Configurable Intermediate Period
You can set how often the OCSBC generates periodic interim records for H.323 and for SIP.
- H.323—The periodic timer (set to the value you specify in the accounting configuration) is dynamically created when the OCSBC receives a Connect message and an H.323 call answer method is invoked. The OCSBC deletes the timer when the H.323 session is terminated.
- SIP—The periodic timer (set to the value you specify in the accounting configuration) is dynamically created when the
OCSBC receives an initial INVITE message. The
OCSBC deletes the timer when the session is terminated.
To set the timer for periodic interim records:
