Storage Expansion Module Monitoring
Low Disk Space Warning
The OCSBC can initiate an alarm and an SNMP trap when a volume reaches a configured threshold of remaining free disk space, configured as a percentage of volume. You can configure multiple alarms, each with increasing severity that indicate less free disk space.
Low Disk Space Threshold Alarm
The low disk space threshold alarm is configured in alarm threshold configuration element. It is non-health affecting. The threshold alarm appears as follows:
SYSTEM# display-alarms
1 alarms to show
ID Task Severity First Occurred Last Occurred
131142 547896076 4 2009-08-25 13:36:26 2009-08-25 13:36:26
Count Description
1 Volume /misc space used 81% is over major threshold of 80%.
Low Disk Space Threshold SNMP Trap
For any threshold reached, an SNMP trap will be sent to all configured trap-receivers. The apSysMgmtStorageSpaceAvailThresholdTrap trap contains the following information:
- VolumeName—name of the volume where a threshold was exceeded
- CurrentValue—current percentage of disk space value that is exceeding one of the thresholds.
- MinorThreshold—configured minor threshold for this volume, if none then this is 0.
- MajorThreshold—configured major threshold for this volume, if none then this is 0.
- CriticalThreshold—configured critical threshold for this volume, if none then this is 0.
Local CDR File Delete Warning
You can configure the OCSBC to initiate an alarm and send an SNMP trap when the oldest local CDR file was deleted under fault conditions. This feature is enabled with the file delete alarm parameter.
The OCSBC deletes a local CDR file in the following three cases:
Querying Storage Space
You can monitor currently used and remaining storage space on the Storage Expansion Module by ACLI, SNMP MIB, and HDR collection group.
ACLI
To view the total disk space used percentage remaining with the ACLI, use the show space hard-drive command. For example:
SYSTEM# show space hard-disk
/sys: 19695716352/19695749120 bytes (99%) remaining
/local: 19693335040/19693367808 bytes (99%) remaining
/logs: 19693335040/19693367808 bytes (99%) remaining
/misc: 19693335040/19693367808 bytes (99%) remaining
SYSTEM#
The check-space-remaining hard-disk command is identical to the show space hard-disk command.Unmounting The Storage Expansion Module
This section explains the ACLI unmount hard-disk command, which—as its name indicates—unmounts the storage expansion module. This command should only be run when you plan to shut down the system. You issue this command to ensure the integrity of the disk when you power off the Oracle Communications Session Border Controller using the power switch. If you do not run the command and use the power switch to power down the system, the Oracle Communications Session Border Controller runs a checkdisk on the module the next time the system boots. The checkdisk lasts one to two minutes.
Note that once you run the unmount hard-disk command, any application configuration set to use a module partition will no longer work. The only way to regain access is to reboot or power cycle the system.
ACLI Instructions and Examples
To ensure the storage expansion module’s integrity when powering down the system (using the power switch), use the unmount hard-disk command:
ORACLE# unmount hard-disk
SNMP MIB
The following MIB Objects are available to query the amount of remaining drive space.
| Name | OID | MIB | Description |
| apSysStorageSpaceTable | 1.3.6.1.4.1.9148.3.2.1.1.23 | APSYSMGMT-MIB | The total percentage space available on the drive/partitions. |
apSysStorageSpaceTable OBJECT-TYPE
SYNTAX SEQUENCE OF ApSysStorageSpaceEntry
MAX-ACCESS not-accessible
STATUS current
DESCRIPTION
"A table to hold the total space and available space
per volume arranged into rows, and indexed by the
volume name.
These are all read only."
::= { apSysMgmtMIBGeneralObjects 23 }
apSysStorageSpaceEntry OBJECT-TYPE
SYNTAX ApSysStorageSpaceEntry
STATUS current
DESCRIPTION
"A table entry designed to hold storage space data, on a
single volume"
INDEX { apSysVolumeName }
::= { apSysStorageSpaceTable 1 }
ApSysStorageSpaceEntry ::= SEQUENCE {
apSysVolumeName DisplayString,
apSysVolumeTotalSpace Unsigned32,
apSysVolumeAvailSpace Unsigned32,
apSysVolumeName OBJECT-TYPE
SYNTAX DisplayString (SIZE (0..255))
MAX-ACCESS read-only
STATUS obsolete
DESCRIPTION
"The name of the volume"
::= {apSysStorageSpaceEntry 1}
apSysVolumeTotalSpace OBJECT-TYPE
SYNTAX Unsigned32
STATUS obsolete
DESCRIPTION
"The total size of the volume, in bytes"
::= {apSysStorageSpaceEntry 2}
apSysVolumeAvailSpace OBJECT-TYPE
SYNTAX Unsigned32
STATUS obsolete
DESCRIPTION
"The total space available on the volume, in bytes"
::= {apSysStorageSpaceEntry 3}
HDR
Historical Data Record statistics are available that track the amount of storage space available on each Storage Expansion Module partition. At each collect interval, space consumption statistics are gathered for every partition. The Storage Space collect group, configured as space, contains these statistics. The contents of this Storage Space group are:
- TimeStamp
- Partition
- Space used
- Space available
