Acme-Packet-Specific-Extension-Rf AVP
The Oracle Acme-Packet-Specific-Extension-Rf AVP uses vendor ID 9148. The following section includes the ACME AVP descriptions.
| AVP | ACME Diameter Attribute | Start | Interim | Stop | Event | AVP Type |
| Ingress-Realm | 2 | Y 1 | Y | Y | N | UTF8String |
| Egress-Realm | 3 | Y | Y | Y | N | UTF8String |
| Ingress-TGRP | 4 | Y | Y | Y | N | UTF8String |
| Egress-TGRP | 5 | Y | Y | Y | N | UTF8String |
| Ingress-Trunk-Context | 6 | Y | Y | Y | N | UTF8String |
| Egress-Trunk-Context | 7 | N | Y | Y | N | UTF8String |
| Ingress-Local-Signaling-Address | 8 | Y | Y | Y | N | UTF8String |
| Ingress-Remote-Signaling-Address | 9 | Y | Y | Y | N | UTF8String |
| Egress-Local-Signaling-Address | 10 | Y | Y | Y | N | UTF8String |
| Egress-Remote-Signaling-Address | 11 | Y | Y | Y | N | UTF8String |
| Ingress-Local-Media-Address | 12 | Y | Y | Y | N | UTF8String |
| Ingress-Remote-Media-Address | 13 | Y | Y | Y | N | UTF8String |
| Egress-Local-Media-Address | 14 | Y | Y | Y | N | UTF8String |
| Egress-Remote-Media-Address | 15 | Y | Y | Y | N | UTF8String |
| NAS-Port | 16 | Y | Y | Y | N | Unsigned32 |
| Acme-Session-Ingress-CallID | 17 | Y | Y | Y | N | UTF8String |
| Acme-Session-Egress-CallID | 18 | Y | Y | Y | N | UTF8String |
| Acme-Session-Protocol-Type | 19 | Y | Y | Y | N | UTF8String |
| Acme-FlowID-FS1-F | 20 | Y | Y | Y | N | UTF8String |
| Acme-FlowType-FS1-F | 21 | Y | Y | Y | N | UTF8String |
| Ingress-Local-Media-Port | 22 | Y | Y | Y | N | Unsigned32 |
| Ingress-Remote-Media-Port | 23 | Y | Y | Y | N | Unsigned32 |
| Egress-Local-Media-Port | 24 | Y | Y | Y | N | Unsigned32 |
| Egress-Remote-Media-Port | 25 | Y | Y | Y | N | Unsigned32 |
| Acme-Session-Charging-Function-Address | 26 | Y | Y | Y | N | UTF8String |
| Acme-Local-Timezone | 27 | Y | Y | Y | N | UTF8String |
| Acme-Post-Dial-Delay | 28 | Y | Y | Y | N | Unsigned32 |
| Acme-SIP-Diversion | 29 | Y | Y | Y | N | UTF8String |
| Acme-Session-Disposition | 30 | N | N | Y | N | Unsigned32 |
| Disconnect-Initiator | 31 | N | N | Y | N | Unsigned32 |
| Terminate-Cause | 32 | N | N | Y | N | Unsigned32 |
| Acme-Session-Disconnect-Cause | 33 | N | N | Y | N | Unsigned32 |
| Acme-SIP-Status | 34 | N | N | Y | N | Integer32 |
| Acme-FlowType-FS1-R | 35 | N | Y | Y | N | UTF8String |
| Acme-Packet-Specific-Rf-QoS | 37 | N | N | Y | N | Grouped |
| RTP Calling Octets FS1 | 38 | N | N | Y | N | Unsigned32 |
| RTP Calling Octets FS1 | 39 | N | N | Y | N | Unsigned32 |
| RTP Calling Packets FS1 | 40 | N | N | Y | N | Unsigned32 |
| RTP Calling Packets FS2 | 41 | N | N | Y | N | Unsigned32 |
| RTP Calling Octets Transmitted FS1 | 42 | N | N | Y | N | Unsigned32 |
| RTP Calling Octets Transmitted FS2 | 43 | N | N | Y | N | Unsigned32 |
| RTP Called Packets Transmitted FS1 | 44 | N | N | Y | N | Unsigned32 |
