3. Appendix B - Upload File Formats B
3.1 Fund Rules Upload Formats
3.1.1 Segment Identification Number
The upload file would contain various segment identification number in the first column to indicate the type of data that is present in that entire row. Each segment identified by a unique tag, indicates the type of fund rule information such as Demographics, Shares Characteristics and so on. The possible segments that would be used in Fund upload are given below for reference:
Description
Segment Mandatory / Optional?
Multiple records allowed for the same Fund and Rule Effective Date
00GEN
This segment is used for providing information com­mon to the other fund rules that need to be uploaded in the system.
Mandatory; and will be the driving header segment for all the other segments.
No
01FDR
This segment is used for providing Fund Demograph­ics related information
Mandatory
No
02SCR
This segment is used for providing Shares Charac­teristics related information
Mandatory
No
03GOR
This segment is used for providing General Operat­ing rules information
Mandatory
No
04TPR
This segment is used for providing Transaction pro­cessing rules information
Mandatory
Yes (For each transaction type - there is a separate record)
05TCM
This segment is used for providing Transaction Pro­cessing Communication Mode information
Mandatory
06INV
This segment is used for providing Transaction Pro­cessing Investor Category related information
Mandatory
07IDR
This segment is used for providing Corporate Action related information
Optional
Yes (For cash and Stock dividend information)
08FSC
This segment is used for providing Fund Sale Coun­try information
Mandatory
Yes
09FRL
This segment is used for providing Fund Residency List information
Mandatory
Yes
10FFM
This segment is used for providing Fund Formula information
Optional
Yes
11FLM
This segment is used for providing Fund Load infor­mation
Optional
Yes
12FTC
This segment is used for providing Fund Transaction Currency information
Mandatory
Yes
13FAI
This segment is used for providing Fund Additional Information
Mandatory
No
14IRA
This segment is used for providing Fund IRA Infor­mation, if applicable
Optional
No
15FDI
This segment is used for providing Fund Delivery Instructions, if applicable
Optional
No
17KYC
This segment is used for providing the Customer document details, if applica­ble
Optional
Yes
18MLD
This segment is used for providing Multi language details, if applicable
Optional
Yes
19FSI
This segment is used for providing Fund Investment Account SI, if applicable
Optional
Yes
20HFP
This segment is used to include hedge fund parame­ters
Optional
No
21HFL
This segment is used to provide hedge fund linkage details
Optional
Yes
22HFD
This segment is used to provide investor category details for hedge funds
Optional
Yes
Each of the segments have variable list of fields stored as information pertaining to that segment. The list of fields for each segment is mentioned in the following tables along with the description of the segment.
3.1.2 Fund Rules Upload Segment Formats
Serial Number: 1
Segment Identification Number: 00GEN
Description: This segment is used for providing information that is common to the other fund rules that need to be uploaded in the system
Mandatory: Mandatory and will be the driving header segment for all the other segments.
Multiple records allowed for the same fund and Rule Effective Date: No
Field Name
Type
Maximum Length
Characteristics / Validations applicable
Description
PROCESSID
Alphanu­meric
50
Mandatory
This should iden­tify the upload uniquely. This should also be unique within a file and it allows to identify imported records later
BULKCLI­ENTCODE
Alphanu­meric
12
Mandatory
Valid authorized, enabled Bulk cli­ent codes main­tained in the system as a part of Entity Mainte­nance.
IMPORT­FILENAME
Alphanu­meric
255
Mandatory
This is the name of the file being uploaded into the FCIS system
AMCID
Alphanu­meric
12
Mandatory
Valid authorized, enabled AMC maintained in the system as a part of Entity Mainte­nance. The fund rule upload defaulting would be based on both AMCID and the Bulk client code.
USERID
Alphanu­meric
15
Mandatory
The fund rule MakerID would have the value of UserID as a part of data storage in all the fund rule tables.
UPLOAD­MODE
Alphanu­meric
1
Mandatory
Valid values are 'N' and 'I'
Should be 'N' for New fund rule, and ‘I’ for Incre­mental for amend­ing an existing authorized fund rule.
GENERA­TEAUTH­FUNDRULE
Alphanu­meric
1
Optional
Valid values are 'A' and 'U'
This indicates whether the fund rule uploaded should be a authorized fund rule or un-author­ized fund rule.
DEFAULTOPTION
Alphanu­meric
15
Optional
Valid values are Null which means 'No defaulting'; 'BULKCLI­ENT­CODE' means defaulting information based on Bulk Client code men­tioned as a part of this segment; existing valid tem­plate id based on which defaulting would hap­pen
This indicates if data needs to be defaulted based on any existing templates or based on bulk cli­ent code.
Serial Number: 2
Segment Identification Number: 01FDR
Description: This segment is used for providing Fund demographics related information
Segment Mandatory / Optional: Mandatory
Multiple records allowed for the same Fund and Rule Effective Date: No
Field Name
Type
Maximum Length
Description
SEG­MEN­TID
Alpha­numeric
20
Mandatory
Default value 01FDR
Standard value of 01FDR to uniquely identify Fund demographics information
PRO­CESSID
Alpha­numeric
50
Mandatory
Same value as in 00GEN - Pro­cessID
FUNDID
Alpha­numeric
6
Mandatory
The Fund ID is a unique Identifica­tion for each Fund in the system. Enter a unique value for the fund for which a Fund Demographics record is being set up
RULEEFFEC­TIVE­DATE
Date
8
Mandatory
The Rule Effec­tive Date should be later than (or same as) the Fund Start Date and it should also be later than (or same as) the current application date of the system.
Specify the date from when the Fund Demograph­ics Rule that is cur­rently being set up should become effective.
FUND­START­DATE
Date
8
Mandatory
Specify the date upon which the fund is to begin operations
FUND­NAME
Alpha­numeric
60
Mandatory
Enter the name of the fund for which the Fund Demo­graphics profile is being set up in this record
FUND­NAMESHORT
Alpha­numeric
15
Mandatory
Enter the short name of the fund for which the Fund Demographics profile is being set up in this record
FUND­CLASS
Alpha­numeric
1
Optional
Valid values are 'O' for Open-ended and 'C' for Closed-ended
Enter the fund class as either Open Ended and Closed-Ended Funds
FUND­TYPE
Number
38
Optional
Valid Fund types defined in the system
Enter the value of Fund Type. The Fund Types are set up as a part of the Fund Type Maintenance.
FUND­FAMILY
Alpha­numeric
2
Optional
Valid Fund fami­lies defined in the system
Enter the fund family under which the fund must be placed
FUND­BASE­CURRENCY
Alpha­numeric
3
Optional
Valid Currency code defined in the system
Specify the cur­rency code in which the fund will be denominated. The NAV and divi­dend declarations for the fund will be in this base cur­rency.
FUND­COUN­TRY
Alpha­numeric
3
Optional
Valid Domicile code defined in the system as a part of Params Maintenance
Enter the country of domicile of the fund. This informa­tion will be used to determine whether a unit holder that subscribes to the fund must be con­sidered a Foreign unit holder or not
FIS­CAL­STARTYEAR
DATE
8
Optional
The Fiscal Start Date must be earlier than the application date and the Rule Effective Date of the fund
Enter the date from when the Fis­cal Year should start for the fund
FISCA­LEND­YEAR
DATE
8
Optional
The Fiscal End Date should be later than (or same as) the current date of the system. It should also be later than (or same as) the Rule Effective Date of the fund that is being set up.
Enter the date on which the Fiscal Year should end for the fund
AMCID
Alpha­numeric
12
Optional
Valid authorized AMC defined in the system as a part of entity maintenance
Specify the AMC that this Fund will be operative in
BRO­KER­SALLOWED
Number
1
Optional
Valid values are 1 and 0
if brokers are to be mandatory for the given Fund, then a value of '1' should be entered else enter 0.
REGIS­TRARID
Alpha­numeric
12
Optional
Valid Registrar defined in the system as a part of Entity mainte­nance
Enter the Registrar ID for the fund being set up
TRUS­TEEID
Alpha­numeric
12
Optional
Valid Trustee defined in the system as a part of Entity mainte­nance
Enter the Trustee ID for the fund being set up
FUNDENABLED
Number
1
Optional
Every new fund is created in the sys­tem initially as an enabled fund. Hence, the value can be defaulted to 1
MIN­HOLD­INGPERIOD
Number
Optional
Enter the lock in period for the investors invest­ing in the fund so that outflow trans­action would be possible only after this period
MINAMOUNT­FOR­TAXID
Number
15
Optional
Maximum of 3 decimal places allowed
Enter the minimum subscription / IPO subscription amount beyond which it is neces­sary / preferable to capture the Tax details for any unit holder.
PRIMA­RYRE­GADDRESS
Alpha­numeric
255
Optional
Registered Address for the fund
FUND­TAXID
Alpha­numeric
25
Optional
Unique Tax ID for the fund
FUN­DIDEN­TIFICATION­NUM­BER
Alpha­numeric
25
Mandatory for DEKA Installation. For others this is optional.
Fund ISIN number that helps to uniquely identify the fund
FUND­TICK­ERSYMBOL
Alpha­numeric
25
Optional
This is another value that helps to uniquely identify the fund. How­ever, if this is not applicable, it can be entered as null also.
ALLOWIRAIN­VEST­MENTS
Number
1
Optional
Valid values are 0 and 1
Only if IRA trans­actions are allowed, the value should be speci­fied as 1. Else specify 0.
CUSTO­DIAN
Alpha­numeric
12
Optional
Valid custodian defined in the system as a part of Entity mainte­nance
Enter the Custo­dian for the fund being set up
HEDGE FUND
Alpha­numeric
1
Optional
Indicate whether the fund is a hedge fund
Serial Number: 3
Segment Identification Number: 02SCR
Description: This segment is used for providing Shares Characteristics related information
Segment Mandatory/Optional? : Mandatory
Field Name
Type
Maximum Length
Description
SEGMEN­TID
Alphanu­meric
20
Mandatory
Default value 02SCR
Standard value of 02SCR to uniquely identify Shares charac­teristics infor­mation
PROCES­SID
Alphanu­meric
50
Mandatory
This should identify the upload uniquely. This should also be unique within a file and it allows to iden­tify imported records later
FUNDID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identi­fication for each Fund and it indi­cates the fund for which Shares charac­teristics infor­mation has to be uploaded
RULEEF­FECTIVE­DATE
Date
8
Mandatory
The Fund ID and Rule effec­tive date combi­nation should be the same as defined in 01FDR
The rule effec­tive date for which share characteristic information for the fund has to be maintained.
SCRIP­BASED
Number
1
Optional
Valid values are 0,1 and 2
This field is used to desig­nate the appli­cability of certificate issue for investment in the fund. The value '0' indi­cates 'Scrip­less'; '1' indicates 'Scrip based' and '2' indicates 'Certif­icate option'
PAR­VALUE
Number
15
Optional
Maximum of 6 decimal places allowed
Enter the Par Value for the fund. Normally, this will be the base price for Initial Public Offer (IPO) period, How­ever you can change the base price for IPO.
NOOF­DECI­MALSFORUNITS
Number
1
Optional
Indicate the maximum num­ber of decimals that would be reckoned for rounding preci­sion, for the number of allot­ted units. You cannot indicate a precision higher than 6 decimal places.
ROUND­OFFTRUNCATE
Alphanu­meric
1
Optional
Valid values are 'R' for Round off; 'T' for Round Down and 'U' for Round up
Indicate the rounding options for the value of the number of allot­ted units, desig­nated for the fund.
MINNOO­FUNITHOLDERS
Number
5
Optional
At any point of time, when the fund is ena­bled, the num­ber of unit holders cannot fall below this value. This value must not be lower than zero.
MAXNOO­FUNITHOLDERS
Number
5
Optional
At any point of time, when the fund is ena­bled, the num­ber of unit holders cannot go above this value.
MINREG­ISTEREDCAPITAL
Number
20
Optional
. At any point of time, when the fund is ena­bled, the fund corpus (regis­tered capital) cannot go below this value.
MAXREG­ISTEREDCAPITAL
Number
NUM­BER(30,12)
Optional
At any point of time, when the fund is ena­bled, the fund corpus (regis­tered capital) cannot go above this value.
CAPINDI­CATOR
Alphanu­meric
1
Optional
Valid values are 'A' and 'P'
This is to spec­ify the foreign investors’ limit to be defined either in per­centage of fund corpus or a flat Amount. Enter A if the foreign investors limit is in terms of an Amount and P for a percent­age of the Reg­istered Capital.
FOREIGN­INVES­TORSLIMIT
Number
NUM­BER(30,12)
Optional
Enter a value to specify the per­centage of fund corpus that for­eigners are allowed to hold. This could be either a per­centage of Fund Corpus or a flat Amount. If it is a percentage, then it cannot be greater than 100.
ACCOUNTSTATE­MENT­FREQ
Alphanu­meric
20
Optional
Valid values are 'F' or 'B' for Bi-weekly; 'M' for 'Monthly; 'Q' for 'Quarterly' ; 'H' for 'Half-yearly' ; 'Y' for 'Yearly'
This is to indi­cate the fre­quency with which the sys­tem should initi­ate the Account Statement pro­cessing
ACCOUNTSTATE­MENTLEADTIME
Number
3
Optional
Enter a lead-time in days..
PRINTAC­COUNT­STATEMENT
Number
1
Optional
Valid values are '1' to print and '0' for not to print account statement
This is to indi­cate that the Account State­ment to be printed for the fund that is being set up
PRINTHOLDINGS­STATE­MENT
Number
1
Optional
Valid values are '1' to print and '0' for not to print holding statement
This is to indi­cate that if the Holding State­ment to be printed for the fund that is being set up
STAND­ARDLOT
Number
1
Optional
Enter a value to specify the standard lot for fund. This is also the market­able lot
PREFIX­CERT­CODE
Alphanu­meric
1
Optional
Enter a charac­ter for this field. This will be used as prefix to the Certifi­cate Number
START­CERTIS­SUEDNO
Number
1
Optional
Enter a value for this field. This is just for information. For a new Fund, the Certificate Numbers will start from this number.
LASTCER­TIS­SUEDNO
Number
5
Optional
Enter a value for this field. This is to spec­ify that this was the last certifi­cate number that has been issued so far and system needs to start from next num­ber. For new funds, this could be zero. This is also equal to the Start Certifi­cate Issue Number in the case of new Funds
PREFIXD­NRCODE
Number
1
Optional
Enter a charac­ter for this field. This will be used as prefix to the Distinc­tive Number Record (DNR) Number. This information is only applicable if you have specified the number of deci­mals for units as zero, in the Number of Dec­imals for Units field in this screen.
STARTDN­RIS­SUEDNO
Alphanu­meric
1
Optional
Enter a value for this field. This is just for information. For new funds, this will be same as last DNR issued number. This information is only applicable if you have specified the number of deci­mals for units as zero, in the Number of Dec­imals for Units field in this screen.
LASTDN­RIS­SUEDNO
Number
5
Optional
Enter a value for this field. This is to spec­ify that this was the last DNR number that has been issued so far and system needs to start from next num­ber. For new funds, this could be zero. This is also equal to the Start Certifi­cate Issue Number in the case of new Funds. This information is only applicable if you have specified the number of deci­mals for units as zero, in the Number of Dec­imals for Units field in this screen
SIN­GLECER­TALLOWED
Number
1
Optional
This is to indi­cate whether a single certificate is needed for the transaction or multiple cer­tificates are needed. Valid values are 0 and 1 indicat­ing 'No' and 'Yes' option for Single certifi­cate allowed.
MINCERT­DENOMI­NATION
Number
5
Optional
Enter a value to specify the mini­mum certificate denomination. I.e., the next level of denomi­nation after the standard lot. The system will use this after exhausting the maximum certif­icate denomina­tions.
MAX­CERTDE­NOMINATION
Number
5
Optional
Enter a value to specify the maximum certif­icate denomina­tion. This is the first level of denomination used by the system.
USER­OVER­RIDEALLOWED
Number
1
Optional
Valid values are '0' and '1'
Enter value as '1' if the user on the unit holder’s request can override the default denomi­nations defined. If the User over­ride is allowed then, system will allow the teller to override the fund default denominations. This is true only for minimum and maximum denominations. The Standard lot cannot be changed. This is applicable only to scrip-based funds.
CER­TREQD
Number
1
Optional
For scrip less funds, this value is to indicate that certificates must be issued to investors for block transac­tions in the fund.
MAXREG­ISTERE­DUNITS
NUM­BER
5
Optional
Capture the Maximum Units Registered Capital.
UHCA­TREG­CAPITAL
VAR­CHAR2
2000
Optional
Tilde separated string with Inv Category and Max Reg Units.
Eg : PB~100;CO~200
Serial Number: 4
Segment Identification Number: 03GOR
Description: This segment is used for providing General Operating rules information
Segment Mandatory/Optional: Mandatory
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alphanu­meric
20
Mandatory
Default value 03GOR
Standard value of 03GOR to uniquely iden­tify General Operating Rules information
PROCES­SID
Alphanu­meric
50
Mandatory
FUNDID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identi­fication for each Fund and it indi­cates the fund for which Gen­eral operating rules informa­tion has to be uploaded
RULEEF­FECTIVE­DATE
Date
8
Mandatory
The rule effec­tive date for which general operating rules information for the fund has to be maintained.
