone 2 of the authorized representative |
CELLPHONENUMBER |
VARCHAR2 |
60 |
Mandatory |
Cellphone number of the authorized representative |
VARCHAR2 |
10 |
Mandatory |
International Dialling code of phone number 1 |
VARCHAR2 |
10 |
Mandatory |
International Dialling code of phone number 2 |
VARCHAR2 |
10 |
Mandatory |
International Dialling code of cell phone number |
AUTHREPADDRESS2 |
VARCHAR2 |
255 |
Mandatory |
Address of the authorized representative |
AUTHREPCATEGORY |
VARCHAR2 |
1 |
Mandatory |
Category of the authorized representative. |
REMARKS |
VARCHAR2 |
255 |
Optional |
Remarks |
Segment Identification Number |
Description |
Segment Mandatory / Optional? |
00EIM |
This segment is used for providing Entity Maintenance related Information |
Mandatory |
01EBD |
This segment is used for providing Entity Bank related Information |
Mandatory |
02ECI |
This segment is used for providing Entity Contact Information related Information |
Mandatory |
03EBD |
This segment is used for providing Entity Broker Definition related Information |
Optional |
04ERP |
This segment is used for providing Related parties Information |
Optional |
05ADD |
This segment is used for providing Additional Information details |
Optional |
06SWF |
This segment is used for providing Swift Message related details |
Optional |
Serial Number: 1
Segment Identification Number: 00EIM
Description: This segment is used for providing Entity Maintenance related Information
Segment Mandatory/ Optional: Mandatory
Data type |
Length |
Mandatory/Optional |
Values |
SEGMENTID |
VARCHAR2 |
16 |
Mandatory |
Segment Id. Value for Segment id is 00EIM |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Optional |
Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
ENTITYID |
VARCHAR2 |
12 |
Mandatory |
Entity ID |
PARENTENTITYFLAG |
NUMBER |
1 |
Optional |
Parent Entity Flag |
ENTITYNAME |
VARCHAR2 |
60 |
Mandatory |
Entity Name |
ENTITYTOBEDELETED |
VARCHAR2 |
12 |
Optional |
Entity To be Deleted |
ENTITYTYPE |
VARCHAR2 |
1 |
Optional |
Entity Type |
PARENTENTITY |
VARCHAR2 |
12 |
Optional |
Parent Entity |
EFFECTIVEDATE |
DATE |
10 |
Optional |
Effective Date |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
MAKER_DT_STAMP |
DATE |
10 |
Optional |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
CHECKER_DT_STAMP |
DATE |
10 |
Optional |
RECORDLINK |
NUMBER |
10 |
Optional |
Record Link |
NEWENTITYNAME |
VARCHAR2 |
60 |
Optional |
New Entity Name |
NEWENTITYID |
VARCHAR2 |
12 |
Optional |
New Entity ID |
ENTITYBASECURRENCY |
VARCHAR2 |
3 |
Optional |
Entity Base Currency |
ADDITIONALINFO1 |
VARCHAR2 |
60 |
Optional |
Additional Information 1 |
ADDITIONALINFO2 |
VARCHAR2 |
60 |
Optional |
Additional Information 2 |
ADDITIONALINFO3 |
VARCHAR2 |
60 |
Optional |
Additional Information 3 |
ADDITIONALINFO4 |
VARCHAR2 |
60 |
Optional |
Additional Information 4 |
ADDITIONALINFO5 |
VARCHAR2 |
60 |
Optional |
Additional Information 5 |
ADDITIONALINFO6 |
VARCHAR2 |
60 |
Optional |
Additional Information 6 |
ADDITIONALINFO7 |
VARCHAR2 |
60 |
Optional |
Additional Information 7 |
ADDITIONALINFO8 |
VARCHAR2 |
60 |
Optional |
Additional Information 8 |
ADDITIONALINFO9 |
VARCHAR2 |
60 |
Optional |
Additional Information 9 |
ADDITIONALINFO10 |
VARCHAR2 |
60 |
Optional |
Additional Information 10 |
ADDITIONALINFO11 |
VARCHAR2 |
60 |
Optional |
Additional Information 11 |
ADDITIONALINFO12 |
VARCHAR2 |
60 |
Optional |
Additional Information 12 |
ADDITIONALINFO13 |
VARCHAR2 |
60 |
Optional |
Additional Information 13 |
ADDITIONALINFO14 |
VARCHAR2 |
60 |
Optional |
Additional Information 14 |
ADDITIONALINFO15 |
VARCHAR2 |
60 |
Optional |
Additional Information 15 |
ADDITIONALINFO16 |
VARCHAR2 |
60 |
Optional |
Additional Information 16 |
ADDITIONALINFO17 |
VARCHAR2 |
60 |
Optional |
Additional Information 17 |
ADDITIONALINFO18 |
VARCHAR2 |
60 |
Optional |
Additional Information 18 |
ADDITIONALINFO19 |
VARCHAR2 |
60 |
Optional |
Additional Information 19 |
ADDITIONALINFO20 |
VARCHAR2 |
60 |
Optional |
Additional Information 20 |
ADDITIONALINFO21 |
VARCHAR2 |
60 |
Optional |
Additional Information 21 |
ADDITIONALINFO22 |
VARCHAR2 |
60 |
Optional |
Additional Information 22 |
ADDITIONALINFO23 |
VARCHAR2 |
60 |
Optional |
Additional Information 23 |
ADDITIONALINFO24 |
VARCHAR2 |
60 |
Optional |
Additional Information 24 |
ADDITIONALINFO25 |
VARCHAR2 |
60 |
Optional |
Additional Information 25 |
ADDITIONALINFO26 |
VARCHAR2 |
60 |
Optional |
Additional Information 26 |
ADDITIONALINFO27 |
VARCHAR2 |
60 |
Optional |
Additional Information 27 |
ADDITIONALINFO28 |
VARCHAR2 |
60 |
Optional |
Additional Information 28 |
ADDITIONALINFO29 |
VARCHAR2 |
60 |
Optional |
Additional Information 29 |
ADDITIONALINFO30 |
VARCHAR2 |
60 |
Optional |
Additional Information 30 |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
Authorisation Status. A - Authorised. U - Unauthorised |
UNIQUERECORDNUMBER |
NUMBER |
5 |
Optional |
Unique Record Number |
MARKEDFORREIMP |
VARCHAR2 |
1 |
Optional |
Marked for Re-Import |
ACCOUNTTYPES |
VARCHAR2 |
1000 |
Optional |
Account Types |
ENTITYCATEGORYTYPE |
VARCHAR2 |
1 |
Optional |
Entity Category Type. I - Individual, C - Corporate |
ENTITYCATEGORY |
VARCHAR2 |
2 |
Optional |
Entity Category |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
SWITCHINGLOGIC |
VARCHAR2 |
12 |
Optional |
Switching Logic |
UHGENERATIONLOGIC |
NUMBER |
1 |
Optional |
Unit Holder Generation Logic. 1 - AGT, 2 - SERIAL&AMC/DIST&CHK, 3- SERIAL, 4 - No Logic, 5- Reference Number, 6 - AJF Generation Logic, 7 - Ctry(1)&Busi(1)&FMG/DIST&A-Z(1)&Num(5) |
NATUREOFBUSINESS |
VARCHAR2 |
1 |
Optional |
Nature of Business. U - UnitTrust, L - LifeProducts, B - Both |
SECTION |
VARCHAR2 |
40 |
Optional |
Section |
ENTITYSUBTYPE |
VARCHAR2 |
3 |
Optional |
Module/Agent Type |
CROSSBRANCHING |
NUMBER |
1 |
Optional |
Cross Branching Allowed ? 1 - Yes, 0 - No |
FUNDSPOWERINSTALLED |
NUMBER |
1 |
Optional |
FLEXCUBE-IS Installation? 1 - Yes, 0 - No |
CUSTOMERINTERFACEKEY |
VARCHAR2 |
1 |
Optional |
Customer Interface Key. C - Customer, A - Account |
ONLINEINTERFACE |
NUMBER |
1 |
Optional |
Online Interface. 1 - Yes, 0 - No |
WEEKENDBITS |
VARCHAR2 |
7 |
Optional |
Weekend Bits |
AUTHORIZEDSIGNATORY |
VARCHAR2 |
70 |
Optional |
Authorized Signatory |
MOD_NO |
NUMBER |
5 |
Optional |
Indicates the max number of times the record is modified |
ALTLANGENTITYNAME |
VARCHAR2 |
60 |
Optional |
Alternate Language Entity Name |
ALTLANGCONTACTPERSON |
VARCHAR2 |
70 |
Optional |
Alternate Language Contact Person |
ALTLANGADDRESS1 |
VARCHAR2 |
80 |
Optional |
Alternate Language Address 1 |
ALTLANGADDRESS2 |
VARCHAR2 |
80 |
Optional |
Alternate Language Address 2 |
ALTLANGCITY |
VARCHAR2 |
80 |
Optional |
Alternate Language City |
ALTLANGSTATE |
VARCHAR2 |
80 |
Optional |
Alternate Language State |
FINWAREPOSTING |
NUMBER |
1 |
Optional |
Finware Posting. 1 - Yes, 0 - No |
CHANNELENTITY |
NUMBER |
1 |
Optional |
Restrict Cross Branching within Agent. 1 - Yes, 0 - No |
MICRCODE |
VARCHAR2 |
12 |
Optional |
MICR Code |
NATIONALITY |
VARCHAR2 |
3 |
Optional |
Nationality |
COUNTRYOFBIRTH |
VARCHAR2 |
3 |
Optional |
Represents the birth country of entity |
COUNTRYOFDOMICILE |
VARCHAR2 |
3 |
Optional |
Represents the country of domicile |
VARCHAR2 |
3 |
Optional |
Country of Incorporation |
TAXID |
VARCHAR2 |
50 |
Optional |
Tax Id |
EIN |
VARCHAR2 |
50 |
Optional |
Employer ID Number |
DATE |
10 |
Optional |
Tax Certificate Effective Date |
DATE |
10 |
Optional |
Tax Certificate Expiry Date |
TAXCIRCLE |
VARCHAR2 |
3 |
Optional |
Tax Circle |
TAXCATEGORY |
VARCHAR2 |
10 |
Optional |
Tax Category |
GIIN |
VARCHAR2 |
30 |
Optional |
Global Intermediary Identification Number |
CURRENCY
VARCHAR2 |
3 |
Optional |
Currency |
ISAREFERENCENO
VARCHAR2 |
5 |
Optional |
ISA ReferenceNo |
MINISATRANSFEROUT
NUMBER |
30 |
Optional |
MinISATransferIn |
MINISATRANSFERIN |
NUMBER |
30 |
Optional |
MinISATransferOut |
Serial Number: 2
Segment Identification Number: 01EBD
Description: This segment is used for providing Entity Bank related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
16 |
Mandatory |
Segment Id. Value for Segment id is 01EBD |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
ENTITYID |
VARCHAR2 |
12 |
Optional |
Entity ID |
ENTITYTYPE |
VARCHAR2 |
1 |
Optional |
Entity Type |
BANKCODE |
VARCHAR2 |
12 |
Optional |
Bank Code |
BRANCHCODE |
VARCHAR2 |
12 |
Optional |
Branch Code |
ACCOUNTTYPE |
VARCHAR2 |
1 |
Optional |
Account Type |
ACCOUNTNUMBER |
VARCHAR2 |
20 |
Optional |
Account Number |
ACCOUNTNAME |
VARCHAR2 |
100 |
Optional |
Account Name |
ACCOUNTCURRENCY |
VARCHAR2 |
3 |
Optional |
Account Currency |
DEFAULTDETAILS |
NUMBER |
1 |
Optional |
Default Details. 1 - Yes, 0 - No |
VARCHAR2 |
1 |
Optional |
Direct Debit Applicable. 1 - Yes, 0 - No |
SWIFTFORMAT |
VARCHAR2 |
6 |
Optional |
Swift Format |
BANKCHARGED |
VARCHAR2 |
12 |
Optional |
Bank charged |
BENEFICIARY |
VARCHAR2 |
35 |
Optional |
Beneficiary |
BENEFICIARYADD1 |
VARCHAR2 |
105 |
Optional |
Beneficiary Address 1 |
BENEFICIARYADD2 |
VARCHAR2 |
105 |
Optional |
Beneficiary Address 2 |
BENEFICIARYADD3 |
VARCHAR2 |
105 |
Optional |
Beneficiary Address 3 |
BENEFICIARYBICCODE |
VARCHAR2 |
24 |
Optional |
BENEFICIARYACCTNO |
VARCHAR2 |
34 |
Optional |
BENEFICIARYCODE |
VARCHAR2 |
24 |
Optional |
Beneficiary Code |
BENEFICIARYINFO |
VARCHAR2 |
100 |
Optional |
Beneficiary Info |
INTERMEDIARY |
VARCHAR2 |
35 |
Optional |
Intermediary |
INTERMEDIARYADD1 |
VARCHAR2 |
105 |
Optional |
Intermediary Address 1 |
INTERMEDIARYADD2 |
VARCHAR2 |
105 |
Optional |
Intermediary Address 2 |
INTERMEDIARYADD3 |
VARCHAR2 |
105 |
Optional |
Intermediary Address 3 |
INTERMEDIARYBICCODE |
VARCHAR2 |
24 |
Optional |
INTERMEDIARYACCTNO |
VARCHAR2 |
34 |
Optional |
Intermediary Account Number |
INTERMEDIARYCODE |
VARCHAR2 |
24 |
Optional |
Intermediary Code |
INTERMEDIARYINFO |
VARCHAR2 |
100 |
Optional |
Intermediary Info |
FURTHERCREDITNAME |
VARCHAR2 |
35 |
Optional |
FURTHERCREDITACCTNO |
VARCHAR2 |
35 |
Optional |
REFERENCE1 |
VARCHAR2 |
35 |
Optional |
Reference 1 |
REFERENCE2 |
VARCHAR2 |
35 |
Optional |
Reference 2 |
IBAN |
VARCHAR2 |
40 |
Optional |
BENEFICIARYIBAN |
VARCHAR2 |
40 |
Optional |
Beneficiary International Bank Account Number |
INTERMEDIARYIBAN |
VARCHAR2 |
40 |
Optional |
Intermediary International Bank Account Number |
Serial Number: 3
Segment Identification Number: 02ECI
Description: This segment is used for providing Entity Contact Information related Information
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
16 |
Mandatory |
Segment Id. Value for Segment id is 02ECI |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
ENTITYID |
VARCHAR2 |
12 |
Optional |
Entity ID |
ENTITYTYPE |
VARCHAR2 |
2 |
Optional |
Entity Type |
ADDRESSTYPE |
VARCHAR2 |
2 |
Optional |
Address Type. CO - Correspondence Address, AL - Alternate Address, SW - Swift Address |
ADDRESSLINE1 |
VARCHAR2 |
105
Mandatory |
Address Line 1 |
ADDRESSLINE2 |
VARCHAR2 |
105 |
Optional |
Address Line 2 |
ADDRESSLINE3 |
VARCHAR2 |
105 |
Optional |
Address Line 3 |
ADDRESSLINE4 |
VARCHAR2 |
80 |
Optional |
Address Line 4 |
ZIPCODE |
VARCHAR2 |
10 |
Optional |
ZIP Code |
COUNTRY |
VARCHAR2 |
3 |
Optional |
Country |
USSTATE |
NUMBER |
1 |
Optional |
US State. 1 - Yes, 0 - No |
TELEPHONE1 |
VARCHAR2 |
60 |
Optional |
Telephone 1 |
TELEPHONE2 |
VARCHAR2 |
60 |
Optional |
Telephone 2 |
CELLPHONENUMBER |
VARCHAR2 |
60 |
Optional |
Cellphone Number |
FAX |
VARCHAR2 |
120 |
Optional |
FAX |
VARCHAR2 |
255 |
Optional |
Email Address |
CONTACTPERSON |
VARCHAR2 |
160 |
Optional |
Contact Person |
EFFECTIVEFROMDATE |
DATE |
10 |
Optional |
Effective From Date |
EFFECTIVETODATE |
DATE |
10 |
Optional |
Effective To Date |
BICCODE |
VARCHAR2 |
16 |
Optional |
BIC Code |
VARCHAR2 |
10 |
Optional |
Int. Dialing Code + Telephone 1 |
VARCHAR2 |
10 |
Optional |
Int. Dialing Code + Telephone 2 |
VARCHAR2 |
10 |
Optional |
Int. Dialing Code + Cellphone Number |
VARCHAR2 |
10 |
Optional |
Int. Dialing Code + Fax |
Serial Number: 4
Segment Identification Number: 03EBD
Description: This segment is used for providing Entity Broker Definition related Information
Segment Mandatory / Optional: Optional
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
16 |
Mandatory |
Segment Id. Value for Segment id is 03EBD |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
ENTITYID |
VARCHAR2 |
12 |
Optional |
Entity ID |
TRANSACTIONTYPE |
VARCHAR2 |
20 |
Optional |
Transaction Type |
BROKERDEFTYPE |
VARCHAR2 |
3 |
Optional |
Broker Defaulting Mechanism |
Serial Number: 5
Segment Identification Number: 04ERP
Description: This segment is used for providing Related parties Information
Segment Mandatory/ Optional: Optional
Data type |
Length |
Mandatory |
Characteristics/ rules |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Yes |
Segment Id - 04ERP |
SEQUENCENUMBER |
NUMBER |
22 |
Yes |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Yes |
Process ID |
ENTITYID |
VARCHAR2 |
12 |
Yes |
Indicates the unique identification code for the related party entity associated with the entity. |
ENTITYTYPE |
VARCHAR2 |
1 |
Yes |
Indicates the entity type of the entity's related party. |
RPENTITYID |
VARCHAR2 |
12 |
Yes |
RPENTITYTYPE |
VARCHAR2 |
1 |
Yes |
Indicates the entity type of the entitys related party. |
PREFMAILMODE |
VARCHAR2 |
1 |
No |
REPORTINGLEVEL |
VARCHAR2 |
1 |
No |
REMARKS |
VARCHAR2 |
255 |
No |
APPLYTO |
VARCHAR2 |
12 |
Yes |
APPLYLEVEL |
VARCHAR2 |
3 |
Yes |
Serial Number: 6
Description: This segment is used for providing Additional Information details.
Data type |
Length |
Mandatory |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Yes |
Segment Id - 05ADD |
SEQUENCENUMBER |
NUMBER |
10 |
Yes |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Yes |
Process ID |
ADDINFOLABEL |
VARCHAR2 |
30 |
Yes |
Additional Information Label |
FIELDVALUE |
CHAR |
23 |
Yes |
Field Value |
Serial Number: 7
Segment Identification Number: 06SWF
Description: This segment is used for providing Swift Message related details.
Data type |
Length |
Mandatory |
Values |
SEGMENTID |
VARCHAR2 |
16 |
Yes |
Segment Id - 06SWF |
SEQUENCENUMBER |
NUMBER |
10 |
Yes |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Yes |
Process ID |
ENTITYID |
VARCHAR2 |
12 |
Yes |
EntityID |
ENTITYTYPE |
VARCHAR2 |
1 |
Yes |
EntityType |
SWIFTCODE |
VARCHAR2 |
30 |
Yes |
Swift Code |
FCISCODE |
VARCHAR2 |
3 |
Yes |
FCIS Code |
Data type |
Length |
Mandatory |
Values |
PROCESSID |
VARCHAR2 |
50 |
PROCESSID |
SEQUENCENUMBER |
NUMBER |
10 |
SEQUENCENUMBER |
BULKCLIENTCODE |
VARCHAR2 |
12 |
BULKCLIENTCODE |
IMPORTFILENAME |
VARCHAR2 |
255 |
IMPORTFILENAME |
UPLOADMODE |
VARCHAR2 |
1 |
UPLOADMODE |
UNITHOLDERID |
VARCHAR2 |
12 |
UNITHOLDERID |
CHASINGDATE |
DATE |
10 |
CHASINGDATE |
CHASERID |
VARCHAR2 |
255 |
CHASERID |
CHASINGMODE |
VARCHAR2 |
2 |
CHASINGMODE |
COMMENTS |
VARCHAR2 |
255 |
COMMENTS |
AUTH_STAT |
VARCHAR2 |
1 |
AUTH_STAT |
MAKER_ID |
VARCHAR2 |
15 |
MAKER_ID |
MAKER_DT_STAMP |
DATE |
10 |
MAKER_DT_STAMP |
CHECKER_ID |
VARCHAR2 |
15 |
CHECKER_ID |
CHECKER_DT_STAMP |
DATE |
10 |
CHECKER_DT_STAMP |
Data type |
Length |
Values |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
UNITHOLDERID |
VARCHAR2 |
12 |
Mandatory |
Unit Holder ID |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Fund ID |
ENTITYID |
VARCHAR2 |
12 |
Mandatory |
Entity ID |
CHECKBOOKNUMBER |
VARCHAR2 |
16 |
Mandatory |
Check Book Number |
STARTCHECKNUMBER |
VARCHAR2 |
12 |
Mandatory |
Start Check Number |
ENDCHECKNUMBER |
VARCHAR2 |
12 |
Mandatory |
End Check Number |
CHECKCURRENCY |
VARCHAR2 |
3 |
Mandatory |
Check Currency |
MAKER_ID |
VARCHAR2 |
12 |
Optional |
It shows the name of the user who has created or modified the specific record. |
MAKER_DT_STAMP |
DATE |
10 |
Optional |
This field specifies the date and time at which this record was created or modified. It is defaulted by system and will be in date format. |
CHECKER_ID |
VARCHAR2 |
12 |
Optional |
It shows the Name of the user who authorizes that specific record. |
CHECKER_DT_STAMP |
DATE |
10 |
Optional |
This field specifies the date and time at which this record was authorized is displayed in this field. It is defaulted by system and will be in date format. |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
This filed indicates where this particular record is authorized or not. A-Authorized U-Not Authorized |
MOD_NO |
NUMBER |
10 |
Optional |
Indicates the max number of times the record is modified. |
RECORD_STAT |
CHAR |
1 |
Optional |
Represents whether the record is open-O or closed-C |
ONCE_AUTH |
CHAR |
1 |
Optional |
Represents whether the record was authorized at least once after its creation. Authorized(Y)/Never Authorized(N) |
STATUS |
VARCHAR2 |
50 |
Optional |
Represents the Status CHECKSTATUSMAINTAINED Check Status Maintained CHECKBOOKAPPLIED Check Book Applied CHECKBOOKEXHAUSTED Check Book Exhausted SENTTOVENDOR Sent To Vendor DISCREPANCYNOTICED Discrepancy Noticed CANCELLED Check Cancelled |
REMARKS |
VARCHAR2 |
200 |
Optional |
Represents the Remarks |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Mode of operation which has to be performed on the record |
Data type |
Length |
Values |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
CIFNUMBER |
VARCHAR2 |
12 |
Mandatory |
CIF Number |
MEDIA |
VARCHAR2 |
15 |
Optional |
Media |
LOCATION |
VARCHAR2 |
15 |
Optional |
Location |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Fund ID |
NEWFUNDID |
VARCHAR2 |
6 |
Optional |
New Fund ID |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Represents the user id who has entered the latest record. |
MAKER_DT_STAMP |
DATE |
10 |
Optional |
Represents the time when the record is created |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
CHECKER_DT_STAMP |
DATE |
10 |
Optional |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
Authorisation Status. A - Authorised, U - Unauthorised |
MODULEID |
VARCHAR2 |
30 |
Mandatory |
Module ID |
AGENTCODE |
VARCHAR2 |
12 |
Mandatory |
Agent Code |
BRANCHCODE |
VARCHAR2 |
12 |
Mandatory |
Branch Code |
Data type |
Length |
Values |
PROCESSID |
VARCHAR2 |
50 |
Optional |
Sequence Number |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Optional |
Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
CIFNUMBER |
VARCHAR2 |
12 |
Mandatory |
CIF Number |
MEDIA |
VARCHAR2 |
15 |
Mandatory |
Media |
LOCATION |
VARCHAR2 |
15 |
Mandatory |
Location |
ADDRESS1 |
VARCHAR2 |
105 |
Mandatory |
Address 1 |
ADDRESS2 |
VARCHAR2 |
105 |
Optional |
Address 2 |
ADDRESS3 |
VARCHAR2 |
105 |
Optional |
Address 3 |
ADDRESS4 |
VARCHAR2 |
105 |
Optional |
Address 4 |
ZIPCODE |
VARCHAR2 |
10 |
Optional |
ZIP Code |
COUNTRY |
VARCHAR2 |
3 |
Optional |
Country |
CONTACTPERSON |
VARCHAR2 |
160 |
Optional |
Contact Person |
TELEPHONENUMBER1 |
VARCHAR2 |
60 |
Optional |
Telephone Number 1 |
TELEPHONENUMBER2 |
VARCHAR2 |
60 |
Optional |
Telephone Number 2 |
CELLPHONENUMBER |
VARCHAR2 |
60 |
Optional |
Cellphone Number |
ENABLEDFLAG |
VARCHAR2 |
1 |
Optional |
Enabled Flag |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
MAKER_DT_STAMP |
DATE |
10 |
Optional |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
Represents the checker id who has authorized the latest record. |
CHECKER_DT_STAMP |
DATE |
10 |
Optional |
Represents the time when it was Authorized. |
MODULEID |
VARCHAR2 |
30 |
Mandatory |
Represents the module ID |
AGENTCODE |
VARCHAR2 |
12 |
Mandatory |
Represents the agent code |
BRANCHCODE |
VARCHAR2 |
12 |
Mandatory |
Represents the branch code |
Description |
01HDR |
This segment is used for providing information related to Employer Header details |
Mandatory |
02DTL |
This segment is used for providing information related to Employer details |
Mandatory |
Serial Number: 1
Segment Identification Number: 01HDR
Description: This segment is used for providing information related to Employer Header details
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
25 |
Mandatory |
Segment Id - 01HDR |
EMPLOYERCODE |
VARCHAR2 |
25 |
Mandatory |
Employee Code |
EMPLOYERNAME |
VARCHAR2 |
100 |
Mandatory |
Employee Name |
BANKCODE |
VARCHAR2 |
12 |
Mandatory |
Bnak Code |
BRANCHCODE |
VARCHAR2 |
12 |
Mandatory |
Braanch Coe |
ACCOUNTTYPE |
VARCHAR2 |
1 |
Mandatory |
Account Type |
ACCOUNTNUMBER |
VARCHAR2 |
20 |
Mandatory |
Account Number |
ACCOUNTNAME |
VARCHAR2 |
100 |
Mandatory |
Account Name |
Serial Number: 2
Segment Identification Number: 02DTL
Description: This segment is used for providing information related to Employer details
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
25 |
Mandatory |
Segment Id - 02DTL |
EMPSURNAME |
VARCHAR2 |
100 |
Mandatory |
Employee Sur Name |
EMPNAME |
VARCHAR2 |
100 |
Mandatory |
Employee Name |
BROKERCODE |
VARCHAR2 |
25 |
Mandatory |
Broker Code |
FUNDID |
VARCHAR2 |
25 |
Mandatory |
Fund Id |
VALUEDATE |
DATE |
7 |
Mandatory |
Value Date |
UNITHOLDERID |
VARCHAR2 |
25 |
Mandatory |
UnitHolder Id |
EMPLOYEEID |
VARCHAR2 |
25 |
Mandatory |
Employee Id |
EMPLYERID |
VARCHAR2 |
25 |
Mandatory |
Employer Id |
TOTALCONTRIBUTION |
VARCHAR2 |
30 |
Mandatory |
Total Contribution |
BASICSALARY |
VARCHAR2 |
30 |
Mandatory |
Basic Salary |
EFFECTIVEEMPLOYEEPERCENTAGE |
VARCHAR2 |
30 |
Mandatory |
Effective Employee Percentage |
EFFECTIVEEMPLOYERPERCENTAGE |
VARCHAR2 |
30 |
Mandatory |
Effective Employer Percentage |
ADMINFEEPERCENTAGE |
VARCHAR2 |
30 |
Mandatory |
Admin Fee Percentage |
ADMINFEE |
VARCHAR2 |
30 |
Mandatory |
Admin Fee |
ADMINFEEFTERVAT |
VARCHAR2 |
30 |
Mandatory |
Admin Fee after VAT |
FLATFEE |
VARCHAR2 |
30 |
Mandatory |
Flat Fee |
BROKERFEEPERCENTAGE |
VARCHAR2 |
30 |
Mandatory |
Broker Percentage |
BROKERFEEAMOUNT |
VARCHAR2 |
30 |
Mandatory |
Broker Fee Amount |
BROKERFEEAMOUNTAFTERVAT |
VARCHAR2 |
30 |
Mandatory |
Broker Fee Amount after VAT |
TOTALDEDUCTIONS |
VARCHAR2 |
30 |
Mandatory |
Total Deductions |
NETINVESTMENT |
VARCHAR2 |
30 |
Mandatory |
Net Investment |
EMPLOYERCONTRIBUTION |
NUMBER |
30 |
Mandatory |
Employer Contribution |
EMPLOYEECONTRIBUTION |
NUMBER |
30 |
Mandatory |
Employee Contribution |
ADDINFO1 |
VARCHAR2 |
30 |
Mandatory |
Addition Information 1 |
ADDINFO2 |
VARCHAR2 |
30 |
Mandatory |
ADDINFO3 |
VARCHAR2 |
30 |
Mandatory |
Description |
00FAT |
This segment is used for providing information related to FATCA Maintenance header Details |
Mandatory |
01DOC |
This segment is used for providing information related to FATCA Maintenance Document Details |
Mandatory |
Serial Number: 1
Segment Identification Number: 00FAT
Description: This segment is used for providing information related to FATCA Maintenance header Details
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 00FAT |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
FATCAREFNO |
VARCHAR2 |
16 |
Mandatory |
Represents the FATCA Reference Number |
FATCAENTITYTYPE |
VARCHAR2 |
2 |
Mandatory |
Represents the FATCA Entity Type |
FATCAENTITYID |
VARCHAR2 |
12 |
Mandatory |
Represents the FATCA Entity ID |
FATCAENTITYNAME |
VARCHAR2 |
100 |
Mandatory |
Represents the FATCA Entity name |
FATCAENTITYCATTYPE |
VARCHAR2 |
1 |
Mandatory |
Represents the FATCA Entity Category type |
FATCACLASSIFICATION |
VARCHAR2 |
25 |
Mandatory |
Represents the FATCA Classification |
FATCACLASSIFICATIONREASON |
VARCHAR2 |
25 |
Mandatory |
Represents the FATCA Classification Reason |
FATCACOMPLAINTREASON |
VARCHAR2 |
255 |
Optional |
Represents the FATCA Complaint Reason |
AUTH_STAT |
VARCHAR2 |
1 |
Mandatory |
Represents the Authorisation Status. A- Authorised, U - Unauthorised. |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
MAKER_DT_STAMP |
DATE |
10 |
Optional |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
CHECKER_DT_STAMP |
DATE |
10 |
Optional |
REPORTABLE |
NUMBER |
1 |
Optional |
FATCA Reportable - Yes/No |
WITHHOLDABLE |
NUMBER |
1 |
Optional |
FATCA Withholdable - Yes/No |
Serial Number: 2
Segment Identification Number: 01DOC
Description: This segment is used for providing information related to FATCA Maintenance Document Details
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 01DOC |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
FATCAREFNO |
VARCHAR2 |
16 |
Mandatory |
FATCA Reference number |
DOCUMENTTYPE |
VARCHAR2 |
25 |
Mandatory |
Represents the FATCA document type. |
ISSUEDATE |
DATE |
10 |
Mandatory |
Represents the document issue date |
EXPIRYDATE |
DATE |
10 |
Mandatory |
Represents the document expiry date |
COPYRECEIVED |
VARCHAR2 |
1 |
Mandatory |
Represents the Flag whether the document copy is received or not. Y- Yes, N- No |
ORIGINALRECEIVED |
VARCHAR2 |
1 |
Mandatory |
Represents the Flag whether the document original is received or not. Y- Yes, N- No |
RECEIVEDDATE |
DATE |
10 |
Mandatory |
Represents the document received date |
REMARKS |
VARCHAR2 |
255 |
Mandatory |
Represents the remarks |
CHASINGDATE |
DATE |
10 |
Mandatory |
Represents the document Chasing date |
DOCUMENTREFNO |
VARCHAR2 |
255 |
Mandatory |
Represents the document reference number |
DOCCATEGORY |
VARCHAR2 |
25 |
Mandatory |
Represents the document category |
DOCUMENTID |
VARCHAR2 |
25 |
Mandatory |
Represents the document ID |
MANDATORY |
VARCHAR2 |
1 |
Mandatory |
Represents the mandatory Criteria. Either it could be 'Standard' - S nor 'Additional' - A. |
Data type |
Length |
Values |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Represents the Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Represents the Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Represents the Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Represents the Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
FUNDID |
VARCHAR2 |
12 |
Mandatory |
Represents the Fund ID |
PRICEDATE |
DATE |
7 |
Mandatory |
Represents the Price Date |
REVISEDPRICE |
NUMBER |
17 |
Mandatory |
Represents the revised Price |
LATESTPRICE |
NUMBER |
1 |
Mandatory |
Represents the latest Price |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
MAKER_DT_STAMP |
DATE |
7 |
Mandatory |
CHECKER_ID |
VARCHAR2 |
15 |
Mandatory |
CHECKER_DT_STAMP |
DATE |
7 |