| RTP Called Packets Transmitted FS2 | 45 | N | N | Y | N | Unsigned32 |
| RTP Calling Packets Lost FS1 | 46 | N | N | Y | N | Unsigned32 |
| RTP Calling Packets Lost FS2 | 47 | N | N | Y | N | Unsigned32 |
| RTP Calling Avg Jitter FS1 | 48 | N | N | Y | N | Unsigned32 |
| RTP Calling Avg Jitter FS2 | 49 | N | N | Y | N | Unsigned32 |
| RTP Calling Max Jitter FS1 | 50 | N | N | Y | N | Unsigned32 |
| RTP Calling Max Jitter FS2 | 51 | N | N | Y | N | Unsigned32 |
| RTCP Calling Packets Lost FS1 | 52 | N | N | Y | N | Unsigned32 |
| RTCP Calling Packets Lost FS2 | 53 | N | N | Y | N | Unsigned32 |
| RTCP Calling Avg Jitter FS1 | 54 | N | N | Y | N | Unsigned32 |
| RTCP Calling Avg Jitter FS2 | 55 | N | N | Y | N | Unsigned32 |
| RTCP Calling Avg Latency FS1 | 56 | N | N | Y | N | Unsigned32 |
| RTCP Calling Avg Latency FS2 | 57 | N | N | Y | N | Unsigned32 |
| RTCP Calling Max Jitter FS1 | 58 | N | N | Y | N | Unsigned32 |
| RTCP Calling Max Jitter FS2 | 59 | N | N | Y | N | Unsigned32 |
| RTCP Calling Max Latency FS1 | 60 | N | N | Y | N | Unsigned32 |
| RTCP Calling Max Latency FS2 | 61 | N | N | Y | N | Unsigned32 |
| RTP Called Octets FS1 | 62 | N | N | Y | N | Unsigned32 |
| RTP Called Octets FS2 | 63 | N | N | Y | N | Unsigned32 |
| RTP Called Packets FS1 | 64 | N | N | Y | N | Unsigned32 |
| RTP Called Packets FS2 | 65 | N | N | Y | N | Unsigned32 |
| RTP Called Octets Transmitted FS1 | 66 | N | N | Y | N | Unsigned32 |
| RTP Called Octets Transmitted FS2 | 67 | N | N | Y | N | Unsigned32 |
| RTP Called Packet Transmitted FS1 | 68 | N | N | Y | N | Unsigned32 |
| RTP Called Packet Transmitted FS2 | 69 | N | N | Y | N | Unsigned32 |
| RTP Called Packets Lost FS1 | 70 | N | N | Y | N | Unsigned32 |
| RTP Called Packets Lost FS2 | 71 | N | N | Y | N | Unsigned32 |
| RTP Called Avg Jitter FS1 | 72 | N | N | Y | N | Unsigned32 |
| RTP Called Avg Jitter FS2 | 73 | N | N | Y | N | Unsigned32 |
| RTP Called Max Jitter FS1 | 74 | N | N | Y | N | Unsigned32 |
| RTP Called Max Jitter FS2 | 75 | N | N | Y | N | Unsigned32 |
| RTCP Called Packets Lost FS1 | 76 | N | N | Y | N | Unsigned32 |
| RTCP Called Packets Lost FS2 | 77 | N | N | Y | N | Unsigned32 |
| RTCP Called Avg Jitter FS1 | 78 | N | N | Y | N | Unsigned32 |
| RTCP Called Avg Jitter FS2 | 79 | N | N | Y | N | Unsigned32 |
| RTCP Called Avg Latency FS1 | 80 | N | N | Y | N | Unsigned32 |
| RTCP Called Avg Latency FS2 | 81 | N | N | Y | N | Unsigned32 |
| RTCP Called Max Jitter FS1 | 82 | N | N | Y | N | Unsigned32 |
| RTCP Max Jitter FS2 | 83 | N | N | Y | N | Unsigned32 |
| RTCP Called Max Latency FS1 | 84 | N | N | Y | N | Unsigned32 |
| RTCP Called Max Latency FS2 | 85 | N | N | Y | N | Unsigned32 |
AVP Definitions
The following table lists and briefly describes the Acme-Packet-Specific-Extension-Rf AVPs.