POST­PRICED
Number
1
Optional
Enter '1'if the price for the fund will be announced Post Transactions. Else enter '0' if it is a pre-priced fund
NEXT­PRICE­DECLAREDATE
DATE
DATE
Optional
Specify the next date upon which the fund price is to be declared. This date must be after the Rule Effective Date of the fund, and the current sys­tem date.
PRICE­DECLAREFREQ
Alphanu­meric
1
Optional
Valid values are 'D' for 'Daily; 'W' for 'Weekly'; 'F' or 'B' for 'Bi-weekly'; 'M' for 'Monthly; 'Q' for 'Quarterly' ; 'H' for 'Half-yearly' ; 'Y' for 'Yearly'
This is used to indicate the fre­quency with which the price will be announced. If the fund is Post-priced Fund, you must spec­ify this fre­quency as Daily
NOOF­DECI­MALSFORNAV
Number
1
Optional
Indicate the maximum num­ber of decimals that would be reckoned for rounding preci­sion, for the NAV. You can­not indicate a precision higher than 6 decimal places.
ROUND­OFFTRUNCATE
Alphanu­meric
1
Optional
MATURI­TYDATE
DATE
DATE
Optional
Indicate the maturity date for the fund. This is applicable only if the fund is closed-ended fund.
RETAIN­IPO­BALANCE
Number
1
Optional
This is used to indicate if the IPO Balance of unit holders must to be stored for later use. '1' indicate maintenance of IPO balance of Unit holders and '0' indi­cates that it need not be maintained sep­arately
CONFBE­FALCRE­QUIRED
Number
1
Optional
This is used to indicate that a rejection of a transaction as applicable, for all authorized transactions, prior to alloca­tion. If this is not specified, then all authorized transactions will be taken up for allocation directly.
AUTORE­DEMP­TIONALLOWED
Number
1
Optional
This is used to indicate if Auto­matic Redemp­tion is to be allowed for the fund. This is applicable only for Open Ended funds. When the balance the unit holder falls below a defined minimum level, then the inves­tor will be inti­mated about it and will be pro­vided with some lead-time to either increase the balance above the mini­mum level or redeem all his units. After the elapsed lead- time, if the unit holder balance still lies below the defined min­imum level, then the auto­matic redemp­tion of those units will be done.
MINI­MUM­BALANCETYPE
Alphanu­meric
1
Optional
Enter the type of Minimum bal­ance (amount / units) to be maintained for Automatic Redemption
MINI­MUM­BALANCE
Number
20
Optional
Enter the mini­mum balance (in amounts / units based on what balance type has been specified above) to be maintained for Automatic Redemption
ELAPSEDDAYSBEFOREAUTORED
Number
3
Optional
Enter the num­ber of days from the date of inti­mation after which Auto­matic Redemp­tion will be initiated. This is the lead-time provided to the investor.
CHQAL­LOTON­CLGDATE
Number
1
Optional
This is used to indicate whether alloca­tion must be done on the transaction date or on the check clearing date, using the price prevailing on that date, for transactions in which the pay­ment mode is Check
AGEING­BASE­DON
Alphanu­meric
1
Optional
Valid values are 'F' for 'FIFO'; 'T' for 'Transaction Receipts' and 'P' for 'FIFO across products'
This is used to indicate if the unit holder has specified as to how transac­tions are to be ordered - FIFO, Tansaction receipts and FIFO across products
MAIN­TAINTRA­DINGBOX
Number
1
Optional
This is used to indicate to the system that the trading func­tions must be enabled for the fund. This means that for the fund, all trading transac­tions and the relevant pro­cessing are allowed
NAVLOT
Number
6
Optional
Specify the number of units for which the NAV quote is deemed to be applicable, for the fund.
CDSC­FUND
Varchar2
2
Optional
Valid values : 1. LOCOM
2.Market Price
3.Not Applicable
4. CDSC Class B
Default : Not Applicable
‘L’,’M’,’N’,’B’
This is used to indicate that the Contingent Deferred Sales Charge (CDSC) is applicable for the transac­tions in this fund.
CDSCAP­PLICA­BLEFORSWITCHES
Number
1
Optional
This is used to indicate that the Contingent Deferred Sales Charge (CDSC) is applicable to switch or exchange for the transac­tions in this fund.
REIN­VEST­MENTFIRST
Number
1
Optional
This is used to indicate that reinvestment transactions must be taken up first for aging during computa­tion of Contin­gent Deferred Sales Charge for redemption transactions in this fund.
VAT­VALUE
Number
5
Optional
Maximum of 2 decimals possi­ble
Value added tax value for the fund
CHECK­FEATU­REEXISTS
Number
1
Optional
Indicates whether the check writing facility is allowed for the fund or not
MINCHECKA­MOUNT
Number
15
Optional
Maximum of 3 decimals possi­ble
If check writing facility is allowed then the minimum check amount possible is indi­cated here.
MAX­CHECKA­MOUNT
Number
15
Optional
If check writing facility is allowed then the maximum check amount possible is indi­cated here.
MINCHECKHOLD­ING­PERIOD
Number
5
Optional
If check writing facility is allowed then the minimum holding period required is indi­cated here.
CHECK­ACCOUNTCLO­SURE
Number
1
Optional
CHECKREDEMP­TION­PENALTY
Number
1
Optional
If check writing facility is allowed then various penal­ties applicable or not is indi­cated by values '0' and '1'
HOLD­INGPERI­ODPENALTY
Number
1
Optional
BALAN­CEPEN­ALTY
Number
1
Optional
STOP­PAY­MENTPENALTY
Number
1
Optional
AMTLIM­ITPEN­ALTY
Number
1
Optional
INTERE­STRATE
Number
15
Optional
Maximum of 6 decimals possi­ble
PERFOR­MANCE­FEETHRESHOLD
Number
5
Optional
LIMI­TORDER­ALLOWED
Number
1
Optional
This indicates whether limit order is applica­ble for the fund depending upon the price
FUTURE­LIMI­TORDERALLOWED
Number
1
Optional
Indicates - limit order based on Date
AUTOLIMITOR­DER­PROCESS
Number
1
Optional
If limit order is based on price, indicates whether auto­matic triggering of processing is required or not.
PRICIN­GRULE
Alphanu­meric
1
Optional
Valid values are 'A' for After and 'P' for Prior
Rule to be applied for pric­ing
MinThreshHold­Limit
Number
5
Optional
Used for captur­ing Minimum Threshold Limit.
EUSD­SCOPE
Alphanu­meric
1
Optional
Valid values are ‘R’ for Redemp­tion & Switch Out and ‘D’ for Dividend and ‘B’ for Both.
Shown only for EUSD applica­ble segments.
Used to cater EUSD require­ments.
Ageing­Date
Alphanu­meric
1
Optional
Valid values are ‘T’ for Transac­tion Date and ‘C’ for Confirma­tion date and ‘D’ for Dealing date.
Used to store Ageing basis value.
INVEST­MENT­SIMULATIONMETHOD
Alphanu­meric
1
Optional
Valid values are ‘N’ and ‘H’
This indicates whether the Investment Sim­ulation Method should be a Not Allowed or His­toric Based NAV.
MIN­LOCKIN­PERIODFORGAIN
Number
4
Optional
Valid values are Greater than or equal to 0
MAX­LOCKIN­PERIODFORGAIN
Number
4
Optional
Valid values are Greater than or equal to the Min Lock-in Period
Number
4
Optional
Valid values are Greater than or equal to the Min Lock-in Period and Less than or equal to the Max Lock-in Period.
AMOUNTBLOCK­ALLOWED
NUMBER
1
Optional
CALCU­LATE­FEEINTXNCCY
NUMBER
1
Optional
INCLU­DEHOLD­INGPERIOD
VAR­CHAR2
1
Optional
Valid Values are 0 and 1
BLOCK­PRIORI­TYNO
NUMBER
4
Optional
Block priority should not be a numeric value.
For amount block, the prior­ity will be derived with this number and for amount unblock the priority would be reverse of this order.
DIVI­DENDE­QUALIZATIONAP­PLICA­BLE
NUMBER
1
Optional
Valid Values are ‘0’ (No) and ‘1’ (Yes)
Dividend equali­zation applica­ble” flag should be set to ‘1’ to support divi­dend / income equalization funds.
Serial Number: 5
Segment Identification Number: 04TPR
Description: This segment is used for providing Transaction processing rules information
Segment Mandatory/Optional?: Mandatory
Multiple records allowed for the same Fund and Rule Effective Date: Yes (For each transaction type - there is a separate record)
Field Name
Type
Maximum Length
Description
SEGMEN­TID
Alphanu­meric
20
Mandatory
Default value 04TPR
Standard value of 04TPR to uniquely iden­tify Transac­tion processing information
PROCES­SID
Alphanu­meric
50
Mandatory
FUNDID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identi­fication for each Fund and it indicates the fund for which Transaction processing information has to be uploaded
RULEEF­FECTIVE­DATE
Date
8
Mandatory
The rule effec­tive date for which transac­tion process­ing information for the fund has to be main­tained.
TRANS­ACTION­TYPE
Alphanu­meric
2
Mandatory
Valid values are '01' for IPO; '02' for Subscrip­tion; '03' for Redemption; '04' for Switch from operation; '05' for trans­fers and so on upto '10'
Indicate the value for which the transaction type for which the rules are being set up
GROS­SORNET
Alphanu­meric
1
Optional
G' for Gross ; 'N' for Net and 'B' for Both
Opting for a gross or net mode in trans­action process­ing is mode is only available for IPO, sub­scription or redemption transactions. For transac­tions with a gross process­ing mode, the value of the transaction, whether as an amount or a number of units, will be processed as a gross value from which any applicable charges will be deducted. For transactions with a net pro­cessing mode, the amount value of the transaction will be processed as a net value apart from the charges.
TRANS­ACTION­STARTDATE
DATE
8
Optional
Enter a date to specify that the above men­tioned transac­tion type will start from this date
TRANS­ACTIONENDDATE
DATE
8
Optional
Enter a date to specify that the above men­tioned transac­tion type will end on this date
TRANS­ACTION­FREQUENCY
Alphanu­meric
1
Optional
Enter a value to specify the frequency with which the transaction type will oper­ate
TRANS­ACTION­STARTPERIOD
NUMBER
1
Optional
Enter a value to specify the Start Period within the fre­quency men­tioned above. Within a par­ticular fre­quency, you have an option to restrict it to a particular period. For example if the transaction Frequency is WEEKLY, Start Period is 2 and End Period is 5. This means that the Fund is open for this transaction from second day till the fifth day of the week.
TRANS­ACTIONENDPERIOD
NUMBER
1
Optional
The End period has to be within the Transac­tion Frequency i.e., it can take values up to 7 (weekly) and not greater than that.
DATE
DATE
Optional
Enter a time to specify the start time for a given working date. On a given day when the fund is open for this transaction, you can start entering trans­actions from this time.
MIN­TRANS­ACTIONAMOUNT
NUMBER
15
Optional
Maximum of 3 decimals allowed
The minimum transaction amount allowed for this transaction type in this fund
STEPAMOUNT
NUMBER
15
Optional
Enter a value to specify the steps of amount in which a unit holder can invest or redeem. This will operate above the Mini­mum Transac­tion Amount.
MAX­TRANS­ACTIONAMOUNT
NUMBER
15
Optional
The maximum transaction amount allowed for this transaction type in this fund
MIN­TRANS­ACTIONUNITS
NUMBER
15
Optional
Maximum of 6 decimals allowed
The minimum transaction units allowed for this transac­tion type in this fund
STEPU­NITS
NUMBER
15
Optional
The unit steps applicable for a unit holder to invest do any operation
MAX­TRANS­ACTIONUNITS
NUMBER
15
Optional
The maximum transaction units allowed for this transac­tion type in this fund
ONLINE­ALLOCA­TION
NUMBER
1
Optional
Valid values '0' and '1'
This is to indi­cate if Online Allocation is to be allowed for the given trans­action type. This can be applicable only if the fund is pre-priced.
For Post Priced Fund with Allo­cation as Online, the Transaction Frequency is Allocation
ALLOCA­TION­PERVSREGCAPI­TAL
NUMBER
1
Optional
Should be below 100.
Specify the per­centage up to which alloca­tion can be allowed for a given regis­tered amount on the day
ALLOCA­TION­POLICY
Alphanu­meric
1
Optional
Enter F for First In First Out or P Proportion­ate to specify the policy for allocation in case the maxi­mum limit is reached for a given day. This policy is with respect to the allocation per­centage that is allowed against the fund cor­pus.
NOOFTX­NAL­LOWEDFORFREQ
NUMBER
1
Optional
This is to spec­ify the number of transactions allowed restric­tion within this frequency
NOOFTX­NAL­LOWEDPERUH
NUMBER
1
Optional
Enter a value to specify the number of transactions that are allowed for a unit holder. You can restrict the unit holder from operating more than the speci­fied limit for transactions.
NOOF­FREETX­NALLOWEDPE­RUH
NUMBER
1
Optional
Enter a value to specify the number of free transactions within the per­mitted transac­tions. This definition will override all loads that will be set for this transaction
ALLOW­BACK­DATING
NUMBER
1
Optional
This is used to indicate whether back­dating should be allowed for this fund. This means that on any given date, for this transac­tion type, the system will allow the user to enter trans­actions dated earlier to the current date
BACK­DATIN­GLIMIT
NUMBER
1
Optional
This is applica­ble only if Allow Back Dating is True. This has to be later than the transaction start date. Fund Price as effective on that date will be taken into account during allocation.
FUNDTRANSAC­TION­COUNTER
NUMBER
1
Optional
Enter a value to specify the total number of transactions to be allowed in this transac­tion type.
ACKNOWLEDGE­MENTRE­QUIRED
NUMBER
1
Optional
This is to indi­cate if the Acknowledg­ment Slip is to be printed after every transac­tion. Otherwise this can be printed on receiving spe­cific request from the User.
CONFIR­MATION­REQUIRED
NUMBER
1
Optional
This is to indi­cate whether confirmation Slip is to be printed after every transac­tion entry. Oth­erwise this can be user initi­ated after allo­cation of the transaction.
NOTI­CEPERI­ODDATEBASIS
VAR­CHAR2
1
Optional
NOTI­CEPER­IOD
NUMBER
3
Optional
BASE­PRICE­DEFINITION
Alphanu­meric
1
Optional
Valid values are 'P' for Par Value and 'N' for declared NAV
This indicates the Base Price definition for the transac­tion. The Unit Price will be calculated based on this price and loads defined for this transaction.
BASE­PRICE­FACTOR
NUMBER
1
Optional
This percent­age will be applied to the price arrived from the above calculations to arrive at the Base Price for this transac­tion type for the fund.
NOOF­DECI­MALSFORBASE­PRICE
NUMBER
1
Optional
Indicate the maximum num­ber of deci­mals that would be reckoned for rounding preci­sion, for the base price. You cannot indi­cate a preci­sion higher than 6 decimal places.
ROUND­OFFTRUNCATE­BASE­PRICE
Alphanu­meric
1
Optional
Indicate the rounding options for the value of the number of allot­ted units, des­ignated for the fund.
TRANS­ACTIONENABLED
NUMBER
1
Optional
This is used to indicate whether the transaction is enabled for the fund. It is pos­sible to set up a temporary sus­pension of transactions, even if the transactions are open for the fund.
CROSS­BRANCHALLOWED
NUMBER
1
Optional
PRICE­LAG
NUMBER
1
Optional
This cannot have negative value. This indicates the price date to be used for the transaction during alloca­tion process
ALLOCA­TIONLAG
NUMBER
1
Optional
Enter a value to specify when the transaction should be allo­cated if the transaction is ‘T’. T + X , where ‘X’ will be days of Lag. Lag can only be positive.
CONFIR­MATION­LAG
NUMBER
1
Optional
Enter a value to specify when the redemption transaction should be picked for con­firmation after allocation. T + X , where ‘X’ will be days of Lag. Lag can only be posi­tive.
CHQAL­LOCON­PARWITHCASH
NUMBER
1
Optional
This is used to specify that all check / Demand Draft transactions are to be treated on par with cash transactions. If this is true, then during allocation, the check / demand draft transactions will be taken for allocation for the same day. The units allo­cated will be provisional, and will be con­firmed only after the check is cleared.
HOLD­INGPERI­ODAPPLICABLE
NUMBER
1
Optional
This is used to indicate whether a lock in period is applicable for the investors investing in the fund for the transaction type
RETAIN­AGEING­TOSUBSCRIP­TION
NUMBER
1
Optional
This is used to indicate that the aging prin­ciple must be applied to sub­scription trans­actions in the fund. Aging is the process of keeping track of a transac­tion from the transaction date right up to when it is cleared in full from the account of the unit holder. Depending upon the pol­icy specified to be followed for aging, (i.e., either FIFO or proportionate), aging is applied.