Mandatory |
RUNTYPE |
VARCHAR2 |
4 |
Mandatory |
Represents the run type |
MOCKRUN |
VARCHAR2 |
1 |
Mandatory |
Flag to represent the mock run |
Data type |
Length |
Values |
SEQUENCENUMBER |
NUMBER(10) |
Yes |
22 |
Sequence Number |
PROCESSID |
VARCHAR2(50) |
Yes |
200 |
Process ID |
IMPORTFILENAME |
VARCHAR2(255) |
Yes |
1020 |
Import File Name |
GIIN |
VARCHAR2(19) |
Yes |
76 |
GIIN Code to be imported |
FINM |
VARCHAR2(30) |
Yes |
120 |
Describes the name field |
COUNTRYNM |
VARCHAR2(30) |
Yes |
120 |
Describes the country field |
Description |
Segment Mandatory/ Optional? |
00HDM |
This segment is used for providing information related to Help desk |
Mandatory |
01HDE |
Mandatory |
Serial Number: 1
Segment Identification Number: 00HDM
Description: This segment is used for providing information related to Help desk
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 00HDM |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
UPLOADMODE |
VARCHAR2 |
10 |
Mandatory |
HELPDESKREFNO |
VARCHAR2 |
12 |
Optional |
Help desk Reference Number |
REPORTINGENTITYTYPE |
VARCHAR2 |
30 |
Mandatory |
Reporting Entity Type |
REPORTINGENTITYID |
VARCHAR2 |
12 |
Mandatory |
Reporting Entity ID |
QUERYTYPE |
VARCHAR2 |
10 |
Mandatory |
Query Type |
QUERYSEVERITY |
VARCHAR2 |
10 |
Mandatory |
Query Severity |
QUERYCATEGORY |
VARCHAR2 |
30 |
Mandatory |
Query Category |
PROBLEMDESCRIPTION |
VARCHAR2 |
255 |
Mandatory |
Problem Description |
ATTENDEDBY |
VARCHAR2 |
15 |
Mandatory |
Attended By |
HELPDESKSTATUS |
VARCHAR2 |
10 |
Mandatory |
Help desk Status |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
MAKER_DT_STAMP |
DATE |
10 |
Optional |
MODULEID |
VARCHAR2 |
30 |
Mandatory |
AMCID |
VARCHAR2 |
12 |
Mandatory |
Serial Number: 2
Segment Identification Number: 01HDE
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 01HDE |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Mandatory |
Sequence Number |
HELPDESKREFNO |
VARCHAR2 |
12 |
Optional |
EVENTDATE |
DATE |
10 |
Mandatory |
Event Date |
HELPDESKMODE |
VARCHAR2 |
1 |
Mandatory |
Help Desk Mode |
EVENTMODE |
VARCHAR2 |
1 |
Mandatory |
Event Mode |
EVENTDESCRIPTION |
VARCHAR2 |
255 |
Mandatory |
Event Description |
Data type |
Length |
Values |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process id |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Dividend Distribution Fund ID |
DIVIDENDFROMDATE |
DATE |
7 |
Optional |
Dividend Period - From Date If not provided, defaulted to Dividend Declaration Date. |
DIVIDENDTODATE |
DATE |
7 |
Optional |
Dividend Period - To Date If not provided, defaulted to Dividend Declaration Date. |
DIVIDENDFREEZEHOLDINGSDATE |
DATE |
7 |
Optional |
Dividend Freeze Holdings Date If not provided, defaulted to Dividend Declaration Date. |
DIVIDENDDECLARATIONDATE |
DATE |
7 |
Mandatory |
Dividend Declaration Date for the Fund, |
COMPONENTVALUES |
VARCHAR2 |
2000 |
Optional |
Component Values with Component ID as ^ separator. For instance, ID^.10;FD^.22;FI^.12;LI^.32;TA^-.2; Pls note that tax/deduction needs to be provided with -ve sign, system derives EPU and it will be summation of the components. Optional, Then EPU to be provided in the below field |
EPU |
NUMBER |
22 |
Optional |
Earnings Per Unit. If the Components are provided this will be ignored |
PAYMENTDATE |
DATE |
7 |
Optional |
Dividend Payment Date for the Fund If not provided, while processing dividend system considers application date when the batch executed. |
REINVESTMENTDATE |
DATE |
7 |
Optional |
Dividend Reinvestment Date for the Fund. If not provided, while processing reinvestments system considers application date when the batch executed as reinvestment date. |
NPICOMPONENT |
VARCHAR2 |
1 |
Mandatory |
NPI Component for the fund |
KEYSTRING |
VARCHAR2 |
50 |
Mandatory |
Keystring |
Data type |
Length |
Values |
KEYSTRING |
VARCHAR2 |
50 |
No |
Keystring |
STATEMENTTYPE |
VARCHAR2 |
7 |
Yes |
Statement type |
TRANSACTIONDATE |
VARCHAR2 |
10 |
Yes |
Transaction date field. If transaction type ref field is branch, this field should be valid branch number. If transaction ref type field is acc-no then transaction date field should be a valid account number else transation date should be a valid date. |
TRANSACTIONTYPEREF |
VARCHAR2 |
9 |
Yes |
Transaction type ref. This field should have BRANCH, ACC-NO, OPEN, CLOSE as mandatory . Other transaction types also can be included. |
CREDITORDEBIT |
VARCHAR2 |
1 |
Yes |
Credit or debit. Credit is + and debit is - |
TRANSACTIONAMOUNT |
VARCHAR2 |
17 |
Yes |
Transaction amount |
STATEMENTREFERENCE |
VARCHAR2 |
41 |
Yes |
Statement reference |
TRANSACTIONCODE |
VARCHAR2 |
7 |
Yes |
Transaction code |
SERVICEFEE |
VARCHAR2 |
6 |
Yes |
Service fee |
Data type |
Length |
Values |
PROCESSID |
VARCHAR2 |
200 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
48 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
1020 |
Mandatory |
Import File Name |
FUNDID |
VARCHAR2 |
24 |
Optional |
Valid FundID in FCIS |
GLTEMPLATEID |
VARCHAR2 |
40 |
Mandatory |
Valid GL Template ID |
ACCOUNTTYPE |
VARCHAR2 |
8 |
Mandatory |
Valid Account Type |
BUSINESSEVENT |
VARCHAR2 |
8 |
Mandatory |
Valid Business event |
TRIGGEREVENT |
VARCHAR2 |
60 |
Mandatory |
Valid Trigger Event |
THEROITICALFLAG |
VARCHAR2 |
4 |
Mandatory |
Theoritcak Flag, Yes/No |
SETUPENABLED |
VARCHAR2 |
4 |
Mandatory |
GL setup enable disable flag, Yes/No |
COMPONENTID |
VARCHAR2 |
80 |
Mandatory |
GL Component ID |
COMPONENTDESCRIPTION |
VARCHAR2 |
1020 |
Mandatory |
GL Component Description |
DEBITCREDITFLAG |
VARCHAR2 |
8 |
Mandatory |
Debit or Credit Flag |
GLSETUPFORPRIMARY |
VARCHAR2 |
4 |
Mandatory |
GL Setup for Primary |
PRIMARYENTITYTYPE |
VARCHAR2 |
4 |
Mandatory |
Primary Entity Type |
ACCOUNTNUMBER |
VARCHAR2 |
20 |
Mandatory |
GL Account number for Primary |
ACCOUNTCURRENCY |
VARCHAR2 |
12 |
Mandatory |
GL Account Currency for Primary |
VARCHAR2 |
12 |
Mandatory |
BANKBRANCH |
VARCHAR2 |
48 |
Optional |
Bank Branch |
DIRECTDEBITAPPLICABLE |
VARCHAR2 |
4 |
Mandatory |
Direct Debit applicable Yes/No |
GLSETUPFORCONTRA |
VARCHAR2 |
4 |
Mandatory |
GL Setup for Contra |
CONTRAPRIMARYENTITYTYPE |
VARCHAR2 |
4 |
Mandatory |
Contra Entity Type |
CONTRAACCOUNTNUMBER |
VARCHAR2 |
64 |
Mandatory |
Contra GL Account Number |
CONTRAACCOUNTCURRENCY |
VARCHAR2 |
12 |
Mandatory |
Contra GL Account Currency |
CONTRATRANSACTIONCURRENCY |
VARCHAR2 |
12 |
Mandatory |
Contra Transaction Currency |
CONTRABANKBRANCH |
VARCHAR2 |
48 |
Optional |
Contra Brank Branch |
CONTRADIRECTDEBITAPPLICABLE |
VARCHAR2 |
4 |
Mandatory |
Contra Direct Debit Applicable Yes/No |
RESTRICTEDREFTYPES |
VARCHAR2 |
1020 |
Optional |
Restricted Ref types for the GL setup(Delimited with ':') |
GLCURRENCY |
VARCHAR2 |
12 |
Mandatory |
GL Currency |
GLREFERENCENUMBER |
VARCHAR2 |
40 |
Mandatory |
GL Reference Number |
PRODUCTID |
VARCHAR2 |
40 |
Optional |
Valid FCIS ProductID |
PRODUCTORFUNDLEVEL |
VARCHAR2 |
4 |
Mandatory |
Indicates the GL setup is at fund level or product level |
MODEODUPLOAD |
VARCHAR2 |
4 |
Mandatory |
Upload Mode |
AUTH_STAT |
VARCHAR2 |
4 |
Optional |
Auth Status |
RESTRICTEDSUBTYPES |
VARCHAR2 |
1020 |
Optional |
Restricted sub types for the GL setup(Delimited with ':') |
Data type |
Length |
Values |
TXNSERIALNUMBER |
NUMBER |
22 |
Mandatory |
Specifies the Transaction Serial Number |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Specifies the Sequence Number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Specifies the Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Specifies the Bulk Client code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Optional |
Specifies the Import File Name |
AMCID |
VARCHAR2 |
12 |
Mandatory |
Specifies the AMC of the Global order |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Upload Mode.Value should be 'N' |
GONUMBER |
VARCHAR2 |
16 |
Mandatory |
Specifies the GO Number of the record |
ALLOTEDUNITS |
NUMBER |
22 |
Mandatory |
Specifies the Alloted units of Global order |
CONFIRMEDUNITS |
NUMBER |
22 |
Mandatory |
Specifies the Confirmed units of Global order |
UNITPRICE |
NUMBER |
22 |
Mandatory |
Specifies the unit Price used for allocation of Global order |
CONFIRMATIONDATE |
DATE |
7 |
Mandatory |
Specifies the Confirmation date of Global order |
PRICEDATE |
DATE |
7 |
Mandatory |
Specifies the Price date of Global order |
AMOUNT |
VARCHAR2 |
22 |
Mandatory |
Specifies the Amount confirmed of Global order |
Description |
00FDR |
This segment is used for providing information related to Fund Demographics |
Mandatory |
01FLT |
This segment is used for providing information related to Fund Language |
Optional |
02SCR |
This segment is used for providing information related to Shares Characteristics |
Mandatory |
03FUH |
This segment is used for providing information related to Fund Unitholder Category Registered Capital |
Optional |
04GOR |
This segment is used for providing information related to General Operating Rules |
Mandatory |
05TRP |
This segment is used for providing information related to Transaction Processing Rules |
Mandatory |
06TRC |
This segment is used for providing information related to Transaction Processing Rules Communication Mode |
Optional |
07FIC |
This segment is used for providing information related to Fund Investor Category Transaction Limits |
Optional |
08FSF |
This segment is used for providing information related to Fund SI Frequency Details |
Optional |
09FSC |
This segment is used for providing information related to Fund Sale Country |
Optional |
10FRL |
This segment is used for providing information related to Fund Residency Country |
Optional |
11FTC |
This segment is used for providing information related to Fund Transaction Currency |
Optional |
12IDR |
This segment is used for providing information related to Income Distribution Rule |
Optional |
13FLM |
This segment is used for providing information related to Fund Load Maintenance |
Optional |
14FFM |
This segment is used for providing information related to Fund Formula Maintenance |
Optional |
15FAI |
This segment is used for providing information related to Fund Additional Information |
Optional |
16SDS |
This segment is used for providing information related to Specific Fund Price date Setup |
Optional |
17FPD |
This segment is used for providing information related to Fund User Defined Price Dates |
Optional |
18IRA |
This segment is used for providing information related to Fund IRA |
Optional |
19FDI |
This segment is used for providing information related to Fund Delivery Instruction |
Optional |
20FIA |
This segment is used for providing information related to Fund Investment Account |
Optional |
21FIS |
This segment is used for providing information related to Fund investment Account SI |
Optional |
22KYC |
This segment is used for providing information related to KYC Fund |
Optional |
23HFR |
This segment is used for providing information related to Hedge Fund Rules |
Optional |
24HFL |
This segment is used for providing information related to Hedge Fund Link |
Optional |
25HFC |
This segment is used for providing information related to Hedge Fund Investor Category Performance Fee |
Optional |
26MID |
This segment is used for providing information related to Multi Distribution Details |
Optional |
Serial Number: 1
Segment Identification Number: 00FDR
Description: This segment is used for providing information related to Fund Demographics
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 00FDR |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Optional |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Optional |
Import File Name |
LEGALENTITY |
VARCHAR2 |
12 |
Optional |
Indicated the legal entity mapped to the fund |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
It shows the name of the user who has created or modified the specific record |
MAKER_DT_STAMP |
DATE |
7 |
Optional |
This field specifies the date and time at which this record was created or modified. It is defaulted by system and will be in date format |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
It shows the Name of the user who authorizes that specific record |
CHECKER_DT_STAMP |
DATE |
7 |
Optional |
This field specifies the date and time at which this record was authorized is displayed in this field. It is defaulted by system and will be in date format |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Operation mode which will be performed on the Upload records. It can have N-New,D-Delete,A-Auth & E- Modify |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
Rule Effective Date |
FUNDSTARTDATE |
DATE |
7 |
Mandatory |
Fund Start Date |
FUNDNAME |
VARCHAR2 |
60 |
Mandatory |
Fund Name |
FUNDNAMESHORT |
VARCHAR2 |
15 |
Mandatory |
Fund Name Short |
FUNDCLASS |
VARCHAR2 |
1 |
Optional |
Fund Class. O - Open-Ended, C - Close-Ended |
FUNDTYPE |
NUMBER |
22 |
Optional |
Fund Type |
FUNDFAMILY |
VARCHAR2 |
6 |
Optional |
Fund Family |
FUNDBASECURRENCY |
VARCHAR2 |
3 |
Optional |
Fund Base Currency |
FUNDCOUNTRY |
VARCHAR2 |
3 |
Optional |
Fund Country |
FISCALSTARTYEAR |
DATE |
7 |
Optional |
Fiscal Year Start Date |
FISCALENDYEAR |
DATE |
7 |
Optional |
Fiscal Year End Date |
AMCID |
VARCHAR2 |
12 |
Optional |
AMC ID |
BROKERSALLOWED |
NUMBER |
22 |
Optional |
Brokers Mandatory? 1 - Yes, 0 - No |
REGISTRARID |
VARCHAR2 |
12 |
Optional |
Registrar ID |
TRUSTEEID |
VARCHAR2 |
12 |
Optional |
Trustee ID |
FUNDENABLED |
NUMBER |
22 |
Optional |
Fund Enabled? 1 - Yes, 0 - No |
MINHOLDINGPERIOD |
NUMBER |
22 |
Optional |
Minimum Holding Period |
PRIMARYREGADDRESS |
VARCHAR2 |
255 |
Optional |
Primary Registration Address |
FUNDTAXID |
VARCHAR2 |
25 |
Optional |
Fund Tax ID |
FUNDIDENTIFICATIONNUMBER |
VARCHAR2 |
25 |
Optional |
Fund Identification Number |
FUNDTICKERSYMBOL |
VARCHAR2 |
25 |
Optional |
Fund Ticker Symbol |
ALLOWIRAINVESTMENTS |
NUMBER |
22 |
Optional |
IRA Investments Allowed? 1 - Yes, 0 - No |
EXISTINGFUND |
VARCHAR2 |
1 |
Optional |
Existing Fund ? 1 - Yes, 0 - No |
CUSTODIAN |
VARCHAR2 |
12 |
Optional |
Custodian |
FUNDSUSPENDED |
NUMBER |
22 |
Optional |
Fund Suspended ? 1 - Yes, 0 - No |
MINAMOUNTFORTAXIDINDV |
NUMBER |
22 |
Optional |
Min Amt for Tax ID-Indv |
MINAMOUNTFORTAXIDCOR |
NUMBER |
22 |
Optional |
Min Amt for Tax ID-Corp |
HEDGEFUND |
VARCHAR2 |
1 |
Optional |
Hedge Fund ? Y - Yes, N - No |
DEFAULTOPTION |
VARCHAR2 |
15 |
Optional |
Default Option |
Serial Number: 2
Segment Identification Number: 01FLT
Description: This segment is used for providing information related to Fund Language
Field Name (as expected in the file) |
Data type |
Length |
Characteristics/rules |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 01FLT |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Optional |
Fund ID |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
Language Code |
LANGUAGECODE |
VARCHAR2 |
12 |
Mandatory |
Sequence Number |
FUNDNAME |
VARCHAR2 |
60 |
Optional |
Fund Name |
Serial Number: 3
Segment Identification Number: 02SCR
Description: This segment is used for providing information related to Shares Characteristics
Segment Mandatory / Optional: Mandatory
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id- 02SCR |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Optional |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Mandatory |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Optional |
SCRIPBASED |
NUMBER |
22 |
Optional |
ScripBased. 2 - Certificate -Option, 1 - Scrip Based, 0 - Scrip Less |
PARVALUE |
NUMBER |
22 |
Optional |
Unit Par Value |
NOOFDECIMALSFORUNITS |
NUMBER |
22 |
Optional |
Rounding Precision For Units |
ROUNDOFFTRUNCATE |
VARCHAR2 |
1 |
Optional |
Rounding Option For Units. R - Round Off, T - Round Down, U - Round Up |
MINNOOFUNITHOLDERS |
NUMBER |
22 |
Optional |
Min No Of Unit Holders |
MAXNOOFUNITHOLDERS |
NUMBER |
22 |
Optional |
Max No Of Unit Holders |
MINREGISTEREDCAPITAL |
NUMBER |
22 |
Optional |
Min Registered Capital |
MAXREGISTEREDCAPITAL |
NUMBER |
22 |
Optional |
Max Registered Capital |
CAPINDICATOR |
VARCHAR2 |
1 |
Optional |
Limit By. A - Amount, P - Percentage |
FOREIGNINVESTORSLIMIT |
NUMBER |
22 |
Optional |
Limit Value |
ACCOUNTSTATEMENTFREQ |
VARCHAR2 |
20 |
Optional |
Account statement frequency |
ACCOUNTSTATEMENTLEADTIME |
NUMBER |
22 |
Optional |
A/c Statement Lead Time |
PRINTACCOUNTSTATEMENT |
NUMBER |
22 |
Optional |
Print Account Statement |
PRINTHOLDINGSSTATEMENT |
NUMBER |
22 |
Optional |
Print Holding Statement |
LASTSTATEMENTNUMBER |
NUMBER |
22 |
Optional |
Last Statement Number |
STANDARDLOT |
NUMBER |
22 |
Optional |
Standard Lot |
PREFIXCERTCODE |
VARCHAR2 |
1 |
Optional |
Prefix Code |
STARTCERTISSUEDNO |
NUMBER |
22 |
Optional |
Start Issue No |
LASTCERTISSUEDNO |
NUMBER |
22 |
Optional |
Last Issue No |
PREFIXDNRCODE |
VARCHAR2 |
1 |
Optional |
Prefix DNR Code |
STARTDNRISSUEDNO |
NUMBER |
22 |
Optional |
Start DNR No. |
LASTDNRISSUEDNO |
NUMBER |
22 |
Optional |
Last DNR No. |
SINGLECERTALLOWED |
NUMBER |
22 |
Optional |
Single Certificate Allowed ? 1 - Yes, 0 - No |
MINCERTDENOMINATION |
NUMBER |
22 |
Optional |
Min Cert Denomination |
MAXCERTDENOMINATION |
NUMBER |
22 |
Optional |
Max Cert Denomination |
USEROVERRIDEALLOWED |
NUMBER |
22 |
Optional |
User Override Allowed |
CERTREQD |
NUMBER |
22 |
Optional |
Certificate Required For Block ? 1 - Yes, 0 - No |
MAXREGISTEREDUNITS |
NUMBER |
22 |
Optional |
Maximum Registered Units |
UHCATREGCAPITAL |
VARCHAR2 |
2000 |
Optional |
Unit Holder Category Registered Capital |
Serial Number: 4
Segment Identification Number: 03FUH
Description: This segment is used for providing information related to Fund Unitholder Category Registered Capital
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 03FUH |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
UHCATEGORY |
VARCHAR2 |
2 |
Mandatory |
UnitHolder Category |
MAXREGUNITS |
NUMBER |
22 |
Optional |
Serial Number: 5
Segment Identification Number: 04GOR
Description: This segment is used for providing information related to General Operating Rules
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 04GOR |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
POSTPRICED |
NUMBER |
22 |
Optional |
Post Priced ? 1 - Yes, 0 - No |
FUNDRISKLEVEL |
VARCHAR2 |
1 |
Optional |
Indicates the risk level of the fund |
NEXTPRICEDECLAREDATE |
DATE |
7 |
Optional |
Next Price Declare Date |
PRICEDECLAREFREQ |
VARCHAR2 |
1 |
Optional |
Price Declare Frequency |
NOOFDECIMALSFORNAV |
NUMBER |
22 |
Optional |
No of Decimals for NAV |
ROUNDOFFTRUNCATE |
VARCHAR2 |
1 |
Optional |
Rounding Options for NAV. R - Round Off, T - Round Down, U - Round Up |
MATURITYDATE |
DATE |
7 |
Optional |
Maturity Date |
RETAINIPOBALANCE |
NUMBER |
22 |
Optional |
Retain IPO Balance? 1 - Yes, 0 - No |
CONFBEFALCREQUIRED |
NUMBER |
22 |
Optional |
Allow Rejections Before Allocation? 1 - Yes, 0 - No |
AUTOREDEMPTIONALLOWED |
NUMBER |
22 |
Optional |
Automatic Redemption Allowed? 1 - Yes, 0 - No |
MINIMUMBALANCETYPE |
VARCHAR2 |
1 |
Optional |
Minimum Balance Type. A - Amount, U - Units |
MINIMUMBALANCE |
NUMBER |
22 |
Optional |
Minimum Balance |
ELAPSEDDAYSBEFOREAUTORED |
NUMBER |
22 |
Optional |
Elapsed Days |
CHQALLOTONCLGDATE |
NUMBER |
22 |
Optional |
Allotment On Check Clearing. 1 - Yes, 0 - No |
AGEINGBASEDON |
VARCHAR2 |
1 |
Optional |
Ageing Policy. F - FIFO, I - IOF/IRRF Optimization, T - Txn-Receipts, P - FIFO Across Products, H - Hierarchy |
MAINTAINTRADINGBOX |
NUMBER |
22 |
Optional |
Maintain Trading Box ? 1 - Yes, 0 - No |
NAVLOT |
NUMBER |
22 |
Optional |
NAV Lot |
CDSCFUND |
VARCHAR2 |
2 |
Optional |
CDSC Fund ? |
CDSCAPPLICABLEFORSWITCHES |
NUMBER |
22 |
Optional |
CDSC Applicable for Switches? 1 - Yes, 0 - No |
REINVESTMENTFIRST |
NUMBER |
22 |
Optional |
Reinvestment First. 1 - Yes, 0 - No |
VATVALUE |
NUMBER |
22 |
Optional |
VAT Percentage |
CHECKFEATUREEXISTS |
NUMBER |
22 |
Optional |
Allow Check Writing. 1 - Yes, 0 - No |
MINCHECKAMOUNT |
NUMBER |
22 |
Optional |
Minimum Amount For Checks |
MAXCHECKAMOUNT |
NUMBER |
22 |
Optional |
Maximum Amount For Checks |
MINCHECKHOLDINGPERIOD |
NUMBER |
22 |
Optional |
Minimum Holding Period (Days) |
CHECKACCOUNTCLOSURE |
NUMBER |
22 |
Optional |
Account Closure? 1 - Yes, 0 - No |
CHECKREDEMPTIONPENALTY |
NUMBER |
22 |
Optional |
Penalty Applicable ? 1 - Yes, 0 - No |
HOLDINGPERIODPENALTY |
NUMBER |
22 |
Optional |
Minimum Holding Period Violation . 1 - Yes, 0 - No |
BALANCEPENALTY |
NUMBER |
22 |
Optional |
Insufficient Account Balance. 1 - Yes, 0 - No |
STOPPAYMENTPENALTY |
NUMBER |
22 |
Optional |
Stop Payment Request on Check. 1 - Yes, 0 - No |
AMTLIMITPENALTY |
NUMBER |
22 |
Optional |
Minimum And Maximum Check Amount Violation. 1 - Yes, 0 - No |
INTERESTRATE |
NUMBER |
22 |
Optional |
Interest Rate |
PERFORMANCEFEETHRESHOLD |
NUMBER |
22 |
Optional |
Performance Fee Threshold |
LIMITORDERALLOWED |
NUMBER |
22 |
Optional |
Allow Limit Order. 1 - Yes, 0 - No |
FUTURELIMITORDERALLOWED |
NUMBER |
22 |
Optional |
Allow Future Dates Txn. 1 - Yes, 0 - No |
AUTOLIMITORDERPROCESS |
NUMBER |
22 |
Optional |
Automatic Processing. 1 - Yes, 0 - No |
PRICINGRULE |
VARCHAR2 |
1 |
Optional |
Pricing Rule. P - Prior, A - After |
MULTIPLEPRICEBASIS |
NUMBER |
22 |
Mandatory |
Multiple Price Basis. 1 - Yes, 0 - No |
MINHOLDINGAMOUNT |
NUMBER |
22 |
Optional |
Minimum Holdings Amount |
MINHOLDINGUNITS |
NUMBER |
22 |
Optional |
Minimum Holdings Units |
MINHOLDINGAPPLYFOR |
VARCHAR2 |
1 |
Optional |
Minimum Holdings Apply For. C - CIF, U - Unit Holder |
CANCELINSTRUCTION |
VARCHAR2 |
2 |
Optional |
Cancel Instruction |
MINHOLDINGINDICATOR |
VARCHAR2 |
1 |
Optional |
Minimum Holdings Indicator. N - Not Applicable, A - Amount, U - Units, L - Lower of Amount/Units, H - Higher of Amount/Units |
TXNCANCELLATIONALLOWED |
NUMBER |
22 |
Optional |
Transaction Cancellation Allowed. 1 - Yes, 0 - No |
TXNCANCELLATIONPERIOD |
NUMBER |
22 |
Optional |
Transaction Cancellation Period |
ALLOWSWITCHINGINCANCELPERIOD |
NUMBER |
22 |
Optional |
Allow Switching in Cancellation Period. 1 - Yes, 0 - No |
CANCELLATIONPRICEBASIS |
VARCHAR2 |
10 |
Optional |
Cancellation Price Basis |
MINTHRESHHOLDLIMIT |
NUMBER |
22 |
Optional |
Minimum Threshold Limit |
EUSDSCOPE |
VARCHAR2 |
1 |
Optional |
EUSD Scope. R - Redemption and Switch, D - Dividend, B - Both |
AGEINGDATE |
VARCHAR2 |
1 |
Optional |
Ageing Date. T - Transaction Date, C - Confirmation Date, D - Dealing Date |
INVESTMENTSIMULATIONMETHOD |
VARCHAR2 |
1 |
Optional |
Investment Simulation Method. N - Not Allowed, H - Historic NAV Based |
MINLOCKINPERIODFORGAIN |
NUMBER |
22 |
Optional |
Min Lock-In Period for Gain(Days) |
MAXLOCKINPERIODFORGAIN |
NUMBER |
22 |
Optional |
Max Lock-In Period for Gain(Days |
DEFAULTLOCKINPERIODFORGAIN |
NUMBER |
22 |
Optional |
Default Lock-In Period for Gain(Days) |
AMOUNTBLOCKALLOWED |
NUMBER |
22 |
Optional |
Amount Block Allowed. 1 - Yes, 0 - No |
CALCULATEFEEINTXNCCY |
NUMBER |
22 |
Mandatory |
Allow Fee Calculation In Transaction Currency. 1 - Yes, 0 - No |
INCLUDEHOLDINGPERIOD |
VARCHAR2 |
1 |
Optional |
Include Holding Period. 1 - Yes, 0 - No |
BLOCKPRIORITYNO |
NUMBER |
22 |
Optional |
Block Priority Number |
DIVIDENDEQAPPLICABLE |
NUMBER |
22 |
Optional |
Dividend Equalization Applicable. 1 - Yes, 0 - No |
FATCAAPPLICABLE |
NUMBER |
1 |
Optional |
FATCA Applicable |
VARCHAR2 |
25 |
Optional |
FATCAREASON |
VARCHAR2 |
255 |
Optional |
FATCA Reason |
FATCAEIN |
VARCHAR2 |
50 |
Optional |
FATCAEFFECTIVEDATE |
DATE |
10 |
Optional |
FATCA Effective Date |
UCITSFUND |
NUMBER |
1 |
Optional |
UCITS Fund 1 - Yes, 0 - No |
DILUTIONLEVYAPPLICABLE |
VARCHAR2 |
5 |
Optional |
Dilution Levy Applicable Y - Yes, N - No |
INFLOWBREACHFACTOR |
NUMBER |
5 |
Optional |
Inflow Breach Factor% |
OUTFLOWBREACHFACTOR |
NUMBER |
5 |
Optional |
Outflow Breach Factor% |
THRESHOLDBASIS |
VARCHAR2 |
12 |
Optional |
Threshold Basis A- Amount ,P- Percentage |
THRESHOLDVALUE |
NUMBER |
30 |
Optional |
Threshold Value |
SWINGPRICEBASIS |
NUMBER |
1 |
Optional |
Swinging Price Basis 1 - Yes, 0 - No,Semi-swingingPrice - 2 |
Serial Number: 6
Segment Identification Number: 05TRP
Description: This segment is used for providing information related to Transaction Processing Rules
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment ID - 05TRP |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
GROSSORNET |
VARCHAR2 |
1 |
Optional |
Gross or Net |
TRANSACTIONSTARTDATE |
DATE |
7 |
Optional |
Start Date |
TRANSACTIONENDDATE |
DATE |
7 |
Optional |
End Date |
TRANSACTIONFREQUENCY |
VARCHAR2 |
1 |
Optional |
Transaction Frequency |
TRANSACTIONSTARTPERIOD |
NUMBER |
22 |
Optional |
Start Period |
TRANSACTIONENDPERIOD |
NUMBER |
22 |
Optional |
End Period |
TRANSACTIONSTARTTIME |
DATE |
7 |
Optional |
Start Time (HH24:MI:SS) |
TRANSACTIONENDTIME |
DATE |
7 |
Optional |
End Time (HH24:MI:SS) |
MINTRANSACTIONAMOUNT |
NUMBER |
22 |
Optional |
Minimum Amount |
STEPAMOUNT |
VARCHAR2 |
22 |
Optional |
Step Amount |
MAXTRANSACTIONAMOUNT |
NUMBER |
22 |
Optional |
Maximum Amount |
MINTRANSACTIONUNITS |
NUMBER |
22 |
Optional |
Minimum Units |
STEPUNITS |
NUMBER |
22 |
Optional |
Step Units |
MAXTRANSACTIONUNITS |
NUMBER |
22 |
Optional |
Maximum Units |
ONLINEALLOCATION |
NUMBER |
22 |
Optional |
Online Allocation? 1 - Yes, 0 - No |
ALLOCATIONPERVSREGCAPITAL |
NUMBER |
22 |
Optional |
Allocation Percentage Versus Registered Capital |
ALLOCATIONPOLICY |
VARCHAR2 |
1 |
Optional |
Allocation Policy. F - FIFO, P - Proportionate |
NOOFTXNALLOWEDFORFREQ |
VARCHAR2 |
1 |
Optional |
Frequency.D - Daily, W - Weekly, F - Bi-Weekly, M - Monthly, Q - Quarterly, H - Half Yearly, Y - Yearly |
NOOFTXNALLOWEDPERUH |
NUMBER |
22 |
Optional |
Limit(No of Txn Allowed per UH) |
NOOFFREETXNALLOWEDPERUH |
NUMBER |
22 |
Optional |
Free(No of Free Txn Allowed per UH) |
ALLOWBACKDATING |
NUMBER |
22 |
Optional |
Back-Dating Allowed.1 - Yes, 0 - No |
BACKDATINGLIMIT |
NUMBER |
22 |
Optional |
Back-Dating Limit |
FUNDTRANSACTIONCOUNTER |
NUMBER |
22 |
Optional |
Counter(Fund Txn Counter) |
ACKNOWLEDGEMENTREQUIRED |
NUMBER |
22 |
Optional |