| AVP | Definition |
| Ingress-Realm | realm of origination |
| Egress-Realm | realm of termination |
| Ingress-TGRP | TGRP received |
| Egress-TGRP | TGRP sent |
| Ingress-Trunk-Context | trunk context received |
| Egress-Trunk-Context | trunk context sent |
| Ingress-Local-Signaling-Address | Signaling address of P-CSCF that received the request from the remote element |
| Ingress-Remote-Signaling-Address | Signaling address of the remote element that sent the request to the P-CSCF |
| Egress-Local-Signaling-Address | Signaling address of P-CSCF that sent the request to the remote element |
| Egress-Remote-Signaling-Address | signaling address of the remote element that received the request from the P-CSCF |
| Ingress-Local-Media-Address | media address of P-CSCF on the originating side |
| Ingress-Remote-Media-Address | media address of the remote element on the originating side |
| Egress-Local-Media-Address | media address of P-CSCF on the terminating side |
| Egress-Remote-Media-Address | media address of the remote element on the terminating side |
| NAS-Port | SIP proxy port or the H.323 stack’s call signaling RAS port. |
| Acme-Session-Ingress-CallID | Call ID generated by the originating device. |
| Acme-Session-Egress-CallID | Call ID generated by the OCSBC to represent a two-way transaction. |
| Acme-Session-Protocol-Type | Signaling protocol used for a particular leg of a session (in the case of IWF, there may be two legs). This attribute contains the signaling protocol type; for example, SIP or H323. |
| Acme-FlowID-FS1-F | Unique identifier for every media flow processed by the OCSBC, flow-set 1 forward direction. |
| Acme-FlowType-FS1-F | Codec that describes the flow, flow-set 1 forward direction: PCMU, PCMA, G726, G723, G728, G729, H261, H263, T38. |
| Ingress-Local-Media-Port | Ingress port portion of address of P-CSCF on the originating side |
| Ingress-Remote-Media-Port | Ingress port portion of media address of the remote element on the originating side |
| Egress-Local-Media-Port | Egress port portion of address of P-CSCF on the terminating side |
| Egress-Remote-Media-Port | Egress port portion of media address of the remote element on the terminating side |
| Acme-Session-Charging-Function-Address | The latest cached copy or the configured ccf-address. |
| Acme-Local-Timezone | Local GMT/UTC time zone that is provisioned on the OCSBC. |
| Acme-Post-Dial-Delay | Amount of time between session initiation and an alerting event. |
| Acme-SIP-Diversion | SIP Diversion header; communicates to the called party from whom and why a call diverted. |
| Acme-Session-Disposition | Status of the call attempt as it progresses from being initiated (using a SIP INVITE or H.323 Setup message) to being either answered or failing to be answered. |
| Disconnect-Initiator | Initiator of a call disconnect. |
| Terminate-Cause | Reason for session ending (refer to Session Termination session). |
| Acme-Session-Disconnect-Cause | Q.850 cause code value. |
| Acme-SIP-Status | SIP status code for RFC 3326 support. |
| Acme-FlowType-FS1-R | Codec that describes the flow, flow-set 1 reverse direction: PCMU, PCMA, G726, G723, G728, G729, H261, H263, T38. |
| RTP-Calling-Octets-FS1 | RTP total calling octets for stream 1 |
| RTP-Calling-Octets-FS2 | RTP total calling octets for stream 2 |