CREDIT­CARDAL­LOCONPARWITH­CASH
NUMBER
1
Optional
This is used to indicate if all credit card transactions to be treated on par with cash transactions. If this is true then during alloca­tion the credit card transac­tions will be taken for allo­cation for the same day. The units allocated will be provi­sional, and will be confirmed only after the credit card transaction is cleared.
LIMITRE­DEMP­TIONMODE
Alphanu­meric
1
Optional
Valid values are 'P' for Percent; 'U' for Units and 'A' for Amount
The mode based on which redemption will be limited
NATURE­OFLIMIT
Alphanu­meric
1
Optional
Indicates whether it is 'A' or 'U' or 'B'
TRANS­FERAL­LOCONPARWITH­CASH
NUMBER
1
Optional
Mark this check box if you want all transfer transactions to be treated on par with cash transactions. If this is true then during alloca­tion the transfer transactions will be taken for allocation for the same day. The units allo­cated will be provisional, and will be con­firmed only after the bank transfers are cleared
MININI­TIALTX­NAMOUNT
NUMBER
15
Optional
Minimum amount appli­cable for initial transaction
MININI­TIALTXN­UNITS
NUMBER
15
Optional
Minimum units applicable for initial transac­tion
MINSITX­NAMOUNT
NUMBER
15
Optional
Minimum amount appli­cable for Standing instructions
MAX­SITX­NAMOUNT
NUMBER
15
Optional
Maximum amount appli­cable for Standing instructions
MINSITX­NUNITS
NUMBER
15
Optional
Minimum units applicable for Standing instructions
MAX­SITXN­UNITS
NUMBER
15
Optional
Maximum units applicable for Standing instructions
EXISTIN­GUH
Alphanu­meric
2
Optional
This is to indi­cate that the subscription transactions for the fund must only be availa­ble to existing customers, and not to new cus­tomers.
NOOF­DECI­MALSFORUNIT­PRICE
NUMBER
1
Optional
Indicate the maximum num­ber of deci­mals that would be reckoned for rounding preci­sion, for the unit price. You cannot indi­cate a preci­sion higher than 6 decimal places.
ROUND­OFFTRUNCATEU­NITPRICE
Alphanu­meric
1
Optional
ROUND­OFFTRUNCATEU­NITS
Alphanu­meric
1
Optional
PAY­MENT­LAG
NUMBER
1
Optional
In the case of redemption transactions, specify a value to indicate the number of days by which the resulted redemption payouts would be lagged or deferred, after the redemption transaction has been allotted and confirmed. To arrive at the actual date of redemption payment, both the confirma­tion lag (if specified) and the payment lag (if specified here) are taken into considera­tion. For instance, if the redemption transaction was allocated on 15th Janu­ary and both the confirma­tion lag and payment lag were specified as 2, then the actual redemp­tion payout to the unit holder would be effected on 19th January (15 + 2+ 2), provided it is not a holiday in the system, and provided there are no intervening hol­idays.
TRANS­ACTION­CUTOFFTIME
DATE
DATE
Optional
Specify the time, on a given working day before which a trans­action of the selected type will be accepted with the transaction date being the current date. Beyond this time on a work­ing day, the transaction date will be set by default to be the next work­ing date.
ENFORCEHOLD­ING­PERIOD
NUMBER
1
Optional
You can indi­cate that the minimum hold­ing period specified for the fund in the Fund Demo­graphics pro­file must be enforced as mandatory for the transaction type, by select­ing this option.
APPLY­ENTRY­TIMELOAD
NUMBER
1
Optional
Applicable for Exit transac­tions
Pseu­doswitch­lag
Number
Optional
Used for cap­turing Pseudo Switch lag
AllowSys­temat­icPlans
Number
1
Optional
MaxIni­tialTx­nAmount
Number
15
Optional
Used for cap­turing the maxi­mum initial transaction amount.
MaxIni­tialTxn­Units
Number
15
Optional
Used for cap­turing maxi­mum initial transaction units.
Pseu­doswitch­lagcalendarbasis
Alphanu­meric Code
1
Optional
Specify whether the ps lag days should be considered based on the holiday calen­dar for the fund, the actual calendar or the System calen­dar.
FULL­OUT­FLOW
NUMBER
1
Optional
MAX­NOOFSI­TRANSACTIONS
NUMBER
4
Optional
MaxNoofSI­Transactions value should be Greater than 0
MAXVA­LIDITY
NUMBER
4
Optional
Maxvalidy value should be Greater than 0
SILEAD­TIME
NUMBER
4
Optional
APPLICA­BLEAC­COUNTTYPES
Alphanu­meric
255
Optional
INFLOW­OVER­RIDABLEMSG
NUMBER
1
Optional
MINMA­TURI­TYPERIOD
NNUM­BER
4
Optional
Min.Maturity Period value sholud be greater than 0
MAXMA­TURI­TYPERIOD
NNUM­BER
4
Optional
Max.Maturity Period value sholud be greater than 0 and greater than or equal to Min.Maturity Period
FUTURE­DATELIMIT
NUMBER
1
Optional
Valid values are positive integer
To facilitate users to input future dated transactions
UHCAL­ENDAR­BASIS
VAR­CHAR2(1)
1
Optional
Valid values are ‘T’ and ‘C’
NUMBER
1
Optional
Valid values are
-1 to 9
CONS­SIAUTO­COUNTER
NUMBER
3
Optional
Used to cap­ture consecu­tive payment rejections allowed for the SI
THRESH­OLDA­MOUNT
NUMBER
(30, 12)
Optional
Threshold Amount
Serial Number: 6
Segment Identification Number: 05TCM
Description: This segment is used for providing Transaction processing communication mode information
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alpha­numeric
20
Mandatory
Default value 05TCM
Standard value of 05TCM to uniquely identify Transaction pro­cessing commu­nication mode information
PRO­CESSID
Alpha­numeric
50
Mandatory
FUNDID
Alpha­numeric
6
Mandatory
The Fund ID is a unique Identifi­cation for each Fund and it indi­cates the fund for which Trans­action process­ing communication mode informa­tion has to be uploaded
RULEEFFEC­TIVE­DATE
Date
8
Mandatory
The rule effec­tive date for which transac­tion processing communication mode informa­tion for the fund has to be main­tained.
TRANS­ACTION­TYPE
Alpha­numeric
2
Mandatory
Valid values are '01' for IPO; '02' for Subscrip­tion; '03' for Redemption; '04' for Switch from operation; '05' for transfers and so on up to '10'
COM­MUNI­CATIONMODE
Alpha­numeric
2
Mandatory
Valid Communi­cation mode code indicated as a part of Par­ams Mainte­nance.
Number
15
Optional
Decimal values up to maximum of 3 digits are allowed
Minimum trans­action amount allowed for the transaction type and communica­tion mode.
Number
15
Optional
Maximum trans­action amount allowed for the transaction type and communica­tion mode.
Number
15
Optional
Decimal values up to maximum of 6 digits are allowed
Minimum trans­action units allowed for the transaction type and communica­tion mode.
Number
15
Optional
Maximum trans­action units allowed for the transaction type and communica­tion mode.
DISAL­LOW­FIRSTTRANS­ACTION
Number
1
Optional
Serial Number: 7
Segment Identification Number: 06INV
Description: This segment is used for providing Transaction processing investor category related information
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alphanu­meric
20
Mandatory
Default value 06INV
Standard value of 06INV to uniquely iden­tify Transaction processing communication mode informa­tion
PRO­CESSID
Alphanu­meric
50
Mandatory
FUNDID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identi­fication for each Fund and it indi­cates the fund for which Trans­action process­ing investor category infor­mation has to be uploaded
RULEEF­FEC­TIVEDATE
Date
8
Mandatory
The rule effec­tive date for which transac­tion processing investor cate­gory informa­tion for the fund has to be main­tained.
TRANS­ACTION­TYPE
Alphanu­meric
2
Mandatory
INVES­TORCAT­EGORY
Alphanu­meric
2
Mandatory
Valid Corporate and Individual categories defined as a part of Params Maintenance.
Number
15
Optional
Minimum trans­action amount allowed for the transaction type and investor category.
STEPAMOUNT
Number
15
Optional
Number
15
Optional
Maximum trans­action amount allowed for the transaction type and investor category.
Number
15
Optional
Minimum trans­action unit allowed for the transaction type and investor category.
STEPU­NITS
Number
15
Optional
Number
15
Optional
Maximum trans­action unit allowed for the transaction type and investor category.
Serial Number: 8
Segment Identification Number: 07IDR
Description: This segment is used for providing Corporate Action related information
Segment Mandatory/Optional?: Optional
Multiple records allowed for the same Fund and Rule Effective Date: Yes (For cash and Stock dividend information)
Field Name
Type
Maximum Length
Description
SEGMEN­TID
Alpha­numeric
20
Mandatory
Default value 07IDR
Standard value of 07IDR to uniquely identify Transaction pro­cessing commu­nication mode information
PROCES­SID
Alpha­numeric
50
Mandatory
FUNDID
Alpha­numeric
6
Mandatory
The Fund ID is a unique Identifi­cation for each Fund and it indi­cates the fund for which Corpo­rate action has to be uploaded
RULEEF­FECTIVE­DATE
Date
8
Mandatory
The rule effec­tive date for which corporate action for the fund has to be maintained.
DIVI­DENDDE­CLAREFREQ
Alpha­numeric
1
Optional
Enter the fre­quency with which the divi­dend is to be declared
DIVI­DEND­PAYMENTFREQ
Alpha­numeric
1
Optional
Enter the fre­quency with which the declared divi­dends are to be paid. As the sys­tem supports accumulation of dividends, the payment could be for any divi­dend that has been declared earlier. The Divi­dend Payment Frequency must not be less than Dividend Decla­ration Fre­quency.
REIN­VEST­MENTALLOWED
Number
1
Optional
This is used to indicate if rein­vestment is allowed for the fund.
TAXID
Alpha­numeric
50
Optional
Enter the tax ID for the fund that is being set up.
BOOK­CLOSIN­GLEADTIME
Number
5
Optional
FREEZE­HOLD­INGLEADTIME
Number
5
Optional
This data is also in days and the Freeze Holding Date is the date on which the balances held by all unit hold­ers in the fund will be consoli­dated
BOARD­MEET­INGLEADTIME
Number
5
Optional
Enter a lead-time in days. This is captured for information purposes only.
DIVI­DEND­PAYMENTLEAD­TIME
Number
5
Optional
The lead time entered is in days. Each of the lead times must be less than the Divi­dend Declara­tion Frequency. For example, if the Dividend Declaration Fre­quency is WEEKLY, the Board Meeting Lead Time can­not be 8 days.
NOOF­DECI­MALSFORDIVI­DEND
Number
5
Optional
Indicate the maximum num­ber of decimals that would be reckoned for rounding preci­sion, for the divi­dend. You cannot indicate a precision higher than 6 decimal places.
ROUND­OFFTRUNCATE­DIVI­DEND
Alpha­numeric
1
Optional
Indicate the rounding options for the value of the dividend, designated for the fund.
TDSBA­SIS
Alpha­numeric
1
Optional
D - Each Divi­dend ; U - Fiscal year
This is to indi­cate whether slab should be looked for every dividend pay­ment separately or whether con­solidated on a fiscal year basis.
EPUCOM­PONENTS
Number
1
Optional
This indicates the applicability of Earnings Per Unit and that the earnings per unit must be defined in terms of com­ponents, or as a single value. Setting up EPU components is not applicable for stock divi­dends.
DEFAULTDISTRI­BUTION­MODE
Alpha­numeric
1
Optional
Valid values are 'T' - Payout-A/C Transfer; 'Q' - Payout-Cheque and 'R' - Full Reinvestment
If the Income Distribution Setup for the unit holder has not yet been specified, the fund level default Unit Holder Distribu­tion Mode to be considered for the unit holder can be specified here. For stock dividends, the only possible option is ’Rein­vestment' as others would not be applicable
EXCHANGERATE­DATEBA­SIS
Alpha­numeric
1
Optional
Valid values are 'P' - Payment Date; 'R' - Ref­erence Date
Specify the basis upon which the exchange rate will be applied for dividend pro­cessing. The system pro­vides two options: Refer­ence Date and Payment Date.
RESTRIC­TIDS
Number
1
Optional
This is used to indicate that specific income distribution set­ups for unit hold­ers may be overridden. For stock dividends this value should always be set.
EPULOT
Number
6
Optional
Specify the num­ber of units for which the EPU quote is deemed to be applica­ble, for the fund. Setting up EPU components is not applicable for stock divi­dends.
DIV­LOOKA­HEAD
Number
1
Optional
This is to indi­cate that in the event of inter­vening holidays, the system would obtain the EPU informa­tion and pro­cess dividends for the holiday period, ahead of the prior busi­ness day, for the fund.
CORPO­RATEAC­TIONTYPE
Alpha­numeric
1
Mandatory
Valid values are 'C' for Cash and 'S' for Stock divi­dends
For cash divi­dend EPU should be men­tioned whereas for Stock divi­dend, Par­ent:Resultant ratio should be mentioned
UNITS­FOR­FREEZEHOLDINGS
Alpha­numeric
1
Optional
Valid values 'A' for all units and 'C' for Con­firmed units
Specify the units to be considered for dividend eli­gibility as on the freeze holdings date. You can specify that all units (including unconfirmed units) must be considered, or that only con­firmed units are to be considered as on the freeze holdings date.
FIRST­DIVI­DENDDECLARE­DATE
Date
8
Optional
Specify the first date for dividend declaration, for the fund
SPECIAL­DIVI­DEND
Number
1
Optional
This is to indi­cate that special dividends are applicable for the fund. This feature is only available if your installation has requested for it.
MOCK­DIVI­DEND
Number
1
Optional
Not applicable now
HOLIDAY­RULE
Alpha­numeric
1
Optional
A' for After and 'P' for prior
Select the rule to be applied if the dividend pro­cessing date falls on a holi­day. You can select either the PRIOR rule (the previous work­ing day is con­sidered) or the AFTER rule (the next working day is consid­ered), for the dividend type. The holiday rule you select here will be applica­ble to all divi­dend-processing dates that have been arrived at using a fre­quency. They are not applica­ble to dates arrived at using lead times or lag periods.
PAY­MENT­LAG
Number
3
Optional
Specify a lag period (in days) for the payment of dividend. The lag value is interpreted in calendar days, and is used to arrive at the pay­ment date for the dividend. The payment date is arrived at as follows: Divi­dend Payment Date = Dividend Declaration Date + Payment Lag
PAYDIVI­DEND­DURINGRED
Number
1
Optional
This is used to indicate that div­idends may be paid during redemption.
REIN­VEST­MENTPRICEBASIS
Alpha­numeric
1
Optional
IRACOM­PULSO­RYREINVEST
Number
1
Optional
Applicable only if IRA is applica­ble for the fund.
NPISUP­PORT
Alpha­numeric
1
Optional
NPIPAY­MENT
Alpha­numeric
3
Optional
NPIU­HOverride
Alpha­numeric
1
Optional
FlgUnset­tleUnits
Alpha­numeric
1
Optional
MIMAMT­TOBEP­AIDOUT
NUM­BER
1
Optional
ACTION
VAR­CHAR2
1
Optional
Valid values are
‘L’ and ‘R’
OVER­RATPAY­TIME
NUM­BER
1
Optional
Valid values are
0 and 1
AUTORE­INVFO­RUNCLCHQ
NUM­BER
1
Optional
Valid values are
0 and 1
AUTORE­INVFO­RUNCLCHQFZB
NUM­BER
1
Optional
Valid values are
0 and 1
TRACK­UNCLEAREDTXNS
VAR­CHAR2
1
Optional
Valid values are
0 and 1
TRACK­BLOCKEDTXNS
VAR­CHAR2
1
Optional
Valid values are
0 and 1
PAYUN­GENRE­INVESTMENT
VAR­CHAR2
1
Optional
Valid values are
0 and 1
TDS APPLICA­BLE FOR ALL UH
Number
1
Optional
Valid values are
0 (No) and 1(Yes)
TDS Applicable for all UH” flag could be set to ‘1’ only if divi­dend equaliza­tion is applicable for the fund.
Serial Number: 9
Segment Identification Number: 08FSC
Description: This segment is used for providing Fund Sale Country information
Segment Mandatory / Optional?: Mandatory
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alphanu­meric
20
Mandatory
Default value 08FSC
Standard value of 08FSC to uniquely identify Fund sale coun­try information
PRO­CESSID
Alphanu­meric
50
Mandatory
FUNDID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identifica­tion for each Fund and it indi­cates the fund for which Fund sale country informa­tion has to be uploaded
RULEEFFEC­TIVE­DATE
Date
8
Mandatory
The rule effec­tive date for which fund sale country informa­tion for the fund has to be main­tained.
