Configuring Diameter-based Accounting
Diameter-based Rf accounting relies on many of the same configuration elements used for RADIUS based accounting. The following two sections explain how to configure both the account-config and account-servers configuration elements. In addition, you must ensure that accounting is enabled for each realm where you want it to occur. The accounting-enable parameter in the realm-config is enabled by default.
Configure the Global Diameter-based Accounting (Rf) Features
To configure the global Diameter-based accounting (Rf) features in the account-config:
In Superuser mode,
type
configure
terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter.
ORACLE(configure)# session-router
Type
account-config
and press Enter.
ORACLE(session-router)# account-config ORACLE(account-config)#
- hostname—Enter a hostname for this system.
port—Enter 3868 for
the RFC-recommended Diameter port number. You may enter a different port
number.
minimum: 1025
maximum: 65535
strategy—Set the
strategy used to select the accounting server which the
OCSBC sends accounting
messages. The following are the available strategies:
- hunt—Selects accounting servers in the order in which they are listed. If the first accounting server is online, working, and has not exceeded any of the defined constraints, all traffic is sent to it. Otherwise the second accounting server is selected. If the first and second accounting servers are offline or exceed any defined constraints, the third accounting server is selected. And so on through the entire list of configured servers
- failover—Uses the first server in the list of predefined accounting servers until a failure is received from that server. Once a failure is received, it moves to the second accounting server in the list until a failure is received. And so on through the entire list of configured servers.
- round robin—Selects each accounting server in order, distributing the selection of each accounting server evenly over time.
- fastest round trip time—Selects the accounting server that has the fastest round trip time (RTT) observed during transactions with the servers (sending a record and receiving an ACK).
- fewest pending—Selects the accounting server that has the fewest number of unacknowledged accounting messages (that are in transit to the OCSBC).
- protocol—Set this parameter to diameter to use the Rf accounting interface with a Diameter-based accounting server.
- state— Enter enabled to use accounting on this system.
max-msg-delay—Retain
the default value of
60 seconds or
indicate the length of time in seconds that you want the
OCSBC to continue trying
to send each accounting message. During this delay, the
OCSBC can hold a generic
queue of 4096 messages.
Minimum: zero (0)
Maximum: 4294967295
acr-retry-interval
— Retain the default value of
10 seconds or enter
the time in seconds for the
OCSBC to wait before
resending an ACR for a session.
Minimum: 5
Maximum: 20
max-acr-retries
— Retain the default value of zero (0) or enter the
maximum number of times that the
OCSBC can resend an ACR
for a session.
Minimum: zero (0)
Maximum: 4
max-wait-failover—Retain
100 messages or
indicate the maximum number of accounting messages the
OCSBC can store its
message waiting queue for a specific accounting server, before it is considered
a failover situation.
Once this value is exceeded, the OCSBC attempts to send it accounting messages, including its pending messages, to the next accounting server in its configured list.
Minimum: one (1) message
Maximum: 4096 messages
trans-at-close—Retain
disabled if you do
not want to defer the transmission of message information to the close of a
session. Enter
enabled if you want
to defer message transmission.
disabled—The OCSBC transmits accounting information at the start of a session (Start), during the session (Interim), and at the close of a session (Stop). The transmitted accounting information for a single session might span a period of hours and be spread out among different storage files.
enabled—Limits the number of files on the OCSBC used to store the accounting message information for one session. It is easiest to store the accounting information from a single session in a single storage file.
generate-start—Retain
the default value
ok if you want the
ACR Start message to be generated once the
OCSBC receives an OK
message in response to an INVITE.
Other options include:
none—Accounting Start message should not be generated.
invite—Accounting Start message should be generated once the OCSBC receives a SIP INVITE.
generate-interim—Retain
the default value
reinvite-response to
cause the
OCSBC to send an Interim
charging message to the accounting server.
You can select none, one, or more than one of the following values:
- ok—Start message is generated when the OCSBC receives an OK message in response to an INVITE.
- reinvite—Interim message is generated when the OCSBC receives a SIP session reINVITE message.
- reinvite-response (default)—Interim message is generated when the OCSBC receives a SIP session reINVITE and responds to it (for example, session connection or failure).
- reinvite-cancel—Interim message is generated when the OCSBC receives a SIP session reINVITE, and the Reinvite is cancelled before the OCSBC responds to it.
- unsuccessful-attempt—Interim message is generated when a SIP session set-up attempt from a preference-ordered list of next-hop destinations is unsuccessful. This can happen when a local policy lookup, LRT lookup, ENUM query response, or SIP redirect returns a preference-ordered list of next-hop destinations. The interim message contains: the destination IP address, the disconnect reason, a timestamp for the failure, and the number that was called.
- intermediate-period—Enter amount of time in seconds between generating periodic interim ACR messages during a SIP call. This parameter defaults to zero, which disables continuous Interim charging messages.
- vsa-id-range—Ensure that this parameter is left blank when communicating with a Diameter-based Rf accounting server.
- generate-event—Enter one or more valid events that prompt creation of an Event record. Current valid values are register and local-register. Multiple values are entered enclosed in parenthesis and separated by spaces.
- Save your work.
Configure Accounting Servers
You must create one or more servers to which the OCSBC can send accounting messages.
Continuing from the previous account-config configuration, enter the account server sub-element by typing
account-servers Enter.
AZALEA(account-config)# account-servers AZALEA(account-server)# - hostname—Set this to the IP address of the Diameter-based Rf accounting server.
port—Enter 3868 for the RFC-recommended Diameter port number. You may enter a different port number if desired.
minimum: 1025
maximum: 65535
- state—Retain the default enabled to enable this account server or enter disabled to disable it.
min-round-trip—Retain the default 250 milliseconds or indicate the minimum round trip time of an accounting message.
minimum: 10 milliseconds
maximum: 5000 milliseconds
A round trip consists of the following:
The OCSBC sends an accounting message to the account server.
The account server processes this message and responds back to the OCSBC.
If the fastest RTT is the strategy for the account configuration, the value you enter here can be used to determine an order of preference (if all the configured account servers are responding in less than their minimum RTT).
max-inactivity—Retain the default 60 seconds or indicate the length of time in seconds that you want the
OCSBC with pending accounting messages to wait when it has not received a valid response from the target account server.
minimum: 1 second
maximum: 300 seconds
Once this timer value is exceeded, the OCSBC marks the unresponsive account server as disabled in its failover scheme. When a server connection is marked as inactive, the OCSBC attempts to restart the connection and transfers pending messages to another queue for transmission. Accounting messages might be moved between different account servers as servers become inactive or disabled. -
restart-delay—Retain the default 30 seconds or indicate the length of time in seconds you want the
OCSBC to wait before resending messages to a disabled account server.
minimum: 1 second
- priority—Enter the number corresponding to the priority of this account server, for use with server prioritization. The default for this parameter is 0, meaning the prioritization feature is turned off—and that the OCSBC will therefore prioritize accounting servers by IP address and port.
- origin-realm—Enter the realm in which the OCSBC communicates with the Diameter Rf accounting server.
- domain-name-suffix—Enter the suffix to be appended to any Diameter FQDN or Diameter Identity used when the OCSBC communicates with the Diameter Rf accounting server. Your value can be any string, to which the OCSBC will prepend with a dot.
- watchdog-ka-timer—Set this parameter to the value in seconds that the OCSBC waits between sending DWRs. 0 disables this feature. Valid non-zero values are 6 - 65535
- Save your work.