Acknowledgement Note Required.1 - Yes, 0 - No |
CONFIRMATIONREQUIRED |
NUMBER |
22 |
Optional |
Confirmation Note Required.1 - Yes, 0 - No |
BASEPRICEDEFINITION |
VARCHAR2 |
60 |
Optional |
Base Price Definition |
BASEPRICEFACTOR |
NUMBER |
22 |
Optional |
Base Price Factor (%) |
NOOFDECIMALSFORBASEPRICE |
NUMBER |
22 |
Optional |
Rounding Precision For Base Price |
ROUNDOFFTRUNCATEBASEPRICE |
VARCHAR2 |
1 |
Optional |
Rounding Options For Base Price. R - Round Off, T - Truncate |
TRANSACTIONENABLED |
NUMBER |
22 |
Optional |
Transaction Enabled.1 - Yes, 0 - No |
CROSSBRANCHALLOWED |
NUMBER |
22 |
Optional |
Cross-Branching Allowed. 1 - Yes, 0 - No |
PRICELAG |
NUMBER |
22 |
Optional |
Price Lag |
ALLOCATIONLAG |
NUMBER |
22 |
Optional |
Allocation Lag |
CONFIRMATIONLAG |
NUMBER |
22 |
Optional |
Confirmation Lag |
CHQALLOCONPARWITHCASH |
NUMBER |
22 |
Optional |
Check On Par With Cash. 1 - Yes, 0 - No |
HOLDINGPERIODAPPLICABLE |
NUMBER |
22 |
Optional |
Holding Period Applicable. 1 - Yes, 0 - No |
RETAINAGEINGTOSUBSCRIPTION |
NUMBER |
22 |
Optional |
Retain Ageing To Subscription. 1 - Yes, 0 - No |
CREDITCARDALLOCONPARWITHCASH |
NUMBER |
22 |
Optional |
Credit Card On Par With Cash. 1 - Yes, 0 - No |
LIMITREDEMPTIONMODE |
VARCHAR2 |
1 |
Optional |
Limit Mode. P - Percent, A - Amount, U - Units |
NATUREOFLIMIT |
VARCHAR2 |
1 |
Optional |
Carry Forward. C - Carry |
TRANSFERALLOCONPARWITHCASH |
NUMBER |
22 |
Optional |
Transfer On Par With Cash. 1 - Yes, 0 - No |
MININITIALTXNAMOUNT |
NUMBER |
22 |
Optional |
Min. Initial Transaction Amount |
MININITIALTXNUNITS |
NUMBER |
22 |
Optional |
Min. Initial Transaction Units |
MINSITXNAMOUNT |
NUMBER |
22 |
Optional |
SI Minimum Amount |
MAXSITXNAMOUNT |
NUMBER |
22 |
Optional |
SI Maximum Amount |
MINSITXNUNITS |
NUMBER |
22 |
Optional |
SI Minimum Units |
MAXSITXNUNITS |
NUMBER |
22 |
Optional |
SI Maximum Units |
EXISTINGUH |
VARCHAR2 |
2 |
Optional |
Restrict Sale to Investor. 1 - Yes, 0 - No |
NOOFDECIMALSFORUNITPRICE |
NUMBER |
22 |
Optional |
ROUNDOFFTRUNCATEUNITPRICE |
VARCHAR2 |
1 |
Optional |
Rounding Options For Unit Price.R - Round Off, T - Round Down, U - Round Up |
ROUNDOFFTRUNCATEUNITS |
VARCHAR2 |
1 |
Optional |
Rounding Options For Units.R - Round Off, T - Round Down, U - Round Up |
PAYMENTLAG |
NUMBER |
22 |
Optional |
Payment Lag (Days) |
TRANSACTIONCUTOFFTIME |
DATE |
7 |
Optional |
Cut Off Time(HH24:MI) |
CUTOFFTIME |
VARCHAR2 |
8 |
Optional |
ENFORCEHOLDINGPERIOD |
NUMBER |
22 |
Optional |
Enforce Holding Period. 1 - Yes, 0 - No |
APPLYENTRYTIMELOAD |
NUMBER |
22 |
Optional |
Apply Entry Time Load. 1 - Yes, 0 - No |
IPOMAXISSUESIZE |
NUMBER |
22 |
Optional |
Maximum IPO Issue Size |
TRANSACTIONSUSPENDED |
NUMBER |
1 |
Optional |
Transaction Suspended. 1 - Yes, 0 - No |
MINSIHOLDINGAMOUNT |
NUMBER |
22 |
Optional |
SI Minimum Holdings Amount |
MINSIHOLDINGUNITS |
NUMBER |
22 |
Optional |
SI Minimum Holdings Units |
MINSIHOLDINGAPPLYFOR |
VARCHAR2 |
1 |
Optional |
SI Minimum Holdings Apply For. C - CIF, U - Unit Holder |
MINSIHOLDINGINDICATOR |
VARCHAR2 |
1 |
Optional |
SI Minimum Holdings Indicator.N - Not Applicable, A - Amount, U - Units, L - Lower of Amount/Units, H - Higher of Amount/Units |
PRICELAGCALENDARBASIS |
VARCHAR2 |
1 |
Optional |
Price Lag Calendar Basis. C - Actual Calendar, S - System Calendar, F - Fund Calendar |
SIDESCRIPTION |
VARCHAR2 |
255 |
Optional |
Default SI Description |
SIHOLIDAYRULE |
VARCHAR2 |
1 |
Optional |
Holiday Rule. P - Prior, A - After |
SICALENDERBASIS |
VARCHAR2 |
1 |
Optional |
SIGENDAY |
VARCHAR2 |
3 |
Optional |
Specific Gen.Day |
SIFREQUENCY |
VARCHAR2 |
1 |
Optional |
Default SI Frequency |
SIGENCYCLE |
VARCHAR2 |
1 |
Optional |
SI Generation Freq. M - Monthly, Q - Quarterly, H - Half Yearly, Y - Yearly |
SICUTOFFDAY |
NUMBER |
22 |
Optional |
SI Cut-Off Day |
SICUTOFFLAG |
NUMBER |
22 |
Optional |
SI Cut-off Lag |
ENFORCESIRULE |
NUMBER |
22 |
Optional |
Enforce Generation |
PAYMENTLAGCALENDARBASIS |
VARCHAR2 |
1 |
Optional |
Payment Lag Calendar Basis. C - Actual Calendar, Y - Currency Calendar, S - System Calendar, F - Fund Calendar |
AMOUNTORUNITS |
VARCHAR2 |
1 |
Optional |
Amounts OR Units |
LINKTOUNSETTLEDINFLOWS |
NUMBER |
22 |
Optional |
Link To Unsettled Trades?. 1 - Yes, 0 - No |
PSEUDOSWITCHLAG |
NUMBER |
22 |
Optional |
Pseudo Switch Lag |
ALLOWSYSTEMATICPLANS |
NUMBER |
22 |
Optional |
Allow Systematic Plans?. 1 - Yes, 0 - No |
MAXINITIALTXNAMOUNT |
NUMBER |
22 |
Optional |
Max. Initial Transaction Amount |
MAXINITIALTXNUNITS |
NUMBER |
22 |
Optional |
Max. Initial Transaction Units |
PSEUDOSWITCHLAGCALENDARBASIS |
VARCHAR2 |
1 |
Optional |
Pseudo Switch Calendar Basis. C - Actual Calendar, S - System Calendar, F - Fund Calendar |
FULLOUTFLOW |
NUMBER |
22 |
Optional |
Full Outflow. 1 - Yes, 0 - No |
MAXNOOFSITRANSACTIONS |
NUMBER |
22 |
Optional |
Max No. of SI Txns |
MAXVALIDITY |
NUMBER |
22 |
Optional |
Max. Validity(Days) |
SILEADTIME |
NUMBER |
22 |
Optional |
SI Lead Time |
APPLICABLEACCOUNTTYPES |
VARCHAR2 |
255 |
Optional |
Applicable Account Types |
INFLOWOVERRIDABLEMSG |
NUMBER |
22 |
Optional |
Inflow Overridable Msg. 1 - Yes, 0 - No |
MINMATURITYPERIOD |
NUMBER |
22 |
Optional |
Min. Maturity Period (Days) |
MAXMATURITYPERIOD |
NUMBER |
22 |
Optional |
Max. Maturity Period (Days) |
FUTUREDATELIMIT |
NUMBER |
22 |
Optional |
Future Date Limit |
UHCALENDARBASIS |
VARCHAR2 |
2 |
Optional |
Cycle Basis |
NUMBER |
22 |
Optional |
No. of Decimals |
NOTICEPERIODDATEBASIS |
VARCHAR2 |
1 |
Optional |
Notice Period Date Basis.C - Actual Calendar, S - System Calendar |
NOTICEPERIOD |
NUMBER |
22 |
Optional |
Notice Period |
SIAUTOTERMINATIONCOUNTER |
VARCHAR2 |
3 |
Optional |
SI Auto-Termination Cumulative Counter |
CONSSIAUTOCOUNTER |
NUMBER |
22 |
Optional |
SI Auto-Termination Consecutive Counter |
THRESHOLDAMOUNT |
NUMBER |
22 |
Optional |
Transaction Threshold Amount |
GOCUTOFFLAG |
VARCHAR2 |
8 |
Optional |
GO Cut Off Lag(HH24:MI) |
GOTHRESHOLDUNITS |
NUMBER |
27 |
Optional |
GO Threshold Units |
GOSETTLEMENTLAG |
NUMBER |
22 |
Optional |
GO Settlement Lag |
GOSETTLAGCALENDAR |
VARCHAR2 |
1 |
Optional |
GO Settlement Lag Calendar |
Serial Number: 7
Segment Identification Number: 06TRC
Description: This segment is used for providing information related to Transaction Processing Rules Communication Mode
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 06TRC |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type. 02 - Subscription, 03 - Redemption, 04 - Switch, 54 - Transfer |
COMMUNICATIONMODE |
VARCHAR2 |
2 |
Mandatory |
NUMBER |
22 |
Optional |
Minimum Transaction Amount |
NUMBER |
22 |
Optional |
Maximum Transaction Amount |
NUMBER |
22 |
Optional |
Minimum Transaction Units |
NUMBER |
22 |
Optional |
Maximum Transaction Units |
DISALLOWFIRSTTRANSACTION |
NUMBER |
22 |
Optional |
Disallow First Transaction. 0 - No, 1 - Yes |
Serial Number: 8
Segment Identification Number: 07FIC
Description: This segment is used for providing information related to Fund Investor Category Transaction Limits
Data type |
Length |
Mandatory/Optional |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 07FIC |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
INVESTORCATEGORY |
VARCHAR2 |
2 |
Mandatory |
Investor Category |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
NUMBER |
22 |
Optional |
STEPAMOUNT |
VARCHAR2 |
22 |
Optional |
Step Amount |
NUMBER |
22 |
Optional |
NUMBER |
22 |
Optional |
STEPUNITS |
NUMBER |
22 |
Optional |
Step Units |
NUMBER |
22 |
Optional |
Serial Number: 9
Segment Identification Number: 08FSF
Description: This segment is used for providing information related to Fund SI Frequency Details
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment id - 08FSF |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
FREQUENCY |
VARCHAR2 |
1 |
Mandatory |
Frequency |
FREQID |
VARCHAR2 |
10 |
Mandatory |
Freq ID |
MINSITXNAMOUNT |
NUMBER |
22 |
Optional |
Minimum SI Transaction Amount |
MAXSITXNAMOUNT |
NUMBER |
22 |
Optional |
Maximum SI Transaction Amount |
MINSITXNUNITS |
NUMBER |
22 |
Optional |
Minimum SI Transaction Units |
MAXSITXNUNITS |
NUMBER |
22 |
Optional |
Maximum SI Transaction Units |
NUMBER |
22 |
Optional |
Minimum SI Holding Amount |
MINSIHOLDINGUNITS |
NUMBER |
22 |
Optional |
Minimum SI Holding Units |
VARCHAR2 |
1 |
Optional |
SI Minimum Holdings Apply For. C - CIF, H - Unit Holder |
VARCHAR2 |
1 |
Mandatory |
MINNOOFSI |
NUMBER |
22 |
Optional |
Minimum Number of SI |
NOOFFAILURESALLOWED |
NUMBER |
22 |
Optional |
Number of failures Allowed |
HOLIDAYRULE |
VARCHAR2 |
1 |
Optional |
Holiday Rule |
VARCHAR2 |
3 |
Optional |
Maximum SI Transaction Allowed |
CONSSIAUTOCOUNTER |
NUMBER |
22 |
Optional |
SI Auto Termination Counter |
MAXSITXNSALLOWED |
NUMBER |
22 |
Optional |
Serial Number: 10
Segment Identification Number: 09FSC
Description: This segment is used for providing information related to Fund Sale Country
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 09FSC |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
COUNTRYCODE |
VARCHAR2 |
3 |
Optional |
Country Code |
Serial Number: 11
Segment Identification Number: 10FRL
Description: This segment is used for providing information related to Fund Residency Country
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 10FRL |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
COUNTRYCODE |
VARCHAR2 |
3 |
Optional |
Country Code |
Serial Number: 12
Segment Identification Number: 11FTC
Description: This segment is used for providing information related to Fund Transaction Currency
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 11FTC |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
COUNTRYCODE |
VARCHAR2 |
3 |
Optional |
Country Code |
Serial Number: 13
Segment Identification Number: 12IDR
Description: This segment is used for providing information related to Income Distribution Rule
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
DIVIDENDDECLAREFREQ |
VARCHAR2 |
1 |
Optional |
Dividend Declare Frequency.D - Daily, F - Bi-Weekly, H - Half-Yearly, M - Monthly, Q - Quarterly, W - Weekly, Y - Yearly |
DIVIDENDPAYMENTFREQ |
VARCHAR2 |
1 |
Optional |
Dividend Payment Frequency.D - Daily, F - Bi-Weekly, H - Half-Yearly, M - Monthly, Q - Quarterly, W - Weekly, Y - Yearly |
REINVESTMENTALLOWED |
NUMBER |
22 |
Optional |
Reinvestment Allowed ? 1 - Yes, 0 - No |
TAXID |
VARCHAR2 |
50 |
Optional |
Tax ID |
BOOKCLOSINGLEADTIME |
NUMBER |
22 |
Optional |
Book Closing Lead Time |
FREEZEHOLDINGLEADTIME |
NUMBER |
22 |
Optional |
Freeze Holding Lead Time |
BOARDMEETINGLEADTIME |
NUMBER |
22 |
Optional |
Board Meeting Lead Time |
DIVIDENDPAYMENTLEADTIME |
NUMBER |
22 |
Optional |
Dividend Payment Lead Time |
NOOFDECIMALSFORDIVIDEND |
NUMBER |
22 |
Optional |
Number of Decimals For Dividend |
ROUNDOFFTRUNCATEDIVIDEND |
VARCHAR2 |
1 |
Optional |
Round OFF Truncate Dividend |
TDSBASIS |
VARCHAR2 |
1 |
Optional |
TDS Basis.D - Each Dividend, U - Fiscal Year, E - Tax Exempt |
EPUCOMPONENTS |
NUMBER |
22 |
Optional |
EPU Based on Components?1 - Yes, 0 - No |
DEFAULTDISTRIBUTIONMODE |
VARCHAR2 |
1 |
Optional |
Default Distribution Mode. T - Payout-A/C Transfer, Q - Payout-Check, R - Full Reinvestment |
EXCHANGERATEDATEBASIS |
VARCHAR2 |
1 |
Optional |
Dividend Exchange Rate Basis.P - Payment Date, R - Reference Date |
RESTRICTIDS |
NUMBER |
22 |
Optional |
Restrict IDS For Unit Holder?1 - Yes, 0 - No |
EPULOT |
NUMBER |
22 |
Optional |
EPU Lot |
DIVLOOKAHEAD |
NUMBER |
22 |
Optional |
Look Ahead Processing? 1 - Yes, 0 - No |
CORPORATEACTIONTYPE |
VARCHAR2 |
1 |
Mandatory |
Corporate Action Type |
UNITSFORFREEZEHOLDINGS |
VARCHAR2 |
1 |
Optional |
Units For Freeze Holdings. A - All Units As Of Allocation Date, C - Confirmed Units As Of Allocation Date, P - All Units As Of Price Date, T - Confirmed Units As Of Transaction Date, D - All Units As Of Transaction Date, U - All Units As Of Dealing Date |
FIRSTDIVIDENDDECLAREDATE |
DATE |
7 |
Optional |
First Dividend Declare Date |
SPECIALDIVIDEND |
NUMBER |
22 |
Optional |
Special Dividend.1 - Yes, 0 - No |
MOCKDIVIDEND |
NUMBER |
22 |
Optional |
Mock Dividend.1 - Yes, 0 - No |
HOLIDAYRULE |
VARCHAR2 |
1 |
Optional |
Holiday Rule. |
PAYMENTLAG |
NUMBER |
22 |
Optional |
PAYDIVIDENDDURINGRED |
NUMBER |
22 |
Optional |
Pay Dividend During Redemption.1 - Yes, 0 - No |
REINVESTMENTPRICEBASIS |
VARCHAR2 |
10 |
Optional |
Reinvestment Price Basis |
IRACOMPULSORYREINVEST |
NUMBER |
22 |
Optional |
Compulsory Reinvestment For Retirement Account? 1 - Yes, 0 - No |
DISTRIBUTIONMODEFORMINBALANCE |
VARCHAR2 |
1 |
Mandatory |
Distribution Mode For Minimum Balance. P - Forced Payout, I - According To Unit Holder IDS |
DEFAULTEPUOFPREVDAY |
VARCHAR2 |
1 |
Optional |
Default EPU to previous Declared EPU? 1 - Yes, 0 - No |
INTERESTCOMPOUNDED |
VARCHAR2 |
1 |
Optional |
Interest to be compounded for the payment Period? Y - Yes, N - No |
NPISUPPORT |
VARCHAR2 |
1 |
Mandatory |
NPI Applicable.Y - Yes, N - No |
NPIPAYMENT |
VARCHAR2 |
3 |
Optional |
NPI Payment |
NPIUHOVERRIDE |
VARCHAR2 |
1 |
Mandatory |
Override Unit holder preference? Y - Yes, N - No |
FLGUNSETTLEUNITS |
VARCHAR2 |
1 |
Mandatory |
Force Reinvestment of Uncleared units |
MIMAMTTOBEPAIDOUT |
NUMBER |
22 |
Optional |
Minimum Amount for Payment |
ACTION |
VARCHAR2 |
1 |
Optional |
Action |
OVERRATPAYTIME |
NUMBER |
22 |
Optional |
Override at Pay Time Y - Yes, N - No |
AUTOREINVFORUNCLCHQ |
NUMBER |
22 |
Optional |
Auto Reinvestment for Unclaimed Dividend. 1 - Yes, 0 - No |
AUTOREINVFORUNCLCHQFZB |
NUMBER |
22 |
Optional |
Auto Reinvestment for Unclaimed Dividend When No Balance Left. 1 - Yes, 0 - No |
TRACKUNCLEAREDTXNS |
VARCHAR2 |
1 |
Optional |
Track Dividend For Uncleared Transaction? 1 - Yes, 0 - No |
TRACKBLOCKEDTXNS |
VARCHAR2 |
1 |
Optional |
Track Dividend for Blocked Transactions? 1 - Yes, 0 - No |
PAYUNGENREINVESTMENT |
VARCHAR2 |
1 |
Optional |
Pay Ungenerated Reinvestments? 1 - Yes, 0 - No |
TDSAPPLICABLEFORALLUH |
NUMBER |
22 |
Optional |
TDS Applicable for all UH. 1 - Yes, 0 - No |
MINAMTTOREINVEST |
NUMBER |
30 |
Optional |
Minimum Amount for Reinvestment |
Serial Number: 14
Segment Identification Number: 13FLM
Description: This segment is used for providing information related to Fund Load Maintenance
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 13FLM |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
Rule Effective date |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
LOADID |
NUMBER |
22 |
Mandatory |
Load ID |
LOADTOPRICE |
NUMBER |
22 |
Optional |
Load To Price |
FROMENTITYTYPE |
VARCHAR2 |
1 |
Mandatory |
From EntityType |
TOENTITYTYPE |
VARCHAR2 |
1 |
Mandatory |
To Entity Type |
PROCESSINGFREQ |
VARCHAR2 |
1 |
Optional |
Processing Frequency |
GLACCOUNTCODE |
VARCHAR2 |
10 |
Optional |
GL account Code |
DEBITORCREDIT |
VARCHAR2 |
1 |
Optional |
Debit or Credit |
CONTRAACCOUNTCODE |
VARCHAR2 |
10 |
Optional |
Contra Account Code |
NOOFDECIMALSFORLOAD |
NUMBER |
22 |
Optional |
Number of Decimals For Load |
ROUNDOFFTRUNCATEFORLOAD |
VARCHAR2 |
1 |
Optional |
Round OFF Truncate For Load |
MANDATORY |
VARCHAR2 |
1 |
Optional |
Mandatory |
PRIORITYNO |
NUMBER |
22 |
Optional |
Priority Number |
LOADVATTOPRICE |
NUMBER |
22 |
Optional |
Load VAT To Price |
APPLYRETVALON |
VARCHAR2 |
1 |
Optional |
Based On Income? G - Capital Gains - Gross, N - Non Capital Gains - Net, C - Capital Gains, S - CDSC, P - Performance Based, I - IOF, D - Default IRRF, O - Optional IRRF |
SENDFORGLINTERFACE |
NUMBER |
22 |
Optional |
Send For GL Interface. 1 - Yes, 0 - No |
DIFFERENTIALFEE |
NUMBER |
22 |
Optional |
Differential Fee? 1 - Yes, 0 - No |
SLABBASIS |
VARCHAR2 |
1 |
Optional |
Slab Basis. G - Gross Amount, N - Net Amount, A - Average Cost |
PRICEADDIN |
NUMBER |
22 |
Optional |
Price Add In. 1 - Yes, 0 - No |
INDEXATIONONCGT |
VARCHAR2 |
1 |
Optional |
Apply Indexation on CGT? 1 - Yes, 0 - No |
LEVELID |
NUMBER |
22 |
Optional |
Level ID |
GROUPID |
VARCHAR2 |
6 |
Mandatory |
Group Id |
DEPENDENTLEVEL |
NUMBER |
22 |
Optional |
Dependent Level |
REFTYPE |
VARCHAR2 |
2 |
Mandatory |
RefType |
Serial Number: 15
Segment Identification Number: 14FFM
Description: This segment is used for providing information related to Fund Formula Maintenance
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 14FFM |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
COMPONENTID |
VARCHAR2 |
10 |
Mandatory |
Component ID |
COMPONENTDESC |
VARCHAR2 |
50 |
Optional |
COMPONENTTYPE |
VARCHAR2 |
5 |
Optional |
Component Type |
FORMULA |
VARCHAR2 |
255 |
Optional |
Formula |
DEFAULTVALUE |
NUMBER |
22 |
Optional |
Default Value |
EXCLUDEFROMCAPITALGAINS |
NUMBER |
22 |
Optional |
Exclude From Capital Gains? 1 - Yes, 0 - No |
USEDFORFPCOMPUTATION |
NUMBER |
22 |
Mandatory |
Used for FP Computation ? 1 - Yes, 0 - No |
PRICEBASIS |
VARCHAR2 |
1 |
Mandatory |
Price Basis. Y - Yes, N - No |
PARENTPRICEBASIS |
VARCHAR2 |
10 |
Optional |
Parent Basis |
INHERENTFEE |
NUMBER |
22 |
Optional |
Inherent Fee |
INHERENTINCENTIVE |
NUMBER |
22 |
Optional |
Inherent Incentive |
DEFAULTPRICEBASE |
VARCHAR2 |
1 |
Mandatory |
Default Price Basis. ON - Y, OFF - N |
Serial Number: 16
Segment Identification Number: 15FAI
Description: This segment is used for providing information related to Fund Additional Information
Segment Mandatory / Optional: Optional
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 15FAI |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
12 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
OTHERINFO1 |
VARCHAR2 |
60 |
Optional |
Other Information 1 |
OTHERINFO2 |
VARCHAR2 |
60 |
Optional |
Other Information 2 |
OTHERINFO3 |
VARCHAR2 |
60 |
Optional |
Other Information 3 |
OTHERINFO4 |
VARCHAR2 |
60 |
Optional |
Other Information 4 |
OTHERINFO5 |
VARCHAR2 |
60 |
Optional |
Other Information 5 |
OTHERINFO6 |
VARCHAR2 |
60 |
Optional |
Other Information 6 |
OTHERINFO7 |
VARCHAR2 |
60 |
Optional |
Other Information 7 |
OTHERINFO8 |
VARCHAR2 |
60 |
Optional |
Other Information 8 |
OTHERINFO9 |
VARCHAR2 |
60 |
Optional |
Other Information 9 |
OTHERINFO10 |
VARCHAR2 |
60 |
Optional |
Other Information 10 |
OTHERINFO11 |
VARCHAR2 |
60 |
Optional |
Other Information 11 |
OTHERINFO12 |
VARCHAR2 |
60 |
Optional |
Other Information 12 |
OTHERINFO13 |
VARCHAR2 |
60 |
Optional |
Other Information 13 |
OTHERINFO14 |
VARCHAR2 |
60 |
Optional |
Other Information 14 |
OTHERINFO15 |
VARCHAR2 |
60 |
Optional |
Other Information 15 |
OTHERINFO16 |
VARCHAR2 |
60 |
Optional |
Other Information 16 |
OTHERINFO17 |
VARCHAR2 |
60 |
Optional |
Other Information 17 |
OTHERINFO18 |
VARCHAR2 |
60 |
Optional |
Other Information 18 |
OTHERINFO19 |
VARCHAR2 |
60 |
Optional |
Other Information 19 |
OTHERINFO20 |
VARCHAR2 |
60 |
Optional |
Other Information 20 |
OTHERINFO21 |
VARCHAR2 |
60 |
Optional |
Other Information 21 |
OTHERINFO22 |
VARCHAR2 |
60 |
Optional |
Other Information 22 |
OTHERINFO23 |
VARCHAR2 |
60 |
Optional |
Other Information 23 |
OTHERINFO24 |
VARCHAR2 |
60 |
Optional |
Other Information 24 |
OTHERINFO25 |
VARCHAR2 |
60 |
Optional |
Other Information 25 |
OTHERINFO26 |
VARCHAR2 |
60 |
Optional |
Other Information 26 |
OTHERINFO27 |
VARCHAR2 |
60 |
Optional |
Other Information 27 |
OTHERINFO28 |
VARCHAR2 |
60 |
Optional |
Other Information 28 |
OTHERINFO29 |
VARCHAR2 |
60 |
Optional |
Other Information 29 |
OTHERINFO30 |
VARCHAR2 |
60 |
Optional |
Other Information 30 |
Serial Number: 17
Segment Identification Number: 16SDS
Description: This segment is used for providing information related to Specific Fund Price date Setup
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 16SDS |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
FIRSTPRICEDATE |
DATE |
7 |
Mandatory |
First Price Date |
PRICEFREQUENCY |
VARCHAR2 |
1 |
Mandatory |
Price Frequency.D - Daily, W - Weekly, F - Fortnightly, M - Monthly, Q - Quarterly, H - Half-Yearly, Y - Yearly, U - User Defined |
HOLIDAYRULE |
VARCHAR2 |
1 |
Mandatory |
LASTPRICEDATE |
DATE |
7 |
Mandatory |
Last Price Date |
FORWARDPRICING |
NUMBER |
22 |
Mandatory |
Forward Pricing Applicable. 0 - No, 1 - Yes |
CALENDARBASIS |
VARCHAR2 |
1 |
Optional |
Calendar Basis. S - System Calender, C - Actual Calender, F - Fund Calender |
PRICEDAY |
NUMBER |
22 |
Optional |
Price Day |
PRICEWEEK |
NUMBER |
22 |
Optional |
Price Week |
PRICEMONTH |
NUMBER |
22 |
Optional |
Price Month |
CUTOFFDAY |
NUMBER |
22 |
Optional |
Cut OFF Day |
CUTOFFWEEK |
NUMBER |
22 |
Optional |
Cut OFF Week |
CUTOFFMONTH |
NUMBER |
22 |
Optional |
Cut OFF Month |
AUTOGENERATE |
NUMBER |
22 |
Optional |
Auto Generate ? |
GENERATIONTYPE |
VARCHAR2 |
1 |
Optional |
Auto Generation Of Fund Prices. A - Auto Generate Fund Prices using the last available Price and Authorize the same, U - Auto Generate Fund Prices using the last available Price but do not Authorize the same, "" - Do not Auto Generate Fund Prices |
CUTOFFFREQUENCY |
VARCHAR2 |
1 |
Optional |
Cut-Off Frequency. D - Daily, W - Weekly, F - Fortnightly, M - Monthly, Q - Quarterly, H - Half-Yearly, Y - Yearly |
LASTWORKINGDAY |
NUMBER |
22 |
Optional |
Last Working Day. ON - Y, OFF - N |
DEALINGLAG |
NUMBER |
22 |
Optional |
Dealing Lag (in days) |
DEALINGRULE |
VARCHAR2 |
1 |
Optional |
Dealing Rule. P - Prior, A - After |
PRICEDEFBASIS |
VARCHAR2 |
1 |
Optional |
Price Frequency Definition |
Serial Number: 18
Segment Identification Number: 17FPD
Description: This segment is used for providing information related to Fund User Defined Price Dates
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 17FPD |
PROCESSID |
VARCHAR2 |
50 |
Optional |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
PRICEDATE |
DATE |
7 |
Mandatory |
Price Date |
Serial Number: 19
Segment Identification Number: 18IRA
Description: This segment is used for providing information related to Fund IRA
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 18IRA |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
MININITIALINVESTMENTAMT |
NUMBER |
22 |
Optional |
Minimum Initial Investment amount |
MAXINITIALINVESTMENTAMT |
NUMBER |
22 |
Optional |
Maximum Initial Investment amount |
MININVESTMENTAMT |
NUMBER |
22 |
Optional |
Minimum Investment amount |
MAXINVESTMENTAMT |
NUMBER |
22 |
Optional |
Maximum Investment amount |
MINWITHDRAWALAMT |
NUMBER |
22 |
Optional |
Minimum Withdrawal amount |
MAXWITHDRAWALAMT |
NUMBER |
22 |
Optional |
Maximum Withdrawal amount |
Serial Number: 20
Segment Identification Number: 19FDI
Description: This segment is used for providing information related to Fund Delivery Instruction
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id - 19FDI |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
REGISTEREDACCOUNT |
NUMBER |
22 |
Optional |
Registered Unit Holder Account. 0 - No, 1 - Yes |
DELIVERYTOCUSTODIAN |
NUMBER |
22 |
Optional |
Deliver to Custodian Account. 0 - No, 1 - Yes |
DELIVERYTOCLGAGENT |
NUMBER |
22 |
Optional |
Deliver to Clearing Agent. 0 - No, 1 - Yes |
PHYSICALCERTDELIVERY |
NUMBER |
22 |
Optional |
Physical Delivery-Certificate option. 0 - No, 1 - Yes |
DEFAULTDELIVERY |
VARCHAR2 |
1 |
Optional |
Default Account. R - Registered Unit Holder Account, C - Deliver to Custodian Account, A - Deliver to Clearing Agent, P - Physical Delivery-Certificate option |
CERTIFICATEDENOMINATIONS |
VARCHAR2 |
200 |
Optional |
Certificate Denomination |
PUEV |
NUMBER |
22 |
Optional |
PUEV.0 - No, 1 - Yes |
Serial Number: 21
Segment Identification Number: 20FIA
Description: This segment is used for providing information related to Fund Investment Account
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id -20FIA |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
ACCOUNTTYPE |
VARCHAR2 |
2 |
Optional |
Account Type |
STARTDATE |
DATE |
7 |
Optional |
Start Date |
ENDDATE |
DATE |
7 |
Mandatory |
End Date |
MINORAGE |
NUMBER |
22 |
Mandatory |
Minor Age |
Serial Number: 22
Segment Identification Number: 21FIS
Description: This segment is used for providing information related to Fund investment Account SI
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id -21FIS |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Mandatory |
Transaction Type |
ACCOUNTTYPE |
VARCHAR2 |
2 |
Mandatory |
Account Type |
SIDESCRIPTION |
VARCHAR2 |
255 |
Optional |
SI Description |
SIFREQUENCY |
VARCHAR2 |
1 |
Optional |
SI Frequency. D - Daily, M - Monthly, Q - Quarterly, W - Weekly, Y - Yearly, F - Bi-Weekly, H - Half-Yearly |
SIGENDAY |
VARCHAR2 |
3 |
Optional |
SI Generation day |
SIGENCYCLE |
VARCHAR2 |
1 |
Optional |
SI Generation day. M - Monthly, Q - Quarterly, H - Half Yearly, Y - Yearly |
MINSITXNAMOUNT |
NUMBER |
22 |
Optional |
SI Minimum Amount |
MAXSITXNAMOUNT |
NUMBER |
22 |
Optional |
SI Maximum Amount |
MINSITXNUNITS |
NUMBER |
22 |
Optional |
SI Minimum Units |
MAXSITXNUNITS |
NUMBER |
22 |
Optional |
SI Maximum Units |
HOLIDAYRULE |
VARCHAR2 |
1 |
Mandatory |
CALENDERBASIS |
VARCHAR2 |
1 |
Mandatory |
Calender Basis. S - System Calender, C - Actual Calender, F - Fund Calender |
SICUTOFFDAY |
NUMBER |
22 |
Optional |
SI Cut-Off Day |
SICUTOFFLAG |
NUMBER |
22 |
Mandatory |
SI Cut-off Lag |
ENFORCESIRULE |
VARCHAR2 |
1 |
Mandatory |
Enforce Generation. 0 - No, 1 - Yes |
NUMBER |
22 |
Optional |
MAXVALIDITY |
NUMBER |
22 |
Optional |
VARCHAR2 |
3 |
Optional |
SI Auto-Termination Counter |
LASTDAYOFSIGENCYCLE |
NUMBER |
22 |
Optional |
Last Day of SI Gen Cycle. 0 - No, 1 - Yes |
CONSSIAUTOCOUNTER |
NUMBER |
22 |
Optional |
MAXSITXNSALLOWED |
NUMBER |
22 |
Optional |
Maximum SI Transactions Allowed |
Serial Number: 23
Segment Identification Number: 22KYC
Description: This segment is used for providing information related to KYC Fund
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id -22KYC |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
DOCUMENTDESCRIPTION |
VARCHAR2 |
255 |
Mandatory |
Document Description |
Serial Number: 24
Segment Identification Number: 23HFR
Description: This segment is used for providing information related to Hedge Fund Rules
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id -23HFR |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
HFUNDTYPE |
VARCHAR2 |
1 |
Mandatory |
Hedge Fund Type. S - Single/Simple, M - Master, O - Fund of Hedge Funds, P - Side Pockets, L - Lead Series, F - Follow Up Series |
TXNGENERATIONBASIS |
VARCHAR2 |
1 |
Optional |
Transaction Generation Basis. N - Net, O - Non Net, T - Non Net Transaction |
MASTERFUNDUHID |
VARCHAR2 |
12 |
Optional |
Master Fund UH ID |
PFCOMPUMETHOD |
VARCHAR2 |
4 |
Optional |
Computation Method |
PFACCRUALFREQ |
VARCHAR2 |
1 |
Optional |
Accrual Frequency. D - Daily, W - Weekly, M - Monthly, Q - Quarterly, Y - Yearly |
PFPAYMENTFREQ |
VARCHAR2 |
1 |
Optional |
Payment Frequency. M - Monthly, Q - Quarterly, H - Half Yearly, Y - Yearly |
HURDLERATEAPPLICABLE |
VARCHAR2 |
1 |
Optional |
Hurdle Rate Applicable.Y - Yes, N - No |
HURDLETYPE |
VARCHAR2 |
1 |
Optional |
Hurdle Type. C - Cumulative, N - Non Cumulative |
RESETHURDLE |
VARCHAR2 |
1 |
Optional |
Reset Hurdle.Y - Yes, N - No |
HURDLERATETYPE |
VARCHAR2 |
20 |
Optional |
Hurdle Rate Type. F - Fixed, V - Variable, S - Semi Variable |
PERFORMANCEFEEPER |
NUMBER |
22 |
Optional |
Performance Fee (%) |
RATECODE |
VARCHAR2 |
10 |
Optional |
Rate Code |
HFUNDMANAGER |
VARCHAR2 |
12 |
Mandatory |
Hedge Fund Manager |
RATEBASIS |
VARCHAR2 |
1 |
Optional |
Rate Basis. 1 - Percentage (%), 2 - Basic Points |
RATE |
NUMBER |
22 |
Optional |
Rate |
LASTACCRUALDATE |
DATE |
7 |
Optional |
Last Accrual Date |
LASTPAYMENTDATE |
DATE |
7 |
Optional |
Last Payment Date |
NEXTACCRUALDATE |
DATE |
7 |
Optional |
Next accrual Date |
NEXTPAYMENTDATE |
DATE |
7 |
Optional |
Next Payment Date |
GROUPID |
VARCHAR2 |
10 |
Optional |
Group ID |
HURDLECALCMETHOD |
VARCHAR2 |
1 |
Optional |
Hurdle Calculation Method. S - Simple, C - Compound |
DAYBASIS |
VARCHAR2 |
1 |
Optional |
Day Basis.1 - Actual, 2 - 360, 3 - 365 |
Serial Number: 25
Segment Identification Number: 24HFL
Description: This segment is used for providing information related to Hedge Fund Link
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id -24HFL |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
HEDGEFUNDID |
VARCHAR2 |
6 |
Optional |
Hedge Fund ID |
PERCENTAGE |
NUMBER |
22 |
Optional |
Percentage |
UNITHOLDERID |
VARCHAR2 |
12 |
Mandatory |
Unit Holder ID |
Serial Number: 26
Segment Identification Number: 25HFC
Description: This segment is used for providing information related to Hedge Fund Investor Category Performance Fee
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id -25HFC |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
INVCATEGORYID |
VARCHAR2 |
12 |
Optional |
Investor Category ID |
PERFORMANCEFEE |
NUMBER |
22 |
Optional |
Performance Fee |
Serial Number: 27
Segment Identification Number: 26MID
Description: This segment is used for providing information related to Multi Distribution Details
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
20 |
Mandatory |
Segment Id -26MID |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
Sequence Number |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
7 |
Mandatory |
VARCHAR2 |
3 |
Optional |
DISTRIBUTIONTYPE |
VARCHAR2 |
3 |
Optional |
Distribution Type |
Column name (as expected in the file) |
Data type |
Length |
Mandatory? |
Description |
REINVESTMENTUNITHOLDERID |
String |
12 |
Mandatory |
For unit holder income distribution setup records, this is the same as the unit holder ID and is defaulted during processing. |
REINVESTMENTFUNDID |
String |
6 |
Mandatory |
The ID of the fund into which the income is being reinvested. The reinvestment fund ID should be unique for an income distribution setup record. |
SPLITPERCENTAGE |
Number |
5, 2 |
Mandatory |
The split percentage to indicate the percentage of income that must be reinvested into the reinvestment fund. The sum of the split percentages for an income distribution setup should add up to one hundred. |
Serial Number: 29
Segment Identification Number: 28PCH
Description: This segment is used to capture the fund price currencies
Segment Mandatory/ Optional: Optional
Data type |
Length |
Mandatory |
Characteristics/ rules |
Values |
PROCESSID |
VARCHAR2 |
50 |
Yes |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Yes |
Sequence Number |
SEGMENTID |
VARCHAR2 |
20 |
No |
Segment id |
FUNDID |
VARCHAR2 |
6 |
Yes |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
Yes |
CURRENCYCODE |
VARCHAR2 |
3 |
Yes |
The currency code which is added as the fund price ccy |
MINHOLDINGAMOUNT |
NUMBER |
22 |
No |
The minimum holding amount for the corresponding FPC |
Serial Number: 30
Segment Identification Number: 29PCD
Description: This segment is used to capture the details of the fund price currencies
Data type |
Length |
Mandatory |
Values |
PROCESSID |
VARCHAR2 |
50 |
Yes |
Process ID |
SEQUENCENUMBER |
NUMBER |
10 |
Yes |
Sequence Number |
SEGMENTID |
VARCHAR2 |
20 |
No |
Segment id |
FUNDID |
VARCHAR2 |
6 |
Yes |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
Yes |
CURRENCYCODE |
VARCHAR2 |
3 |
Yes |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Yes |
Transaction type mapped |
NUMBER |
22 |
Yes |
Min. Transaction Amount |
NUMBER |
22 |
Yes |
Max. Transaction Amount |
NUMBER |
22 |
No |
NUMBER |
22 |
Yes |
STEPAMOUNT |
NUMBER |
22 |
Yes |
Step amount |
MINSITXNAMOUNT |
NUMBER |
22 |
No |
Min. SI Transaction Amount |
MAXSITXNAMOUNT |
NUMBER |
22 |
No |
Max. SI Transaction Amount |
Serial Number: 31
Segment Identification Number: 30FSR
Description: This segment is used to capture the share class restriction details
Data type |
Length |
Mandatory |
Values |
SEGMENTID |
VARCHAR2 |
20 |
No |
Segment ID |
PROCESSID |
VARCHAR2 |
50 |
Yes |
Process id |
SEQUENCENUMBER |
NUMBER |
10 |
Yes |
Sequence number |
FUNDID |
VARCHAR2 |
6 |
Yes |
Fund ID |
RULEEFFECTIVEDATE |
DATE |
Yes |
RESTRICTEDFUND |
NUMBER |
22 |
No |
Cannot be marked as Yes if fund risk level is not null |
RESTRICTIONAPPLIEDTO |
VARCHAR2 |
1 |
No |
Allowed/disallowed list of transaction types |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Yes |
Transaction type |
REFTYPE |
VARCHAR2 |
2 |
Yes |
Ref type |
Note
For all imports of unit holder deal information, the external hand-off file containing the information must
Data type |
Field length |
Mandatory |
Characteristics / rules |
Values |
SEQUENCENUMBER |
Number |
number(10) |
Mandatory |
System generated sequence number for the records in the file |
PROCESSID |
String |
varchar2(50) |
Mandatory |
The Process ID, along with the system generated sequence number, identifies the uploaded record uniquely. Each file must have a unique Process ID. This should be same for all records within a file. |
BULKCLIENTCODE |
String |
varchar2(12) |
Mandatory |
The Code of the Bulk client. |
IMPORTFILENAME |
String |
varchar2(255) |
Mandatory |
Name of the file being uploaded should be specified. Each file must have a unique name. |
UPLOADMODE |
String |
varchar2(1) |
Mandatory |
Upload mode can be “N” for New unit holder uploads and ‘I’ for Incremental change. |
AMCID |
String |
varchar2(12) |
Mandatory |
The ID of the AMC for which the bulk client has maintained the default details. This should be same within a file for all the records. |
DEALTRANSACTIONNUMBER |
String |
VARCHAR2(16) |
Optional |
Null for a new mode. It may or may not be passed for other modes. |
UHIDORCIFNUMBER |
String |
VARCHAR2(12) |
Mandatory |
Could be any valid unit holder ID or CIF number maintained in the system. |
APPLYATCIFLEVEL |
Number |
NUMBER(1) |
Optional |
Could be either 0- No or 1-Yes. If not supplied, value to be taken from bulk client defaults |
APPLYDEALAT |
String |
VARCHAR2(1) |
Mandatory |
Could be any of the following values: G- Group Level, P- Product Level, F-Fund Level, L-Load level. |
STATUS |
String |
VARCHAR2(1) |
Mandatory |
Could be either A- Active or C-Cancelled. |
EFFECTIVESTARTDATE |
date |
DATE |
Mandatory |
The effective date from which the deal is applicable |
EFFECTIVEENDDATE |
date |
DATE |
Optional |
The effective date on which the deal ends. In case of null values it will take the default value as the system high date. |
AUTHSTATUS |
String |
VARCHAR2(1) |
Mandatory |
Could be either A- Authorized or U- Unauthorized. |
LOADGROUPID |
String |
VARCHAR2(16) |
Optional |
Could be any valid group ID maintained in system. |
FUNDID |
String |
VARCHAR2(6) |
Optional |
Could be any valid fund ID maintained in the system. |
LOADID |
Number |
NUMBER(5) |
Mandatory |
Could be any valid load ID maintained in the system. |
LOADSLABDETAILS |
String |
VARCHAR2(2000) |
Optional |
Could be any valid slab details maintained for the load in the system. It should have the slab number and the return value. Field separator is "," and record separator is ";". slabno>, <returnvalue>; |
DERIVEDLOADSLABDETAILS |
String |
VARCHAR2(2000) |
Optional |
Could be any valid slab details maintained for the derived load in the system. It has derived load id, and return value. Field separator is "," and record separator is ";". <derivedloadid> ,<returnvalue>; |
APPLYRETVALUETOALLSLABS |
Number |
NUMBER(1) |
Optional |
Could be either 0-No or 1-Yes |
RETURNVALUE |
Number |
NUMBER(15,6) |
Optional |
If the above field is ‘1’, then return value is applicable to all the slabs |
PRODUCTID |
String |
VARCHAR2(10) |
Optional |
Could be any valid product ID maintained in the system. For UT it should be 'UT'. ‘ALL’ – Option would be applicable for all products. |
MAKERID |
String |
VARCHAR2(15) |
Optional |
If not supplied in the handoff file, value is defaulted as maintained in Bulk client defaults. |
MAKERDATE |
date |
DATE |
Optional |
CHECKERID |
String |
VARCHAR2(15) |
Optional |
CHECKERDATE |
date |
DATE |
Optional |
POLICYNUMBER |
String |
Varchar2(16) |
Optional |
Could be any valid Policy maintained in the system. For UT, it should be 'UT'. |
DealBasedOn |
String |
Varcahr2(1) |
Optional |
I – Inclusion Percentage A – Flat Rate Amount P – Flat Rate Percentage |
For all imports of new and amended Cheque Tracking data, the external hand-off file containing the information must:
Data type |
Field length |
Mandatory? |
Values |
SEGMENTID |
String |
20 |
Mandatory |
Sequence no. of records in the file |
SEQUENCENUMBER |
Number |
10 |
Mandatory |
PROCESSID |
String |
50 |
Mandatory |
BULKCLIENTCODE |
String |
12 |
Mandatory |
IMPORTFILENAME |
String |
255 |
Mandatory |
AMCID |
String |
12 |
Mandatory |
The ID of the AMC/Distributor for which the bulk client has maintained the defaults details. |
UPLOADMODE |
String |
1 |
Mandatory |
“N” for New Mode and ‘E’ for Edit Mode, “M” for modify mode , “D” for delete mode. |
CHEQUETYPE |
String |
3 |
Mandatory |
Should be valid type as maintained in the system. |
TRANSACTIONNUMBER |
String |
16 |
Transaction number should be specified if the Transaction Type is “RED”. |
FUNDID |
String |
6 |
Mandatory |
The ID of a valid and enabled fund maintained in the system |
PAYMENTNUMBER |
Number |
5 |
Mandatory |
Payment number should be specified if the Transaction Type is “UHD”. |
UNITHOLDERID |
String |
12 |
Mandatory |
The Unit holder ID to identify a unit holder in the system, depending on the scheme/cross reference number. |
PRODUCTID |
String |
10 |
Optional |
ID of the product under which the corresponding Policy has been created. |
String |
1 |
Optional |
C- Cash Dividend S – Stock Dividend |
CHEQUEAMOUNT |
Number |
30,12 |
Mandatory |
This field denotes the cheque Amount |
CHEQUECURRENCY |
String |
3 |
Mandatory |
This field denotes the cheque currency |
CHEQUEDATE |
Date |
10 |
Mandatory |
For check payment modes, this is the date of issue of the check. Must not be later than the current application date.. |
CHEQUENUMBER |
String |
16 |
Mandatory |
Indicates the check number for Payment mode (Q) and Credit card number for payment mode (R). This is mandatory if mode of Payment is check (Q) or credit card (R). |
OLDCHEQUENUMBER |
String |
16 |
Optional |
This field denotes the previous cheque number. |
DRAWEEBANK |
String |
12 |
Mandatory |
Should be a valid Bank Code as defined in the system |
DRAWEEBRANCHCODE |
String |
12 |
Optional |
Mandatory |
Should be a valid Branch Code as defined in the system |
DUPLICATE |
String |
1 |
Optional |
TRANSACTIONTYPE |
String |
4 |
Optional |
Mandatory |
Should valid type as maintained in the system. |
SPOOLSERIALNO |
Number |
10 |
Optional |
Unique Serial No. |
CHECKSTATUS |
String |
1 |
Mandatory |
Check Status( N- New, A – Active, D- Duplicate, C- Cleared, I – Invalid) |
CHECKPRINTEDDATE |
Date |
10 |
Optional |
Actual Chq Printed Date |
FILENAME |
String |
30 |
Optional |
Chq Upload File Name |
PROCESSED |
String |
1 |
Optional |
Mandatory |
Unique Sequence number |
TIMESTAMP |
Date |
10 |
Optional |
Date Time Stamp |
PRINTERID |
String |
15 |
Optional |
MAKERID |
String |
15 |
Mandatory |
There should not be any validation on Maker ID field with regards to the user profile maintenance in FCIS if it is supplied with the import file. If it is not supplied, default it to the logged in user id |
MAKERDATE |
Date |
10 |
Optional |
If the date is not specified in the import file, the application date is considered to be the Maker Date by default. |
DEPOSITRYID |
String |
12 |
Optional |
DP Id |
PAYMENTMODE |
String |
2 |
Mandatory |
Indicates mode of payment. Can be any of the following values. Q-Cheque, T-Transfer, R-Credit card, C-Cash, D-Draft |
SUBPAYMENTMODE |
String |
2 |
Optional |
Can have valid values as defined in the mode of payment table |
PAYINBANK |
String |
12 |
Optional |
Should be a valid Bank as defined in the system. |
PAYINBRANCH |
String |
12 |
Optional |
Should be a valid Brach as defined in the system. |
PAYINNUMBER |
String |
12 |
Optional |
Unique Serial Number |
MODULEID |
String |
30 |
Mandatory |
Should be a valid module id as defined in the system. |
COMMISSION |
Number |
30,12 |
Optional |
Entity Commission Amount |
CHEQOPTYPE |
String |
1 |
Optional |
0 – Cheque 3 – Demand Draft 4 – Outstation Cheques/DD 5 - Others |
SYSREFERENCENUMBER |
String |
25 |
Mandatory |
Unique Serial number |
CHECKERID |
String |
15 |
Optional |
This information is specified in the import file, no validation is made with regards to the user profile maintenance in the FCIS system. If it is not specified, it is defaulted to ‘SYSTEM’. This information is applicable for authorized unit holder generation. |
CHECKERDATE |
Date |
10 |
Optional |
If the date is not specified in the import file, the application date is considered to be the Checker Date by default. This information is applicable for authorized unit holder generation. |
MICRCODE |
String |
40 |
Cheque MICR Code |
AUTHTYPE |
String |
1 |
Mandatory |
Could be either of the following values: "U" - Unauthorized, "A" – Authorized |
IBAN |
String |
36 |
Optional |
Used to capture the IBAN |
This is used to capture the pseudo switch lag details
Data type |
Length |
Values |
PROCESSID |
VARCHAR2 |
5 |
Mandatory |
Process ID (either sequence number or process id should be unique) |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
Mode of operation which has to be performed on the record |
FUNDORFUNDFAMILY |
VARCHAR2 |
2 |
Mandatory |
Default Value is Fund |
AMCID |
VARCHAR2 |
12 |
Mandatory |
AMC ID |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Maker_id |
MAKER_DT_STAMP |
DATE |
7 |
Optional |
Maker Date Stamp |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
Checker Id |
CHECKER_DT_STAMP |
DATE |
7 |
Optional |
Checker Date Stamp |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
Authorisation status |
ONCE_AUTH |
CHAR |
1 |
Optional |
Once Authorized |
MOD_NO |
NUMBER |
1 |
Optional |
Mod number |
RECORD_STAT |
CHAR |
1 |
Optional |
Record status |
This is used to capture emergency day transaction processing review.
Data type |
Length |
Values |
SEQUENCENUMBER |
NUMBER |
Mandatory |
Sequence number |
PROCESSID |
VARCHAR2 |
50 |
Mandatory |
Process ID |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
bulkclientcode |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
importfilename |
KEYSTRING |
VARCHAR2 |
50 |
Optional |
keystring |
TRANSACTIONNUMBER |
VARCHAR2 |
16 |
Mandatory |
Transactionnumber |
TRANSACTIONTYPE |
VARCHAR2 |
2 |
Optional |
Transactiontype |
REFTYPE |
VARCHAR2 |
2 |
Optional |
Reftype |
FUNDID |
VARCHAR2 |
6 |
Optional |
Fundid |
AMCID |
VARCHAR2 |
12 |
Optional |
Amcid |
FUNDFAMILY |
VARCHAR2 |
6 |
Optional |
Fundfamily |
TRANSACTIONDATE |
DATE |
7 |
Optional |
Transactiondate |
NEWTRANSACTIONDATE |
DATE |
7 |
Optional |
System derived transaction date considering Emergency day |
PRICEDATE |
DATE |
7 |
Optional |
Pricedate |
NEWPRICEDATE |
DATE |
7 |
Optional |
System derived pricedate considering Emergency day |
PAYMENTDATE |
DATE |
7 |
Optional |
Paymentdate |
NEWPAYMENTDATE |
DATE |
7 |
Optional |
System derived payment date considering Emergency day. |
DEALINGDATE |
DATE |
7 |
Optional |
Dealingdate |
NEWDEALINGDATE |
DATE |
7 |
Optional |
System derived dealing date considering Emergency day. |
FXDEALDATE |
DATE |
7 |
Optional |
Fxdealdate |
NEWFXDEALDATE |
DATE |
7 |
Optional |
System derived fxdeal date Considering Emergency day. |
FXVALUEDATE |
DATE |
7 |
Optional |
Fxvaluedate |
NEWFXVALUEDATE |
DATE |
7 |
Optional |
System derived fxvalue date considering Emergency day |
PROCESSDATE |
DATE |
7 |
Optional |
Date which is declared as Emergency day |
USERID |
VARCHAR2 |
15 |
Mandatory |
User who reviewed the transactions |
ACTION |
VARCHAR2 |
1 |
Mandatory |
Action performed on the review screen |
MODULEID |
VARCHAR2 |
30 |
Optional |
Module Id |
EXCHANGERATESTATUS |
VARCHAR2 |
1 |
Optional |
Exchange rate status |
SETTLEMENTDUEDATE |
DATE |
7 |
Optional |
Settlementduedate |
NEWSETTLEMENTDUEDATE |
DATE |
7 |
Optional |
System derived Settlement due date considering Emergency day. |
Serial Number: 1
Segment Identification Number: 00CMP
Description: This is used to capture campaign upload details
Segment Mandatory/ Optional: Mandatory
Field Name (as expected in the file) |
Data type |
Length |
Values |
SEGMENTID |
VARCHAR2 |
80 |
Segment ID - 00CMP |
SEQUENCENUMBER |
NUMBER |
10 |
Sequence Number (either sequence number or process id should be unique) |
PROCESSID |
VARCHAR2 |
50 |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Bulk Client Code |
IMPORTFILENAME |
VARCHAR2 |
255 |
Import File Name |
UPLOADMODE |
VARCHAR2 |
1 |
CAMPAIGNCODE |
VARCHAR2 |
10 |
Mandatory |
Campaign Code |
CAMPAIGNNAME |
VARCHAR2 |
60 |
Mandatory |
Campaign Name |
CAMPAIGNTYPES |
VARCHAR2 |
1 |
Mandatory |
Campaign Types-. Valid Values are: A-Account Opening Date T-Transaction Date L-Loyality, B-Birth Day Campaign |
STARTDATE |
DATE |
Mandatory |
Campaign code start date |
ENDDATE |
DATE |
Mandatory |
Campaign code end date |
INVESTORTYPE |
VARCHAR2 |
1 |
Optional |
Investor type. Valid Values are: I-individual, C-Corporate |
INVESTORCATEGORY |
VARCHAR2 |
2 |
Optional |
Investor category |
COMMUNICATIONMODE |
VARCHAR2 |
2 |
Optional |
Communication mode |
OCCUPATION |
VARCHAR2 |
3 |
Optional |
Occupation |
MININVESTMENTAMOUNT |
NUMBER |
30,12 |
Minimum investment amount. Value should be greater than zero |
MAXINVESTMENTAMOUNT |
NUMBER |
30,12 |
Maximum investment amount Value should be greater than zero and greater than minimum investment amount |
ACTIVITYBASEDON |
VARCHAR2 |
1 |
Activity Based on. .Valid values are T-Transaction Date, A-Account Opening Date, B-Birth Day |
ACTIVITYFROMPERIOD |
DATE |
Optional |
Activity from period |
ACTIVITYTOPERIOD |
DATE |
Optional |
Activity to period |
AGERANGEFROM |
NUMBER |
Optional |
Age Range From |
AGERANGETO |
NUMBER |
Optional |
Age Range To |
BIRTHDAYCONCEPTS |
VARCHAR2 |
50 |
Optional |
Birth Day concepts -Comma separated string |
BENEFITCOUNTER |
NUMBER |
Mandatory |
Benefit counter |
FUNDORFUNDTYPE |
NUMBER |
38 |
Optional |
Fund or Fund type |
PERIOD |
VARCHAR2 |
1 |
Optional |
Period |
RSPDATE |
VARCHAR2 |
10 |
Optional |
RSP Date |
RSP |
VARCHAR2 |
1 |
Optional |
RSP |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
Maker_id |
MAKER_DT_STAMP |
DATE |
Optional |
Maker Date Stamp |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
Checker Id |
CHECKER_DT_STAMP |
DATE |
Optional |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
BIRTHDAYMONTH |
VARCHAR2 |
50 |
Optional |
Birth Day Month -comma separated string |
This is used to capture special discount upload details.
Field or Column Name |
Data Type |
Length |
Table Name |
SEGMENTID |
VARCHAR2 |
80 |
BULKSPECIALDISCMAINTTBL |
Mandatory |
SEQUENCENUMBER |
NUMBER |
22 |
Mandatory |
PROCESSID |
VARCHAR2 |
5 |
Mandatory |
BULKCLIENTCODE |
VARCHAR2 |
12 |
Mandatory |
IMPORTFILENAME |
VARCHAR2 |
255 |
Mandatory |
UPLOADMODE |
VARCHAR2 |
1 |
Mandatory |
FUNDTYPE |
VARCHAR2 |
3 |
Mandatory |
UNITHOLDERID |
VARCHAR2 |
12 |
Mandatory |
TRANSACTIONDATE |
DATE |
7 |
Mandatory |
TRANSACTIONCURRENCY |
VARCHAR2 |
22 |
Optional |
CAMPAIGNCODE |
VARCHAR2 |
12 |
Mandatory |
AUTH_STAT |
VARCHAR2 |
1 |
Optional |
MAKER_ID |
VARCHAR2 |
15 |
Mandatory |
MAKER_DT_STAMP |
DATE |
7 |
Optional |
CHECKER_ID |
VARCHAR2 |
15 |
Optional |
CHECKER_DT_STAMP |
DATE |
7 |
Optional |
ONCE_AUTH |
CHAR |
1 |
Optional |
MOD_NO |
NUMBER |
22 |
Optional |
RECORD_STAT |
CHAR |
1 |
Optional |
Segment Identification Number |
Description |
01MAS |
This segment is used to provide pension order upload details |
02INT |
This segment is used to provide pension order instrument upload details |
03AST |
This segment is used to provide pension order asset upload detail |
04INT |
This segment is used to provide pension order intermediary upload detail |
05SET |
This segment is used to provide pension order settlement upload detail |
06SIN |
This segment is used to provide pension order instrument upload detail |
07SAS |
08ADD |
This segment is used to provide additional information upload detail |
For Pension order upload, use UH bulk client code as pension is needed to be maintained in FMG.
Export path of one system should be import path for another system:
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ORDERUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PATB_ORDERUPLOAD |
PROCESSID |
Processid |
VARCHAR2 |
50 |
PATB_ORDERUPLOAD |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
PATB_ORDERUPLOAD |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
PATB_ORDERUPLOAD |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PATB_ORDERUPLOAD |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
PATB_ORDERUPLOAD |
REFERENCENUMBER |
Referencenumber |
VARCHAR2 |
16 |
PATB_ORDERUPLOAD |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PATB_ORDERUPLOAD |
PORTFOLIOID |
Portfolioid |
VARCHAR2 |
16 |
PATB_ORDERUPLOAD |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
PATB_ORDERUPLOAD |
ORDERCURRENCY |
Ordercurrency |
VARCHAR2 |
3 |
PATB_ORDERUPLOAD |
ORDERMODE |
Ordermode |
VARCHAR2 |
1 |
PATB_ORDERUPLOAD |
ORDERVALUE |
Ordervalue |
NUMBER |
30 |
PATB_ORDERUPLOAD |
INSTRUCTIONDATE |
Instructiondate |
DATE |
7 |
PATB_ORDERUPLOAD |
ORDERTYPE |
Ordertype |
VARCHAR2 |
3 |
PATB_ORDERUPLOAD |
ORDERSUBTYPE |
Ordersubtype |
VARCHAR2 |
3 |
PATB_ORDERUPLOAD |
PAYMENTMODE |
Paymentmode |
VARCHAR2 |
2 |
PATB_ORDERUPLOAD |
GROSSORNET |
Grossornet |
VARCHAR2 |
1 |
PATB_ORDERUPLOAD |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
PATB_ORDERUPLOAD |
ORDERSTATUS |
Orderstatus |
NUMBER |
2 |
PATB_ORDERUPLOAD |
ORIGINALORDNUMBER |
Originalordnumber |
VARCHAR2 |
16 |
PATB_ORDERUPLOAD |
ORIGINALREFNUMBER |
Originalrefnumber |
VARCHAR2 |
16 |
PATB_ORDERUPLOAD |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
PATB_ORDERUPLOAD |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
PATB_ORDERUPLOAD |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
PATB_ORDERUPLOAD |
MOD_NO |
Mod_No |
NUMBER |
22 |
PATB_ORDERUPLOAD |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
PATB_ORDERUPLOAD |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
PATB_ORDERUPLOAD |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
PATB_ORDERUPLOAD |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
PATB_ORDERUPLOAD |
REMARKS |
Remarks |
VARCHAR2 |
255 |
PATB_ORDERUPLOAD |
SWIORDERSTATUS |
Swiorderstatus |
NUMBER |
2 |
PATB_ORDERUPLOAD |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ORDERINSTRUMENTUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
22 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ORDERINSTASSETUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
ASSETID |
Assetid |
VARCHAR2 |
16 |
RATIO |
Ratio |
NUMBER |
22 |
OVERRIDE |
Override |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ORDERINTERMEDIARYUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INTERMEDIARYID |
Intermediaryid |
VARCHAR2 |
12 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
22 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ORDERSETTLEMENTUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
PAYMENTREFNUMBER |
Paymentrefnumber |
VARCHAR2 |
16 |
BANKREFERENCENO |
Bankreferenceno |
VARCHAR2 |
16 |
CHEQUEDATE |
Chequedate |
DATE |
7 |
CHEQUENUMBER |
Chequenumber |
VARCHAR2 |
20 |
PAYMENTAMOUNT |
Paymentamount |
NUMBER |
22 |
PAIDDATE |
Paiddate |
DATE |
7 |
SETTLED |
Settled |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_SWORDERINSTRUMENTUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
22 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_SWORDERINSTASSETUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
ASSETID |
Assetid |
VARCHAR2 |
16 |
RATIO |
Ratio |
NUMBER |
22 |
OVERRIDE |
Override |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ADDINFOUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
ADDINFOLABEL |
Addinfolabel |
VARCHAR2 |
30 |
FIELDVALUE |
Fieldvalue |
CHAR |
23 |
The DATE format for Payroll and Pension Data Interface Standard (PAPDIS) upload to be maintained as per the PAPDIS standard format which is YYYY-MM-DD. Format maintained at interface definition level will be overridden by this.
Note
CFU and PAPDIS are the standard format, where we cannot have the audit fields in the upload template.
Contribution File Upload Upload
Employer level portfolio mapping for the following portfolios mandatory for CFU/PAPDIS upload:
Export path of one system should be import path for another system.