COUN­TRY­CODE
Alphanu­meric
3
Valid country code present in the system as a part of Domicile in Params main­tenance
If no country code is men­tioned and this field is left blank then it means that there is no restriction on the sale of the fund. However, if valid value is entered then the fund would be restricted for sale in those coun­tries
Serial Number: 10
Segment Identification Number: 09FRL
Description: This segment is used for providing Fund residency list information
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alphanu­meric
20
Mandatory
Default value 09FRL
Standard value of 09FRL to uniquely identify Fund resi­dency list informa­tion
PRO­CESSID
Alphanu­meric
50
Mandatory
FUNDID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identifica­tion for each Fund and it indicates the fund for which Fund residency list information has to be uploaded
RULEEFFEC­TIVE­DATE
Date
8
Mandatory
The rule effective date for which fund residency list infor­mation for the fund has to be main­tained.
COUN­TRY­CODE
Alphanu­meric
3
If no country code is mentioned and this field is left blank then it means that there is no restriction on the investor resid­ing in any domi­cile. However, if valid value is entered then the fund would be restricted for investors residing in that domicile.
Serial Number: 11
Segment Identification Number: 10FFM
Description: This segment is used for providing Fund formula information
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alphanu­meric
20
Mandatory
Default value 10FFM
Standard value of 10FFM to uniquely identify Fund formula related informa­tion
PRO­CESSID
Alphanu­meric
50
Mandatory
FUNDID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identifica­tion for each Fund and it indi­cates the fund for which Fund for­mula information has to be uploaded
RULEEFFEC­TIVE­DATE
Date
8
Mandatory
The rule effective date for which fund formula information for the fund has to be maintained.
COM­PONEN­TID
Alphanu­meric
10
Mandatory
Valid compo­nents maintained in the system as a part of Params maintenance. This also depends on whether this is used for Fund price computa­tion or not.
FUND­PRICE­COMPUTATION
Alphanu­meric
1
Optional
Indicates whether the data has to be used for Fund price computa­tion or not. This value should remain the same for the fund and Rule effective date combina­tion. In other words, for a fund and Rule effec­tive date - we cannot have one component used for fund price computation and the other compo­nent not used for fund price com­putation.
FOR­MULA
Alphanu­meric
255
Optional
DEFAULTVALUE
Number
15
Optional
EXCLU­DEFROMCAPI­TAL­GAINS
Number
1
Optional
Serial Number: 12
Segment Identification Number: 11FLM
Description: This segment is used for providing Fund load information
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alphanu­meric
20
Mandatory
Default value 11FLM
Standard value of 11FLM to uniquely iden­tify Fund load related informa­tion
PROCES­SID
Alphanu­meric
50
Mandatory
This should identify the upload uniquely. This should also be unique within a file and it allows to identify imported records later
FUNDID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identifi­cation for each Fund and it indi­cates the fund for which Fund load informa­tion has to be uploaded
RULEEF­FECTIVE­DATE
Date
8
Mandatory
The rule effec­tive date for which fund load information for the fund has to be maintained.
TRANS­ACTION­TYPE
Alphanu­meric
2
Mandatory
Valid values are from '01' to '10' ranging from IPO to Re-issue
This is to indi­cate the trans­action type for which the loads are being defined
LOADID
Number
5
Mandatory
Valid load ID defined in the system
Specify the name of the Load (fee/incen­tive) that must be applied for the selected Fund.
LOADTO­PRICE
Number
Optional
This is to indi­cate that this load is to be loaded to the base price
FRO­MENTI­TYTYPE
Alphanu­meric
1
Mandatory
Valid values are· 'M' for AMC, 'A' for Agent, 'B' for Broker, 'D' for Distributor, 'F' for Fund, 'R' for Registrar, 'T' for Trustee, 'U' for Unit Holder, 'S' for Custodian
This is to indi­cate the entity type from which the load is applied
TOENTI­TYTYPE
Alphanu­meric
1
Mandatory
This is to indi­cate the entity type to which the load is applied
PRO­CESS­INGFREQ
Alphanu­meric
1
Optional
Valid values are 'A', 'T' and 'P'
Specify the fre­quency at which this load is to be applied. Loads can be applied at any of three possible fre­quencies - Allo­cation time, Transaction time and Post allocation. (Refer the table marked ‘PRO­CESSING­FREQ’ at the end of this doc­ument)
GLAC­COUNT­CODE
Alphanu­meric
10
Optional
When transac­tion information is exported to an external sys­tem, if separate books of accounts are to be posted for different loads, this code will be used to identify this load infor­mation in the export data.
DEBI­TOR­CREDIT
Alphanu­meric
1
Optional
Valid values are 'D' and 'C'
This is used to indicate that the applied load would result in a debit or credit for the fund. This data is cap­tured for infor­mation purposes only and has no pro­cessing implica­tions in the system data­base.
CON­TRAAC­COUNTCODE
Alphanu­meric
10
Optional
Specify the code that will be used to identify the second leg of accounting entries for any transaction, in the event of exporting of transaction information to an external sys­tem.
NOOF­DECI­MALSFORLOAD
Number
1
Optional
Indicate the rounding options for the value of the load, desig­nated for the fund.
ROUND­OFFTRUNCATE­FOR­LOAD
Alphanu­meric
1
Optional
Indicate the maximum num­ber of decimals that would be reckoned for rounding preci­sion, for the load. You can­not indicate a precision higher than 6 decimal places.
MANDA­TORY
Alphanu­meric
1
Optional
Valid values are 'M' and 'O'
Select Manda­tory or Optional to specify whether the load is manda­tory or optional
PRIORI­TYNO
Number
Optional
For a manda­tory load, the priority number is set to 0 and for an optional load the priority number should be unique i.e.. for a given Fund, no more than one load can have the same priority number.
Enter a value to specify the pri­ority number in case of optional loads.
LOAD­VATTO­PRICE
Number
Optional
APPLY­RETVA­LON
Alphanu­meric
1
Optional
Valid vales are 'G' - Capital Gains Gross; 'N' - Non-capital gains Net and 'C' - Capital gains and
‘P’ - Perfor­mance Based and ‘I’ – IOF and ‘D’ - Default IRRF and ‘O’ - Optional IRRF and ‘S’- CDSC
If the load is a Capital Gains Tax, and it is to be applied based on the gross amount after allocation, choose the Cap­ital Gains – Gross option in this field, for such a load.
SEND­FOR­GLINTERFACE
Number
1
Optional
This is used to indicate that accounting entries due only to the selected load must be posted to the external asset management system, for the fund.
REFTYPE
Alphanu­meric
2
Mandatory
Valid reference type as per the pre-shipped data in RefTy­peTbl
When load needs to be mapped to a ref­erence transac­tion type like Reinvestment and if the sys­tem supports the mapping of the Ref Type to any load, then such RefTypes can be indicated here.
DIFFER­ENTIAL­FEE
Number
1
Optional
This is to indi­cate whether differential fee in the case of switch transac­tions for any fund is to be applicable
SLABBA­SIS
Alphanu­meric
1
Optional
Valid values are 'G' for Gross and 'N' for Net
‘W’ – Weighted Average
This is to Indi­cate the basis on which the slabs will be reckoned for an amount-based load that you are designating as applicable for the fund
PRICEADDIN
Number
1
Optional
This is used to indicate the add-in factor that is to be applicable for computing the return value for the load, for the selected trans­action type. The add-in factor is used to arrive at the return value for a load, at the time of alloca­tion.
GROUPID
Alphanu­meric
6
Optional
Valid Group Id present in the system
INDEXA­TIONON­CGT
Alphanu­meric
1
Optional
Valid values are 'Y' for Yes and 'N' for 'No'
LevelID
Number
Optional
Used for captur­ing the LevelID
DependentLevel
Number
Optional
Used for captur­ing Dependent level.
Serial Number: 13
Segment Identification Number: 12FTC
Description: This segment is used for providing Fund transaction currency information
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alpha­numeric
20
Mandatory
Default value 12FTC
Standard value of 12FTC to uniquely identify Fund transaction currency infor­mation
PROCES­SID
Alpha­numeric
50
Mandatory
FUNDID
Alpha­numeric
6
Mandatory
The Fund ID is a unique Identifica­tion for each Fund and it indi­cates the fund for which Fund transaction cur­rency informa­tion has to be uploaded
RULEEF­FECTIVE­DATE
Date
8
Mandatory
The rule effective date for which fund transaction currency infor­mation for the fund has to be maintained.
CURREN­CYCODE
Alpha­numeric
3
Optional
Valid currency maintained in the system
If no currency code is men­tioned and this field is left blank then it means that there is no restriction on the currency used for transaction for this fund. How­ever, if valid value is entered then the fund would be restricted for transaction in those currencies
Serial Number: 14
Segment Identification Number: 13FAI
Description: This segment is used for providing Fund additional information
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alphanu­meric
20
Mandatory
Default value 13FAI
Standard value of 13FAI to uniquely identify Fund additional infor­mation
PRO­CESSID
Alphanu­meric
50
Mandatory
FUNDID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identifica­tion for each Fund and it indi­cates the fund for which Fund addi­tional informa­tion has to be uploaded
RULEEF­FEC­TIVEDATE
Date
8
Mandatory
The rule effec­tive date for which fund addi­tional informa­tion for the fund has to be main­tained.
OTHER­INFO1
Alphanu­meric
60
Optional
Additional infor­mation could be maintained in the system as a art of 'Add Info Main­tenance'. Once this is done, for a specific AMC, the additional infor­mation can be mapped for the entity type Fund. Hence, as a part of Fund addi­tional informa­tion maintenance, the values could be captured. Any such additional information can be captured using these fields
OTHER­INFO2
Alphanu­meric
60
Optional
OTHER­INFO3
Alphanu­meric
60
Optional
OTHER­INFO4
Alphanu­meric
60
Optional
OTHER­INFO5
Alphanu­meric
60
Optional
OTHER­INFO6
Alphanu­meric
60
Optional
OTHER­INFO7
Alphanu­meric
60
Optional
OTHER­INFO8
Alphanu­meric
60
Optional
OTHER­INFO9
Alphanu­meric
60
Optional
OTHER­INFO10
Alphanu­meric
60
Optional
OTHER­INFO11
Alphanu­meric
60
Optional
OTHER­INFO12
Alphanu­meric
60
Optional
OTHER­INFO13
Alphanu­meric
60
Optional
OTHER­INFO14
Alphanu­meric
60
Optional
OTHER­INFO15
Alphanu­meric
60
Optional
OTHER­INFO16
Alphanu­meric
60
Optional
OTHER­INFO17
Alphanu­meric
60
Optional
OTHER­INFO18
Alphanu­meric
60
Optional
OTHER­INFO19
Alphanu­meric
60
Optional
OTHER­INFO20
Alphanu­meric
60
Optional
OTHER­INFO21
Alphanu­meric
60
Optional
OTHER­INFO22
Alphanu­meric
60
Optional
OTHER­INFO23
Alphanu­meric
60
Optional
OTHER­INFO24
Alphanu­meric
60
Optional
OTHER­INFO25
Alphanu­meric
60
Optional
OTHER­INFO26
Alphanu­meric
60
Optional
OTHER­INFO27
Alphanu­meric
60
Optional
OTHER­INFO28
Alphanu­meric
60
Optional
OTHER­INFO29
Alphanu­meric
60
Optional
OTHER­INFO30
Alphanu­meric
60
Optional
Serial Number: 15
Segment Identification Number: 14IRA
Description: This segment is used for providing Fund IRA information, if applicable
Segment Mandatory/Optional? : Optional
Field Name
Type
Maximum Length
Description
SEG­MEN­TID
Alphanu­meric
20
Mandatory
Default value 14IRA
Standard value of 14IRA to uniquely identify Fund IRA information
PRO­CES­SID
Alphanu­meric
50
Mandatory
FUN­DID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identifica­tion for each Fund and it indicates the fund for which Fund IRA informa­tion has to be uploaded
RULEEFFEC­TIVE­DATE
Date
8
Mandatory
The rule effective date for which fund IRA information for the fund has to be maintained.
MININI­TIALIN­VESTMENTAMT
Number
15
Mandatory
Minimum initial investment amount
MAX­INI­TIALINVEST­MEN­TAMT
Number
15
Mandatory
Maximum initial investment amount
MININ­VEST­MENTAMT
Number
15
Mandatory
Minimum invest­ment amount
MAXIN­VEST­MENTAMT
Number
15
Mandatory
Maximum invest­ment amount
MIN­WITH­DRAWALAMT
Number
15
Mandatory
Minimum With­drawal amount
MAX­WITH­DRAWALAMT
Number
15
Mandatory
Maximum With­drawal amount
Serial Number: 16
Segment Identification Number: 15FDI
Description: This segment is used for providing Fund delivery instruction information, if applicable
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alphanu­meric
20
Mandatory
Default value 15FDI
Standard value of 15FDI to uniquely identify Fund trans­action currency information
PRO­CESSID
Alphanu­meric
50
Mandatory
Same value as in 00GEN - ProcessID
FUNDID
Alphanu­meric
6
Mandatory
The Fund ID is a unique Identifica­tion for each Fund and it indicates the fund for which Fund delivery instruction has to be uploaded
RULEEFFEC­TIVE­DATE
Date
8
Mandatory
The Fund ID and Rule effec­tive date com­bination should be the same as defined in 01FDR
The rule effective date for which Fund delivery instruction informa­tion for the fund has to be main­tained.
REGIS­TERE­DACCOUNT
Number
1
Mandatory
Indicate as '1' if the respective delivery mode is applicable for the fund
DELIV­ERYTO­CUSTODIAN
Number
1
Mandatory
DELIV­ERYTO­CLGAGENT
Number
1
Mandatory
PHYSI­CALCERTDE­LIVERY
Number
1
Mandatory
DEFAULTDE­LIVERY
Alphanu­meric
2
Mandatory
Valid values are ‘RA’ for Registered account, ‘CU’ for Deliver to Custodian, ’CL’ for Deliver to Clearing Agent and ‘PD’ for Physical deliv­ery
Should be based on allowed deliv­ery modes
CER­TIFI­CATEDENOMI­NATIONS
Alphanu­meric
200
Optional
This value should be specified with necessary field and record separator as shown below:- 10|0:100|1:500|0:1000|0 where the field separator between Denomination value and Default is ‘|’ and the record separator is colon - ‘:’
This is applicable only in case of scri­pless funds having Physical delivery as one of the deliv­ery instruction.
PUEV
NUM­BER
1
Optional
This is a new deliv­ery+ option
3.1.3 PROCESSINGFREQ (ref 11FLM, 12.10)
* Allocation: This will mean that you will be charging the investor a fee or giving an incentive at the time of allocation of units. Allocation time loads cannot be designated for any transaction types other than IPO, subscription, redemption, and switch.
* Transaction: The charge (fee) or incentive will be applied at the time the transaction request is accepted from the investor.
* Post Allocation: This frequency is applicable typically to the Capital Gains Tax, which may be applied after allocation, on the gross amount.
Capital Gains Tax may also be designated as an allocation time load.
Serial Number: 17
Segment Identification Number: 17KYC
Description: This segment is used for capturing the Document information, if applicable
Field Name
Type
Maximum Length
Characteristics / Validations applicable
Description
SEG­MENTID
Alphanu­meric
20
Mandatory
Default value 17KYC
Standard value of 17KYC is to uniquely identify Fund document description.
PRO­CESSID
Alphanu­meric
50
Mandatory
This should iden­tify the upload uniquely. This should also be unique within a file and it allows to identify imported records later
FUNDID
Alphanu­meric
6
Mandatory
RULEEFFEC­TIVE­DATE
Date
8
Mandatory
The rule effective date for which Fund delivery instruction infor­mation for the fund has to be maintained.
Docu­mentDe­scription
Alphanu­meric Code
255
Optional
Captured only if the KYCAML parameter is set to True.
Used for captur­ing the document description.
Serial Number: 18
Segment Identification Number: 18MLD
Description: This segment is used for capturing the information in multiple languages against the language codes.
Field Name
Type
Maximum Length
Description
SEG­MENTID
Alpha­numeric
20
Mandatory
Default value 18MLD
Standard value of 18MLD is to uniquely identify multiple lan­guages.
PRO­CESSID
Alpha­numeric
50
Mandatory
FUNDID
Alpha­numeric
6
Mandatory
RULEEFFEC­TIVE­DATE
Date
8
Mandatory
Lan­guage­Code
Alpha­numeric Code
12
Optional
Used for capturing the information in multiple lan­guages against the language code.
