CDR File Transfer Failure Alarm
The OCSBC sends out traps and triggers corresponding alarms when it encounters failure when attempting to transfer locally stored CDR files via FTP or SFTP. One set of traps is used for instances when one CDR push receiver fails; another is used when all enabled CDR receivers fail. They are part of the apSysMgmtCDRPushReceiverNotificationsGroup.
All of the traps contain information about the type of push receiver, the address of the push receiver, and the failure reason code.
The trap and corresponding clearing trap for single push receiver failure are:
- apSysMgmtCDRPushReceiverFailureTrap
- apSysMgmtCDRPushReceiverFailureClearTrap
The trap and corresponding clearing trap for global push receiver failure are:
- apSysMgmtCDRAllPushReceiversFailureTrap
- apSysMgmtCDRAllPushReceiverFailuresClearTrap