Field name |
Description |
Datatype |
Length |
SEQUENCENUMBER |
Sequence number of the record |
VARCHAR2 |
10 |
PROCESSID |
Process ID of the record |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulk client code for the external system |
VARCHAR2 |
12 |
UPLOADMODE |
Mod e of upload(N,E,A,D) |
VARCHAR2 |
1 |
IMPORTFILENAME |
Name of the file |
VARCHAR2 |
255 |
MODULEID |
Module |
VARCHAR2 |
30 |
PAPDISVERSION |
Version |
VARCHAR2 |
5 |
PENSIONPROVIDERID |
ID of the pension provider |
VARCHAR2 |
35 |
EMPLOYERID |
ID of the employer |
VARCHAR2 |
40 |
GROUPCODE |
Group code |
VARCHAR2 |
40 |
SUBGROUP |
Sub group |
VARCHAR2 |
40 |
PAYPERIODSTARTDATE |
Start date of the pay period |
VARCHAR2 |
10 |
PAYPERIODENDDATE |
End date of the pay period |
VARCHAR2 |
10 |
CONTRIDEDUCTIONDATE |
Deduction date of the contri |
VARCHAR2 |
10 |
FREQUENCYCODE |
Code of frequency |
VARCHAR2 |
2 |
TAXPERIOD |
Tax period |
VARCHAR2 |
2 |
TITLE |
Title |
VARCHAR2 |
35 |
FORENAME1 |
Forename1 |
VARCHAR2 |
35 |
FORENAME2 |
Forename2 |
VARCHAR2 |
35 |
SURNAME |
Surname |
VARCHAR2 |
35 |
EMPLOYEEID |
EmployeeID |
VARCHAR2 |
35 |
BIRTHDATE |
Birthdate |
VARCHAR2 |
10 |
GENDER |
Gender |
VARCHAR2 |
1 |
NATIONALINSURANCENO |
Number of national insurance |
VARCHAR2 |
9 |
ADDRESS1 |
Address1 |
VARCHAR2 |
35 |
ADDRESS2 |
Address2 |
VARCHAR2 |
35 |
ADDRESS3 |
Address3 |
VARCHAR2 |
35 |
ADDRESS4 |
Address4 |
VARCHAR2 |
35 |
POSTCODE |
Post code |
VARCHAR2 |
10 |
COUNTRY |
Country |
VARCHAR2 |
35 |
EMAILADDRESS |
Emailaddress |
VARCHAR2 |
75 |
EMPLOYMENTSTARTDATE |
Employmentstartdate |
VARCHAR2 |
10 |
EXITDATE |
Exitdate |
NUMBER |
10 |
EXITREASONCODE |
Exitreasoncode |
NUMBER |
1 |
ASSESSMENTCODE |
Assessmentcode |
NUMBER |
1 |
EVENTCODE |
Eventcode |
VARCHAR2 |
1 |
EVENTDATE |
Eventdate |
VARCHAR2 |
10 |
DEFERRALDATE |
Deferraldate |
VARCHAR2 |
10 |
AEOPTOUTDATE |
Aeoptoutdate |
VARCHAR2 |
10 |
AEOPTOUTREFERENCE |
Aeoptoutreference |
VARCHAR2 |
35 |
ENROLMENTCOMMISSUEDDT |
Enrolmentcommissueddt |
NUMBER |
10 |
EMPLOYERCONTRIBUTIONSAMT |
Employercontributionsamt |
NUMBER |
32 |
EMPLOYEECONTRIBUTIONSAMT |
Employeecontributionsamt |
NUMBER |
32 |
ADDITIONALVOLUNTARYAMT |
Additionalvoluntaryamt |
NUMBER |
32 |
ADDITIONALVOLUNTARYPER |
Additionalvoluntaryper |
NUMBER |
5 |
PENSIONABLEEARNINGSAMT |
Pensionableearningsamt |
NUMBER |
32 |
EMPLOYERCONTRIBUTIONSPER |
Employercontributionsper |
NUMBER |
5 |
EMPLOYEECONTRIBUTIONSPER |
Employeecontributionsper |
VARCHAR2 |
5 |
SALARYSACRIFICEINDICATOR |
Salarysacrificeindicator |
VARCHAR2 |
1 |
TOTALGROSSEARNINGS |
Totalgrossearnings |
NUMBER |
32 |
WORKEREXCLUSIONCODE |
Workerexclusioncode |
VARCHAR2 |
2 |
STATUTORYLETTERCODE |
Statutorylettercode |
VARCHAR2 |
3 |
ISINDALREADYMEMBEROFQPS |
Isindalreadymemberofqps |
VARCHAR2 |
1 |
REENROLMENTINDICATOR |
Reenrolmentindicator |
VARCHAR2 |
1 |
SECONDARYEMAILADDRESS |
Secondaryemailaddress |
VARCHAR2 |
75 |
STAGINGDATE |
Stagingdate |
VARCHAR2 |
10 |
CYCLICALREENROLMENTDATE |
Cyclicalreenrolmentdate |
NUMBER |
10 |
MESSAGEFUNCTIONCODE |
Messagefunctioncode |
VARCHAR2 |
3 |
PAYREFERENCESTARTDATE |
Payreferencestartdate |
VARCHAR2 |
10 |
PAYREFERENCEENDDATE |
Payreferenceenddate |
VARCHAR2 |
10 |
OPTOUTWINDOWENDDATE |
Optoutwindowenddate |
VARCHAR2 |
10 |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_CFUPLOADHDR |
PROCESSID |
Processid |
VARCHAR2 |
50 |
PATB_CFUPLOADHDR |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
PATB_CFUPLOADHDR |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
PATB_CFUPLOADHDR |
BATCHREFNUMBER |
Batchrefnumber |
VARCHAR2 |
16 |
PATB_CFUPLOADHDR |
EMPLOYERCODE |
Employercode |
VARCHAR2 |
12 |
PATB_CFUPLOADHDR |
EARNINGSSTPERIOD |
Earningsstperiod |
VARCHAR2 |
11 |
PATB_CFUPLOADHDR |
EARNINGSENDPERIOD |
Earningsendperiod |
VARCHAR2 |
11 |
PATB_CFUPLOADHDR |
CONTRIBUTIONCCY |
Contributionccy |
VARCHAR2 |
3 |
PATB_CFUPLOADHDR |
TOTALCONTRIBUTIONAMT |
Totalcontributionamt |
NUMBER |
30 |
PATB_CFUPLOADHDR |
SETTLEMENTREQ |
Settlementreq |
VARCHAR2 |
1 |
PATB_CFUPLOADHDR |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_CFUPLOADDETAIL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
EMPLOYEECODE |
Employeecode |
VARCHAR2 |
12 |
EMPLOYERMANDATORY |
Employermandatory |
NUMBER |
30 |
EMPLOYEEMANDATORY |
Employeemandatory |
NUMBER |
30 |
EMPLOYERVOLUNTARY |
Employervoluntary |
NUMBER |
30 |
EMPLOYEEVOLUNTARY |
Employeevoluntary |
NUMBER |
30 |
REMARKS |
Remarks |
VARCHAR2 |
255 |
Description |
01ORD |
This segment is used to provide Pension order master upload details |
02OIN |
This segment is used to provide Pension order instrument upload details |
03OIA |
This segment is used to provide Pension order investment asset upload detail |
04OIT |
This segment is used to provide Pension order intermediary upload detail |
05OSE |
This segment is used to provide Pension settlement upload detail |
06PMA |
This segment is used to provide Pension party master upload detail |
07PCO |
This segment is used to provide Pension party contact upload detail |
08PID |
This segment is used to provide Pension party ID upload detail |
09IAM |
This segment is used to provide Pension investment master upload detail |
10IAI |
This segment is used to provide Pension investment account intermediary upload detail |
11IAB |
This segment is used to provide Pension bank upload detail |
12IBE |
This segment is used to provide Pension investment account beneficiary upload detail |
13ALO |
This segment is used to provide Pension order allocation upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHORDERUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PHORDERUPLOADTBL |
PROCESSID |
Processid |
VARCHAR2 |
50 |
PHORDERUPLOADTBL |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
PHORDERUPLOADTBL |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
PHORDERUPLOADTBL |
USERREFERENCENUMBER |
Userreferencenumber |
VARCHAR2 |
16 |
PHORDERUPLOADTBL |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
PHORDERUPLOADTBL |
REFERENCENUMBER |
Referencenumber |
VARCHAR2 |
16 |
PHORDERUPLOADTBL |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PHORDERUPLOADTBL |
PORTFOLIOID |
Portfolioid |
VARCHAR2 |
16 |
PHORDERUPLOADTBL |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
PHORDERUPLOADTBL |
ORDERCURRENCY |
Ordercurrency |
VARCHAR2 |
3 |
PHORDERUPLOADTBL |
ORDERMODE |
Ordermode |
VARCHAR2 |
1 |
PHORDERUPLOADTBL |
ORDERVALUE |
Ordervalue |
NUMBER |
30 |
PHORDERUPLOADTBL |
INSTRUCTIONDATE |
Instructiondate |
DATE |
7 |
PHORDERUPLOADTBL |
ORDERTYPE |
Ordertype |
VARCHAR2 |
3 |
PHORDERUPLOADTBL |
ORDERSUBTYPE |
Ordersubtype |
VARCHAR2 |
3 |
PHORDERUPLOADTBL |
PAYMENTMODE |
Paymentmode |
VARCHAR2 |
2 |
PHORDERUPLOADTBL |
GROSSORNET |
Grossornet |
VARCHAR2 |
1 |
PHORDERUPLOADTBL |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
PHORDERUPLOADTBL |
ORDERSTATUS |
Orderstatus |
NUMBER |
2 |
PHORDERUPLOADTBL |
ORIGINALORDNUMBER |
Originalordnumber |
VARCHAR2 |
16 |
PHORDERUPLOADTBL |
ORIGINALREFNUMBER |
Originalrefnumber |
VARCHAR2 |
16 |
PHORDERUPLOADTBL |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
PHORDERUPLOADTBL |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
PHORDERUPLOADTBL |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
PHORDERUPLOADTBL |
MOD_NO |
Mod_No |
NUMBER |
22 |
PHORDERUPLOADTBL |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
PHORDERUPLOADTBL |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
PHORDERUPLOADTBL |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
PHORDERUPLOADTBL |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
PHORDERUPLOADTBL |
REMARKS |
Remarks |
VARCHAR2 |
255 |
PHORDERUPLOADTBL |
SWIORDERSTATUS |
Swiorderstatus |
VARCHAR2 |
2 |
PHORDERUPLOADTBL |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHORDERINSTRUMENTUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
5 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHORDERINSTASSETUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
ASSETID |
Assetid |
VARCHAR2 |
16 |
RATIO |
Ratio |
NUMBER |
5 |
OVERRIDE |
Override |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHORDERINTERMEDIARYUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INTERMEDIARYID |
Intermediaryid |
VARCHAR2 |
12 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
5 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHORDERSETTLEMENTUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
PAYMENTREFNUMBER |
Paymentrefnumber |
VARCHAR2 |
16 |
BANKREFERENCENO |
Bankreferenceno |
VARCHAR2 |
16 |
CHEQUEDATE |
Chequedate |
DATE |
7 |
CHEQUENUMBER |
Chequenumber |
VARCHAR2 |
20 |
PAYMENTAMOUNT |
Paymentamount |
NUMBER |
30 |
PAIDDATE |
Paiddate |
DATE |
7 |
SETTLED |
Settled |
VARCHAR2 |
1 |
ACCOUNTHOLDERNAME |
Accountholdername |
VARCHAR2 |
100 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
IBAN |
Iban |
VARCHAR2 |
40 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHPARTYMASTERUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PARTYTYPE |
Partytype |
VARCHAR2 |
3 |
TITLE |
Title |
VARCHAR2 |
15 |
FIRSTNAME |
Firstname |
VARCHAR2 |
100 |
MIDDLENAME |
Middlename |
VARCHAR2 |
100 |
LASTNAME |
Lastname |
VARCHAR2 |
100 |
REGISTEREDNAME |
Registeredname |
VARCHAR2 |
100 |
DATEOFBIRTH |
Dateofbirth |
DATE |
7 |
DATEOFINCORPORATION |
Dateofincorporation |
DATE |
7 |
MARITALSTATUS |
Maritalstatus |
VARCHAR2 |
1 |
OCCUPATION |
Occupation |
VARCHAR2 |
3 |
GENDER |
Gender |
VARCHAR2 |
1 |
PREFERREDCURRENCY |
Preferredcurrency |
VARCHAR2 |
3 |
MINOR |
Minor |
NUMBER |
1 |
NATIONALITY |
Nationality |
VARCHAR2 |
3 |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
DUALNATIONALITY |
Dualnationality |
VARCHAR2 |
3 |
SUBSTANTIALSTAYINUS |
Substantialstayinus |
NUMBER |
1 |
HEALTHSTATUS |
Healthstatus |
VARCHAR2 |
1 |
PROTECTIONLEVEL |
Protectionlevel |
VARCHAR2 |
1 |
FIRSTAUTHORIZEDSIGNATORY |
Firstauthorizedsignatory |
VARCHAR2 |
100 |
SECONDAUTHORIZEDSIGNATORY |
Secondauthorizedsignatory |
VARCHAR2 |
100 |
THIRDAUTHORIZEDSIGNATORY |
Thirdauthorizedsignatory |
VARCHAR2 |
100 |
CORPORATIONTYPE |
Corporationtype |
VARCHAR2 |
3 |
MINNOOFCORPORATESIGNATORY |
Minnoofcorporatesignatory |
NUMBER |
22 |
INCORPORATIONCOUNTRY |
Incorporationcountry |
VARCHAR2 |
3 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
FATHERSPOUSENAME |
Fatherspousename |
VARCHAR2 |
105 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHPARTYCONTACTUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
CONTACTREFNO |
Contactrefno |
VARCHAR2 |
16 |
ADDRESSTYPE |
Addresstype |
VARCHAR2 |
2 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
100 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
100 |
ADDRESSLINE3 |
Addressline3 |
VARCHAR2 |
100 |
POSTBOXNO |
Postboxno |
VARCHAR2 |
16 |
CITY |
City |
VARCHAR2 |
80 |
STATE |
State |
VARCHAR2 |
80 |
COUNTRY |
Country |
VARCHAR2 |
3 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
BICCODE |
Biccode |
VARCHAR2 |
16 |
WEBSITE |
Website |
VARCHAR2 |
100 |
EMAILADDRESS |
Emailaddress |
VARCHAR2 |
100 |
EFFECTIVEFROMDATE |
Effectivefromdate |
DATE |
7 |
EFFECTIVETODATE |
Effectivetodate |
DATE |
7 |
PRIMARYCONTACTPERSON |
Primarycontactperson |
VARCHAR2 |
100 |
PRIMARYINTERNDIALCODE1 |
Primaryinterndialcode1 |
VARCHAR2 |
10 |
PRIMARYINTERNDIALCODE2 |
Primaryinterndialcode2 |
VARCHAR2 |
10 |
PRIMARYINTERNDIALCODE3 |
Primaryinterndialcode3 |
VARCHAR2 |
10 |
PRIMARYINTERNDIALCODE4 |
Primaryinterndialcode4 |
VARCHAR2 |
10 |
PRIMARYPOSITION |
Primaryposition |
VARCHAR2 |
60 |
PRIMARYMOBILENUMBER1 |
Primarymobilenumber1 |
VARCHAR2 |
60 |
PRIMARYMOBILENUMBER2 |
Primarymobilenumber2 |
VARCHAR2 |
60 |
PRIMARYFIXEDLINE |
Primaryfixedline |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
PRIMARYCONTACTINSTRN |
Primarycontactinstrn |
VARCHAR2 |
100 |
PRIMARYEXTN |
Primaryextn |
VARCHAR2 |
60 |
SECONDARYCONTACTPERSON |
Secondarycontactperson |
VARCHAR2 |
100 |
SECONDARYINTERNDIALCODE1 |
Secondaryinterndialcode1 |
VARCHAR2 |
10 |
SECONDARYINTERNDIALCODE2 |
Secondaryinterndialcode2 |
VARCHAR2 |
10 |
SECONDARYPOSITION |
Secondaryposition |
VARCHAR2 |
60 |
SECONDARYMOBILENUMBER |
Secondarymobilenumber |
VARCHAR2 |
60 |
SECONDARYFIXEDLINE |
Secondaryfixedline |
VARCHAR2 |
60 |
SECONDARYCONTACTINSTRN |
Secondarycontactinstrn |
VARCHAR2 |
105 |
SECONDARYEXTN |
Secondaryextn |
VARCHAR2 |
60 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHPARTYIDUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
IDREFERENCENO |
Idreferenceno |
VARCHAR2 |
16 |
IDENTIFICATIONTYPE |
Identificationtype |
VARCHAR2 |
20 |
IDENTIFICATIONNUMBER |
Identificationnumber |
VARCHAR2 |
50 |
PLACEOFISSUE |
Placeofissue |
VARCHAR2 |
3 |
ISSUEAUTHORITY |
Issueauthority |
VARCHAR2 |
50 |
ISSUECOUNTRY |
Issuecountry |
VARCHAR2 |
3 |
DATEOFISSUE |
Dateofissue |
DATE |
7 |
DATEOFEXPIRY |
Dateofexpiry |
DATE |
7 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
VERIFICATIONSTATUS |
Verificationstatus |
VARCHAR2 |
1 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHINVACCMASTERUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
ACOPERATIONTYPE |
Acoperationtype |
VARCHAR2 |
1 |
DEALINGTYPE |
Dealingtype |
VARCHAR2 |
3 |
GUARDIANID |
Guardianid |
VARCHAR2 |
12 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
INVESTORCATEGORY |
Investorcategory |
VARCHAR2 |
2 |
ACOPENINGDATE |
Acopeningdate |
DATE |
7 |
ACCOUNTREFNO |
Accountrefno |
VARCHAR2 |
16 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
ACCOUNTSTATUS |
Accountstatus |
VARCHAR2 |
1 |
PENSIONACCOUNT |
Pensionaccount |
VARCHAR2 |
1 |
ACCOUNTCLOSED |
Accountclosed |
VARCHAR2 |
1 |
CHANGEDATE |
Changedate |
DATE |
7 |
CHANGEREASON |
Changereason |
VARCHAR2 |
255 |
CHANGEREFERENCENO |
Changereferenceno |
VARCHAR2 |
16 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHINVACCINTERUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
INTERMEDIARYID |
Intermediaryid |
VARCHAR2 |
12 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
5 |
DEFAULTFLAG |
Defaultflag |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHINVACCBANKUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
BANKREFERENCENO |
Bankreferenceno |
VARCHAR2 |
16 |
DIRECTDEBITAPPLICABLE |
Directdebitapplicable |
VARCHAR2 |
1 |
DEFAULTFLAG |
Defaultflag |
VARCHAR2 |
1 |
ACCOUNTHOLDERNAME |
Accountholdername |
VARCHAR2 |
100 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
IBAN |
Iban |
VARCHAR2 |
40 |
VARCHAR2 |
1 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHINVESTACCBENFUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
BENEFICIARYTYPE |
Beneficiarytype |
VARCHAR2 |
2 |
BENFPARTYID |
Benfpartyid |
VARCHAR2 |
16 |
AWARDPERCENTAGE |
Awardpercentage |
NUMBER |
5 |
BENFPARTYNAME |
Benfpartyname |
VARCHAR2 |
100 |
DATEOFBIRTH |
Dateofbirth |
DATE |
7 |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
GENDER |
Gender |
VARCHAR2 |
1 |
VARCHAR2 |
20 |
VARCHAR2 |
50 |
RELATIONSHIP |
Relationship |
VARCHAR2 |
70 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
100 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
100 |
CITY |
City |
VARCHAR2 |
80 |
STATE |
State |
VARCHAR2 |
80 |
COUNTRY |
Country |
VARCHAR2 |
3 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
EMAILADDRESS |
Emailaddress |
VARCHAR2 |
100 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
PRIMARYFIXEDLINE |
Primaryfixedline |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
CONTACTPERSON |
Contactperson |
VARCHAR2 |
100 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
ACCOUNTNAME |
Accountname |
VARCHAR2 |
100 |
IBAN |
Iban |
VARCHAR2 |
40 |
DESIGNATION |
Designation |
VARCHAR2 |
100 |
CONTROLLINGPERSON |
Controllingperson |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHORDERALLOCDETUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
EXTERNALTXNNUMBER |
Externaltxnnumber |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PORTFOLIOID |
Portfolioid |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
ASSETID |
Assetid |
VARCHAR2 |
16 |
ORDERAMOUNT |
Orderamount |
NUMBER |
30 |
LOADAMOUNT |
Loadamount |
NUMBER |
30 |
NETAMOUNT |
Netamount |
NUMBER |
30 |
SETTLEMENTAMT |
Settlementamt |
NUMBER |
30 |
NAV |
Nav |
NUMBER |
17 |
NAVDATE |
Navdate |
DATE |
7 |
ALLOTEDUNITS |
Allotedunits |
NUMBER |
30 |
ALLOCATIONDATE |
Allocationdate |
DATE |
7 |
FROMORTOLEG |
Fromortoleg |
VARCHAR2 |
1 |
ORIGINALORDNUMBER |
Originalordnumber |
VARCHAR2 |
16 |
ORDERTYPE |
Ordertype |
VARCHAR2 |
3 |
STATUS |
Status |
VARCHAR2 |
2 |
ERR_CODE |
Err_Code |
VARCHAR2 |
20 |
ERRDESCRIPTION |
Errdescription |
VARCHAR2 |
255 |
TATRANSACTIONDATE |
Tatransactiondate |
DATE |
7 |
BLOCKEDFLAG |
Blockedflag |
VARCHAR2 |
1 |
Description |
00FDU |
This segment is used to provide pension allocation import from asset upload details |
03TPR |
This segment is used to provide pension allocation import from third party asset upload details |
04FLU |
This segment is used to provide pension allocation import from third party asset load upload details |
Field name |
Description |
Datatype |
Length |
Table Name |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PATB_ALLOCDETAILSTAUPLOADHF |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
EXTERNALTXNNUMBER |
Externaltxnnumber |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PORTFOLIOID |
Portfolioid |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
ASSETID |
Assetid |
VARCHAR2 |
16 |
ORDERAMOUNT |
Orderamount |
NUMBER |
30 |
LOADAMOUNT |
Loadamount |
NUMBER |
30 |
NETAMOUNT |
Netamount |
NUMBER |
30 |
SETTLEMENTAMT |
Settlementamt |
NUMBER |
30 |
NAV |
Nav |
NUMBER |
17 |
NAVDATE |
Navdate |
DATE |
7 |
ALLOTEDUNITS |
Allotedunits |
NUMBER |
30 |
ALLOCATIONDATE |
Allocationdate |
DATE |
7 |
FROMORTOLEG |
Fromortoleg |
VARCHAR2 |
1 |
ORIGINALORDNUMBER |
Originalordnumber |
VARCHAR2 |
16 |
ORDERTYPE |
Ordertype |
VARCHAR2 |
3 |
STATUS |
Status |
VARCHAR2 |
2 |
ERR_CODE |
Err_Code |
VARCHAR2 |
20 |
ERRDESCRIPTION |
Errdescription |
VARCHAR2 |
255 |
TATRANSACTIONDATE |
Tatransactiondate |
DATE |
7 |
BLOCKEDFLAG |
Blockedflag |
VARCHAR2 |
1 |
Description |
00PAR |
This segment is used to provide pension investment master upload details |
03ADR |
This segment is used to provide pension party contact upload details |
04IDD |
This segment is used to provide pension party ID upload detail |
05IAC |
This segment is used to provide pension investment account master upload detail |
06INT |
This segment is used to provide pension investment account intermediary upload detail |
07IBK |
This segment is used to provide pension investment account bank upload detail |
08IBF |
This segment is used to provide pension investment account beneficiary upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PARTYTYPE |
Partytype |
VARCHAR2 |
3 |
TITLE |
Title |
VARCHAR2 |
15 |
FIRSTNAME |
Firstname |
VARCHAR2 |
100 |
MIDDLENAME |
Middlename |
VARCHAR2 |
100 |
LASTNAME |
Lastname |
VARCHAR2 |
100 |
REGISTEREDNAME |
Registeredname |
VARCHAR2 |
100 |
DATEOFBIRTH |
Dateofbirth |
DATE |
7 |
DATE |
7 |
MARITALSTATUS |
Maritalstatus |
VARCHAR2 |
1 |
OCCUPATION |
Occupation |
VARCHAR2 |
3 |
GENDER |
Gender |
VARCHAR2 |
1 |
PREFERREDCURRENCY |
Preferredcurrency |
VARCHAR2 |
3 |
MINOR |
Minor |
NUMBER |
1 |
NATIONALITY |
Nationality |
VARCHAR2 |
3 |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
DUALNATIONALITY |
Dualnationality |
VARCHAR2 |
3 |
NUMBER |
1 |
HEALTHSTATUS |
Healthstatus |
VARCHAR2 |
1 |
PROTECTIONLEVEL |
Protectionlevel |
VARCHAR2 |
1 |
VARCHAR2 |
100 |
VARCHAR2 |
100 |
VARCHAR2 |
100 |
CORPORATIONTYPE |
Corporationtype |
VARCHAR2 |
3 |
NUMBER |
22 |
VARCHAR2 |
3 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
FATHERSPOUSENAME |
Fatherspousename |
VARCHAR2 |
105 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
CONTACTREFNO |
Contactrefno |
VARCHAR2 |
16 |
ADDRESSTYPE |
Addresstype |
VARCHAR2 |
2 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
100 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
100 |
ADDRESSLINE3 |
Addressline3 |
VARCHAR2 |
100 |
POSTBOXNO |
Postboxno |
VARCHAR2 |
16 |
CITY |
City |
VARCHAR2 |
80 |
STATE |
State |
VARCHAR2 |
80 |
COUNTRY |
Country |
VARCHAR2 |
3 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
BICCODE |
Biccode |
VARCHAR2 |
16 |
WEBSITE |
Website |
VARCHAR2 |
100 |
EMAILADDRESS |
Emailaddress |
VARCHAR2 |
100 |
EFFECTIVEFROMDATE |
Effectivefromdate |
DATE |
7 |
EFFECTIVETODATE |
Effectivetodate |
DATE |
7 |
VARCHAR2 |
100 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
PRIMARYPOSITION |
Primaryposition |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
PRIMARYFIXEDLINE |
Primaryfixedline |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
VARCHAR2 |
100 |
PRIMARYEXTN |
Primaryextn |
VARCHAR2 |
60 |
VARCHAR2 |
100 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
SECONDARYPOSITION |
Secondaryposition |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
105 |
SECONDARYEXTN |
Secondaryextn |
VARCHAR2 |
60 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
IDREFERENCENO |
Idreferenceno |
VARCHAR2 |
16 |
VARCHAR2 |
20 |
VARCHAR2 |
50 |
PLACEOFISSUE |
Placeofissue |
VARCHAR2 |
3 |
ISSUEAUTHORITY |
Issueauthority |
VARCHAR2 |
50 |
ISSUECOUNTRY |
Issuecountry |
VARCHAR2 |
3 |
DATEOFISSUE |
Dateofissue |
DATE |
7 |
DATEOFEXPIRY |
Dateofexpiry |
DATE |
7 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
VARCHAR2 |
1 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
ACOPERATIONTYPE |
Acoperationtype |
VARCHAR2 |
1 |
DEALINGTYPE |
Dealingtype |
VARCHAR2 |
3 |
GUARDIANID |
Guardianid |
VARCHAR2 |
12 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
INVESTORCATEGORY |
Investorcategory |
VARCHAR2 |
2 |
ACOPENINGDATE |
Acopeningdate |
DATE |
7 |
ACCOUNTREFNO |
Accountrefno |
VARCHAR2 |
16 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
ACCOUNTSTATUS |
Accountstatus |
VARCHAR2 |
1 |
PENSIONACCOUNT |
Pensionaccount |
VARCHAR2 |
1 |
ACCOUNTCLOSED |
Accountclosed |
VARCHAR2 |
1 |
CHANGEDATE |
Changedate |
DATE |
7 |
CHANGEREASON |
Changereason |
VARCHAR2 |
255 |
CHANGEREFERENCENO |
Changereferenceno |
VARCHAR2 |
16 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
INTERMEDIARYID |
Intermediaryid |
VARCHAR2 |
12 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
5 |
DEFAULTFLAG |
Defaultflag |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
BANKREFERENCENO |
Bankreferenceno |
VARCHAR2 |
16 |
VARCHAR2 |
1 |
DEFAULTFLAG |
Defaultflag |
VARCHAR2 |
1 |
ACCOUNTHOLDERNAME |
Accountholdername |
VARCHAR2 |
100 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
IBAN |
Iban |
VARCHAR2 |
40 |
VARCHAR2 |
1 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
BENEFICIARYTYPE |
Beneficiarytype |
VARCHAR2 |
2 |
BENFPARTYID |
Benfpartyid |
VARCHAR2 |
16 |
AWARDPERCENTAGE |
Awardpercentage |
NUMBER |
5 |
BENFPARTYNAME |
Benfpartyname |
VARCHAR2 |
100 |
DATEOFBIRTH |
Dateofbirth |
DATE |
7 |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
GENDER |
Gender |
VARCHAR2 |
1 |
VARCHAR2 |
20 |
VARCHAR2 |
50 |
RELATIONSHIP |
Relationship |
VARCHAR2 |
70 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
100 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
100 |
CITY |
City |
VARCHAR2 |
80 |
STATE |
State |
VARCHAR2 |
80 |
COUNTRY |
Country |
VARCHAR2 |
3 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
EMAILADDRESS |
Emailaddress |
VARCHAR2 |
100 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
PRIMARYFIXEDLINE |
Primaryfixedline |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
CONTACTPERSON |
Contactperson |
VARCHAR2 |
100 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
ACCOUNTNAME |
Accountname |
VARCHAR2 |
100 |
IBAN |
Iban |
VARCHAR2 |
40 |
DESIGNATION |
Designation |
VARCHAR2 |
100 |
CONTROLLINGPERSON |
Controllingperson |
VARCHAR2 |
1 |
Field name |
Description |
Datatype |
Length |
Table Name |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PHALLOCDETAILSTAUPLOADHF |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
EXTERNALTXNNUMBER |
Externaltxnnumber |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PORTFOLIOID |
Portfolioid |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
ASSETID |
Assetid |
VARCHAR2 |
16 |
ORDERAMOUNT |
Orderamount |
NUMBER |
30 |
LOADAMOUNT |
Loadamount |
NUMBER |
30 |
NETAMOUNT |
Netamount |
NUMBER |
30 |
SETTLEMENTAMT |
Settlementamt |
NUMBER |
30 |
NAV |
Nav |
NUMBER |
17 |
NAVDATE |
Navdate |
DATE |
7 |
ALLOTEDUNITS |
Allotedunits |
NUMBER |
30 |
ALLOCATIONDATE |
Allocationdate |
DATE |
7 |
FROMORTOLEG |
Fromortoleg |
VARCHAR2 |
1 |
ORIGINALORDNUMBER |
Originalordnumber |
VARCHAR2 |
16 |
ORDERTYPE |
Ordertype |
VARCHAR2 |
3 |
STATUS |
Status |
VARCHAR2 |
2 |
ERR_CODE |
Err_Code |
VARCHAR2 |
20 |
ERRDESCRIPTION |
Errdescription |
VARCHAR2 |
255 |
TATRANSACTIONDATE |
Tatransactiondate |
DATE |
7 |
BLOCKEDFLAG |
Blockedflag |
VARCHAR2 |
1 |
Description |
01LOD |
This segment is used to provide load upload details |
02DET |
This segment is used to provide load detail upload details |
03BAS |
This segment is used to provide basis definition upload detail |
04DER |
This segment is used to provide derived load upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
B_LOADUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
B_LOADUPLOADTBL |
PROCESSID |
Processid |
VARCHAR2 |
50 |
B_LOADUPLOADTBL |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
B_LOADUPLOADTBL |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
B_LOADUPLOADTBL |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
B_LOADUPLOADTBL |
KEYSTRING |
Keystring |
VARCHAR2 |
50 |
B_LOADUPLOADTBL |
LOADID |
Loadid |
NUMBER |
5 |
B_LOADUPLOADTBL |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
B_LOADUPLOADTBL |
LOADDESCRIPTION |
Loaddescription |
VARCHAR2 |
60 |
B_LOADUPLOADTBL |
LOADTYPE |
Loadtype |
VARCHAR2 |
1 |
B_LOADUPLOADTBL |
AMOUNTORPERCENTAGE |
Amountorpercentage |
VARCHAR2 |
1 |
B_LOADUPLOADTBL |
LOADCALCMETHOD |
Loadcalcmethod |
VARCHAR2 |
1 |
B_LOADUPLOADTBL |
LOADOVERRIDEABLE |
Loadoverrideable |
NUMBER |
1 |
B_LOADUPLOADTBL |
CRITERIA |
Criteria |
VARCHAR2 |
255 |
B_LOADUPLOADTBL |
FROMTABLES |
Fromtables |
VARCHAR2 |
20 |
B_LOADUPLOADTBL |
LOWERBOUNDARYINCLUSIVE |
Lowerboundaryinclusive |
NUMBER |
1 |
B_LOADUPLOADTBL |
CUMULATIVELOADAPPLICABLE |
Cumulativeloadapplicable |
NUMBER |
1 |
B_LOADUPLOADTBL |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
B_LOADUPLOADTBL |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
B_LOADUPLOADTBL |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
B_LOADUPLOADTBL |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
B_LOADUPLOADTBL |
LASTMODIFIEDUSERID |
Lastmodifieduserid |
VARCHAR2 |
15 |
B_LOADUPLOADTBL |
LASTMODIFIEDDATE |
Lastmodifieddate |
DATE |
7 |
B_LOADUPLOADTBL |
MOD_NO |
Mod_No |
NUMBER |
22 |
B_LOADUPLOADTBL |
PRICEBASISLOAD |
Pricebasisload |
NUMBER |
1 |
B_LOADUPLOADTBL |
AMOUNTBASIS |
Amountbasis |
VARCHAR2 |
1 |
B_LOADUPLOADTBL |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
B_LOADUPLOADTBL |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
B_LOADUPLOADTBL |
ROATHRESHOLDFORINITIALFEE |
Roathresholdforinitialfee |
NUMBER |
30 |
B_LOADUPLOADTBL |
CREATEDMODULE |
Createdmodule |
VARCHAR2 |
30 |
B_LOADUPLOADTBL |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
B_LOADDETUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
KEYSTRING |
Keystring |
VARCHAR2 |
50 |
LOADID |
Loadid |
NUMBER |
5 |
SLABSEQNO |
Slabseqno |
NUMBER |
5 |
SLABFROMDATE |
Slabfromdate |
DATE |
7 |
SLABTODATE |
Slabtodate |
DATE |
7 |
SLABFROMAMOUNT |
Slabfromamount |
NUMBER |
30 |
SLABTOAMOUNT |
Slabtoamount |
NUMBER |
30 |
SLABFROMUNITS |
Slabfromunits |
NUMBER |
27 |
SLABTOUNITS |
Slabtounits |
NUMBER |
27 |
SLABFROMPERIOD |
Slabfromperiod |
NUMBER |
22 |
SLABTOPERIOD |
Slabtoperiod |
NUMBER |
22 |
RETURNVALUE |
Returnvalue |
NUMBER |
30 |
FLOORVALUE |
Floorvalue |
NUMBER |
15 |
CEILINGVALUE |
Ceilingvalue |
NUMBER |
30 |
PERIODBASIS |
Periodbasis |
VARCHAR2 |
1 |
SLABFROMCOUNTER |
Slabfromcounter |
NUMBER |
22 |
SLABTOCOUNTER |
Slabtocounter |
NUMBER |
22 |
UHDEALCEILINGVALUE |
Uhdealceilingvalue |
NUMBER |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
B_BASISDEFUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
KEYSTRING |
Keystring |
VARCHAR2 |
50 |
LOADID |
Loadid |
NUMBER |
5 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
TABLESREFERRED |
Tablesreferred |
VARCHAR2 |
16 |
BASISAMOUNT |
Basisamount |
VARCHAR2 |
255 |
BASISDAYS |
Basisdays |
VARCHAR2 |
255 |
BASISUNITS |
Basisunits |
VARCHAR2 |
255 |
JOINCLAUSE |
Joinclause |
VARCHAR2 |
255 |
FIELDFLAG |
Fieldflag |
VARCHAR2 |
1 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
VARCHAR2 |
15 |
LASTMODIFIEDDATE |
Lastmodifieddate |
DATE |
7 |
MOD_NO |
Mod_No |
NUMBER |
22 |
RECORD_STAT |
Record_Stat |
CHAR |
1 |
ONCE_AUTH |
Once_Auth |
CHAR |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
B_DERIVEDLOADUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
KEYSTRING |
Keystring |
VARCHAR2 |
50 |
LOADID |
Loadid |
NUMBER |
5 |
DESCRIPTION |
Description |
VARCHAR2 |
60 |
PARENTLOADID |
Parentloadid |
VARCHAR2 |
6 |
TOENTITYTYPE |
Toentitytype |
VARCHAR2 |
1 |
TOENTITYID |
Toentityid |
VARCHAR2 |
12 |
LOADPERCENTAGE |
Loadpercentage |
NUMBER |
5 |
CRITERIA |
Criteria |
VARCHAR2 |
255 |
FROMTABLES |
Fromtables |
VARCHAR2 |
20 |
MANDATORY |
Mandatory |
NUMBER |
38 |
PRIORITY |
Priority |
NUMBER |
38 |
AMOUNTBASIS |
Amountbasis |
VARCHAR2 |
1 |
CAPTOPARENTLOADAMOUNT |
Captoparentloadamount |
NUMBER |
30 |
DIFFERENTIALLOAD |
Differentialload |
VARCHAR2 |
1 |
DEPENDENTLOADID |
Dependentloadid |
VARCHAR2 |
6 |
FDAPINCOME |
Fdapincome |
NUMBER |
1 |
Description |
00BKR |
This segment is used to provide broker upload details |
01BLG |
This segment is used to provide broker legal upload details |
02BRF |
This segment is used to provide broker preference upload detail |
03BBK |
This segment is used to provide broker bank upload detail |
04BCT |
This segment is used to provide broker contact information upload detail |
05RLP |
This segment is used to provide broker related parties upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHBROKERTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PHBROKERTBL |
PROCESSID |
Processid |
VARCHAR2 |
50 |
PHBROKERTBL |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
PHBROKERTBL |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
PHBROKERTBL |
VARCHAR2 |
16 |
PHBROKERTBL |
BROKERCODE |
Brokercode |
VARCHAR2 |
12 |
PHBROKERTBL |
BROKERNAME |
Brokername |
VARCHAR2 |
105 |
PHBROKERTBL |
PARENTBROKERCODE |
Parentbrokercode |
VARCHAR2 |
12 |
PHBROKERTBL |
BROKERBASECCY |
Brokerbaseccy |
VARCHAR2 |
3 |
PHBROKERTBL |
AMCID |
Amcid |
VARCHAR2 |
12 |
PHBROKERTBL |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
PHBROKERTBL |
DELETEDSTATUS |
Deletedstatus |
NUMBER |
1 |
PHBROKERTBL |
OVERRIDDENTAXPERCENTAGE |
Overriddentaxpercentage |
NUMBER |
15 |
PHBROKERTBL |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
PHBROKERTBL |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
PHBROKERTBL |
LEVELNUMBER |
Levelnumber |
NUMBER |
3 |
PHBROKERTBL |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
PHBROKERTBL |
CHANGETYPE |
Changetype |
VARCHAR2 |
1 |
PHBROKERTBL |
VATREGISTERED |
Vatregistered |
NUMBER |
1 |
PHBROKERTBL |
VATREGISTRATIONNUMBER |
Vatregistrationnumber |
VARCHAR2 |
15 |
PHBROKERTBL |
COMMISSIONPERCENTAGE |
Commissionpercentage |
NUMBER |
5 |
PHBROKERTBL |
COMMISSIONPAYMENTFREQ |
Commissionpaymentfreq |
VARCHAR2 |
1 |
PHBROKERTBL |
UNITHOLDERID |
Unitholderid |
VARCHAR2 |
12 |
PHBROKERTBL |
LASTPAYMENTDATE |
Lastpaymentdate |
DATE |
7 |
PHBROKERTBL |
LASTPAYMENTNUMBER |
Lastpaymentnumber |
NUMBER |
5 |
PHBROKERTBL |
LASTPROCESSEDDATE |
Lastprocesseddate |
DATE |
7 |
PHBROKERTBL |
NEXTPAYMENTDATE |
Nextpaymentdate |
DATE |
7 |
PHBROKERTBL |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
PHBROKERTBL |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
PHBROKERTBL |
BROKERTYPE |
Brokertype |
VARCHAR2 |
6 |
PHBROKERTBL |
USEBROKERTYPEPAYMENTDATES |
Usebrokertypepaymentdates |
NUMBER |
1 |
PHBROKERTBL |
BROKERCONSULTANT |
Brokerconsultant |
VARCHAR2 |
40 |
PHBROKERTBL |
BROKERCATEGORY |
Brokercategory |
VARCHAR2 |
1 |
PHBROKERTBL |
HOLDBACKPAYMENT |
Holdbackpayment |
NUMBER |
1 |
PHBROKERTBL |
MOD_NO |
Mod_No |
NUMBER |
10 |
PHBROKERTBL |
HOLDPYMTFROMDATE |
Holdpymtfromdate |
DATE |
7 |
PHBROKERTBL |
LATESTRULE |
Latestrule |
NUMBER |
22 |
PHBROKERTBL |
BROKERSTATUS |
Brokerstatus |
VARCHAR2 |
1 |
PHBROKERTBL |
RECORD_STAT |
Record_Stat |
CHAR |
1 |
PHBROKERTBL |
ONCE_AUTH |
Once_Auth |
CHAR |
1 |
PHBROKERTBL |
REPLICATEPARENTDET |
Replicateparentdet |
CHAR |
1 |
PHBROKERTBL |
VATREGISTRATIONDATE |
Vatregistrationdate |
DATE |
7 |
PHBROKERTBL |
TEMPLATEID |
Templateid |
VARCHAR2 |
6 |
PHBROKERTBL |
USINDICIAAVAILABLE |
Usindiciaavailable |
NUMBER |
1 |
PHBROKERTBL |
FATCASTATUS |
Fatcastatus |
VARCHAR2 |
25 |
PHBROKERTBL |
NATIONALITY |
Nationality |
VARCHAR2 |
3 |
PHBROKERTBL |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
PHBROKERTBL |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
PHBROKERTBL |
VARCHAR2 |
3 |
PHBROKERTBL |
TAXID |
Taxid |
VARCHAR2 |
50 |
PHBROKERTBL |
EIN |
Ein |
VARCHAR2 |
50 |
PHBROKERTBL |
TAXCERTIFICATEEFFEDATE |
Taxcertificateeffedate |
DATE |
7 |
PHBROKERTBL |
TAXCERTIFICATEEXPDATE |
Taxcertificateexpdate |
DATE |
7 |
PHBROKERTBL |
TAXCIRCLE |
Taxcircle |
VARCHAR2 |
15 |
PHBROKERTBL |
FATCACLASSIFICATION |
Fatcaclassification |
VARCHAR2 |
25 |
PHBROKERTBL |
GIIN |
Giin |
VARCHAR2 |
30 |
PHBROKERTBL |
GIINISSUEDATE |
Giinissuedate |
DATE |
7 |
PHBROKERTBL |
GIINEXPIRYDATE |
Giinexpirydate |
DATE |
7 |
PHBROKERTBL |
GIINVERIFIEDFLAG |
Giinverifiedflag |
NUMBER |
1 |
PHBROKERTBL |
FATCASPONSORTYPE |
Fatcasponsortype |
VARCHAR2 |
2 |
PHBROKERTBL |
SPONSORINGENTITYTYPE |
Sponsoringentitytype |
VARCHAR2 |
1 |
PHBROKERTBL |
SPONSORINGENTITYID |
Sponsoringentityid |
VARCHAR2 |
12 |
PHBROKERTBL |
VATEXPIRYDATE |
Vatexpirydate |
DATE |
7 |
PHBROKERTBL |
UNAUTHEXIST |
Unauthexist |
VARCHAR2 |
1 |
PHBROKERTBL |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHBROKERLEGACYTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PHBROKERLEGACYTBL |
PROCESSID |
Processid |
VARCHAR2 |
50 |
PHBROKERLEGACYTBL |
VARCHAR2 |
16 |
PHBROKERLEGACYTBL |
BROKERCODE |
Brokercode |
VARCHAR2 |
12 |
PHBROKERLEGACYTBL |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
PHBROKERLEGACYTBL |
BROKERLEGACYCODE |
Brokerlegacycode |
VARCHAR2 |
12 |
PHBROKERLEGACYTBL |
MOD_NO |
Mod_No |
NUMBER |
10 |
PHBROKERLEGACYTBL |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHBROKERPREFERENCETBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
BROKERCODE |
Brokercode |
VARCHAR2 |
12 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
FEEDTYPE |
Feedtype |
VARCHAR2 |
20 |
FEEDSTRUCT |
Feedstruct |
VARCHAR2 |
4 |
FEEDSTARTDATE |
Feedstartdate |
DATE |
7 |
FEEDFREQUENCY |
Feedfrequency |
VARCHAR2 |
20 |
FEEDFORMAT |
Feedformat |
VARCHAR2 |
6 |
MOD_NO |
Mod_No |
NUMBER |
10 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHBROKERBANKDETAILSTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
BROKERCODE |
Brokercode |
VARCHAR2 |
12 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
REFERENCENUMBER |
Referencenumber |
VARCHAR2 |
12 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
ACCOUNTNAME |
Accountname |
VARCHAR2 |
100 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
DEFAULTDETAILS |
Defaultdetails |
NUMBER |
1 |
NUMBER |
1 |
SWIFTFORMAT |
Swiftformat |
VARCHAR2 |
6 |
BANKCHARGED |
Bankcharged |
VARCHAR2 |
12 |
BENEFICIARY |
Beneficiary |
VARCHAR2 |
35 |
BENEFICIARYADD1 |
Beneficiaryadd1 |
VARCHAR2 |
105 |
BENEFICIARYADD2 |
Beneficiaryadd2 |
VARCHAR2 |
105 |
BENEFICIARYADD3 |
Beneficiaryadd3 |
VARCHAR2 |
105 |
BENEFICIARYBICCODE |
Beneficiarybiccode |
VARCHAR2 |
24 |
BENEFICIARYACCTNO |
Beneficiaryacctno |
VARCHAR2 |
34 |
BENEFICIARYCODE |
Beneficiarycode |
VARCHAR2 |
24 |
BENEFICIARYINFO |
Beneficiaryinfo |
VARCHAR2 |
100 |
INTERMEDIARY |
Intermediary |
VARCHAR2 |
35 |
INTERMEDIARYADD1 |
Intermediaryadd1 |
VARCHAR2 |
105 |
INTERMEDIARYADD2 |
Intermediaryadd2 |
VARCHAR2 |
105 |
INTERMEDIARYADD3 |
Intermediaryadd3 |
VARCHAR2 |
105 |
INTERMEDIARYBICCODE |
Intermediarybiccode |
VARCHAR2 |
24 |
INTERMEDIARYACCTNO |
Intermediaryacctno |
VARCHAR2 |
34 |
INTERMEDIARYCODE |
Intermediarycode |
VARCHAR2 |
24 |
INTERMEDIARYINFO |
Intermediaryinfo |
VARCHAR2 |
100 |
FURTHERCREDITNAME |
Furthercreditname |
VARCHAR2 |
35 |
FURTHERCREDITACCTNO |
Furthercreditacctno |
VARCHAR2 |
35 |
REFERENCE1 |
Reference1 |
VARCHAR2 |
35 |
REFERENCE2 |
Reference2 |
VARCHAR2 |
35 |
IBAN |
Iban |
VARCHAR2 |
40 |
BENEFICIARYIBAN |
Beneficiaryiban |
VARCHAR2 |
40 |
INTERMEDIARYIBAN |
Intermediaryiban |
VARCHAR2 |
40 |
MOD_NO |
Mod_No |
NUMBER |
10 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHBROKERCONTACTINFOTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ENTITYID |
Entityid |
VARCHAR2 |
12 |
ENTITYTYPE |
Entitytype |
VARCHAR2 |
2 |
ADDRESSTYPE |
Addresstype |
VARCHAR2 |
2 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
80 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
80 |
ADDRESSLINE3 |
Addressline3 |
VARCHAR2 |
80 |
ADDRESSLINE4 |
Addressline4 |
VARCHAR2 |
80 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
COUNTRY |
Country |
VARCHAR2 |
3 |
USSTATE |
Usstate |
NUMBER |
1 |
TELEPHONE1 |
Telephone1 |
VARCHAR2 |
60 |
TELEPHONE2 |
Telephone2 |
VARCHAR2 |
60 |
CELLPHONENUMBER |
Cellphonenumber |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
VARCHAR2 |
255 |
CONTACTPERSON |
Contactperson |
VARCHAR2 |
160 |
EFFECTIVEFROMDATE |
Effectivefromdate |
DATE |
7 |
EFFECTIVETODATE |
Effectivetodate |
DATE |
7 |
BICCODE |
Biccode |
VARCHAR2 |
16 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
INTDIALLINGCODEFAX |
Intdiallingcodefax |
VARCHAR2 |
10 |
INTDIALLINGCODEPH2 |
Intdiallingcodeph2 |
VARCHAR2 |
10 |
INTDIALLINGCODEPH1 |
Intdiallingcodeph1 |
VARCHAR2 |
10 |
INTDIALLINGCODECELL |
Intdiallingcodecell |
VARCHAR2 |
10 |
MOD_NO |
Mod_No |
NUMBER |
10 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PHBROKERRELATEDPARTIESTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
BROKERCODE |
Brokercode |
VARCHAR2 |
12 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
RPENTITYID |
Rpentityid |
VARCHAR2 |
12 |
RPENTITYTYPE |
Rpentitytype |
VARCHAR2 |
2 |
REPORTINGLEVEL |
Reportinglevel |
VARCHAR2 |
1 |
PREFMAILMODE |
Prefmailmode |
VARCHAR2 |
1 |
REMARKS |
Remarks |
VARCHAR2 |
255 |
APPLYLEVEL |
Applylevel |
VARCHAR2 |
3 |
APPLYTO |
Applyto |
VARCHAR2 |
12 |
MOD_NO |
Mod_No |
NUMBER |
10 |
Description |
01LOD |
02DET |
This segment is used to provide load detail upload |
03BAS |
04DER |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_LOADUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PATB_LOADUPLOAD |
PROCESSID |
Processid |
VARCHAR2 |
50 |
PATB_LOADUPLOAD |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
PATB_LOADUPLOAD |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
PATB_LOADUPLOAD |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PATB_LOADUPLOAD |
LOADID |
Loadid |
NUMBER |
5 |
PATB_LOADUPLOAD |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
PATB_LOADUPLOAD |
LOADDESCRIPTION |
Loaddescription |
VARCHAR2 |
60 |
PATB_LOADUPLOAD |
LOADTYPE |
Loadtype |
VARCHAR2 |
1 |
PATB_LOADUPLOAD |
VARCHAR2 |
1 |
PATB_LOADUPLOAD |
LOADCALCMETHOD |
Loadcalcmethod |
VARCHAR2 |
1 |
PATB_LOADUPLOAD |
LOADOVERRIDEABLE |
Loadoverrideable |
NUMBER |
1 |
PATB_LOADUPLOAD |
CRITERIA |
Criteria |
VARCHAR2 |
255 |
PATB_LOADUPLOAD |
FROMTABLES |
Fromtables |
VARCHAR2 |
20 |
PATB_LOADUPLOAD |
NUMBER |
1 |
PATB_LOADUPLOAD |
NUMBER |
1 |
PATB_LOADUPLOAD |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
PATB_LOADUPLOAD |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
PATB_LOADUPLOAD |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
PATB_LOADUPLOAD |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
PATB_LOADUPLOAD |
VARCHAR2 |
15 |
PATB_LOADUPLOAD |
LASTMODIFIEDDATE |
Lastmodifieddate |
DATE |
7 |
PATB_LOADUPLOAD |
MOD_NO |
Mod_No |
NUMBER |
22 |
PATB_LOADUPLOAD |
PRICEBASISLOAD |
Pricebasisload |
NUMBER |
1 |
PATB_LOADUPLOAD |
AMOUNTBASIS |
Amountbasis |
VARCHAR2 |
1 |
PATB_LOADUPLOAD |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
PATB_LOADUPLOAD |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
PATB_LOADUPLOAD |
NUMBER |
30 |
PATB_LOADUPLOAD |
CREATEDMODULE |
Createdmodule |
VARCHAR2 |
30 |
PATB_LOADUPLOAD |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_LOADDETUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
LOADID |
Loadid |
NUMBER |
5 |
SLABSEQNO |
Slabseqno |
NUMBER |
5 |
SLABFROMDATE |
Slabfromdate |
DATE |
7 |
SLABTODATE |
Slabtodate |
DATE |
7 |
SLABFROMAMOUNT |
Slabfromamount |
NUMBER |
30 |
SLABTOAMOUNT |
Slabtoamount |
NUMBER |
30 |
SLABFROMUNITS |
Slabfromunits |
NUMBER |
27 |
SLABTOUNITS |
Slabtounits |
NUMBER |
27 |
SLABFROMPERIOD |
Slabfromperiod |
NUMBER |
22 |
SLABTOPERIOD |
Slabtoperiod |
NUMBER |
22 |
RETURNVALUE |
Returnvalue |
NUMBER |
30 |
FLOORVALUE |
Floorvalue |
NUMBER |
15 |
CEILINGVALUE |
Ceilingvalue |
NUMBER |
30 |
PERIODBASIS |
Periodbasis |
VARCHAR2 |
1 |
SLABFROMCOUNTER |
Slabfromcounter |
NUMBER |
22 |
SLABTOCOUNTER |
Slabtocounter |
NUMBER |
22 |
NUMBER |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_BASISDEFUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
LOADID |
Loadid |
NUMBER |
5 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
TABLESREFERRED |
Tablesreferred |
VARCHAR2 |
16 |
BASISAMOUNT |
Basisamount |
VARCHAR2 |
255 |
BASISDAYS |
Basisdays |
VARCHAR2 |
255 |
BASISUNITS |
Basisunits |
VARCHAR2 |
255 |
JOINCLAUSE |
Joinclause |
VARCHAR2 |
255 |
FIELDFLAG |
Fieldflag |
VARCHAR2 |
1 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
VARCHAR2 |
15 |
LASTMODIFIEDDATE |
Lastmodifieddate |
DATE |
7 |
MOD_NO |
Mod_No |
NUMBER |
22 |
RECORD_STAT |
Record_Stat |
CHAR |
1 |
ONCE_AUTH |
Once_Auth |
CHAR |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_DERIVEDLOADUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
LOADID |
Loadid |
NUMBER |
5 |
DESCRIPTION |
Description |
VARCHAR2 |
60 |
PARENTLOADID |
Parentloadid |
VARCHAR2 |
6 |
TOENTITYTYPE |
Toentitytype |
VARCHAR2 |
1 |
TOENTITYID |
Toentityid |
VARCHAR2 |
12 |
LOADPERCENTAGE |
Loadpercentage |
NUMBER |
5 |
CRITERIA |
Criteria |
VARCHAR2 |
255 |
FROMTABLES |
Fromtables |
VARCHAR2 |
20 |
MANDATORY |
Mandatory |
NUMBER |
38 |
PRIORITY |
Priority |
NUMBER |
38 |
AMOUNTBASIS |
Amountbasis |
VARCHAR2 |
1 |
NUMBER |
30 |
DIFFERENTIALLOAD |
Differentialload |
VARCHAR2 |
1 |
DEPENDENTLOADID |
Dependentloadid |
VARCHAR2 |
6 |
FDAPINCOME |
Fdapincome |
NUMBER |
1 |
Description |
00BKR |
01BLG |
This segment is used to provide broker legacy upload details |
02BRF |
This segment is used to provide broker preference upload details |
03BNK |
This segment is used to provide broker bank detail upload |
04BCT |
This segment is used to provide broker contact upload details |
05RLP |
This segment is used to provide broker parties upload details |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_BROKERUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PATB_BROKERUPLOAD |
PROCESSID |
Processid |
VARCHAR2 |
50 |
PATB_BROKERUPLOAD |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
PATB_BROKERUPLOAD |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
PATB_BROKERUPLOAD |
VARCHAR2 |
16 |
PATB_BROKERUPLOAD |
BROKERCODE |
Brokercode |
VARCHAR2 |
12 |
PATB_BROKERUPLOAD |
BROKERNAME |
Brokername |
VARCHAR2 |
105 |
PATB_BROKERUPLOAD |
PARENTBROKERCODE |
Parentbrokercode |
VARCHAR2 |
12 |
PATB_BROKERUPLOAD |
BROKERBASECCY |
Brokerbaseccy |
VARCHAR2 |
3 |
PATB_BROKERUPLOAD |
AMCID |
Amcid |
VARCHAR2 |
12 |
PATB_BROKERUPLOAD |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
PATB_BROKERUPLOAD |
DELETEDSTATUS |
Deletedstatus |
NUMBER |
1 |
PATB_BROKERUPLOAD |
NUMBER |
15 |
PATB_BROKERUPLOAD |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
PATB_BROKERUPLOAD |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
PATB_BROKERUPLOAD |
LEVELNUMBER |
Levelnumber |
NUMBER |
3 |
PATB_BROKERUPLOAD |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
PATB_BROKERUPLOAD |
CHANGETYPE |
Changetype |
VARCHAR2 |
1 |
PATB_BROKERUPLOAD |
VATREGISTERED |
Vatregistered |
NUMBER |
1 |
PATB_BROKERUPLOAD |
VARCHAR2 |
15 |
PATB_BROKERUPLOAD |
NUMBER |
5 |
PATB_BROKERUPLOAD |
VARCHAR2 |
1 |
PATB_BROKERUPLOAD |
UNITHOLDERID |
Unitholderid |
VARCHAR2 |
12 |
PATB_BROKERUPLOAD |
LASTPAYMENTDATE |
Lastpaymentdate |
DATE |
7 |
PATB_BROKERUPLOAD |
LASTPAYMENTNUMBER |
Lastpaymentnumber |
NUMBER |
5 |
PATB_BROKERUPLOAD |
LASTPROCESSEDDATE |
Lastprocesseddate |
DATE |
7 |
PATB_BROKERUPLOAD |
NEXTPAYMENTDATE |
Nextpaymentdate |
DATE |
7 |
PATB_BROKERUPLOAD |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
PATB_BROKERUPLOAD |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
PATB_BROKERUPLOAD |
BROKERTYPE |
Brokertype |
VARCHAR2 |
6 |
PATB_BROKERUPLOAD |
NUMBER |
1 |
PATB_BROKERUPLOAD |
BROKERCONSULTANT |
Brokerconsultant |
VARCHAR2 |
40 |
PATB_BROKERUPLOAD |
BROKERCATEGORY |
Brokercategory |
VARCHAR2 |
1 |
PATB_BROKERUPLOAD |
HOLDBACKPAYMENT |
Holdbackpayment |
NUMBER |
1 |
PATB_BROKERUPLOAD |
MOD_NO |
Mod_No |
NUMBER |
10 |
PATB_BROKERUPLOAD |
HOLDPYMTFROMDATE |
Holdpymtfromdate |
DATE |
7 |
PATB_BROKERUPLOAD |
LATESTRULE |
Latestrule |
NUMBER |
22 |
PATB_BROKERUPLOAD |
BROKERSTATUS |
Brokerstatus |
VARCHAR2 |
1 |
PATB_BROKERUPLOAD |
RECORD_STAT |
Record_Stat |
CHAR |
1 |
PATB_BROKERUPLOAD |
ONCE_AUTH |
Once_Auth |
CHAR |
1 |
PATB_BROKERUPLOAD |
CHAR |
1 |
PATB_BROKERUPLOAD |
DATE |
7 |
PATB_BROKERUPLOAD |
TEMPLATEID |
Templateid |
VARCHAR2 |
6 |
PATB_BROKERUPLOAD |
NUMBER |
1 |
PATB_BROKERUPLOAD |
FATCASTATUS |
Fatcastatus |
VARCHAR2 |
25 |
PATB_BROKERUPLOAD |
NATIONALITY |
Nationality |
VARCHAR2 |
3 |
PATB_BROKERUPLOAD |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
PATB_BROKERUPLOAD |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
PATB_BROKERUPLOAD |
VARCHAR2 |
3 |
PATB_BROKERUPLOAD |
TAXID |
Taxid |
VARCHAR2 |
50 |
PATB_BROKERUPLOAD |
EIN |
Ein |
VARCHAR2 |
50 |
PATB_BROKERUPLOAD |
DATE |
7 |
PATB_BROKERUPLOAD |
DATE |
7 |
PATB_BROKERUPLOAD |
TAXCIRCLE |
Taxcircle |
VARCHAR2 |
15 |
PATB_BROKERUPLOAD |
VARCHAR2 |
25 |
PATB_BROKERUPLOAD |
GIIN |
Giin |
VARCHAR2 |
30 |
PATB_BROKERUPLOAD |
GIINISSUEDATE |
Giinissuedate |
DATE |
7 |
PATB_BROKERUPLOAD |
GIINEXPIRYDATE |
Giinexpirydate |
DATE |
7 |
PATB_BROKERUPLOAD |
GIINVERIFIEDFLAG |
Giinverifiedflag |
NUMBER |
1 |
PATB_BROKERUPLOAD |
FATCASPONSORTYPE |
Fatcasponsortype |
VARCHAR2 |
2 |
PATB_BROKERUPLOAD |
VARCHAR2 |
1 |
PATB_BROKERUPLOAD |
VARCHAR2 |
12 |
PATB_BROKERUPLOAD |
VATEXPIRYDATE |
Vatexpirydate |
DATE |
7 |
PATB_BROKERUPLOAD |
UNAUTHEXIST |
Unauthexist |
VARCHAR2 |
1 |
PATB_BROKERUPLOAD |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_BROKERLEGACYUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
BROKERCODE |
Brokercode |
VARCHAR2 |
12 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
BROKERLEGACYCODE |
Brokerlegacycode |
VARCHAR2 |
12 |
MOD_NO |
Mod_No |
NUMBER |
10 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_BROKERPREFUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
BROKERCODE |
Brokercode |
VARCHAR2 |
12 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
FEEDTYPE |
Feedtype |
VARCHAR2 |
20 |
FEEDSTRUCT |
Feedstruct |
VARCHAR2 |
4 |
FEEDSTARTDATE |
Feedstartdate |
DATE |
7 |
FEEDFREQUENCY |
Feedfrequency |
VARCHAR2 |
20 |
FEEDFORMAT |
Feedformat |
VARCHAR2 |
6 |
MOD_NO |
Mod_No |
NUMBER |
10 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_BROKERBANKDETUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
BROKERCODE |
Brokercode |
VARCHAR2 |
12 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
REFERENCENUMBER |
Referencenumber |
VARCHAR2 |
12 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
ACCOUNTNAME |
Accountname |
VARCHAR2 |
100 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
DEFAULTDETAILS |
Defaultdetails |
NUMBER |
1 |
NUMBER |
1 |
SWIFTFORMAT |
Swiftformat |
VARCHAR2 |
6 |
BANKCHARGED |
Bankcharged |
VARCHAR2 |
12 |
BENEFICIARY |
Beneficiary |
VARCHAR2 |
35 |
BENEFICIARYADD1 |
Beneficiaryadd1 |
VARCHAR2 |
105 |
BENEFICIARYADD2 |
Beneficiaryadd2 |
VARCHAR2 |
105 |
BENEFICIARYADD3 |
Beneficiaryadd3 |
VARCHAR2 |
105 |
VARCHAR2 |
24 |
BENEFICIARYACCTNO |
Beneficiaryacctno |
VARCHAR2 |
34 |
BENEFICIARYCODE |
Beneficiarycode |
VARCHAR2 |
24 |
BENEFICIARYINFO |
Beneficiaryinfo |
VARCHAR2 |
100 |
INTERMEDIARY |
Intermediary |
VARCHAR2 |
35 |
INTERMEDIARYADD1 |
Intermediaryadd1 |
VARCHAR2 |
105 |
INTERMEDIARYADD2 |
Intermediaryadd2 |
VARCHAR2 |
105 |
INTERMEDIARYADD3 |
Intermediaryadd3 |
VARCHAR2 |
105 |
VARCHAR2 |
24 |
VARCHAR2 |
34 |
INTERMEDIARYCODE |
Intermediarycode |
VARCHAR2 |
24 |
INTERMEDIARYINFO |
Intermediaryinfo |
VARCHAR2 |
100 |
FURTHERCREDITNAME |
Furthercreditname |
VARCHAR2 |
35 |
VARCHAR2 |
35 |
REFERENCE1 |
Reference1 |
VARCHAR2 |
35 |
REFERENCE2 |
Reference2 |
VARCHAR2 |
35 |
IBAN |
Iban |
VARCHAR2 |
40 |
BENEFICIARYIBAN |
Beneficiaryiban |
VARCHAR2 |
40 |
INTERMEDIARYIBAN |
Intermediaryiban |
VARCHAR2 |
40 |
MOD_NO |
Mod_No |
NUMBER |
10 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_BROKERCONTACTUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ENTITYID |
Entityid |
VARCHAR2 |
12 |
ENTITYTYPE |
Entitytype |
VARCHAR2 |
2 |
ADDRESSTYPE |
Addresstype |
VARCHAR2 |
2 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
80 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
80 |
ADDRESSLINE3 |
Addressline3 |
VARCHAR2 |
80 |
ADDRESSLINE4 |
Addressline4 |
VARCHAR2 |
80 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
COUNTRY |
Country |
VARCHAR2 |
3 |
USSTATE |
Usstate |
NUMBER |
1 |
TELEPHONE1 |
Telephone1 |
VARCHAR2 |
60 |
TELEPHONE2 |
Telephone2 |
VARCHAR2 |
60 |
CELLPHONENUMBER |