Fund­Name
Alpha­numeric Code
60
Optional
Serial Number: 19
Segment Identification Number: 19FSI
Description: This segment is used for providing Fund Investment Account SI, if applicable
Field Name
Type
Maximum Length
MAXNOOFSITRANSACTIONS
NUMBER
4
Optional
MAXVALIDITY
NUMBER
4
Optional
Serial Number: 20
Segment Identification Number: 20HFP
Description: This segment is used for providing hedge fund parameters
Field Name
Type
Maximum Length
SegmentID
VARCHAR2
20
Mandatory
ProcessID
VARCHAR2
50
Mandatory
FundID
VARCHAR2
6
Mandatory
RuleEffectiveDate
DATE
7
Mandatory
HedgeFundType
VARCHAR2
1
Mandatory
HedgeFundManager
VARCHAR2
12
Mandatory
TxnGenerationBasis
VARCHAR2
1
Optional
MasterFundUHID
VARCHAR2
12
Optional
NoticePeriodforRed
NUMBER
5
Optional
ComputationMethod
VARCHAR2
4
Optional
RuleGroupID
VARCHAR2
10
Optional
PerformancefeePer
NUMBER
3
Optional
AccrualFrequency
VARCHAR2
1
Optional
NextAccrualDate
DATE
7
Optional
PaymentFrequency
VARCHAR2
1
Optional
NextPaymentDate
DATE
7
Optional
HurdleRateApplicable
VARCHAR2
1
Optional
HurdleType
VARCHAR2
1
Optional
ResetHurdle
VARCHAR2
1
Optional
HurdleRateType
VARCHAR2
1
Optional
CalculationMethod
VARCHAR2
1
Optional
DayBasis
VARCHAR2
1
Optional
RateCode
VARCHAR2
15
Optional
RateBasis
VARCHAR2
1
Optional
Rate
NUMBER
20
Optional
Serial Number: 21
Segment Identification Number: 21HFL
Description: This segment is used for providing hedge fund linkage details
Field Name
Type
Maximum Length
SegmentID
VARCHAR2
20
Mandatory
ProcessID
VARCHAR2
50
Mandatory
FundID
VARCHAR2
6
Mandatory
RuleEffectiveDate
DATE
7
Mandatory
LinkFundID
VARCHAR2
6
Mandatory
Percentage
NUMBER
3
Optional
Unit holder ID
VARCHAR2
12
Optional
Serial Number: 22
Segment Identification Number: 21HFD
Description: This segment is used for providing investor category details for hedge funds
Field Name
Type
Maximum Length
SegmentID
VARCHAR2
20
Mandatory
ProcessID
VARCHAR2
50
Mandatory
FundID
VARCHAR2
6
Mandatory
RuleEffectiveDate
DATE
7
Mandatory
InvestorCategory
VARCHAR2
25
Mandatory
PerformanceFeeR­ate
NUMBER
20
Mandatory
3.1.4 Fund Related Information Upload Segments Format
The upload file would contain various segment identification numbers in the first column to indicate the type of data that is present in that entire row. Each segment identified by a unique tag, indicates the type of Fund rule related information like Fund entity, Fund calendar and Fund Agency Branch Back-dating limit.
Description
00GEN
This segment is used for providing information that is common to the other fund related rules that need to be uploaded in the system.
Mandatory and will be the driving header segment for all the other segments.
No
01FEM
This segment is used for providing Fund entity related information that needs to be uploaded in the system for the Fund.
Optional
Yes [For various entity types and entity ids]
02FAB
This segment is used for providing Fund agency branch back-dating informa­tion that needs to be uploaded in the system for the Fund.
Optional
Yes [For various transaction types]
03FBC
This segment is used for providing Fund based cal­endar related information that needs to be uploaded in the system for the Fund.
Optional
Yes [For various years]
3.1.4.1 Fund Related Information Segments Formats
Serial Number: 1
Segment Identification Number: 00GEN
Description: This segment is used for providing information that is common to the other fund related rules that need to be uploaded in the system.
Segment Mandatory / Optional?: Mandatory and will be the driving header segment for all the other segments.
Multiple records allowed for the same Fund and Rule Effective Date: No
Field Name
Type
Maximum Length
Description
PROCES­SID
Alphanu­meric
50
Mandatory
BULKCLI­ENT­CODE
Alphanu­meric
12
Mandatory
Valid authorized, enabled Bulk cli­ent codes main­tained in the system as a part of Entity mainte­nance.
IMPORT­FILE­NAME
Alphanu­meric
255
Mandatory
This is the name of the file being uploaded into the FCIS system
AMCID
Alphanu­meric
12
Mandatory
Valid authorized, enabled AMC maintained in the system as a part of Entity mainte­nance. The fund rule upload defaulting would be based on both AMCID and the Bulk client code.
USERID
Alphanu­meric
15
Mandatory
The fund rule MakerID would have the value of UserID as a part of data storage in all the fund rule tables.
UPLOAD­MODE
Alphanu­meric
1
Mandatory
Valid values are 'N' and 'I'
Should be 'N' for New fund rule. And ‘I’ for Amending an existing author­ized fund rule.
GENERA­TEAUTH­FUNDRULE
Alphanu­meric
1
Optional
Valid values are 'A' and 'U'
This indicates whether the fund rule uploaded should be a authorized fund rule or un-author­ized fund rule.
Serial Number: 2
Segment Identification Number: 01FEM
Description: This segment is used for providing Fund entity related information
Segment Mandatory / Optional: Optional
Multiple records allowed for the same Fund and Rule Effective Date: Yes (For various entity types and entity IDs)
Field Name
Type
Maximum Length
Mandatory/Optional?
Description
SEG­MENTID
Alpha­numeric
20
Mandatory
Default value 01FEM
Standard value of 01FEM to uniquely identify Fund entity information
PRO­CESSID
Alpha­numeric
50
Mandatory
FUNDID
Alpha­numeric
6
Mandatory
Depending upon the scheme cross reference maintained at the Bulk client defaults - this field value could either be FundID, Fund Identification number or Fund ticker symbol.
The Fund ID is a unique Identification for each Fund in the system. Enter the fund for which a Fund entity map­ping needs to be maintained.
ENTITY­TYPE
Alpha­numeric
2
Optional
Valid values are - 'A' for Agent; 'Q' for Check Ven­dor;'U' for Investor, 'L' for Clearing Agent; 'IC' for Individual cus­tomer cate­gory and 'CC' for Corporate customer cate­gory
The entity type for which the fund is mapped. This helps us to understand whether it is a Fund-Agent map­ping, Fund-Check Vendor mapping, Fund-Clearing Agent mapping, Fund-Investor map­ping, Fund-Individ­ual category mapping or Fund - Corporate category mapping
ENTIT­YID
Alpha­numeric
12
Optional
Valid entity ID maintained in the system as a part of Single entity mainte­nance for the respective entity type.
The Entity ID which belongs to the entity type specified
DISA­BLE
Number
1
Optional
This is to indicate whether the defini­tion should be disa­bled or enabled.
RESTRICTIVEL­IST
Number
1
Optional
Indicates whether the mapping is a positive list or nega­tive list. The value of '1' indicates that it is a negative list and vice versa.
DEFAULTOP­TION
Alpha­numeric
15
Optional
Valid values are null, 'BULKCLIENT­CODE' or any valid Fund Id available in the system.
* If the default option is null, then all values provided by the user for entity type, entity id and Restrictive list should be used. * If the value 'BULK­CLIENTCODE' is mentioned, then default the informa­tion based on the bulk client code mentioned as a part of header segment. * If any other Fund ID value is men­tioned, then default values based on the latest available record for the Fund mentioned.
UPLOADMODE
Alpha­numeric
1
Optional
Valid values are null, 'N' and 'I'. This is to override the value men­tioned as a part of header segment.
Should be 'N' for New fund rule. And ‘I’ for Incremental for Amending an existing authorized fund rule.
GENER­ATEAU­THFUNDRULE
Alpha­numeric
1
Optional
Valid values are null, 'A' and 'U'. This is to override the value men­tioned as a part of header segment.
This indicates whether the fund rule uploaded should be a author­ized fund rule or un-authorized fund rule.
Serial Number: 3
Segment Identification Number: 02FAB
Description: This segment is used for providing Fund agency branch back-dated related information
Segment Mandatory/Optional: Optional
Multiple records allowed for the same Fund and Rule Effective Date: Yes (For various transaction types)
Field Name
Type
Maximum Length
Mandatory/Optional?
Description
SEG­MEN­TID
Alpha­numeric
20
Mandatory
Default value 02FAB
Standard value of 02FAB to uniquely identify Fund agency branch back-dating limit information
PRO­CES­SID
Alpha­numeric
50
Mandatory
FUN­DID
Alpha­numeric
6
Mandatory
Depending upon the scheme cross reference main­tained at the Bulk client defaults - this field value could either be FundID, Fund Identification number or Fund ticker symbol.
The Fund ID is a unique Identifica­tion for each Fund in the system. Enter the fund for which a Fund agency branch back-dated limit needs to be main­tained.
AGENTCODE
Alpha­numeric
12
Optional
Valid agent as a part of entity maintenance
Valid entity id in the system for which entity type is 'A'
AGEN­CYBRANCH­CODE
Alpha­numeric
12
Optional
Valid agency branch as a part of entity maintenance
Valid entity id in the system for which the parent code is Agent code men­tioned in the previ­ous column
TRANSACTIONTYPE
Alpha­numeric
2
Optional
Valid values are '01' for IPO; '02' for Subscrip­tion; '03' for Redemption and so on.
Transaction type for which back-dat­ing limit is main­tained. Valid values are '01' to '10' rang­ing from IPO to Re-issue
BACK­DAT­INGPERIOD
Number
Optional
Back dating limit in days
DISA­BLE
Number
1
Optional
DEFAULTOP­TION
Alpha­numeric
15
Optional
Valid values are null, 'BULKCLI­ENTCODE' or any valid Fund Id available in the system.
* If the default option is null, then all values provided by the user for entity type, entity id and Restrictive list should be used. * If the value 'BULK­CLIENTCODE' is mentioned, then default the informa­tion based on the bulk client code mentioned as a part of header seg­ment. * If any other Fund ID value is mentioned, then default values based on the latest available record for the Fund men­tioned.
UPLOADMODE
Alpha­numeric
1
Optional
Valid values are null, 'N' and 'I'. This is to over­ride the value mentioned as a part of header segment.
GEN­ERA­TEAUTHFUN­DRULE
Alpha­numeric
1
Optional
Valid values are null, 'A' and 'U'. This is to over­ride the value mentioned as a part of header segment.
This indicates whether the fund rule uploaded should be an authorized fund rule or un-author­ized fund rule.
Serial Number: 4
Segment Identification Number: 03FBC
Description: This segment is used for providing Fund based calendar information
Multiple records allowed for the same Fund and Rule Effective Date: Yes (for various years)
Field Name
Type
Maximum Length
Mandatory/Optional?
Description
SEG­MEN­TID
Alpha­numeric
20
Mandatory
Default value 03FBC
Standard value of 03FBC to uniquely identify Fund agency branch back-dating limit information
PRO­CES­SID
Alpha­numeric
50
Mandatory
This should identify the upload uniquely. This should also be unique within a file and it allows to iden­tify imported records later
FUN­DID
Alpha­numeric
6
Mandatory
The Fund ID is a unique Identification for each Fund in the system. Enter the fund for which a Fund agency branch back-dated limit needs to be maintained.
YEAR
Number
4
Optional
The year for which the calendar need to be maintained for the fund.
DEFAULTOPTION
Alpha­numeric
15
Optional
* If the default option is null, then all values provided by the user for entity type, entity id and Restrictive list should be used. * If the value 'BULKCLI­ENTCODE' is men­tioned, then default the information based on the bulk client code mentioned as a part of header segment. * If any other Fund ID value is mentioned, then default values based on the latest available record for the Fund mentioned.
UPLOADMODE
Alpha­numeric
1
Optional
GEN­ERA­TEAUTHFUNDRULE
Alpha­numeric
1
Optional
This indicates whether the fund rule uploaded should be a authorized fund rule or un-authorized fund rule.
3.1.5 EPU Upload File Format
EPU upload is specific to OMSTA, as the assumption is that OMSTA maintains the following components and those component names are hard-coded in DIVIDENDEPUIMPTBL:
Field Name
Data Type
Remarks
Fund Id
Char (3)
The fund id in FCIS.
Distribution Type
Char (1)
This field will be ignored and the dividend type in FCIS will be treated as cash dividend.
Gross Or Net Distribu­tion
Char (1)
This field will be ignored.
Declaration Date
Date
The interface will verify if there is any generated cash dividend record for this date, and will update that record with the required EPU.
Payment Date / Re-investment Date
Date
This field will be ignored by the interface.
Gross Amount
Float
This will be a dividend component. Component code ‘GA’.
Dividend Amount
Float
This will be a dividend component. Component code ‘DA’.
Dividend Amount For­eign
Float
This will be a dividend component. Component code ‘AF’.
Dividend Amount For­eign Withholding Tax
Float
This will be a dividend component. Component code ‘WF’.
Dividend Amount For­eign Exempt
Float
This will be a dividend component. Component code ‘EF’.
Interest Amount
Float
This will be a dividend component. Component code ‘IA’.
Interest Amount Local
Float
This will be a dividend component. Component code ‘IL’.
Interest Amount For­eign
Float
This will be a dividend component. Component code ‘IF’.
Interest Amount For­eign Withholding Tax
Float
This will be a dividend component. Component code ‘TF’.
NPI Amount
Float
This will be a dividend component. Component code ‘NP’.
Interest Withheld Tax Amount
Float
This will be a dividend component. Component code ‘IT’.
Property Dividend Amount
Float
This will be a dividend component. Component code ‘PD’.
3.1.6 Tax Aggregation Interface Format
The formats for export and import of files for transfer of tax information are given below. This is applicable to annuity taxes only.
The Record Specifications for the export file containing tax is as follows:
Field Name
Description
Data Type
Remarks
Tax Year
The tax year applicable –format – ddmmccyy
Number (8)
This will be set to the last day of the fiscal year in he required format.
LOB
Line of Business code – ‘GAL’
String (3)
Will be set as ‘GAL’.
Agree­ment_Code
Contract number
Char (12)
Policy number
Pro­duct_Code
Product Code
Char (10)
Product code.
Sequence
Numeric Count
Number (4)
Record number, incremented sequentially.
Owner_­Client_Id
Client Number or owner of the contract
Char (9)
The unitholder id.
Title
Null
Char (12)
This will be set to null.
Initials
Null
Char (15)
Surname
Null
Char (64)
IDNumber
Null
Char (15)
IDType
Null
Char (2)
DOB
Nulls
Char (10)
ClientType
‘N’ for naturals
Char (1)
Tax_Num­ber
Nulls
Char (12)
TRUST­NUMBER
Nulls
Char (12)
AnnuType
‘C’ for compulsory, ‘V’ for voluntary
Char (1)
This will be set to ‘C’.
GN18
‘Y’ or ‘N’
Char (1)
This will be set to ‘N’.
Fund­Name
The pension Fund Name
Char (70)
Fund Name
Frequency
Frequency of the annu­ity income
Char (1)
The frequency of the annuity.
Pay­ments_left
No of payments left within the tax year
Number (2)
The remaining number of annuities to be executed.
TaxEarn­ings_YTD
The taxable earning to date for the tax year.
Number (8,2)
The total annuity till date, including the tax already applied.
TaxDe­duct­ed_YTD
Tax deducted for the tax year
Number (8,2)
The tax deducted for the current fis­cal year.
TaxEarn­ings
Taxable earnings for this annuity income
Number (8,2)
TaxDe­ducted
Tax to be deducted for that annuity income
Number (8,2)
SystemId
The system ID as defined by the tax aggregation module.
Char (10)
This will be set to ‘FCIS’.
Scheme
Nulls
Char (30)
The control record for the export of information relating to tax has the following format:
Field Name
Description
Data Type
Remarks
Record
‘CONTROL’
Char (7)
This field will be set as ‘CONTROL’
SystemId
Char (10)
Will be set as ‘FCIS’.
Entries
Number of entries on the file
Num­ber (8)
The number of entries in the file.
TaxEarn­ings_YTD
Num­ber (13,2)
The sum of all the TaxEarn­ings_YTD in the file.
TaxDeduct­ed_YTD
The tax deducted for that tax year.
Num­ber (13,2)
The sum of all the TaxDe­ducted_YTD in the file.
TaxEarnings
The taxable earnings for this annuity income
Num­ber (13,2)
The sum of all the TaxEarn­ings in the file.
TaxDeducted
The tax to be deducted for that annuity income.
Num­ber (13,2)
The sum of all the TaxDe­ducted in the file.
Tax_Recalc
The tax amount that should be deducted
Num­ber (13,2)
Tax_Differ
The difference between what should be deducted and what was calculated by the product admin system.
Num­ber (13,2)
Monthly_Ad­just
Not applicable
The Record Specifications for the import of tax aggregation information into FCIS is as indicated below. The import will only log the data in the designated tables of FCIS. There is no processing carried out on the data imported.
Field Name
Description
Data Type
Remarks
GCS_CLNO
The group client id
Char (20)
TaxYear
The tax year applicable in dd/mm/ccyy format
Char (8)
TaxMonth
Month of the year
Char (2)
PARM
ProductCode
Char (8)
Agreement_Code
Contract Number
Char (12)
The policy number.
Sequence
Numeric Count
Char (4)
This fiekld will be ignored.
LOB
Line of Business – ‘GAL’
Char (3)
Owner_Client_Id
Client Number or Owner of the contract
Char (9)
The unitholder id in FCIS.