| RTP-Calling-Packets-FS1 | RTP total calling packets for stream 1 |
| RTP-Calling-Packets-FS2 | RTP total calling packets for stream 2 |
| RTP-Calling-Octets-Transmitted-FS1 | RTP calling octets transmitted for stream 1 |
| RTP-Calling-Octets-Transmitted-FS2 | RTP calling octets transmitted for stream 2 |
| RTP-Calling-Packet-Transmitted-FS1 | RTP calling packets transmitted for stream 1 |
| RTP-Calling-Packet-Transmitted-FS2 | RTP calling packets transmitted for stream 2 |
| RTP-Calling-Packets-Lost-FS1 | RTP calling packets lost for stream 1 |
| RTP-Calling-Packets-Lost-FS2 | RTP calling packets lost for stream 2 |
| RTP-Calling-Avg-Jitter-FS1 | RTP calling average jitter rate for stream 1 |
| RTP-Calling-Avg-Jitter-FS2 | RTP calling average jitter rate for stream 2 |
| RTP-Calling-Max-Jitter-FS1 | RTP calling maximum jitter rate for stream 1 |
| RTP-Calling-Max-Jitter-FS2 | RTP calling maximum jitter rate for stream 1 |
| RTCP-Calling-Packets-Lost-FS1 | RTCP calling packet lost rate for stream 1 |
| RTCP-Calling-Packets-Lost-FS2 | RTCP calling packet lost rate for stream 2 |
| RTCP-Calling-Avg-Jitter-FS1 | RTCP calling average jitter rate for stream 1 |
| RTCP-Calling-Avg-Jitter-FS2 | RTCP calling average jitter rate for stream 2 |
| RTCP-Calling-Max-Jitter-FS1 | RTCP calling maximum jitter rate for stream 1 |
| RTCP-Calling-Max-Jitter-FS2 | RTCP calling maximum jitter rate for stream 2 |
| RTCP-Calling-Max-Latency-FS1 | RTCP calling maximum latency rate for stream 1 |
| RTCP-Calling-Max-Latency-FS2 | RTCP calling maximum latency rate for stream 2 |
| RTP-Called-Octets-FS1 | RTP called total octets for stream 1 |
| RTP-Called-Octets-FS2 | RTP called total octets for stream 2 |
| RTP-Called-Packets-FS1 | RTP called total packets for stream 1 |
| RTP-Called-Packets-FS2 | RTP called total packets for stream 2 |
| RTP-Called-Octets-Transmitted-FS1 | RTP called octets transmitted for stream 1 |
| RTP-Called-Octets-Transmitted-FS2 | RTP called octets transmitted for stream 2 |
| RTP-Called-Packets-Transmitted-FS1 | RTP called packets transmitted for stream 1 |
| RTP-Called-Packets-Transmitted-FS2 | RTP called packets transmitted for stream 2 |
| RTP-Called-Packets-Lost-FS1 | RTP called packets lost for stream 1 |
| RTP-Called-Packets-Lost-FS2 | RTP called packets lost for stream 2 |
| RTP-Called-Avg-Jitter-FS1 | RTP called average jitter for stream 1 |
| RTP-Called-Avg-Jitter-FS2 | RTP called average jitter for stream 2 |
| RTP-Called-Max-Jitter-FS1 | RTP called maximum jitter for stream 1 |
| RTP-Called-Max-Jitter-FS2 | RTP called maximum jitter for stream 2 |
| RTCP-Called-Packets-Lost-FS1 | RTCP called packets lost for stream 1 |
| RTCP-Called-Packets-Lost-FS2 | RTCP called packets lost for stream 2 |
| RTCP-Called-Avg-Jitter-FS1 | RTCP called average jitter for stream 1 |
| RTCP-Called-Avg-Jitter-FS2 | RTCP called average jitter for stream 2 |
| RTCP-Called-Avg-Latency-FS1 | RTCP called average latency for stream 1 |
| RTCP-Called-Avg-Latency-FS2 | RTCP called average latency for stream 2 |
| RTCP-Called-Max-Jitter-FS1 | RTCP called maximum jitter for stream 1 |
| RTCP-Called-Max-Jitter-FS2 | RTCP called maximum jitter for stream 2 |
| RTCP-Called-Max-Latency-FS1 | RTCP called maximum latency for stream 1 |
| RTCP-Called-Max-Latency-FS1 | RTCP called maximum latency for stream 2 |