Cellphonenumber |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
VARCHAR2 |
255 |
CONTACTPERSON |
Contactperson |
VARCHAR2 |
160 |
EFFECTIVEFROMDATE |
Effectivefromdate |
DATE |
7 |
EFFECTIVETODATE |
Effectivetodate |
DATE |
7 |
BICCODE |
Biccode |
VARCHAR2 |
16 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
MOD_NO |
Mod_No |
NUMBER |
10 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_BROKERPARTIESUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
BROKERCODE |
Brokercode |
VARCHAR2 |
12 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
RPENTITYID |
Rpentityid |
VARCHAR2 |
12 |
RPENTITYTYPE |
Rpentitytype |
VARCHAR2 |
2 |
REPORTINGLEVEL |
Reportinglevel |
VARCHAR2 |
1 |
PREFMAILMODE |
Prefmailmode |
VARCHAR2 |
1 |
REMARKS |
Remarks |
VARCHAR2 |
255 |
APPLYLEVEL |
Applylevel |
VARCHAR2 |
3 |
APPLYTO |
Applyto |
VARCHAR2 |
12 |
MOD_NO |
Mod_No |
NUMBER |
10 |
The upload format for Pension held-away holdings is as follows:
Field Name |
Description |
Datatype |
Length |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
ASSETCLASS |
Assetclass |
VARCHAR2 |
10 |
PORTFOLIOID |
Portfolioid |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
ASSETID |
Assetid |
VARCHAR2 |
16 |
UNITBALANCE |
Unitbalance |
NUMBER |
30 |
BLOCKEDUNITS |
Blockedunits |
NUMBER |
30 |
AVAILABLEBALANCE |
Availablebalance |
NUMBER |
30 |
The upload format for identification details is as follows:
Field Name |
Description |
Data Type |
Length |
SEQUENCENUMBER |
NUMBER |
22 |
PROCESSID |
VARCHAR2 |
50 |
BULKCLIENTCODE |
BulkclientCode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
IDREFERENCENO |
Idreferenceno |
VARCHAR2 |
16 |
VARCHAR2 |
16 |
VARCHAR2 |
20 |
VARCHAR2 |
50 |
PLACEOFISSUE |
Placeofissue |
VARCHAR2 |
3 |
ISSUEAUTHORITY |
Issueauthority |
VARCHAR2 |
50 |
ISSUECOUNTRY |
Issuecountry |
VARCHAR2 |
3 |
DATEOFISSUE |
Dateofissue |
DATE |
7 |
DATEOFEXPIRY |
Dateofexpiry |
DATE |
7 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
VARCHAR2 |
1 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
MAKER_ID |
Maker_ID |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_ID |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
Field Name |
Description |
Data Type |
Length |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
BANKREFERENCENO |
Bankreferenceno |
VARCHAR2 |
16 |
VARCHAR2 |
16 |
ACCOUNTHOLDERNAME |
Accountholdername |
VARCHAR2 |
100 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
IBAN |
Iban |
VARCHAR2 |
40 |
VARCHAR2 |
1 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
Field Name |
Description |
Datatype |
Length |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
CONTACTREFNO |
Contactrefno |
VARCHAR2 |
16 |
VARCHAR2 |
16 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
100 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
100 |
ADDRESSLINE3 |
Addressline3 |
VARCHAR2 |
100 |
POSTBOXNO |
Postboxno |
VARCHAR2 |
16 |
CITY |
City |
VARCHAR2 |
80 |
STATE |
State |
VARCHAR2 |
80 |
COUNTRY |
Country |
VARCHAR2 |
3 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
BICCODE |
Biccode |
VARCHAR2 |
16 |
WEBSITE |
Website |
VARCHAR2 |
100 |
EMAILADDRESS |
Emailaddress |
VARCHAR2 |
100 |
EFFECTIVEFROMDATE |
Effectivefromdate |
DATE |
7 |
EFFECTIVETODATE |
Effectivetodate |
DATE |
7 |
VARCHAR2 |
100 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
PRIMARYPOSITION |
Primaryposition |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
PRIMARYFIXEDLINE |
Primaryfixedline |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
VARCHAR2 |
100 |
PRIMARYEXTN |
Primaryextn |
VARCHAR2 |
60 |
VARCHAR2 |
100 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
SECONDARYPOSITION |
Secondaryposition |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
105 |
SECONDARYEXTN |
Secondaryextn |
VARCHAR2 |
60 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
Field Name |
Description |
Datatype |
Length |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYROLE |
Partyrole |
VARCHAR2 |
2 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PARTYROLEID |
Partyroleid |
VARCHAR2 |
16 |
EMPLOYEEID |
Employeeid |
VARCHAR2 |
20 |
EMPLOYERCODE |
Employercode |
VARCHAR2 |
12 |
COMPLIANCESTATUS |
Compliancestatus |
VARCHAR2 |
1 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
Segment Identification Number |
Description |
01MAS |
This segment is used to provide investment account master upload details |
02INT |
This segment is used to provide intermediary account upload details |
03BNK |
This segment is used to provide bank account upload detail |
04BNF |
This segment is used to provide beneficiary account upload detail |
05ADD |
This segment is used to provide additional information of account upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_INVESTMENTACCMASTERUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
ACOPERATIONTYPE |
Acoperationtype |
VARCHAR2 |
1 |
DEALINGTYPE |
Dealingtype |
VARCHAR2 |
3 |
GUARDIANID |
Guardianid |
VARCHAR2 |
12 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
INVESTORCATEGORY |
Investorcategory |
VARCHAR2 |
2 |
ACOPENINGDATE |
Acopeningdate |
DATE |
7 |
ACCOUNTREFNO |
Accountrefno |
VARCHAR2 |
16 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
ACCOUNTSTATUS |
Accountstatus |
VARCHAR2 |
1 |
PENSIONACCOUNT |
Pensionaccount |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_INVESTACCINTERUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
INTERMEDIARYID |
Intermediaryid |
VARCHAR2 |
12 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
22 |
DEFAULTFLAG |
Defaultflag |
VARCHAR2 |
1 |
Description |
01MAS |
This segment is used to provide portfolio upload details |
02PID |
This segment is used to provide portfolio ID details |
03INS |
This segment is used to provide portfolio instrument upload detail |
04AST |
This segment is used to provide portfolio asset upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYPORTFOLIOUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYROLE |
Partyrole |
VARCHAR2 |
12 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYPORTFOLIOIDUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYROLE |
Partyrole |
VARCHAR2 |
12 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
PORTFOLIOID |
Portfolioid |
VARCHAR2 |
16 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYPORTFOLIOASSETUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYROLE |
Partyrole |
VARCHAR2 |
12 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
PORTFOLIOID |
Portfolioid |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
ASSETID |
Assetid |
VARCHAR2 |
12 |
RATIO |
Ratio |
NUMBER |
22 |
OVERRIDE |
Override |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYPFINSTASSETUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYROLE |
Partyrole |
VARCHAR2 |
12 |
PARTYID |
Party ID |
VARCHAR2 |
12 |
ACCOUNTID |
Account ID |
VARCHAR2 |
16 |
PORTFOLIOID |
Portfolio ID |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrument ID |
VARCHAR2 |
16 |
INSTRUMENTRATIO |
Instrument Ratio |
NUMBER |
22 |
Description |
01MAS |
This segment is used to provide party master upload details |
02CON |
This segment is used to provide party contact upload details |
03DIR |
This segment is used to provide party director upload detail |
04BNK |
This segment is used to provide party bank upload detail |
05IDN |
This segment is used to provide party identification upload detail |
06TAX |
This segment is used to provide party tax compilation upload detail |
07ADD |
This segment is used to provide party additional information upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYMASTERUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PARTYTYPE |
Partytype |
VARCHAR2 |
3 |
TITLE |
Title |
VARCHAR2 |
15 |
FIRSTNAME |
Firstname |
VARCHAR2 |
100 |
MIDDLENAME |
Middlename |
VARCHAR2 |
100 |
LASTNAME |
Lastname |
VARCHAR2 |
100 |
REGISTEREDNAME |
Registeredname |
VARCHAR2 |
100 |
DATEOFBIRTH |
Dateofbirth |
DATE |
7 |
DATE |
7 |
MARITALSTATUS |
Maritalstatus |
VARCHAR2 |
1 |
OCCUPATION |
Occupation |
VARCHAR2 |
3 |
GENDER |
Gender |
VARCHAR2 |
1 |
PREFERREDCURRENCY |
Preferredcurrency |
VARCHAR2 |
3 |
MINOR |
Minor |
NUMBER |
1 |
NATIONALITY |
Nationality |
VARCHAR2 |
3 |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
DUALNATIONALITY |
Dualnationality |
VARCHAR2 |
3 |
NUMBER |
1 |
HEALTHSTATUS |
Healthstatus |
VARCHAR2 |
1 |
PROTECTIONLEVEL |
Protectionlevel |
VARCHAR2 |
1 |
VARCHAR2 |
100 |
VARCHAR2 |
100 |
VARCHAR2 |
100 |
CORPORATIONTYPE |
Corporationtype |
VARCHAR2 |
3 |
NUMBER |
22 |
VARCHAR2 |
3 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
FATHERSPOUSENAME |
Fatherspousename |
VARCHAR2 |
105 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYCONTACTUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
CONTACTREFNO |
Contactrefno |
VARCHAR2 |
16 |
ADDRESSTYPE |
Addresstype |
VARCHAR2 |
2 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
100 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
100 |
ADDRESSLINE3 |
Addressline3 |
VARCHAR2 |
100 |
POSTBOXNO |
Postboxno |
VARCHAR2 |
16 |
CITY |
City |
VARCHAR2 |
80 |
STATE |
State |
VARCHAR2 |
80 |
COUNTRY |
Country |
VARCHAR2 |
3 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
WEBSITE |
Website |
VARCHAR2 |
100 |
VARCHAR2 |
100 |
EFFECTIVEFROMDATE |
Effectivefromdate |
DATE |
7 |
EFFECTIVETODATE |
Effectivetodate |
DATE |
7 |
VARCHAR2 |
100 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
PRIMARYPOSITION |
Primaryposition |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
PRIMARYFIXEDLINE |
Primaryfixedline |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
VARCHAR2 |
100 |
PRIMARYEXTN |
Primaryextn |
VARCHAR2 |
60 |
VARCHAR2 |
100 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
SECONDARYPOSITION |
Secondaryposition |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
105 |
SECONDARYEXTN |
Secondaryextn |
VARCHAR2 |
60 |
BICCODE |
Biccode |
VARCHAR2 |
16 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYDIRECTORUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
DIRECTORID |
Directorid |
VARCHAR2 |
12 |
PERCENTAGE |
Percentage |
NUMBER |
5 |
CONTROLLINGPERSON |
Controllingperson |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYBANKUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
BANKREFERENCENO |
Bankreferenceno |
VARCHAR2 |
16 |
OWNERSHIPTYPE |
Ownershiptype |
VARCHAR2 |
1 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
IBAN |
Iban |
VARCHAR2 |
40 |
VARCHAR2 |
1 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
ACCOUNTHOLDERNAME |
Accountholdername |
VARCHAR2 |
100 |
USERREFERENCENUMBER |
Userreferencenumber |
VARCHAR2 |
16 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYIDENTIFICATIONUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
IDREFERENCENO |
Idreferenceno |
VARCHAR2 |
16 |
VARCHAR2 |
16 |
VARCHAR2 |
20 |
VARCHAR2 |
50 |
PLACEOFISSUE |
Placeofissue |
VARCHAR2 |
3 |
ISSUEAUTHORITY |
Issueauthority |
VARCHAR2 |
50 |
ISSUECOUNTRY |
Issuecountry |
VARCHAR2 |
3 |
DATEOFISSUE |
Dateofissue |
DATE |
7 |
DATEOFEXPIRY |
Dateofexpiry |
DATE |
7 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYTAXCOMPLUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
TAXCOMPLIANCE |
Taxcompliance |
VARCHAR2 |
10 |
TAXJURISDICTION |
Taxjurisdiction |
VARCHAR2 |
3 |
INDICIAAVAILABLE |
Indiciaavailable |
NUMBER |
1 |
REPORTABLESTATUS |
Reportablestatus |
VARCHAR2 |
1 |
REMARKS |
Remarks |
VARCHAR2 |
255 |
CRITERIAMATCHED |
Criteriamatched |
VARCHAR2 |
255 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYADDINFOUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PARTYID |
Partyid |
VARCHAR2 |
16 |
ADDINFOLABEL |
Addinfolabel |
VARCHAR2 |
30 |
FIELDVALUE |
Fieldvalue |
CHAR |
23 |
Description |
00FDU |
This segment is used to provide fund demographics upload details |
01TPR |
This segment is used to provide third party upload details |
02FLU |
This segment is used to provide fund load upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
FUNDDEMOGRAPHICSUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
VARCHAR2 |
50 |
FUNDID |
Fundid |
VARCHAR2 |
6 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
FUNDSTARTDATE |
Fundstartdate |
DATE |
7 |
FUNDNAME |
Fundname |
VARCHAR2 |
60 |
FUNDNAMESHORT |
Fundnameshort |
VARCHAR2 |
90 |
FUNDCLASS |
Fundclass |
VARCHAR2 |
1 |
FUNDTYPE |
Fundtype |
NUMBER |
38 |
FUNDFAMILY |
Fundfamily |
VARCHAR2 |
6 |
FUNDBASECURRENCY |
Fundbasecurrency |
VARCHAR2 |
3 |
FUNDCOUNTRY |
Fundcountry |
VARCHAR2 |
3 |
FISCALSTARTYEAR |
Fiscalstartyear |
DATE |
7 |
FISCALENDYEAR |
Fiscalendyear |
DATE |
7 |
AMCID |
Amcid |
VARCHAR2 |
12 |
BROKERSALLOWED |
Brokersallowed |
NUMBER |
1 |
REGISTRARID |
Registrarid |
VARCHAR2 |
12 |
TRUSTEEID |
Trusteeid |
VARCHAR2 |
12 |
LATESTRULE |
Latestrule |
NUMBER |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
MINHOLDINGPERIOD |
Minholdingperiod |
NUMBER |
22 |
PRIMARYREGADDRESS |
Primaryregaddress |
VARCHAR2 |
255 |
FUNDTAXID |
Fundtaxid |
VARCHAR2 |
25 |
FUNDIDENTIFICATIONNUMBER |
Fundidentificationnumber |
VARCHAR2 |
25 |
FUNDTICKERSYMBOL |
Fundtickersymbol |
VARCHAR2 |
25 |
ALLOWIRAINVESTMENTS |
Allowirainvestments |
NUMBER |
1 |
CUSTODIAN |
Custodian |
VARCHAR2 |
12 |
FUNDSUSPENDED |
Fundsuspended |
NUMBER |
1 |
MINAMOUNTFORTAXIDINDV |
Minamountfortaxidindv |
NUMBER |
30 |
MINAMOUNTFORTAXIDCOR |
Minamountfortaxidcor |
NUMBER |
30 |
RECORD_STAT |
Record_Stat |
CHAR |
1 |
ONCE_AUTH |
Once_Auth |
CHAR |
1 |
EXISTINGFUND |
Existingfund |
NUMBER |
1 |
UMBRELLAFUND |
Umbrellafund |
NUMBER |
1 |
HEDGEFUND |
Hedgefund |
VARCHAR2 |
1 |
FUNDENABLED |
Fundenabled |
NUMBER |
1 |
COEENABLED |
Coeenabled |
VARCHAR2 |
1 |
LEGALENTITY |
Legalentity |
VARCHAR2 |
12 |
FUNDCLOSEDDATE |
Fundcloseddate |
DATE |
7 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
TPRUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
TPRUPLOADTBL |
PROCESSID |
Processid |
VARCHAR2 |
50 |
TPRUPLOADTBL |
VARCHAR2 |
50 |
TPRUPLOADTBL |
FUNDID |
Fundid |
VARCHAR2 |
6 |
TPRUPLOADTBL |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
TPRUPLOADTBL |
TRANSACTIONTYPE |
Transactiontype |
VARCHAR2 |
2 |
TPRUPLOADTBL |
TRANSACTIONSTARTDATE |
Transactionstartdate |
DATE |
7 |
TPRUPLOADTBL |
TRANSACTIONENDDATE |
Transactionenddate |
DATE |
7 |
TPRUPLOADTBL |
TRANSACTIONFREQUENCY |
Transactionfrequency |
VARCHAR2 |
1 |
TPRUPLOADTBL |
TRANSACTIONSTARTPERIOD |
Transactionstartperiod |
NUMBER |
22 |
TPRUPLOADTBL |
TRANSACTIONENDPERIOD |
Transactionendperiod |
NUMBER |
22 |
TPRUPLOADTBL |
TRANSACTIONSTARTTIME |
Transactionstarttime |
DATE |
7 |
TPRUPLOADTBL |
TRANSACTIONENDTIME |
Transactionendtime |
DATE |
7 |
TPRUPLOADTBL |
MINTRANSACTIONAMOUNT |
Mintransactionamount |
NUMBER |
30 |
TPRUPLOADTBL |
STEPAMOUNT |
Stepamount |
NUMBER |
30 |
TPRUPLOADTBL |
MAXTRANSACTIONAMOUNT |
Maxtransactionamount |
NUMBER |
30 |
TPRUPLOADTBL |
MINTRANSACTIONUNITS |
Mintransactionunits |
NUMBER |
27 |
TPRUPLOADTBL |
STEPUNITS |
Stepunits |
NUMBER |
27 |
TPRUPLOADTBL |
MAXTRANSACTIONUNITS |
Maxtransactionunits |
NUMBER |
27 |
TPRUPLOADTBL |
ONLINEALLOCATION |
Onlineallocation |
NUMBER |
1 |
TPRUPLOADTBL |
ALLOCATIONPERVSREGCAPITAL |
Allocationpervsregcapital |
NUMBER |
20 |
TPRUPLOADTBL |
ALLOCATIONPOLICY |
Allocationpolicy |
VARCHAR2 |
1 |
TPRUPLOADTBL |
NOOFTXNALLOWEDFORFREQ |
Nooftxnallowedforfreq |
VARCHAR2 |
1 |
TPRUPLOADTBL |
NOOFTXNALLOWEDPERUH |
Nooftxnallowedperuh |
NUMBER |
22 |
TPRUPLOADTBL |
NOOFFREETXNALLOWEDPERUH |
Nooffreetxnallowedperuh |
NUMBER |
22 |
TPRUPLOADTBL |
ALLOWBACKDATING |
Allowbackdating |
NUMBER |
1 |
TPRUPLOADTBL |
BACKDATINGLIMIT |
Backdatinglimit |
NUMBER |
22 |
TPRUPLOADTBL |
FUNDTRANSACTIONCOUNTER |
Fundtransactioncounter |
NUMBER |
22 |
TPRUPLOADTBL |
ACKNOWLEDGEMENTREQUIRED |
Acknowledgementrequired |
NUMBER |
1 |
TPRUPLOADTBL |
CONFIRMATIONREQUIRED |
Confirmationrequired |
NUMBER |
1 |
TPRUPLOADTBL |
BASEPRICEDEFINITION |
Basepricedefinition |
VARCHAR2 |
60 |
TPRUPLOADTBL |
BASEPRICEFACTOR |
Basepricefactor |
NUMBER |
7 |
TPRUPLOADTBL |
NOOFDECIMALSFORBASEPRICE |
Noofdecimalsforbaseprice |
NUMBER |
22 |
TPRUPLOADTBL |
ROUNDOFFTRUNCATEBASEPRICE |
Roundofftruncatebaseprice |
VARCHAR2 |
1 |
TPRUPLOADTBL |
TRANSACTIONENABLED |
Transactionenabled |
NUMBER |
1 |
TPRUPLOADTBL |
CROSSBRANCHALLOWED |
Crossbranchallowed |
NUMBER |
1 |
TPRUPLOADTBL |
PRICELAG |
Pricelag |
NUMBER |
22 |
TPRUPLOADTBL |
ALLOCATIONLAG |
Allocationlag |
NUMBER |
22 |
TPRUPLOADTBL |
CONFIRMATIONLAG |
Confirmationlag |
NUMBER |
22 |
TPRUPLOADTBL |
CHQALLOCONPARWITHCASH |
Chqalloconparwithcash |
NUMBER |
1 |
TPRUPLOADTBL |
HOLDINGPERIODAPPLICABLE |
Holdingperiodapplicable |
NUMBER |
1 |
TPRUPLOADTBL |
RETAINAGEINGTOSUBSCRIPTION |
Retainageingtosubscription |
NUMBER |
1 |
TPRUPLOADTBL |
CREDITCARDALLOCONPARWITHCASH |
Creditcardalloconparwithcash |
NUMBER |
1 |
TPRUPLOADTBL |
LIMITREDEMPTIONMODE |
Limitredemptionmode |
VARCHAR2 |
1 |
TPRUPLOADTBL |
NATUREOFLIMIT |
Natureoflimit |
VARCHAR2 |
1 |
TPRUPLOADTBL |
TRANSFERALLOCONPARWITHCASH |
Transferalloconparwithcash |
NUMBER |
1 |
TPRUPLOADTBL |
GROSSAMOUNT |
Grossamount |
VARCHAR2 |
1 |
TPRUPLOADTBL |
GROSSUNITS |
Grossunits |
VARCHAR2 |
1 |
TPRUPLOADTBL |
NETAMOUNT |
Netamount |
VARCHAR2 |
1 |
TPRUPLOADTBL |
NETUNITS |
Netunits |
VARCHAR2 |
1 |
TPRUPLOADTBL |
MININITIALTXNAMOUNT |
Mininitialtxnamount |
NUMBER |
30 |
TPRUPLOADTBL |
MININITIALTXNUNITS |
Mininitialtxnunits |
NUMBER |
27 |
TPRUPLOADTBL |
MINSITXNAMOUNT |
Minsitxnamount |
NUMBER |
30 |
TPRUPLOADTBL |
MAXSITXNAMOUNT |
Maxsitxnamount |
NUMBER |
30 |
TPRUPLOADTBL |
MINSITXNUNITS |
Minsitxnunits |
NUMBER |
27 |
TPRUPLOADTBL |
MAXSITXNUNITS |
Maxsitxnunits |
NUMBER |
27 |
TPRUPLOADTBL |
EXISTINGUH |
Existinguh |
VARCHAR2 |
2 |
TPRUPLOADTBL |
NOOFDECIMALSFORUNITPRICE |
Noofdecimalsforunitprice |
NUMBER |
22 |
TPRUPLOADTBL |
ROUNDOFFTRUNCATEUNITPRICE |
Roundofftruncateunitprice |
VARCHAR2 |
1 |
TPRUPLOADTBL |
ROUNDOFFTRUNCATEUNITS |
Roundofftruncateunits |
VARCHAR2 |
1 |
TPRUPLOADTBL |
PAYMENTLAG |
Paymentlag |
NUMBER |
22 |
TPRUPLOADTBL |
TRANSACTIONCUTOFFTIME |
Transactioncutofftime |
DATE |
7 |
TPRUPLOADTBL |
ENFORCEHOLDINGPERIOD |
Enforceholdingperiod |
NUMBER |
1 |
TPRUPLOADTBL |
APPLYENTRYTIMELOAD |
Applyentrytimeload |
NUMBER |
1 |
TPRUPLOADTBL |
IPOMAXISSUESIZE |
Ipomaxissuesize |
NUMBER |
27 |
TPRUPLOADTBL |
FLUCTUATIONALLOWED |
Fluctuationallowed |
NUMBER |
5 |
TPRUPLOADTBL |
TRANSACTIONSUSPENDED |
Transactionsuspended |
NUMBER |
1 |
TPRUPLOADTBL |
MINSIHOLDINGAMOUNT |
Minsiholdingamount |
NUMBER |
30 |
TPRUPLOADTBL |
MINSIHOLDINGUNITS |
Minsiholdingunits |
NUMBER |
27 |
TPRUPLOADTBL |
MINSIHOLDINGAPPLYFOR |
Minsiholdingapplyfor |
VARCHAR2 |
1 |
TPRUPLOADTBL |
MINSIHOLDINGINDICATOR |
Minsiholdingindicator |
VARCHAR2 |
1 |
TPRUPLOADTBL |
PRICELAGCALENDARBASIS |
Pricelagcalendarbasis |
VARCHAR2 |
1 |
TPRUPLOADTBL |
ALLOCLAGCALENDARBASIS |
Alloclagcalendarbasis |
VARCHAR2 |
1 |
TPRUPLOADTBL |
SIDESCRIPTION |
Sidescription |
VARCHAR2 |
255 |
TPRUPLOADTBL |
SIHOLIDAYRULE |
Siholidayrule |
VARCHAR2 |
1 |
TPRUPLOADTBL |
SICALENDERBASIS |
Sicalenderbasis |
VARCHAR2 |
1 |
TPRUPLOADTBL |
SIGENDAY |
Sigenday |
VARCHAR2 |
3 |
TPRUPLOADTBL |
SIFREQUENCY |
Sifrequency |
VARCHAR2 |
1 |
TPRUPLOADTBL |
SIGENCYCLE |
Sigencycle |
VARCHAR2 |
1 |
TPRUPLOADTBL |
SICUTOFFDAY |
Sicutoffday |
NUMBER |
22 |
TPRUPLOADTBL |
SICUTOFFLAG |
Sicutofflag |
NUMBER |
22 |
TPRUPLOADTBL |
ENFORCESIRULE |
Enforcesirule |
NUMBER |
22 |
TPRUPLOADTBL |
PAYMENTLAGCALENDARBASIS |
Paymentlagcalendarbasis |
VARCHAR2 |
1 |
TPRUPLOADTBL |
LINKTOUNSETTLEDINFLOWS |
Linktounsettledinflows |
NUMBER |
1 |
TPRUPLOADTBL |
PSEUDOSWITCHLAG |
Pseudoswitchlag |
NUMBER |
22 |
TPRUPLOADTBL |
ALLOWSYSTEMATICPLANS |
Allowsystematicplans |
NUMBER |
1 |
TPRUPLOADTBL |
MAXINITIALTXNAMOUNT |
Maxinitialtxnamount |
NUMBER |
30 |
TPRUPLOADTBL |
MAXINITIALTXNUNITS |
Maxinitialtxnunits |
NUMBER |
27 |
TPRUPLOADTBL |
PSEUDOSWITCHLAGCALENDARBASIS |
Pseudoswitchlagcalendarbasis |
VARCHAR2 |
1 |
TPRUPLOADTBL |
FULLOUTFLOW |
Fulloutflow |
NUMBER |
1 |
TPRUPLOADTBL |
MAXNOOFSITRANSACTIONS |
Maxnoofsitransactions |
NUMBER |
4 |
TPRUPLOADTBL |
MAXVALIDITY |
Maxvalidity |
NUMBER |
4 |
TPRUPLOADTBL |
SILEADTIME |
Sileadtime |
NUMBER |
22 |
TPRUPLOADTBL |
APPLICABLEACCOUNTTYPES |
Applicableaccounttypes |
VARCHAR2 |
255 |
TPRUPLOADTBL |
INFLOWOVERRIDABLEMSG |
Inflowoverridablemsg |
NUMBER |
1 |
TPRUPLOADTBL |
MINMATURITYPERIOD |
Minmaturityperiod |
NUMBER |
4 |
TPRUPLOADTBL |
MAXMATURITYPERIOD |
Maxmaturityperiod |
NUMBER |
4 |
TPRUPLOADTBL |
FUTUREDATELIMIT |
Futuredatelimit |
NUMBER |
22 |
TPRUPLOADTBL |
UHCALENDARBASIS |
Uhcalendarbasis |
VARCHAR2 |
1 |
TPRUPLOADTBL |
NOOFDECIMALSFORUNITS |
Noofdecimalsforunits |
NUMBER |
22 |
TPRUPLOADTBL |
NOTICEPERIODDATEBASIS |
Noticeperioddatebasis |
VARCHAR2 |
1 |
TPRUPLOADTBL |
NOTICEPERIOD |
Noticeperiod |
NUMBER |
3 |
TPRUPLOADTBL |
SIAUTOTERMINATIONCOUNTER |
Siautoterminationcounter |
NUMBER |
3 |
TPRUPLOADTBL |
THRESHOLDAMOUNT |
Thresholdamount |
NUMBER |
30 |
TPRUPLOADTBL |
CONSSIAUTOCOUNTER |
Conssiautocounter |
NUMBER |
3 |
TPRUPLOADTBL |
MAXSITXNSALLOWED |
Maxsitxnsallowed |
NUMBER |
3 |
TPRUPLOADTBL |
STARTTIME |
Starttime |
VARCHAR2 |
8 |
TPRUPLOADTBL |
ENDTIME |
Endtime |
VARCHAR2 |
8 |
TPRUPLOADTBL |
CUTOFFTIME |
Cutofftime |
VARCHAR2 |
8 |
TPRUPLOADTBL |
GOCUTOFFLAG |
Gocutofflag |
VARCHAR2 |
8 |
TPRUPLOADTBL |
GOTHRESHOLDUNITS |
Gothresholdunits |
NUMBER |
27 |
TPRUPLOADTBL |
GOSETTLEMENTLAG |
Gosettlementlag |
NUMBER |
22 |
TPRUPLOADTBL |
GOSETTLAGCALENDAR |
Gosettlagcalendar |
VARCHAR2 |
1 |
TPRUPLOADTBL |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
FUNDLOADUPLOADTBL |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
FUNDLOADUPLOADTBL |
PROCESSID |
Processid |
VARCHAR2 |
50 |
FUNDLOADUPLOADTBL |
VARCHAR2 |
50 |
FUNDLOADUPLOADTBL |
FUNDID |
Fundid |
VARCHAR2 |
6 |
FUNDLOADUPLOADTBL |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
FUNDLOADUPLOADTBL |
TRANSACTIONTYPE |
Transactiontype |
VARCHAR2 |
2 |
FUNDLOADUPLOADTBL |
LOADID |
Loadid |
NUMBER |
5 |
FUNDLOADUPLOADTBL |
LOADTOPRICE |
Loadtoprice |
NUMBER |
22 |
FUNDLOADUPLOADTBL |
FROMENTITYTYPE |
Fromentitytype |
VARCHAR2 |
1 |
FUNDLOADUPLOADTBL |
TOENTITYTYPE |
Toentitytype |
VARCHAR2 |
1 |
FUNDLOADUPLOADTBL |
PROCESSINGFREQ |
Processingfreq |
VARCHAR2 |
1 |
FUNDLOADUPLOADTBL |
GLACCOUNTCODE |
Glaccountcode |
VARCHAR2 |
10 |
FUNDLOADUPLOADTBL |
DEBITORCREDIT |
Debitorcredit |
VARCHAR2 |
1 |
FUNDLOADUPLOADTBL |
CONTRAACCOUNTCODE |
Contraaccountcode |
VARCHAR2 |
10 |
FUNDLOADUPLOADTBL |
NOOFDECIMALSFORLOAD |
Noofdecimalsforload |
NUMBER |
1 |
FUNDLOADUPLOADTBL |
ROUNDOFFTRUNCATEFORLOAD |
Roundofftruncateforload |
VARCHAR2 |
1 |
FUNDLOADUPLOADTBL |
MANDATORY |
Mandatory |
VARCHAR2 |
1 |
FUNDLOADUPLOADTBL |
PRIORITYNO |
Priorityno |
NUMBER |
22 |
FUNDLOADUPLOADTBL |
LOADVATTOPRICE |
Loadvattoprice |
NUMBER |
22 |
FUNDLOADUPLOADTBL |
APPLYRETVALON |
Applyretvalon |
VARCHAR2 |
1 |
FUNDLOADUPLOADTBL |
SENDFORGLINTERFACE |
Sendforglinterface |
NUMBER |
1 |
FUNDLOADUPLOADTBL |
REFTYPE |
Reftype |
VARCHAR2 |
4 |
FUNDLOADUPLOADTBL |
DIFFERENTIALFEE |
Differentialfee |
NUMBER |
1 |
FUNDLOADUPLOADTBL |
SLABBASIS |
Slabbasis |
VARCHAR2 |
1 |
FUNDLOADUPLOADTBL |
PRICEADDIN |
Priceaddin |
NUMBER |
1 |
FUNDLOADUPLOADTBL |
GROUPID |
Groupid |
VARCHAR2 |
6 |
FUNDLOADUPLOADTBL |
INDEXATIONONCGT |
Indexationoncgt |
VARCHAR2 |
1 |
FUNDLOADUPLOADTBL |
LEVELID |
Levelid |
NUMBER |
22 |
FUNDLOADUPLOADTBL |
DEPENDENTLEVEL |
Dependentlevel |
NUMBER |
22 |
FUNDLOADUPLOADTBL |
FDAPINCOME |
Fdapincome |
NUMBER |
1 |
FUNDLOADUPLOADTBL |
Field name |
Description |
Datatype |
Length |
Table Name |
SEQUENCENUMBER |
Sequence Number |
NUMBER |
10 |
PHFUNDPRICETBL |
PROCESSID |
Process ID |
VARCHAR2 |
50 |
PHFUNDPRICETBL |
BULKCLIENTCODE |
Bulk Client Code |
VARCHAR2 |
12 |
PHFUNDPRICETBL |
UPLOADMODE |
Upload Mode |
VARCHAR2 |
1 |
PHFUNDPRICETBL |
UserReference Number |
VARCHAR2 |
16 |
PHFUNDPRICETBL |
FUNDID |
Fund ID |
VARCHAR2 |
6 |
PHFUNDPRICETBL |
TRANSACTIONTYPE |
Transaction Type |
VARCHAR2 |
2 |
PHFUNDPRICETBL |
TRANSACTIONBASEPRICE |
Txn Base Price |
VARCHAR2 |
20 |
PHFUNDPRICETBL |
Description |
00PAR |
This segment is used to provide party master investment upload details |
03ADR |
This segment is used to provide party contact investment upload details |
04IDD |
This segment is used to provide party ID investment upload detail |
05IAC |
This segment is used to provide investment master export upload detail |
06INT |
This segment is used to provide investment account intermediary export upload detail |
07IBK |
This segment is used to provide investment party bank upload detail |
08IBF |
This segment is used to provide investment account beneficiary upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_PARTYMASTERINVEXPORT |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PARTYTYPE |
Partytype |
VARCHAR2 |
3 |
TITLE |
Title |
VARCHAR2 |
15 |
FIRSTNAME |
Firstname |
VARCHAR2 |
100 |
MIDDLENAME |
Middlename |
VARCHAR2 |
100 |
LASTNAME |
Lastname |