Tax_Number
Nulls
Char (12)
TrustNumber
Nulls
Char (16)
AnnuType
‘C’ for compulsory, ‘V’ for volun­tary
Char (1)
GN18
‘Y’ or ‘N’
Char (1)
FundName
Nulls
Char (30)
Frequency
Frequency of the annuity income
Char (1)
Payments_Left
Char (2)
TaxEarnings_YTD
Char (16)
TAXDEDUCT­ED_YTD
Char (16)
TaxEarnings
Char (16)
TaxDeducted
Tax to be deducted for that annu­ity income
Char (16)
Scheme
Nulls
Char (10)
Tax_Recalc
Tax amount that should be deducted
Char (16)
Tax_Deffer
Char (16)
Monthly_Adjust
Not applicable
Char (16)
SystemId
Char (10)
Tax_Remunera­tion
The total taxable income across the Old Mutual group.
Char (16)
The Control Record for the import of information pertaining to tax aggregation should be in the following format:
Field Name
Description
Data Type
Remarks
Record
‘CONTROL’
Char (7)
SystemId
The system ID as defined by the tax aggre­gation module.
Char (10)
Entries
Number (8)
TaxEarn­ings_YTD
Number (13,2)
TaxDeduct­ed_YTD
Number (13,2)
TaxEarnings
Number (13,2)
TaxDeducted
Number (13,2)
Tax_Recalc
Number (13,2)
Tax_Differ
Number (13,2)
Monthly_Ad­just
Not applicable
3.1.7 Agent Reference File
The files uploaded using the Agent Reference File have to be imported and the broker details updated. They should have the following format:
Field Name
Format
Comments
Remarks/ Mapping
Intermediary or Broker Code
Char 10
Intermediary Code and No
Broker Code
Broker Category
Char 1
Corporate/ Individual
Broker Category
Broker Name
Char 50
Individual name or corporate name
Broker Name
Broker Type
Char
For example, Platinum, Gold, Silver
Broker Type
Parent Broker
Char
Channel – For example, PFA, BD
Parent Broker Code
Active Flag
Char
Y/N
Broker Enabled
Date Effective
Date
Rule effective date
Control Record
The sum of the transaction amount for each day is recorded in the Control Record. The file upload should have the following format:
Field Name
Description
Data Type
OMUT Value
Galaxy Value
RECORD_ID
Indicates it’s the trailer record
Char (50)
All 9s
All 9s
GROUP_ID
Unique Group Number to distin­guish import data within a source
Char (15)
Source file id & run number
TOTAL_AMT_DR
Total monetary amount of debits on the file
Char (15)
Format: 999999999999.99'
TOTAL_CNT_DR
Total count of debits on the file
Char (8)
Format: 99999999
Format: 99999999
TOTAL_AMT_CR
Total monetary amount of credits on the file
Char (15)
TOTAL_CNT_CR
Total count of cred­its on the file
Char (8)
Format: 99999999
Format: 99999999
3.1.8 Global Order Placement Interface
Files uploaded using the Global Order Placement should have the following format:
Field Name
Calculation
Disinvestments
Investments
Transaction Date
N/A
Transaction Date
Transaction Date
Asset Code
For each Product – Fund combination, an asset code would be maintained
Yes
Yes
Fund Name
N/A
Yes
Yes
Product Name
N/A
Yes
Yes
Net Investment Amount (Amount with +ve sign)/ Disinvestment Amount(Amount with -ve sign)
Derived
0
Yes
Disinvestment Units
N/A
Yes
0
Manco Initial Unit Trust Fee
N/A
0
Yes
Transaction Type Name
Transaction Descrip­tions as available in the system
Yes
Yes
Internal Reference Number
Running serial per batch
Yes
Yes
3.1.9 GL Setup Upload Interface Format
Files uploaded using the GL Setup Upload should have the following format:
Field Name
Data Type
Details
Fund Id
Character(6)
GL Template Id
Character(10)
The template Id of the GL set up. A dummy value to be provided for this.
Account type
Character(2)
The account type of the GL set up.
Business Event
Character(2)
One of the valid codes for business events.
Trigger Event
Character(15)
The triggering event. One of the valid enu­merations for the triggering event.
Theoretical Flag
Character (1)
Y: Theoretical N: Actual
Setup Enabled
Character (1)
Y: Enabled N: Disabled
Component Id
Character(20)
Component Description
Character (255)
Description of the component code.
Debit credit Flag
Character(2)
Dr: Debit Cr: Credit
GL set up for primary
Character(1)
C: CASA G:GL S:SAP P:Payment
Primary Entity Type
Character(1)
The primary entity type of the GL set up. U: Uniholder D:Distributor M:AMC F:Fund
Account Number
Character(16)
AccountCurrency
Character(3)
Transaction Currency
Character(3)
Bank branch
Character(12)
Direct DebitApplicable
Character(1)
1: Applicable 0: Not applicable
GL setup for Contra
Character(1)
Contra Primary Entity Type
Character(1)
Contra Account Number
Character(16)
Contra Account Currency
Character(3)
Contra Transaction Cur­rency
Character(3)
Contra Bank branch
Character(12)
Contra Direct DebitAppli­cable
Character(1)
Restricted reference types
Character(255)
A semicolon separated list of the restricted reference types.
GL Currency
Character(3)
GL reference number
Character(10)
Product Id
Character(10)
Product or Fund Level
Character(1)
F: Fund Level P: Product level
Mode of upload
Character(1)
N: new mode A: Amend mode
3.1.10 Interface to Check for Transaction Unrelated to GL Extraction
Files uploaded for checking the transaction unrelated to GL Extraction Interface should have the format mentioned below:
Field Name
Data Type
Details
IFaceRefNo
Charac­ter(25)
The reference number of the entry in the AMInter­facemasterTbl.
TransactionType
Character(2)
The transaction type of the entry.
Component
Charac­ter(20)
The component code of the entry.
TransactionNum­ber
Charac­ter(16)
The transaction number of the missing entry.
Valuedate
Date
The date on which the entry was expected to be passed.
3.1.11 File Format for OMIPAY FILE INTERFACE
The interface is capable of exporting the details in two separate formats. These are:
The system extracts commission details for upfront and trailer (periodic load) commission.
3.1.12 File format for Header Record
The File format for the Header Record is as follows:
Field Name
Data Type
Details
Record Category
Number
It is displayed as 00
Trigger System
Character
Ensures the entries which require to be entered for calculation of Commission
Product Provider
Character
The code for which the file is processed to cal­culate commission. For example Unit Trust ‘UT’
Cycle Number
Number
The number of the cycle for which the export action is being processed
Interface Date
Number
The date of generation of the interface file
Number Of Transaction Records (01 Category)
Number
Total Number of transaction records on input file
Commission Total
Number
The total value of Premium amount on the Input File
Commission Allowance Total
Number
Value of Commission Allowance amounts on the Input File
Fund Value Total
Number
The total value of Fund Value amounts on the Input File
Current Potential Com­mission
Number
Applicable to recurring business only
Future Potential Commis­sion
Number
Numeric Field 11
Number
Provide preceding zeros as 0000000
3.1.13 File format for Detailed Record
The Detail Record File format is the record of all the Broker details, involved in all the transactions for that day, taken individually. The file containing the Detailed records for all the individual Brokers. The file format used for Detailed records is:
Field Name
Data Type
Details
Record Category
Number
Transaction Sequence Number
Number
Unique identifier of transaction in the source external interface
Product Provider
Character
The code for which the file is processed to calcu­late commission. For example Unit Trust ‘UT’
Cycle Number
Number
Preceded by zeros
Intermediary Code (Sales Code)
Number
The intermediary’s sales code as supplied on the policy proposal / application form. It consists of six digits preceded by zeros
Intermediary Type (Sales Type)
Number
Code for the intermediary who has initiated the sale of that policy;
0 is for the Sales Staff
1 is for the Office staff
Intermediary Commis­sion Percentage (Direct Share)
Number
The percentage of commission as indicated in the policy/ application form
Intermediary Figure Percentage (Indirect Share)
Numeric
The percentage of indirect commission as indi­cated in the policy/ application form
Sales Centre (branch / team structure code)
Character
An optional field
Sale Type
Character
Not applicable can be left blank
Policy Number (Con­tract Number)
Character
It is the Policy or Contract number
Policy Type (Contract Type)
Character
Only applicable for recurring business types, can be left blank
Policy Term
Number
It is applicable for recurring business only, default set at 01
Product Code
Character
The selection is available from a drop down list
Premium Amount
Number
The amount of the premium for a transaction
Premium Frequency
Character
You can select from a list, for the type of premium applicable
Premium Term
Number
The term for which the premium is applicable
Movement Code
Number
It is the number code for the type of transaction
Transaction Date
Number
The date on which the transaction takes place
Entry Date
Number
The date from which the new business/policy is started
Effective Date
Number
The date from which the policy becomes effective
Client or Entity Number
Character
It is an optional field
Client Name
Character
The name as mentioned in description
Fees
Character
Optional field
Commission Amount 01
Number
The commission amount for 1 year
Commission Amount 02
Number
The commission amount for the 2nd year
Life Credit
Character
Not mandatory can be left blank
Commission Year Indi­cator
Number
It indicates the year for which the commission is applicable
Commission Content
Number
It contains the commission amount for the two years
Commission Scaling Factor
Number
The amount agreed between the client and the broker
Commission Frequency
Character
It is optional, left blank
Commission Type
Character
This field is left blank
Current Potential Com­mission (Primary)
Number
It is applicable for only recurring business, input display shows 000000000000000
Future Potential Com­mission (Secondary)
Number
VAT
Number
It is the value added tax, not required as input
Broker Reference
Character
It is the reference as specified on the application form
Currency Indicator
Character
It indicates the currency type selected
Agents Commission
Number
It is not applicable in this case, displayed as 000000000000000
Number
It is the waiver amount on the broker’s commis­sion
New Business Date
Number
It is the transaction date
Total Investment
Number
It is the total amount of investments
Investment Type
Character
An optional field can be left blank
Fund Value
Number
It is the sum of the average of the absolute values of the fund of the client
Layer type
Character
Layer Number
Number
This field displays 00
Reject ID
Number
This field is not required for entry, it displays 00000000
Adjustment Indicator
Character
This field is not required for entry and is left blank
Territory
Character
Annual Fund Total
Number
This field is not required for entry, it displays 000000000000000
Distribution Fee (Chan­nel)
Number
Maximum Commission
Number
Instance Number
Character
BEN Type
Character
EMM Client Number
Character
Sales Instance
Number
Transaction Instance
Number
3.2 Incremental Upload Format
For Incremental mode, the system will modify data present in upload file. If data provided in the file is already present, then the system will override existing data with new value provided in the file. If data is not present in system, then the data provided in the file will be added.
The system will not change/replace data which is not available in file for incremental mode. for instance, in unit holder upload, if only telephone number is given in Incremental mode, the system will just update old phone number with new phone number without changing other fields.
The upload file would contain various segment identification number in the first column to indicate the type of data that is present in that entire row. The possible segments that would be used in Incremental upload are given below for reference:
Upload Type
Use Case
Description
Upload mode
Segments to be used in Incremental upload
Entity
Contact details update
Cell phone number to be made available in upload file
I
00EIM,02ECI
Entity
E-mail to be made available in upload file
I
00EIM,02ECI
Entity
Bank details Update
BANKCODE,BRANCH­CODE,ACCOUNT­TYPE,ACCOUNTNUMBER,ACCOUNTNAME,ACCOUNT­CURRENCY,DEFAULTDE­TAILS,DIRECTDEBITAPPLICABLE to be made available in upload file.If default flag is set as Yes, default flag for existing bank detail for same bank/branch/account type/account currency combination will be set as No
I
00EIM,01EBD
Broker
I
00BRO,01CON
Broker
email number to be made avail­able in upload file
I
00BRO,01CON
Broker
Bank details Update
I
00BRO,02BAN
Unitholder
Address update
Address1,2,3,4,zip code, coun­try code to be made available in upload file
I
00UH,15CON
Unitholder
Address update
Address line to be made availa­ble in upload file
I
00UH,15CON
Unitholder
Address update
Address type along with Address1,2, city, country & BIC code to be made available in upload file
I
00UH,15CON
Unitholder
I
00UH,15CON
Unitholder
email to be made available in upload file
I
00UH,15CON
Unitholder
Bank details Update
Beneficiary details to be made available in upload file
I
00UH,03BNK
Unitholder
Bank details Update
I
00UH,03BNK
Unitholder
Address & bank details update
Alternate Address line 2 & ben­eficiary info details to be made available in upload file in respective segments
I
00UH,15CON,03BNK
Trans­action
Settlement details Update
Cheque number & cheque date to be made available in file
I
00CON,01SET
Trans­action
Paid Date and settled to be made available in file
I
00CON,01SET
Trans­action
TRANSFERACCOUNTCUR­RENCY,TRANSFERAC­COUNTNUMBER,TRANSFERACCOUNTTYPE,TRANSFER­BRANCHCODE,PAYMENT DATE,PAYMENT AMOUNT to be made available in file
I
00CON,01SET
Trans­action
SWIFTFORMAT,BANK­CHARGED,BENEFI­CIARY,BENEFICIARYADDRESS,BENEFICIARYBIC­CODE,BENEFICIAR­YACCTNO,BENEFICIARYCODE,BENEFICIARYINFO to be made available in file
I
00CON,01SET
3.3 Sub Service Upload Format
You can create subservice to support specific amendment requests. Using Amendment maintenance, you can create a subservice to modify only specific fields as per the modifiable fields given in maintenance.
The upload file would contain various segment identification number in the first column to indicate the type of data that is present in that entire row. The possible segments that would be used in sub service upload are given below for reference:
Upload Type
Use Case
Description
Sub service operation
Entity
Bank details Update
BANKCODE,BRANCH­CODE,ACCOUNT­TYPE,ACCOUNTNUMBER,ACCOUNTNAME,ACCOUNTCUR­RENCY,DEFAULTDE­TAILS,DIRECTDEBITAPPLICABLE to be made available in upload file.If default flag is set as Yes, default flag for existing bank detail for same bank/branch/account type/account currency combination will be set as No
ENTITY_­BANKDTLS
Broker
Bank details Update
BROKER_­BANKDTLS
Unitholder
Address update
Address1,2,3,4,zip code, country code to be made available in upload file
UH_CONDTLS
Unitholder
Bank details Update
UH_BNK­DTLS
Unitholder
Beneficiary details
Email to be made available in upload file
UH_BENDTLS
Unitholder
Intermediary details
complete intermediary segment details to be made available in upload file
UH_IN­MDTLS
Transaction
First segment is mandatory.Com­plete details to be provided for settlement segment
TXN_SET­DTLS
Transaction
Intermediary update
TXN_INT­DTLS
Transaction
Intermediary update
TXN_INT­DTLS
Unitholder
UH_IN­MDTLS
3.4 Entity Upload Format
The upload file would contain various segment identification number in the first column to indicate the type of data that is present in that entire row. The possible segments that would be used in entity upload are given below for reference:
Segment ID - 00EIM: This segment will be mandatory for incremental upload
Column Name
Mandatory fields in upload file for upload mode I
Modifiable fields in Incremental mode
Remarks
SEGMENTID
Yes
00EIM
PROCESSID
Yes
Unique
SEQUENCENUM­BER
Yes
Unique
BULKCLIENTCODE
Yes
Unique
IMPORTFILENAME
Yes
Unique
ENTITYID
Yes
Existing Entity ID
PARENTENTITY­FLAG
No
ENTITYNAME
No
ENTITYTYPE
Yes
Entity type belong­ing to Entity ID
PARENTENTITY
No
EFFECTIVEDATE
No
RECORDLINK
No
NEWENTITYNAME
No
NEWENTITYID
No
ENTITYBASECUR­RENCY
No
AUTH_STAT
Yes
UNIQUERECORD­NUMBER
No
MARKEDFORREIMP
No
ACCOUNTTYPES
No
ENTITYCATEGORY­TYPE
No
ENTITYCATEGORY
No
AMCID
No
SWITCHINGLOGIC
No
UHGENERATION­LOGIC
No
NATUREOFBUSI­NESS
No
SECTION
No
ENTITYSUBTYPE
No
CROSSBRANCHING
No
FUNDSPOWERIN­STALLED
No
CUSTOMERINTER­FACEKEY
No
ONLINEINTERFACE
No
WEEKENDBITS
No
AUTHORIZEDSIG­NATORY
No
LINKENTITYID
No
LINKENTITYTYPE
No
ALTLANGENTI­TYNAME
No
ALTLANGCONTACT­PERSON
No
ALTLANGAD­DRESS1
No
ALTLANGAD­DRESS2
No
ALTLANGCITY
No
ALTLANGSTATE
No
FINWAREPOSTING
No
CHANNELENTITY
No
MICRCODE
No
CHECK­ER_DT_STAMP
No
CHECKER_ID
No
COUNTRYOFBIRTH
No
COUNTRYOFDOMI­CILE
No
EIN
No
FATCACLASSIFICA­TION
No
FATCASTATUS
No
INCORPORATION­COUNTRY
No
MAKER_DT_STAMP
No
MAKER_ID
Yes
Valid id in system
MOD_NO
No
NATIONALITY
No
TAXCATEGORY
No
TAXCERTIFICA­TEEFFEDATE
No
TAXCERTIFICATE­EXPDATE
No
TAXCIRCLE
No
TAXID
No
UPLOADMODE
Yes
I
USINDICIAAVAILA­BLE
No
GIIN
No
No
ISAREFERENCENO
No
CURRENCY
No
MINISATRANSFERIN
No
MINISATRANSFER­OUT
No
FUNDSTRUCTAP­PLICABLE
No
AUTOSETTLE­SWITCH
No
SWIFTMSGLIST
No
ELECTRONICDEAL­FLAG
No
DEFAULTAGENCY­BRANCH
No
BENEFICIAR­YACCTNO
No
EMAILID
No
PHONENUMBER
No
Segment ID - 01EBD
Column Name
Remarks
SEGMENTID
Yes
01EBD
PROCESSID
Yes
Unique
SEQUENCENUMBER
Yes
Unique
BULKCLIENTCODE
No
ENTITYID
No
ENTITYTYPE
No
BANKCODE
Yes
If bank/branch/account type/account number/account currency combination pro­vided in file exists in system- other details will be updated.If does not exist, record will be inserted in system
BRANCHCODE
Yes
ACCOUNTTYPE
Yes
ACCOUNTNUMBER
Yes
ACCOUNTNAME
Yes
ACCOUNTCUR­RENCY
Yes
DEFAULTDETAILS
Yes
Yes
DIRECTDEBITAPPLI­CABLE
No
Yes
SWIFTFORMAT
No
Yes
BANKCHARGED
No
Yes
BENEFICIARY
No
Yes
BENEFICIARYADD1
No
Yes
BENEFICIARYADD2
No
Yes
BENEFICIARYADD3
No
Yes
BENEFICIARYBIC­CODE
No
Yes
BENEFICIAR­YACCTNO
No
Yes
BENEFICIARYCODE
No
Yes
BENEFICIARYINFO
No
Yes
INTERMEDIARY
No
Yes
INTERMEDIARYADD1
No
Yes
INTERMEDIARYADD2
No
Yes
INTERMEDIARYADD3
No
Yes
INTERMEDIARYBIC­CODE
No
Yes
INTERMEDIAR­YACCTNO
No
Yes
INTERMEDIARY­CODE
No
Yes
INTERMEDIARYINFO
No
Yes
FURTHERCREDIT­NAME
No
Yes
FURTHERCRED­ITACCTNO
No
Yes
REFERENCE1
No
Yes
REFERENCE2
No
Yes
IBAN
No
Yes
BENEFICIARYIBAN
No
Yes
INTERMEDIARYIBAN
No
Yes
Segment ID - 02ECI
Column Name
Remarks
SEGMENTID
Yes
02ECI
PROCESSID
Yes
Unique
SEQUENCENUMBER
Yes
Unique
BULKCLIENTCODE
No
ENTITYID
No
ENTITYTYPE
No
ADDRESSTYPE
Yes
If address type present in file is available in sys­tem, system will be updated with remaining details present in file.If Address type pres­ent in file is not available in sys­tem, new address type will be added with details as avail­able in file
ADDRESSLINE1
No
Yes
ADDRESSLINE2
No
Yes
ADDRESSLINE3
No
Yes
ADDRESSLINE4
No
Yes
ZIPCODE
No
Yes
COUNTRY
No
Yes
USSTATE
No
Yes
TELEPHONE1
No
Yes
TELEPHONE2
No
Yes
CELLPHONENUMBER
No
Yes
FAX
No
Yes
EMAIL
No
Yes
CONTACTPERSON
No
Yes
EFFECTIVEFROMDATE
No
Yes
EFFECTIVETODATE
No
Yes
BICCODE
No
Yes
INTDIALLINGCODEPH1
No
Yes
INTDIALLINGCODEPH2
No
Yes
INTDIALLINGCODE­CELL
No
Yes
INTDIALLINGCODEFAX
No
Yes
Segment ID - 05ADD
Column Name
Remarks
SEGMENTID
Yes
05ADD
SEQUENCENUMBER
Yes
Unique
PROCESSID
Yes
Unique
ADDINFOLABEL
Yes
FIELDVALUE
Yes
Yes
3.5 Broker Upload Format
The upload file would contain various segment identification number in the first column to indicate the type of data that is present in that entire row. The possible segments that would be used in Broker upload are given below for reference:
Segment ID - 00BRO: This segment will be mandatory for incremental upload
Column Name
Remarks
SEGMENTID
Y
00BRO
SEQUENCENUMBER
Y
Unique
PROCESSID
Y
Unique
BULKCLIENTCODE
Y
Unique
IMPORTFILENAME
Y
Unique
UPLOADMODE
Y
I
BROKERCODE
Y
Valid broker code
BROKERNAME
N
PARENTBROKERCODE
N
BROKERBASECCY
N
AMCID
N
AUTH_STAT
Y
U/A
DELETEDSTATUS
N
OVERRIDDENTAXPER­CENTAGE
N
MAKER_ID
Y
Valid maker id
MAKER_DT_STAMP
N
LEVELNUMBER
N
RULEEFFECTIVEDATE
Y
CHANGETYPE
N
VATREGISTERED
N
VATREGISTRATION­NUMBER
N
COMMISSIONPERCENT­AGE
N
COMMISSIONPAYMENT­FREQ
N
UNITHOLDERID
N
LASTPAYMENTDATE
N
LASTPAYMENTNUMBER
N
LASTPROCESSEDDATE
N
NEXTPAYMENTDATE
N
CHECKER_ID
N
CHECKER_DT_STAMP
N
BROKERTYPE
N
USEBROKERTYPEPAY­MENTDATES
N
BROKERCONSULTANT
N
BROKERCATEGORY
N
HOLDBACKPAYMENT
N
MOD_NO
N
HOLDPYMTFROMDATE
N
LATESTRULE
N
BROKERSTATUS
N
RECORD_STAT
N
ONCE_AUTH
N
REPLICATEPARENTDET
N
VATREGISTRATION­DATE
N
TEMPLATEID
N
USINDICIAAVAILABLE
N
FATCASTATUS
N
NATIONALITY
N
COUNTRYOFBIRTH
N
COUNTRYOFDOMICILE
N
INCORPORATIONCOUN­TRY
N
TAXID
N
EIN
N
TAXCERTIFICATEEFFE­DATE
N
TAXCERTIFICATEEXP­DATE
N
TAXCIRCLE
N
FATCACLASSIFICATION
N
GIIN
N
VATEXPIRYDATE
N
Segment ID -01CON
Column Name
Remarks
SEGMENTID
Y
01CON
SEQUENCENUMBER
Y
Unique
PROCESSID
Y
Unique
ENTITYID
N
ENTITYTYPE
N
ADDRESSTYPE
Y
If address type present in file is available in sys­tem, system will be updated with remaining details present in file.If Address type pres­ent in file is not available in sys­tem, new address type will be added with details as available in file
ADDRESSLINE1
N
Y
ADDRESSLINE2
N
Y
ADDRESSLINE3
N
Y
ADDRESSLINE4
N
Y
ZIPCODE
N
Y
COUNTRY
N
Y
USSTATE
N
Y
TELEPHONE1
N
Y
TELEPHONE2
N
Y
CELLPHONENUMBER
N
Y
FAX
N
Y
EMAIL
N
Y
CONTACTPERSON
N
Y
EFFECTIVEFROMDATE
N
Y
EFFECTIVETODATE
N
Y
BICCODE
N
Y
RULEEFFECTIVEDATE
Y
Y
INTDIALLINGCODEFAX
N
Y
INTDIALLINGCODEPH2
N
Y
INTDIALLINGCODEPH1
N
Y
INTDIALLINGCODECELL
N
Y
Segment ID -02BAN
Column Name
Remarks
SEGMENTID
Y
02BAN
SEQUENCENUMBER
Y
Unique
PROCESSID
Y
Unique
BROKERCODE
N
RULEEFFECTIVEDATE
Y
REFERENCENUMBER
N
BANKCODE
Y
If bank/branch/account type/account number/account ccy combi­nation provided in file exists in sys­tem- other details will be updated.If does not exist, record will be inserted in system
BRANCHCODE
Y
ACCOUNTTYPE
Y
ACCOUNTNUMBER
Y
ACCOUNTNAME
Y
ACCOUNTCURRENCY
Y
DEFAULTDETAILS
Y
Y
DIRECTDEBITAPPLICA­BLE
N
Y
SWIFTFORMAT
N
Y
BANKCHARGED
N
Y
BENEFICIARY
N
Y
BENEFICIARYADD1
N
Y
BENEFICIARYADD2
N
Y
BENEFICIARYADD3
N
Y
BENEFICIARYBICCODE
N
Y
BENEFICIARYACCTNO
N
Y
BENEFICIARYCODE
N
Y
BENEFICIARYINFO
N
Y
INTERMEDIARY
N
Y
INTERMEDIARYADD1
N
Y
INTERMEDIARYADD2
N
Y
INTERMEDIARYADD3
N
Y
N
Y
INTERMEDIARYACCTNO
N
Y
INTERMEDIARYCODE
N
Y
INTERMEDIARYINFO
N
Y
FURTHERCREDITNAME
N
Y
N
Y
REFERENCE1
N
Y
REFERENCE2
N
Y
IBAN
N
Y
BENEFICIARYIBAN
N
Y
INTERMEDIARYIBAN
N
Y
Segment ID - 05ADD
Column Name
Remarks
SEGMENTID
Y
05ADD
SEQUENCENUMBER
Y
Unique
PROCESSID
Y
Unique
OTHERINFOFIELD
Y
FIELDVALUE
N
Y
3.6 Unit Holder Upload Format
The upload file would contain various segment identification number in the first column to indicate the type of data that is present in that entire row. The possible segments that would be used in Unit Holder upload are given below for reference:
Segment ID - 00UH: This segment will be mandatory for incremental upload
Column Name
Remarks
SEGMENTID
YES
00UH
SEQUENCENUM­BER
YES
Unique
PROCESSID
YES
Unique
BULKCLIENTCODE
YES
Unique
IMPORTFILENAME
YES
Unique
AMCID
YES
UPLOADMODE
NO
I
CIFNUMBER
NO
UNITHOLDERID
Yes
REFERENCENUM­BER
NO
ACCOUNTOPEN­INGDATE
NO
TITLE
NO
FIRSTNAME
NO
MIDDLENAME
NO
LASTNAME
NO
ACCOUNTOPERA­TIONTYPE
NO
FIRSTNOMINEE
NO
SECONDNOMINEE
NO
THIRDNOMINEE
NO
FATHER_SPOUSENAME
NO
INVESTORTYPE
NO
TAXDEDUCTEDAT­SOURCE
NO
TAXID
NO
TAXCIRCLE
NO
IDENTIFICATION­TYPE
NO
IDENTIFICATION­NUMBER
NO
IDENTIFICATIONIS­SUEDATE
NO
IDENTIFICATION­EXPIRYDATE
NO
RESIDENTSTATUS
NO
UHCATEGORY
NO
ACCOUNTSTMT­FREQ
NO
YTDSTMTREQD
NO
DATEOFBIRTH
NO
GUARDIANNAME
NO
RELATIONSHIP
NO
BENEFICIARY
NO
SEX
NO
MARITALSTATUS
NO
OCCUPATION
NO
NATIONALITY
NO
COUNTRYOFDOMI­CILE
NO
CORPORATION­TYPE
NO
FIRSTAUTHOR­IZEDSIGNATORY
NO
SECONDAUTHOR­IZEDSIGNATORY
NO
THIRDAUTHOR­IZEDSIGNATORY
NO
CONTACTNAME
NO
MINNOOFCORPO­RATESIGNATORY
NO
SCHEMECROSS­REFNO
NO
UHBASECUR­RENCY
NO
LANGUAGE
NO
REDEMPTIONMOP
NO
ACCOUNTSTMT­CURRENCY
NO
EMAILID
NO
FIRSTJOIN­TUHNAME
NO
SECONDJOIN­TUHNAME
NO
THIRDJOIN­TUHNAME
NO
ALTADDRESS­FROMDATE
NO
ALTADDRESSTO­DATE
NO
TELEPHONERED
NO
TELEPHONESWI
NO
WRITECHECK­FORMMF
NO
FEDWIREACHPAY­MENT
NO
IRSNOTIFICATION
NO
ROAINVESTOR
NO
ALLOWROAATCI­FLEVEL
NO
UHACCOUNTTYPE
NO
RPOCODE
NO
REGISTRATION­TYPE
NO
REGISTRATION­NAME
NO
ACCOUNTOPEN­INGPURPOSE
NO
REMARKS
NO
PREFERRED­MAILMODE
NO
NOTEPADAVAILA­BLE
NO
FEECATEGORY
NO
FEESUBCATE­GORY
NO
AGENTCODE
NO
BRANCHCODE
NO
MAKER_ID
Yes
MAKER_DT_STAMP
NO
CHECKER_ID
NO
CHECK­ER_DT_STAMP
NO
AUTH_STAT
Yes
STOPACCOUN­TREASON
NO
RELEASEDATE
NO
ALLSIGNATORIES­REQDTOSIGN
NO
TAXEXEMPTED
NO
INDEXATIONON­CGT
NO
CERTDELIVERY­PREF
NO
TEMPLATEID
NO
EFFECTIVEDATE
NO
CELLPHONENUM­BER
NO
PRIMARYCOUN­TRYCODE
NO
ALTCELLPHONE­NUMBER
NO
ALTHOMEPHONE­NUMBER
NO
ALTOFFICEPHONE­NUMBER
NO
ALTEMAILID
NO
SECONDARY­COUNTRYCODE
NO
PLACEOFISSUE
NO
ALTCONTACTNAME
NO
ALTFAXNUMBER
NO
PREFERREDFUND­FORREDEMPTION
NO
GUARDIANPAN­GIRNO
NO
GUARDIAN­FORM6061
NO
PRIMARYUH­FORM6061
NO
UNITHOLDERNRI
NO
EUSDOPTION
NO
NO
PLACEOFBIRTH
NO
COUNTRYOFBIRTH
NO
FATFORNONFATF
NO
CHASINGDATE
NO
ADDNCOMMENTS
NO
ALLKYCRECEIVED
NO
RETAINTRADEACK
NO
RETAINCONTRACT­NOTES
NO
NOTREPORTKY­CREQ
NO
UHBICCODE
NO
ALTLANGFIRST­NAME
NO
ALTLANGMIDDLE­NAME
NO
ALTLANGLAST­NAME
NO
ALTLANGFIR­STAUTHSIGN
NO
ALTLANGSEC­ONDAUTHSIGN
NO
ALTLANGTH­IRDAUTHSIGN
NO
ALTLANGCON­TACTPERSON
NO
ALTLANGCORAD­DRESSLINE1
NO
ALTLANGCORAD­DRESSLINE2
NO
ALTLANGCORAD­DRESSLINE3
NO
ALTLANGCORAD­DRESSLINE4
NO
ALTLANGALTAD­DRESSLINE1
NO
ALTLANGALTAD­DRESSLINE2
NO
ALTLANGALTAD­DRESSLINE3
NO
ALTLANGALTAD­DRESSLINE4
NO
DATEOFCONTRI­BUTION
NO
TRANSFERDATE
NO
RETIREMENTAGE
NO
RETIREMENTDATE
NO
DATEOFDEATH
NO
DEATHCAUSE
NO
AREACODE
NO
DISPATCHDATE
NO
RETURNEDDATE
NO
PRIMARYUHMFIN
NO
GUARDIANMFIN
NO
RECOVERCGT
NO
PROCESSID1
NO
INITIALS
NO
KYCPURCHASE­LIMIT
NO
KYCANNUALDEBI­TORDERLIMIT
NO
CAMPAIGNCODE
NO
REDEMPTIONPAY­OUT
NO
DIVIDENDPAYOUT
NO
DUALNATIONALITY
NO
SUBSTANTIAL­STAYINUS
NO
NO
SECONDIDENTITY­TYPE
NO
SECONDIDENTITY­NUMBER
NO
SECONDISSUE­DATE
NO
SECONDEXPIRY­DATE
NO
SECONDPLA­CEOFISSUE
NO
TRAILCOMMPREF
NO
DUEDILI­GENCELEVEL
NO
REVIEWEDBY
NO
LASTREVIEWED­DATE
NO
CHASERID
NO
CHASINGMODE
NO
NAMESCHECKOP­TION
NO
NAMESCHECK­REMARKS
NO
ACCOUNTSTATE­MENT
NO
CONTRACTNOTES
NO
INVESTORRISK­LEVEL
NO
Segment ID - 03BNK
Column Name
Remarks
SEGMENTID
YES
03BNK
PROCESSID
YES
Unique
SEQUENCENUM­BER
YES
Unique
BANKCODE
YES
If bank/branch/account type/account num­ber/account ccy combination provided in file exists in sys­tem- other details will be updated.If does not exist, record will be inserted in sys­tem
BRANCHCODE
YES
ACCOUNTTYPE
YES
ACCOUNTNUMBER
YES
ACCOUNTNAME
YES
ACCOUNTCUR­RENCY
YES
DEFAULTDETAILS
YES
Y
If this is marked as Yes- the old bank/branch/account num­ber/account ccy combination will be marked as Default No.