VARCHAR2 |
100 |
REGISTEREDNAME |
Registeredname |
VARCHAR2 |
100 |
DATEOFBIRTH |
Dateofbirth |
DATE |
7 |
DATEOFINCORPORATION |
Dateofincorporation |
DATE |
7 |
MARITALSTATUS |
Maritalstatus |
VARCHAR2 |
1 |
OCCUPATION |
Occupation |
VARCHAR2 |
3 |
GENDER |
Gender |
VARCHAR2 |
1 |
PREFERREDCURRENCY |
Preferredcurrency |
VARCHAR2 |
3 |
MINOR |
Minor |
NUMBER |
1 |
NATIONALITY |
Nationality |
VARCHAR2 |
3 |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
DUALNATIONALITY |
Dualnationality |
VARCHAR2 |
3 |
SUBSTANTIALSTAYINUS |
Substantialstayinus |
NUMBER |
1 |
HEALTHSTATUS |
Healthstatus |
VARCHAR2 |
1 |
PROTECTIONLEVEL |
Protectionlevel |
VARCHAR2 |
1 |
FIRSTAUTHORIZEDSIGNATORY |
Firstauthorizedsignatory |
VARCHAR2 |
100 |
SECONDAUTHORIZEDSIGNATORY |
Secondauthorizedsignatory |
VARCHAR2 |
100 |
THIRDAUTHORIZEDSIGNATORY |
Thirdauthorizedsignatory |
VARCHAR2 |
100 |
CORPORATIONTYPE |
Corporationtype |
VARCHAR2 |
3 |
MINNOOFCORPORATESIGNATORY |
Minnoofcorporatesignatory |
NUMBER |
22 |
INCORPORATIONCOUNTRY |
Incorporationcountry |
VARCHAR2 |
3 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
FATHERSPOUSENAME |
Fatherspousename |
VARCHAR2 |
105 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_PARTYCONTACTINVEXPORT |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
CONTACTREFNO |
Contactrefno |
VARCHAR2 |
16 |
ADDRESSTYPE |
Addresstype |
VARCHAR2 |
2 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
100 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
100 |
ADDRESSLINE3 |
Addressline3 |
VARCHAR2 |
100 |
POSTBOXNO |
Postboxno |
VARCHAR2 |
16 |
CITY |
City |
VARCHAR2 |
80 |
STATE |
State |
VARCHAR2 |
80 |
COUNTRY |
Country |
VARCHAR2 |
3 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
BICCODE |
Biccode |
VARCHAR2 |
16 |
WEBSITE |
Website |
VARCHAR2 |
100 |
EMAILADDRESS |
Emailaddress |
VARCHAR2 |
100 |
EFFECTIVEFROMDATE |
Effectivefromdate |
DATE |
7 |
EFFECTIVETODATE |
Effectivetodate |
DATE |
7 |
PRIMARYCONTACTPERSON |
Primarycontactperson |
VARCHAR2 |
100 |
PRIMARYINTERNDIALCODE1 |
Primaryinterndialcode1 |
VARCHAR2 |
10 |
PRIMARYINTERNDIALCODE2 |
Primaryinterndialcode2 |
VARCHAR2 |
10 |
PRIMARYINTERNDIALCODE3 |
Primaryinterndialcode3 |
VARCHAR2 |
10 |
PRIMARYINTERNDIALCODE4 |
Primaryinterndialcode4 |
VARCHAR2 |
10 |
PRIMARYPOSITION |
Primaryposition |
VARCHAR2 |
60 |
PRIMARYMOBILENUMBER1 |
Primarymobilenumber1 |
VARCHAR2 |
60 |
PRIMARYMOBILENUMBER2 |
Primarymobilenumber2 |
VARCHAR2 |
60 |
PRIMARYFIXEDLINE |
Primaryfixedline |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
PRIMARYCONTACTINSTRN |
Primarycontactinstrn |
VARCHAR2 |
100 |
PRIMARYEXTN |
Primaryextn |
VARCHAR2 |
60 |
SECONDARYCONTACTPERSON |
Secondarycontactperson |
VARCHAR2 |
100 |
SECONDARYINTERNDIALCODE1 |
Secondaryinterndialcode1 |
VARCHAR2 |
10 |
SECONDARYINTERNDIALCODE2 |
Secondaryinterndialcode2 |
VARCHAR2 |
10 |
SECONDARYPOSITION |
Secondaryposition |
VARCHAR2 |
60 |
SECONDARYMOBILENUMBER |
Secondarymobilenumber |
VARCHAR2 |
60 |
SECONDARYFIXEDLINE |
Secondaryfixedline |
VARCHAR2 |
60 |
SECONDARYCONTACTINSTRN |
Secondarycontactinstrn |
VARCHAR2 |
105 |
SECONDARYEXTN |
Secondaryextn |
VARCHAR2 |
60 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_PARTYIDINVEXPORT |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
IDREFERENCENO |
Idreferenceno |
VARCHAR2 |
16 |
IDENTIFICATIONTYPE |
Identificationtype |
VARCHAR2 |
20 |
Identificationnumber |
VARCHAR2 |
50 |
PLACEOFISSUE |
Placeofissue |
VARCHAR2 |
3 |
ISSUEAUTHORITY |
Issueauthority |
VARCHAR2 |
50 |
ISSUECOUNTRY |
Issuecountry |
VARCHAR2 |
3 |
DATEOFISSUE |
Dateofissue |
DATE |
7 |
DATEOFEXPIRY |
Dateofexpiry |
DATE |
7 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
VERIFICATIONSTATUS |
Verificationstatus |
VARCHAR2 |
1 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_INVACCMASTERINVEXPORT |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
ACOPERATIONTYPE |
Acoperationtype |
VARCHAR2 |
1 |
DEALINGTYPE |
Dealingtype |
VARCHAR2 |
3 |
GUARDIANID |
Guardianid |
VARCHAR2 |
12 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
INVESTORCATEGORY |
Investorcategory |
VARCHAR2 |
2 |
ACOPENINGDATE |
Acopeningdate |
DATE |
7 |
ACCOUNTREFNO |
Accountrefno |
VARCHAR2 |
16 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
ACCOUNTSTATUS |
Accountstatus |
VARCHAR2 |
1 |
PENSIONACCOUNT |
Pensionaccount |
VARCHAR2 |
1 |
ACCOUNTCLOSED |
Accountclosed |
VARCHAR2 |
1 |
CHANGEDATE |
Changedate |
DATE |
7 |
CHANGEREASON |
Changereason |
VARCHAR2 |
255 |
CHANGEREFERENCENO |
Changereferenceno |
VARCHAR2 |
16 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_INVACCINTERINVEXPORT |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
INTERMEDIARYID |
Intermediaryid |
VARCHAR2 |
12 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
5 |
DEFAULTFLAG |
Defaultflag |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_PARTYBANKINVEXPORT |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
BANKREFERENCENO |
Bankreferenceno |
VARCHAR2 |
16 |
DIRECTDEBITAPPLICABLE |
Directdebitapplicable |
VARCHAR2 |
1 |
DEFAULTFLAG |
Defaultflag |
VARCHAR2 |
1 |
ACCOUNTHOLDERNAME |
Accountholdername |
VARCHAR2 |
100 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
IBAN |
Iban |
VARCHAR2 |
40 |
VARCHAR2 |
1 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_INVESTACCBENFINVEXPORT |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
BENEFICIARYTYPE |
Beneficiarytype |
VARCHAR2 |
2 |
BENFPARTYID |
Benfpartyid |
VARCHAR2 |
16 |
AWARDPERCENTAGE |
Awardpercentage |
NUMBER |
5 |
BENFPARTYNAME |
Benfpartyname |
VARCHAR2 |
100 |
DATEOFBIRTH |
Dateofbirth |
DATE |
7 |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
GENDER |
Gender |
VARCHAR2 |
1 |
BENFIDTYPE |
Benfidtype |
VARCHAR2 |
20 |
BENFIDNUMBER |
Benfidnumber |
VARCHAR2 |
50 |
RELATIONSHIP |
Relationship |
VARCHAR2 |
70 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
100 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
100 |
CITY |
City |
VARCHAR2 |
80 |
STATE |
State |
VARCHAR2 |
80 |
COUNTRY |
Country |
VARCHAR2 |
3 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
VARCHAR2 |
100 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
PRIMARYFIXEDLINE |
Primaryfixedline |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
CONTACTPERSON |
Contactperson |
VARCHAR2 |
100 |
BANK |
Bank |
VARCHAR2 |
12 |
BRANCH |
Branch |
VARCHAR2 |
12 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
ACCOUNTNAME |
Accountname |
VARCHAR2 |
100 |
IBAN |
Iban |
VARCHAR2 |
40 |
Field name |
Description |
Datatype |
Length |
Table Name |
SEQUENCENUMBER |
Sequence Number |
VARCHAR2 |
10 |
PATB_ASSETPRICEUPLOAD |
PROCESSID |
Processi D |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulk Client Code |
VARCHAR2 |
12 |
UPLOADMODE |
Upload Mode |
VARCHAR2 |
1 |
User reference Number |
VARCHAR2 |
16 |
FUNDID |
Fund ID |
VARCHAR2 |
6 |
TRANSACTIONTYPE |
Txn Type |
VARCHAR2 |
2 |
Txn Base Price |
VARCHAR2 |
30 |
Description |
01ORD |
This segment is used to provide Pension order master upload details |
02OIN |
This segment is used to provide Pension order instrument upload details |
03OIA |
This segment is used to provide Pension order investment asset upload detail |
04OIT |
This segment is used to provide Pension order intermediary upload detail |
05OSE |
This segment is used to provide Pension settlement upload detail |
06PMA |
This segment is used to provide Pension party master upload detail |
07PCO |
This segment is used to provide Pension party contact upload detail |
08PID |
This segment is used to provide Pension party ID upload detail |
09IAM |
This segment is used to provide Pension investment master upload detail |
10IAI |
This segment is used to provide Pension investment account intermediary upload detail |
11IAB |
This segment is used to provide Pension bank upload detail |
12IBE |
This segment is used to provide Pension investment account beneficiary upload detail |
13ALO |
This segment is used to provide Pension order allocation upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ORDERTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
REFERENCENUMBER |
Referencenumber |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PORTFOLIOID |
Portfolioid |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
ORDERCURRENCY |
Ordercurrency |
VARCHAR2 |
3 |
ORDERMODE |
Ordermode |
VARCHAR2 |
1 |
ORDERVALUE |
Ordervalue |
NUMBER |
30 |
INSTRUCTIONDATE |
Instructiondate |
DATE |
7 |
ORDERTYPE |
Ordertype |
VARCHAR2 |
3 |
ORDERSUBTYPE |
Ordersubtype |
VARCHAR2 |
3 |
PAYMENTMODE |
Paymentmode |
VARCHAR2 |
2 |
GROSSORNET |
Grossornet |
VARCHAR2 |
1 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
ORDERSTATUS |
Orderstatus |
NUMBER |
2 |
ORIGINALORDNUMBER |
Originalordnumber |
VARCHAR2 |
16 |
ORIGINALREFNUMBER |
Originalrefnumber |
VARCHAR2 |
16 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
REMARKS |
Remarks |
VARCHAR2 |
255 |
SWIORDERSTATUS |
Swiorderstatus |
NUMBER |
2 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ORDERINSTRTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
5 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ORDERINSTASSETTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
ASSETID |
Assetid |
VARCHAR2 |
16 |
RATIO |
Ratio |
NUMBER |
5 |
OVERRIDE |
Override |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ORDERINTERMEDIARYTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
INTERMEDIARYID |
Intermediaryid |
VARCHAR2 |
12 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
5 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ORDERSETTLEMENTTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
PAYMENTREFNUMBER |
Paymentrefnumber |
VARCHAR2 |
16 |
BANKREFERENCENO |
Bankreferenceno |
VARCHAR2 |
16 |
CHEQUEDATE |
Chequedate |
DATE |
7 |
CHEQUENUMBER |
Chequenumber |
VARCHAR2 |
20 |
PAYMENTAMOUNT |
Paymentamount |
NUMBER |
30 |
PAIDDATE |
Paiddate |
DATE |
7 |
SETTLED |
Settled |
VARCHAR2 |
1 |
ACCOUNTHOLDERNAME |
Accountholdername |
VARCHAR2 |
100 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
IBAN |
Iban |
VARCHAR2 |
40 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYMASTERTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PARTYTYPE |
Partytype |
VARCHAR2 |
3 |
TITLE |
Title |
VARCHAR2 |
15 |
FIRSTNAME |
Firstname |
VARCHAR2 |
100 |
MIDDLENAME |
Middlename |
VARCHAR2 |
100 |
LASTNAME |
Lastname |
VARCHAR2 |
100 |
REGISTEREDNAME |
Registeredname |
VARCHAR2 |
100 |
DATEOFBIRTH |
Dateofbirth |
DATE |
7 |
DATE |
7 |
MARITALSTATUS |
Maritalstatus |
VARCHAR2 |
1 |
OCCUPATION |
Occupation |
VARCHAR2 |
3 |
GENDER |
Gender |
VARCHAR2 |
1 |
PREFERREDCURRENCY |
Preferredcurrency |
VARCHAR2 |
3 |
MINOR |
Minor |
NUMBER |
1 |
NATIONALITY |
Nationality |
VARCHAR2 |
3 |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
DUALNATIONALITY |
Dualnationality |
VARCHAR2 |
3 |
NUMBER |
1 |
HEALTHSTATUS |
Healthstatus |
VARCHAR2 |
1 |
PROTECTIONLEVEL |
Protectionlevel |
VARCHAR2 |
1 |
VARCHAR2 |
100 |
VARCHAR2 |
100 |
VARCHAR2 |
100 |
CORPORATIONTYPE |
Corporationtype |
VARCHAR2 |
3 |
NUMBER |
22 |
VARCHAR2 |
3 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
FATHERSPOUSENAME |
Fatherspousename |
VARCHAR2 |
105 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYCONTACTTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
CONTACTREFNO |
Contactrefno |
VARCHAR2 |
16 |
ADDRESSTYPE |
Addresstype |
VARCHAR2 |
2 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
100 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
100 |
ADDRESSLINE3 |
Addressline3 |
VARCHAR2 |
100 |
POSTBOXNO |
Postboxno |
VARCHAR2 |
16 |
CITY |
City |
VARCHAR2 |
80 |
STATE |
State |
VARCHAR2 |
80 |
COUNTRY |
Country |
VARCHAR2 |
3 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
BICCODE |
Biccode |
VARCHAR2 |
16 |
WEBSITE |
Website |
VARCHAR2 |
100 |
EMAILADDRESS |
Emailaddress |
VARCHAR2 |
100 |
EFFECTIVEFROMDATE |
Effectivefromdate |
DATE |
7 |
EFFECTIVETODATE |
Effectivetodate |
DATE |
7 |
VARCHAR2 |
100 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
PRIMARYPOSITION |
Primaryposition |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
PRIMARYFIXEDLINE |
Primaryfixedline |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
VARCHAR2 |
100 |
PRIMARYEXTN |
Primaryextn |
VARCHAR2 |
60 |
VARCHAR2 |
100 |
VARCHAR2 |
10 |
VARCHAR2 |
10 |
SECONDARYPOSITION |
Secondaryposition |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
VARCHAR2 |
105 |
SECONDARYEXTN |
Secondaryextn |
VARCHAR2 |
60 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_PARTYIDTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
IDREFERENCENO |
Idreferenceno |
VARCHAR2 |
16 |
VARCHAR2 |
20 |
VARCHAR2 |
50 |
PLACEOFISSUE |
Placeofissue |
VARCHAR2 |
3 |
ISSUEAUTHORITY |
Issueauthority |
VARCHAR2 |
50 |
ISSUECOUNTRY |
Issuecountry |
VARCHAR2 |
3 |
DATEOFISSUE |
Dateofissue |
DATE |
7 |
DATEOFEXPIRY |
Dateofexpiry |
DATE |
7 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
VARCHAR2 |
1 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_INVACCMASTERTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
ACOPERATIONTYPE |
Acoperationtype |
VARCHAR2 |
1 |
DEALINGTYPE |
Dealingtype |
VARCHAR2 |
3 |
GUARDIANID |
Guardianid |
VARCHAR2 |
12 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
INVESTORCATEGORY |
Investorcategory |
VARCHAR2 |
2 |
ACOPENINGDATE |
Acopeningdate |
DATE |
7 |
ACCOUNTREFNO |
Accountrefno |
VARCHAR2 |
16 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
ONCE_AUTH |
Once_Auth |
VARCHAR2 |
1 |
RECORD_STAT |
Record_Stat |
VARCHAR2 |
1 |
MOD_NO |
Mod_No |
NUMBER |
22 |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
ACCOUNTSTATUS |
Accountstatus |
VARCHAR2 |
1 |
PENSIONACCOUNT |
Pensionaccount |
VARCHAR2 |
1 |
ACCOUNTCLOSED |
Accountclosed |
VARCHAR2 |
1 |
CHANGEDATE |
Changedate |
DATE |
7 |
CHANGEREASON |
Changereason |
VARCHAR2 |
255 |
CHANGEREFERENCENO |
Changereferenceno |
VARCHAR2 |
16 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_INVACCINTERTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
INTERMEDIARYID |
Intermediaryid |
VARCHAR2 |
12 |
SPLITPERCENTAGE |
Splitpercentage |
NUMBER |
5 |
DEFAULTFLAG |
Defaultflag |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_INVACCBANKTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
BANKREFERENCENO |
Bankreferenceno |
VARCHAR2 |
16 |
VARCHAR2 |
1 |
DEFAULTFLAG |
Defaultflag |
VARCHAR2 |
1 |
ACCOUNTHOLDERNAME |
Accountholdername |
VARCHAR2 |
100 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
IBAN |
Iban |
VARCHAR2 |
40 |
VARCHAR2 |
1 |
LASTVERIFIEDDATE |
Lastverifieddate |
DATE |
7 |
MODULEID |
Moduleid |
VARCHAR2 |
30 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATM_INVESTACCBENFTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
BENEFICIARYTYPE |
Beneficiarytype |
VARCHAR2 |
2 |
BENFPARTYID |
Benfpartyid |
VARCHAR2 |
16 |
AWARDPERCENTAGE |
Awardpercentage |
NUMBER |
5 |
BENFPARTYNAME |
Benfpartyname |
VARCHAR2 |
100 |
DATEOFBIRTH |
Dateofbirth |
DATE |
7 |
COUNTRYOFBIRTH |
Countryofbirth |
VARCHAR2 |
3 |
COUNTRYOFDOMICILE |
Countryofdomicile |
VARCHAR2 |
3 |
GENDER |
Gender |
VARCHAR2 |
1 |
VARCHAR2 |
20 |
VARCHAR2 |
50 |
RELATIONSHIP |
Relationship |
VARCHAR2 |
70 |
ADDRESSLINE1 |
Addressline1 |
VARCHAR2 |
100 |
ADDRESSLINE2 |
Addressline2 |
VARCHAR2 |
100 |
CITY |
City |
VARCHAR2 |
80 |
STATE |
State |
VARCHAR2 |
80 |
COUNTRY |
Country |
VARCHAR2 |
3 |
ZIPCODE |
Zipcode |
VARCHAR2 |
10 |
EMAILADDRESS |
Emailaddress |
VARCHAR2 |
100 |
VARCHAR2 |
60 |
VARCHAR2 |
60 |
PRIMARYFIXEDLINE |
Primaryfixedline |
VARCHAR2 |
60 |
FAX |
Fax |
VARCHAR2 |
120 |
CONTACTPERSON |
Contactperson |
VARCHAR2 |
100 |
BANKCODE |
Bankcode |
VARCHAR2 |
12 |
BRANCHCODE |
Branchcode |
VARCHAR2 |
12 |
ACCOUNTTYPE |
Accounttype |
VARCHAR2 |
1 |
ACCOUNTCURRENCY |
Accountcurrency |
VARCHAR2 |
3 |
ACCOUNTNUMBER |
Accountnumber |
VARCHAR2 |
20 |
ACCOUNTNAME |
Accountname |
VARCHAR2 |
100 |
IBAN |
Iban |
VARCHAR2 |
40 |
DESIGNATION |
Designation |
VARCHAR2 |
100 |
CONTROLLINGPERSON |
Controllingperson |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ALLOCDETAILSTAUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
10 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
16 |
ORDERNUMBER |
Ordernumber |
VARCHAR2 |
16 |
EXTERNALTXNNUMBER |
Externaltxnnumber |
VARCHAR2 |
16 |
PARTYID |
Partyid |
VARCHAR2 |
12 |
PORTFOLIOID |
Portfolioid |
VARCHAR2 |
16 |
ACCOUNTID |
Accountid |
VARCHAR2 |
16 |
INSTRUMENTID |
Instrumentid |
VARCHAR2 |
16 |
ASSETID |
Assetid |
VARCHAR2 |
16 |
ORDERAMOUNT |
Orderamount |
NUMBER |
30 |
LOADAMOUNT |
Loadamount |
NUMBER |
30 |
NETAMOUNT |
Netamount |
NUMBER |
30 |
SETTLEMENTAMT |
Settlementamt |
NUMBER |
30 |
NAV |
Nav |
NUMBER |
17 |
NAVDATE |
Navdate |
DATE |
7 |
ALLOTEDUNITS |
Allotedunits |
NUMBER |
30 |
ALLOCATIONDATE |
Allocationdate |
DATE |
7 |
FROMORTOLEG |
Fromortoleg |
VARCHAR2 |
1 |
ORIGINALORDNUMBER |
Originalordnumber |
VARCHAR2 |
16 |
ORDERTYPE |
Ordertype |
VARCHAR2 |
3 |
STATUS |
Status |
VARCHAR2 |
2 |
ERR_CODE |
Err_Code |
VARCHAR2 |
20 |
ERRDESCRIPTION |
Errdescription |
VARCHAR2 |
255 |
TATRANSACTIONDATE |
Tatransactiondate |
DATE |
7 |
BLOCKEDFLAG |
Blockedflag |
VARCHAR2 |
1 |
Description |
00FDU |
This segment is used to provide asset upload details |
03TPR |
This segment is used to provide asset third party upload details |
04FLU |
This segment is used to provide asset load upload detail |
Field name |
Description |
Datatype |
Length |
Table Name |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ASSETUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PATB_ASSETUPLOAD |
PROCESSID |
Processid |
VARCHAR2 |
50 |
PATB_ASSETUPLOAD |
BULKCLIENTCODE |
Bulkclientcode |
VARCHAR2 |
12 |
PATB_ASSETUPLOAD |
UPLOADMODE |
Uploadmode |
VARCHAR2 |
1 |
PATB_ASSETUPLOAD |
IMPORTFILENAME |
Importfilename |
VARCHAR2 |
255 |
PATB_ASSETUPLOAD |
VARCHAR2 |
50 |
PATB_ASSETUPLOAD |
FUNDID |
Fundid |
VARCHAR2 |
6 |
PATB_ASSETUPLOAD |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
PATB_ASSETUPLOAD |
AUTH_STAT |
Auth_Stat |
VARCHAR2 |
1 |
PATB_ASSETUPLOAD |
FUNDSTARTDATE |
Fundstartdate |
DATE |
7 |
PATB_ASSETUPLOAD |
FUNDNAME |
Fundname |
VARCHAR2 |
60 |
PATB_ASSETUPLOAD |
FUNDNAMESHORT |
Fundnameshort |
VARCHAR2 |
90 |
PATB_ASSETUPLOAD |
FUNDCLASS |
Fundclass |
VARCHAR2 |
1 |
PATB_ASSETUPLOAD |
FUNDTYPE |
Fundtype |
NUMBER |
38 |
PATB_ASSETUPLOAD |
FUNDFAMILY |
Fundfamily |
VARCHAR2 |
6 |
PATB_ASSETUPLOAD |
FUNDBASECURRENCY |
Fundbasecurrency |
VARCHAR2 |
3 |
PATB_ASSETUPLOAD |
FUNDCOUNTRY |
Fundcountry |
VARCHAR2 |
3 |
PATB_ASSETUPLOAD |
FISCALSTARTYEAR |
Fiscalstartyear |
DATE |
7 |
PATB_ASSETUPLOAD |
FISCALENDYEAR |
Fiscalendyear |
DATE |
7 |
PATB_ASSETUPLOAD |
AMCID |
Amcid |
VARCHAR2 |
12 |
PATB_ASSETUPLOAD |
BROKERSALLOWED |
Brokersallowed |
NUMBER |
1 |
PATB_ASSETUPLOAD |
REGISTRARID |
Registrarid |
VARCHAR2 |
12 |
PATB_ASSETUPLOAD |
TRUSTEEID |
Trusteeid |
VARCHAR2 |
12 |
PATB_ASSETUPLOAD |
LATESTRULE |
Latestrule |
NUMBER |
1 |
PATB_ASSETUPLOAD |
MOD_NO |
Mod_No |
NUMBER |
22 |
PATB_ASSETUPLOAD |
MAKER_ID |
Maker_Id |
VARCHAR2 |
15 |
PATB_ASSETUPLOAD |
MAKER_DT_STAMP |
Maker_Dt_Stamp |
DATE |
7 |
PATB_ASSETUPLOAD |
CHECKER_ID |
Checker_Id |
VARCHAR2 |
15 |
PATB_ASSETUPLOAD |
CHECKER_DT_STAMP |
Checker_Dt_Stamp |
DATE |
7 |
PATB_ASSETUPLOAD |
MINHOLDINGPERIOD |
Minholdingperiod |
NUMBER |
22 |
PATB_ASSETUPLOAD |
PRIMARYREGADDRESS |
Primaryregaddress |
VARCHAR2 |
255 |
PATB_ASSETUPLOAD |
FUNDTAXID |
Fundtaxid |
VARCHAR2 |
25 |
PATB_ASSETUPLOAD |
VARCHAR2 |
25 |
PATB_ASSETUPLOAD |
FUNDTICKERSYMBOL |
Fundtickersymbol |
VARCHAR2 |
25 |
PATB_ASSETUPLOAD |
NUMBER |
1 |
PATB_ASSETUPLOAD |
CUSTODIAN |
Custodian |
VARCHAR2 |
12 |
PATB_ASSETUPLOAD |
FUNDSUSPENDED |
Fundsuspended |
NUMBER |
1 |
PATB_ASSETUPLOAD |
NUMBER |
30 |
PATB_ASSETUPLOAD |
NUMBER |
30 |
PATB_ASSETUPLOAD |
RECORD_STAT |
Record_Stat |
CHAR |
1 |
PATB_ASSETUPLOAD |
ONCE_AUTH |
Once_Auth |
CHAR |
1 |
PATB_ASSETUPLOAD |
EXISTINGFUND |
Existingfund |
NUMBER |
1 |
PATB_ASSETUPLOAD |
UMBRELLAFUND |
Umbrellafund |
NUMBER |
1 |
PATB_ASSETUPLOAD |
HEDGEFUND |
Hedgefund |
VARCHAR2 |
1 |
PATB_ASSETUPLOAD |
FUNDENABLED |
Fundenabled |
NUMBER |
1 |
PATB_ASSETUPLOAD |
COEENABLED |
Coeenabled |
VARCHAR2 |
1 |
PATB_ASSETUPLOAD |
LEGALENTITY |
Legalentity |
VARCHAR2 |
12 |
PATB_ASSETUPLOAD |
FUNDCLOSEDDATE |
Fundcloseddate |
DATE |
7 |
PATB_ASSETUPLOAD |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ASSETTPRUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
50 |
FUNDID |
Fundid |
VARCHAR2 |
6 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
TRANSACTIONTYPE |
Transactiontype |
VARCHAR2 |
2 |
DATE |
7 |
DATE |
7 |
VARCHAR2 |
1 |
NUMBER |
22 |
NUMBER |
22 |
DATE |
7 |
DATE |
7 |
NUMBER |
30 |
STEPAMOUNT |
Stepamount |
NUMBER |
30 |
NUMBER |
30 |
NUMBER |
27 |
STEPUNITS |
Stepunits |
NUMBER |
27 |
NUMBER |
27 |
ONLINEALLOCATION |
Onlineallocation |
NUMBER |
1 |
NUMBER |
20 |
ALLOCATIONPOLICY |
Allocationpolicy |
VARCHAR2 |
1 |
VARCHAR2 |
1 |
NUMBER |
22 |
NUMBER |
22 |
ALLOWBACKDATING |
Allowbackdating |
NUMBER |
1 |
BACKDATINGLIMIT |
Backdatinglimit |
NUMBER |
22 |
NUMBER |
22 |
NUMBER |
1 |
NUMBER |
1 |
VARCHAR2 |
60 |
BASEPRICEFACTOR |
Basepricefactor |
NUMBER |
7 |
NUMBER |
22 |
VARCHAR2 |
1 |
NUMBER |
1 |
NUMBER |
1 |
PRICELAG |
Pricelag |
NUMBER |
22 |
ALLOCATIONLAG |
Allocationlag |
NUMBER |
22 |
CONFIRMATIONLAG |
Confirmationlag |
NUMBER |
22 |
NUMBER |
1 |
NUMBER |
1 |
NUMBER |
1 |
NUMBER |
1 |
VARCHAR2 |
1 |
NATUREOFLIMIT |
Natureoflimit |
VARCHAR2 |
1 |
NUMBER |
1 |
GROSSAMOUNT |
Grossamount |
VARCHAR2 |
1 |
GROSSUNITS |
Grossunits |
VARCHAR2 |
1 |
NETAMOUNT |
Netamount |
VARCHAR2 |
1 |
NETUNITS |
Netunits |
VARCHAR2 |
1 |
NUMBER |
30 |
NUMBER |
27 |
MINSITXNAMOUNT |
Minsitxnamount |
NUMBER |
30 |
MAXSITXNAMOUNT |
Maxsitxnamount |
NUMBER |
30 |
MINSITXNUNITS |
Minsitxnunits |
NUMBER |
27 |
MAXSITXNUNITS |
Maxsitxnunits |
NUMBER |
27 |
EXISTINGUH |
Existinguh |
VARCHAR2 |
2 |
NUMBER |
22 |
VARCHAR2 |
1 |
VARCHAR2 |
1 |
PAYMENTLAG |
Paymentlag |
NUMBER |
22 |
DATE |
7 |
NUMBER |
1 |
NUMBER |
1 |
IPOMAXISSUESIZE |
Ipomaxissuesize |
NUMBER |
27 |
NUMBER |
5 |
NUMBER |
1 |
NUMBER |
30 |
MINSIHOLDINGUNITS |
Minsiholdingunits |
NUMBER |
27 |
VARCHAR2 |
1 |
VARCHAR2 |
1 |
VARCHAR2 |
1 |
VARCHAR2 |
1 |
SIDESCRIPTION |
Sidescription |
VARCHAR2 |
255 |
SIHOLIDAYRULE |
Siholidayrule |
VARCHAR2 |
1 |
SICALENDERBASIS |
Sicalenderbasis |
VARCHAR2 |
1 |
SIGENDAY |
Sigenday |
VARCHAR2 |
3 |
SIFREQUENCY |
Sifrequency |
VARCHAR2 |
1 |
SIGENCYCLE |
Sigencycle |
VARCHAR2 |
1 |
SICUTOFFDAY |
Sicutoffday |
NUMBER |
22 |
SICUTOFFLAG |
Sicutofflag |
NUMBER |
22 |
ENFORCESIRULE |
Enforcesirule |
NUMBER |
22 |
VARCHAR2 |
1 |
NUMBER |
1 |
PSEUDOSWITCHLAG |
Pseudoswitchlag |
NUMBER |
22 |
NUMBER |
1 |
NUMBER |
30 |
NUMBER |
27 |
VARCHAR2 |
1 |
FULLOUTFLOW |
Fulloutflow |
NUMBER |
1 |
NUMBER |
4 |
MAXVALIDITY |
Maxvalidity |
NUMBER |
4 |
SILEADTIME |
Sileadtime |
NUMBER |
22 |
VARCHAR2 |
255 |
NUMBER |
1 |
MINMATURITYPERIOD |
Minmaturityperiod |
NUMBER |
4 |
MAXMATURITYPERIOD |
Maxmaturityperiod |
NUMBER |
4 |
FUTUREDATELIMIT |
Futuredatelimit |
NUMBER |
22 |
UHCALENDARBASIS |
Uhcalendarbasis |
VARCHAR2 |
1 |
NUMBER |
22 |
VARCHAR2 |
1 |
NOTICEPERIOD |
Noticeperiod |
NUMBER |
3 |
NUMBER |
3 |
THRESHOLDAMOUNT |
Thresholdamount |
NUMBER |
30 |
CONSSIAUTOCOUNTER |
Conssiautocounter |
NUMBER |
3 |
MAXSITXNSALLOWED |
Maxsitxnsallowed |
NUMBER |
3 |
STARTTIME |
Starttime |
VARCHAR2 |
8 |
ENDTIME |
Endtime |
VARCHAR2 |
8 |
CUTOFFTIME |
Cutofftime |
VARCHAR2 |
8 |
GOCUTOFFLAG |
Gocutofflag |
VARCHAR2 |
8 |
GOTHRESHOLDUNITS |
Gothresholdunits |
NUMBER |
27 |
GOSETTLEMENTLAG |
Gosettlementlag |
NUMBER |
22 |
GOSETTLAGCALENDAR |
Gosettlagcalendar |
VARCHAR2 |
1 |
SEGMENTID |
Segmentid |
VARCHAR2 |
20 |
PATB_ASSETLOADUPLOAD |
SEQUENCENUMBER |
Sequencenumber |
NUMBER |
22 |
PROCESSID |
Processid |
VARCHAR2 |
50 |
VARCHAR2 |
50 |
FUNDID |
Fundid |
VARCHAR2 |
6 |
RULEEFFECTIVEDATE |
Ruleeffectivedate |
DATE |
7 |
TRANSACTIONTYPE |
Transactiontype |
VARCHAR2 |
2 |
LOADID |
Loadid |
NUMBER |
5 |
LOADTOPRICE |
Loadtoprice |
NUMBER |
22 |
FROMENTITYTYPE |
Fromentitytype |
VARCHAR2 |
1 |
TOENTITYTYPE |
Toentitytype |
VARCHAR2 |
1 |
PROCESSINGFREQ |
Processingfreq |
VARCHAR2 |
1 |
GLACCOUNTCODE |
Glaccountcode |
VARCHAR2 |
10 |
DEBITORCREDIT |
Debitorcredit |
VARCHAR2 |
1 |
CONTRAACCOUNTCODE |
Contraaccountcode |
VARCHAR2 |
10 |
NUMBER |
1 |
VARCHAR2 |
1 |
MANDATORY |
Mandatory |
VARCHAR2 |
1 |
PRIORITYNO |
Priorityno |
NUMBER |
22 |
LOADVATTOPRICE |
Loadvattoprice |
NUMBER |
22 |
APPLYRETVALON |
Applyretvalon |
VARCHAR2 |
1 |
NUMBER |
1 |
REFTYPE |
Reftype |
VARCHAR2 |
4 |
DIFFERENTIALFEE |
Differentialfee |
NUMBER |
1 |
SLABBASIS |
Slabbasis |
VARCHAR2 |
1 |
PRICEADDIN |
Priceaddin |
NUMBER |
1 |
GROUPID |
Groupid |
VARCHAR2 |
6 |
INDEXATIONONCGT |
Indexationoncgt |
VARCHAR2 |
1 |
LEVELID |
Levelid |
NUMBER |
22 |
DEPENDENTLEVEL |
Dependentlevel |
NUMBER |
22 |
FDAPINCOME |
Fdapincome |
NUMBER |
1 |