DIRECTDEBITAP­PLICABLE
No
Y
ACCOUNTCATE­GORY
No
Y
INITIALS
No
Y
LASTNAME
No
Y
IDENTIFICATION­TYPE
No
Y
No
Y
STATUS
No
Y
IBAN
No
Y
REFERENCENUM­BER
No
Y
FUNDID
No
Y
TRANSACTION­TYPE
No
Y
SWIFTFORMAT
No
Y
BANKCHARGED
No
Y
BENEFICIARY
No
Y
BENEFICIARYADD1
No
Y
BENEFICIARYADD2
No
Y
BENEFICIARYADD3
No
Y
BENEFICIARYBIC­CODE
No
Y
BENEFICIAR­YACCTNO
No
Y
BENEFICIARY­CODE
No
Y
BENEFICIARYINFO
No
Y
INTERMEDIARY
No
Y
INTERMEDIARY­ADD1
No
Y
INTERMEDIARY­ADD2
No
Y
INTERMEDIARY­ADD3
No
Y
INTERMEDIARY­BICCODE
No
Y
INTERMEDIAR­YACCTNO
No
Y
INTERMEDIARY­CODE
No
Y
INTERMEDIARY­INFO
No
Y
FURTHERCREDIT­NAME
No
Y
No
Y
REFERENCE1
No
Y
REFERENCE2
No
Y
RELATIONSHIP
No
Y
BENEFICIARYIBAN
No
Y
INTERMEDIARY­IBAN
No
Y
Segment ID - 04INM
Column Name
Remarks
SEGMENTID
Y
04INM
PROCESSID
Y
Unique
SEQUENCENUM­BER
Y
Unique
ENTITYTYPE
Y
Existing inter­mediary in sys­tem will be replaced by one provided in file
ENTITYID
Y
Y
SPLITPERCENT
N
Y
DEFAULTINTERME­DIARY
N
Y
Segment ID - 02BEN
Column Name
Remarks
SEGMENTID
Y
02BEN
SEQUENCENUM­BER
Y
Unique
PROCESSID
Y
Unique
EXISTINGUHORCIF
Y
ADDRESSLINE1
N
Y
ADDRESSLINE2
N
Y
ADDRESSLINE3
N
Y
ADDRESSLINE4
N
Y
ZIPCODE
N
Y
COUNTRY
N
Y
EMAIL
N
Y
CONTACTPERSON
N
Y
COUNTRYOFDOM­ICILE
N
Y
IBAN
N
Y
BENEFICIARYID
Y
If benefeciary id is existing in sys­tem,details in file wil be used to modify the record.If benefe­ciary id is not available for UH, new benefeciary record will be cre­ated
BENEFICIARY­TYPE
Y
BENEFI­CIARYNAME
N
Y
This field will not be modifiable if existing UH or CIF field is yes
BENEFICIARYDOB
N
Y
BENEFICIARYRE­LATION
N
Y
BENEFICIARYGEN­DER
N
Y
BENEFICIARYID­TYPE
N
Y
BENEFICIARYID­NUMBER
N
Y
BENEFICIAR­YAWARD
N
Y
BENEFICIA­RYBANKCODE
N
Y
BENEFICIARY­BRANCHCODE
N
Y
BENEFICIAR­YACCTYPE
N
Y
BENEFICIAR­YACCNAME
N
Y
BENEFICIAR­YACCCCY
N
Y
ACCOUNTNUM­BER
N
Y
Segment ID - 07JNT
Column Name
Remarks
SEGMENTID
Y
07JNT
PROCESSID
Y
Unique
SEQUENCENUM­BER
Y
Unique
EXISTINGUHORCIF
Y
BENEFICIARYID
Y
If benefeciary id is existing in sys­tem,details in file wil be used to modify the record.If benefe­ciary id is not available for UH, new Joint UH record will be cre­ated subject to existing valida­tions
BENEFI­CIARYNAME
N
BENEFICIARYTYPE
Y
BENEFICIARYDOB
N
Y
BENEFICIARYGEN­DER
N
Y
BENEFICIARYP­ANNO
N
Y
BENEFICIARY­FORM60
N
Y
BENEFICIARYMFIN
N
Y
COUNTRYOFDOMI­CILE
N
Y
RECOVERCGT
N
Y
ADDRESSLINE1
N
Y
ADDRESSLINE2
N
Y
ADDRESSLINE3
N
Y
ADDRESSLINE4
N
Y
ZIPCODE
N
Y
COUNTRY
N
Y
EMAIL
N
Y
CONTACTPERSON
N
Y
USINDICIAAVAILA­BLE
N
N
Segment ID - 10ADD
Column Name
Remarks
SEGMENTID
Y
10ADD
SEQUENCENUM­BER
Y
Unique
PROCESSID
Y
Unique
ADDINFOLABEL
Y
FIELDVALUE
N
Y
Segment ID - 15CON
Column Name
Remarks
SEGMENTID
Y
15CON
PROCESSID
Y
Unique
SEQUENCENUM­BER
Y
Unique
UNITHOLDERID
N
REFERENCENUM­BER
N
ADDRESSTYPE
Y
If address type present in file is available in sys­tem, system will be updated with remaining details present in file.If Address type present in file is not available in system, new address type will be added with details as availa­ble in file
ADDRESSLINE1
N
Y
ADDRESSLINE2
N
Y
ADDRESSLINE3
N
Y
ADDRESSLINE4
N
Y
ZIPCODE
N
Y
COUNTRY
N
Y
USSTATE
N
Y
TELEPHONE1
N
Y
TELEPHONE2
N
Y
CELLPHONENUM­BER
N
Y
FAX
N
Y
EMAIL
N
Y
CONTACTPERSON
N
Y
EFFECTIVEFROM­DATE
N
Y
EFFECTIVETODATE
N
Y
BICCODE
N
Y
INTDIALLINGCO­DEPH1
N
Y
INTDIALLINGCO­DEPH2
N
Y
N
Y
INTDIALLINGCODE­FAX
N
Y
3.7 Transactions Upload Format
The upload file would contain various segment identification number in the first column to indicate the type of data that is present in that entire row. The possible segments that would be used in Transaction upload are given below for reference:
Segment ID - 00CON: This segment will be mandatory for incremental upload
Column Name
Remarks
SEGMENTID
Y
00CON
PROCESSID
Y
Unique
SEQUENCENUM­BER
Y
Unique
TXNSERIALNUM­BER
Y
Unique
BULKCLIENT­CODE
Y
Unique
IMPORTFILENAME
Y
Unique
AMCID
Y
UPLOADMODE
Y
I
TRANSACTION­NUMBER
Y
REFERENCENUM­BER
N
TRANSACTION­DATE
Y
UNITHOLDERID
N
REFUNITHOLDE­RID
N
AGENTCODE
N
BRANCHCODE
N
FUNDID
N
AMOUNT
N
PAYMENTMODE
N
CHEQUENUMBER
N
CLEARINGDATE
N
TRANSACTION­CURRENCY
N
TRANSACTION­MODE
N
UNITSAPPLIED
N
PERCENTAPPLIED
N
TOFUNDID
N
TOUNITHOLDERID
N
REFTOUNITHOLD­ERID
N
TRANSACTION­TYPE
Y
REFTYPE
N
REMARKS
N
CERTIFICATE
N
N
CIFNUMBER
N
TOCIFNUMBER
N
GROSSORNET
N
SUBPAYMENT­MODE
N
COMMUNICATION­MODE
N
POLICYNUMBER
N
PRODUCTID
N
LOIAPPLICABLE
N
REFFUNDID
N
REFTOFUNDID
N
ENTITYTYPE
N
ENTITYID
N
SETTLEMENT­DATE
N
DELIVERYOPTION
N
TRANSACTION­SUBTYPE
N
REVERSALCODE
N
CANCELINSTRUC­TION
N
FROMFUND­PRICEBASIS
N
TOFUNDPRICEBA­SIS
N
TXN_OR_PRICE_­DATE_FLAG
N
FROMPRICEDATE
N
TOPRICEDATE
N
SUBSCRIPTION­FUNDID
N
SUBSCRIPTION­PRICEBASIS
N
PAYMENTAL­LOWED
N
PROCESSID1
N
SUBSETTLE­MENTDATE
N
SUBPRICEDATE
N
BASECOST
N
EXCHANGERATE­DETAILS
N
DEALINGDATE
N
COMPLETION­DATE
N
EUSDOPTION
N
TODEALINGDATE
N
KYCCHASING­DATE
N
KYCRECEIVED
N
LOCKINPERIOD­FORGAIN
N
SWIINEXCHANG­ERATEAPPLIED
N
AUTOCLEARPRO­VISIONALBAL­ANCE
N
AUTOCLEARREIN­VESTMENTS
N
FEECURRENCY
N
MATURITYDATE
N
SUBSOURCEID
N
CERTSPILLOVER
N
ISSUED
N
BLOCKTXNNUM­BER
N
CPMFBONUSPER­CENT
N
CPMFCREDITLAG
N
RETAINAGEING
N
CAMPAIGNCODE
N
FXDEALDATE
N
FXVALUEDATE
N
MAKER_ID
Y
MAK­ER_DT_STAMP
N
CHECKER_ID
N
CHECK­ER_DT_STAMP
N
AUTH_STAT
Y
ORDERRE­CEIVEDDATE
N
TXNCATEGORY
N
ORDERRE­CEIVEDTIME
N
SOURCEID
N
LOADREFTYPE
N
KIIDRECEIVED
N
Segment ID - 01SET
Column Name
Remarks
SEGMENTID
Y
01SET
TXNSERIALNUM­BER
Y
Unique
SEQUENCENUM­BER
Y
Unique
PROCESSID
Y
Unique
BULKCLIENT­CODE
Y
Unique
IMPORTFILENAME
Y
Unique
AMCID
N
TRANSACTION­NUMBER
N
PRODUCTID
N
POLICYNUMBER
N
SYSREFERENCE­NUMBER
N
UNITHOLDERID
N
PAYMENTREFER­ENCENUMBER
N
PAYMENTMODE
N
SUBPAYMENT­MODE
N
PAYMENTCUR­RENCY
N
PAYMENTDATE
N
Y
PAYMENTAMOUNT
N
Y
BANKCHARGES
N
Y
PAY­MENTCHARGES
N
Y
EXCHANGERATE­SOURCE
N
Y
EXCHANGERATE
N
Y
PAYMENTFBCTX­NAMOUNT
N
PAYMENTALTER­NATEAMOUNT
N
SETTLEMENT­DUEDATE
N
Y
PAIDDATE
N
Y
AUTOSETTLE­MENT
N
Y
PAYMENTSTATUS
N
CLEARINGSTATUS
N
PAID
N
Y
SETTLEMENT­METHOD
N
SETTLEMENTSTA­TUS
N
SETTLEMENTAT
N
CHEQUEDATE
N
Y
CHEQUENUMBER
N
Y
CHEQUECUR­RENCY
N
Y
CHEQUEAMOUNT
N
Y
DRAWEEBANK­CODE
N
Y
DRAWEE­BRANCHNAME
N
Y
PAYMEN­TREMARKS
N
Y
PAYMENTTYPE
N
THIRDPARTYAD­DRESS
N
Y
THIRDPARTYAD­DRESSLINE1
N
Y
THIRDPARTYAD­DRESSLINE2
N
Y
THIRDPARTYAD­DRESSLINE3
N
Y
THIRDPARTYAD­DRESSLINE4
N
Y
THIRDPARTYBIC­CODE
N
Y
THIRDPARTY­COUNTRYCODE
N
Y
THIRDPARTYPAY­MENTREFER­ENCE
N
Y
THIRDPARTYS­TATE
N
Y
THIRDPARTY­USSTATE
N
Y
THIRDPARTYZIP­CODE
N
Y
TRANSFERAC­COUNTCUR­RENCY
N
Complete transfer details can be updated if there are no existing transfer details & mode of payment is transfer or existing transfer details to be changed to new transfer details
TRANSFERAC­COUNTHOLDER­NAME
N
N
Y
TRANSFERAC­COUNTTYPE
N
Y
TRANSFER­BRANCHCODE
N
Y
TRANSFERREF­ERENCENUMBER
N
Y
CREDITCAR­DREFNO
N
Y
INKINDPAYMENT­DETAILS
N
Y
PAYMENTAD­DRESSDETAILS
N
Y
OLDPAYMEN­TREFERENCENO
N
UHBICCODE
N
Y
SWIFTFORMAT
N
Y
BANKCHARGED
N
Y
BENEFICIARY
N
Y
BENEFICIARY­ADD1
N
Y
BENEFICIARY­ADD2
N
Y
BENEFICIARY­ADD3
N
Y
BENEFICIARYBIC­CODE
N
Y
BENEFICIAR­YACCTNO
N
Y
BENEFICIARY­CODE
N
Y
BENEFICIARY­INFO
N
Y
INTERMEDIARY
N
Y
INTERMEDIARY­ADD1
N
Y
INTERMEDIARY­ADD2
N
Y
INTERMEDIARY­ADD3
N
Y
N
Y
INTERMEDIAR­YACCTNO
N
Y
INTERMEDIARY­CODE
N
Y
INTERMEDIARY­INFO
N
Y
FURTHERCREDIT­NAME
N
Y
N
Y
REFERENCE1
N
Y
REFERENCE2
N
Y
ENTITYID
N
Y
ENTITYTYPE
N
Y
IBAN
N
Y
BENEFICIARY­IBAN
N
Y
INTERMEDIARY­IBAN
N
Y
BENEFICIARYID
N
Y
BENEFI­CIARYPERCENT­AGE
N
Y
AMOUNTBLOC­KNO
N
SETTLED
N
Y
REVERSED
N
Y
Segment ID - 03AIF
Column Name
Remarks
SEGMENTID
Y
03AIF
TXNSERIALNUM­BER
Y
Unique
SEQUENCENUM­BER
Y
Unique
PROCESSID
Y
Unique
BULKCLIENT­CODE
Y
Unique
IMPORTFILENAME
Y
Unique
AMCID
N
TRANSACTION­NUMBER
N
REFERENCENUM­BER
N
OTHERINFO1
N
Y
OTHERINFO2
N
Y
OTHERINFO3
N
Y
OTHERINFO4
N
Y
OTHERINFO5
N
Y
OTHERINFO6
N
Y
OTHERINFO7
N
Y
OTHERINFO8
N
Y
OTHERINFO9
N
Y
OTHERINFO10
N
Y
OTHERINFO11
N
Y
OTHERINFO12
N
Y
OTHERINFO13
N
Y
OTHERINFO14
N
Y
OTHERINFO15
N
Y
OTHERINFO16
N
Y
OTHERINFO17
N
Y
OTHERINFO18
N
Y
OTHERINFO19
N
Y
OTHERINFO20
N
Y
OTHERINFO21
N
Y
OTHERINFO22
N
Y
OTHERINFO23
N
Y
OTHERINFO24
N
Y
OTHERINFO25
N
Y
OTHERINFO26
N
Y
OTHERINFO27
N
Y
OTHERINFO28
N
Y
OTHERINFO29
N
Y
OTHERINFO30
N
Y
Segment ID - 04INT
Column Name
Remarks
SEGMENTID
Y
Segment ID - 04INT
PROCESSID
Y
Unique
TXNSERIALNUM­BER
Y
Unique
SEQUENCENUM­BER
Y
Unique
ENTITYID
Y
Y
If this field is popu­lated along with dependant fields, this will replace entity at transaction level
ENTITYTYPE
Y
Y
SPLITPERCENT­AGE
N
Y
FROMORTOLEG
N
Y
Segment ID - 09LOD
Column Name
Remarks
SEGMENTID
Y
09LOD
PROCESSID
Y
Unique
SEQUENCENUM­BER
Y
Unique
TXNSERIALNUM­BER
Y
Unique
LOADID
Y
FUNDID
N
CHANGETYPE
N
Y
CHANGEVALUE
N
Y
GROUPID
N
If not provided, sys­tem will consider this as DEFGRP
Segment ID - 10DLO
Column Name
Remarks
SEGMENTID
Y
10DLO
PROCESSID
Y
Unique
SEQUENCENUM­BER
Y
Unique
TXNSERIALNUM­BER
Y
Unique
DERIVEDLOADID
Y
FUNDID
N
CHANGETYPE
N
Y
CHANGEVALUE
N
Y
PARENTLOADID
N
Segment ID - 12PSL
Column Name
Remarks
SEGMENTID
Y
12PSL
PROCESSID
Y
Unique
SEQUENCENUM­BER
Y
Unique
TXNSERIALNUM­BER
Y
Unique
REFERENCENUM­BER
Y
LOADID
Y
FUNDID
N
CHANGETYPE
N
Y
CHANGEVALUE
N
Y
GROUPID
N
Segment ID - 13PSD
Column Name
Remarks
SEGMENTID
Y
13PSD
PROCESSID
Y
Unique
SEQUENCENUM­BER
Y
Unique
TXNSERIALNUM­BER
Y
Unique
REFERENCENUM­BER
Y
DERIVEDLOADID
Y
FUNDID
N
CHANGETYPE
N
Y
DER­CHANGEVALUE
N
Y
PARENTLOADID
N
